Im trying to use the BMA4xx driver (via i2c) in 2.7.0. The driver seems to init the device ok but I am getting a "SECURE FAULT" as soon as I do a sensor_sample_fetch. Attached is a minimal project to reproduce the issue.
[00:00:00.398,223] <dbg> bma4xx: bma4xx_chip_init: chip_id is 0x90
[00:00:00.404,815] <wrn> bma4xx: Driver tested for BMA422. Check for unintended operation.
*** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
*** Using Zephyr OS v3.6.99-100befc70c74 ***
Found bma4xx@14
[00:00:00.428,955] <err> os: ***** SECURE FAULT *****
[00:00:00.434,661] <err> os: Invalid entry point
[00:00:00.440,155] <err> os: r0/a1: 0x0001d2d8 r1/a2: 0x0000003b r2/a3: 0x00000000
[00:00:00.448,852] <err> os: r3/a4: 0x00000000 r12/ip: 0x00000004 r14/lr: 0x00019201
[00:00:00.457,550] <err> os: xpsr: 0x00000000
[00:00:00.462,768] <err> os: Faulting instruction address (r15/pc): 0x00000000
[00:00:00.470,703] <err> os: >>> ZEPHYR FATAL ERROR 38: Unknown error on CPU 0
[00:00:00.478,637] <err> os: Current thread: 0x2000c858 (main)
[00:00:00.485,137] <err> os: Halting system
CONFIG_I2C=y
CONFIG_SENSOR=y
CONFIG_SENSOR_ASYNC_API=y
CONFIG_BMA4XX=y
&i2c2 {
status = "okay";
bma4xx: bma4xx@14 {
compatible = "bosch,bma4xx";
reg = <0x14>;
const struct device *const bma400_dev = DEVICE_DT_GET_ANY(bosch_bma4xx);
SENSOR_DT_READ_IODEV(bma400_iodev, DT_COMPAT_GET_ANY_STATUS_OKAY(bosch_bma4xx),
{SENSOR_CHAN_ACCEL_XYZ, 0});
if (bma400_dev == NULL) {
printk("\nError: no device found.\n");
return -1;
if (!device_is_ready(bma400_dev)) {
printk("\nError: Device \"%s\" is not ready\n", bma400_dev->name);
return -1;
printk("Found %s\n", bma400_dev->name);
sensor_sample_fetch(bma400_dev); // <<< Crash
return 0;
