Fast pair input device sample application is not working as expected on my nrf52840 dk
I want to develop some applications on top of Google Fast Pair.
Created the fast pair input device application with the SDK version 2.7.0 rc1
and built with prj.config
# Copyright (c) 2022 Nordic Semiconductor
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
CONFIG_DK_LIBRARY=y
# Enable settings to store data in non-volatile memory
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS_NVS=y
CONFIG_SETTINGS=y
CONFIG_BT_SETTINGS=y
CONFIG_BT=y
CONFIG_BT_DEVICE_NAME="Nordic_Fast_Pair"
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_PERIPHERAL_PREF_MIN_INT=6
CONFIG_BT_PERIPHERAL_PREF_MAX_INT=6
CONFIG_BT_PERIPHERAL_PREF_LATENCY=99
CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400
# Appear as a Generic Human Interface Device
CONFIG_BT_DEVICE_APPEARANCE=960
CONFIG_BT_ADV_PROV=y
CONFIG_BT_ADV_PROV_FLAGS=y
CONFIG_BT_ADV_PROV_TX_POWER=y
CONFIG_BT_ADV_PROV_FAST_PAIR=y
CONFIG_BT_ADV_PROV_DEVICE_NAME=y
CONFIG_BT_ADV_PROV_DEVICE_NAME_SD=y
CONFIG_BT_ADV_PROV_GAP_APPEARANCE=y
CONFIG_BT_ADV_PROV_GAP_APPEARANCE_SD=y
# Align the advertised TX power with Fast Pair expectations.
# The value has been tailored for following DKs:
#   * nrf52840dk/nrf52840
#   * nrf52dk/nrf52832
#   * nrf5340dk/nrf5340/cpuapp
CONFIG_BT_ADV_PROV_TX_POWER_CORRECTION_VAL=-14
# Disable automatic initiation of PHY updates.
# Workaround to prevent disconnection with reason 42 (BT_HCI_ERR_DIFF_TRANS_COLLISION).
# Some Android phones reply to the LL_PHY_REQ and at the same time initiate a connection
# update which triggers an invalid procedure collision.
CONFIG_BT_AUTO_PHY_UPDATE=n
CONFIG_BT_ID_MAX=1
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=8
CONFIG_BT_SMP=y
CONFIG_BT_PRIVACY=y
CONFIG_BT_RPA_TIMEOUT=960
CONFIG_BT_FAST_PAIR=y
CONFIG_LOG=y
CONFIG_BT_FAST_PAIR_LOG_LEVEL_DBG=y
CONFIG_BT_HIDS=y
CONFIG_BT_HIDS_DEFAULT_PERM_RW_ENCRYPT=y
CONFIG_BT_CONN_CTX=y
# Enable BAS to comply with HID over GATT profile
CONFIG_BT_BAS=y
# Fill DIS characteristic to comply with HID over GATT profile
CONFIG_BT_DIS_MANUF="NordicSemiconductor"
CONFIG_BT_DIS_PNP=y
CONFIG_BT_DIS_PNP_VID_SRC=2
CONFIG_BT_DIS_PNP_VID=0x1915
CONFIG_BT_DIS_PNP_PID=0xEEED
I am currently using the pixel 7a and the Samsung s23 ultra both are connected to the internet and Bluetooth I turned on
But after programming the device I see the device is advertising but the fast pair pop-is not popping up on the phones
We need to ensure that 0x2A410B  model id is correct
Thanks in advance
Nandy
