running Windows 10 Pro 22H2 and using j-link v9
i tried to read firmware from nrf51822-QFAB by using "nrfjprog --readcode dump_nRF51822.hex", but it gave me an error -102:
C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin>nrfjprog.exe -r
[error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 187 milliseconds with result -102
ERROR: Unable to connect to a debugger.
[error] [ Worker] - An unknown error.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
All drivers installed
Running latest version of nRF command-tools 10.24.2 for Windows x64
j-link is connected to SWCLK and SWDIO pins correctly
nRF51822-QFAB uses external power and microcontroller itself works correctly
here is the log.log file for better information:
[2024-Aug-20 22:21:45] [debug] --------------------------------------------------------------------------------
[2024-Aug-20 22:21:45] [debug] nrfjprog --readcode dump_nRF51822.hex --log
[2024-Aug-20 22:21:45] [debug] nrfjprog version 10.24.2 external
[2024-Aug-20 22:21:45] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2024-Aug-20 22:21:45] [ info] Library loaded, loading member functions.
[2024-Aug-20 22:21:45] [ info] Member functions succesfully loaded.
[2024-Aug-20 22:21:45] [debug] [ Client] - open
[2024-Aug-20 22:21:45] [debug] [ Client] - start
[2024-Aug-20 22:21:45] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence fc13b9d6-179c-4b57-b51d-9f8b7e1818d8.
[2024-Aug-20 22:21:45] [trace] [ Client] - Command open executed for 34 milliseconds with result 0
[2024-Aug-20 22:21:45] [debug] [ Client] - config
[2024-Aug-20 22:21:45] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
[2024-Aug-20 22:21:45] [debug] [ Client] - enum_emu_snr
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2024-Aug-20 22:21:45] [debug] [ JLink] - Logger sink registered in JLink logger
[2024-Aug-20 22:21:45] [debug] [ nRFXX] - open
[2024-Aug-20 22:21:45] [debug] [ nRFXX] - just_check_family
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - open_dll
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2024-Aug-20 22:21:45] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V794e\JLink_x64.dll.
[2024-Aug-20 22:21:45] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2024-Aug-20 22:21:45] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - Set batch mode
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - dll_version
[2024-Aug-20 22:21:45] [ info] [SeggerBackend] - Segger dll version 7.94.e loaded.
[2024-Aug-20 22:21:45] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
[2024-Aug-20 22:21:45] [debug] [ nRFXX] - config
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - enum_emu_snr
[2024-Aug-20 22:21:45] [trace] [ Worker] - Command config executed for 3 milliseconds with result 0
[2024-Aug-20 22:21:45] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
[2024-Aug-20 22:21:45] [debug] [ Client] - connect_to_emu_with_snr
[2024-Aug-20 22:21:45] [debug] [ nRFXX] - enum_emu_con_info
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - is_connected_to_emu
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - enum_emu_con_info
[2024-Aug-20 22:21:45] [trace] [ Worker] - Command enum_emu_con_info executed for 1 milliseconds with result 0
[2024-Aug-20 22:21:45] [debug] [ nRFXX] - connect_to_emu_with_snr
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - ---just_get_num_emus
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - Segger logging enabled.
[2024-Aug-20 22:21:45] [trace] [ JLink] - Firmware: J-Link V9 compiled May 7 2021 16:26:12
[2024-Aug-20 22:21:45] [trace] [ JLink] - Decompressing FW timestamp took 117 us
[2024-Aug-20 22:21:45] [trace] [ JLink] - Hardware: V9.60
[2024-Aug-20 22:21:45] [trace] [ JLink] - S/N: 69653975
[2024-Aug-20 22:21:45] [trace] [ JLink] - OEM: SEGGER
[2024-Aug-20 22:21:45] [trace] [ JLink] - Feature(s): RDI, GDB, FlashDL, FlashBP, JFlash
[2024-Aug-20 22:21:45] [trace] [ JLink] - Bootloader: (Could not read)
[2024-Aug-20 22:21:45] [trace] [ JLink] - TELNET listener socket opened on port 19021
[2024-Aug-20 22:21:45] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2024-Aug-20 22:21:45] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
[2024-Aug-20 22:21:45] [trace] [ JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V794e\JLinkGUIServer.exe
[2024-Aug-20 22:21:45] [trace] [ JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V794e\JLinkGUIServer.exe
[2024-Aug-20 22:21:45] [trace] [ JLink] - J-Link GUI Server info: "J-Link GUI server V7.94e "
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 29.515ms returns "O.K."
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_HasError()
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_Lock()
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.001ms returns 0x01
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.000ms returns 0x00
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.002ms returns 0x00
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.010ms returns 0
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.458ms returns 0x00
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_GetSpeedInfo()
[2024-Aug-20 22:21:45] [trace] [ JLink] - 12000000 Hz / n, n >= 1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.008ms
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 12000kHz
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_SetSpeed(2000)
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.050ms
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_GetSpeed()
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.003ms returns 2000
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_GetSN()
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.005ms returns 69653975
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.004ms
[2024-Aug-20 22:21:45] [debug] [ nRFXX] - read_device_family
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_IsOpen()
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.003ms returns 0x01
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - read_debug_port_idr
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - read_debug_port_register
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - coresight_configure
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_GetHWStatus(...)
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.134ms returns 0
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 100.776ms returns 0
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.908ms returns -1
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - ---just_abort_debug_action
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.984ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.896ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.886ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.894ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.592ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.558ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.842ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.830ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.538ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.602ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.876ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.835ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.838ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.688ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.657ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.833ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.840ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.650ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.740ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.807ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.818ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.717ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.699ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.563ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.573ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.828ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.741ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.737ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.715ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.686ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.837ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.543ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.719ms returns -1
[2024-Aug-20 22:21:45] [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 187 milliseconds with result -102
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.836ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.899ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.529ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.659ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.049ms
[2024-Aug-20 22:21:45] [error] [ Worker] - An unknown error.
[2024-Aug-20 22:21:45] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 182 milliseconds with result -102
[2024-Aug-20 22:21:45] [debug] [ nRFXX] - close
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.008ms returns 0x01
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - close
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - disconnect_from_emu
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - is_connected_to_device
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_IsConnected()
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.003ms returns FALSE
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.819ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.888ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.805ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.679ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.639ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.527ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.631ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.605ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.647ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.628ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.528ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.521ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.815ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.826ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.857ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.585ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.567ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.485ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.575ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.499ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.667ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.590ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.495ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.594ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.526ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.588ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.603ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.601ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.492ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.580ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.531ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.678ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.493ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.545ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.600ms returns -1
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.534ms returns -1
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - Ignore exception An unknown error.
[2024-Aug-20 22:21:45] [trace] [ JLink] - - 0.126ms
[2024-Aug-20 22:21:45] [trace] [ JLink] - JLINK_Close()
[2024-Aug-20 22:21:45] [debug] [SeggerBackend] - Segger Backend closed.
[2024-Aug-20 22:21:45] [debug] [ nRFXX] - nRF family DLL closed
[2024-Aug-20 22:21:45] [trace] [ Worker] - Command close executed for 90 milliseconds with result 0
[2024-Aug-20 22:21:45] [trace] [ Client] - Command close executed for 108 milliseconds with result 0
[2024-Aug-20 22:21:45] [debug] [ Client] - terminate
[2024-Aug-20 22:21:45] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2024-Aug-20 22:21:45] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2024-Aug-20 22:21:45] [trace] [ Worker] - Executed 6 commands for 280 milliseconds
[2024-Aug-20 22:21:45] [debug] [ Client] - Worker process exited with code: 0
[2024-Aug-20 22:21:45] [debug] [ Client] - Child process terminated with result 0
[2024-Aug-20 22:21:45] [trace] [ Client] - Executed 6 commands for 359 milliseconds
P.S. i was able to connect to the nRF51822 once through JTAG target interface and using j-flash software.
