We are using two nRF54l15-PDF to communicate as SPI, one is in master mode and one is in slave mode. The master device sends a simple array of bytes, the first one being incremented at each transaction. The other one simply receive the data using the blocking spi_read_dt function.
The slave receives the data correctly exactly when the master writes, we can see it by having two RTT connected at the same time on each. However, it looks like the slave can either lose a message or get the same one between successives calls to spi_read_dt function.
Examples shown:
master
00> [00:57:45.720,154] <inf> main: sending a message with byte 0xb6 00> [00:57:50.720,554] <inf> main: sending a message with byte 0xb7 00> [00:57:55.720,954] <inf> main: sending a message with byte 0xb8 00> [00:58:00.721,354] <inf> main: sending a message with byte 0xb9 00> [00:58:05.721,754] <inf> main: sending a message with byte 0xba 00> [00:58:10.722,154] <inf> main: sending a message with byte 0xbb 00> [00:58:15.722,554] <inf> main: sending a message with byte 0xbc
slave
[00:04:24.112,272] <inf> main: first bytes received: 0xb6, 0x0 [00:04:24.112,422] <inf> main: client waiting for data... [00:04:29.112,578] <inf> main: first bytes received: 0xb6, 0x0 [00:04:29.112,729] <inf> main: client waiting for data... [00:04:34.112,885] <inf> main: first bytes received: 0xb8, 0x0 [00:04:34.113,035] <inf> main: client waiting for data... [00:04:39.113,191] <inf> main: first bytes received: 0xb8, 0x0 [00:04:39.113,341] <inf> main: client waiting for data... [00:04:44.113,497] <inf> main: first bytes received: 0xba, 0x0 [00:04:44.113,646] <inf> main: client waiting for data... [00:04:49.113,804] <inf> main: first bytes received: 0xba, 0x0 [00:04:49.113,954] <inf> main: client waiting for data... [00:04:54.114,111] <inf> main: first bytes received: 0xbc, 0x0 [00:04:54.114,261] <inf> main: client waiting for data...
This is the master code
#include <stdint.h>
#include <string.h>
#include <zephyr/drivers/spi.h>
#define LEN 130
#define M_NODE DT_NODELABEL(sub)
#define M_OP SPI_WORD_SET(8) | SPI_TRANSFER_LSB | SPI_OP_MODE_MASTER
static const struct spi_dt_spec spi = SPI_DT_SPEC_GET(M_NODE, M_OP, 0);
LOG_MODULE_REGISTER(main);
uint8_t rx_data[LEN], tx_data[LEN];
uint8_t byte = 0;
int rv;
struct spi_buf rx_buf = {
.buf = rx_data,
.len = sizeof (rx_data)
struct spi_buf_set rx_set = {
.buffers = &rx_buf,
.count = 1
struct spi_buf tx_buf = {
.buf = tx_data,
.len = sizeof (tx_data)
struct spi_buf_set tx_set = {
.buffers = &tx_buf,
.count = 1
if (!spi_is_ready_dt(&spi)) {
LOG_ERR("SPI device not ready");
return 1;
for (;;) {
memset(rx_data, 0, sizeof (rx_data));
memset(tx_data, 0, sizeof (tx_data));
tx_data[0] = ++byte;
LOG_INF("sending a message with byte 0x%x", (unsigned)tx_data[0]);
rv = spi_transceive_dt(&spi, &tx_set, &rx_set);
if (rv != 0)
LOG_WRN("SPI error: %s", strerror(rv));
k_msleep(5000);
And this is the slave code
#include <stdint.h>
#include <string.h>
#define LEN 130
#define S_NODE DT_NODELABEL(main)
#define S_OP SPI_WORD_SET(8) | SPI_TRANSFER_LSB | SPI_OP_MODE_SLAVE
static const struct spi_dt_spec spi = SPI_DT_SPEC_GET(S_NODE, S_OP, 0);
uint8_t rx_data[LEN], tx_data[LEN] = {0xaa, 0xbb};
int rv;
.buf = rx_data,
.buffers = &rx_buf,
.count = 1
.buf = tx_data,
.buffers = &tx_buf,
.count = 1
return 1;
for (;;) {
LOG_INF("client waiting for data...");
if (rv < 0 && rv != -EAGAIN)
LOG_INF("first bytes received: 0x%x, 0x%x", (unsigned)rx_data[0], rx_data[1]);
Finally, master and slave devicetree overlays respectively:
master
aliases {
spi = &spi;
&pinctrl {
spi_default: spi_default {
group1 {
psels = <NRF_PSEL(SPIM_SCK, 2, 6)>,
<NRF_PSEL(SPIM_MOSI, 2, 8)>,
<NRF_PSEL(SPIM_MISO, 2, 9)>;
bias-pull-down;
spi_sleep: spi_sleep {
group1 {
low-power-enable;
spi: &spi00 {
status = "okay";
pinctrl-0 = <&spi_default>;
pinctrl-1 = <&spi_sleep>;
cs-gpios = <&gpio2 10 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
sub: sub@0 {
status = "okay";
compatible = "vnd,spi-device";
reg = <0>;
spi-max-frequency = <10000000>;
label = "sub";
&uart20 {
status = "disabled";
slave
aliases {
spi = &spidev;
&pinctrl {
spidev_default: spidev_default {
group1 {
psels = <NRF_PSEL(SPIS_MOSI, 1, 4)>,
<NRF_PSEL(SPIS_MISO, 1, 6)>,
<NRF_PSEL(SPIS_SCK, 1, 11)>,
<NRF_PSEL(SPIS_CSN, 1, 12)>;
spidev_sleep: spidev_sleep {
group1 {
low-power-enable;
spidev: &spi20 {
/delete-property/ rx-delay;
/delete-property/ rx-delay-supported;
status = "okay";
compatible = "nordic,nrf-spis";
pinctrl-0 = <&spidev_default>;
pinctrl-1 = <&spidev_sleep>;
def-char = <0x00>;
main: main@0 {
label = "main";
reg = <0>;
status = "okay";
&uart20 {
Are we missing something obvious? Is this behavior caused by the SPI experimental slave support in zephyr? I also have seen that CS GPIO control is not supported by the nRF slave SPI driver, but CSN is used though.
