Accessing two channels of i2s
Hi,I am using NRF5340 AUDIO DK BOARD and Ihave been trying to access i2s mic and I want to transfer the mic data to Amplifier .Is it possible to do with single I2s ? As I observe nrf5340  has two channels.If it possible how to configure pins for mic and amplifier as I have been using SCK,SDIN,LRCK but if want to configure for Amplifier what pins can I use for it as it doesn't have other SCK,LRCK pins.And I want to know difference between MCK and SCK in i2s configuration,Ihave attached the i2s configuration below.
  • Amplifier needs PCM data of mic.
    Can you please provide me any sorce code how can i able to use 2 channels in I2S one mic and one for transmitting to amplifier.First confirm is nrf having two channels I2S format for config this thing
  • PCM and I2S is almost the same thing. An I2S interface will provide you a PCM stream of data. The default Audio example (ncs\nrf\applications\nrf5340_audio) should provide an example how to use both I2S to a microphone and PCM to an output stream, or to a sound device.
    Please check the nRF5340_Audio documentation.
    So e.g. the configuration of an Broadcast source should record the audio from somewhere (the microphone) using I2S, and the Broadcast sink will take that data and output it as PCM (via the I2S interface).
    Edvin
  • I mainly wanted to know how to perform getting mic data as well send data for amplification by sharing same clock of LRCK and SCK .I need how to configure that both to achieve .Will i get any source for achieving or first is it possible to achieve that live data.
  • We don't provide source code, unfortunately. You need to write the application yourself.
    If you just want to pass the data into the amplifier, is it not possible to just provide the clock signal, and wire the I2S data directly to the amplifier? Also connect it to the nRF (using the same wire split into two), so that you can just read the mic data like it is done in the sample, and the I2S' PCM stream will go directly to the amplifier as well? You would also need to wire the LRCLK to both devices.
    Are you sure the amplifier doesn't provide it's own clock signals to the microphone? I am not saying it does, but it could make sense that it does.
    BR,
    Edvin
  • I would like to explain my application here and need to confirm if I can achieve this using nrf5340
    1) We will read data from Microphone using I2S
    2) Then, We will send the same data to Amplifier which is also connected through I2S
    (This process should not have any larger delay and we need live streaming of microphone data)
    Query:
    Can this be achieved using the below connection method. If not, what should be done to use this I2S with 2 channels
    I am not sure whether it works,please confirm me that,If yes will it achieve by using i2s_buf_write will be transfer to amplifier?
    Please note: Our chosen amplifier will act only as slave and it cannot give out its own clock signals to Microphone.
