nRF5340
NCS 2.6.1
nrfjprog 10.18.1
My project is based on coap_client and also uses MCUBOOT.
I can program both cores using VS Code, and I notice it splits merged_domains.hex into separate files for the application cpu and network core cpu. It programs each separately.
-- west flash: using runner nrfjprog -- runners.nrfjprog: Flashing file: d:\FloLogic\VS_Code_Projects\FloLogic_NCS_2_6\fl_digitalio\build_5340\zephyr\merged_domains.hex -- runners.nrfjprog: d:\VS_Code_Projects\NCS_2_6\myproject\build_5340\zephyr\merged_domains.hex targets both nRF53 coprocessors; splitting it into: d:\VS_Code_Projects\NCS_2_6\myproject\build_5340\zephyr\GENERATED_CP_NETWORK_merged_domains.hex and d:\VS_Code_Projects\NCS_2_6\myproject\build_5340\zephyr\GENERATED_CP_APPLICATION_merged_domains.hex [ #################### ] 8.655s | Erase file - Done erasing [ #################### ] 0.929s | Program file - Done programming [ #################### ] 0.943s | Verify file - Done verifying [ #################### ] 27.379s | Erase file - Done erasing [ #################### ] 3.764s | Program file - Done programming [ #################### ] 3.816s | Verify file - Done verifying -- runners.nrfjprog: Board with serial number 1050012637 flashed successfully.
For production I need to use a command line in a script. This seems to be the recommended way in the documentation, and in DevZone answers.
But I get an error:
>nrfjprog --program merged_domains.hex --recover --verify --reset Recovering device. This operation might take 30s. [error] [ Worker] - Address 0x01000000 does not map to a known memory.7 ERROR: The file specified is not a valid hex file, has data outside valid areas ERROR: or does not have data in valid areas. NOTE: For additional output, try running again with logging enabled (--log). NOTE: Any generated log error messages will be displayed.
How do you split the file?
What is the right way to use merged_domains.hex?
Mary
