Hi when I try to run the HRM collector the scan start fails with error code 12289 I am using visual studio and C++
What am I missing? I downloaded "connectivity_115k2_with_s130_1.0.0" to a nrf58122 qfac usb dongle (PCA10031)
#include "stdafx.h"
#include "nrf_error.h"
#include "ble.h"
#include "ble_types.h"
#include "sd_rpc.h"
#include <string.h>
#include <stdbool.h>
#include <stdio.h>
#define UART_PORT_NAME "COM48"
#define ADVERTISING_INTERVAL_40_MS 64 // * 0.625 ms = 40 ms
#define ADVERTISING_TIMEOUT_3_MIN 180 // * 1 sec = 3 min
enum
UNIT_0_625_MS = 625, /**< Number of microseconds in 0.625 milliseconds. */
UNIT_1_25_MS = 1250, /**< Number of microseconds in 1.25 milliseconds. */
UNIT_10_MS = 10000 /**< Number of microseconds in 10 milliseconds. */
#define MSEC_TO_UNITS(TIME, RESOLUTION) (((TIME) * 1000) / (RESOLUTION))
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(60, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 millisecond. */
#define TARGET_DEV_NAME "HRM Example" /**< Target device name that application is looking for. */
#define MAX_PEER_COUNT 1 /**< Maximum number of peer's application intends to manage. */
#define HRM_SERVICE_UUID 0x180D
#define HRM_MEAS_CHAR_UUID 0x2A37
#define CCCD_UUID 0x2902
#define CCCD_NOTIFY 0x01
#define STRING_BUFFER_SIZE 50
typedef struct
uint8_t * p_data; /**< Pointer to data. */
uint16_t data_len; /**< Length of data. */
} data_t;
static uint8_t m_connected_devices = 0;
static uint16_t m_connection_handle = 0;
static uint16_t m_service_start_handle = 0;
static uint16_t m_service_end_handle = 0;
static uint16_t m_hrm_char_handle = 0;
static uint16_t m_hrm_cccd_handle = 0;
static bool m_connection_is_in_progress = false;
static const ble_gap_scan_params_t m_scan_param =
0, // Active scanning set.
0, // Selective scanning not set.
NULL, // White-list not set.
(uint16_t)SCAN_INTERVAL, // Scan interval.
(uint16_t)SCAN_WINDOW, // Scan window.
0 // Never stop scanning unless explicit asked to.
static const ble_gap_conn_params_t m_connection_param =
(uint16_t)MIN_CONNECTION_INTERVAL, // Minimum connection
(uint16_t)MAX_CONNECTION_INTERVAL, // Maximum connection
0, // Slave latency
(uint16_t)SUPERVISION_TIMEOUT // Supervision time-out
/* Local function declarations */
static void log_handler(sd_rpc_log_severity_t severity, const char * message);
static uint32_t ble_stack_init();
static void on_connected(const ble_gap_evt_t * const p_ble_gap_evt);
static void on_adv_report(const ble_gap_evt_t * const p_ble_gap_evt);
static void on_timeout(const ble_gap_evt_t * const p_ble_gap_evt);
static void on_service_discovery_response(const ble_gattc_evt_t * const p_ble_gattc_evt);
static void on_characteristic_discover_response(const ble_gattc_evt_t * const p_ble_gattc_evt);
static void on_descriptor_discover_response(const ble_gattc_evt_t * const p_ble_gattc_evt);
static void on_write_response(const ble_gattc_evt_t * const p_ble_gattc_evt);
static uint32_t adv_report_parse(uint8_t type, data_t * p_advdata, data_t * p_typedata);
static uint32_t scan_start();
static uint32_t service_discovery_start();
static uint32_t char_discovery_start();
static uint32_t descr_discovery_start();
static uint32_t hrm_cccd_set(uint8_t value);
static void ble_address_to_string_convert(ble_gap_addr_t address, uint8_t * string_buffer);
switch (severity)
case LOG_ERROR:
printf("Error: %s\n", message); fflush(stdout);
case LOG_WARNING:
printf("Warning: %s\n", message); fflush(stdout);
printf("Log: %s\n", message); fflush(stdout);
printf("Connection established\n"); fflush(stdout);
m_connected_devices++;
m_connection_handle = p_ble_gap_evt->conn_handle;
uint32_t err_code;
data_t adv_data;
data_t type_data;
uint8_t str[STRING_BUFFER_SIZE] = { 0 };
ble_address_to_string_convert(p_ble_gap_evt->params.adv_report.peer_addr, str);
printf("Received advertisment report, address: 0x%s\n", str); fflush(stdout);
adv_data.p_data = (uint8_t *)(p_ble_gap_evt->params.adv_report.data);
adv_data.data_len = p_ble_gap_evt->params.adv_report.dlen;
err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME,
&adv_data,
&type_data);
if (err_code != NRF_SUCCESS)
// Compare short local name in case complete name does not match.
err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME,
&adv_data,
&type_data);
return;
if (0 == memcmp(TARGET_DEV_NAME, type_data.p_data, strlen(TARGET_DEV_NAME)))
if (m_connected_devices >= MAX_PEER_COUNT)
return;
if (m_connection_is_in_progress)
return;
err_code = sd_ble_gap_connect(&(p_ble_gap_evt->params.adv_report.peer_addr),
&m_scan_param,
&m_connection_param);
printf("Connection Request Failed, reason %d\n", err_code); fflush(stdout);
return;
m_connection_is_in_progress = true;
if (p_ble_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
else if (p_ble_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
scan_start();
int count;
int service_index;
const ble_gattc_service_t * service;
if (p_ble_gattc_evt->gatt_status != NRF_SUCCESS)
printf("Error. Service discovery failed. Error code 0x%X\n",
p_ble_gattc_evt->gatt_status);
fflush(stdout);
return;
count = p_ble_gattc_evt->params.prim_srvc_disc_rsp.count;
if (count == 0)
printf("Error. Service not found\n"); fflush(stdout);
return;
printf("Received service discovery response\n"); fflush(stdout);
service_index = 0; /* We specifically requested to discover Heart Rate service, so we can
* safely select the first returned service. */
service = &(p_ble_gattc_evt->params.prim_srvc_disc_rsp.services[service_index]);
m_service_start_handle = service->handle_range.start_handle;
m_service_end_handle = service->handle_range.end_handle;
printf("UUID: 0x%04X, start handle: 0x%04X, end handle: 0x%04X\n",
service->uuid.uuid, m_service_start_handle, m_service_end_handle);
fflush(stdout);
int i;
int count;
ble_gattc_char_t * p_characteristic;
printf("Error. Characteristic discovery failed. Error code 0x%X\n",
fflush(stdout);
return;
count = p_ble_gattc_evt->params.char_disc_rsp.count;
printf("Received characteristic discovery response, characteristics count: %d\n", count);
fflush(stdout);
for (i = 0; i < count; i++)
p_characteristic = (ble_gattc_char_t *)&(p_ble_gattc_evt->params.char_disc_rsp.chars[i]);
printf("Handle: 0x%04X, UUID: 0x%04X\n",
p_characteristic->handle_decl,
p_characteristic->uuid.uuid);
fflush(stdout);
if (p_characteristic->uuid.uuid == HRM_MEAS_CHAR_UUID)
m_hrm_char_handle = p_characteristic->handle_decl;
int i;
int count;
ble_gattc_desc_t * p_descriptor;
printf("Error. Descriptor discovery failed. Error code 0x%X\n",
fflush(stdout);
return;
count = p_ble_gattc_evt->params.desc_disc_rsp.count;
printf("Received descriptor discovery response, descriptor count: %d\n", count);
fflush(stdout);
p_descriptor = (ble_gattc_desc_t *)&(p_ble_gattc_evt->params.desc_disc_rsp.descs[i]);
printf("Handle: 0x%04X, UUID: 0x%04X\n", p_descriptor->handle, p_descriptor->uuid.uuid);
fflush(stdout);
if (p_descriptor->uuid.uuid == CCCD_UUID)
m_hrm_cccd_handle = p_descriptor->handle;
printf("Press enter to toggle notifications\n"); fflush(stdout);
printf("Received write response.\n"); fflush(stdout);
printf("Error. Write operation failed. Error code 0x%X\n",
fflush(stdout);
return;
static void on_hvx(const ble_gattc_evt_t * const p_ble_gattc_evt)
int i = 0;
int length = p_ble_gattc_evt->params.hvx.len;
printf("Received handle value notification, handle: 0x%04X, value: 0x",
p_ble_gattc_evt->params.hvx.handle);
fflush(stdout);
for (i = 0; i < length; i++)
printf("%02X", p_ble_gattc_evt->params.hvx.data[i]);
fflush(stdout);
printf("\n"); fflush(stdout);
const int address_length = 6;
char temp_str[3];
int i = 0;
for (i = address_length - 1; i >= 0; --i)
snprintf(temp_str, sizeof(temp_str), "%02X", address.addr[i]);
strncat_s((char *)string_buffer, STRING_BUFFER_SIZE, temp_str,sizeof(temp_str));
uint8_t * p_data;
uint32_t index;
p_data = p_advdata->p_data;
index = 0;
while (index < p_advdata->data_len)
uint8_t field_length = p_data[index];
uint8_t field_type = p_data[index + 1];
if (field_type == type)
p_typedata->p_data = &p_data[index + 2];
p_typedata->data_len = field_length - 1;
return NRF_SUCCESS;
index += field_length + 1;
return NRF_ERROR_NOT_FOUND;
uint32_t err_code;
ble_enable_params_t ble_enable_params;
memset(&ble_enable_params, 0, sizeof(ble_enable_params));
ble_enable_params.gatts_enable_params.attr_tab_size = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
ble_enable_params.gatts_enable_params.service_changed = false;
err_code = sd_ble_enable(&ble_enable_params);
if (err_code == NRF_SUCCESS)
return err_code;
if (err_code == NRF_ERROR_INVALID_STATE)
printf("BLE stack already enabled\n"); fflush(stdout);
return NRF_SUCCESS;
printf("Failed to enable BLE stack.\n"); fflush(stdout);
return err_code;
uint32_t error_code = sd_ble_gap_scan_start(&m_scan_param);
if (error_code != NRF_SUCCESS)
printf("Scan start failed\n"); fflush(stdout);
return error_code;
printf("Scan started\n"); fflush(stdout);
return NRF_SUCCESS;
uint16_t start_handle;
uint32_t err_code;
ble_uuid_t srvc_uuid;
printf("Discovering primary services\n"); fflush(stdout);
start_handle = 0x0001;
srvc_uuid.type = BLE_UUID_TYPE_BLE;
srvc_uuid.uuid = HRM_SERVICE_UUID;
err_code = sd_ble_gattc_primary_services_discover(m_connection_handle, start_handle,
&srvc_uuid);
printf("Failed to discover primary services\n"); fflush(stdout);
return err_code;
return NRF_SUCCESS;
uint32_t err_code;
ble_gattc_handle_range_t handle_range;
printf("Discovering characteristics\n"); fflush(stdout);
handle_range.start_handle = m_service_start_handle;
handle_range.end_handle = m_service_end_handle;
err_code = sd_ble_gattc_characteristics_discover(m_connection_handle, &handle_range);
return err_code;
uint32_t err_code;
printf("Discovering descriptors\n"); fflush(stdout);
if (m_hrm_char_handle == 0)
printf("Error. No HRM characteristic handle has been found\n"); fflush(stdout);
handle_range.start_handle = m_hrm_char_handle;
err_code = sd_ble_gattc_descriptors_discover(m_connection_handle, &handle_range);
return err_code;
uint32_t err_code;
ble_gattc_write_params_t write_params;
uint8_t cccd_value[2] = { value, 0 };
printf("Setting HRM CCCD\n"); fflush(stdout);
if (m_hrm_cccd_handle == 0)
printf("Error. No CCCD handle has been found\n"); fflush(stdout);
write_params.handle = m_hrm_cccd_handle;
write_params.len = 2;
write_params.p_value = cccd_value;
write_params.write_op = BLE_GATT_OP_WRITE_REQ;
write_params.offset = 0;
err_code = sd_ble_gattc_write(m_connection_handle, &write_params);
return err_code;
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
if (p_ble_evt == NULL)
printf("Received empty ble_event\n"); fflush(stdout);
return;
case BLE_GAP_EVT_CONNECTED:
on_connected(&(p_ble_evt->evt.gap_evt));
printf("Disconnected, reason: 0x%02X\n", p_ble_evt->evt.gap_evt.params.disconnected.reason);
fflush(stdout);
m_connected_devices--;
case BLE_GAP_EVT_ADV_REPORT:
on_adv_report(&(p_ble_evt->evt.gap_evt));
case BLE_GAP_EVT_TIMEOUT:
on_timeout(&(p_ble_evt->evt.gap_evt));
case BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP:
on_service_discovery_response(&(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_CHAR_DISC_RSP:
on_characteristic_discover_response(&(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_DESC_DISC_RSP:
on_descriptor_discover_response(&(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_WRITE_RSP:
on_write_response(&(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_HVX:
on_hvx(&(p_ble_evt->evt.gattc_evt));
printf("Unhandled event with ID: %d\n", p_ble_evt->header.evt_id); fflush(stdout);
int main(int argc, char * argv[])
uint32_t error_code;
uint8_t cccd_value;
char * serial_port;
serial_port = UART_PORT_NAME;
printf("Serial port used: %s\n", serial_port); fflush(stdout);
sd_rpc_serial_port_name_set(serial_port);
sd_rpc_serial_baud_rate_set(115200);
sd_rpc_log_handler_set(log_handler);
sd_rpc_evt_handler_set(ble_evt_dispatch);
error_code = sd_rpc_open();
printf("Failed to open the nRF51 BLE Driver. Error code: 0x%02X\n", error_code);
fflush(stdout);
return error_code;
scan_start();
while (true)
getchar();
cccd_value ^= CCCD_NOTIFY;
hrm_cccd_set(cccd_value);
error_code = sd_rpc_close();
printf("Failed to close the nRF51 BLE Driver. Error code: 0x%02X\n", error_code);
fflush(stdout);
return error_code;
printf("Closed\n"); fflush(stdout);
return 0;
edit: Moved all the code into preformatted text. -Terje
