here is a brief description of my app with nrf9161DK (2.6.1 SDK, the app was built starting from the MQTT sample): The app is reading RTCM messages from a server via modem, sends them to GNSS via UART, then reads NMEA information from GNSS using the same UART and finally sends the data to a MQTT server via the modem.
I struggled with "FATAL ERROR: UsageFault" (initially, there was reset, then I made CONFIG_RESET_ON_FATAL_ERROR=n) which rather mysteriously occured regularly after 6 minutes from the app reset. I was, however, not able to debug any more detailed info about the root cause.
Among the advices I have found in this site, there was a suggestion to set CONFIG_TFM_PROFILE_TYPE_NOT_SET=y. And quite mysteriously, up to now, the error disappeared.
How could this be explained please? Below, there is FYI my cluttered prj.conf.
So currently, I have no pending issue, but I'd be happy to understand more what could happen here.
Thank you!
#### "debugging" ########################################## ### debug network timing # CONFIG_NET_LOG=y ### debug MQTT timing # CONFIG_MQTT_LOG_LEVEL_DBG=y ### increase LOG buffer size # CONFIG_LOG_BUFFER_SIZE=64000 ### debug optimizations (-Og) CONFIG_DEBUG=y CONFIG_DEBUG_OPTIMIZATIONS=y CONFIG_DEBUG_THREAD_INFO=y ### to try to debug unwanted soft resets (not resetting): CONFIG_RESET_ON_FATAL_ERROR=n # CONFIG_REBOOT=n # ### SECURE TFM logging ### disabling logging of TF-M # CONFIG_TFM_LOG_LEVEL_SILENCE=y ### forward TF-M secure logging to the same UART as application logging (comment the previous) CONFIG_TFM_SECURE_UART=y CONFIG_TFM_SECURE_UART_SHARE_INSTANCE=y CONFIG_TFM_SECURE_UART0=y CONFIG_TFM_PARTITION_LOG_LEVEL_DEBUG=y CONFIG_TFM_SPM_LOG_LEVEL_DEBUG=y # Dump exception info. Must be combined with enabling log output. CONFIG_TFM_EXCEPTION_INFO_DUMP=y ############################################################# # CONFIG_NEWLIB_LIBC_NANO=n ### Possible solution for Fatal error??? # Don't use the minimal TF-M configuration as that doesn't support logging CONFIG_TFM_PROFILE_TYPE_NOT_SET=y ### Memory CONFIG_MAIN_STACK_SIZE=2048 CONFIG_HEAP_MEM_POOL_SIZE=4096 CONFIG_ISR_STACK_SIZE=4096 # try to increase MODEM library heap size: # CONFIG_NRF_MODEM_LIB_HEAP_SIZE=4096 # Modem trace CONFIG_AT_HOST_LIBRARY=y # enable GPIO CONFIG_GPIO=y # enable uart driver CONFIG_SERIAL=y CONFIG_UART_ASYNC_API=y # if dynamic uart configuration needed CONFIG_UART_USE_RUNTIME_CONFIGURE=y # enable console CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y # Logging CONFIG_LOG=y # Newlib CONFIG_NEWLIB_LIBC=y # Networking CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y # Modem library CONFIG_NRF_MODEM_LIB=y # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT=y # MQTT CONFIG_MQTT_LIB=y CONFIG_MQTT_CLEAN_SESSION=y
