NMP timeout error with SMP sample / mcumgr on nrf52840dk
SUMMARY
Attempting to OTA the nrf52840dk over BLE.
I was able to perform most of the steps in this sample: https://docs.nordicsemi.com/bundle/ncs-2.1.4/page/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/README.html
However, when running the image upload command
mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' image upload /Users/username/project/Code/SW/build/zephyr/zephyr.signed.bin -lDEBUG
I get an NMP timeout error approximately 15% of the way through the upload: HandleError off 38159 error NMP timeout
I assume this means the DK did not respond in time, but I'm not sure what would cause this error.
STEPS
Most of the steps in the sample were followed, however
The sign command required a header and padding to be specified. The command was edited to:
west sign -t imgtool -- --key /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/root-rsa-2048.pem --header-size 32 --pad-header
This command appears to complete successfully and generates a new zephyr.signed.bin
Initially, running the command
gave errors as in this post:  Solution: mcumgr not working in MacOs  (which by the way will NOT appear in search if you paste the error). Following the steps in this post resolved the issue.
Running the mcumgr echo command or image list commands both work.
However, running the image upload command as above gives the NMP error:
DEBU[2024-09-06 03:23:04.42] {remove-nmp-listener} [.:0] seq=47
DEBU[2024-09-06 03:23:04.42] HandleError off 76071 error NMP timeout
ATTEMPTS:
- Tried changing the clock source as described in mcumgr communication times out with NMP when nRF5340 supports DFU.although AFAIK the DK has an external crystal. No change.
- Tried increasing stack sizes in prj.conf, no change:
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4608
CONFIG_MAIN_STACK_SIZE=4096
- Tried increasing global log level to 4 in prj.conf, this I assume used too much memory and would just boot loop. Using 3 gave no insight into the issue.
CONFIG_LOG_OVERRIDE_LEVEL=3
- Any number of pristine builds / reflashes / board recoveries or clears etc.
- Increasing timeout and retries: mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' image upload /Users/username/project/Code/SW/build/zephyr/zephyr.signed.bin -lDEBUG -t 20 -r 3
None of the above changed the behavior.
SETUP
- I'm using an nrf52840 devkit.
- ncs was newly updated to 2.6.1, build command is therefore
- west build \
   -b nrf52840dk_nrf52840 \
   /opt/nordic/ncs/v2.6.1/zephyr/samples/subsys/mgmt/mcumgr/smp_svr \
   -DOVERLAY_CONFIG=overlay-bt.conf
-Attached are the build/zephyr/zephyr.dts, build/zephyr/.config, and /opt/nordic/ncs/v2.6.1/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/prj.conf, which I modified.
- Also attached are snips from the output of the mcumgr image upload command and a snip from connecting to the DK over USB with the vscode extension.
5852.nordic_help.zip
