BLE scanning base on lte_ble_gateway and app crash
Hello, I made modifications based on the nrf9160 lte_ble_gateway demo. I modified the BLE.c file and changed the BLE connection to BLE scanning.
The scanning algorithm is as follows: idle for 1000ms, then scan for 90ms, and repeat the cycle. To ensure that the BLE scan time is not delayed for a long time, I use the K_TIMER timer. I submit work in the K_TIMER callback, and then start and stop Bluetooth scanning in the work.
I found that after scanning for a period of time, about 10-20 minutes, the application may crash.
In addition, there are many Bluetooth devices in my surrounding environment. Approximately 20 broadcast messages can be scanned within 90ms.
My own product has encountered this issue. I also reproduced this issue on the nrf9160dk_nrf9160(PCA10090 1.0.0) development board, with NCS version 2.2. The LTE modem version is 1.3.6.
Modify on lte_ble_gateway:
1. Modify the ble.c file, please see the attachment.
2. Add define in prj.conf. (CONFIG_BT_BUF_ACL_RX_SIZE=251)
3. Change the uart speed from 1000000 to 115200. (current-speed = <115200> in nrf9160dk_nrf9160_ns.overlay)
 52840 is based on hci_lpuart and only modifies the UART rate to 115200.
I tried to increase CONFIG_BT_BUF_ACL_RX_SIZE, but still encountered a crash. I am trying to reduce the number of BLE devices in the surrounding area, which will lower the probability of this problem occurring.  I speculate that it may be due to receiving a large number of Bluetooth broadcasts that the internal cache of the HCI driver is insufficient?
I hope you can help. thank you!
The crush log on nrf9160dk was:
[00:13:32.103,240] [1;31m<err> bt_driver: TX interrupt but no pending buffer![0m
[22:32:38.840]收←◆ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:335
k_sem_take failed with err -11
[00:13:42.115,631] [1;31m<err> os: r0/a1: 0x00000003 r1/a2: 0x00000000 r2/a3: 0x00000000[0m
[00:13:42.115,661] [1;31m<err> os: r3/a4: 0x00018b61 r12/ip: 0x00000000 r14/lr: 0x000119d7[0m
[00:13:42.115,661] [1;31m<err> os: xpsr: 0x41000000[0m
[00:13:42.115,692] [1;31m<err> os: Faulting instruction address (r15/pc): 0x000119e2[0m
[00:13:42.115,722] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0[0m
[00:13:42.115,753] [1;31m<err> os: Current thread: 0x2000ef20 (unknown)[0m
[00:13:42.160,675] [1;31m<err> fatal_error: Resetting system[0m\0
[22:32:39.667]收←◆*** Booting Zephyr OS build v3.2.99-ncs1 ***
 * Copyright (c) 2018 Nordic Semiconductor ASA
#include <zephyr/kernel.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/uuid.h>
#include <bluetooth/gatt_dm.h>
#include <bluetooth/scan.h>
#include <dk_buttons_and_leds.h>
#include <zephyr/sys/byteorder.h>
#include <net/nrf_cloud.h>
#include "aggregator.h"
LOG_MODULE_DECLARE(lte_ble_gw);
static void connected(struct bt_conn *conn, uint8_t conn_err)
static struct bt_conn_cb conn_callbacks = {
	.connected = connected,
static int gap_scan_num = 0;
static void ble_scan_no_filter_match(struct bt_scan_device_info *device_info, bool connectable)
	gap_scan_num++;
static void scan_timer_handler(struct k_timer *dummy);
BT_SCAN_CB_INIT(scan_cb, NULL, ble_scan_no_filter_match, NULL, NULL);
K_TIMER_DEFINE(scan_timer_id, scan_timer_handler, NULL);
static struct k_work gap_scan_worker;
static void scan_work_callback(struct k_work *work);
bool gap_is_scanning = false;
#define SCAN_INTERVAL_MS 1000
	if (gap_is_scanning)
    	k_timer_start(&scan_timer_id, K_MSEC(SCAN_INTERVAL_MS), K_NO_WAIT);
        k_timer_start(&scan_timer_id, K_MSEC(90), K_NO_WAIT);
	k_work_submit(&gap_scan_worker);
static struct bt_le_scan_param gap_scan_param =
	.type = BT_LE_SCAN_TYPE_PASSIVE,
	.options = (BT_LE_SCAN_OPT_FILTER_DUPLICATE),
	.interval = 0x10,
	.window = 0x10,
static struct bt_scan_init_param gap_scan_init =
	.connect_if_match = 0,
	.scan_param = &gap_scan_param,
	.conn_param = BT_LE_CONN_PARAM_DEFAULT,
static void scan_start(void)
	bt_scan_init(&gap_scan_init);
	bt_scan_cb_register(&scan_cb);
	k_timer_start(&scan_timer_id, K_MSEC(5000), K_NO_WAIT);
	LOG_INF("Scanning...");
static void ble_ready(int err)
	LOG_INF("Bluetooth ready");
	bt_conn_cb_register(&conn_callbacks);
	scan_start();
	static uint32_t gap_total_start = 0;
	gap_total_start++;
        int err = bt_scan_stop();
        if (err)
	        LOG_ERR("Fail to stop scan, err %d", err);
	        return;
	    	LOG_INF("Stop scan success:%d, num:%d", gap_scan_num, gap_total_start);
		gap_scan_num = 0;
        //check if need refresh scannning cfg before start scanning
        int err = bt_scan_start(BT_SCAN_TYPE_SCAN_PASSIVE);
	    if (err)
	    	LOG_ERR("Fail to start scan, err %d", err);
	    	return;
	    	LOG_INF("start scan success");
	    gap_is_scanning = true;
void nrf_ble_hardware_reset(void)
void ble_init(void)
	int err;
	LOG_INF("Initializing Bluetooth..");
	err = bt_enable(ble_ready);
	if (err) {
		LOG_ERR("Bluetooth init failed (err %d)", err);
		return;
    k_work_init(&gap_scan_worker, scan_work_callback);
9160dk_crash_log.txt
    Can you double check which SDK version you are using, and if you have any changes on your end? I ask as there is no assert on line 335 in zephyr/subsys/bluetooth/host/hci_core.c in nRF Connect SDK 2.2.0.
    That said, it looks like communication issues with the network core. Do you have logs for the network core as well? If so, can you share those?
    Br,
    Einar
  • Sorry, we added a function in hci_core.c that resulted in incorrect numbering.
    I have re-downloaded Version SDK 2.2.0. We have retested and there are still issues.
    In this test, We did not make any modifications to the prj.conf file and overlay file. Keeping UART at the default rate of 1000000 and not modifying the ACL_SX size. To avoid the influence of LTE modems, we have comments the LTE section.
    Test condition:
    -SDK version: v2.2.0
    -tools: nrf9160dk, hardware version: v1.1.3
    -hci_lpuart:
    * not change prj.conf and overlay file
    -lte_ble_gateway
    * replace the ble.c file
    * comments the lte code
    void main(void)
    LOG_INF("LTE Sensor Gateway sample started");
    buttons_leds_init();
    ble_init();
    //work_init();
    //cloud_init();
    //modem_configure();
    //cloud_connect(NULL);
    Error log on sdk 2.2:
    sdk2.2_error_log.txt
    We also conducted a test on SDK 2.6. We did not make any modifications to the prj.conf file and overlay file. Keeping UART at the default rate of 1000000 and not modifying the ACL_SX size, but kept the LTE code. During testing, some errors were also encountered.
    Test condition:
    -SDK version: v2.6.0
    -hci_lpuart:
    -lte_ble_gateway
    Error log on SDK2.6.0:
    1. Test condition:
    -lte_ble_gateway:
      *not change prj.conf and overlay file.
      *only replace ble.c.
    -hci_lpuart:(no change)
    2. Test Log on lte_ble_gateway:
    [09:18:02.179]收←◆*** Booting nRF Connect SDK v3.5.99-ncs1-1-1-g02ae5d8ded21 ***
    [00:00:00.363,922] <inf> lte_ble_gw: LTE Sensor Gateway sample started
    [00:00:00.364,135] <inf> lte_ble_gw: Initializing Bluetooth..
    [09:18:02.932]收←◆[00:00:00.617,889] <inf> lte_ble_gw: Establishing LTE link (this may take some time) ...
    [00:00:01.067,382] <wrn> bt_hci_core: opcode 0x0000 pool id 3 pool 0x2000d040 != &hci_cmd_pool 0x2000d0a8
    [00:00:01.109,497] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:01.109,527] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:01.109,558] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
    [00:00:01.118,194] <inf> bt_hci_core: Identity: D4:CB:39:15:51:B3 (random)
    [00:00:01.118,225] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x118f, manufacturer 0x0059
    [00:00:01.118,255] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x118f
    [00:00:01.118,255] <inf> lte_ble_gw: Bluetooth ready
    [00:00:01.118,316] <inf> lte_ble_gw: Scanning...
    [09:18:08.940]收←◆[00:00:06.125,854] <inf> lte_ble_gw: start scan success
    [00:00:06.209,716] <inf> lte_ble_gw: Stop scan success:33, num:2
    [09:18:10.031]收←◆[00:00:07.215,820] <inf> lte_ble_gw: start scan success
    [00:00:07.299,743] <inf> lte_ble_gw: Stop scan success:30, num:4
    [09:18:11.119]收←◆[00:00:08.305,847] <inf> lte_ble_gw: start scan success
    [00:00:08.391,448] <inf> lte_ble_gw: Stop scan success:30, num:6
    [09:18:12.210]收←◆[00:00:09.395,874] <inf> lte_ble_gw: start scan success
    [00:00:09.479,980] <inf> lte_ble_gw: Stop scan success:30, num:8
    [09:18:13.299]收←◆[00:00:10.485,870] <inf> lte_ble_gw: start scan success
    [00:00:10.569,824] <inf> lte_ble_gw: Stop scan success:29, num:10
    [09:18:14.389]收←◆[00:00:11.575,927] <inf> lte_ble_gw: start scan success
    [00:00:11.659,851] <inf> lte_ble_gw: Stop scan success:27, num:12
    [09:18:15.480]收←◆[00:00:12.665,985] <inf> lte_ble_gw: start scan success
    [00:00:12.749,908] <inf> lte_ble_gw: Stop scan success:28, num:14
    [09:18:16.570]收←◆[00:00:13.755,950] <inf> lte_ble_gw: start scan success
    [00:00:13.839,904] <inf> lte_ble_gw: Stop scan success:21, num:16
    [09:18:17.659]收←◆[00:00:14.846,008] <inf> lte_ble_gw: start scan success
    [00:00:14.930,603] <inf> lte_ble_gw: Stop scan success:27, num:18
    [09:18:18.750]收←◆[00:00:15.936,035] <inf> lte_ble_gw: start scan success
    [00:00:16.020,019] <inf> lte_ble_gw: Stop scan success:24, num:20
    [09:18:19.840]收←◆[00:00:17.026,062] <inf> lte_ble_gw: start scan success
    [00:00:17.110,046] <inf> lte_ble_gw: Stop scan success:31, num:22
    [09:18:20.930]收←◆[00:00:18.116,088] <inf> lte_ble_gw: start scan success
    [00:00:18.200,286] <inf> lte_ble_gw: Stop scan success:23, num:24
    [09:18:22.021]收←◆[00:00:19.206,146] <inf> lte_ble_gw: start scan success
    [00:00:19.290,039] <inf> lte_ble_gw: Stop scan success:26, num:26
    [09:18:23.110]收←◆[00:00:20.296
    [09:18:23.133]收←◆,142] <inf> lte_ble_gw: start scan success
    [00:00:20.380,065] <inf> lte_ble_gw: Stop scan success:25, num:28
    [09:18:24.200]收←◆[00:00:21.386,199] <inf> lte_ble_gw: start scan success
    [00:00:21.471,008] <inf> lte_ble_gw: Stop scan success:34, num:30
    [09:18:25.291]收←◆[00:00:22.476,196] <inf> lte_ble_gw: start scan success
    [00:00:22.560,119] <inf> lte_ble_gw: Stop scan success:29, num:32
    [09:18:26.380]收←◆[00:00:23.566,223] <inf> lte_ble_gw: start scan success
    [00:00:23.650,146] <inf> lte_ble_gw: Stop scan success:22, num:34
    [09:18:27.470]收←◆[00:00:24.656
    [09:18:27.487]收←◆,250] <inf> lte_ble_gw: start scan success
    [00:00:24.740,173] <inf> lte_ble_gw: Stop scan success:21, num:36
    [09:18:28.560]收←◆[00:00:
    [09:18:28.581]收←◆25.746,307] <inf> lte_ble_gw: start scan success
    [00:00:25.830,383] <inf> lte_ble_gw: Stop scan success:36, num:38
    [09:18:29.650]收←◆[00:00:26.836,303] <inf> lte_ble_gw: start scan success
    [00:00:26.921,112] <inf> lte_ble_gw: Stop scan success:25, num:40
    [09:18:30.740]收←◆[00:00:27.926,330] <inf> lte_ble_gw: start scan success
    [00:00:28.010,253] <inf> lte_ble_gw: Stop scan success:22, num:42
    [09:18:31.830]收←◆[00:00:29.016,387] <inf> lte_ble_gw: start scan success
    [00:00:29.100,372] <inf> lte_ble_gw: Stop scan success:21, num:44
    [09:18:32.920]收←◆[00:00:30.106,384] <inf> lte_ble_gw: start scan success
    [00:00:30.190,307] <inf> lte_ble_gw: Stop scan success:37, num:46
    [09:18:34.010]收←◆[00:00:31.196,380] <inf> lte_ble_gw: start scan success
    [00:00:31.280,792] <inf> lte_ble_gw: Stop scan success:27, num:48
    [09:18:35.100]收←◆[00:00:32.286,437] <inf> lte_ble_gw: start scan success
    [00:00:32.370,361] <inf> lte_ble_gw: Stop scan success:34, num:50
    [09:18:36.190]收←◆[00:00:33.376,464] <inf> lte_ble_gw: start scan success
    [00:00:33.460,388] <inf> lte_ble_gw: Stop scan success:34, num:52
    [09:18:37.280]收←◆[00:00:34.466,491] <inf> lte_ble_gw: start scan success
    [00:00:34.550,750] <inf> lte_ble_gw: Stop scan success:29, num:54
    [09:18:38.370]收←◆[00:00:35.556,549] <inf> lte_ble_gw: start scan success
    [00:00:35.640,441] <inf> lte_ble_gw: Stop scan success:39, num:56
    [09:18:39.460]收←◆[00:00:36.646,545] <inf> lte_ble_gw: start scan success
    [00:00:36.730,560] <inf> lte_ble_gw: Stop scan success:30, num:58
    [09:18:40.550]收←◆[00:00:37.736,572] <inf> lte_ble_gw: start scan success
    [00:00:37.820,495] <inf> lte_ble_gw: Stop scan success:26, num:60
    [09:18:41.640]收←◆[00:00:38.826,629] <inf> lte_ble_gw: start scan success
    [00:00:38.910,705] <inf> lte_ble_gw: Stop scan success:36, num:62
    [09:18:42.731]收←◆[00:00:39.916,625] <inf> lte_ble_gw: start scan success
    [00:00:40.000,579] <inf> lte_ble_gw: Stop scan success:28, num:64
    [09:18:43.820]收←◆[00:00:41.006,652] <inf> lte_ble_gw: start scan success
    [00:00:41.091,918] <inf> lte_ble_gw: Stop scan success:28, num:66
    [09:18:44.910]收←◆[00:00:42.096,679] <inf> lte_ble_gw: start scan success
    [00:00:42.181,518] <inf> lte_ble_gw: Stop scan success:28, num:68
    [09:18:46.000]收←◆[00:00:43.186,706] <inf> lte_ble_gw: start scan success
    [00:00:43.271,209] <inf> lte_ble_gw: Stop scan success:27, num:70
    [09:18:47.090]收←◆[00:00:44.276,733] <inf> lte_ble_gw: start scan success
    [00:00:44.361,663] <inf> lte_ble_gw: Stop scan success:29, num:72
    [09:18:48.181]收←◆[00:00:45.366,760] <inf> lte_ble_gw: start scan success
    [00:00:45.450,897] <inf> lte_ble_gw: Stop scan success:28, num:74
    [09:18:49.270]收←◆[00:00:46.456,787] <inf> lte_ble_gw: start scan success
    [00:00:46.541,717] <inf> lte_ble_gw: Stop scan success:23, num:76
    [09:18:50.360]收←◆[00:00:47.546,813] <inf> lte_ble_gw: start scan success
    [00:00:47.631,652] <inf> lte_ble_gw: Stop scan success:32, num:78
    [09:18:51.449]收←◆[00:00:48.636,871] <inf> lte_ble_gw: start scan success
    [00:00:48.720,794] <inf> lte_ble_gw: Stop scan success:33, num:80
    [09:18:52.542]收←◆[00:00:49.726,867] <inf> lte_ble_gw: start scan success
    [00:00:49.811,737] <inf> lte_ble_gw: Stop scan success:30, num:82
    [09:18:53.631]收←◆[00:00:50.816,894] <inf> lte_ble_gw: start scan success
    [00:00:50.900,817] <inf> lte_ble_gw: Stop scan success:29, num:84
    [09:18:54.721]收←◆[00:00:51.906,951] <inf> lte_ble_gw: start scan success
    [00:00:51.991,394] <inf> lte_ble_gw: Stop scan success:25, num:86
    [09:18:55.811]收←◆[00:00:52.996,
    [09:18:55.832]收←◆948] <inf> lte_ble_gw: start scan success
    [00:00:53.080,871] <inf> lte_ble_gw: Stop scan success:26, num:88
    [09:18:56.901]收←◆[00:00:54.086,944] <inf> lte_ble_gw: start scan success
    [00:00:54.171,752] <inf> lte_ble_gw: Stop scan success:27, num:90
    [09:18:57.993]收←◆[00:00:55.177,001] <inf> lte_ble_gw: start scan success
    [00:00:55.260,925] <inf> lte_ble_gw: Stop scan success:27, num:92
    [09:18:59.080]收←◆[00:00:56.267,028] <inf> lte_ble_gw: start scan success
    [00:00:56.352,020] <inf> lte_ble_gw: Stop scan success:31, num:94
    [09:19:00.171]收←◆[00:00:57.357,055] <inf> lte_ble_gw: start scan success
    [00:00:57.440,979] <inf> lte_ble_gw: Stop scan success:25, num:96
    [09:19:01.260]收←◆[00:00:58.447,113] <inf> lte_ble_gw: start scan success
    [00:00:58.531,494] <inf> lte_ble_gw: Stop scan success:31, num:98
    [09:19:02.350]收←◆[00:00:59.537,109] <inf> lte_ble_gw: start scan success
    [00:00:59.621,032] <inf> lte_ble_gw: Stop scan success:37, num:100
    [09:19:03.440]收←◆[00:01:00.627,136] <inf> lte_ble_gw: start scan success
    [00:01:00.711,975] <inf> lte_ble_gw: Stop scan success:34, num:102
    [09:19:04.531]收←◆[00:01:01.717,163] <inf> lte_ble_gw: start scan success
    [00:01:01.801,849] <inf> lte_ble_gw: Stop scan success:27, num:104
    [09:19:05.621]收←◆[00:01:02.807,189] <inf> lte_ble_gw: start scan success
    [00:01:02.892,089] <inf> lte_ble_gw: Stop scan success:28, num:106
    [09:19:06.711]收←◆[00:01:03.897,216] <inf> lte_ble_gw: start scan success
    [00:01:03.981,140] <inf> lte_ble_gw: Stop scan success:31, num:108
    [09:19:07.801]收←◆[00:01:04.987,274] <inf> lte_ble_gw: start scan success
    [00:01:05.071,166] <inf> lte_ble_gw: Stop scan success:29, num:110
    [09:19:08.891]收←◆[00:01:
    [09:19:08.912]收←◆06.077,270] <inf> lte_ble_gw: start scan success
    [00:01:06.161,193] <inf> lte_ble_gw: Stop scan success:28, num:112
    [09:19:09.981]收←◆[00:01:07.167,297] <inf> lte_ble_gw: start scan success
    [00:01:07.251,464] <inf> lte_ble_gw: Stop scan success:27, num:114
    [09:19:11.071]收←◆[00:01:08.257,354] <inf> lte_ble_gw: start scan success
    [00:01:08.341,247] <inf> lte_ble_gw: Stop scan success:24, num:116
    [09:19:12.161]收←◆[00:01:09.347,351] <inf> lte_ble_gw: start scan success
    [00:01:09.431,274] <inf> lte_ble_gw: Stop scan success:30, num:118
    [09:19:13.252]收←◆[00:01:10.437,377] <inf> lte_ble_gw: start scan success
    [00:01:10.521,301] <inf> lte_ble_gw: Stop scan success:24, num:120
    [09:19:14.341]收←◆[00:01:11.527,435] <inf> lte_ble_gw: start scan success
    [00:01:11.611,328] <inf> lte_ble_gw: Stop scan success:29, num:122
    [09:19:15.431]收←◆[00:01:12.617,431] <inf> lte_ble_gw: start scan success
    [00:01:12.701,934] <inf> lte_ble_gw: Stop scan success:25, num:124
    [09:19:16.521]收←◆[00:01:13.707,458] <inf> lte_ble_gw: start scan success
    [00:01:13.791,595] <inf> lte_ble_gw: Stop scan success:30, num:126
    [09:19:17.611]收←◆[00:01:14.797,515] <inf> lte_ble_gw: start scan success
    [00:01:14.881,408] <inf> lte_ble_gw: Stop scan success:19, num:128
    [09:19:18.701]收←◆[00:01:1
    [09:19:18.722]收←◆5.887,512] <inf> lte_ble_gw: start scan success
    [00:01:15.971,618] <inf> lte_ble_gw: Stop scan success:23, num:130
    [09:19:19.792]收←◆[00:01:16.977,508] <inf> lte_ble_gw: start scan success
    [00:01:17.061,492] <inf> lte_ble_gw: Stop scan success:27, num:132
    [09:19:20.882]收←◆[00:01:18.067,596] <inf> lte_ble_gw: start scan success
    [00:01:18.151,489] <inf> lte_ble_gw: Stop scan success:25, num:134
    [09:19:21.972]收←◆[00:01:19.157,592] <inf> lte_ble_gw: start scan success
    [00:01:19.242,584] <inf> lte_ble_gw: Stop scan success:25, num:136
    [09:19:23.062]收←◆[00:01:20.247,619] <inf> lte_ble_gw: start scan success
    [00:01:20.332,122] <inf> lte_ble_gw: Stop scan success:24, num:138
    [09:19:24.151]收←◆[00:01:21.337,646] <inf> lte_ble_gw: start scan success
    [00:01:21.421,569] <inf> lte_ble_gw: Stop scan success:35, num:140
    [09:19:25.241]收←◆[00:01:22.427,642] <inf> lte_ble_gw: start scan success
    [00:01:22.511,993] <inf> lte_ble_gw: Stop scan success:33, num:142
    [09:19:26.331]收←◆[00:01:23.517,700] <inf> lte_ble_gw: start scan success
    [00:01:23.601,623] <inf> lte_ble_gw: Stop scan success:35, num:144
    [09:19:27.422]收←◆[00:01:24.607
    [09:19:27.440]收←◆,757] <inf> lte_ble_gw: start scan success
    [00:01:24.691,986] <inf> lte_ble_gw: Stop scan success:32, num:146
    [09:19:28.511]收←◆[00:01:25.697,753] <inf> lte_ble_gw: start scan success
    [00:01:25.781,951] <inf> lte_ble_gw: Stop scan success:30, num:148
    [09:19:29.602]收←◆[00:01:26.787,811] <inf> lte_ble_gw: start scan success
    [00:01:26.872,711] <inf> lte_ble_gw: Stop scan success:31, num:150
    [09:19:30.692]收←◆[00:01:27.877,807] <inf> lte_ble_gw: start scan success
    [00:01:27.961,822] <inf> lte_ble_gw: Stop scan success:27, num:152
    [09:19:31.781]收←◆[00:01:28.967,834] <inf> lte_ble_gw: start scan success
    [00:01:29.052,551] <inf> lte_ble_gw: Stop scan success:30, num:154
    [09:19:32.871]收←◆[00:01:30.057,861] <inf> lte_ble_gw: start scan success
    [00:01:30.141,906] <inf> lte_ble_gw: Stop scan success:31, num:156
    [09:19:33.961]收←◆[00:01:31.147,857] <inf> lte_ble_gw: start scan success
    [00:01:31.231,872] <inf> lte_ble_gw: Stop scan success:27, num:158
    [09:19:35.052]收←◆[00:01:32.237,945] <inf> lte_ble_gw: start scan success
    [00:01:32.321,960] <inf> lte_ble_gw: Stop scan success:27
    [09:19:35.082]收←◆, num:160
    [09:19:36.142]收←◆[00:01:33.327,941] <inf> lte_ble_gw: start scan success
    [00:01:33.412,200] <inf> lte_ble_gw: Stop scan success:25, num:162
    [09:19:37.232]收←◆[00:01:34.417,968] <inf> lte_ble_gw: start scan success
    [00:01:34.501,892] <inf> lte_ble_gw: Stop scan success:30, num:164
    [09:19:38.322]收←◆[00:01:35.508,026] <inf> lte_ble_gw: start scan success
    [00:01:35.593,109] <inf> lte_ble_gw: Stop scan success:30, num:166
    [09:19:39.411]收←◆[00:01:36.597,991] <inf> lte_ble_gw: start scan success
    [00:01:36.682,403] <inf> lte_ble_gw: Stop scan success:28, num:168
    [09:19:40.501]收←◆[00:01:37.688,049] <inf> lte_ble_gw: start scan success
    [00:01:37.772,155] <inf> lte_ble_gw: Stop scan success:32, num:170
    [09:19:41.592]收←◆[00:01:38.778,106] <inf> lte_ble_gw: start scan success
    [00:01:38.861,999] <inf> lte_ble_gw: Stop scan success:23, num:172
    [09:19:42.682]收←◆[00:01:39.868,103] <inf> lte_ble_gw: start scan success
    [00:01:39.952,209] <inf> lte_ble_gw: Stop scan success:37, num:174
    [09:19:43.771]收←◆[00:01:40.958,129] <inf> lte_ble_gw: start scan success
    [00:01:41.042,053] <inf> lte_ble_gw: Stop scan success:28, num:176
    [09:19:44.862]收←◆[00:01:42.048,187] <inf> lte_ble_gw: start scan success
    [00:01:42.132,080] <inf> lte_ble_gw: Stop scan success:24, num:178
    [09:19:45.952]收←◆[00:01:43.138,183] <inf> lte_ble_gw: start scan success
    [00:01:43.222,106] <inf> lte_ble_gw: Stop scan success:23, num:180
    [09:19:47.041]收←◆[00:01:44.228,210] <inf> lte_ble_gw: start scan success
    [00:01:44.312,133] <inf> lte_ble_gw: Stop scan success:25, num:182
    [09:19:48.132]收←◆[00:01:45.318,267] <inf> lte_ble_gw: start scan success
    [00:01:45.402,160] <inf> lte_ble_gw: Stop scan success:23, num:184
    [09:19:49.222]收←◆[00:01:46.408,264] <inf> lte_ble_gw: start scan success
    [00:01:46.492,187] <inf> lte_ble_gw: Stop scan success:31, num:186
    [09:19:50.312]收←◆[00:01:47.498,291] <inf> lte_ble_gw: start scan success
    [00:01:47.582,305] <inf> lte_ble_gw: Stop scan success:28, num:188
    [09:19:51.402]收←◆[00:01:48.588,348] <inf> lte_ble_gw: start scan success
    [00:01:48.672,241] <inf> lte_ble_gw: Stop scan success:22, num:190
    [09:19:52.493]收←◆[00:01:49.678,344] <inf> lte_ble_gw: start scan success
    [00:01:49.762,420] <inf> lte_ble_gw: Stop scan success:37, num:192
    [09:19:53.582]收←◆[00:01:50.768,341] <inf> lte_ble_gw: start scan success
    [00:01:50.852,325] <inf> lte_ble_gw: Stop scan success:34, num:194
    [09:19:54.672]收←◆[00:01:51.858,428] <inf> lte_ble_gw: start scan success
    [00:01:51.942,535] <inf> lte_ble_gw: Stop scan success:30, num:196
    [09:19:55.762]收←◆[00:01:52.948,425] <inf> lte_ble_gw: start scan success
    [00:01:53.032,379] <inf> lte_ble_gw: Stop scan success:24, num:198
    [09:19:56.852]收←◆[00:01:54.038,452] <inf> lte_ble_gw: start scan success
    [00:01:54.123,260] <inf> lte_ble_gw: Stop scan success:30, num:200
    [09:19:57.942]收←◆[00:01:55.128,479] <inf> lte_ble_gw: start scan success
    [00:01:55.212,402] <inf> lte_ble_gw: Stop scan success:24, num:202
    [09:19:59.032]收←◆[00:01:56.218,505] <inf> lte_ble_gw: start scan success
    [00:01:56.303,283] <inf> lte_ble_gw: Stop scan success:23, num:204
    [09:20:00.122]收←◆[00:01:57.308,532] <inf> lte_ble_gw: start scan success
    [00:01:57.392,486] <inf> lte_ble_gw: Stop scan success:31, num:206
    [09:20:01.219]收←◆[00:01:58.404,968] <inf> lte_ble_gw: start scan success
    [00:01:58.482,574] <inf> lte_ble_gw: Stop scan success:30, num:208
    [09:20:02.303]收←◆[00:01:59.488,555] <inf> lte_ble_gw: start scan success
    [00:01:59.572,509] <inf> lte_ble_gw: Stop scan success:27, num:210
    [09:20:03.392]收←◆[00:02:00.578,613] <inf> lte_ble_gw: start scan success
    [00:02:00.662,719] <inf> lte_ble_gw: Stop scan success:28, num:212
    [09:20:04.482]收←◆[00:02:01.668,640] <inf> lte_ble_gw: start scan success
    [00:02:01.752,685] <inf> lte_ble_gw: Stop scan success:34, num:214
    [09:20:05.572]收←◆[00:02:02.758,697] <inf> lte_ble_gw: start scan success
    [00:02:02.842,590] <inf> lte_ble_gw: Stop scan success:27, num:216
    [09:20:06.662]收←◆[00:02:03.848,693] <inf> lte_ble_gw: start scan success
    [00:02:03.933,349] <inf> lte_ble_gw: Stop scan success:34, num:218
    [09:20:07.752]收←◆[00:02:04.938,690] <inf> lte_ble_gw: start scan success
    [00:02:05.022,766] <inf> lte_ble_gw: Stop scan success:26, num:220
    [09:20:08.849]收←◆[00:02:06.035,095] <inf> lte_ble_gw: start scan success
    [00:02:06.123,321] <inf> lte_ble_gw: Stop scan success:22, num:222
    [09:20:09.939]收←◆[00:02:07.125,091] <inf> lte_ble_gw: start scan success
    [00:02:07.207,580] <inf> lte_ble_gw: Stop scan success:25, num:224
    [09:20:11.023]收←◆[00:02:08.208,801] <inf> lte_ble_gw: start scan success
    +CEREG: 2,"7859","0779FC51",9
    [00:02:08.292,785] <inf> lte_ble_gw: Stop scan success:29, num:226
    [09:20:12.119]收←◆[00:02:09.305,145] <inf> lte_ble_gw: start scan success
    [00:02:09.392,425] <inf> lte_ble_gw: Stop scan success:24, num:228
    [09:20:13.203]收←◆[00:02:10.388,885] <inf> lte_ble_gw: start scan success
    [00:02:10.472,900] <inf> lte_ble_gw: Stop scan success:30, num:230
    [09:20:14.299]收←◆[00:02:11.485,198] <inf> lte_ble_gw: start scan success
    [00:02:11.580,383] <inf> lte_ble_gw: Stop scan success:30, num:232
    [09:20:15.389]收←◆[00:02:12
    [09:20:15.409]收←◆.575,256] <inf> lte_ble_gw: start scan success
    [00:02:12.659,362] <inf> lte_ble_gw: Stop scan success:29, num:234
    [09:20:16.478]收←◆[00:02:13.665,252] <inf> lte_ble_gw: start scan success
    [00:02:13.745,117] <inf> lte_ble_gw: Stop scan success:24, num:236
    [09:20:17.569]收←◆[00:02:14.755,279] <inf> lte_ble_gw: start scan success
    [00:02:14.842,895] <inf> lte_ble_gw: Stop scan success:28, num:238
    [09:20:18.660]收←◆[00:02:15.845,336] <inf> lte_ble_gw: start scan success
    [00:02:15.928,405] <inf> lte_ble_gw: Stop scan success:24, num:240
    [09:20:19.749]收←◆[00:02:16.935,333] <inf> lte_ble_gw: start scan success
    [00:02:17.028,259] <inf> lte_ble_gw: Stop scan success:28, num:242
    [09:20:20.833]收←◆[00:02:18.019,042] <inf> lte_ble_gw: start scan success
    [00:02:18.103,179] <inf> lte_ble_gw: Stop scan success:31, num:244
    [09:20:21.929]收←◆[00:02:19.115,386] <inf> lte_ble_gw: start scan success
    [00:02:19.196,472] <inf> lte_ble_gw: Stop scan success:24, num:246
    [09:20:23.020]收←◆[00:02:20.205,413] <inf> lte_ble_gw: start scan success
    [00:02:20.290,283] <inf> lte_ble_gw: Stop scan success:29, num:248
    [09:20:24.110]收←◆[00:02:21.295,
    [09:20:24.128]收←◆471] <inf> lte_ble_gw: start scan success
    [00:02:21.377,624] <inf> lte_ble_gw: Stop scan success:22, num:250
    [09:20:25.199]收←◆[00:02:22.385,498] <inf> lte_ble_gw: start scan success
    [00:02:22.473,571] <inf> lte_ble_gw: Stop scan success:23, num:252
    [09:20:26.289]收←◆[00:02:23.475,494] <inf> lte_ble_gw: start scan success
    [00:02:23.560,302] <inf> lte_ble_gw: Stop scan success:26, num:254
    [09:20:27.378]收←◆[00:02:24.565,551] <inf> lte_ble_gw: start scan success
    [00:02:24.648,132] <inf> lte_ble_gw: Stop scan success:23, num:256
    [09:20:28.463]收←◆[00:02:25.649,230] <inf> lte_ble_gw: start scan success
    [00:02:25.733,154] <inf> lte_ble_gw: Stop scan success:25, num:258
    [09:20:29.559]收←◆[00:02:26.745,574] <inf> lte_ble_gw: start scan success
    [00:02:26.831,390] <inf> lte_ble_gw: Stop scan success:27, num:260
    [09:20:30.649]收←◆[00:02:27.835,601] <inf> lte_ble_gw: start scan success
    [00:02:27.926,666] <inf> lte_ble_gw: Stop scan success:29, num:262
    [09:20:31.740]收←◆[00:02:28.925,628] <inf> lte_ble_gw: start scan success
    [00:02:29.006,164] <inf> lte_ble_gw: Stop scan success:26, num:264
    [09:20:32.830]收←◆[00:02:30.015,686] <inf> lte_ble_gw: start scan success
    [00:02:30.099,578] <inf> lte_ble_gw: Stop scan success:24, num:266
    [09:20:33.920]收←◆[00:02:31.105,743] <inf> lte_ble_gw: start scan success
    [00:02:31.208,862] <inf> lte_ble_gw: Stop scan success:34, num:268
    [09:20:35.010]收←◆[00:02:32.195,709] <inf> lte_ble_gw: start scan success
    [00:02:32.287,750] <inf> lte_ble_gw: Stop scan success:30, num:270
    [09:20:36.099]收←◆[00:02:33.285,705] <inf> lte_ble_gw: start scan success
    [00:02:33.363,342] <inf> lte_ble_gw: Stop scan success:24, num:272
    [09:20:37.189]收←◆[00:02:34.375,762] <inf> lte_ble_gw: start scan success
    [00:02:34.466,766] <inf> lte_ble_gw: Stop scan success:28, num:274
    [09:20:38.280]收←◆[00:02:35.465,789
    [09:20:38.301]收←◆] <inf> lte_ble_gw: start scan success
    [00:02:35.559,539] <inf> lte_ble_gw: Stop scan success:32, num:276
    [09:20:39.370]收←◆[00:02:36.555,847] <inf> lte_ble_gw: start scan success
    [00:02:36.648,529] <inf> lte_ble_gw: Stop scan success:31, num:278
    [09:20:40.459]收←◆[00:02:37.645,843] <inf> lte_ble_gw: start scan success
    [00:02:37.730,865] <inf> lte_ble_gw: Stop scan success:23, num:280
    [09:20:41.550]收←◆[00:02:38.735,900] <inf> lte_ble_gw: start scan success
    [00:02:38.819,885] <inf> lte_ble_gw: Stop scan success:27, num:282
    [09:20:42.640]收←◆[00:02:39.825,927] <inf> lte_ble_gw: start scan success
    [00:02:39.913,574] <inf> lte_ble_gw: Stop scan success:30, num:284
    [09:20:43.729]收←◆[00:02:40.915,954] <inf> lte_ble_gw: start scan success
    [00:02:40.994,445] <inf> lte_ble_gw: Stop scan success:24, num:286
    [09:20:44.820]收←◆[00:02:42.005,950] <inf> lte_ble_gw: start scan success
    [00:02:42.092,254] <inf> lte_ble_gw: Stop scan success:26, num:288
    [09:20:45.910]收←◆[00:02:43.096,008] <inf> lte_ble_gw: start scan success
    [00:02:43.183,563] <inf> lte_ble_gw: Stop scan success:30, num:290
    [09:20:47.000]收←◆[00:02:44.186,035] <inf> lte_ble_gw: start scan success
    [00:02:44.271,392] <inf> lte_ble_gw: Stop scan success:28, num:292
    [09:20:48.091]收←◆[00:02:45.276,031] <inf> lte_ble_gw: start scan success
    [00:02:45.359,344] <inf> lte_ble_gw: Stop scan success:27, num:294
    [09:20:49.180]收←◆[00:02:46.366,088] <inf> lte_ble_gw: start scan success
    [00:02:46.447,845] <inf> lte_ble_gw: Stop scan success:18, num:296
    [09:20:50.270]收←◆[00:02:47.456,085] <inf> lte_ble_gw: start scan success
    [00:02:47.546,356] <inf> lte_ble_gw: Stop scan success:27, num:298
    [09:20:51.360]收←◆[00:02:48.546,142] <inf> lte_ble_gw: start scan success
    [00:02:48.638,671] <inf> lte_ble_gw: Stop scan success:32, num:300
    [09:20:52.450]收←◆[00:02:49.636,169] <inf> lte_ble_gw: start scan success
    [00:02:49.720,336] <inf> lte_ble_gw: Stop scan success:27, num:302
    [09:20:53.540]收←◆[00:02:50.726,165] <inf> lte_ble_gw: start scan success
    [00:02:50.817,687] <inf> lte_ble_gw: Stop scan success:26, num:304
    [09:20:54.630]收←◆[00:02:51.816,192] <inf> lte_ble_gw: start scan success
    [00:02:51.898,986] <inf> lte_ble_gw: Stop scan success:24, num:306
    [09:20:55.720]收←◆[00:02:52.906,219] <inf> lte_ble_gw: start scan success
    [00:02:53.008,056] <inf> lte_ble_gw: Stop scan success:35, num:308
    [09:20:56.804]收←◆[00:02:53.989,959] <inf> lte_ble_gw: start scan success
    [00:02:54.080,871] <inf> lte_ble_gw: Stop scan success:26, num:310
    [09:20:57.900]收←◆[00:02:55.086,273] <inf> lte_ble_gw: start scan success
    [00:02:55.185,852] <inf> lte_ble_gw: Stop scan success:29, num:312
    [09:20:58.990]收←◆[00:02:56.176,330] <inf> lte_ble_gw: start scan success
    [00:02:56.269,805] <inf> lte_ble_gw: Stop scan success:30, num:314
    [09:21:00.080]收←◆[00:02:57.266,326] <inf> lte_ble_gw: start scan success
    [00:02:57.353,973] <inf> lte_ble_gw: Stop scan success:25, num:316
    [09:21:01.170]收←◆[00:02:58.356,445] <inf> lte_ble_gw: start scan success
    [00:02:58.456,512] <inf> lte_ble_gw: Stop scan success:34, num:318
    [09:21:02.197]收←◆+CEREG: 2,"7859","01824ADC",9
    [00:02:59.440,093] <inf> lte_ble_gw: start scan success
    [00:02:59.526,245] <inf> lte_ble_gw: Stop scan success:36, num:320
    [09:21:03.350]收←◆[00:03:00.536,407] <inf> lte_ble_gw: start scan success
    [00:03:00.647,125] <inf> lte_ble_gw: Stop scan success:36, num:322
    [09:21:04.434]收←◆[00:03:01.620,117] <inf> lte_ble_gw: start scan success
    [00:03:01.704,071] <inf> lte_ble_gw: Stop scan success:37, num:324
    [09:21:05.530]收←◆[00:03:02.716,461] <inf> lte_ble_gw: start scan success
    [00:03:02.813,262] <inf> lte_ble_gw: Stop scan success:26, num:326
    [09:21:06.621]收←◆[00:03:03.806,518] <inf> lte_ble_gw: start scan success
    [00:03:03.883,178] <wrn> bt_driver: Unable to send H:4 type
    [09:21:15.697]收←◆ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:331
    	command opcode 0x200c timeout with err -11
    [00:03:13.883,056] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000000  r2/a3:  0x00000002
    [00:03:13.883,056] <err> os: r3/a4:  0x2000d2f8 r12/ip:  0x00000010 r14/lr:  0x0000ee11
    [00:03:13.883,087] <err> os:  xpsr:  0x41000000
    [00:03:13.883,087] <err> os: Faulting instruction address (r15/pc): 0x0000ee1c
    [00:03:13.883,117] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    [00:03:13.883,148] <err> os: Current thread: 0x2000f8c8 (unknown)
    [00:03:13.939,361] <err> fatal_error: Resetting system\0
    [09:21:16.295]收←◆*** Booting nRF Connect SDK v3.5.99-ncs1-1-1-g02ae5d8ded21 ***
    [00:00:00.260,223] <inf> lte_ble_gw: LTE Sensor Gateway sample started
    [00:00:00.260,437] <inf> lte_ble_gw: Initializing Bluetooth..
    [00:00:00.262,298] <wrn> lpuart: req pin low when expected high
    [00:00:00.262,420] <err> lpuart: Empty receiver state:4
    [09:21:17.050]收←◆[00:00:00.514,221] <inf> lte_ble_gw: Establishing LTE link (this may take some time) ...
    [00:00:00.963,745] <wrn> bt_hci_core: opcode 0x0000 pool id 3 pool 0x2000d040 != &hci_cmd_pool 0x2000d0a8
    [00:00:01.005,798] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:01.005,828] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:01.005,859] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
    [00:00:01.014,495] <inf> bt_hci_core: Identity: D4:CB:39:15:51:B3 (random)
    [00:00:01.014,526] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x118f, manufacturer 0x0059
    [00:00:01.014,556] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x118f
    [00:00:01.014,556] <inf> lte_ble_gw: Bluetooth ready
    [00:00:01.014,617] <inf> lte_ble_gw: Scanning...
    [09:21:42.683]收←◆5.642,578] <inf> lte_ble_gw: start scan success
    [00:00:25.727,539] <inf> lte_ble_gw: Stop scan success:32, num:38
    [09:21:43.767]收←◆[00:00:26.732,604] <inf> lte_ble_gw: start scan success
    [00:00:26.816,528] <inf> lte_ble_gw: Stop scan success:33, num:40
    [09:21:44.857]收←◆[00:00:27.822,662] <inf> lte_ble_gw: start scan success
    [00:00:27.906,555] <inf> lte_ble_gw: Stop scan success:29, num:42
    [09:21:45.947]收←◆[00:00:28.912,628] <inf> lte_ble_gw: start scan success
    [00:00:28.997,467] <inf> lte_ble_gw: Stop scan success:28, num:44
    [09:21:47.037]收←◆[00:00:30.002,685] <inf> lte_ble_gw: start scan success
    [00:00:30.086,914] <inf> lte_ble_gw: Stop scan success:27, num:46
    [09:21:48.127]收←◆[00:00:31.092,742] <inf> lte_ble_gw: start scan success
    [00:00:31.177,398] <inf> lte_ble_gw: Stop scan success:25, num:48
    [09:21:49.217]收←◆[00:00:32.182,739] <inf> lte_ble_gw: start scan success
    [00:00:32.267,395] <inf> lte_ble_gw: Stop scan success:27, num:50
    [09:21:50.307]收←◆[00:00:33.272,766] <inf> lte_ble_gw: start scan success
    [00:00:33.357,116] <inf> lte_ble_gw: Stop scan success:29, num:52
    [09:21:51.397]收←◆[00:00:34.362,762] <inf> lte_ble_gw: start scan success
    [00:00:34.446,777] <inf> lte_ble_gw: Stop scan success:27, num:54
    [09:21:52.487]收←◆[00:00:35.452,819] <inf> lte_ble_gw: start scan success
    [00:00:35.536,743] <inf> lte_ble_gw: Stop scan success:25, num:56
    [09:21:53.577]收←◆[00:00:36.542,846] <inf> lte_ble_gw: start scan success
    [00:00:36.626,983] <inf> lte_ble_gw: Stop scan success:24, num:58
    [09:21:54.668]收←◆[00:00:37.632,904] <inf> lte_ble_gw: start scan success
    [00:00:37.716,796] <inf> lte_ble_gw: Stop scan success:34, num:60
    [09:21:55.758]收←◆[00:00:38.722,900] <inf> lte_ble_gw: start scan success
    [00:00:38.806,823] <inf> lte_ble_gw: Stop scan success:28, num:62
    [09:21:56.847]收←◆[00:00:39.812,927] <inf> lte_ble_gw: start scan success
    [00:00:39.896,881] <inf> lte_ble_gw: Stop scan success:25, num:64
    [09:21:57.937]收←◆[00:00:40.902,984] <inf> lte_ble_gw: start scan success
    [00:00:40.987,548] <inf> lte_ble_gw: Stop scan success:36, num:66
    [09:21:59.028]收←◆[00:00:41.992,980] <inf> lte_ble_gw: start scan success
    [00:00:42.078,002] <inf> lte_ble_gw: Stop scan success:24, num:68
    [09:22:00.118]收←◆[00:00:43.083,007] <inf> lte_ble_gw: start scan success
    [00:00:43.166,931] <inf> lte_ble_gw: Stop scan success:24, num:70
    [09:22:01.207]收←◆[00:00:44.173,065] <inf> lte_ble_gw: start scan success
    [00:00:44.257,080] <inf> lte_ble_gw: Stop scan success:31, num:72
    [09:22:02.297]收←◆[00:00:45.263,061] <inf> lte_ble_gw: start scan success
    [00:00:45.347,198] <inf> lte_ble_gw: Stop scan success:27, num:74
    [09:22:03.388]收←◆[00:00:46.353,088] <inf> lte_ble_gw: start scan success
    [00:00:46.437,255] <inf> lte_ble_gw: Stop scan success:29, num:76
    [09:22:04.478]收←◆[00:00:47.443,145] <inf> lte_ble_gw: start scan success
    [00:00:47.527,160] <inf> lte_ble_gw: Stop scan success:26, num:78
    [09:22:05.568]收←◆[00:00:48.533,142] <inf> lte_ble_gw: start scan success
    [00:00:48.617,065] <inf> lte_ble_gw: Stop scan success:22, num:80
    [09:22:06.657]收←◆[00:00:49.623,168] <inf> lte_ble_gw: start scan success
    [00:00:49.707,092] <inf> lte_ble_gw: Stop scan success:27, num:82
    [09:22:07.749]收←◆[00:00:50.713,226] <inf> lte_ble_gw: start scan success
    [00:00:50.797,119] <inf> lte_ble_gw: Stop scan success:32, num:84
    [09:22:08.838]收←◆[00:00:51.803,222] <inf> lte_ble_gw: start scan success
    [00:00:51.887,237] <inf> lte_ble_gw: Stop scan success:28, num:86
    [09:22:09.012]收←◆[00:00:52.893,249] <inf> lte_ble_gw: start scan success
    [00:00:52.978,790] <err> os: ***** SECURE FAULT *****
    [00:00:52.978,790] <err> os:   Address: 0xc
    [00:00:52.978,820] <err> os:   Attribution unit violation
    [00:00:52.978,820] <err> os: r0/a1:  0x00000001  r1/a2:  0x00000057  r2/a3:  0x40031000
    [00:00:52.978,851] <err> os: r3/a4:  0x00000000 r12/ip:  0x2000f858 r14/lr:  0x000250d9
    [00:00:52.978,881] <err> os:  xpsr:  0x61000000
    [00:00:52.978,881] <err> os: Faulting instruction address (r15/pc): 0x00016110
    [00:00:52.978,912] <err> os: >>> ZEPHYR FATAL ERROR 41: Unknown error on CPU 0
    [00:00:52.978,942] <err> os: Current thread: 0x2000d868 (unknown)
    [00:00:53.046,997] <err> fatal_error: Resetting system\0
    [09:22:09.622]收←◆*** Booting nRF Connect SDK v3.5.99-ncs1-1-1-g02ae5d8ded21 ***
    [00:00:00.260,070] <inf> lte_ble_gw: LTE Sensor Gateway sample started
    [00:00:00.260,528] <inf> lte_ble_gw: Initializing Bluetooth..
    [00:00:00.270,874] <wrn> lpuart: req pin low when expected high
    [00:00:00.270,965] <err> lpuart: Empty receiver state:4
    [09:22:10.377]收←◆[00:00:00.512
    [09:22:10.397]收←◆,390] <inf> lte_ble_gw: Establishing LTE link (this may take some time) ...
    [00:00:00.963,775] <wrn> bt_hci_core: opcode 0x0000 pool id 3 pool 0x2000d040 != &hci_cmd_pool 0x2000d0a8
    [00:00:01.005,828] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:01.005,859] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:01.005,889] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
    [00:00:01.014,587] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x118f
    [00:00:01.014,587] <inf> lte_ble_gw: Bluetooth ready
    [09:22:16.385]收←◆[00:00:06.022,186] <inf> lte_ble_gw: start scan success
    [00:00:06.106,048] <inf> lte_ble_gw: Stop scan success:30, num:2
    I am sorry for the delay. I will look into this and get bac to you next week.
    A short update from my. Using  your project and nRF Connect SDK 2.2.0 I am able to reproduce the issue, but I do not have an explanation for the cause. I will continue to look into it.
    I am sorry for the delay. I have not made much progress on my end. This is n old demo that is a bit unstable under load, and that seems to have always been the case. I am continuing to look into it, but it may take some time. Please let me know if you have any progress on your end as well.
    Br,
    Einar
  • Hi, Thank you for your efforts.
    I'll try to reduce the scan window to test and see if I can reduce the probability of the problem happening.
    I am sorry for the delay. There is a issue with stable communication between the nRF91 and nRF52840 in this sample and inherited by your application, and we are continuing to look into it.
