How to build nanopb proto sources into a zephyr_library
I'm currently porting a project that was originally developed on NRF5 SDK to Zephyr RTOS.
We used protobuf in varoius places.  We also have multiple different conditional builds for different target markets that enable or disable certain features so code needs to be built conditoinally based on Kconfig settings.
I'm now trying to port our protobuf based features which we used for portability between our firmware and the mobile apps.  I see that nanopb has already been integrated into zephyr as a module.  There are also examples of using nanopb directly in the CMakelist.txt from your application build folder.
The problem I'm having is adding protobuf support in a library instead of directly in the app/src.
My directory layout:
zephyr
repo/app/CMakelists.txt    -- app build
repo/lib/data_exchange/file_formats/CMakelists.txt    -- library folder
repo/lib/data_exchange/file_formats/file_format.proto
The goal is to run protoc on file_format.proto and add the generated source files to a zephyr_library named file_formats.
the file zephyr/modules/nanopb/nanopb.cmake has this function:
# Generate source and header files from provided .proto files and
# add these as sources to the specified target.
function(zephyr_nanopb_sources target)
# Turn off the default nanopb behavior
set(NANOPB_GENERATE_CPP_STANDALONE OFF)
nanopb_generate_cpp(proto_srcs proto_hdrs RELPATH ${CMAKE_CURRENT_SOURCE_DIR} ${ARGN})
target_include_directories(${target} PUBLIC ${CMAKE_CURRENT_BINARY_DIR})
target_sources(${target} PRIVATE ${proto_srcs} ${proto_hdrs})
# Create unique target name for generated header list
string(MD5 unique_chars "${proto_hdrs}")
set(gen_target_name ${target}_proto_${unique_chars})
add_custom_target(${gen_target_name} DEPENDS ${proto_hdrs})
add_dependencies(nanopb_generated_headers ${gen_target_name})
endfunction()
I'm trying to create my own function that would be add the source files into a zephyr_library:
zephyr_library()
zephyr_library_nanopb_source(file_format.proto)
I tried doing this:
function(zephyr_library_nanopb_sources target)
  # add protoc dependencies to generate c and add c to library
  #zephyr_include_directories(${target} PUBLIC ${CMAKE_CURRENT_BINARY_DIR})
  #zephyr_library_sources(${target} PRIVATE ${proto_srcs} ${proto_hdrs})
  #zephyr_include_directories(${CMAKE_CURRENT_BINARY_DIR})
  zephyr_library_sources(${proto_srcs})
endfunction()
but it doesn't work:
zephyr_library_sources Function invoked with incorrect arguments for
function named: zephyr_library_sources
    I don't have that much experience with Protobuf, but wouldn't it be sufficient if you could conditionally select the *.proto file during compilation?  Below is a demo sample I created  based on the nanopb project that selects the *.proto file based on  the Kconfig configuration (CONFIG_SAMPLE_PB_PROD_A or CONFIG_SAMPLE_PB_PROD_B).
    Project
    nanopb_332011.zip
    Build command
    $ west build -b <target board> -- -DCONFIG_SAMPLE_PB_PROD_A
    Vidar
  • The issue isn't with configuring the build, Kconfig and prj.conf handles that just fine.  I"m trying to figure out the cmake parts of the system, which I'm as experienced with.
    The nanopb common files need to be added into the project somewhere, probably in the app cmake, and then in the library folder the optional proto files need to be converted into .c and .h files and then those files compiled into a library.
    Perhaps someone could suggest a better forum for me to get help on this?
  • It’s not clear to me why you would build nanopb as a separate library rather than using the integrated Zephyr module as demonstrated in the sample application. When using the module, the generated source files will be placed in the build folder. Are you looking to have the generated source files copied to your project source directory instead, or is there other functionality missing in the Zephyr integration of nanopb?
    If you want to build a separate linkable library from your project, you can use the External Library sample as a reference.
  • I'm not asking to make nanopb a separate library, I'm trying to make the generated protobuf c files that have been implemented as multiple modular schemas into a zephyr library.
    The .proto file are located in a lib/schema/schema.proto.   protoc and the nanopb generator should be used to convert those files into .c and .h files located in the lib/schema   and those .c and .h files should be added into the build from the lib/schema/CMakeLists.txt and compiled into a zephyr_library()
    the nanopb examples add the .proto files from the application folder which does not scale well when there are multiple application folders, such as when there is a manufacturing test application and multiple applications for different markets/products.
  • Thanks for the clarification. According to this commit: https://github.com/nrfconnect/sdk-zephyr/commit/86c92869d25fb85444c7b4a0de6d03b94d9c688e , it seems that you'll need to convert your 'lib' directory into a Zephyr module to create a Zephyr library. The library can then be enabled and configured in your applications.
