Error when run west zap-generate with parameters
I am using matter SDK v2.7.0, when I run command below:
west zap-generate -z ~/Work/matter/light_switch/src/light_switch.zap -m /opt/nordic/ncs/v2.7.0
I get error:
FileNotFoundError: [Errno 2] No such file or directory: '/opt/nordic/ncs/v2.7.0/scripts/tools/zap/zap_execution.py'
The path "/opt/nordic/ncs/v2.7.0/scripts/tools/zap/zap_execution.py" is incorrect. It should be "/opt/nordic/ncs/v2.7.0/modules/lib/matter/scripts/tools/zap/zap_execution.py"?
    The path is wrong because you are missing the /modules/lib/matter part of the -m parameter value. The -m parameter should be the path to the Matter SDK installation which is in ncs/v2.7.0/modules/lib/matter. See the documentation for the zap-generate command here.
    Maria
    Thank for your support!
    I used command with /modules/lib/matter, but below error occurs:
    west zap-generate -z ~/Work/matter/light_switch/src/light_switch.zap -m /opt/nordic/ncs/v2.7.0/modules/lib/matter
    ZAP installation directory: /opt/nordic/ncs/v2.7.0/modules/lib/matter/.zap-install
    Found ZAP 2024.3.14 (up to date)
    Searching for zcl file from /Users/hien/Work/matter/light_switch/src/light_switch.zap
    Error: /Users/modules/lib/matter/src/app/zap-templates/zcl/zcl.json does not exists or is not a file.
    FATAL ERROR: command exited with status 1: /Library/Developer/CommandLineTools/usr/bin/python3 /opt/nordic/ncs/v2.7.0/modules/lib/matter/scripts/tools/zap/generate.py /Users/hien/Work/matter/light_switch/src/light_switch.zap -t /opt/nordic/ncs/v2.7.0/modules/lib/matter/src/app/zap-templates/app-templates.json -o /Users/hien/Work/matter/light_switch/src/zap-generated
    Happy to help!
    Now it looks like the first path is the wrong one. Please check that the value sent to the -z parameter reflects the location on your machine.
    If you still get build errors, make sure that you have installed the ZAP took like described in the documentation.
    Maria
  • Hi Maria,
    I have installed ZAP tool like described in the documentation by run command west zap-gui in directory /opt/nordic/ncs/v2.7.0/modules/lib/matter.
    The ZAP tool can be open ok, but when I run west zap-generate so the above error occurs.
    Maybe we need update environment variable?
    I am running on macOS.
    Hien
  • Hi Hien,
    It is worth to see if there are issues with your NCS installation.
    How did you install it?
    Which MacOS version are you running?
    Maria
