Can nRF54H20 work with nRF7002?
Dear Nordic team,
I am currently working with the nRF54H20 and have been researching the nRF7002 (using the nRF7002-DK). I would like to ask if the nRF54H20 is compatible with the nRF7002 chip. I might need to manually connect the nRF54H20 to the nRF7002 chip on the nRF7002-DK.
** As far as I know, the nRF7002 is designed for the nRF52, nRF53, and nRF91. Is there any updated information or plans to support the nRF54H20?
www.nordicsemi.com/.../nRF7002
Thanks.
  • Hi Lam,
    We do have experimental support for nRF7002 and nRF54H in SDK v2.7.0
    You can take a look here: https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/releases_and_maturity/software_maturity.html#protocol_support
    I haven't tried myself to run the nRF7002 from the nRF54H but let us know if you face any problem.
  • Hi  ,
    Context:
    • WiFi board: nRF7002-EK
    • Host boards: nRF52840, nRF5340, and nRF54H20
    I've successfully built and flashed the Wi-Fi: Shell example for nRF52-DK and nRF53-DK, which works well with nRF7002-EK.
    uart:~$
    [00:00:00.259,460] <inf> wifi_nrf_bus: SPIM spi@4002f000: freq = 8 MHz
    [00:00:00.259,490] <inf> wifi_nrf_bus: SPIM spi@4002f000: latency = 0
    *** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
    *** Using Zephyr OS v3.6.99-100befc70c74 ***
    Starting nrf52840dk with CPU frequency: 64 MHz
    [00:00:00.515,899] <inf> wpa_supp: Successfully initialized wpa_supplicant
    uart:~$ wifi
      version             ap                  connect
      disconnect          ps                  ps_mode
      scan                statistics          status
      twt                 reg_domain          mode
      packet_filter       channel             ps_timeout
      ps_listen_interval  ps_wakeup_mode      rts_threshold
    I can build and flash Wi-Fi: Shell for nRF54H20 (nrf54h20dk/nrf54h20/cpuapp) and nRF7002-EK (nrf700x_nrf54h20dk), but I'm encountering an error as shown in the log below:
    uart:~$
    [00:00:00.200,002] <inf> wifi_nrf_bus: SPIM spi@9a5000: freq = 8 MHz
    [00:00:00.200,023] <inf> wifi_nrf_bus: SPIM spi@9a5000: latency = 0
    [00:00:00.206,997] <err> wifi_nrf: hal_rpu_reg_read: Error !! Value read at addr_offset = 400 is = FFFFFFFF
    [00:00:00.207,019] <err> wifi_nrf: hal_rpu_irq_enable: Reading from Root interrupt register failed
    [00:00:00.207,034] <err> wifi_nrf: nrf_wifi_hal_dev_add: hal_rpu_irq_enable failed
    [00:00:00.207,093] <err> wifi_nrf: nrf_wifi_fmac_dev_add: nrf_wifi_hal_dev_add failed
    [00:00:00.207,102] <err> wifi_nrf: nrf_wifi_fmac_dev_add_zep: nrf_wifi_fmac_dev_add failed
    [00:00:00.207,109] <err> wifi_nrf: nrf_wifi_if_start_zep: nrf_wifi_fmac_dev_add_zep failed
    [00:00:00.208,131] <inf> fs_nvs: 6 Sectors of 4096 bytes
    [00:00:00.208,135] <inf> fs_nvs: alloc wra: 0, fd0
    [00:00:00.208,144] <inf> fs_nvs: data wra: 0, 0
    Starting nrf54h20dk with CPU frequency: 320 MHz
    [00:00:00.209,089] <inf> wpa_supp: Successfully initialized wpa_supplicant
    Here's my hardware connection between nRF7002-EK and nRF54H20:
    Func nRF7002-EK nRF5340-DK nRF54H20
    iovdd-ctrl-gpios IOVDD_EN P1.00 P1.00 [P1.03]
    bucken-gpios BUCK_EN P1.01 P1.00
    host-irq-gpios HOST_IRQ P1.09 P1.02
    cs SS P1.12 P1.04
    MOSI MOSI P1.13 P1.05
    MISO MISO P1.14 P1.06
    SCK CLK P1.15 P1.01
    //nrf700x_nrf54h20dk.overlay
    &pinctrl {
    	spi130_default: spi130_default {
    		group1 {
    			/* SCK has to be 0..3 and other signals can't use these pins */
    			psels = <NRF_PSEL(SPIM_SCK, 1, 1)>,
    				<NRF_PSEL(SPIM_MISO, 1, 6)>,
    				<NRF_PSEL(SPIM_MOSI, 1, 5)>;
    	spi130_sleep: spi130_sleep {
    		group1 {
    			low-power-enable;
    &spi130 {
    	status = "okay";
    	cs-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>;
    	pinctrl-0 = <&spi130_default>;
    	pinctrl-1 = <&spi130_sleep>;
    	memory-regions = <&cpuapp_dma_region>;
    	nrf700x: nrf7002@0 {
    		compatible = "nordic,nrf700x-spi";
    		status = "okay";
    		reg = <0>;
    		spi-max-frequency = <DT_FREQ_M(8)>;
    		bucken-gpios = <&gpio1 0 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
    		iovdd-ctrl-gpios = <&gpio1 0 (GPIO_ACTIVE_HIGH | GPIO_PULL_DOWN)>;
    		host-irq-gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>;
    &gpio1 {
    	status = "okay";
    Questions:
    1. Why are both bucken-gpios and iovdd-ctrl-gpios set to P1.00 for nrf700x_nrf54h20dk? I've tried changing iovdd-ctrl-gpios from P1.00 to P1.03, but the result remains the same.
    2. Is my connection between nRF7002-EK and nRF54H20 correct? Are there any missing pins?
    3. If the hardware connection is correct, what error am I facing? Is there a way to identify the root cause?
    Thank you in advance for any help or insights you can provide. I appreciate your time and expertise.
  • Yes, I am using the nRF54H20-DK connected to the nRF7002-EK.
    When building the Wi-Fi: Shell, I use the Board target: nrf54h20dk/nrf54h20/cpuapp and Shields: nrf700x_nrf54h20dk as specified in the README Requirements. What confuses me is that Pin1.00 is configured for both iovdd-ctrl-gpios and bucken-gpios.
    &spi130 {
    	status = "okay";
    		status = "okay";
    		reg = <0>;
  • I see. I guess this can explain the pin issues. The EB is what we recommend for the 54 series. The EK is only compatible with the 52/53/91 series DKs. Do you have an EB? Your RSM is hopefully able to provide one to you.
    The EB do not have separate iovdd-ctrl pin as EK. There is a small circuit which uses bucken itself as iovdd-ctrl due to lack of pins. So in the code same P1.00 pin is used for both iovdd-ctrl and bucken. Our “shield” based support for the 54H is the EB mounted on a custom interposer.
    Another thing I should mention is that if you are planning on designing your own PCB, then don't use this shared BUCKEN and IOVDD_EN approach (as used on the EB) as it does not satisfy the documented power up/powerdown requirements as detailed in the PS. We just decided on doing it this way as there were not enough IOs on the EB to support independent controls.
    Elfving
  • Hi
    I get it now. Adding eb to the overlay file name (e.g: nrf700eb_nrf54h20dk.overlay) makes more sense. I have both nRF7002EK and EB, so I'll try with the EB.
    Thanks for your help.
  • No problem at all, and sorry about the slow response from me here.
    So it seems that the current version of the DK doesn't support the EB without the custom interposer. I am looking into getting the schematics for that for you.
    Though the EK can work with the wiring strategy you tried there as well (our Wi-Fi R&D team just tested it). Just note that power sequence is violated with both bucken and iovdden connected to same pin and we do not want that situation in a real product.
    Elfving
  • Thanks  for your update .
    Have a good weekendd.
