Icarus IoT Board v2'yi USB kablosu ile bilgisayarıma bağlayıp boot moduna almak itiyorum lakin olmuyor.
Unfortunately we need keep all conversations here on DevZone in English. But I understand (using google translate) that you have issues putting the board in bootloader mode. Have you had a a tutorial for doing this from Icarus? In what way does it fail?
Elfving
Hello, I installed nRF Connect for Desktop to my Windows 10 computer and I connect my Icarus card with a USB cable and the nRF Connect for Desktop software sees the card. I select the board configurator option. These are written in the console. 15:58:49.970 Initializing nrfutil module: device
15:58:54.400 Using nrfutil-device core version: 7.13.0
15:58:55.383 Using nrfutil-device version: 2.4.3
15:58:55.383 Using nrf-device-lib version: 0.17.22
15:58:55.384 Using nrfjprog DLL version: 10.24.0
15:58:55.384 Using JLink version: JLink_V7.94e
15:58:55.623 Getting serialport options from persistent store ACP58E7V.pc-nrfconnect-board-configurator
15:59:58.326 Selected device with s/n ACP58E7V
16:00:00.029 Error: Failed with exit code 1. One or more batch tasks failed: - No matching plugin found for operations to execute, code: UnsupportedDevice. Message: Batch task smp failed, No matching plugin found for operations to execute. I think I need to put it in boot or DFU mode, but it doesn't work. First I press the Boot button, then I press the reset button, I wait a while and release the boot button, but it doesn't go into boot or DFU mode at all.I am not sure if these are the right steps for your board, but it seems like it. It says the following about bootloader mode:
"Press and hold the reset button. Then press the user button and release the reset button. Finally release the user button as well. This will put the Icarus in MCUBoot mode."
I am not sure about the names of the different buttons, but if you have tried this, could you try changing usb ports and usb cable?
Elfving
