Data ID in SoftDevice Extended Advertising
I am using version S140 of an nRF52840 in an application that creates an extended (S=8) advertising beacon. For my application to comply with regulations, I need to set the 12-bit advertising data ID field in the extended header to 0x000 - for both the ADV_EXT_IND and AUX_EXT_IND packets. From bench testing, it appears that the advertising data ID is being randomly assigned in the firmware.
I found the structure for changing the advertising data set ID, but the data ID seems to be missing in the structure. What must I do to force data ID to 0x000? If this is not something that I can do in the API, what options are available to achieve this goal?
Thank you,
Nathan Snyder
