Firmware Reset failing with MCUboot and WDT
Hi all,
We have an application which uses both MCUboot and a watchdog timer. This combination seems to be causing issues anytime we attempt a soft reset using sys_reboot or NVIC reset directly.
Our system;
  • Custom board using nRF5340
  • ncs v2.2.0
When we attempt a soft reset the following happens;
  1. Device powers down and enters bg_thread_main() in "ncs\v2.2.0\zephyr\kernel\init.c", it doesn't enter our application main()
  2. Device enters MCUboot
  3. After sometime the watchdog resets, the device enters MCUboot again
  4. Finally the device enters bg_thread_main() again, this time our application main() runs successfully
All this is monitored using UART log (shown below).
This issue looks similar to another devzone post, however, we've tried the suggestion of adding CONFIG_BOOT_WATCHDOG_FEED to our mcuboot.conf but we still get the same sequence of events.
From the RESET table, software resets don't reset the WDT which explains why we get 2 resets but it doesn't explain why we don't enter our application main loop in 1. We've tried forcing a WDT timer reset instead of a soft reset and this does fix the issue - we only get one reset and it enters our application main loop successfully.
One solution is if we tie a gpio directly to the RESET pin and use this gpio for resets from within the application. This isn't ideal as it requires hardware changes and limits ours design.
Does anyone have any other suggestions we can try?
  • Hi Vidar,
    Apologies for the delayed response; I’ve been tied up with other projects. I’ve now returned to this and managed to reproduce the issue on the nRF53 DK. I’ve attached a .zip file containing the source code, board files, and overlays.
    The firmware is designed to initialise and activate LED1 on the DK, stay active for 2 seconds, then reboot. This works as expected for the first ~4 reboots*, but after that, the device fails to reboot correctly. It hangs for around 30 seconds (until the WDT window elapses), at which point the watchdog timer kicks in and the device reboots properly. Strangely, this doesn’t happen when the RTT viewer is connected. The issue occurs regardless of whether I use sys_reboot or NVIC_SystemReset to trigger the reboot. The firmware is built using nRF SDK 2.2.0.
    *The issue tends to occur between the 3rd and 5th reboot.
    To compile and run the firmware:
    1. Set nRF toolchain and SDK to NCS v2.2.0
    2. Select "demo_boards_cpuapp_ns" as the board type
    3. Include the overlay-rtt.conf Kconfig fragment
    4. Add external_flash.overlay and power_enhance.overlay
    5. Flash the firmware onto the DK
    6. Don't connect to RTT! Instead, connect via serial interface to view logs through UART
    Below is a screenshot of my build configuration from the nRF VS Code extension.
    When the issue arises (typically after 3-5 reboots), the logs will freeze on the following output for about 30 seconds.
    After the WDT has elapsed the device will reset and boot.
    demo_wdt_issue.zip
    Let me know if you need anything more from me.
  • I also tried connecting the RESET pin directly to a GPIO to trigger a pin reset instead of a software reset. However, when I attempted this, our custom board freezes after setting the GPIO low, I think its because the RESET pin remains low.
    Do you know if it’s possible to trigger a pin reset using a GPIO on the same nRF53 controller?
  • Thank you for this example. I'm able to reproduce the same here now, and it looks like the program hangs in the SPU_IRQHandler when the WD times out.
    I will continue to debug this to try find out what is triggering the SPU IRQ.
    This should work, but it is important that the GPIO is never becomes configured as an output low during boot. Is this GPIO configured in the code your prodived?
    Great to hear you can see it your side too.
    It isn't in the demo I provided, however, it can be added easily.
    On the DK you just need to add a solder bridge to SB43 so the reset can be controlled via the pin, then add a jumper between a gpio and the RESET pin.
    I've used GPIO (0,26) below)
    Then you can add the following function to the demo example which triggers a pin reset.
    #define CONTROL_PIN NRF_GPIO_PIN_MAP(0,26)
    void pin_reset(void)
    	 LOG_DBG("Resetting Device");
        // Configure the GPIO pin
       // nrfx_gpiote_out_config_t pin_config = NRFX_GPIOTE_CONFIG_OUT_SIMPLE(true);
            .action = GPIOTE_CONFIG_POLARITY_LoToHi,
            .init_state = GPIOTE_CONFIG_OUTINIT_High,
            .task_pin = false,
        nrfx_err_t err = nrfx_gpiote_out_init(CONTROL_PIN, &pin_config);
        if (err != NRFX_SUCCESS)
            LOG_DBG("nrfx error 2 ox%X",err);
        k_msleep(300);
        // Set the pin high
            // power up unused ram for mcuboot
        if (IS_ENABLED(CONFIG_RAM_POWER_DOWN_LIBRARY))
            power_up_unused_ram();
        nrfx_gpiote_out_clear(CONTROL_PIN);
    	LOG_DBG("triggered reset pin"); //shouldn't get to here
    In my testing I call pin_reset() in main after the 2 second delay and led initialisation.
    It seems like because the reset pin never goes low again it doesn't complete a reset. You can see this using the "Boot Reset" button on the DK; if I hold the button down the device won't reset, It's only when I release the button does it reset.
  • I'm sorry for the delayed response. I've been working on debugging the code to identify what is triggering the SPU event. It turned out to be quite challenging because the security violation is not caused by the CPU but by another bus master.
    I have not been able to pinpoint the source of the flash access error, nor have I found any other reports of this event happening under similar conditions. However, upgrading to SDK v2.4.4 may resolve this issue as it includes several errata workarounds that were not present in SDK v2.2.0.
    A workaround for now may be to issue a soft reset from the SPU ISR in TF-M to avoid having to wait for the WDT timeout. For example, by adding the following to ncs/v2.2.0/modules/tee/tf-m/trusted-firmware-m:
    diff --git a/platform/ext/common/faults.c b/platform/ext/common/faults.c
    index eb87c971c..9124030c2 100644
    --- a/platform/ext/common/faults.c
    +++ b/platform/ext/common/faults.c
    @@ -107,3 +107,8 @@ __attribute__((naked)) void UsageFault_Handler(void)
             "b         .                      \n"
    +void SPU_IRQHandler(void)
    +    NVIC_SystemReset();
    \ No newline at end of file
    I think you are right. The specification does not guarantee the pin state in reset, only when going out of reset. I know this approach with using a GPIO to trigger pinreset worked with the nRF52840 but there are some differences in the reset mechanism between the nRF52840 and the nRF5340.
