case about nRF52840 dongle coprocessor
How to fix this compilation problem:
D:\ncs\v2.7.0>west build -p always -b nrf52840dongle_nrf52840 nrf/samples/openthread/coprocessor/ -- -DOVERLAY_CONFIG="overlay-usb.conf" -DDTC_OVERLAY_FILE="usb.overlay"
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: D:/ncs/toolchains/ce3b5ff664/opt/bin/python.exe (found suitable version "3.9.13", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: D:/ncs/v2.7.0/zephyr/.cache
CMake Warning at D:/ncs/v2.7.0/zephyr/cmake/modules/boards.cmake:110 (message):
Deprecated BOARD=nrf52840dongle_nrf52840 specified, board automatically
changed to: nrf52840dongle.
cmake/modules/sysbuild_default.cmake:14 (include)
D:/ncs/v2.7.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
D:/ncs/v2.7.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
D:/ncs/v2.7.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
template/CMakeLists.txt:10 (find_package)
-- Board: nrf52840dongle, qualifiers: nrf52840
Parsing D:/ncs/v2.7.0/zephyr/share/sysbuild/Kconfig
Loaded configuration 'D:/ncs/v2.7.0/build/_sysbuild/empty.conf'
Merged configuration 'D:/ncs/v2.7.0/build/_sysbuild/empty.conf'
Configuration saved to 'D:/ncs/v2.7.0/build/zephyr/.config'
Kconfig header saved to 'D:/ncs/v2.7.0/build/_sysbuild/autoconf.h'
* Running CMake for coprocessor *
-- Application: D:/ncs/v2.7.0/nrf/samples/openthread/coprocessor
-- CMake version: 3.21.0
-- Using NCS Toolchain 2.6.20240605.885759407716 for building. (D:/ncs/toolchains/ce3b5ff664/cmake)
CMake Error at cmake/modules/sysbuild_extensions.cmake:486 (message):
CMake configure failed for Zephyr project: coprocessor
Location: D:/ncs/v2.7.0/nrf/samples/openthread/coprocessor
cmake/modules/sysbuild_images.cmake:20 (ExternalZephyrProject_Cmake)
cmake/modules/sysbuild_default.cmake:19 (include)
See also "D:/ncs/v2.7.0/build/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: 'D:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.EXE' -DWEST_PYTHON=D:/ncs/toolchains/ce3b5ff664/opt/bin/python.exe '-BD:\ncs\v2.7.0\build' -GNinja -DBOARD=nrf52840dongle_nrf52840 -DOVERLAY_CONFIG=overlay-usb.conf -DDTC_OVERLAY_FILE=usb.overlay '-SD:\ncs\v2.7.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=D:\ncs\v2.7.0\nrf\samples\openthread\coprocessor'
Thank you for all your assistance.
Peter.Min
  • Hi Peter.Min,
    Your build command is outdated. Please make sure that you are consulting the documentation with the same version as your NCS version.
    NCS v2.6.0 introduced snippets for selecting different configurations for samples. For the co-processor sample the usb snippet is chosen by adding -S usb to the west build command or by selecting the usb snippet through the Build Configuration UI in the nRF Connect for VS Code extension. Also see the sample documentation for the NCS v2.7.0 version of the co-processor sample and the Using Snippets documentation for general usage instructions.
    NCS v2.7.0 introduced a new hardware model, so the correct formatting for the board when building with the nRF52840 Dongle as the target is nrf52840dongle/nrf52840.
    For a more detailed view on updates for each NCS version, please see the release notes(v2.7.0).
    Maria
