I tested the matter LOCK sample, how to disconnect the Bluetooth connection immediately after matter commissioning is completed, the log is as follows. thanks.
uart:~$ *** Booting My Application v2.7.0 - unknown commit ***
*** Using nRF Connect SDK v2.7.0-5cb85570ca43 ***
*** Using Zephyr OS v3.6.99-100befc70c74 ***
I: No users indexes stored
I: No stored indexes for credential of type: 1
I: 57 [DL]CHIP task running
I: Init CHIP stack
I: 63 [DL]OpenThread started: OK
I: 65 [DL]Setting OpenThread device type to SLEEPY END DEVICE
I: 71 [SVR]Subscription persistence not supported
I: 75 [SVR]Server initializing...
I: 79 [TS]Last Known Good Time: [unknown]
I: 82 [TS]Setting Last Known Good Time to firmware build time 2023-10-14T01:16:48
I: 94 [DMG]AccessControl: initializing
I: 97 [DMG]Examples::AccessControlDelegate::Init
I: 101 [DMG]AccessControl: setting
I: 105 [DMG]DefaultAclStorage: initializing
I: 108 [DMG]DefaultAclStorage: 0 entries loaded
E: 113 [IN]IPV6_PKTINFO failed: 109
I: 128 [ZCL]Using ZAP configuration...
I: 133 [DMG]AccessControlCluster: initializing
I: 138 [ZCL]Initiating Admin Commissioning cluster.
I: 142 [ZCL]Door Lock server initialized
I: 146 [ZCL]Door Lock cluster initialized at endpoint #1
I: 151 [ZCL]0xac2be ep 1 clus 0x0000_0101 attr 0x0000_0013 not supported
E: 158 [ZCL]Failed to set DoorLock number of RFID users: 86
I: 163 [DIS]Updating services using commissioning mode 0
E: 168 [DIS]Failed to remove advertised services: 3
E: 172 [DIS]Failed to finalize service update: 3
I: 177 [IN]CASE Server enabling CASE session setups
I: 182 [SVR]Joining Multicast groups
I: 185 [SVR]Server Listening...
I: 188 [DL]Device Configuration:
I: 191 [DL] Serial Number: 11223344556677889900
I: 195 [DL] Vendor Id: 65521 (0xFFF1)
I: 199 [DL] Product Id: 32774 (0x8006)
I: 202 [DL] Product Name: not-specified
I: 206 [DL] Hardware Version: 0
I: 209 [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 215 [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 221 [DL] Manufacturing Date: (not set)
I: 225 [DL] Device Type: 65535 (0xFFFF)
I: 229 [SVR]SetupQRCode: [MT:8IXS142C00KA0648G00]
I: 234 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 240 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A8IXS142C00KA0648G00
I: 249 [SVR]Manual pairing code: [34970112332]
E: 253 [DL]Long dispatch time: 193 ms, for event type 2
uart:~$ I: BLE advertising is already enabled and active
I: 22546 [DL]Current number of connections: 1/1
I: 22551 [DL]BLE connection established (ConnId: 0x00)
I: 22556 [DL]CHIPoBLE advertising stopped
I: 22560 [DL]NFC Tag emulation stopped
I: 23252 [BLE]local and remote recv window sizes = 5
I: 23257 [BLE]selected BTP version 4
I: 23260 [BLE]using BTP fragment sizes rx 244 / tx 244.
I: 23373 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
I: 23434 [EM]>>> [E:29414r S:0 M:167471605] (U) Msg RX from 0:40CBD573537B908E [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
I: 23447 [EM]<<< [E:29414r S:0 M:186243255] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
I: 23459 [SVR]Commissioning session establishment step started
I: 23494 [EM]>>> [E:29414r S:0 M:167471606] (U) Msg RX from 0:40CBD573537B908E [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
I: 23631 [EM]<<< [E:29414r S:0 M:186243256] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2)
E: 23644 [DL]Long dispatch time: 151 ms, for event type 16388
I: 23704 [EM]>>> [E:29414r S:0 M:167471607] (U) Msg RX from 0:40CBD573537B908E [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
I: 23716 [EM]<<< [E:29414r S:0 M:186243257] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport)
I: 23730 [SC]SecureSession[0x20003900, LSID:39337]: State change 'kEstablishing' --> 'kActive'
I: 23738 [SVR]Commissioning completed session establishment step
I: 23744 [DIS]Updating services using commissioning mode 0
E: 23749 [DIS]Failed to remove advertised services: 3
E: 23754 [DIS]Failed to finalize service update: 3
I: 23759 [SVR]Device completed Rendezvous process
I: 23765 [EM]>>> [E:29415r S:39337 M:230913937] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
I: 23778 [EM]<<< [E:29415r S:39337 M:232363108] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
I: 23824 [EM]>>> [E:29416r S:39337 M:230913938] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
I: 23837 [EM]<<< [E:29416r S:39337 M:232363109] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
I: 23944 [EM]>>> [E:29417r S:39337 M:230913939] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
I: 23957 [EM]<<< [E:29417r S:39337 M:232363110] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
I: 24064 [EM]>>> [E:29418r S:39337 M:230913940] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
I: 24077 [EM]<<< [E:29418r S:39337 M:232363111] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
I: 24184 [EM]>>> [E:29419r S:39337 M:230913941] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
I: 24197 [EM]<<< [E:29419r S:39337 M:232363112] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
I: 24305 [EM]>>> [E:29420r S:39337 M:230913942] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
I: 24326 [EM]<<< [E:29420r S:39337 M:232363113] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData)
I: 24544 [EM]>>> [E:29421r S:39337 M:230913943] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 24557 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 24563 [EM]<<< [E:29421r S:39337 M:232363114] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 24664 [EM]>>> [E:29422r S:39337 M:230913944] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 24682 [EM]<<< [E:29422r S:39337 M:232363115] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 24784 [EM]>>> [E:29423r S:39337 M:230913945] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 24797 [ZCL]OpCreds: Certificate Chain request received for PAI
I: 24805 [EM]<<< [E:29423r S:39337 M:232363116] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 25144 [EM]>>> [E:29424r S:39337 M:230913946] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 25157 [ZCL]OpCreds: Certificate Chain request received for DAC
I: 25165 [EM]<<< [E:29424r S:39337 M:232363117] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 25564 [EM]>>> [E:29425r S:39337 M:230913947] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 25577 [ZCL]OpCreds: Received an AttestationRequest command
I: 25613 [ZCL]OpCreds: AttestationRequest successful.
I: 25621 [EM]<<< [E:29425r S:39337 M:232363118] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 25984 [EM]>>> [E:29426r S:39337 M:230913948] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 25997 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 26003 [EM]<<< [E:29426r S:39337 M:232363119] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 27184 [EM]>>> [E:29427r S:39337 M:230913949] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 27196 [ZCL]OpCreds: Received a CSRRequest command
I: 27262 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 27297 [ZCL]OpCreds: CSRRequest successful.
I: 27304 [EM]<<< [E:29427r S:39337 M:232363120] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
E: 27316 [DL]Long dispatch time: 133 ms, for event type 16388
I: 27664 [EM]>>> [E:29428r S:39337 M:230913950] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 27677 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
I: 27739 [ZCL]OpCreds: AddTrustedRootCertificate successful.
I: 27745 [EM]<<< [E:29428r S:39337 M:232363121] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 27965 [EM]>>> [E:29429r S:39337 M:230913951] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 27978 [ZCL]OpCreds: Received an AddNOC command
I: 27984 [FP]Validating NOC chain
I: 28044 [FP]NOC chain validation successful
I: 28048 [FP]Added new fabric at index: 0x1
I: 28052 [FP]Assigned compressed fabric ID: 0x6DEC3AF778E63B79, node ID: 0x00000000ACB89E51
I: 28060 [TS]Last Known Good Time: 2023-10-14T01:16:48
I: 28065 [TS]New proposed Last Known Good Time: 2024-09-01T04:10:48
I: 28071 [TS]Updating pending Last Known Good Time to 2024-09-01T04:10:48
I: 28102 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x0000000019363B86
I: 28111 [DIS]Advertise operational node 6DEC3AF778E63B79-00000000ACB89E51
I: 28118 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
I: 28125 [EM]<<< [E:29429r S:39337 M:232363122] (S) Msg TX to 1:FFFFFFFB00000000 [3B79] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
E: 28137 [DL]Long dispatch time: 174 ms, for event type 16388
I: 28205 [EM]>>> [E:29430r S:39337 M:230913952] (S) Msg RX from 1:FFFFFFFB00000000 [3B79] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 28224 [EM]<<< [E:29430r S:39337 M:232363123] (S) Msg TX to 1:FFFFFFFB00000000 [3B79] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 28324 [EM]>>> [E:29431r S:39337 M:230913953] (S) Msg RX from 1:FFFFFFFB00000000 [3B79] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 28337 [FS]GeneralCommissioning: Received ArmFailSafe (104s)
I: 28343 [EM]<<< [E:29431r S:39337 M:232363124] (S) Msg TX to 1:FFFFFFFB00000000 [3B79] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 28444 [EM]>>> [E:29432r S:39337 M:230913954] (S) Msg RX from 1:FFFFFFFB00000000 [3B79] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 30023 [DL]SRP Client was started, detected server: fdcd:72f9:be11:0000:0000:00ff:fe00:fc11
I: 30032 [ZCL]ThreadDiagnosticsDelegate: OnConnectionStatusChanged
I: 30041 [EM]<<< [E:29432r S:39337 M:232363125] (S) Msg TX to 1:FFFFFFFB00000000 [3B79] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 30054 [DIS]Advertise operational node 6DEC3AF778E63B79-00000000ACB89E51
I: 30061 [SVR]Operational advertising enabled
I: 30574 [SVR]Server initialization complete
I: 30578 [DIS]Updating services using commissioning mode 0
I: 30584 [DIS]Advertise operational node 6DEC3AF778E63B79-00000000ACB89E51
I: 30591 [DL]advertising srp service: 6DEC3AF778E63B79-00000000ACB89E51._matter._tcp
I: 32511 [EM]>>> [E:29433r S:0 M:167471608] (U) Msg RX from 0:7A350BD537E046BD [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 32522 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005588
I: 32530 [EM]<<< [E:29433r S:0 M:186243258 (Ack:167471608)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 32549 [SC]Received Sigma1 msg
I: 32558 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x00000000ACB89E51
I: 32649 [EM]<<< [E:29433r S:0 M:186243259 (Ack:167471608)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
I: 32667 [SC]Sent Sigma2 msg
I: 33209 [EM]>>> [E:29433r S:0 M:167471609 (Ack:186243259)] (U) Msg RX from 0:7A350BD537E046BD [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
I: 33223 [EM]<<< [E:29433r S:0 M:186243260 (Ack:167471609)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 33241 [SC]Received Sigma3 msg
E: 33249 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time
E: 33372 [DL]Long dispatch time: 113 ms, for event type 2
I: 33395 [EM]<<< [E:29433r S:0 M:186243261 (Ack:167471609)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0000:40 (SecureChannel:StatusReport)
I: 33416 [SC]SecureSession[0x20003830, LSID:39336]: State change 'kEstablishing' --> 'kActive'
I: 33425 [IN]CASE Session established to peer: <0000000019363B86, 1>
I: 33586 [EM]>>> [E:29434r S:39336 M:253392250] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 33601 [FS]GeneralCommissioning: Received CommissioningComplete
I: 33616 [FP]Metadata for Fabric 0x1 persisted to storage.
I: 33637 [TS]Committing Last Known Good Time to storage: 2024-09-01T04:10:48
I: 33650 [ZCL]OpCreds: Fabric index 0x1 was committed to storage. Compressed Fabric Id 0x6DEC3AF778E63B79, FabricId 000000006CA20564, NodeId 00000000ACB89E51, VendorId 0x1349
I: 33667 [FS]GeneralCommissioning: Successfully commited pending fabric data
I: 33674 [FS]Fail-safe cleanly disarmed
I: 33679 [EM]<<< [E:29434r S:39336 M:31939385 (Ack:253392250)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 33698 [SVR]Commissioning completed successfully
I: 33703 [DIS]Updating services using commissioning mode 0
I: 33708 [DIS]Advertise operational node 6DEC3AF778E63B79-00000000ACB89E51
I: 33715 [SC]SecureSession[0x20003900, LSID:39337]: State change 'kActive' --> 'kPendingEviction'
I: 33724 [BLE]Releasing end point's BLE connection back to application.
I: 33731 [DL]Closing BLE GATT connection (ConnId 00)
I: 33738 [EM]>>> [E:29433r S:0 M:167471610 (Ack:186243261)] (U) Msg RX from 0:7A350BD537E046BD [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 33831 [EM]>>> [E:29434r S:39336 M:253392251 (Ack:31939385)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 33952 [EM]>>> [E:29435r S:39336 M:253392252] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 33965 [EM]<<< [E:29435r S:39336 M:31939386 (Ack:253392252)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 34157 [EM]>>> [E:29435r S:39336 M:253392253 (Ack:31939386)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 34175 [EM]>>> [E:29436r S:39336 M:253392254] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 34188 [EM]<<< [E:29436r S:39336 M:31939387 (Ack:253392254)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 34370 [EM]>>> [E:29436r S:39336 M:253392255 (Ack:31939387)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 34490 [EM]>>> [E:29437r S:39336 M:253392256] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 34503 [EM]<<< [E:29437r S:39336 M:31939388 (Ack:253392256)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 34790 [EM]>>> [E:29437r S:39336 M:253392257 (Ack:31939388)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 34912 [EM]>>> [E:29438r S:39336 M:253392258] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 34925 [EM]<<< [E:29438r S:39336 M:31939389 (Ack:253392258)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 35131 [EM]>>> [E:29438r S:39336 M:253392259 (Ack:31939389)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 35148 [EM]>>> [E:29439r S:39336 M:253392260] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 35161 [EM]<<< [E:29439r S:39336 M:31939390 (Ack:253392260)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 35449 [EM]>>> [E:29439r S:39336 M:253392261 (Ack:31939390)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 35569 [EM]>>> [E:29440r S:39336 M:253392262] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 35582 [EM]<<< [E:29440r S:39336 M:31939391 (Ack:253392262)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 35780 [EM]>>> [E:29440r S:39336 M:253392263 (Ack:31939391)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 35797 [EM]>>> [E:29441r S:39336 M:253392264] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 35810 [EM]<<< [E:29441r S:39336 M:31939392 (Ack:253392264)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 35993 [EM]>>> [E:29441r S:39336 M:253392265 (Ack:31939392)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 36116 [EM]>>> [E:29442r S:39336 M:253392266] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 36129 [EM]<<< [E:29442r S:39336 M:31939393 (Ack:253392266)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 36324 [EM]>>> [E:29442r S:39336 M:253392267 (Ack:31939393)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 36342 [EM]>>> [E:29443r S:39336 M:253392268] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 36355 [EM]<<< [E:29443r S:39336 M:31939394 (Ack:253392268)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 36598 [EM]>>> [E:29443r S:39336 M:253392269 (Ack:31939394)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 36617 [EM]>>> [E:29444r S:39336 M:253392270] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 36630 [EM]<<< [E:29444r S:39336 M:31939395 (Ack:253392270)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 36811 [EM]>>> [E:29444r S:39336 M:253392271 (Ack:31939395)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 36829 [EM]>>> [E:29445r S:39336 M:253392272] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 36842 [EM]<<< [E:29445r S:39336 M:31939396 (Ack:253392272)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 37127 [EM]>>> [E:29445r S:39336 M:253392273 (Ack:31939396)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 37246 [EM]>>> [E:29446r S:39336 M:253392274] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 37262 [EM]<<< [E:29446r S:39336 M:31939397 (Ack:253392274)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 37282 [EM]>>> [E:29447r S:39336 M:253392275] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 37296 [EM]<<< [E:29447r S:39336 M:31939398 (Ack:253392275)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 37466 [EM]>>> [E:29446r S:39336 M:253392276 (Ack:31939397)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 37660 [EM]>>> [E:29447r S:39336 M:253392277 (Ack:31939398)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 37677 [EM]>>> [E:29448r S:39336 M:253392278] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:02 (IM:ReadRequest)
I: 37691 [EM]<<< [E:29448r S:39336 M:31939399 (Ack:253392278)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:05 (IM:ReportData)
I: 37884 [EM]>>> [E:29448r S:39336 M:253392279 (Ack:31939399)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 38763 [DL]Current number of connections: 0/1
I: 38768 [DL]BLE GAP connection terminated (reason 0x22)
I: 38876 [EM]>>> [E:29449r S:39336 M:253392280] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 38889 [FS]GeneralCommissioning: Received ArmFailSafe (30s)
I: 38896 [EM]<<< [E:29449r S:39336 M:31939400 (Ack:253392280)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 39073 [EM]>>> [E:29449r S:39336 M:253392281 (Ack:31939400)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 39098 [EM]>>> [E:29450r S:39336 M:253392282] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 39111 [ZCL]OpCreds: Received a CSRRequest command
I: 39116 [EM]<<< [E:29450r S:39336 M:31939401 (Ack:253392282)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 39198 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 39233 [ZCL]OpCreds: CSRRequest successful.
I: 39239 [EM]<<< [E:29450r S:39336 M:31939402 (Ack:253392282)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 39507 [EM]>>> [E:29450r S:39336 M:253392283 (Ack:31939402)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 39570 [EM]>>> [E:29451r S:39336 M:253392284] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 39582 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
I: 39589 [EM]<<< [E:29451r S:39336 M:31939403 (Ack:253392284)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 39665 [ZCL]OpCreds: AddTrustedRootCertificate successful.
I: 39672 [EM]<<< [E:29451r S:39336 M:31939404 (Ack:253392284)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 39966 [EM]>>> [E:29451r S:39336 M:253392285 (Ack:31939404)] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 40032 [EM]>>> [E:29452r S:39336 M:253392286] (S) Msg RX from 1:0000000019363B86 [3B79] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 40044 [ZCL]OpCreds: Received an AddNOC command
I: 40050 [EM]<<< [E:29452r S:39336 M:31939405 (Ack:253392286)] (S) Msg TX to 1:0000000019363B86 [3B79] [UDP:[fdcd:72f9:be11:a34a:43e:b6dd:ac0:ce1e]:59599] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 40072 [FP]Validating NOC chain
I: 40132 [FP]NOC chain validation successful
I: 40136 [FP]Added new fabric at index: 0x2
I: 40140 [FP]Assigned compressed fabric ID: 0x7B9AEB7B1B2F1E40, node ID: 0x00000000295282F6
I: 40148 [TS]Last Known Good Time: 2024-09-01T04:10:48
I: 40153 [TS]New proposed Last Known Good Time: 2024-09-01T04:11:00
I: 40159 [TS]Updating pending Last Known Good Time to 2024-09-01T04:11:00
I: 40188 [ZCL]OpCreds: ACL entry created for Fabric index 0x2 CASE Admin Subject 0x000000002B65DDF2
I: 40197 [DIS]Advertise operational node 6DEC3AF778E63B79-00000000ACB89E51
I: 40204 [DIS]Advertise operational node 7B9AEB7B1B2F1E40-00000000295282F6
I: 40211 [DL]advertising srp service: 7B9AEB7B1B2F1E40-00000000295282F6._matter._tcp
I: 40219 [ZCL]OpCreds: successfully created fabric index 0x2 via AddNOC
