Initializing MQTT helper library takes system into MPU fault
Hi, I am using nrf9160 with aws_iot library with zeyphros
Now the issue is when aws is initalized I get mpu fault, I have tracked down that issue is coming from mqtt helper library, the way I tracked it down is I ditch aws library and directly started using mqtt helper library and the issue persists and to further track down the issue from where it was coming, I then used simple mqtt library, now simple mqtt library works fine the issue arrives when I try to find ip address for the broker links here the sample code. This piece of code takes the controller into MPU fault
/**@brief Resolves the configured hostname and
 * initializes the MQTT broker structure
static int broker_init(void)
	int err;
	struct addrinfo *result;
	struct addrinfo *addr;
	struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_STREAM
	err = getaddrinfo(CONFIG_MQTT_BROKER_HOSTNAME, NULL, &hints, &result);
	if (err) {
		LOG_ERR("getaddrinfo failed: %d", err);
		return -ECHILD;
	addr = result;
	/* Look for address of the broker. */
	while (addr != NULL) {
		/* IPv4 Address. */
		if (addr->ai_addrlen == sizeof(struct sockaddr_in)) {
			struct sockaddr_in *broker4 =
				((struct sockaddr_in *)&broker);
			char ipv4_addr[NET_IPV4_ADDR_LEN];
			broker4->sin_addr.s_addr =
				((struct sockaddr_in *)addr->ai_addr)
				->sin_addr.s_addr;
			broker4->sin_family = AF_INET;
			broker4->sin_port = htons(CONFIG_MQTT_BROKER_PORT);
			inet_ntop(AF_INET, &broker4->sin_addr.s_addr,
				  ipv4_addr, sizeof(ipv4_addr));
			LOG_INF("IPv4 Address found %s", log_strdup(ipv4_addr));
		} else {
			LOG_ERR("ai_addrlen = %u should be %u or %u",
				(unsigned int)addr->ai_addrlen,
				(unsigned int)sizeof(struct sockaddr_in),
				(unsigned int)sizeof(struct sockaddr_in6));
		addr = addr->ai_next;
	/* Free the address. */
	freeaddrinfo(result);
	return err;
Now getting back to aws library which in the backend using mqtt helper library which runs this specific code to find brokers ip address.
Here is my code
#include <zephyr/kernel.h>
#include <zephyr/sys/reboot.h>
#include <zephyr/dfu/mcuboot.h>
#include <zephyr/logging/log_ctrl.h>
#include <zephyr/net/net_if.h>
#include <zephyr/net/net_core.h>
#include <zephyr/net/net_context.h>
#include <zephyr/net/net_mgmt.h>
#include <zephyr/net/socket.h>
#include <zephyr/net/conn_mgr_connectivity.h>
#include <zephyr/net/conn_mgr_monitor.h>
#include <net/aws_iot.h>
#include <stdio.h>
#include <stdlib.h>
#include <hw_id.h>
#include "json_payload.h"
LOG_MODULE_REGISTER(app_aws);
#define CONFIG_AWS_IOT_SAMPLE_APP_VERSION "v1.0.0"
/* Application specific topics. */
#define MY_CUSTOM_TOPIC_1 "my-custom-topic/example"
#define MY_CUSTOM_TOPIC_2 "my-custom-topic/example_2"
/* Variable used to store the device's hardware ID. */
static char hw_id[HW_ID_LEN];
static bool connected;
/* Event handlers */
static void aws_iot_event_handler(const struct aws_iot_evt *const evt)
	switch (evt->type) {
	case AWS_IOT_EVT_CONNECTING:
		LOG_INF("AWS_IOT_EVT_CONNECTING");
	case AWS_IOT_EVT_CONNECTED:
		LOG_INF("AWS_IOT_EVT_CONNECTED");
		//on_aws_iot_evt_connected(evt);
        connected = true;
	case AWS_IOT_EVT_DISCONNECTED:
		LOG_INF("AWS_IOT_EVT_DISCONNECTED");
		//on_aws_iot_evt_disconnected();
        connected = false;
	case AWS_IOT_EVT_DATA_RECEIVED:
		LOG_INF("AWS_IOT_EVT_DATA_RECEIVED");
		LOG_INF("Received message: \"%.*s\" on topic: \"%.*s\"", evt->data.msg.len,
									 evt->data.msg.ptr,
									 evt->data.msg.topic.len,
									 evt->data.msg.topic.str);
	case AWS_IOT_EVT_PUBACK:
		LOG_INF("AWS_IOT_EVT_PUBACK, message ID: %d", evt->data.message_id);
	case AWS_IOT_EVT_PINGRESP:
		LOG_INF("AWS_IOT_EVT_PINGRESP");
	case AWS_IOT_EVT_FOTA_START:
		LOG_INF("AWS_IOT_EVT_FOTA_START");
	case AWS_IOT_EVT_FOTA_ERASE_PENDING:
		LOG_INF("AWS_IOT_EVT_FOTA_ERASE_PENDING");
	case AWS_IOT_EVT_FOTA_ERASE_DONE:
		LOG_INF("AWS_FOTA_EVT_ERASE_DONE");
	case AWS_IOT_EVT_FOTA_DONE:
		LOG_INF("AWS_IOT_EVT_FOTA_DONE");
		//on_aws_iot_evt_fota_done(evt);
	case AWS_IOT_EVT_FOTA_DL_PROGRESS:
		LOG_INF("AWS_IOT_EVT_FOTA_DL_PROGRESS, (%d%%)", evt->data.fota_progress);
	case AWS_IOT_EVT_ERROR:
		LOG_INF("AWS_IOT_EVT_ERROR, %d", evt->data.err);
		//FATAL_ERROR();
	case AWS_IOT_EVT_FOTA_ERROR:
		LOG_INF("AWS_IOT_EVT_FOTA_ERROR");
		LOG_WRN("Unknown AWS IoT event type: %d", evt->type);
static int app_topics_subscribe(void)
	int err;
	static const struct mqtt_topic topic_list[] = {
			.topic.utf8 = MY_CUSTOM_TOPIC_1,
			.topic.size = strlen(MY_CUSTOM_TOPIC_1),
			.qos = MQTT_QOS_1_AT_LEAST_ONCE,
			.topic.utf8 = MY_CUSTOM_TOPIC_2,
			.topic.size = strlen(MY_CUSTOM_TOPIC_2),
	err = aws_iot_application_topics_set(topic_list, ARRAY_SIZE(topic_list));
	if (err) {
		LOG_ERR("aws_iot_application_topics_set, error: %d", err);
		return err;
	return 0;
static int aws_iot_client_init(void)
	int err;
	err = aws_iot_init(aws_iot_event_handler);
	if (err) {
		LOG_ERR("AWS IoT library could not be initialized, error: %d", err);
		return err;
	/* Add application specific non-shadow topics to the AWS IoT library.
	 * These topics will be subscribed to when connecting to the broker.
	err = app_topics_subscribe();
	if (err) {
		LOG_ERR("Adding application specific topics failed, error: %d", err);
		return err;
	return 0;
    int app_aws_client_init()
    int err;
    err = aws_iot_client_init();
	if (err) {
		LOG_ERR("aws_iot_client_init, error: %d", err);
		return err;
int app_aws_init()
	LOG_INF("The AWS IoT sample started, version: %s", CONFIG_AWS_IOT_SAMPLE_APP_VERSION);
	int err;
	/* Get unique hardware ID, can be used as AWS IoT MQTT broker device/client ID. */
	err = hw_id_get(hw_id, ARRAY_SIZE(hw_id));
	if (err) {
		LOG_ERR("Failed to retrieve hardware ID, error: %d", err);
		return err;
	LOG_INF("Hardware ID: %s", hw_id);
	const struct aws_iot_config config = {
		.client_id = hw_id,
	LOG_INF("Connecting to AWS IoT");
 int rc, i = 0;
 while (i++ < 10 && !connected) {
	err = aws_iot_connect(&config);
         k_msleep(500);
	if (err == -EAGAIN) {
        LOG_INF("Connection attempt timed out");
        k_msleep(300);
	} else if (err) {
		LOG_ERR("aws_iot_connect, error: %d", err);
        return err;
Main.c
#include <stdlib.h>
#include <zephyr/device.h>
LOG_MODULE_REGISTER(Main);
#include <app_network.h>
#include <app_mqtt.h>
#include "app_aws.h"
int aws_client;
          LOG_INF("Main started .... ");
 /* Init network */
    app_net_init();
aws_client = app_aws_client_init();
       while (true)
        struct app_event evt = {0};
        app_event_manager_get(&evt);
        switch (evt.type)
        case APP_EVENT_ETHERNET_READY:
            LOG_INF("Ethernet is Ready");
            //app_mqtt_init();
            if(!aws_client)
                app_aws_init();
             LOG_INF("aws client issue");
        return 0;
.conf file
# GPIO
CONFIG_GPIO=y
# Logging
CONFIG_LOG=y
CONFIG_CONSOLE=y
#CONFIG_LOG_BUFFER_SIZE=2048
CONFIG_HW_ID_LIBRARY=y
CONFIG_JSON_LIBRARY=y
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=10240
CONFIG_MAIN_STACK_SIZE=10240
#CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048
# Newlibc
CONFIG_NEWLIB_LIBC=y
# Ethernet
CONFIG_SPI=y
CONFIG_NET_L2_ETHERNET=y
CONFIG_ETH_W5500=y
CONFIG_ETH_W5500_TIMEOUT=10000
CONFIG_ETHERNET_LOG_LEVEL_DBG=y
CONFIG_ETHERNET_LOG_LEVEL_INF=y
CONFIG_NETWORKING=y
CONFIG_NET_IPV6=n
CONFIG_NET_IPV4=y
CONFIG_NET_ARP=y
CONFIG_NET_UDP=y
CONFIG_NET_DHCPV4=y
CONFIG_NET_DHCPV4_OPTION_CALLBACKS=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_TCP=y
CONFIG_NET_CONNECTION_MANAGER=y
CONFIG_NET_CONNECTION_MANAGER_MONITOR_STACK_SIZE=1024
CONFIG_DNS_RESOLVER=y
CONFIG_DNS_SERVER_IP_ADDRESSES=y
CONFIG_DNS_SERVER1="8.8.8.8"
# CONFIG_NET_CONFIG_NEED_IPV4=y
# CONFIG_NET_CONFIG_SETTINGS=y
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_INIT_STACKS=y
CONFIG_NET_MGMT=y
CONFIG_NET_MGMT_EVENT=y
CONFIG_NET_LOG=y
#CONFIG_SLIP_STATISTICS=n
CONFIG_NET_SHELL=y
# AWS IoT library
CONFIG_AWS_IOT=y
CONFIG_AWS_IOT_CLIENT_ID_STATIC="aws_nrf9160"
CONFIG_AWS_IOT_BROKER_HOST_NAME="xxx.amazonaws.com"
CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y
CONFIG_AWS_IOT_TOPIC_GET_ACCEPTED_SUBSCRIBE=y
CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=y
# MQTT helper library
CONFIG_MQTT_HELPER=y
CONFIG_MQTT_HELPER_SEC_TAG=201
CONFIG_MQTT_HELPER_LAST_WILL=y
CONFIG_MQTT_HELPER_STACK_SIZE=4096
# MQTT - Maximum MQTT keepalive timeout specified by AWS IoT Core
CONFIG_MQTT_KEEPALIVE=1200
CONFIG_MQTT_CLEAN_SESSION=y
And my output
now output shows that main thread failed but in my .conf file you can see I have allocated alot of space for heap and main thread as well and it still fails. I am lost at this part.
UPDATE:
I solved this issue, in .conf file I had to turn of CONFIG_NET_SOCKETS_OFFLOAD for some reason this was causing the issue and making system go into MPU fault
Now I am facing the issue that nrf9160 is not connecting to AWS IOT
