To prepare our new device, we are using a nrf5340dk board.
For our application, we need to perform DFU over BT.
Si, i following the tutorial https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-bootloaders-and-dfu-fota/topic/exercise-3-fota-over-bluetooth-low-energy/ and everything working well on the board.
So, in my application i add the following line on prj.conf
CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
And, then, when i want to perform DFU with my android using nrf connect, my device is stuck, and on nrf connect i have the message " Starting DFU" (see pictures below)
and see the last log on console on nrf5340 dk
[00:07:31.898,773] <inf> mcuboot_util: Image index: 0, Swap type: none [00:07:32.031,677] <inf> mcuboot_util: Image index: 0, Swap type: none [00:07:32.046,569] <inf> mcuboot_util: Image index: 0, Swap type: none
After some research, i found that if i not enable my uart device, DFU are working well. More precisely if i not enable the rx.
See my code to init uart
int uart1_init(void)
int err;
if (!device_is_ready(uart1))
LOG_ERR("UART device not ready\r\n");
return -1 ;
err = uart_callback_set(uart1, uart1_cb, NULL);
if (err)
return err;
// DFU working if line below commented
err = uart_rx_enable(uart1 ,uart1_rx_buf,sizeof(uart1_rx_buf),RX_TIMEOUT_US);
return err;
If i use uart_rx_disable once a connection is detected, then DFU perform working well.
Could you help me on this issue ? I don't want to perform a DFU by UART, but only by BT so disable CONFIG_SERIAL on mcuboot.conf, but still have the same issue.
Thanks in advance,
Best Regards,
Julien F.
