Thingy:91 Out of the box build of Asset Tracker V2 causes reboot every x seconds
Hi there!
I have a Thingy:91 which I've registered on the NRF Cloud and verified its operation by flashing the prebuild hex files to my board. After doing this, I can see data coming in on the NRF dashboard.
The files flashed are:
  • Modem: mfw_nrf9160_1.3.6.zip
  • App: thingy91_asset_tracker_v2_2024-07-04_20471118.hex
In a next step I tried to build the Asset Tracker V2 application myself using vscode, without adjusting anything, resulting in the following build command:
west build --build-dir PROJECT_PATH/Thingy-91/asset_tracker_v2/build PROJECT_PATH/Thingy-91/asset_tracker_v2 --pristine --board thingy91_nrf9160_ns --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=PROJECT_PATH/thingy-91/asset_tracker_v2 -Dmcuboot_OVERLAY_CONFIG=C:/ncs/v2.5.0/nrf/modules/mcuboot/tfm.conf;C:/ncs/v2.5.0/nrf/modules/mcuboot/fih_low_enable.conf;C:/ncs/v2.5.0/nrf/subsys/partition_manager/partition_manager_enabled.conf;PROJECT_PATH/Thingy-91/asset_tracker_v2/child_image/mcuboot.conf -DCACHED_CONF_FILE=PROJECT_PATH/Thingy-91/asset_tracker_v2/prj.conf;PROJECT_PATH/Thingy-91/asset_tracker_v2/boards/thingy91_nrf9160_ns.conf -DDTC_OVERLAY_FILE=PROJECT_PATH/Thingy-91/asset_tracker_v2/boards/thingy91_nrf9160_ns.overlay
After flashing app_signed.hex to the board using the NRF Desktop Programmer v4.4.0, the board starts up and reboots at random moments, but I can see that it:
  • Starts up
  • Creates a LTE connection successfully
  • Creates a Cloud connection successfully
As a sanity check, I flashed the original precompiled hex file (thingy91_asset_tracker_v2_2024-07-04_20471118.hex) back to the board, and verified that this works just fine.
In the following log from my locally compiled code (with cloud log set to debug), we can see the device connecting to the cloud and rebooting, and afterwards it reboots again but way sooner before while attempting an LTE connection:
*** Booting nRF Connect SDK v2.5.0 ***
[00:00:00.269,897] <inf> app_event_manager: APP_EVT_START
[00:00:00.516,693] <inf> app_event_manager: MODEM_EVT_INITIALIZED
[00:00:00.526,550] <dbg> nrf_cloud_transport: nct_client_id_set: client_id = nrf-351901930739010
[00:00:00.526,885] <dbg> nrf_cloud_transport: nct_topics_populate: accepted_topic: nrf-351901930739010/shadow/get/accepted
[00:00:00.526,916] <dbg> nrf_cloud_transport: nct_topics_populate: rejected_topic: $aws/things/nrf-351901930739010/shadow/get/rejected
[00:00:00.526,977] <dbg> nrf_cloud_transport: nct_topics_populate: update_delta_topic: $aws/things/nrf-351901930739010/shadow/update/delta
[00:00:00.527,008] <dbg> nrf_cloud_transport: nct_topics_populate: update_topic: $aws/things/nrf-351901930739010/shadow/update
[00:00:00.527,069] <dbg> nrf_cloud_transport: nct_topics_populate: shadow_get_topic: $aws/things/nrf-351901930739010/shadow/get
[00:00:00.527,099] <dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 1
[00:00:00.676,300] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
[00:00:01.271,362] <inf> app_event_manager: DATA_EVT_CONFIG_INIT
[00:01:45.800,323] <dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 15000 result = 0
[00:01:45.800,354] <dbg> nrf_cloud_fsm: cc_tx_ack_handler: Data ACK for user tag: 15000
[00:01:45.800,384] <dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 7
[00:01:46.120,483] <dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id = 301 result = 0
[00:01:46.120,513] <dbg> nrf_cloud_transport: nct_dc_connect: nct_dc_connect
[00:01:46.121,307] <dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 8
[00:01:46.528,381] <dbg> nrf_cloud_transport: nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id = 101 result = 0
[00:01:46.529,205] <dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 9
[00:01:46.530,334] <dbg> nrf_cloud_transport: nct_cc_send: mqtt_publish: id = 1000 opcode = 1 len = 145, topic: $aws/things/nrf-351901930739010/shadow/update
[00:01:46.531,585] <inf> app_event_manager: CLOUD_EVT_CONNECTED
[00:01:46.532,592] <inf> app_event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, MOD_STAT, LOCATION)
[00:01:46.633,422] <inf> app_event_manager: LOCATION_MODULE_EVT_AGNSS_NEEDED
[00:01:46.633,850] <inf> app_event_manager: LOCATION_MODULE_EVT_ACTIVE
[00:00:00.269,866] <inf> app_event_manager: APP_EVT_START
[00:00:00.516,571] <inf> app_event_manager: MODEM_EVT_INITIALIZED
[00:00:00.526,428] <dbg> nrf_cloud_transport: nct_client_id_set: client_id = nrf-351901930739010
[00:00:00.526,763] <dbg> nrf_cloud_transport: nct_topics_populate: accepted_topic: nrf-351901930739010/shadow/get/accepted
[00:00:00.526,794] <dbg> nrf_cloud_transport: nct_topics_populate: rejected_topic: $aws/things/nrf-351901930739010/shadow/get/rejected
[00:00:00.526,855] <dbg> nrf_cloud_transport: nct_topics_populate: update_delta_topic: $aws/things/nrf-351901930739010/shadow/update/delta
[00:00:00.526,885] <dbg> nrf_cloud_transport: nct_topics_populate: update_topic: $aws/things/nrf-351901930739010/shadow/update
[00:00:00.526,947] <dbg> nrf_cloud_transport: nct_topics_populate: shadow_get_topic: $aws/things/nrf-351901930739010/shadow/get
[00:00:00.526,977] <dbg> nrf_cloud: nfsm_set_current_state_and_notify: state: 1
[00:00:00.676,147] <inf> app_event_manager: MODEM_EVT_LTE_CONNECTING
[00:00:01.271,331] <inf> app_event_manager: DATA_EVT_CONFIG_INIT
[00:00:01.944,854] <inf> app_event_manager: SENSOR_EVT_MOVEMENT_ACTIVITY_DETECTED
%MDMEV: SEARCH STATUS 1
Any ideas what this could be?
  • I can give it a go in v2.6.1 if you want?
  • So I gave it a go in v2.6.1, still rebooting, but now I get an error message which wasn't there before, a 'SECURE FAULT':
    *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
    [00:01:53.553,039] <wrn> location: GNSS timed out possibly due to too short GNSS time windows
    %NCELLMEAS: 0,"07E65A0C","26801","0008",145,6300,259,46,17,112288,6300,127,43,11,0,6300,100,38,4,0,21902
    %NCELLMEAS: 0,"07E65A0C","26801","0008",145,21902,6300,259,46,16,113568,1,0
    %NCELLMEAS: 0,"07E65A0C","26801","0008",145,21902,6300,259,45,15,118688,1,0
    [00:01:59.589,324] <inf> app_event_manager: LOCATION_MODULE_EVT_CLOUD_LOCATION_DATA_READY
    [00:01:59.589,874] <inf> app_event_manager: DATA_EVT_DATA_READY
    [00:01:59.590,972] <err> os: ***** SECURE FAULT *****
    [00:01:59.591,003] <err> os:   Address: 0x1
    [00:01:59.591,003] <err> os:   Attribution unit violation
    [00:01:59.591,033] <err> os: r0/a1:  0x00000000  r1/a2:  0x00000000  r2/a3:  0x2001cc60
    [00:01:59.591,033] <err> os: r3/a4:  0x00000000 r12/ip:  0x00000001 r14/lr:  0x00049f5d
    [00:01:59.591,064] <err> os:  xpsr:  0x21000000
    [00:01:59.591,064] <err> os: s[ 0]:  0x20013930  s[ 1]:  0x20013870  s[ 2]:  0x00000001  s[ 3]:  0x00000000
    [00:01:59.591,125] <err> os: s[ 4]:  0x00000000  s[ 5]:  0x0003d4f1  s[ 6]:  0x00000000  s[ 7]:  0x0003d591
    [00:01:59.591,125] <err> os: s[ 8]:  0x00000010  s[ 9]:  0x00000000  s[10]:  0x20013870  s[11]:  0x0003bd13
    [00:01:59.591,156] <err> os: s[12]:  0x0004a207  s[13]:  0x2001c0b8  s[14]:  0x0004028d  s[15]:  0x20013d0c
    [00:01:59.591,156] <err> os: fpscr:  0x00000000
    [00:01:59.591,186] <err> os: Faulting instruction address (r15/pc): 0x00033e7c
    [00:01:59.591,217] <err> os: >>> ZEPHYR FATAL ERROR 41: Unknown error on CPU 0
    [00:01:59.591,247] <err> os: Current thread: 0x2000e830 (unknown)
    *** Booting nRF Connect SDK v3.5.99-ncs1-1 ***g
    FYI: I updated using the Tool Manager in NRF Connect Desktop, then restarted vscode and updated the toolchain and sdk to the new version. After that, did a pristine build and flashed app_signed.hex to the device.
