Why Serial LTE modem(SLM)doesn't work on SIAA.
Hi.
I wrote a firmware on nrf9160(SIAA chip), but it doesn't work.
On the hardware side, the circuit is same as that of nrf9160-DK, CTS and RTS is short respectively.
If the firmware is normal, I'll expect the firmware transmits "Ready".
But, I activate the circuit, when the firmware doesn't transmit "Ready" from TX.
I explain how to make firmware as below.
The firmware consists of two type firmware , a modem firmware and an application one.
The modem firmware version is 'mfw_nrf9160_1.3.6.zip' , written with Programmer (v4.3.0) from nrfConnect Desktop.
While, I built an application firmware of Serial LTE Modem with nRF Connect SDK (v2.7.9-rc2) .
I added "CONFIG_SLM_GNSS=n" in prj.conf file because it doesn't use GNSS.
Does the firmware requires anything else for normally working on SIAA ?
Best regards.
    does this work with other hardware versions? Can you show the log?
    I confirmed SICA chip works normally, but it won't long an hour.
    SIAA chip has no response.
    On the other side, SICA, I can show the log below, I omitted the personal information as "..." .
    Should I add any other option in prj.conf ?
    I use TLS session. When I use modem side TLS, I failed to upload on SIAA (SICA is successful).
    Best regards.
    AT%CMNG=0,222,0,"
    -----BEGIN CERTIFICATE-----
    -----END CERTIFICATE-----"
     <-LTE(236 - 167) : Ready[OK]
     AT%XSYSTEMMODE=1,0,0,0
    OK
    AT+CGDCONT=0,"IP","..."
    OK
    AT+CFUN=1
    OK
    AT+CGDCONT?
    +CGDCONT: 0,"IP","...","",0,0
    OK
    AT+CGDCONT?
    +CGDCONT: 0,"IP","...","MMM.NNN.OOO.PPP",0,0
    OK
    AT#XHTTPCCON=1,"....amazonaws.com",443,222
    #XHTTPCCON: 1
    OK
    AT#XHTTPCREQ="POST","...","User-Agent: slm\r\naccept: */*\r\n","2024/08/01 10:00:39,...,...",32
    OK
    #XHTTPCREQ: 1
    2024/08/24 16:54:39,WLA-051,28.6
    #XDATAMODE: 0
    #XHTTPCREQ: 0
    HTTP/1.1 200 OK
    Date: Thu, 01 Aug 2024 01:35:43 GMT
    Content-Type: application/json
    Content-Length: 26
    Connection: keep-alive
    x-amzn-RequestId: d9caa529-f671-43f6-b204-0adff4aca122
    x-amz-apigw-id: bzjxVHqnNjMEDCA=
    X-Amzn-Trace-Id: Root=1-66aae5f1-4c2814ed165b9d8b153655d0;Parent=1dcfaf7248eacb1d;Sampled=0;lineage=7656a112:0
    #XHTTPCRSP:334,1
    CSV Processed Successfully
    #XHTTPCRSP:26,1
  • I would advice you to capture a modem trace then.
