nRF5340 Not Receiving CAN Traffic
I'm developing a custom board with a uBlox NORA-B121 module, which contains an nRF5340.  The board has a Microchip MCP2515 CAN controller, and for some reason, I can't receive CAN data.  I can send it, the controller appears to receive correctly, and the result is transmitted on the SPI bus, but software never seems to recognize that something has been received.  I've been using the Zephyr CAN counter sample, slightly modified with hardware setup code and config to enable RTT and disable CAN loopback.  I have 2 of these units with CANH/CANL connected together, and termination enabled on one of the boards (my logic analyzer doesn't pick the data with termination on both ends, but CAN works well enough like this with a short bus at low speed.) The screenshots show transmit and receive sequences: the Tx command is sent on SPI, the frame is transmitted, the controller asserts its interrupt# line on completion, the 5340 reads and resets the interrupt flag, and the CAN controller deasserts interrupt#.  On receive (of a frame send from the other unit,) the CAN controller interrupts, the 5340 reads the interrupt flags, and receives the frame contents.  The CAN controller deasserts interrupt#, as the receive flag is automatically cleared by reading out the buffer contents.  I don't have an example of SPI traffic for this when it's working, but from reading the datasheet, this all looks right.  However, whether I use message queqes with can_add_rx_filter_msgq() or a callback with can_add_rx_filter(), the relevant callback or message queue monitor never triggers, and I can't get CAN traffic in Zephyr.
Transmit command and CAN transmission
Transmission complete interrupt and flag clear
CAN frame reception
Receive Interrupt and reading CAN data into nRF5340 via SPI
Relevant sections of the cpuapp_common.dtsi file from my BSP
chosen {
	zephyr,console = &uart0;
	zephyr,shell-uart = &uart0;
	zephyr,uart-mcumgr = &uart0;
	zephyr,bt-mon-uart = &uart0;
	zephyr,bt-uart = &uart0;
	zephyr,bt-c2h-uart = &uart0;
	zephyr,bt-hci-ipc = &ipc0;
	nordic,802154-spinel-ipc = &ipc0;
	zephyr,ieee802154 = &ieee802154;
	zephyr,canbus = &can0;
arduino_spi: &spi3 {
	status = "okay";
	cs-gpios = <&gpio0 27 GPIO_ACTIVE_LOW>; //CAN CS
	pinctrl-0 = <&spi3_default>;
	pinctrl-1 = <&spi3_sleep>;
	can0: can@0 {
		compatible = "microchip,mcp2515";
		spi-max-frequency = <1000000>;
		int-gpios = <&gpio1 14 GPIO_ACTIVE_LOW>; //CAN Interrupt
		status = "okay";
		reg = <0x0>;
		osc-freq = <20000000>;
		bus-speed = <250000>;
		sample-point = <875>;
		can-transceiver {
			max-bitrate = <1000000>;
main.c
 * Copyright (c) 2018 Alexander Wachter
#include <stdio.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/can.h>
#include <zephyr/sys/byteorder.h>
#define RX_THREAD_STACK_SIZE 512
#define RX_THREAD_PRIORITY 2
#define STATE_POLL_THREAD_STACK_SIZE 512
#define STATE_POLL_THREAD_PRIORITY 2
#define LED_MSG_ID 0x10
#define COUNTER_MSG_ID 0x12345
#define SET_LED 1
#define RESET_LED 0
#define SLEEP_TIME K_MSEC(250)
K_THREAD_STACK_DEFINE(rx_thread_stack, RX_THREAD_STACK_SIZE);
K_THREAD_STACK_DEFINE(poll_state_stack, STATE_POLL_THREAD_STACK_SIZE);
const struct device *const can_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_canbus));
struct gpio_dt_spec led = GPIO_DT_SPEC_GET_OR(DT_ALIAS(led0), gpios, {0});
struct k_thread rx_thread_data;
struct k_thread poll_state_thread_data;
struct k_work_poll change_led_work;
struct k_work state_change_work;
enum can_state current_state;
struct can_bus_err_cnt current_err_cnt;
CAN_MSGQ_DEFINE(change_led_msgq, 2);
CAN_MSGQ_DEFINE(counter_msgq, 2);
static struct k_poll_event change_led_events[1] = {
	K_POLL_EVENT_STATIC_INITIALIZER(K_POLL_TYPE_MSGQ_DATA_AVAILABLE,
					K_POLL_MODE_NOTIFY_ONLY,
					&change_led_msgq, 0)
void tx_irq_callback(const struct device *dev, int error, void *arg)
	char *sender = (char *)arg;
	ARG_UNUSED(dev);
	if (error != 0) {
		printf("Callback! error-code: %d\nSender: %s\n",
		       error, sender);
void rx_thread(void *arg1, void *arg2, void *arg3)
	ARG_UNUSED(arg1);
	ARG_UNUSED(arg2);
	ARG_UNUSED(arg3);
	const struct can_filter filter = {
		.flags = CAN_FILTER_DATA | CAN_FILTER_IDE,
		.id = COUNTER_MSG_ID,
		.mask = CAN_EXT_ID_MASK
	struct can_frame frame;
	int filter_id;
	filter_id = can_add_rx_filter_msgq(can_dev, &counter_msgq, &filter);
	printf("Counter filter id: %d\n", filter_id);
	while (1) {
		k_msgq_get(&counter_msgq, &frame, K_FOREVER);
		if (frame.dlc != 2U) {
			printf("Wrong data length: %u\n", frame.dlc);
			continue;
		printf("Counter received: %u\n",
		       sys_be16_to_cpu(UNALIGNED_GET((uint16_t *)&frame.data)));
void change_led_work_handler(struct k_work *work)
	int ret;
	while (k_msgq_get(&change_led_msgq, &frame, K_NO_WAIT) == 0) {
		if (led.port == NULL) {
			printf("LED %s\n", frame.data[0] == SET_LED ? "ON" : "OFF");
		} else {
			gpio_pin_set(led.port, led.pin, frame.data[0] == SET_LED ? 1 : 0);
	ret = k_work_poll_submit(&change_led_work, change_led_events,
				 ARRAY_SIZE(change_led_events), K_FOREVER);
	if (ret != 0) {
		printf("Failed to resubmit msgq polling: %d", ret);
char *state_to_str(enum can_state state)
	switch (state) {
	case CAN_STATE_ERROR_ACTIVE:
		return "error-active";
	case CAN_STATE_ERROR_WARNING:
		return "error-warning";
	case CAN_STATE_ERROR_PASSIVE:
		return "error-passive";
	case CAN_STATE_BUS_OFF:
		return "bus-off";
	case CAN_STATE_STOPPED:
		return "stopped";
		return "unknown";
void poll_state_thread(void *unused1, void *unused2, void *unused3)
	struct can_bus_err_cnt err_cnt = {0, 0};
	struct can_bus_err_cnt err_cnt_prev = {0, 0};
	enum can_state state_prev = CAN_STATE_ERROR_ACTIVE;
	enum can_state state;
	int err;
	while (1) {
		err = can_get_state(can_dev, &state, &err_cnt);
		if (err != 0) {
			printf("Failed to get CAN controller state: %d", err);
			k_sleep(K_MSEC(100));
			continue;
		if (err_cnt.tx_err_cnt != err_cnt_prev.tx_err_cnt ||
		    err_cnt.rx_err_cnt != err_cnt_prev.rx_err_cnt ||
		    state_prev != state) {
			err_cnt_prev.tx_err_cnt = err_cnt.tx_err_cnt;
			err_cnt_prev.rx_err_cnt = err_cnt.rx_err_cnt;
			state_prev = state;
			printf("state: %s\n"
			       "rx error count: %d\n"
			       "tx error count: %d\n",
			       state_to_str(state),
			       err_cnt.rx_err_cnt, err_cnt.tx_err_cnt);
		} else {
void state_change_work_handler(struct k_work *work)
	printf("State Change ISR\nstate: %s\n"
		state_to_str(current_state),
		current_err_cnt.rx_err_cnt, current_err_cnt.tx_err_cnt);
#ifndef CONFIG_CAN_AUTO_BUS_OFF_RECOVERY
	if (current_state == CAN_STATE_BUS_OFF) {
		printf("Recover from bus-off\n");
		if (can_recover(can_dev, K_MSEC(100)) != 0) {
			printf("Recovery timed out\n");
#endif /* CONFIG_CAN_AUTO_BUS_OFF_RECOVERY */
void state_change_callback(const struct device *dev, enum can_state state,
			   struct can_bus_err_cnt err_cnt, void *user_data)
	struct k_work *work = (struct k_work *)user_data;
	ARG_UNUSED(dev);
	current_state = state;
	current_err_cnt = err_cnt;
	k_work_submit(work);
int custom_hw_init(){
	static const struct gpio_dt_spec can_term = GPIO_DT_SPEC_GET(DT_ALIAS(cantermpin), gpios);
	static const struct gpio_dt_spec gps_mux1 = GPIO_DT_SPEC_GET(DT_ALIAS(gpsmux1pin), gpios);
	static const struct gpio_dt_spec gps_mux2 = GPIO_DT_SPEC_GET(DT_ALIAS(gpsmux2pin), gpios);
	static const struct gpio_dt_spec serial_en = GPIO_DT_SPEC_GET(DT_ALIAS(serialenpin), gpios);
	static const struct gpio_dt_spec gps_en = GPIO_DT_SPEC_GET(DT_ALIAS(gpsenpin), gpios);
	static const struct gpio_dt_spec S1_422 = GPIO_DT_SPEC_GET(DT_ALIAS(s1modepin), gpios);
	static const struct gpio_dt_spec S2_422 = GPIO_DT_SPEC_GET(DT_ALIAS(s2modepin), gpios);
	static const struct gpio_dt_spec S_spd = GPIO_DT_SPEC_GET(DT_ALIAS(serialspdpin), gpios);
	static const struct gpio_dt_spec ledgate = GPIO_DT_SPEC_GET(DT_ALIAS(led3), gpios);
	gpio_pin_configure_dt(&can_term, GPIO_OUTPUT_ACTIVE);
	gpio_pin_configure_dt(&gps_mux1, GPIO_OUTPUT_INACTIVE);
	gpio_pin_configure_dt(&gps_mux2, GPIO_OUTPUT_INACTIVE);
	gpio_pin_configure_dt(&serial_en, GPIO_OUTPUT_INACTIVE);
	gpio_pin_configure_dt(&gps_en, GPIO_OUTPUT_INACTIVE);
	gpio_pin_configure_dt(&S1_422, GPIO_OUTPUT_ACTIVE);
	gpio_pin_configure_dt(&S2_422, GPIO_OUTPUT_ACTIVE);
	gpio_pin_configure_dt(&S_spd, GPIO_OUTPUT_ACTIVE);
	gpio_pin_configure_dt(&ledgate, GPIO_OUTPUT_ACTIVE);
	return 0;
	const struct can_filter change_led_filter = {
		.flags = CAN_FILTER_DATA,
		.id = LED_MSG_ID,
		.mask = CAN_STD_ID_MASK
	struct can_frame change_led_frame = {
		.flags = 0,
		.id = LED_MSG_ID,
		.dlc = 1
	struct can_frame counter_frame = {
		.flags = CAN_FRAME_IDE,
		.dlc = 2
	uint8_t toggle = 1;
	uint16_t counter = 0;
	k_tid_t rx_tid, get_state_tid;
	int ret;
	custom_hw_init();
	if (!device_is_ready(can_dev)) {
		printf("CAN: Device %s not ready.\n", can_dev->name);
		return 0;
#ifdef CONFIG_LOOPBACK_MODE
	ret = can_set_mode(can_dev, CAN_MODE_LOOPBACK);
	if (ret != 0) {
		printf("Error setting CAN mode [%d]", ret);
		return 0;
	ret = can_start(can_dev);
	if (ret != 0) {
		printf("Error starting CAN controller [%d]", ret);
		return 0;
	if (led.port != NULL) {
		if (!gpio_is_ready_dt(&led)) {
			printf("LED: Device %s not ready.\n",
			       led.port->name);
			return 0;
		ret = gpio_pin_configure_dt(&led, GPIO_OUTPUT_HIGH);
		if (ret < 0) {
			printf("Error setting LED pin to output mode [%d]",
			       ret);
			led.port = NULL;
	k_work_init(&state_change_work, state_change_work_handler);
	k_work_poll_init(&change_led_work, change_led_work_handler);
	ret = can_add_rx_filter_msgq(can_dev, &change_led_msgq, &change_led_filter);
	if (ret == -ENOSPC) {
		printf("Error, no filter available!\n");
		return 0;
	printf("Change LED filter ID: %d\n", ret);
	if (ret != 0) {
		printf("Failed to submit msgq polling: %d", ret);
		return 0;
	rx_tid = k_thread_create(&rx_thread_data, rx_thread_stack,
				 K_THREAD_STACK_SIZEOF(rx_thread_stack),
				 rx_thread, NULL, NULL, NULL,
				 RX_THREAD_PRIORITY, 0, K_NO_WAIT);
	if (!rx_tid) {
		printf("ERROR spawning rx thread\n");
	get_state_tid = k_thread_create(&poll_state_thread_data,
					poll_state_stack,
					K_THREAD_STACK_SIZEOF(poll_state_stack),
					poll_state_thread, NULL, NULL, NULL,
					STATE_POLL_THREAD_PRIORITY, 0,
					K_NO_WAIT);
	if (!get_state_tid) {
		printf("ERROR spawning poll_state_thread\n");
	can_set_state_change_callback(can_dev, state_change_callback, &state_change_work);
	printf("Finished init.\n");
	while (1) {
		//change_led_frame.data[0] = toggle++ & 0x01 ? SET_LED : RESET_LED;
		change_led_frame.data[0] = 0x02; //debug
		/* This sending call is none blocking. */
		can_send(can_dev, &change_led_frame, K_FOREVER,
			 tx_irq_callback,
			 "LED change");
		k_sleep(SLEEP_TIME);
		UNALIGNED_PUT(sys_cpu_to_be16(counter),
			      (uint16_t *)&counter_frame.data[0]);
		counter++;
		/* This sending call is blocking until the message is sent. */
		can_send(can_dev, &counter_frame, K_MSEC(100), NULL, NULL);
  • Once you see the data going into the NRF MCU on the SPI lines, its a good idea to look at the actual mcp2515 driver source code.
    Maybe hook up a debugger and check what its doing. You probably missed some minor detail in the driver API, and reading the source usually makes this kind of issue obvious.
  • That's good advice, thank you.  After digging through the controller driver (and the nRFX SPIM driver,) I've found a few tings.  It looks like the interrupt code in the driver is triggered, but the interrupt flags don't make it there (the interrupt handler is fed 0x00 instead of the actual flag byte, 0x04.)  I'm trying to track this down through the SPI driver code, but it is crashing when I use printk very much, probably because this is timing sensitive code, and I'm inserting a bloated monster called printk into it.  The stack overflows/improper EPSR use/etc fatal errors have variously implicated timing code or the printk function.  I'm trying to find another way to extract data from here, probably by copying it elsewhere in memory, to then print it from a non timing critical context (main, some thread, etc.)  However, I don't know how to do this from a driver, when the OS has created several levels of separation between the driver and somewhere I can safely run complex code like printk.  Is there a good way to stick a pointer to my harvested data in memory somewhere, and then find and use it from some other, unrelated code?  I figure there has to be a system call to do this kind of thing.
    I also found that the ISO-TP sample does work, receiving data and everything, but I can't figure out what it's doing differently (or how it could be different, since they both use the same MCP2515 driver.)
  • I found the problem, I was using GPIO 0.00 as the CIPO of my SPI bus, which is one of the low frequency crystal oscillator (LFXO) pins.  The LFXO must be disabled with:
    CONFIG_SOC_ENABLE_LFXO=n
    to use this pin for other purposes.  CAN works properly now.
