nrf52840 capture security level negotiation
I am using a nrf52840 dongle. I have my own device which has BLE and I am connecting to an app in mobile phone our bluetooth. My goal is to check for the security level what my device has and when it's getting connected with app I was trying to find if there is any security negotiation. To check this I am using the nrf52840 dongle for bluetooth sniffing so that I can check for the security negotiation.
Based on this link I followed all the steps https://academy.nordicsemi.com/courses/bluetooth-low-energy-fundamentals/lessons/lesson-6-bluetooth-le-sniffer/topic/nrf-sniffer-for-bluetooth-le/
I have flashed firmware 4.1.1 version.
I get the PDU type as 0x08
In documentation there is nothing referencing to Packet ID 0x08. It says security level error and CRC is bad wanted to understand more on this.
Also how to check for security level negotiation which packet should I look for specifically? Also with the firmware version 4.1.1 can I get to know the security negotiation?
  • complete_connection.pcapng
    This logs are from Android phone to my device.
    complete_connection_iphone.pcapng
     The logs when I connect iphone says insufficient authentication what could be the reason
     hope this is what you're expecting
    Thanks for the trace. I can read it now.
    Could you tell which device was used in the test ? Did it run on our chip ?
    In the Android trace, I don't see any response from the peripheral about Insufficient Authentication. This mean you may want to configure the characteristic to require encryption. This way it will force the phone to pair.
    In the iPhone trace, it's the peripheral that's trying to do the read and get Insufficient Authentication response from the phone but the peripheral didn't request pairing after that. So you may want to implement the code to request pairing. Or you should wait for the phone to start pairing by doing what I suggested above.
    Please be aware that if you are not using our chip, we can't really help you here as we don't know your device.
  • Hi  ,
    The setup is like this nrf52840 dongle is connected to windows machine and to this windows machine my device is connected. I am trying to connect via bluetooth to my device using phone's nrf connect app. I have opened the wireshark in windows machine and filtered it based on my device mac address and sniffing.
    So, I am trying to understand here when the device is getting paired what is the security level, is there any security level negotiation? The pairing is happening fine and I am able to send and receive data also[all these are done in application level code with my device to phone not with dongle please dont get confused here]. From the logs I dont see anything on LL_enc_start or ll_enc_req since I am using just works pairing. Just by seeing these wireshark logs can we conclude what level of security mode we are in.
    Hope this should be clear. Let me know if you have any more questions.
  • Hi again,
    Yes I don't see any pairing in the trace you sent. I explained in the last reply.
    I would suggest you to go through the exercises in lesson 5 and 6, especially at lesson 5. The exercise will show you how to configure the device so that pairing would happen automatically.
    From that you can implement to your device.
  • Hi Hung,
    I have configured the dongle based on this(https://www.nordicsemi.com/Products/Development-tools/nRF-Sniffer-for-Bluetooth-LE/Download?lang=en#infotabs). I am able to see the Connect_IND log also please check the file complete_connection.pcapng, 9th log we could see that.
    Please Refer below image,
    this has come because I have connected my phone to my device and sniffing through nrf52840 dongle.
    Hope you see both encryption and authentication signature are no and false everywhere seeing this can we conclude the security mode?
    I could also see the LL_CONNECTION_PARAM_RSP in same logs which shows interval which means connection is successfully established
    Hope the same is visible to you also please let me know.
