NMP timeout error with SMP sample / mcumgr on nrf52840dk
SUMMARY
Attempting to OTA the nrf52840dk over BLE.
I was able to perform most of the steps in this sample: https://docs.nordicsemi.com/bundle/ncs-2.1.4/page/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/README.html
However, when running the image upload command
mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' image upload /Users/username/project/Code/SW/build/zephyr/zephyr.signed.bin -lDEBUG
I get an NMP timeout error approximately 15% of the way through the upload: HandleError off 38159 error NMP timeout
I assume this means the DK did not respond in time, but I'm not sure what would cause this error.
STEPS
Most of the steps in the sample were followed, however
The sign command required a header and padding to be specified. The command was edited to:
west sign -t imgtool -- --key /opt/nordic/ncs/v2.6.1/bootloader/mcuboot/root-rsa-2048.pem --header-size 32 --pad-header
This command appears to complete successfully and generates a new zephyr.signed.bin
Initially, running the command
gave errors as in this post:  Solution: mcumgr not working in MacOs  (which by the way will NOT appear in search if you paste the error). Following the steps in this post resolved the issue.
Running the mcumgr echo command or image list commands both work.
However, running the image upload command as above gives the NMP error:
DEBU[2024-09-06 03:23:04.42] {remove-nmp-listener} [.:0] seq=47
DEBU[2024-09-06 03:23:04.42] HandleError off 76071 error NMP timeout
ATTEMPTS:
- Tried changing the clock source as described in mcumgr communication times out with NMP when nRF5340 supports DFU.although AFAIK the DK has an external crystal. No change.
- Tried increasing stack sizes in prj.conf, no change:
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4608
CONFIG_MAIN_STACK_SIZE=4096
- Tried increasing global log level to 4 in prj.conf, this I assume used too much memory and would just boot loop. Using 3 gave no insight into the issue.
CONFIG_LOG_OVERRIDE_LEVEL=3
- Any number of pristine builds / reflashes / board recoveries or clears etc.
- Increasing timeout and retries: mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' image upload /Users/username/project/Code/SW/build/zephyr/zephyr.signed.bin -lDEBUG -t 20 -r 3
None of the above changed the behavior.
SETUP
- I'm using an nrf52840 devkit.
- ncs was newly updated to 2.6.1, build command is therefore
- west build \
   -b nrf52840dk_nrf52840 \
   /opt/nordic/ncs/v2.6.1/zephyr/samples/subsys/mgmt/mcumgr/smp_svr \
   -DOVERLAY_CONFIG=overlay-bt.conf
-Attached are the build/zephyr/zephyr.dts, build/zephyr/.config, and /opt/nordic/ncs/v2.6.1/zephyr/samples/subsys/mgmt/mcumgr/smp_svr/prj.conf, which I modified.
- Also attached are snips from the output of the mcumgr image upload command and a snip from connecting to the DK over USB with the vscode extension.
5852.nordic_help.zip
  • Addendum: The NMP error seems to consistently fail at 15.38% of the upload. If I immediately re-run the same image upload command, the error occurs at almost exactly double, 30.54%. This feels like memory running out somewhere?, but I get no warnings or errors in the DK terminal.
    The "v3" in the "devkit_output" file was used as a heartbeat to determine whether some part of the application was crashing. It was a printk() statement inside the while(1) block in main.c of the sample.
    Some ideas / paths to source files in which to add debug breakpoints for the SMP server firmware would also be appreciated.
    I have written both this course on DFU and this webinar on DFU.
    Do you think you can try to follow either of those and see if that fixes your issue?
    Also, the mcumgr tool you use is known to be suboptimal, I recommend that you have a look at alternate tools mentioned over at upstream mcumgr docs (both lib an tool has the same name "mcumgr", to confuse us).
    Sigurd Hellesvik
    Thanks for the pointers. I will go through them in detail this week and report back.
    Glancing at the "FOTA over Bluetooth Low Energy" section of the course, it appears that either the Device Manager mobile app or the mcumgr tool is recommended. I'm using mac currently and we must be able to use BLE - I can try AuTerm and the mcumgr-web to see if that changes behavior, if you believe the issue lies on the desktop side rather than the device side. At one point in the past I was able to FOTA with some example using device manager (I cannot recall the specifics).
    The eventual goal is to provide our customers with an NRF52840 device, along with a mobile app and desktop which should be able to execute a BLE FOTA with the device.
    For the mobile app, it appears we can use the nRF connect device manager (library). Is this correct? Do you have any guidance for a universal desktop solution? The mcumgr page mentions a "universal replacement" - is there any notion when this would be released?
    I think it is more likely that it is device side.
    Our mobile app is very stable, so if it fails with this, it is likely the device.
    Yes
    In fact, this mention was removed in Upstream documentation lately: https://github.com/zephyrproject-rtos/zephyr/commit/1906ab33da8970f4098bcacba11cd5f35e572754
    I think the note refers to the list of new tools now available, and that you can choose which of them fits your use-case best.
  • Hi Sigurd, thanks for the help. I used the web version of mcumgr (https://boogie.github.io/mcumgr-web/) and it worked on the first try, so indeed something was not working on the desktop side using mcumgr.
    I'm now having a separate issue, where trying to integrate BLE FOTA into my existing application (rather than attempting the example) results in a failure to boot. Would this be a separate ticket?
    Many thanks.
