ERROR: update failed for projects: matter, cmock
I'm trying to set up nRF Connect Toolchain and SDK manually using west, but I've encountered the following error:
C:\ncs>west update
=== updating zephyr (zephyr):
HEAD is now at 100befc70c7 [nrf fromtree] sysbuild: introduce sysbuild_root for root adjustment
=== updating bsim (tools/bsim):
HEAD is now at 68f6282 developer_set: Remove .git suffix in paths
=== updating hostap (modules/lib/hostap):
HEAD is now at 6311fde66 [nrf noup] mbedtls: Fix memory leak
=== updating wfa-qt-control-app (modules/lib/wfa-qt-control-app):
HEAD is now at 9f91589 [nrf noup] zephyr: Fix POSIX failures
=== updating mcuboot (bootloader/mcuboot):
HEAD is now at daf2946a [nrf noup] boot/../loader: reboot after updating s0/s1
=== updating qcbor (modules/tee/tf-m/qcbor):
HEAD is now at 751d365 restore inc/qcbor.h for backwards compatibility (#181)
=== updating mbedtls (modules/crypto/mbedtls):
HEAD is now at 72868c6f1 [nrf noup] Add MBEDTLS_PSA_CRYPTO_CLIENT support for TLS/DTLS and X.509
=== updating oberon-psa-crypto (modules/crypto/oberon-psa-crypto):
HEAD is now at e0800ec [nrf noup] Allow import and destroy of builtin keys
=== updating nrfxlib (nrfxlib):
HEAD is now at 37e2ac22 nrf_modem: doc: add info about PDN down when NRF_SO_KEEPOPEN is used
=== updating trusted-firmware-m (modules/tee/tf-m/trusted-firmware-m):
HEAD is now at 553c47a6a [nrf noup] Fix version warning
=== updating psa-arch-tests (modules/tee/tf-m/psa-arch-tests):
HEAD is now at 94a349d [nrf fromlist] Fix base address for the nrf watchdog
=== updating matter (modules/lib/matter):
HEAD is now at 022f2c92f6 [nrf toup] Fix missing network band in scan response.
      2 [main] sh 1309 dofork: child -1 - forked process 1880 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/Program Files/Git/mingw64/libexec/git-core\git-submodule: fork: retry: Resource temporarily unavailable
1144801 [main] sh 1309 dofork: child -1 - forked process 12712 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
3297060 [main] sh 1309 dofork: child -1 - forked process 12204 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
7446900 [main] sh 1309 dofork: child -1 - forked process 5340 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
15554313 [main] sh 1309 dofork: child -1 - forked process 8900 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/Program Files/Git/mingw64/libexec/git-core\git-submodule: fork: Resource temporarily unavailable
=== updating soc-hwmv1 (modules/soc-hwmv1):
HEAD is now at 32b1ee3 soc: Update Kconfig.peripherals from sdk-zephyr bdda11b
=== updating cjson (modules/lib/cjson):
HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
=== updating azure-sdk-for-c (modules/lib/azure-sdk-for-c):
HEAD is now at 308c171c [nrf fromlist] Make repository a Zephyr module
=== updating cirrus (modules/hal/cirrus-logic):
HEAD is now at 3873a08 Added missing curly brace for #ifdef __cplusplus
=== updating openthread (modules/lib/openthread):
HEAD is now at a57d927b0 [string] add `ParseDigit()`, `ParseHexDigit()`, and other helper functions (#10282)
=== updating suit-generator (modules/lib/suit-generator):
HEAD is now at 3458313 feat: add binary file name value to template generator
=== updating suit-processor (modules/lib/suit-processor):
HEAD is now at 4505925 Fix coverity issues for 2.7 release
=== updating cmock (test/cmock):
HEAD is now at f65066f Merge pull request #404 from tz18/patch-1
      2 [main] sh 571 dofork: child -1 - forked process 7224 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
1128330 [main] sh 571 dofork: child -1 - forked process 12532 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
3236469 [main] sh 571 dofork: child -1 - forked process 11448 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
7364927 [main] sh 571 dofork: child -1 - forked process 7004 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
15487507 [main] sh 571 dofork: child -1 - forked process 7876 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
=== updating memfault-firmware-sdk (modules/lib/memfault-firmware-sdk):
HEAD is now at 3d51c80 Memfault Firmware SDK 1.6.0 (Build 5464)
=== updating coremark (modules/benchmark/coremark):
HEAD is now at d5fad6b Merge pull request #51 from volodymyr-bondarchuk/zephyr
=== updating canopennode (modules/lib/canopennode):
HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t()
=== updating chre (modules/lib/chre):
HEAD is now at 3b32c76e zephyr: link the .unstable_id data in ROM
=== updating lz4 (modules/lib/lz4):
HEAD is now at 8e303c2 zephyr: make this repo a zephyr module
=== updating nanopb (modules/lib/nanopb):
HEAD is now at 7f88274 Add migration note about CMake protoc default (#958)
=== updating tf-m-tests (modules/tee/tf-m/tf-m-tests):
HEAD is now at 85f533a Crypto: Use RSA key in PSA format
=== updating zscilib (modules/lib/zscilib):
HEAD is now at ee1b287 samples/tests: Update for hwmv2 board names
=== updating cmsis (modules/hal/cmsis):
HEAD is now at 4b96cbb doc: Update documentations for CMSIS 5.9.0
=== updating cmsis-dsp (modules/lib/cmsis-dsp):
HEAD is now at 6489e771 do not generate warnings when scalar functions are used with MVE
=== updating cmsis-nn (modules/lib/cmsis-nn):
HEAD is now at 0c8669d Merge pull request #1 from XenuIsWatching/zephyr
=== updating edtt (tools/edtt):
HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop
=== updating fatfs (modules/fs/fatfs):
HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE
=== updating hal_nordic (modules/hal/nordic):
HEAD is now at ab5cb2e nrfx: drivers: nrfx_gpiote: move enabling GPIOTE port interrupt
=== updating hal_st (modules/hal/st):
HEAD is now at b77157f drivers: sensor: st: Move to vendor subdirectory
=== updating hal_wurthelektronik (modules/hal/wurthelektronik):
HEAD is now at e5bcb2e Update WE sensors SDK to version 2.5.0
=== updating libmetal (modules/hal/libmetal):
HEAD is now at 243eed5 lib: update libmetal to SHA f55c02a7b582
=== updating liblc3 (modules/lib/liblc3):
HEAD is now at 1a5938e meson: Bump to version 1.0.4
=== updating littlefs (modules/fs/littlefs):
HEAD is now at 408c16a Merge pull request #14 from de-nordic/update-to-v2.8.1
=== updating loramac-node (modules/lib/loramac-node):
HEAD is now at fb00b383 zephyr: configure FragDecoder using Kconfig
=== updating lvgl (modules/lib/gui/lvgl):
HEAD is now at 2b498e6f Merge pull request #51 from faxe1008/upddate_lvgl_840
=== updating mipi-sys-t (modules/debug/mipi-sys-t):
HEAD is now at 71ace1f mipi_syst: fix build error when having protocol timestamp disabled
=== updating net-tools (tools/net-tools):
HEAD is now at 7c7a856 websocket-console: Add a helper script for websocket console
=== updating nrf_hw_models (modules/bsim_hw_models/nrf_hw_models):
HEAD is now at 36b1271 54L15: Added RRAMC, RRAM & UICR
=== updating open-amp (modules/lib/open-amp):
HEAD is now at da78aea lib: update open-amp lib to release v2023.10.0
=== updating picolibc (modules/lib/picolibc):
HEAD is now at 764ef4e40 Version 1.8.6
=== updating segger (modules/debug/segger):
HEAD is now at b011c45 segger: config: Add CCM option for linker sections
=== updating tinycrypt (modules/crypto/tinycrypt):
HEAD is now at 1012a3e Fix warnings reported by UBSAN
=== updating uoscore-uedhoc (modules/lib/uoscore-uedhoc):
HEAD is now at 150f4eb [zephyr fromlist] Adapt to changes in name generation in zcbor 0.8.0
=== updating zcbor (modules/lib/zcbor):
HEAD is now at 75d0880 tests: Update mps2 board name
Before encountering this error, I tried to install SDK automatically from VS Code extension, which I successfully installed the 2.7.0 toolchain but failed to install the SDK multiple times, and from tool chain manager from nRF Connect for Desktop for 4 times, which also ended in failure with the same log as the VS Code did. This is the log file of the installation by the tool chain manager:
2024-09-07T14:56:07.335Z INFO Initialising nrfutil module: toolchain-manager
2024-09-07T14:56:07.394Z INFO Initializing environments...
2024-09-07T14:56:07.396Z DEBUG Application data folder: C:\Users\user\AppData\Roaming\nrfconnect\pc-nrfconnect-toolchain-manager
2024-09-07T14:56:07.831Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T14:56:07.833Z DEBUG App pc-nrfconnect-toolchain-manager v1.5.1 (official)
2024-09-07T14:56:07.833Z DEBUG App path: C:\Users\user\.nrfconnect-apps\node_modules\pc-nrfconnect-toolchain-manager
2024-09-07T14:56:07.834Z DEBUG nRFConnect 5.0.2, required by the app is (>=5.0.2)
2024-09-07T14:56:07.834Z DEBUG nRFConnect path: C:\Users\user\AppData\Local\Programs\nrfconnect\resources\app.asar
2024-09-07T14:56:07.834Z DEBUG HomeDir: C:\Users\user
2024-09-07T14:56:07.835Z DEBUG TmpDir: C:\Users\user\AppData\Local\Temp
2024-09-07T14:56:07.970Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T14:56:10.645Z DEBUG Sending event "toolchain-manager: Status of VS Code installation"
2024-09-07T14:56:10.646Z DEBUG Sending event "toolchain-manager: Status of nrfjprog installation"
2024-09-07T14:56:10.818Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T14:56:10.820Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T14:56:10.974Z INFO Using nrfutil-toolchain-manager core version: 7.13.0
2024-09-07T14:56:11.051Z INFO nrfutil-toolchain-manager 0.15.0 (30dc218a99ce1abd296f9ff5de836eacda2cc474 2024-06-12)
2024-09-07T14:56:11.087Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T14:56:11.092Z INFO Using toolchain-manager version: 0.15.0
2024-09-07T14:56:11.277Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T14:56:12.512Z INFO Toolchain v2.7.99-cs1 has been added to the list
2024-09-07T14:56:12.513Z INFO Toolchain v2.7.0 has been added to the list
2024-09-07T14:56:12.514Z INFO Toolchain v2.7.0-rc3 has been added to the list
2024-09-07T14:56:12.515Z INFO Toolchain v2.7.0-rc2 has been added to the list
2024-09-07T14:56:12.517Z INFO Toolchain v2.7.0-rc1 has been added to the list
2024-09-07T14:56:12.517Z INFO Toolchain v2.6.99-cs2 has been added to the list
2024-09-07T14:56:12.518Z INFO Toolchain v2.6.1 has been added to the list
2024-09-07T14:56:12.519Z INFO Toolchain v2.6.0 has been added to the list
2024-09-07T14:56:12.520Z INFO Toolchain v2.6.0-rc2 has been added to the list
2024-09-07T14:56:12.521Z INFO Toolchain v2.6.0-rc1 has been added to the list
2024-09-07T14:56:12.522Z INFO Toolchain v2.5.3 has been added to the list
2024-09-07T14:56:12.523Z INFO Toolchain v2.5.2 has been added to the list
2024-09-07T14:56:12.524Z INFO Toolchain v2.5.1 has been added to the list
2024-09-07T14:56:12.525Z INFO Toolchain v2.5.0 has been added to the list
2024-09-07T14:56:12.526Z INFO Toolchain v2.5.0-rc2 has been added to the list
2024-09-07T14:56:12.527Z INFO Toolchain v2.5.0-rc1 has been added to the list
2024-09-07T14:56:12.529Z INFO Toolchain v2.4.4 has been added to the list
2024-09-07T14:56:12.530Z INFO Toolchain v2.4.3 has been added to the list
2024-09-07T14:56:12.531Z INFO Toolchain v2.4.2 has been added to the list
2024-09-07T14:56:12.531Z INFO Toolchain v2.4.1 has been added to the list
2024-09-07T14:56:12.532Z INFO Toolchain v2.4.0 has been added to the list
2024-09-07T14:56:12.533Z INFO Toolchain v2.4.0-rc1 has been added to the list
2024-09-07T14:56:12.534Z INFO Toolchain v2.3.0 has been added to the list
2024-09-07T14:56:12.535Z INFO Toolchain v2.3.0-rc1 has been added to the list
2024-09-07T14:56:12.536Z INFO Toolchain v2.2.99-dev3 has been added to the list
2024-09-07T14:56:12.537Z INFO Toolchain v2.2.0 has been added to the list
2024-09-07T14:56:12.538Z INFO Toolchain v2.2.0-rc1 has been added to the list
2024-09-07T14:56:12.540Z INFO Toolchain v2.1.3 has been added to the list
2024-09-07T14:56:12.541Z INFO Toolchain v2.1.2 has been added to the list
2024-09-07T14:56:12.542Z INFO Toolchain v2.1.1 has been added to the list
2024-09-07T14:56:12.543Z INFO Toolchain v2.1.0 has been added to the list
2024-09-07T14:56:12.546Z INFO Toolchain v2.1.0-rc2 has been added to the list
2024-09-07T14:56:12.547Z INFO Toolchain v2.1.0-rc1 has been added to the list
2024-09-07T14:56:12.548Z INFO Toolchain v2.0.2 has been added to the list
2024-09-07T14:56:12.548Z INFO Toolchain v2.0.1 has been added to the list
2024-09-07T14:56:12.549Z INFO Toolchain v2.0.0 has been added to the list
2024-09-07T14:56:12.551Z INFO Toolchain v2.0.0-rc2 has been added to the list
2024-09-07T14:56:12.776Z DEBUG Downloading index json with buffer length: 9261
2024-09-07T14:56:12.777Z DEBUG Index json has been downloaded with result: [
        "version": "v1.4.99-dev1",
        "toolchains": [
                "version": "20201204",
                "name": "ncs-toolchain-v1.4.99-dev1-20201204-7e01b60.zip",
                "sha512": "18a975e0607bade592e728e6f3addfd88bcca861153ce6679f24b506ab3ed496a720dac7d8b536c8f1ddb18f2654b2e8b74500deed6c9a6a67d65d3ab72d2aea"
        "version": "v1.4.1",
        "toolchains": [
                "version": "20201215",
                "name": "ncs-toolchain-v1.4.1-20201215-7ecf886.zip",
                "sha512": "94a32758310a7a930085e671a4dd37d2ead292ddbf4d40d7146940e2981d121d5c6d3706a436ef0ac22cce607a071750f1c6ffd788a52f47407153a73bdaefff"
        "version": "v1.4.0",
        "toolchains": [
                "version": "20201030",
                "name": "ncs-toolchain-v1.4.0-20201030-2750604.zip",
                "sha512": "2eb53d3950af53947ba15434b32e31238d224f3906d78679c17f5b02d8492d9718f1121bbd721fbf39424ffb556d7e042cfac4565d75e9f3b0fbf8800bbc082c"
        "version": "v1.3.2",
        "toolchains": [
                "version": "20201012",
                "name": "ncs-toolchain-v1.3.2-20201012-09b2ade.zip",
                "sha512": "1c9a0a4d916143c007b6aa2919f4c0a101e0563a1d00cf12b6fc3bea4fd065979bea030905c2538c5694eed4d44d4fbe5ae285d10298bc3b57b39166c1f2d6cc"
        "version": "v1.3.1",
        "toolchains": [
                "version": "20200917",
                "name": "ncs-toolchain-v1.3.1-20200917-806240b.zip",
                "sha512": "5a9fc19c09a6573715fbe0b6dff5e7950f025f3b6665040bfa1a21b8a16fc8e82b60f1186f3d815eff158a12ad63904765072e25389016109292516d0fba277e"
        "version": "v1.3.0",
        "toolchains": [
                "version": "20200618",
                "name": "ncs-toolchain-v1.3.0-20200618-509f057.zip",
                "sha512": "6ab7e4cfd94c7fa574a4e6e5395c04ba143ebc7fffe9cdc0dc1a4a2da912f5f39aa56dc54feb44f8a40d7c1117233710ddeb12a0a40fc5a95f733044f8a5b9fb"
        "version": "v1.3.0-rc1",
        "toolchains": [
                "version": "20200602",
                "name": "ncs-toolchain-v1.3.0-rc1-20200602-dbcfd6c.zip",
                "sha512": "7b17afff0961e1a7d25d7b332e5be3e7ebdcf189dc8f0e3b581ec0fbb39fd564e05c7c99ba45a5796822175e1d21fe8fac28be07fe94d415bc11f6a85a5fa367"
                "version": "20200609",
                "name": "ncs-toolchain-v1.3.0-rc1-20200609-590da70.zip",
                "sha512": "7ced1d4db15bf125a7612ea9ff0e076843366c778d06f7a4e81cf5009b9e883dd3da61c15452ab973a1a581737228996509b805b3a2f0471c7497b5615622673"
        "version": "v1.2.1",
        "toolchains": [
                "version": "20200625",
                "name": "ncs-toolchain-v1.2.1-20200625-153a59e.zip",
                "sha512": "8b41e562cd392db503d1601e74b50f083e7c71f9dcec5befa13d5dbddce8d4d3a57ebe1701ed8754df54a8cba8886741d4bc52e2de2b628682cfcb4244dd9b73"
        "version": "v1.2.0",
        "toolchains": [
                "version": "20200217",
                "name": "ncs-toolchain-v1.2.0-20200217-a56f2eb.zip",
                "sha512": "931369c90d8d53e966c8f3efc99be87fd0a9175dac1b4b54b7647e05809e0124fb34cf740a7d2575245633840c0547a741b581ebad637b1cdb35cb181048e3c6"
                "version": "20200218",
                "name": "ncs-toolchain-v1.2.0-20200218-0ef73a3.zip",
                "sha512": "48ae4b973c706cf94c1ee2866d29a73d156d6b5575fd7b3e40edf64323e4577f6f6259879b7b79faaea176900fde02d5d45fa44a81c9ee60655d80926a3d1154"
                "version": "20200225",
                "name": "ncs-toolchain-v1.2.0-20200225-52e8a34.zip",
                "sha512": "2ac84f7c664763ff7803061714ed97c06bda778fb6b55327642129bb086fe98da79a83d4cd40964a1eb6cde61f7a47bddf0aa6a8c53e13bf1b7bcafdb5cb40b6"
                "version": "20200303",
                "name": "ncs-toolchain-v1.2.0-20200303-457af40.zip",
                "sha512": "18f059e238766f0a837b98dfeba87772937bf24d8e627d77dc1adf52d394a92da3788d0a62458fa5448b06d6191acf95287b7e6830812092bb55396051798e23"
                "version": "20200401",
                "name": "ncs-toolchain-v1.2.0-20200401-cf4ebd3.zip",
                "sha512": "f7d404775dab0e752cf10e6ea0785544ad17578c3155828aa77409e5fc211df42758ca1944d5c5271c04dd5697bf3189564f3e16385ed09d21346dbd812b1834"
        "version": "v1.4.2",
        "toolchains": [
                "version": "20210113",
                "name": "ncs-toolchain-v1.4.2-20210113-7ecf886.zip",
                "sha512": "4498414542dd2bc7fcb5b7d74083ad5cc7c8ac81b12ec0fe50fcbf3fb6c80ae7f7fbfe8c87eebeec32467d25cbbbee1aacb6cf37b773c2a0299c482c905c786a"
        "version": "v1.5.0-rc1",
        "toolchains": [
                "version": "20210215",
                "name": "ncs-toolchain-v1.5.0-rc1-20210215-2c30941.zip",
                "sha512": "b214a17a01ba72ec9e2c39a072692e85374dd0de6d6d4db43452f28fba2896ac23e7883db008707305292b8e107cf8dc593ac8535a26001b6b7ab0f923269a43"
        "version": "v1.5.0",
        "toolchains": [
                "version": "20210225",
                "name": "ncs-toolchain-v1.5.0-20210225-607a0e0.zip",
                "sha512": "5781e7500271805e1595ebf3eb04e75b5bd1e0f204dcb29a7c172d2b388f1a9a62b0fd40483b6d529c4e0a6a2f138e040fabb5ca2e360a40256ccb87c573bdce"
        "version": "v1.5.1-rc1",
        "toolchains": [
                "version": "20210409",
                "name": "ncs-toolchain-v1.5.1-rc1-20210409-96ab6aa.zip",
                "sha512": "8b4b971a8c02e2dfa3ddc37a1e5af23e74bd9663f262af5a95a47c22303db84b9ec4d3b0e39937466559c6357bb4e2bbb0739582bab300635b3748eae8109203"
        "version": "v1.5.1",
        "toolchains": [
                "version": "20210416",
                "name": "ncs-toolchain-v1.5.1-20210416-96ab6aa.zip",
                "sha512": "c211f8e5442b3f58a53f712e4fd6500153308e3c4063a0858ec682a27c1b5a42e4c15d63a52efe441b88e45490e93595620a442e4091abfc2d4ed1e46df4162a"
        "version": "v1.6.0",
        "toolchains": [
                "version": "20210701",
                "name": "ncs-toolchain-v1.6.0-20210701-de414c8.zip",
                "sha512": "06562bc82e3b7e757131520410d89a791c996ed0c495b0d428b0e14c808e91bf8616979946e87804b774f08011716e27afa73e3d82d5051785b11857bce66c52"
        "version": "v1.6.1",
        "toolchains": [
                "version": "20210729",
                "name": "ncs-toolchain-v1.6.1-20210729-3e85a62.zip",
                "sha512": "a9c7a2581fcac8ccb2a03d0959ed08908fa0c9e44361b5e958840b0a4ba203d4c252fba65c772b165640502927ae7fbe31ed13236fd1c28781157db32190d8c4"
        "version": "v1.7.0",
        "toolchains": [
                "version": "20210923",
                "name": "ncs-toolchain-v1.7.0-20210923-4c380d0.zip",
                "sha512": "5352ba5ec154cde5c3ba62d1f49ea55910852765c9ade6bed85adc303713adcf7a416bd284a2dff9eb216613a2ff7685bd53ee307c457955329d73aafa285634"
        "version": "v1.7.1",
        "toolchains": [
                "version": "20211028",
                "name": "ncs-toolchain-v1.7.1-20211028-4c380d0.zip",
                "sha512": "226161242cbb6acfcf5d0fcc2eb7f60c923da91446495ddfa29084103ec493d0f173773bcde505193981c9cced48a2176a2ed6f7b282be7233848985194ff516"
        "version": "v1.8.0",
        "toolchains": [
                "version": "20211214",
                "name": "ncs-toolchain-v1.8.0-20211214-4c380d0.zip",
                "sha512": "80d5df162c6f286b742e9c207c860d3cf4fbc7d1f79b3c2de2dbd8e4faa00847aded3016a497a01ef707ed6c82bd0039a08a2129984c292eeb3a3477bfde87b5"
        "version": "v1.9.0",
        "toolchains": [
                "version": "20220217",
                "name": "ncs-toolchain-v1.9.0-20220217-728bbd5.zip",
                "sha512": "2d9cece9c41d93c5bebd082e303c77416147960a77f2768e2ffb713bfc5b0eb21766c0ae660bcf82ba80479a5430c4d9f064546debb696ceddb8c2cd5d3382d4"
        "version": "v1.9.1",
        "toolchains": [
                "version": "20220304",
                "name": "ncs-toolchain-v1.9.1-20220304-728bbd5.zip",
                "sha512": "97c125b00a9d4004924f43edb74fdb69f930dd4b6f04ca7cc4d54efa5aa75a56977b29115ee4ad798c3e42636d36f94064b12d59c7f3ad11f08e0740f063a42c"
2024-09-07T14:56:12.781Z INFO Toolchain v1.4.99-dev1 has been added to the list
2024-09-07T14:56:12.782Z INFO Toolchain v1.4.1 has been added to the list
2024-09-07T14:56:12.784Z INFO Toolchain v1.4.0 has been added to the list
2024-09-07T14:56:12.785Z INFO Toolchain v1.3.2 has been added to the list
2024-09-07T14:56:12.787Z INFO Toolchain v1.3.1 has been added to the list
2024-09-07T14:56:12.788Z INFO Toolchain v1.3.0 has been added to the list
2024-09-07T14:56:12.790Z INFO Toolchain v1.3.0-rc1 has been added to the list
2024-09-07T14:56:12.791Z INFO Toolchain v1.2.1 has been added to the list
2024-09-07T14:56:12.792Z INFO Toolchain v1.2.0 has been added to the list
2024-09-07T14:56:12.795Z INFO Toolchain v1.4.2 has been added to the list
2024-09-07T14:56:12.796Z INFO Toolchain v1.5.0-rc1 has been added to the list
2024-09-07T14:56:12.798Z INFO Toolchain v1.5.0 has been added to the list
2024-09-07T14:56:12.800Z INFO Toolchain v1.5.1-rc1 has been added to the list
2024-09-07T14:56:12.802Z INFO Toolchain v1.5.1 has been added to the list
2024-09-07T14:56:12.803Z INFO Toolchain v1.6.0 has been added to the list
2024-09-07T14:56:12.805Z INFO Toolchain v1.6.1 has been added to the list
2024-09-07T14:56:12.807Z INFO Toolchain v1.7.0 has been added to the list
2024-09-07T14:56:12.808Z INFO Toolchain v1.7.1 has been added to the list
2024-09-07T14:56:12.809Z INFO Toolchain v1.8.0 has been added to the list
2024-09-07T14:56:12.811Z INFO Toolchain v1.9.0 has been added to the list
2024-09-07T14:56:12.812Z INFO Toolchain v1.9.1 has been added to the list
2024-09-07T14:56:19.713Z INFO Start to install toolchain v2.7.0
2024-09-07T14:56:19.775Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T15:02:05.217Z DEBUG Sending event "toolchain-manager: Install toolchain from nrfutil"
2024-09-07T15:02:05.219Z INFO Cloning nRF Connect SDK v2.7.0
2024-09-07T15:02:05.221Z DEBUG Sending event "toolchain-manager: Clone nRF Connect SDK"
2024-09-07T15:02:05.259Z INFO Initializing environment for v2.7.0
2024-09-07T15:02:05.275Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T15:02:06.465Z DEBUG === Initializing in C:\ncs\v2.7.0
2024-09-07T15:02:06.466Z DEBUG --- Cloning manifest repository from https://github.com/nrfconnect/sdk-nrf, rev. v2.7.0
2024-09-07T15:03:21.994Z DEBUG --- setting manifest.path to nrf
2024-09-07T15:03:22.038Z DEBUG === Initialized. Now run "west update" inside C:\ncs\v2.7.0.
2024-09-07T15:03:22.102Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T15:03:22.973Z DEBUG === updating zephyr (zephyr):
2024-09-07T15:03:22.975Z INFO Updating zephyr repository for v2.7.0
2024-09-07T15:03:23.003Z DEBUG --- zephyr: initializing
2024-09-07T15:03:23.121Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/zephyr/.git/
2024-09-07T15:03:23.225Z DEBUG --- zephyr: fetching, need revision v3.6.99-ncs2
2024-09-07T15:07:15.988Z DEBUG === updating bsim (tools/bsim):
2024-09-07T15:07:16.039Z INFO Updating bsim repository for v2.7.0
2024-09-07T15:07:16.072Z DEBUG --- bsim: initializing
2024-09-07T15:07:16.107Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/tools/bsim/.git/
2024-09-07T15:07:16.244Z DEBUG --- bsim: fetching, need revision 68f6282c6a7f54641b75f5f9fc953c85e272a983
2024-09-07T15:07:21.850Z DEBUG === updating hostap (modules/lib/hostap):
2024-09-07T15:07:21.894Z INFO Updating hostap repository for v2.7.0
2024-09-07T15:07:21.929Z DEBUG --- hostap: initializing
2024-09-07T15:07:21.957Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/hostap/.git/
2024-09-07T15:07:22.054Z DEBUG --- hostap: fetching, need revision 6311fde66f87ac8c8838a2d5fcfe55a498a8682a
2024-09-07T15:07:45.637Z DEBUG === updating wfa-qt-control-app (modules/lib/wfa-qt-control-app):
2024-09-07T15:07:45.688Z INFO Updating wfa-qt-control-app repository for v2.7.0
2024-09-07T15:07:45.723Z DEBUG --- wfa-qt-control-app: initializing
2024-09-07T15:07:45.742Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/wfa-qt-control-app/.git/
2024-09-07T15:07:45.862Z DEBUG --- wfa-qt-control-app: fetching, need revision 9f91589a5be2b95a77a2b109901aad3298255315
2024-09-07T15:07:48.707Z DEBUG === updating mcuboot (bootloader/mcuboot):
2024-09-07T15:07:48.708Z INFO Updating mcuboot repository for v2.7.0
2024-09-07T15:07:48.732Z DEBUG --- mcuboot: initializing
2024-09-07T15:07:49.639Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/bootloader/mcuboot/.git/
2024-09-07T15:07:49.735Z DEBUG --- mcuboot: fetching, need revision v2.1.0-ncs1
2024-09-07T15:08:01.417Z DEBUG === updating qcbor (modules/tee/tf-m/qcbor):
2024-09-07T15:08:01.466Z INFO Updating qcbor repository for v2.7.0
2024-09-07T15:08:01.499Z DEBUG --- qcbor: initializing
2024-09-07T15:08:01.537Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/tee/tf-m/qcbor/.git/
2024-09-07T15:08:01.635Z DEBUG --- qcbor: fetching, need revision 751d36583a9ce1a640900c57e13c9b6b8f3a2ba2
2024-09-07T15:08:06.524Z DEBUG === updating mbedtls (modules/crypto/mbedtls):
2024-09-07T15:08:06.572Z INFO Updating mbedtls repository for v2.7.0
2024-09-07T15:08:06.606Z DEBUG --- mbedtls: initializing
2024-09-07T15:08:06.645Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/crypto/mbedtls/.git/
2024-09-07T15:08:06.732Z DEBUG --- mbedtls: fetching, need revision v3.5.2-ncs2
2024-09-07T15:08:46.444Z DEBUG === updating oberon-psa-crypto (modules/crypto/oberon-psa-crypto):
2024-09-07T15:08:46.494Z INFO Updating oberon-psa-crypto repository for v2.7.0
2024-09-07T15:08:46.526Z DEBUG --- oberon-psa-crypto: initializing
2024-09-07T15:08:46.546Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto/.git/
2024-09-07T15:08:46.660Z DEBUG --- oberon-psa-crypto: fetching, need revision e0800ec5283ba89b2619919ef1889d98a9a79132
2024-09-07T15:08:57.181Z DEBUG === updating nrfxlib (nrfxlib):
2024-09-07T15:08:57.228Z INFO Updating nrfxlib repository for v2.7.0
2024-09-07T15:08:57.263Z DEBUG --- nrfxlib: initializing
2024-09-07T15:08:57.280Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/nrfxlib/.git/
2024-09-07T15:08:57.379Z DEBUG --- nrfxlib: fetching, need revision v2.7.0
2024-09-07T15:10:17.636Z DEBUG === updating trusted-firmware-m (modules/tee/tf-m/trusted-firmware-m):
2024-09-07T15:10:17.685Z INFO Updating trusted-firmware-m repository for v2.7.0
2024-09-07T15:10:17.713Z DEBUG --- trusted-firmware-m: initializing
2024-09-07T15:10:17.772Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m/.git/
2024-09-07T15:10:17.890Z DEBUG --- trusted-firmware-m: fetching, need revision v2.0.0-ncs2
2024-09-07T15:10:49.081Z DEBUG === updating psa-arch-tests (modules/tee/tf-m/psa-arch-tests):
2024-09-07T15:10:49.131Z INFO Updating psa-arch-tests repository for v2.7.0
2024-09-07T15:10:49.163Z DEBUG --- psa-arch-tests: initializing
2024-09-07T15:10:49.208Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/tee/tf-m/psa-arch-tests/.git/
2024-09-07T15:10:49.312Z DEBUG --- psa-arch-tests: fetching, need revision 94a349db22cd0e44136c281724ffc71b6e7391c3
2024-09-07T15:11:01.317Z DEBUG === updating matter (modules/lib/matter):
2024-09-07T15:11:01.365Z INFO Updating matter repository for v2.7.0
2024-09-07T15:11:01.399Z DEBUG --- matter: initializing
2024-09-07T15:11:01.453Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/matter/.git/
2024-09-07T15:11:01.533Z DEBUG --- matter: fetching, need revision v2.7.0
2024-09-07T15:13:51.326Z DEBUG nrf-802154: skipping inactive project
2024-09-07T15:13:51.377Z DEBUG === updating soc-hwmv1 (modules/soc-hwmv1):
2024-09-07T15:13:51.379Z INFO Updating soc-hwmv1 repository for v2.7.0
2024-09-07T15:13:51.380Z DEBUG --- soc-hwmv1: initializing
2024-09-07T15:13:51.455Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/soc-hwmv1/.git/
2024-09-07T15:13:51.543Z DEBUG --- soc-hwmv1: fetching, need revision 32b1ee3e4576815bebf9ce3e8d63efe73bd89c62
2024-09-07T15:13:54.062Z DEBUG dragoon: skipping inactive project
2024-09-07T15:13:54.063Z DEBUG === updating cjson (modules/lib/cjson):
2024-09-07T15:13:54.064Z INFO Updating cjson repository for v2.7.0
2024-09-07T15:13:54.064Z DEBUG --- cjson: initializing
2024-09-07T15:13:54.165Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/cjson/.git/
2024-09-07T15:13:54.275Z DEBUG --- cjson: fetching, need revision c6af068b7f05207b28d68880740e4b9ec1e4b50a
2024-09-07T15:13:59.454Z DEBUG sidewalk: skipping inactive project
2024-09-07T15:13:59.498Z DEBUG find-my: skipping inactive project
2024-09-07T15:13:59.500Z DEBUG === updating azure-sdk-for-c (modules/lib/azure-sdk-for-c):
2024-09-07T15:13:59.501Z INFO Updating azure-sdk-for-c repository for v2.7.0
2024-09-07T15:13:59.502Z DEBUG --- azure-sdk-for-c: initializing
2024-09-07T15:13:59.552Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c/.git/
2024-09-07T15:13:59.652Z DEBUG --- azure-sdk-for-c: fetching, need revision 308c171cb4b5eed266649012a68406487ec81fb2
2024-09-07T15:14:07.435Z DEBUG === updating cirrus (modules/hal/cirrus-logic):
2024-09-07T15:14:07.480Z INFO Updating cirrus repository for v2.7.0
2024-09-07T15:14:07.515Z DEBUG --- cirrus: initializing
2024-09-07T15:14:07.542Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/cirrus-logic/.git/
2024-09-07T15:14:07.641Z DEBUG --- cirrus: fetching, need revision 3873a08377d93a479105a75ac390d3bbcd31d690
2024-09-07T15:14:21.012Z DEBUG === updating openthread (modules/lib/openthread):
2024-09-07T15:14:21.057Z INFO Updating openthread repository for v2.7.0
2024-09-07T15:14:21.095Z DEBUG --- openthread: initializing
2024-09-07T15:14:21.140Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/openthread/.git/
2024-09-07T15:14:21.221Z DEBUG --- openthread: fetching, need revision a57d927b0ace94972a49ea2672c9073b88b86377
2024-09-07T15:14:59.736Z DEBUG === updating suit-generator (modules/lib/suit-generator):
2024-09-07T15:14:59.784Z INFO Updating suit-generator repository for v2.7.0
2024-09-07T15:14:59.813Z DEBUG --- suit-generator: initializing
2024-09-07T15:14:59.881Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/suit-generator/.git/
2024-09-07T15:14:59.986Z DEBUG --- suit-generator: fetching, need revision v2.7.0
2024-09-07T15:15:03.150Z DEBUG === updating suit-processor (modules/lib/suit-processor):
2024-09-07T15:15:03.151Z INFO Updating suit-processor repository for v2.7.0
2024-09-07T15:15:03.178Z DEBUG --- suit-processor: initializing
2024-09-07T15:15:03.250Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/suit-processor/.git/
2024-09-07T15:15:03.346Z DEBUG --- suit-processor: fetching, need revision v2.7.0
2024-09-07T15:15:06.809Z DEBUG === updating cmock (test/cmock):
2024-09-07T15:15:06.859Z INFO Updating cmock repository for v2.7.0
2024-09-07T15:15:06.892Z DEBUG --- cmock: initializing
2024-09-07T15:15:06.920Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/test/cmock/.git/
2024-09-07T15:15:07.046Z DEBUG --- cmock: fetching, need revision f65066f15d8248e6dcb778efb8739904a4512087
2024-09-07T15:15:30.090Z DEBUG === updating memfault-firmware-sdk (modules/lib/memfault-firmware-sdk):
2024-09-07T15:15:30.141Z INFO Updating memfault-firmware-sdk repository for v2.7.0
2024-09-07T15:15:30.176Z DEBUG --- memfault-firmware-sdk: initializing
2024-09-07T15:15:30.195Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk/.git/
2024-09-07T15:15:30.322Z DEBUG --- memfault-firmware-sdk: fetching, need revision 1.6.0
2024-09-07T15:15:43.335Z DEBUG ant: skipping inactive project
2024-09-07T15:15:43.385Z DEBUG bme68x: skipping inactive project
2024-09-07T15:15:43.386Z DEBUG bsec: skipping inactive project
2024-09-07T15:15:43.387Z DEBUG === updating coremark (modules/benchmark/coremark):
2024-09-07T15:15:43.388Z INFO Updating coremark repository for v2.7.0
2024-09-07T15:15:43.389Z DEBUG --- coremark: initializing
2024-09-07T15:15:43.463Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/benchmark/coremark/.git/
2024-09-07T15:15:43.579Z DEBUG --- coremark: fetching, need revision d5fad6bd094899101a4e5fd53af7298160ced6ab
2024-09-07T15:15:49.010Z DEBUG === updating canopennode (modules/lib/canopennode):
2024-09-07T15:15:49.057Z INFO Updating canopennode repository for v2.7.0
2024-09-07T15:15:49.092Z DEBUG --- canopennode: initializing
2024-09-07T15:15:49.109Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/canopennode/.git/
2024-09-07T15:15:49.209Z DEBUG --- canopennode: fetching, need revision dec12fa3f0d790cafa8414a4c2930ea71ab72ffd
2024-09-07T15:15:52.497Z DEBUG === updating chre (modules/lib/chre):
2024-09-07T15:15:52.544Z INFO Updating chre repository for v2.7.0
2024-09-07T15:15:52.576Z DEBUG --- chre: initializing
2024-09-07T15:15:52.596Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/chre/.git/
2024-09-07T15:15:52.703Z DEBUG --- chre: fetching, need revision 3b32c76efee705af146124fb4190f71be5a4e36e
2024-09-07T15:16:00.105Z DEBUG === updating lz4 (modules/lib/lz4):
2024-09-07T15:16:00.153Z INFO Updating lz4 repository for v2.7.0
2024-09-07T15:16:00.188Z DEBUG --- lz4: initializing
2024-09-07T15:16:00.246Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/lz4/.git/
2024-09-07T15:16:00.327Z DEBUG --- lz4: fetching, need revision 8e303c264fc21c2116dc612658003a22e933124d
2024-09-07T15:16:07.586Z DEBUG === updating nanopb (modules/lib/nanopb):
2024-09-07T15:16:07.628Z INFO Updating nanopb repository for v2.7.0
2024-09-07T15:16:07.664Z DEBUG --- nanopb: initializing
2024-09-07T15:16:07.682Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/nanopb/.git/
2024-09-07T15:16:07.780Z DEBUG --- nanopb: fetching, need revision 7f88274070afa5edfaf608f4d8e32f3d3c1de139
2024-09-07T15:16:18.289Z DEBUG === updating tf-m-tests (modules/tee/tf-m/tf-m-tests):
2024-09-07T15:16:18.336Z INFO Updating tf-m-tests repository for v2.7.0
2024-09-07T15:16:18.372Z DEBUG --- tf-m-tests: initializing
2024-09-07T15:16:18.400Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/tee/tf-m/tf-m-tests/.git/
2024-09-07T15:16:18.515Z DEBUG --- tf-m-tests: fetching, need revision 85f533a4aa5b4fe31247676a923db7453eb4429c
2024-09-07T15:16:25.477Z DEBUG === updating zscilib (modules/lib/zscilib):
2024-09-07T15:16:25.527Z INFO Updating zscilib repository for v2.7.0
2024-09-07T15:16:25.562Z DEBUG --- zscilib: initializing
2024-09-07T15:16:25.580Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/zscilib/.git/
2024-09-07T15:16:25.685Z DEBUG --- zscilib: fetching, need revision ee1b287d9dd07208d2cc52284240ac25bb66eae3
2024-09-07T15:16:32.423Z DEBUG === updating cmsis (modules/hal/cmsis):
2024-09-07T15:16:32.474Z INFO Updating cmsis repository for v2.7.0
2024-09-07T15:16:32.507Z DEBUG --- cmsis: initializing
2024-09-07T15:16:32.529Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/cmsis/.git/
2024-09-07T15:16:32.649Z DEBUG --- cmsis: fetching, need revision 4b96cbb174678dcd3ca86e11e1f24bc5f8726da0
2024-09-07T15:16:36.601Z DEBUG === updating cmsis-dsp (modules/lib/cmsis-dsp):
2024-09-07T15:16:36.646Z INFO Updating cmsis-dsp repository for v2.7.0
2024-09-07T15:16:36.680Z DEBUG --- cmsis-dsp: initializing
2024-09-07T15:16:36.720Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/cmsis-dsp/.git/
2024-09-07T15:16:36.806Z DEBUG --- cmsis-dsp: fetching, need revision 6489e771e9c405f1763b52d64a3f17a1ec488ace
2024-09-07T15:17:05.291Z DEBUG === updating cmsis-nn (modules/lib/cmsis-nn):
2024-09-07T15:17:05.340Z INFO Updating cmsis-nn repository for v2.7.0
2024-09-07T15:17:05.374Z DEBUG --- cmsis-nn: initializing
2024-09-07T15:17:05.400Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/cmsis-nn/.git/
2024-09-07T15:17:05.507Z DEBUG --- cmsis-nn: fetching, need revision 0c8669d81381ccf3b1a01d699f3b68b50134a99f
2024-09-07T15:17:12.550Z DEBUG === updating edtt (tools/edtt):
2024-09-07T15:17:12.600Z INFO Updating edtt repository for v2.7.0
2024-09-07T15:17:12.638Z DEBUG --- edtt: initializing
2024-09-07T15:17:12.680Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/tools/edtt/.git/
2024-09-07T15:17:12.776Z DEBUG --- edtt: fetching, need revision 64e5105ad82390164fb73fc654be3f73a608209a
2024-09-07T15:17:16.096Z DEBUG === updating fatfs (modules/fs/fatfs):
2024-09-07T15:17:16.144Z INFO Updating fatfs repository for v2.7.0
2024-09-07T15:17:16.180Z DEBUG --- fatfs: initializing
2024-09-07T15:17:16.213Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/fs/fatfs/.git/
2024-09-07T15:17:16.322Z DEBUG --- fatfs: fetching, need revision 427159bf95ea49b7680facffaa29ad506b42709b
2024-09-07T15:17:22.516Z DEBUG === updating hal_nordic (modules/hal/nordic):
2024-09-07T15:17:22.565Z INFO Updating hal_nordic repository for v2.7.0
2024-09-07T15:17:22.601Z DEBUG --- hal_nordic: initializing
2024-09-07T15:17:22.649Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/nordic/.git/
2024-09-07T15:17:22.733Z DEBUG --- hal_nordic: fetching, need revision ab5cb2e2faeb1edfad7a25286dcb513929ae55da
2024-09-07T15:17:39.285Z DEBUG === updating hal_st (modules/hal/st):
2024-09-07T15:17:39.336Z INFO Updating hal_st repository for v2.7.0
2024-09-07T15:17:39.373Z DEBUG --- hal_st: initializing
2024-09-07T15:17:39.394Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/st/.git/
2024-09-07T15:17:39.503Z DEBUG --- hal_st: fetching, need revision b77157f6bc4395e398d90ab02a7d2cbc01ab2ce7
2024-09-07T15:17:57.152Z DEBUG === updating hal_wurthelektronik (modules/hal/wurthelektronik):
2024-09-07T15:17:57.202Z INFO Updating hal_wurthelektronik repository for v2.7.0
2024-09-07T15:17:57.238Z DEBUG --- hal_wurthelektronik: initializing
2024-09-07T15:17:57.250Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/wurthelektronik/.git/
2024-09-07T15:17:57.355Z DEBUG --- hal_wurthelektronik: fetching, need revision e5bcb2eac1bb9639ce13b4dafc78eb254e014342
2024-09-07T15:17:59.596Z DEBUG === updating libmetal (modules/hal/libmetal):
2024-09-07T15:17:59.597Z INFO Updating libmetal repository for v2.7.0
2024-09-07T15:17:59.625Z DEBUG --- libmetal: initializing
2024-09-07T15:17:59.692Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/libmetal/.git/
2024-09-07T15:17:59.794Z DEBUG --- libmetal: fetching, need revision 243eed541b9c211a2ce8841c788e62ddce84425e
2024-09-07T15:18:03.161Z DEBUG === updating liblc3 (modules/lib/liblc3):
2024-09-07T15:18:03.162Z INFO Updating liblc3 repository for v2.7.0
2024-09-07T15:18:03.191Z DEBUG --- liblc3: initializing
2024-09-07T15:18:03.257Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/liblc3/.git/
2024-09-07T15:18:03.356Z DEBUG --- liblc3: fetching, need revision 1a5938ebaca4f13fe79ce074f5dee079783aa29f
2024-09-07T15:18:06.566Z DEBUG === updating littlefs (modules/fs/littlefs):
2024-09-07T15:18:06.568Z INFO Updating littlefs repository for v2.7.0
2024-09-07T15:18:06.597Z DEBUG --- littlefs: initializing
2024-09-07T15:18:06.674Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/fs/littlefs/.git/
2024-09-07T15:18:06.782Z DEBUG --- littlefs: fetching, need revision 408c16a909dd6cf128874a76f21c793798c9e423
2024-09-07T15:18:10.505Z DEBUG === updating loramac-node (modules/lib/loramac-node):
2024-09-07T15:18:10.553Z INFO Updating loramac-node repository for v2.7.0
2024-09-07T15:18:10.586Z DEBUG --- loramac-node: initializing
2024-09-07T15:18:10.656Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/loramac-node/.git/
2024-09-07T15:18:10.723Z DEBUG --- loramac-node: fetching, need revision fb00b383072518c918e2258b0916c996f2d4eebe
2024-09-07T15:18:31.106Z DEBUG === updating lvgl (modules/lib/gui/lvgl):
2024-09-07T15:18:31.154Z INFO Updating lvgl repository for v2.7.0
2024-09-07T15:18:31.183Z DEBUG --- lvgl: initializing
2024-09-07T15:18:31.247Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/gui/lvgl/.git/
2024-09-07T15:18:31.349Z DEBUG --- lvgl: fetching, need revision 2b498e6f36d6b82ae1da12c8b7742e318624ecf5
2024-09-07T15:19:00.361Z DEBUG === updating mipi-sys-t (modules/debug/mipi-sys-t):
2024-09-07T15:19:00.411Z INFO Updating mipi-sys-t repository for v2.7.0
2024-09-07T15:19:00.447Z DEBUG --- mipi-sys-t: initializing
2024-09-07T15:19:00.472Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/debug/mipi-sys-t/.git/
2024-09-07T15:19:00.569Z DEBUG --- mipi-sys-t: fetching, need revision 71ace1f5caa03e56c8740a09863e685efb4b2360
2024-09-07T15:19:03.764Z DEBUG === updating net-tools (tools/net-tools):
2024-09-07T15:19:03.766Z INFO Updating net-tools repository for v2.7.0
2024-09-07T15:19:03.793Z DEBUG --- net-tools: initializing
2024-09-07T15:19:03.879Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/tools/net-tools/.git/
2024-09-07T15:19:03.967Z DEBUG --- net-tools: fetching, need revision 7c7a856814d7f27509c8511fef14cec21f7d0c30
2024-09-07T15:19:11.969Z DEBUG === updating nrf_hw_models (modules/bsim_hw_models/nrf_hw_models):
2024-09-07T15:19:12.019Z INFO Updating nrf_hw_models repository for v2.7.0
2024-09-07T15:19:12.050Z DEBUG --- nrf_hw_models: initializing
2024-09-07T15:19:12.088Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/bsim_hw_models/nrf_hw_models/.git/
2024-09-07T15:19:12.185Z DEBUG --- nrf_hw_models: fetching, need revision 36b12714a5ed32450d907c89bb118f6280da3483
2024-09-07T15:19:19.744Z DEBUG === updating open-amp (modules/lib/open-amp):
2024-09-07T15:19:19.788Z INFO Updating open-amp repository for v2.7.0
2024-09-07T15:19:19.825Z DEBUG --- open-amp: initializing
2024-09-07T15:19:19.867Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/open-amp/.git/
2024-09-07T15:19:19.960Z DEBUG --- open-amp: fetching, need revision da78aea63159771956fe0c9263f2e6985b66e9d5
2024-09-07T15:19:24.008Z DEBUG === updating picolibc (modules/lib/picolibc):
2024-09-07T15:19:24.055Z INFO Updating picolibc repository for v2.7.0
2024-09-07T15:19:24.089Z DEBUG --- picolibc: initializing
2024-09-07T15:19:24.116Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/picolibc/.git/
2024-09-07T15:19:24.231Z DEBUG --- picolibc: fetching, need revision 764ef4e401a8f4c6a86ab723533841f072885a5b
2024-09-07T15:20:53.456Z DEBUG === updating segger (modules/debug/segger):
2024-09-07T15:20:53.506Z INFO Updating segger repository for v2.7.0
2024-09-07T15:20:53.545Z DEBUG --- segger: initializing
2024-09-07T15:20:53.577Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/debug/segger/.git/
2024-09-07T15:20:53.690Z DEBUG --- segger: fetching, need revision b011c45b585e097d95d9cf93edf4f2e01588d3cd
2024-09-07T15:20:55.886Z DEBUG === updating tinycrypt (modules/crypto/tinycrypt):
2024-09-07T15:20:55.887Z INFO Updating tinycrypt repository for v2.7.0
2024-09-07T15:20:55.916Z DEBUG --- tinycrypt: initializing
2024-09-07T15:20:55.980Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/crypto/tinycrypt/.git/
2024-09-07T15:20:56.077Z DEBUG --- tinycrypt: fetching, need revision 1012a3ebee18c15ede5efc8332ee2fc37817670f
2024-09-07T15:21:00.547Z DEBUG === updating uoscore-uedhoc (modules/lib/uoscore-uedhoc):
2024-09-07T15:21:00.595Z INFO Updating uoscore-uedhoc repository for v2.7.0
2024-09-07T15:21:00.631Z DEBUG --- uoscore-uedhoc: initializing
2024-09-07T15:21:00.672Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc/.git/
2024-09-07T15:21:00.768Z DEBUG --- uoscore-uedhoc: fetching, need revision 150f4eb2955eaf36ac0f9519d4f4f58d5ade5740
2024-09-07T15:21:06.580Z DEBUG === updating zcbor (modules/lib/zcbor):
2024-09-07T15:21:06.624Z INFO Updating zcbor repository for v2.7.0
2024-09-07T15:21:06.662Z DEBUG --- zcbor: initializing
2024-09-07T15:21:06.705Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/zcbor/.git/
2024-09-07T15:21:06.825Z DEBUG --- zcbor: fetching, need revision 75d088037eb237b18e7ec1f47c9ce494b9b95aab
2024-09-07T15:21:11.732Z DEBUG babblesim_base: skipping inactive project
2024-09-07T15:21:11.772Z DEBUG babblesim_ext_2G4_libPhyComv1: skipping inactive project
2024-09-07T15:21:11.773Z DEBUG babblesim_ext_2G4_phy_v1: skipping inactive project
2024-09-07T15:21:11.773Z DEBUG babblesim_ext_2G4_channel_NtNcable: skipping inactive project
2024-09-07T15:21:11.774Z DEBUG babblesim_ext_2G4_channel_multiatt: skipping inactive project
2024-09-07T15:21:11.774Z DEBUG babblesim_ext_2G4_modem_magic: skipping inactive project
2024-09-07T15:21:11.775Z DEBUG babblesim_ext_2G4_modem_BLE_simple: skipping inactive project
2024-09-07T15:21:11.775Z DEBUG babblesim_ext_2G4_device_burst_interferer: skipping inactive project
2024-09-07T15:21:11.775Z DEBUG babblesim_ext_2G4_device_WLAN_actmod: skipping inactive project
2024-09-07T15:21:11.776Z DEBUG babblesim_ext_2G4_device_playback: skipping inactive project
2024-09-07T15:21:11.777Z DEBUG babblesim_ext_2G4_device_playbackv2: skipping inactive project
2024-09-07T15:21:11.777Z DEBUG babblesim_ext_libCryptov1: skipping inactive project
2024-09-07T15:21:11.858Z ERROR Failed to clone the repositories: Error: From https://github.com/nrfconnect/sdk-zephyr
 * tag                       v3.6.99-ncs2              -> FETCH_HEAD
 * [new tag]                 v1.13.99-ncs1             -> v1.13.99-ncs1
 * [new tag]                 v1.13.99-ncs1-rc1         -> v1.13.99-ncs1-rc1
 * [new tag]                 v1.13.99-ncs2             -> v1.13.99-ncs2
 * [new tag]                 v1.13.99-ncs2-rc1         -> v1.13.99-ncs2-rc1
 * [new tag]                 v1.13.99-ncs2-rc2         -> v1.13.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs1             -> v1.14.99-ncs1
 * [new tag]                 v1.14.99-ncs1-rc1         -> v1.14.99-ncs1-rc1
 * [new tag]                 v1.14.99-ncs1-rc2         -> v1.14.99-ncs1-rc2
 * [new tag]                 v1.14.99-ncs2             -> v1.14.99-ncs2
 * [new tag]                 v1.14.99-ncs2-rc1         -> v1.14.99-ncs2-rc1
 * [new tag]                 v1.14.99-ncs2-rc2         -> v1.14.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs2-rc3         -> v1.14.99-ncs2-rc3
 * [new tag]                 v1.14.99-ncs2-rc4         -> v1.14.99-ncs2-rc4
 * [new tag]                 v1.14.99-ncs3-snapshot1   -> v1.14.99-ncs3-snapshot1
 * [new tag]                 v1.14.99-ncs3-snapshot2   -> v1.14.99-ncs3-snapshot2
 * [new tag]                 v2.0.99-ncs1              -> v2.0.99-ncs1
 * [new tag]                 v2.0.99-ncs1-rc1          -> v2.0.99-ncs1-rc1
 * [new tag]                 v2.0.99-ncs1-rc2          -> v2.0.99-ncs1-rc2
 * [new tag]                 v2.0.99-ncs1-rc3          -> v2.0.99-ncs1-rc3
 * [new tag]                 v2.0.99-ncs1-snapshot1    -> v2.0.99-ncs1-snapshot1
 * [new tag]                 v2.1.0-ncs1-snapshot1     -> v2.1.0-ncs1-snapshot1
 * [new tag]                 v2.1.99-ncs1              -> v2.1.99-ncs1
 * [new tag]                 v2.1.99-ncs1-rc1          -> v2.1.99-ncs1-rc1
 * [new tag]                 v2.1.99-ncs1-rc2          -> v2.1.99-ncs1-rc2
 * [new tag]                 v2.1.99-ncs1-snapshot1    -> v2.1.99-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs1           -> v2.3.0-rc1-ncs1
 * [new tag]                 v2.3.0-rc1-ncs1-rc1       -> v2.3.0-rc1-ncs1-rc1
 * [new tag]                 v2.3.0-rc1-ncs1-rc2       -> v2.3.0-rc1-ncs1-rc2
 * [new tag]                 v2.3.0-rc1-ncs1-rc3       -> v2.3.0-rc1-ncs1-rc3
 * [new tag]                 v2.3.0-rc1-ncs1-snapshot1 -> v2.3.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs2           -> v2.3.0-rc1-ncs2
 * [new tag]                 v2.3.0-rc1-ncs3           -> v2.3.0-rc1-ncs3
 * [new tag]                 v2.4.0-ncs1               -> v2.4.0-ncs1
 * [new tag]                 v2.4.0-ncs1-rc1           -> v2.4.0-ncs1-rc1
 * [new tag]                 v2.4.0-ncs1-rc2           -> v2.4.0-ncs1-rc2
 * [new tag]                 v2.4.0-ncs1-snapshot1     -> v2.4.0-ncs1-snapshot1
 * [new tag]                 v2.4.0-ncs2               -> v2.4.0-ncs2
 * [new tag]                 v2.4.0-ncs2-rc1           -> v2.4.0-ncs2-rc1
 * [new tag]                 v2.4.99-ncs1              -> v2.4.99-ncs1
 * [new tag]                 v2.4.99-ncs1-rc1          -> v2.4.99-ncs1-rc1
 * [new tag]                 v2.4.99-ncs1-snapshot1    -> v2.4.99-ncs1-snapshot1
 * [new tag]                 v2.4.99-ncs2              -> v2.4.99-ncs2
 * [new tag]                 v2.4.99-ncs2-1            -> v2.4.99-ncs2-1
 * [new tag]                 v2.4.99-ncs2-rc1          -> v2.4.99-ncs2-rc1
 * [new tag]                 v2.6.0-ncs1-rc3           -> v2.6.0-ncs1-rc3
 * [new tag]                 v2.6.0-rc1-ncs1           -> v2.6.0-rc1-ncs1
 * [new tag]                 v2.6.0-rc1-ncs1-rc1       -> v2.6.0-rc1-ncs1-rc1
 * [new tag]                 v2.6.0-rc1-ncs1-snapshot1 -> v2.6.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.6.99-ncs1              -> v2.6.99-ncs1
 * [new tag]                 v2.6.99-ncs1-1            -> v2.6.99-ncs1-1
 * [new tag]                 v2.6.99-ncs1-rc1          -> v2.6.99-ncs1-rc1
 * [new tag]                 v2.6.99-ncs1-rc2          -> v2.6.99-ncs1-rc2
 * [new tag]                 v2.6.99-ncs1-snapshot1    -> v2.6.99-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1               -> v2.7.0-ncs1
 * [new tag]                 v2.7.0-ncs1-rc1           -> v2.7.0-ncs1-rc1
 * [new tag]                 v2.7.0-ncs1-rc2           -> v2.7.0-ncs1-rc2
 * [new tag]                 v2.7.0-ncs1-snapshot1     -> v2.7.0-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1-snapshot2     -> v2.7.0-ncs1-snapshot2
 * [new tag]                 v2.7.99-ncs1              -> v2.7.99-ncs1
 * [new tag]                 v2.7.99-ncs1-1            -> v2.7.99-ncs1-1
 * [new tag]                 v2.7.99-ncs1-rc1          -> v2.7.99-ncs1-rc1
 * [new tag]                 v2.7.99-ncs1-rc2          -> v2.7.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1              -> v3.0.99-ncs1
 * [new tag]                 v3.0.99-ncs1-1            -> v3.0.99-ncs1-1
 * [new tag]                 v3.0.99-ncs1-rc1          -> v3.0.99-ncs1-rc1
 * [new tag]                 v3.0.99-ncs1-rc2          -> v3.0.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1-snapshot1    -> v3.0.99-ncs1-snapshot1
 * [new tag]                 v3.1.99-ncs1              -> v3.1.99-ncs1
 * [new tag]                 v3.1.99-ncs1-1            -> v3.1.99-ncs1-1
 * [new tag]                 v3.1.99-ncs1-2            -> v3.1.99-ncs1-2
 * [new tag]                 v3.1.99-ncs1-3            -> v3.1.99-ncs1-3
 * [new tag]                 v3.1.99-ncs1-rc1          -> v3.1.99-ncs1-rc1
 * [new tag]                 v3.1.99-ncs1-rc2          -> v3.1.99-ncs1-rc2
 * [new tag]                 v3.1.99-ncs1-snapshot1    -> v3.1.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs1              -> v3.2.99-ncs1
 * [new tag]                 v3.2.99-ncs1-rc1          -> v3.2.99-ncs1-rc1
 * [new tag]                 v3.2.99-ncs1-rc2          -> v3.2.99-ncs1-rc2
 * [new tag]                 v3.2.99-ncs1-snapshot1    -> v3.2.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs2              -> v3.2.99-ncs2
 * [new tag]                 v3.2.99-ncs2-rc1          -> v3.2.99-ncs2-rc1
 * [new tag]                 v3.2.99-ncs2-rc2          -> v3.2.99-ncs2-rc2
 * [new tag]                 v3.2.99-ncs2-snapshot1    -> v3.2.99-ncs2-snapshot1
 * [new tag]                 v3.3.99-ncs1              -> v3.3.99-ncs1
 * [new tag]                 v3.3.99-ncs1-1            -> v3.3.99-ncs1-1
 * [new tag]                 v3.3.99-ncs1-2            -> v3.3.99-ncs1-2
 * [new tag]                 v3.3.99-ncs1-3            -> v3.3.99-ncs1-3
 * [new tag]                 v3.3.99-ncs1-rc1          -> v3.3.99-ncs1-rc1
 * [new tag]                 v3.3.99-ncs1-rc2          -> v3.3.99-ncs1-rc2
 * [new tag]                 v3.3.99-ncs1-snapshot1    -> v3.3.99-ncs1-snapshot1
 * [new tag]                 v3.4.99-ncs1              -> v3.4.99-ncs1
 * [new tag]                 v3.4.99-ncs1-1            -> v3.4.99-ncs1-1
 * [new tag]                 v3.4.99-ncs1-1-rc1        -> v3.4.99-ncs1-1-rc1
 * [new tag]                 v3.4.99-ncs1-2            -> v3.4.99-ncs1-2
 * [new tag]                 v3.4.99-ncs1-3            -> v3.4.99-ncs1-3
 * [new tag]                 v3.4.99-ncs1-rc1          -> v3.4.99-ncs1-rc1
 * [new tag]                 v3.4.99-ncs1-rc2          -> v3.4.99-ncs1-rc2
 * [new tag]                 v3.4.99-ncs1-snapshot1    -> v3.4.99-ncs1-snapshot1
 * [new tag]                 v3.5.99-ncs1              -> v3.5.99-ncs1
 * [new tag]                 v3.5.99-ncs1-1            -> v3.5.99-ncs1-1
 * [new tag]                 v3.5.99-ncs1-rc1          -> v3.5.99-ncs1-rc1
 * [new tag]                 v3.5.99-ncs1-rc2          -> v3.5.99-ncs1-rc2
 * [new tag]                 v3.5.99-ncs1-snapshot1    -> v3.5.99-ncs1-snapshot1
 * [new tag]                 v3.6.99-ncs2              -> v3.6.99-ncs2
 * [new tag]                 v3.6.99-ncs2-rc1          -> v3.6.99-ncs2-rc1
 * [new tag]                 v3.6.99-ncs2-rc2          -> v3.6.99-ncs2-rc2
 * [new tag]                 v3.6.99-ncs2-rc3          -> v3.6.99-ncs2-rc3
 * [new tag]                 v3.6.99-ncs2-snapshot1    -> v3.6.99-ncs2-snapshot1
From https://github.com/BabbleSim/bsim_west
 * [new branch]      main       -> refs/west/main
 * [new branch]      v2.1       -> refs/west/v2.1
 * [new branch]      v2.1.1     -> refs/west/v2.1.1
 * [new branch]      v2.2       -> refs/west/v2.2
 * [new branch]      v2.2.1     -> refs/west/v2.2.1
 * [new branch]      v2.3       -> refs/west/v2.3
From https://github.com/nrfconnect/sdk-hostap
 * [new branch]          hcs                      -> refs/west/hcs
 * [new branch]          hostap_2_11_devel-ncs1-branch -> refs/west/hostap_2_11_devel-ncs1-branch
 * [new branch]          nrf700x-dev              -> refs/west/nrf700x-dev
 * [new branch]          nrf700x-test             -> refs/west/nrf700x-test
 * [new branch]          v2.5-branch              -> refs/west/v2.5-branch
 * [new branch]          v2.6-branch              -> refs/west/v2.6-branch
 * [new tag]             fix_sauce_tag_snapshot   -> fix_sauce_tag_snapshot
 * [new tag]             hostap_2_11_devel-ncs1   -> hostap_2_11_devel-ncs1
 * [new tag]             prepare_upmerge_snapshot -> prepare_upmerge_snapshot
From https://github.com/nrfconnect/sdk-wi-fiquicktrack-controlappc
 * [new branch]      qt_v2.5.1      -> refs/west/qt_v2.5.1
 * [new tag]         R2.1-snapshot1 -> R2.1-snapshot1
 * [new tag]         pre_zephyr_separation_snapshot -> pre_zephyr_separation_snapshot
From https://github.com/nrfconnect/sdk-mcuboot
 * tag                 v2.1.0-ncs1             -> FETCH_HEAD
 * [new tag]           v1.10.0-ncs1            -> v1.10.0-ncs1
 * [new tag]           v1.10.0-ncs1-1          -> v1.10.0-ncs1-1
 * [new tag]           v1.10.0-ncs1-rc1        -> v1.10.0-ncs1-rc1
 * [new tag]           v1.10.0-ncs1-rc2        -> v1.10.0-ncs1-rc2
 * [new tag]           v1.10.0-ncs1-snapshot1  -> v1.10.0-ncs1-snapshot1
 * [new tag]           v1.10.99-ncs1           -> v1.10.99-ncs1
 * [new tag]           v1.10.99-ncs1-1         -> v1.10.99-ncs1-1
 * [new tag]           v1.10.99-ncs1-1-rc1     -> v1.10.99-ncs1-1-rc1
 * [new tag]           v1.10.99-ncs1-2         -> v1.10.99-ncs1-2
 * [new tag]           v1.10.99-ncs1-3         -> v1.10.99-ncs1-3
 * [new tag]           v1.10.99-ncs1-rc1       -> v1.10.99-ncs1-rc1
 * [new tag]           v1.10.99-ncs1-rc2       -> v1.10.99-ncs1-rc2
 * [new tag]           v1.10.99-ncs1-snapshot1 -> v1.10.99-ncs1-snapshot1
 * [new tag]           v1.2.99-ncs1            -> v1.2.99-ncs1
 * [new tag]           v1.2.99-ncs1-rc1        -> v1.2.99-ncs1-rc1
 * [new tag]           v1.2.99-ncs2            -> v1.2.99-ncs2
 * [new tag]           v1.2.99-ncs2-rc1        -> v1.2.99-ncs2-rc1
 * [new tag]           v1.2.99-ncs2-rc2        -> v1.2.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs1            -> v1.3.99-ncs1
 * [new tag]           v1.3.99-ncs1-rc1        -> v1.3.99-ncs1-rc1
 * [new tag]           v1.3.99-ncs1-rc2        -> v1.3.99-ncs1-rc2
 * [new tag]           v1.3.99-ncs2            -> v1.3.99-ncs2
 * [new tag]           v1.3.99-ncs2-rc1        -> v1.3.99-ncs2-rc1
 * [new tag]           v1.3.99-ncs2-rc2        -> v1.3.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs2-rc3        -> v1.3.99-ncs2-rc3
 * [new tag]           v1.3.99-ncs2-rc4        -> v1.3.99-ncs2-rc4
 * [new tag]           v1.3.99-ncs3-snapshot1  -> v1.3.99-ncs3-snapshot1
 * [new tag]           v1.3.99-ncs3-snapshot2  -> v1.3.99-ncs3-snapshot2
 * [new tag]           v1.4.99-ncs1            -> v1.4.99-ncs1
 * [new tag]           v1.4.99-ncs1-rc1        -> v1.4.99-ncs1-rc1
 * [new tag]           v1.4.99-ncs1-rc2        -> v1.4.99-ncs1-rc2
 * [new tag]           v1.4.99-ncs1-rc3        -> v1.4.99-ncs1-rc3
 * [new tag]           v1.4.99-ncs1-snapshot1  -> v1.4.99-ncs1-snapshot1
 * [new tag]           v1.4.99-ncs2            -> v1.4.99-ncs2
 * [new tag]           v1.4.99-ncs2-rc1        -> v1.4.99-ncs2-rc1
 * [new tag]           v1.4.99-ncs2-rc2        -> v1.4.99-ncs2-rc2
 * [new tag]           v1.4.99-ncs2-snapshot1  -> v1.4.99-ncs2-snapshot1
 * [new tag]           v1.5.99-ncs1-rc1        -> v1.5.99-ncs1-rc1
 * [new tag]           v1.5.99-ncs1-rc2        -> v1.5.99-ncs1-rc2
 * [new tag]           v1.5.99-ncs1-rc3        -> v1.5.99-ncs1-rc3
 * [new tag]           v1.5.99-ncs1-snapshot1  -> v1.5.99-ncs1-snapshot1
 * [new tag]           v1.6.0-rc2-ncs1         -> v1.6.0-rc2-ncs1
 * [new tag]           v1.6.99-ncs1            -> v1.6.99-ncs1
 * [new tag]           v1.6.99-ncs1-rc1        -> v1.6.99-ncs1-rc1
 * [new tag]           v1.6.99-ncs1-rc2        -> v1.6.99-ncs1-rc2
 * [new tag]           v1.6.99-ncs1-snapshot1  -> v1.6.99-ncs1-snapshot1
 * [new tag]           v1.7.0-ncs1-rc1         -> v1.7.0-ncs1-rc1
 * [new tag]           v1.7.0-ncs1-rc3         -> v1.7.0-ncs1-rc3
 * [new tag]           v1.7.0-ncs1-snapshot1   -> v1.7.0-ncs1-snapshot1
 * [new tag]           v1.7.2                  -> v1.7.2
 * [new tag]           v1.7.2-ncs1             -> v1.7.2-ncs1
 * [new tag]           v1.7.2-ncs1-rc2         -> v1.7.2-ncs1-rc2
 * [new tag]           v1.7.2-ncs2             -> v1.7.2-ncs2
 * [new tag]           v1.7.2-ncs2-rc1         -> v1.7.2-ncs2-rc1
 * [new tag]           v1.7.2-ncs2-rc2         -> v1.7.2-ncs2-rc2
 * [new tag]           v1.7.2-ncs3             -> v1.7.2-ncs3
 * [new tag]           v1.7.2-ncs3-rc1         -> v1.7.2-ncs3-rc1
 * [new tag]           v1.7.2-ncs3-rc2         -> v1.7.2-ncs3-rc2
 * [new tag]           v1.7.99-ncs1            -> v1.7.99-ncs1
 * [new tag]           v1.7.99-ncs1-1          -> v1.7.99-ncs1-1
 * [new tag]           v1.7.99-ncs1-rc1        -> v1.7.99-ncs1-rc1
 * [new tag]           v1.7.99-ncs2            -> v1.7.99-ncs2
 * [new tag]           v1.7.99-ncs2-snapshot1  -> v1.7.99-ncs2-snapshot1
 * [new tag]           v1.7.99-ncs3            -> v1.7.99-ncs3
 * [new tag]           v1.7.99-ncs3-1          -> v1.7.99-ncs3-1
 * [new tag]           v1.7.99-ncs3-rc1        -> v1.7.99-ncs3-rc1
 * [new tag]           v1.7.99-ncs3-rc2        -> v1.7.99-ncs3-rc2
 * [new tag]           v1.7.99-ncs4            -> v1.7.99-ncs4
 * [new tag]           v1.7.99-ncs4-rc1        -> v1.7.99-ncs4-rc1
 * [new tag]           v1.7.99-ncs4-rc2        -> v1.7.99-ncs4-rc2
 * [new tag]           v1.8.99-ncs1            -> v1.8.99-ncs1
 * [new tag]           v1.8.99-ncs1-rc1        -> v1.8.99-ncs1-rc1
 * [new tag]           v1.8.99-ncs1-rc2        -> v1.8.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1            -> v1.9.99-ncs1
 * [new tag]           v1.9.99-ncs1-rc1        -> v1.9.99-ncs1-rc1
 * [new tag]           v1.9.99-ncs1-rc2        -> v1.9.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1-snapshot1  -> v1.9.99-ncs1-snapshot1
 * [new tag]           v1.9.99-ncs2            -> v1.9.99-ncs2
 * [new tag]           v1.9.99-ncs2-rc1        -> v1.9.99-ncs2-rc1
 * [new tag]           v1.9.99-ncs2-rc2        -> v1.9.99-ncs2-rc2
 * [new tag]           v1.9.99-ncs2-snapshot1  -> v1.9.99-ncs2-snapshot1
 * [new tag]           v1.9.99-ncs3            -> v1.9.99-ncs3
 * [new tag]           v1.9.99-ncs3-rc1        -> v1.9.99-ncs3-rc1
 * [new tag]           v1.9.99-ncs3-rc2        -> v1.9.99-ncs3-rc2
 * [new tag]           v1.9.99-ncs4            -> v1.9.99-ncs4
 * [new tag]           v1.9.99-ncs4-rc1        -> v1.9.99-ncs4-rc1
 * [new tag]           v1.9.99-ncs4-rc2        -> v1.9.99-ncs4-rc2
 * [new tag]           v1.9.99-ncs4-snapshot1  -> v1.9.99-ncs4-snapshot1
 * [new tag]           v1.9.99-ncs4-snapshot2  -> v1.9.99-ncs4-snapshot2
 * [new tag]           v2.0.99-ncs1-1          -> v2.0.99-ncs1-1
 * [new tag]           v2.1.0-ncs1             -> v2.1.0-ncs1
 * [new tag]           v2.1.0-ncs1-rc1         -> v2.1.0-ncs1-rc1
 * [new tag]           v2.1.0-ncs1-rc2         -> v2.1.0-ncs1-rc2
 * [new tag]           v2.1.0-ncs1-rc3         -> v2.1.0-ncs1-rc3
From https://github.com/laurencelundblade/QCBOR
 * [new branch]      BeforeSpiffyDecode -> refs/west/BeforeSpiffyDecode
 * [new branch]      CDE                -> refs/west/CDE
 * [new branch]      NaN                -> refs/west/NaN
 * [new branch]      arrays             -> refs/west/arrays
 * [new branch]      better_big_num     -> refs/west/better_big_num
 * [new branch]      const              -> refs/west/const
 * [new branch]      dev                -> refs/west/dev
 * [new branch]      disable            -> refs/west/disable
 * [new branch]      enter-array        -> refs/west/enter-array
 * [new branch]      makewarn           -> refs/west/makewarn
 * [new branch]      mappie             -> refs/west/mappie
 * [new branch]      master             -> refs/west/master
 * [new branch]      newtag             -> refs/west/newtag
 * [new branch]      ub-example         -> refs/west/ub-example
 * [new branch]      versioning         -> refs/west/versioning
 * [new branch]      warn_in_tests      -> refs/west/warn_in_tests
 * [new tag]         v1.0               -> v1.0
 * [new tag]         v1.1               -> v1.1
 * [new tag]         v1.2               -> v1.2
 * [new tag]         v1.3               -> v1.3
 * [new tag]         v1.4               -> v1.4
 * [new tag]         v1.4.1             -> v1.4.1
From https://github.com/nrfconnect/sdk-mbedtls
 * tag                   v3.5.2-ncs2           -> FETCH_HEAD
 * [new tag]             mbedtls-2.26.0        -> mbedtls-2.26.0
 * [new tag]             v3.0.0-ncs1           -> v3.0.0-ncs1
 * [new tag]             v3.0.0-ncs1-rc2       -> v3.0.0-ncs1-rc2
 * [new tag]             v3.0.0-ncs2           -> v3.0.0-ncs2
 * [new tag]             v3.0.0-ncs2-rc1       -> v3.0.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs1           -> v3.1.0-ncs1
 * [new tag]             v3.1.0-ncs1-rc1       -> v3.1.0-ncs1-rc1
 * [new tag]             v3.1.0-ncs1-rc2       -> v3.1.0-ncs1-rc2
 * [new tag]             v3.1.0-ncs2           -> v3.1.0-ncs2
 * [new tag]             v3.1.0-ncs2-rc1       -> v3.1.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs2-rc2       -> v3.1.0-ncs2-rc2
 * [new tag]             v3.1.0-ncs3           -> v3.1.0-ncs3
 * [new tag]             v3.1.0-ncs3-rc1       -> v3.1.0-ncs3-rc1
 * [new tag]             v3.1.0-ncs3-rc2       -> v3.1.0-ncs3-rc2
 * [new tag]             v3.3.0-ncs1           -> v3.3.0-ncs1
 * [new tag]             v3.3.0-ncs1-1         -> v3.3.0-ncs1-1
 * [new tag]             v3.3.0-ncs1-rc1       -> v3.3.0-ncs1-rc1
 * [new tag]             v3.3.0-ncs1-rc2       -> v3.3.0-ncs1-rc2
 * [new tag]             v3.3.0-ncs1-snapshot1 -> v3.3.0-ncs1-snapshot1
 * [new tag]             v3.3.0-ncs2           -> v3.3.0-ncs2
 * [new tag]             v3.3.0-ncs2-1         -> v3.3.0-ncs2-1
 * [new tag]             v3.3.0-ncs2-1-rc1     -> v3.3.0-ncs2-1-rc1
 * [new tag]             v3.3.0-ncs2-2         -> v3.3.0-ncs2-2
 * [new tag]             v3.3.0-ncs2-3         -> v3.3.0-ncs2-3
 * [new tag]             v3.3.0-ncs2-rc1       -> v3.3.0-ncs2-rc1
 * [new tag]             v3.3.0-ncs2-rc2       -> v3.3.0-ncs2-rc2
 * [new tag]             v3.5.2-ncs1           -> v3.5.2-ncs1
 * [new tag]             v3.5.2-ncs1-1         -> v3.5.2-ncs1-1
 * [new tag]             v3.5.2-ncs1-rc1       -> v3.5.2-ncs1-rc1
 * [new tag]             v3.5.2-ncs1-rc2       -> v3.5.2-ncs1-rc2
 * [new tag]             v3.5.2-ncs1-snapshot1 -> v3.5.2-ncs1-snapshot1
 * [new tag]             v3.5.2-ncs2           -> v3.5.2-ncs2
 * [new tag]             v3.5.2-ncs2-rc1       -> v3.5.2-ncs2-rc1
 * [new tag]             v3.5.2-ncs2-rc2       -> v3.5.2-ncs2-rc2
 * [new tag]             v3.5.2-ncs2-rc3       -> v3.5.2-ncs2-rc3
 * [new tag]             v3.5.2-ncs2-snapshot1 -> v3.5.2-ncs2-snapshot1
From https://github.com/nrfconnect/sdk-oberon-psa-crypto
 * [new branch]      add_test_spec -> refs/west/add_test_spec
 * [new branch]      oberon_west   -> refs/west/oberon_west
 * [new branch]      test          -> refs/west/test
From https://github.com/nrfconnect/sdk-nrfxlib
 * tag                 v2.7.0       -> FETCH_HEAD
 * [new tag]           v0.1.0       -> v0.1.0
 * [new tag]           v0.1.0-rc1   -> v0.1.0-rc1
 * [new tag]           v0.3.0       -> v0.3.0
 * [new tag]           v0.3.0-rc1   -> v0.3.0-rc1
 * [new tag]           v0.3.0-rc2   -> v0.3.0-rc2
 * [new tag]           v0.4.0       -> v0.4.0
 * [new tag]           v0.4.0-rc1   -> v0.4.0-rc1
 * [new tag]           v0.4.0-rc2   -> v0.4.0-rc2
 * [new tag]           v1.0.0       -> v1.0.0
 * [new tag]           v1.0.0-rc1   -> v1.0.0-rc1
 * [new tag]           v1.0.0-rc2   -> v1.0.0-rc2
 * [new tag]           v1.0.0-rc3   -> v1.0.0-rc3
 * [new tag]           v1.0.0-rc4   -> v1.0.0-rc4
 * [new tag]           v1.1.0       -> v1.1.0
 * [new tag]           v1.1.0-rc1   -> v1.1.0-rc1
 * [new tag]           v1.1.0-rc2   -> v1.1.0-rc2
 * [new tag]           v1.1.0-rc3   -> v1.1.0-rc3
 * [new tag]           v1.2.0       -> v1.2.0
 * [new tag]           v1.2.0-rc1   -> v1.2.0-rc1
 * [new tag]           v1.2.0-rc2   -> v1.2.0-rc2
 * [new tag]           v1.2.1       -> v1.2.1
 * [new tag]           v1.3.0       -> v1.3.0
 * [new tag]           v1.3.0-rc1   -> v1.3.0-rc1
 * [new tag]           v1.3.0-rc2   -> v1.3.0-rc2
 * [new tag]           v1.3.0-rc3   -> v1.3.0-rc3
 * [new tag]           v1.3.1       -> v1.3.1
 * [new tag]           v1.4.0       -> v1.4.0
 * [new tag]           v1.4.0-rc1   -> v1.4.0-rc1
 * [new tag]           v1.4.2       -> v1.4.2
 * [new tag]           v1.5.0       -> v1.5.0
 * [new tag]           v1.5.0-rc1   -> v1.5.0-rc1
 * [new tag]           v1.5.1       -> v1.5.1
 * [new tag]           v1.5.1-rc1   -> v1.5.1-rc1
 * [new tag]           v1.5.2       -> v1.5.2
 * [new tag]           v1.6.0       -> v1.6.0
 * [new tag]           v1.6.0-rc3   -> v1.6.0-rc3
 * [new tag]           v1.6.1       -> v1.6.1
 * [new tag]           v1.7.0       -> v1.7.0
 * [new tag]           v1.7.0-rc1   -> v1.7.0-rc1
 * [new tag]           v1.7.0-rc2   -> v1.7.0-rc2
 * [new tag]           v1.7.1       -> v1.7.1
 * [new tag]           v1.8.0       -> v1.8.0
 * [new tag]           v1.8.0-rc1   -> v1.8.0-rc1
 * [new tag]           v1.8.0-rc2   -> v1.8.0-rc2
 * [new tag]           v1.9.0       -> v1.9.0
 * [new tag]           v1.9.0-rc1   -> v1.9.0-rc1
 * [new tag]           v1.9.0-rc2   -> v1.9.0-rc2
 * [new tag]           v1.9.1       -> v1.9.1
 * [new tag]           v1.9.2       -> v1.9.2
 * [new tag]           v1.9.2-dev1  -> v1.9.2-dev1
 * [new tag]           v2.0.0       -> v2.0.0
 * [new tag]           v2.0.0-rc1   -> v2.0.0-rc1
 * [new tag]           v2.0.0-rc2   -> v2.0.0-rc2
 * [new tag]           v2.0.0-rc2-1 -> v2.0.0-rc2-1
 * [new tag]           v2.0.1       -> v2.0.1
 * [new tag]           v2.0.2       -> v2.0.2
 * [new tag]           v2.1.0       -> v2.1.0
 * [new tag]           v2.1.0-rc1   -> v2.1.0-rc1
 * [new tag]           v2.1.0-rc2   -> v2.1.0-rc2
 * [new tag]           v2.1.1       -> v2.1.1
 * [new tag]           v2.1.2       -> v2.1.2
 * [new tag]           v2.1.3       -> v2.1.3
 * [new tag]           v2.1.4       -> v2.1.4
 * [new tag]           v2.2.0       -> v2.2.0
 * [new tag]           v2.2.0-rc1   -> v2.2.0-rc1
 * [new tag]           v2.2.0-rc2   -> v2.2.0-rc2
 * [new tag]           v2.3.0       -> v2.3.0
 * [new tag]           v2.3.0-rc1   -> v2.3.0-rc1
 * [new tag]           v2.3.0-rc2   -> v2.3.0-rc2
 * [new tag]           v2.4.0       -> v2.4.0
 * [new tag]           v2.4.0-rc1   -> v2.4.0-rc1
 * [new tag]           v2.4.0-rc2   -> v2.4.0-rc2
 * [new tag]           v2.4.1       -> v2.4.1
 * [new tag]           v2.4.2       -> v2.4.2
 * [new tag]           v2.4.3       -> v2.4.3
 * [new tag]           v2.4.4       -> v2.4.4
 * [new tag]           v2.5.0       -> v2.5.0
 * [new tag]           v2.5.0-rc1   -> v2.5.0-rc1
 * [new tag]           v2.5.0-rc2   -> v2.5.0-rc2
 * [new tag]           v2.5.1       -> v2.5.1
 * [new tag]           v2.5.1-rc1   -> v2.5.1-rc1
 * [new tag]           v2.5.2       -> v2.5.2
 * [new tag]           v2.5.3       -> v2.5.3
 * [new tag]           v2.6.0       -> v2.6.0
 * [new tag]           v2.6.0-rc1   -> v2.6.0-rc1
 * [new tag]           v2.6.0-rc2   -> v2.6.0-rc2
 * [new tag]           v2.6.1       -> v2.6.1
 * [new tag]           v2.7.0       -> v2.7.0
 * [new tag]           v2.7.0-rc1   -> v2.7.0-rc1
 * [new tag]           v2.7.0-rc2   -> v2.7.0-rc2
 * [new tag]           v2.7.0-rc3   -> v2.7.0-rc3
HEAD is now at 37e2ac22 nrf_modem: doc: add info about PDN down when NRF_SO_KEEPOPEN is used
From https://github.com/nrfconnect/sdk-trusted-firmware-m
 * tag                   v2.0.0-ncs2            -> FETCH_HEAD
 * [new tag]             v1.2.99-ncs1-1         -> v1.2.99-ncs1-1
 * [new tag]             v1.3.99-ncs1-rc3       -> v1.3.99-ncs1-rc3
 * [new tag]             v1.3.99-ncs1-snapshot1 -> v1.3.99-ncs1-snapshot1
 * [new tag]             v1.3.99-ncs1-snapshot2 -> v1.3.99-ncs1-snapshot2
 * [new tag]             v1.3.99-ncs2-1         -> v1.3.99-ncs2-1
 * [new tag]             v1.3.99-ncs3           -> v1.3.99-ncs3
 * [new tag]             v1.3.99-ncs3-rc1       -> v1.3.99-ncs3-rc1
 * [new tag]             v1.3.99-ncs3-rc2       -> v1.3.99-ncs3-rc2
 * [new tag]             v1.5.0-ncs1            -> v1.5.0-ncs1
 * [new tag]             v1.5.0-ncs1-1          -> v1.5.0-ncs1-1
 * [new tag]             v1.5.0-ncs1-rc1        -> v1.5.0-ncs1-rc1
 * [new tag]             v1.5.0-ncs1-rc2        -> v1.5.0-ncs1-rc2
 * [new tag]             v1.5.0-ncs2            -> v1.5.0-ncs2
 * [new tag]             v1.5.0-ncs2-rc1        -> v1.5.0-ncs2-rc1
 * [new tag]             v1.5.0-ncs2-rc2        -> v1.5.0-ncs2-rc2
 * [new tag]             v1.5.0-ncs2-snapshot1  -> v1.5.0-ncs2-snapshot1
 * [new tag]             v1.6.0-ncs1            -> v1.6.0-ncs1
 * [new tag]             v1.6.0-ncs1-rc1        -> v1.6.0-ncs1-rc1
 * [new tag]             v1.6.0-ncs1-rc2        -> v1.6.0-ncs1-rc2
 * [new tag]             v1.6.0-ncs1-snapshot1  -> v1.6.0-ncs1-snapshot1
 * [new tag]             v1.6.0-ncs2            -> v1.6.0-ncs2
 * [new tag]             v1.6.0-ncs2-rc1        -> v1.6.0-ncs2-rc1
 * [new tag]             v1.6.0-ncs2-rc2        -> v1.6.0-ncs2-rc2
 * [new tag]             v1.6.0-ncs3            -> v1.6.0-ncs3
 * [new tag]             v1.6.0-ncs3-rc1        -> v1.6.0-ncs3-rc1
 * [new tag]             v1.6.0-ncs3-rc2        -> v1.6.0-ncs3-rc2
 * [new tag]             v1.7.0-ncs1            -> v1.7.0-ncs1
 * [new tag]             v1.7.0-ncs1-1          -> v1.7.0-ncs1-1
 * [new tag]             v1.7.0-ncs1-rc2        -> v1.7.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1            -> v1.8.0-ncs1
 * [new tag]             v1.8.0-ncs1-1          -> v1.8.0-ncs1-1
 * [new tag]             v1.8.0-ncs1-1-rc1      -> v1.8.0-ncs1-1-rc1
 * [new tag]             v1.8.0-ncs1-2          -> v1.8.0-ncs1-2
 * [new tag]             v1.8.0-ncs1-3          -> v1.8.0-ncs1-3
 * [new tag]             v1.8.0-ncs1-rc1        -> v1.8.0-ncs1-rc1
 * [new tag]             v1.8.0-ncs1-rc2        -> v1.8.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1-snapshot1  -> v1.8.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs1            -> v2.0.0-ncs1
 * [new tag]             v2.0.0-ncs1-1          -> v2.0.0-ncs1-1
 * [new tag]             v2.0.0-ncs1-rc1        -> v2.0.0-ncs1-rc1
 * [new tag]             v2.0.0-ncs1-rc2        -> v2.0.0-ncs1-rc2
 * [new tag]             v2.0.0-ncs1-snapshot1  -> v2.0.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs2            -> v2.0.0-ncs2
 * [new tag]             v2.0.0-ncs2-rc1        -> v2.0.0-ncs2-rc1
 * [new tag]             v2.0.0-ncs2-rc2        -> v2.0.0-ncs2-rc2
 * [new tag]             v2.0.0-ncs2-rc3        -> v2.0.0-ncs2-rc3
 * [new tag]             v2.0.0-ncs2-snapshot1  -> v2.0.0-ncs2-snapshot1
HEAD is now at 553c47a6a [nrf noup] Fix version warning
From https://github.com/nrfconnect/sdk-psa-arch-tests
 * [new branch]      54l_its         -> refs/west/54l_its
 * [new branch]      fix_wdt_address -> refs/west/fix_wdt_address
HEAD is now at 94a349d [nrf fromlist] Fix base address for the nrf watchdog
From https://github.com/nrfconnect/sdk-connectedhomeip
 * [new tag]               v1.6.99-20210901    -> v1.6.99-20210901
 * [new tag]               v1.6.99-snapshot1   -> v1.6.99-snapshot1
 * [new tag]               v1.7.99-20211125    -> v1.7.99-20211125
 * [new tag]               v1.9.99-matter-dev1 -> v1.9.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev1 -> v2.0.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev2 -> v2.0.99-matter-dev2
 * [new tag]               v2.1.0-snapshot1    -> v2.1.0-snapshot1
 * [new tag]               v2.2.0-snapshot1    -> v2.2.0-snapshot1
 * [new tag]               v2.3.0-snapshot1    -> v2.3.0-snapshot1
 * [new tag]               v2.4.99-snapshot1   -> v2.4.99-snapshot1
 * [new tag]               v2.5.99-dev1        -> v2.5.99-dev1
HEAD is now at 022f2c92f6 [nrf toup] Fix missing network band in scan response.
      2 [main] sh (13652) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x13A1408/0x1151408.
This problem is probably due to using incompatible versions of the cygwin DLL.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version.  The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution.  Rebooting is also suggested if you
are unable to find another cygwin DLL.
      2 [main] sh 1382 dofork: child -1 - forked process 13652 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/ce3b5ff664/mingw64/libexec/git-core\git-submodule: fork: retry: Resource temporarily unavailable
1142856 [main] sh 1382 dofork: child -1 - forked process 14804 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (8240) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x13A1408/0x1091408.
3276331 [main] sh 1382 dofork: child -1 - forked process 8240 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (2008) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x13A1408/0x11E1408.
7409807 [main] sh 1382 dofork: child -1 - forked process 2008 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (9732) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x13A1408/0x10F1408.
15564735 [main] sh 1382 dofork: child -1 - forked process 9732 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/ce3b5ff664/mingw64/libexec/git-core\git-submodule: fork: Resource temporarily unavailable
From https://github.com/nrfconnect/sdk-soc-hwmv1
HEAD is now at 32b1ee3 soc: Update Kconfig.peripherals from sdk-zephyr bdda11b
From https://github.com/nrfconnect/sdk-cjson
 * [new tag]         v1.7.14    -> v1.7.14
HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
From https://github.com/nrfconnect/azure-sdk-for-c
HEAD is now at 308c171c [nrf fromlist] Make repository a Zephyr module
From https://github.com/nrfconnect/sdk-mcu-drivers
HEAD is now at 3873a08 Added missing curly brace for #ifdef __cplusplus
From https://github.com/nrfconnect/sdk-openthread
 * [new branch]          debug/tomaszkob89/key-rotation -> refs/west/debug/tomaszkob89/key-rotation
 * [new branch]          for-testing       -> refs/west/for-testing
 * [new branch]          v1.7-branch       -> refs/west/v1.7-branch
 * [new branch]          v1.9-branch       -> refs/west/v1.9-branch
 * [new branch]          v2.0-branch       -> refs/west/v2.0-branch
 * [new branch]          v2.4-branch       -> refs/west/v2.4-branch
 * [new branch]          zephyr            -> refs/west/zephyr
 * [new tag]             thread-reference-20200818-ncs1-rc1 -> thread-reference-20200818-ncs1-rc1
 * [new tag]             thread-reference-20200818-ncs1-rc3 -> thread-reference-20200818-ncs1-rc3
 * [new tag]             v1.8.99-snapshot1 -> v1.8.99-snapshot1
 * [new tag]             v1.9.99-snapshot1 -> v1.9.99-snapshot1
HEAD is now at a57d927b0 [string] add `ParseDigit()`, `ParseHexDigit()`, and other helper functions (#10282)
From https://github.com/nrfconnect/suit-generator
HEAD is now at 3458313 feat: add binary file name value to template generator
From https://github.com/nrfconnect/suit-processor
HEAD is now at 4505925 Fix coverity issues for 2.7 release
From https://github.com/ThrowTheSwitch/cmock
 * [new branch]      branch_2_5_1           -> refs/west/branch_2_5_1
 * [new branch]      cmock_2_6_rc           -> refs/west/cmock_2_6_rc
 * [new branch]      feature/only_config_is_shared -> refs/west/feature/only_config_is_shared
 * [new branch]      reapply_329            -> refs/west/reapply_329
 * [new branch]      revert-329-master      -> refs/west/revert-329-master
 * [new branch]      test/switch_to_actions -> refs/west/test/switch_to_actions
 * [new tag]         v2.4.5                 -> v2.4.5
 * [new tag]         v2.4.6                 -> v2.4.6
HEAD is now at f65066f Merge pull request #404 from tz18/patch-1
      2 [main] sh (9048) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1001408/0x1201408.
      2 [main] sh 1392 dofork: child -1 - forked process 9048 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (9564) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1001408/0x11C1408.
1129745 [main] sh 1392 dofork: child -1 - forked process 9564 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (10160) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1001408/0x10F1408.
3256649 [main] sh 1392 dofork: child -1 - forked process 10160 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (2976) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1001408/0x1091408.
7383241 [main] sh 1392 dofork: child -1 - forked process 2976 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
15523633 [main] sh 1392 dofork: child -1 - forked process 6136 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
From https://github.com/memfault/memfault-firmware-sdk
 * tag               1.6.0      -> FETCH_HEAD
 * [new tag]         0.0.10     -> 0.0.10
 * [new tag]         0.0.11     -> 0.0.11
 * [new tag]         0.0.12     -> 0.0.12
 * [new tag]         0.0.13     -> 0.0.13
 * [new tag]         0.0.14     -> 0.0.14
 * [new tag]         0.0.15     -> 0.0.15
 * [new tag]         0.0.16     -> 0.0.16
 * [new tag]         0.0.17     -> 0.0.17
 * [new tag]         0.0.18     -> 0.0.18
 * [new tag]         0.0.2      -> 0.0.2
 * [new tag]         0.0.3      -> 0.0.3
 * [new tag]         0.0.4      -> 0.0.4
 * [new tag]         0.0.5      -> 0.0.5
 * [new tag]         0.0.6      -> 0.0.6
 * [new tag]         0.0.7      -> 0.0.7
 * [new tag]         0.0.8      -> 0.0.8
 * [new tag]         0.0.9      -> 0.0.9
 * [new tag]         0.1.0      -> 0.1.0
 * [new tag]         0.10.0     -> 0.10.0
 * [new tag]         0.10.1     -> 0.10.1
 * [new tag]         0.11.0     -> 0.11.0
 * [new tag]         0.11.1     -> 0.11.1
 * [new tag]         0.11.2     -> 0.11.2
 * [new tag]         0.11.3     -> 0.11.3
 * [new tag]         0.11.4     -> 0.11.4
 * [new tag]         0.12.0     -> 0.12.0
 * [new tag]         0.13.0     -> 0.13.0
 * [new tag]         0.13.1     -> 0.13.1
 * [new tag]         0.14.0     -> 0.14.0
 * [new tag]         0.15.0     -> 0.15.0
 * [new tag]         0.16.0     -> 0.16.0
 * [new tag]         0.16.1     -> 0.16.1
 * [new tag]         0.17.0     -> 0.17.0
 * [new tag]         0.17.1     -> 0.17.1
 * [new tag]         0.18.0     -> 0.18.0
 * [new tag]         0.19.0     -> 0.19.0
 * [new tag]         0.2.0      -> 0.2.0
 * [new tag]         0.2.1      -> 0.2.1
 * [new tag]         0.2.2      -> 0.2.2
 * [new tag]         0.2.3      -> 0.2.3
 * [new tag]         0.2.4      -> 0.2.4
 * [new tag]         0.2.5      -> 0.2.5
 * [new tag]         0.20.0     -> 0.20.0
 * [new tag]         0.20.1     -> 0.20.1
 * [new tag]         0.20.2     -> 0.20.2
 * [new tag]         0.21.0     -> 0.21.0
 * [new tag]         0.21.1     -> 0.21.1
 * [new tag]         0.22.0     -> 0.22.0
 * [new tag]         0.23.0     -> 0.23.0
 * [new tag]         0.24.0     -> 0.24.0
 * [new tag]         0.24.1     -> 0.24.1
 * [new tag]         0.24.2     -> 0.24.2
 * [new tag]         0.25.0     -> 0.25.0
 * [new tag]         0.26.0     -> 0.26.0
 * [new tag]         0.26.1     -> 0.26.1
 * [new tag]         0.27.0     -> 0.27.0
 * [new tag]         0.27.1     -> 0.27.1
 * [new tag]         0.27.2     -> 0.27.2
 * [new tag]         0.27.3     -> 0.27.3
 * [new tag]         0.28.0     -> 0.28.0
 * [new tag]         0.28.1     -> 0.28.1
 * [new tag]         0.28.2     -> 0.28.2
 * [new tag]         0.29.0     -> 0.29.0
 * [new tag]         0.29.1     -> 0.29.1
 * [new tag]         0.3.0      -> 0.3.0
 * [new tag]         0.3.1      -> 0.3.1
 * [new tag]         0.3.2      -> 0.3.2
 * [new tag]         0.3.3      -> 0.3.3
 * [new tag]         0.3.4      -> 0.3.4
 * [new tag]         0.30.0     -> 0.30.0
 * [new tag]         0.30.1     -> 0.30.1
 * [new tag]         0.30.2     -> 0.30.2
 * [new tag]         0.30.3     -> 0.30.3
 * [new tag]         0.30.4     -> 0.30.4
 * [new tag]         0.30.5     -> 0.30.5
 * [new tag]         0.31.0     -> 0.31.0
 * [new tag]         0.31.1     -> 0.31.1
 * [new tag]         0.31.2     -> 0.31.2
 * [new tag]         0.31.3     -> 0.31.3
 * [new tag]         0.31.4     -> 0.31.4
 * [new tag]         0.31.5     -> 0.31.5
 * [new tag]         0.32.0     -> 0.32.0
 * [new tag]         0.32.1     -> 0.32.1
 * [new tag]         0.32.2     -> 0.32.2
 * [new tag]         0.33.0     -> 0.33.0
 * [new tag]         0.33.1     -> 0.33.1
 * [new tag]         0.33.2     -> 0.33.2
 * [new tag]         0.33.3     -> 0.33.3
 * [new tag]         0.33.4     -> 0.33.4
 * [new tag]         0.33.5     -> 0.33.5
 * [new tag]         0.34.0     -> 0.34.0
 * [new tag]         0.34.1     -> 0.34.1
 * [new tag]         0.34.2     -> 0.34.2
 * [new tag]         0.35.0     -> 0.35.0
 * [new tag]         0.36.0     -> 0.36.0
 * [new tag]         0.36.1     -> 0.36.1
 * [new tag]         0.37.0     -> 0.37.0
 * [new tag]         0.37.1     -> 0.37.1
 * [new tag]         0.37.2     -> 0.37.2
 * [new tag]         0.38.0     -> 0.38.0
 * [new tag]         0.39.0     -> 0.39.0
 * [new tag]         0.39.1     -> 0.39.1
 * [new tag]         0.4.0      -> 0.4.0
 * [new tag]         0.4.1      -> 0.4.1
 * [new tag]         0.4.2      -> 0.4.2
 * [new tag]         0.40.0     -> 0.40.0
 * [new tag]         0.41.0     -> 0.41.0
 * [new tag]         0.41.1     -> 0.41.1
 * [new tag]         0.41.2     -> 0.41.2
 * [new tag]         0.42.0     -> 0.42.0
 * [new tag]         0.42.1     -> 0.42.1
 * [new tag]         0.43.0     -> 0.43.0
 * [new tag]         0.43.1     -> 0.43.1
 * [new tag]         0.43.2     -> 0.43.2
 * [new tag]         0.43.3     -> 0.43.3
 * [new tag]         0.5.0      -> 0.5.0
 * [new tag]         0.5.1      -> 0.5.1
 * [new tag]         0.6.0      -> 0.6.0
 * [new tag]         0.6.1      -> 0.6.1
 * [new tag]         0.7.0      -> 0.7.0
 * [new tag]         0.7.1      -> 0.7.1
 * [new tag]         0.7.2      -> 0.7.2
 * [new tag]         0.7.3      -> 0.7.3
 * [new tag]         0.8.0      -> 0.8.0
 * [new tag]         0.8.1      -> 0.8.1
 * [new tag]         0.8.2      -> 0.8.2
 * [new tag]         0.9.0      -> 0.9.0
 * [new tag]         0.9.1      -> 0.9.1
 * [new tag]         0.9.2      -> 0.9.2
 * [new tag]         0.9.3      -> 0.9.3
 * [new tag]         1.0.0      -> 1.0.0
 * [new tag]         1.0.1      -> 1.0.1
 * [new tag]         1.1.0      -> 1.1.0
 * [new tag]         1.1.1      -> 1.1.1
 * [new tag]         1.1.2      -> 1.1.2
 * [new tag]         1.1.3      -> 1.1.3
 * [new tag]         1.10.0     -> 1.10.0
 * [new tag]         1.10.1     -> 1.10.1
 * [new tag]         1.11.0     -> 1.11.0
 * [new tag]         1.11.1     -> 1.11.1
 * [new tag]         1.11.2     -> 1.11.2
 * [new tag]         1.11.3     -> 1.11.3
 * [new tag]         1.2.0      -> 1.2.0
 * [new tag]         1.2.1      -> 1.2.1
 * [new tag]         1.2.2      -> 1.2.2
 * [new tag]         1.2.3      -> 1.2.3
 * [new tag]         1.2.4      -> 1.2.4
 * [new tag]         1.2.5      -> 1.2.5
 * [new tag]         1.3.0      -> 1.3.0
 * [new tag]         1.3.1      -> 1.3.1
 * [new tag]         1.3.2      -> 1.3.2
 * [new tag]         1.3.3      -> 1.3.3
 * [new tag]         1.3.4      -> 1.3.4
 * [new tag]         1.3.5      -> 1.3.5
 * [new tag]         1.4.0      -> 1.4.0
 * [new tag]         1.4.1      -> 1.4.1
 * [new tag]         1.4.2      -> 1.4.2
 * [new tag]         1.4.3      -> 1.4.3
 * [new tag]         1.4.4      -> 1.4.4
 * [new tag]         1.5.0      -> 1.5.0
 * [new tag]         1.5.1      -> 1.5.1
 * [new tag]         1.5.2      -> 1.5.2
 * [new tag]         1.6.0      -> 1.6.0
 * [new tag]         1.6.1      -> 1.6.1
 * [new tag]         1.6.2      -> 1.6.2
 * [new tag]         1.7.0      -> 1.7.0
 * [new tag]         1.7.1      -> 1.7.1
 * [new tag]         1.7.2      -> 1.7.2
 * [new tag]         1.7.3      -> 1.7.3
 * [new tag]         1.7.4      -> 1.7.4
 * [new tag]         1.7.5      -> 1.7.5
 * [new tag]         1.7.6      -> 1.7.6
 * [new tag]         1.7.7      -> 1.7.7
 * [new tag]         1.8.0      -> 1.8.0
 * [new tag]         1.8.1      -> 1.8.1
 * [new tag]         1.9.0      -> 1.9.0
 * [new tag]         1.9.1      -> 1.9.1
 * [new tag]         1.9.2      -> 1.9.2
 * [new tag]         1.9.3      -> 1.9.3
 * [new tag]         1.9.4      -> 1.9.4
HEAD is now at 3d51c80 Memfault Firmware SDK 1.6.0 (Build 5464)
From https://github.com/eembc/coremark
 * [new branch]      128b-pointer -> refs/west/128b-pointer
 * [new branch]      posix-make   -> refs/west/posix-make
 * [new tag]         v1.01        -> v1.01
HEAD is now at d5fad6b Merge pull request #51 from volodymyr-bondarchuk/zephyr
From https://github.com/zephyrproject-rtos/canopennode
 * [new tag]         zephyr-snapshot-1 -> zephyr-snapshot-1
HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t()
From https://github.com/zephyrproject-rtos/chre
HEAD is now at 3b32c76e zephyr: link the .unstable_id data in ROM
From https://github.com/zephyrproject-rtos/lz4
 * [new tag]         lz4-r130   -> lz4-r130
 * [new tag]         r116       -> r116
 * [new tag]         r117       -> r117
 * [new tag]         r118       -> r118
 * [new tag]         r119       -> r119
 * [new tag]         r120       -> r120
 * [new tag]         r121       -> r121
 * [new tag]         r122       -> r122
 * [new tag]         r123       -> r123
 * [new tag]         r124       -> r124
 * [new tag]         r125       -> r125
 * [new tag]         r126       -> r126
 * [new tag]         r127       -> r127
 * [new tag]         r128       -> r128
 * [new tag]         r129       -> r129
 * [new tag]         r130       -> r130
 * [new tag]         r131       -> r131
 * [new tag]         rc129v0    -> rc129v0
 * [new tag]         v1.7.3     -> v1.7.3
 * [new tag]         v1.7.4     -> v1.7.4
 * [new tag]         v1.7.4.2   -> v1.7.4.2
 * [new tag]         v1.7.5     -> v1.7.5
 * [new tag]         v1.8.1     -> v1.8.1
 * [new tag]         v1.8.1.2   -> v1.8.1.2
 * [new tag]         v1.8.2     -> v1.8.2
 * [new tag]         v1.8.3     -> v1.8.3
 * [new tag]         v1.9.3     -> v1.9.3
HEAD is now at 8e303c2 zephyr: make this repo a zephyr module
From https://github.com/zephyrproject-rtos/nanopb
 * [new branch]      cifuzz_test4           -> refs/west/cifuzz_test4
 * [new branch]      dev_dynamic_nanopb_pb2 -> refs/west/dev_dynamic_nanopb_pb2
 * [new branch]      dev_markdown_docs      -> refs/west/dev_markdown_docs
 * [new branch]      maintenance_0.1        -> refs/west/maintenance_0.1
 * [new branch]      maintenance_0.2        -> refs/west/maintenance_0.2
 * [new branch]      maintenance_0.3        -> refs/west/maintenance_0.3
 * [new tag]         0.2.9.5                -> 0.2.9.5
 * [new tag]         0.3.6                  -> 0.3.6
 * [new tag]         0.3.7                  -> 0.3.7
 * [new tag]         0.3.8                  -> 0.3.8
 * [new tag]         0.3.9                  -> 0.3.9
 * [new tag]         0.3.9.1                -> 0.3.9.1
 * [new tag]         0.3.9.2                -> 0.3.9.2
 * [new tag]         0.3.9.3                -> 0.3.9.3
 * [new tag]         0.3.9.4                -> 0.3.9.4
 * [new tag]         0.3.9.5                -> 0.3.9.5
 * [new tag]         0.3.9.6                -> 0.3.9.6
 * [new tag]         0.3.9.7                -> 0.3.9.7
 * [new tag]         0.3.9.8                -> 0.3.9.8
 * [new tag]         0.4.3                  -> 0.4.3
 * [new tag]         0.4.4                  -> 0.4.4
 * [new tag]         0.4.5                  -> 0.4.5
 * [new tag]         nanopb-0.1.0           -> nanopb-0.1.0
 * [new tag]         nanopb-0.1.1           -> nanopb-0.1.1
 * [new tag]         nanopb-0.1.2           -> nanopb-0.1.2
 * [new tag]         nanopb-0.1.3           -> nanopb-0.1.3
 * [new tag]         nanopb-0.1.4           -> nanopb-0.1.4
 * [new tag]         nanopb-0.1.5           -> nanopb-0.1.5
 * [new tag]         nanopb-0.1.6           -> nanopb-0.1.6
 * [new tag]         nanopb-0.1.7           -> nanopb-0.1.7
 * [new tag]         nanopb-0.1.8           -> nanopb-0.1.8
 * [new tag]         nanopb-0.1.9           -> nanopb-0.1.9
 * [new tag]         nanopb-0.1.9.1         -> nanopb-0.1.9.1
 * [new tag]         nanopb-0.2.0           -> nanopb-0.2.0
 * [new tag]         nanopb-0.2.1           -> nanopb-0.2.1
 * [new tag]         nanopb-0.2.2           -> nanopb-0.2.2
 * [new tag]         nanopb-0.2.3           -> nanopb-0.2.3
 * [new tag]         nanopb-0.2.4           -> nanopb-0.2.4
 * [new tag]         nanopb-0.2.5           -> nanopb-0.2.5
 * [new tag]         nanopb-0.2.6           -> nanopb-0.2.6
 * [new tag]         nanopb-0.2.7           -> nanopb-0.2.7
 * [new tag]         nanopb-0.2.8           -> nanopb-0.2.8
 * [new tag]         nanopb-0.2.9           -> nanopb-0.2.9
 * [new tag]         nanopb-0.2.9.1         -> nanopb-0.2.9.1
 * [new tag]         nanopb-0.2.9.2         -> nanopb-0.2.9.2
 * [new tag]         nanopb-0.2.9.3         -> nanopb-0.2.9.3
 * [new tag]         nanopb-0.2.9.4         -> nanopb-0.2.9.4
 * [new tag]         nanopb-0.2.9.5         -> nanopb-0.2.9.5
 * [new tag]         nanopb-0.3.0           -> nanopb-0.3.0
 * [new tag]         nanopb-0.3.1           -> nanopb-0.3.1
 * [new tag]         nanopb-0.3.2           -> nanopb-0.3.2
 * [new tag]         nanopb-0.3.3           -> nanopb-0.3.3
 * [new tag]         nanopb-0.3.4           -> nanopb-0.3.4
 * [new tag]         nanopb-0.3.5           -> nanopb-0.3.5
 * [new tag]         nanopb-0.3.6           -> nanopb-0.3.6
 * [new tag]         nanopb-0.3.7           -> nanopb-0.3.7
 * [new tag]         nanopb-0.3.8           -> nanopb-0.3.8
 * [new tag]         nanopb-0.3.9           -> nanopb-0.3.9
 * [new tag]         nanopb-0.3.9.1         -> nanopb-0.3.9.1
 * [new tag]         nanopb-0.3.9.2         -> nanopb-0.3.9.2
 * [new tag]         nanopb-0.3.9.3         -> nanopb-0.3.9.3
 * [new tag]         nanopb-0.3.9.4         -> nanopb-0.3.9.4
 * [new tag]         nanopb-0.3.9.5         -> nanopb-0.3.9.5
 * [new tag]         nanopb-0.3.9.6         -> nanopb-0.3.9.6
 * [new tag]         nanopb-0.3.9.7         -> nanopb-0.3.9.7
 * [new tag]         nanopb-0.3.9.8         -> nanopb-0.3.9.8
 * [new tag]         nanopb-0.4.0           -> nanopb-0.4.0
 * [new tag]         nanopb-0.4.0-dev       -> nanopb-0.4.0-dev
 * [new tag]         nanopb-0.4.1           -> nanopb-0.4.1
 * [new tag]         nanopb-0.4.2           -> nanopb-0.4.2
 * [new tag]         nanopb-0.4.3           -> nanopb-0.4.3
 * [new tag]         nanopb-0.4.4           -> nanopb-0.4.4
 * [new tag]         nanopb-0.4.5           -> nanopb-0.4.5
HEAD is now at 7f88274 Add migration note about CMake protoc default (#958)
From https://github.com/zephyrproject-rtos/tf-m-tests
 * [new branch]      release/1.7.x -> refs/west/release/1.7.x
HEAD is now at 85f533a Crypto: Use RSA key in PSA format
From https://github.com/zephyrproject-rtos/zscilib
 * [new branch]      gh-pages   -> refs/west/gh-pages
 * [new branch]      revert-38-fix_zephyr_3_1 -> refs/west/revert-38-fix_zephyr_3_1
 * [new tag]         v0.2.0-rc1 -> v0.2.0-rc1
HEAD is now at ee1b287 samples/tests: Update for hwmv2 board names
From https://github.com/zephyrproject-rtos/cmsis
HEAD is now at 4b96cbb doc: Update documentations for CMSIS 5.9.0
From https://github.com/zephyrproject-rtos/cmsis-dsp
HEAD is now at 6489e771 do not generate warnings when scalar functions are used with MVE
From https://github.com/zephyrproject-rtos/cmsis-nn
 * [new branch]      zephyr-v6.0.0 -> refs/west/zephyr-v6.0.0
HEAD is now at 0c8669d Merge pull request #1 from XenuIsWatching/zephyr
From https://github.com/zephyrproject-rtos/edtt
 * [new branch]      le-audio      -> refs/west/le-audio
 * [new branch]      public_master -> refs/west/public_master
HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop
From https://github.com/zephyrproject-rtos/fatfs
 * [new branch]      v1.14-branch -> refs/west/v1.14-branch
HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE
From https://github.com/zephyrproject-rtos/hal_nordic
 * [new branch]      dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3 -> refs/west/dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3
 * [new tag]         nrfx-2.10.0  -> nrfx-2.10.0
 * [new tag]         nrfx-2.11.0  -> nrfx-2.11.0
 * [new tag]         nrfx-3.0.0   -> nrfx-3.0.0
HEAD is now at ab5cb2e nrfx: drivers: nrfx_gpiote: move enabling GPIOTE port interrupt
From https://github.com/zephyrproject-rtos/hal_st
HEAD is now at b77157f drivers: sensor: st: Move to vendor subdirectory
From https://github.com/zephyrproject-rtos/hal_wurthelektronik
HEAD is now at e5bcb2e Update WE sensors SDK to version 2.5.0
From https://github.com/zephyrproject-rtos/libmetal
HEAD is now at 243eed5 lib: update libmetal to SHA f55c02a7b582
From https://github.com/zephyrproject-rtos/liblc3
HEAD is now at 1a5938e meson: Bump to version 1.0.4
From https://github.com/zephyrproject-rtos/littlefs
 * [new tag]         littlefs-v2.1.0 -> littlefs-v2.1.0
 * [new tag]         littlefs-v2.1.1 -> littlefs-v2.1.1
 * [new tag]         littlefs-v2.1.2 -> littlefs-v2.1.2
 * [new tag]         littlefs-v2.1.3 -> littlefs-v2.1.3
 * [new tag]         littlefs-v2.1.4 -> littlefs-v2.1.4
 * [new tag]         littlefs-v2.2.0 -> littlefs-v2.2.0
HEAD is now at 408c16a Merge pull request #14 from de-nordic/update-to-v2.8.1
From https://github.com/zephyrproject-rtos/loramac-node
 * [new branch]        v4.5.2-zephyr -> refs/west/v4.5.2-zephyr
 * [new branch]        v4.6.0-zephyr -> refs/west/v4.6.0-zephyr
 * [new branch]        v4.7.0-zephyr -> refs/west/v4.7.0-zephyr
 * [new branch]        zephyr-v2.6   -> refs/west/zephyr-v2.6
 * [new tag]           4.4.2-rc.4    -> 4.4.2-rc.4
 * [new tag]           V3.4          -> V3.4
 * [new tag]           v2.0          -> v2.0
 * [new tag]           v2.1          -> v2.1
 * [new tag]           v2.2          -> v2.2
 * [new tag]           v2.3.RC1      -> v2.3.RC1
 * [new tag]           v2.3.RC2      -> v2.3.RC2
 * [new tag]           v3.0          -> v3.0
 * [new tag]           v3.1          -> v3.1
 * [new tag]           v3.2          -> v3.2
 * [new tag]           v3.3          -> v3.3
 * [new tag]           v3.4.1        -> v3.4.1
 * [new tag]           v4.0.0        -> v4.0.0
 * [new tag]           v4.1.0        -> v4.1.0
 * [new tag]           v4.2.0        -> v4.2.0
 * [new tag]           v4.3.0        -> v4.3.0
 * [new tag]           v4.3.1        -> v4.3.1
 * [new tag]           v4.3.2        -> v4.3.2
 * [new tag]           v4.4.0        -> v4.4.0
 * [new tag]           v4.4.1        -> v4.4.1
 * [new tag]           v4.4.2        -> v4.4.2
 * [new tag]           v4.4.2-rc.1   -> v4.4.2-rc.1
 * [new tag]           v4.4.2-rc.2   -> v4.4.2-rc.2
 * [new tag]           v4.4.2-rc.3   -> v4.4.2-rc.3
 * [new tag]           v4.4.2-rc.5   -> v4.4.2-rc.5
 * [new tag]           v4.4.2-rc.6   -> v4.4.2-rc.6
 * [new tag]           v4.4.2-rc.7   -> v4.4.2-rc.7
 * [new tag]           v4.4.3        -> v4.4.3
 * [new tag]           v4.4.3_zephyr -> v4.4.3_zephyr
HEAD is now at fb00b383 zephyr: configure FragDecoder using Kconfig
From https://github.com/zephyrproject-rtos/lvgl
HEAD is now at 2b498e6f Merge pull request #51 from faxe1008/upddate_lvgl_840
From https://github.com/zephyrproject-rtos/mipi-sys-t
HEAD is now at 71ace1f mipi_syst: fix build error when having protocol timestamp disabled
From https://github.com/zephyrproject-rtos/net-tools
HEAD is now at 7c7a856 websocket-console: Add a helper script for websocket console
From https://github.com/zephyrproject-rtos/nrf_hw_models
HEAD is now at 36b1271 54L15: Added RRAMC, RRAM & UICR
From https://github.com/zephyrproject-rtos/open-amp
 * [new branch]      bump_v2024.05.0 -> refs/west/bump_v2024.05.0
 * [new tag]         old_master      -> old_master
HEAD is now at da78aea lib: update open-amp lib to release v2023.10.0
From https://github.com/zephyrproject-rtos/picolibc
 * [new branch]          Z-emcb-cygwin_daemon        -> refs/west/Z-emcb-cygwin_daemon
 * [new branch]          aarch64                     -> refs/west/aarch64
 * [new branch]          add-fakeroots-dir           -> refs/west/add-fakeroots-dir
 * [new branch]          amd64_to_x86_64             -> refs/west/amd64_to_x86_64
 * [new branch]          ancient-clang               -> refs/west/ancient-clang
 * [new branch]          arc-20081103-branch         -> refs/west/arc-20081103-branch
 * [new branch]          arc-insight_6_8-branch      -> refs/west/arc-insight_6_8-branch
 * [new branch]          arm-read-tp-cleanup         -> refs/west/arm-read-tp-cleanup
 * [new branch]          binutils-2_10-branch        -> refs/west/binutils-2_10-branch
 * [new branch]          binutils-2_11-branch        -> refs/west/binutils-2_11-branch
 * [new branch]          binutils-2_12-branch        -> refs/west/binutils-2_12-branch
 * [new branch]          binutils-2_13-branch        -> refs/west/binutils-2_13-branch
 * [new branch]          binutils-2_14-branch        -> refs/west/binutils-2_14-branch
 * [new branch]          binutils-2_15-branch        -> refs/west/binutils-2_15-branch
 * [new branch]          binutils-2_16-branch        -> refs/west/binutils-2_16-branch
 * [new branch]          binutils-2_17-branch        -> refs/west/binutils-2_17-branch
 * [new branch]          binutils-2_18-branch        -> refs/west/binutils-2_18-branch
 * [new branch]          binutils-2_19-branch        -> refs/west/binutils-2_19-branch
 * [new branch]          binutils-2_20-branch        -> refs/west/binutils-2_20-branch
 * [new branch]          binutils-2_21-branch        -> refs/west/binutils-2_21-branch
 * [new branch]          binutils-2_22-branch        -> refs/west/binutils-2_22-branch
 * [new branch]          binutils-2_22_branch        -> refs/west/binutils-2_22_branch
 * [new branch]          binutils-2_23-branch        -> refs/west/binutils-2_23-branch
 * [new branch]          binutils-2_24-branch        -> refs/west/binutils-2_24-branch
 * [new branch]          binutils-arc-20080908-branch -> refs/west/binutils-arc-20080908-branch
 * [new branch]          binutils-arc-20081103-branch -> refs/west/binutils-arc-20081103-branch
 * [new branch]          binutils-csl-2_17-branch    -> refs/west/binutils-csl-2_17-branch
 * [new branch]          binutils-csl-arm-2005q1-branch -> refs/west/binutils-csl-arm-2005q1-branch
 * [new branch]          binutils-csl-gxxpro-3_4-branch -> refs/west/binutils-csl-gxxpro-3_4-branch
 * [new branch]          branch-1.4.6                -> refs/west/branch-1.4.6
 * [new branch]          branch-1.8.4                -> refs/west/branch-1.8.4
 * [new branch]          c-sky                       -> refs/west/c-sky
 * [new branch]          cagney-unwind-20030108-branch -> refs/west/cagney-unwind-20030108-branch
 * [new branch]          cagney_bfdfile-20040213-branch -> refs/west/cagney_bfdfile-20040213-branch
 * [new branch]          cagney_bigcore-20040122-branch -> refs/west/cagney_bigcore-20040122-branch
 * [new branch]          cagney_convert-20030606-branch -> refs/west/cagney_convert-20030606-branch
 * [new branch]          cagney_fileio-20030521-branch -> refs/west/cagney_fileio-20030521-branch
 * [new branch]          cagney_frameaddr-20030403-branch -> refs/west/cagney_frameaddr-20030403-branch
 * [new branch]          cagney_framebase-20030326-branch -> refs/west/cagney_framebase-20030326-branch
 * [new branch]          cagney_lazyid-20030317-branch -> refs/west/cagney_lazyid-20030317-branch
 * [new branch]          cagney_offbyone-20030303-branch -> refs/west/cagney_offbyone-20030303-branch
 * [new branch]          cagney_regbuf-20020515-branch -> refs/west/cagney_regbuf-20020515-branch
 * [new branch]          cagney_sysregs-20020825-branch -> refs/west/cagney_sysregs-20020825-branch
 * [new branch]          cagney_tramp-20040309-branch -> refs/west/cagney_tramp-20040309-branch
 * [new branch]          cagney_writestrings-20030508-branch -> refs/west/cagney_writestrings-20030508-branch
 * [new branch]          cagney_x86i386-20030821-branch -> refs/west/cagney_x86i386-20030821-branch
 * [new branch]          callout                     -> refs/west/callout
 * [new branch]          carlton_dictionary-branch   -> refs/west/carlton_dictionary-branch
 * [new branch]          cgen-1_1-branch             -> refs/west/cgen-1_1-branch
 * [new branch]          cgf-deleteme                -> refs/west/cgf-deleteme
 * [new branch]          cgf-dev-branch              -> refs/west/cgf-dev-branch
 * [new branch]          cmake                       -> refs/west/cmake
 * [new branch]          cmake-no-tls                -> refs/west/cmake-no-tls
 * [new branch]          cmake-small-ultoa           -> refs/west/cmake-small-ultoa
 * [new branch]          cr-0x3b58                   -> refs/west/cr-0x3b58
 * [new branch]          cr-0x5e6                    -> refs/west/cr-0x5e6
 * [new branch]          cr-0x5ef                    -> refs/west/cr-0x5ef
 * [new branch]          cr-0x5f1                    -> refs/west/cr-0x5f1
 * [new branch]          cr-0x9b                     -> refs/west/cr-0x9b
 * [new branch]          cr-0x9c                     -> refs/west/cr-0x9c
 * [new branch]          cr-0x9d                     -> refs/west/cr-0x9d
 * [new branch]          cr-0x9e                     -> refs/west/cr-0x9e
 * [new branch]          csl-arm-20050325-branch     -> refs/west/csl-arm-20050325-branch
 * [new branch]          cv-branch                   -> refs/west/cv-branch
 * [new branch]          cv-branch-2                 -> refs/west/cv-branch-2
 * [new branch]          cv-post-1_7_9               -> refs/west/cv-post-1_7_9
 * [new branch]          cygnus                      -> refs/west/cygnus
 * [new branch]          cygwin-1-1-4                -> refs/west/cygwin-1-1-4
 * [new branch]          cygwin-1-3-1                -> refs/west/cygwin-1-3-1
 * [new branch]          cygwin-1-3-10-1             -> refs/west/cygwin-1-3-10-1
 * [new branch]          cygwin-1-3-11-3             -> refs/west/cygwin-1-3-11-3
 * [new branch]          cygwin-1-3-12-1             -> refs/west/cygwin-1-3-12-1
 * [new branch]          cygwin-1-3-13-1             -> refs/west/cygwin-1-3-13-1
 * [new branch]          cygwin-1-3-13-2             -> refs/west/cygwin-1-3-13-2
 * [new branch]          cygwin-1-3-14-1             -> refs/west/cygwin-1-3-14-1
 * [new branch]          cygwin-1-3-15-1             -> refs/west/cygwin-1-3-15-1
 * [new branch]          cygwin-1-3-16-1             -> refs/west/cygwin-1-3-16-1
 * [new branch]          cygwin-1-3-17-1             -> refs/west/cygwin-1-3-17-1
 * [new branch]          cygwin-1-3-18-1             -> refs/west/cygwin-1-3-18-1
 * [new branch]          cygwin-1-3-19-1             -> refs/west/cygwin-1-3-19-1
 * [new branch]          cygwin-1-3-2                -> refs/west/cygwin-1-3-2
 * [new branch]          cygwin-1-3-3                -> refs/west/cygwin-1-3-3
 * [new branch]          cygwin-1-3-4                -> refs/west/cygwin-1-3-4
 * [new branch]          cygwin-1-3-5                -> refs/west/cygwin-1-3-5
 * [new branch]          cygwin-1-3-5-2              -> refs/west/cygwin-1-3-5-2
 * [new branch]          cygwin-1-3-5-3              -> refs/west/cygwin-1-3-5-3
 * [new branch]          cygwin-1-3-6-1              -> refs/west/cygwin-1-3-6-1
 * [new branch]          cygwin-1-3-6-2              -> refs/west/cygwin-1-3-6-2
 * [new branch]          cygwin-1-3-6-3              -> refs/west/cygwin-1-3-6-3
 * [new branch]          cygwin-1-3-6-4              -> refs/west/cygwin-1-3-6-4
 * [new branch]          cygwin-1-3-6-5              -> refs/west/cygwin-1-3-6-5
 * [new branch]          cygwin-1-3-6-6              -> refs/west/cygwin-1-3-6-6
 * [new branch]          cygwin-1-3-7-1              -> refs/west/cygwin-1-3-7-1
 * [new branch]          cygwin-1-3-8-1              -> refs/west/cygwin-1-3-8-1
 * [new branch]          cygwin-1-3-9                -> refs/west/cygwin-1-3-9
 * [new branch]          cygwin-1_7_29-release-branchpoint -> refs/west/cygwin-1_7_29-release-branchpoint
 * [new branch]          cygwin-2.0                  -> refs/west/cygwin-2.0
 * [new branch]          cygwin-3_0-branch           -> refs/west/cygwin-3_0-branch
 * [new branch]          cygwin-64bit-branch         -> refs/west/cygwin-64bit-branch
 * [new branch]          cygwin-64bit-premerge-branch -> refs/west/cygwin-64bit-premerge-branch
 * [new branch]          cygwin-acl                  -> refs/west/cygwin-acl
 * [new branch]          cygwin_daemon               -> refs/west/cygwin_daemon
 * [new branch]          debian                      -> refs/west/debian
 * [new branch]          dje-cgen-play1-branch       -> refs/west/dje-cgen-play1-branch
 * [new branch]          docker-builder-packages.txt-hash -> refs/west/docker-builder-packages.txt-hash
 * [new branch]          drow-cplus-branch           -> refs/west/drow-cplus-branch
 * [new branch]          drow-reverse-20070409-branch -> refs/west/drow-reverse-20070409-branch
 * [new branch]          drow_intercu-20040221-branch -> refs/west/drow_intercu-20040221-branch
 * [new branch]          ezannoni_pie-20030916-branch -> refs/west/ezannoni_pie-20030916-branch
 * [new branch]          ezannoni_pie-20040323-branch -> refs/west/ezannoni_pie-20040323-branch
 * [new branch]          fifo_doover3                -> refs/west/fifo_doover3
 * [new branch]          fixes-newlib                -> refs/west/fixes-newlib
 * [new branch]          float-inlines               -> refs/west/float-inlines
 * [new branch]          fp-zeuch                    -> refs/west/fp-zeuch
 * [new branch]          gdb-csl-20060226-branch     -> refs/west/gdb-csl-20060226-branch
 * [new branch]          gdb-csl-arm-20051020-branch -> refs/west/gdb-csl-arm-20051020-branch
 * [new branch]          gdb-csl-available-20060303-branch -> refs/west/gdb-csl-available-20060303-branch
 * [new branch]          gdb-csl-gxxpro-6_3-branch   -> refs/west/gdb-csl-gxxpro-6_3-branch
 * [new branch]          gdb-csl-symbian-20060226-branch -> refs/west/gdb-csl-symbian-20060226-branch
 * [new branch]          gdb-premipsmulti-2000-06-06-branch -> refs/west/gdb-premipsmulti-2000-06-06-branch
 * [new branch]          gdb_5_0-2000-04-10-branch   -> refs/west/gdb_5_0-2000-04-10-branch
 * [new branch]          gdb_5_1-2001-07-29-branch   -> refs/west/gdb_5_1-2001-07-29-branch
 * [new branch]          gdb_5_1_0_1-2002-01-03-branch -> refs/west/gdb_5_1_0_1-2002-01-03-branch
 * [new branch]          gdb_5_2-branch              -> refs/west/gdb_5_2-branch
 * [new branch]          gdb_5_3-branch              -> refs/west/gdb_5_3-branch
 * [new branch]          gdb_6_0-branch              -> refs/west/gdb_6_0-branch
 * [new branch]          gdb_6_1-branch              -> refs/west/gdb_6_1-branch
 * [new branch]          gdb_6_2-branch              -> refs/west/gdb_6_2-branch
 * [new branch]          gdb_6_3-branch              -> refs/west/gdb_6_3-branch
 * [new branch]          gdb_6_4-branch              -> refs/west/gdb_6_4-branch
 * [new branch]          gdb_6_5-branch              -> refs/west/gdb_6_5-branch
 * [new branch]          gdb_6_6-branch              -> refs/west/gdb_6_6-branch
 * [new branch]          gdb_6_7-branch              -> refs/west/gdb_6_7-branch
 * [new branch]          gdb_6_8-branch              -> refs/west/gdb_6_8-branch
 * [new branch]          gdb_7_0-branch              -> refs/west/gdb_7_0-branch
 * [new branch]          gdb_7_1-branch              -> refs/west/gdb_7_1-branch
 * [new branch]          gdb_7_2-branch              -> refs/west/gdb_7_2-branch
 * [new branch]          gdb_7_3-branch              -> refs/west/gdb_7_3-branch
 * [new branch]          gdb_7_4-branch              -> refs/west/gdb_7_4-branch
 * [new branch]          gdb_7_5-branch              -> refs/west/gdb_7_5-branch
 * [new branch]          gdb_7_6-branch              -> refs/west/gdb_7_6-branch
 * [new branch]          gdb_s390-2001-09-26-branch  -> refs/west/gdb_s390-2001-09-26-branch
 * [new branch]          gh                          -> refs/west/gh
 * [new branch]          insight_6_8-branch          -> refs/west/insight_6_8-branch
 * [new branch]          interps-20030202-branch     -> refs/west/interps-20030202-branch
 * [new branch]          isblank-extern-inline       -> refs/west/isblank-extern-inline
 * [new branch]          jimb-gdb_6_2-e500-branch    -> refs/west/jimb-gdb_6_2-e500-branch
 * [new branch]          jimb-macro-020506-branch    -> refs/west/jimb-macro-020506-branch
 * [new branch]          jimb-ppc64-linux-20030509-branch -> refs/west/jimb-ppc64-linux-20030509-branch
 * [new branch]          jimb-ppc64-linux-20030528-branch -> refs/west/jimb-ppc64-linux-20030528-branch
 * [new branch]          jimb-ppc64-linux-20030613-branch -> refs/west/jimb-ppc64-linux-20030613-branch
 * [new branch]          jimb-rda-nptl-branch        -> refs/west/jimb-rda-nptl-branch
 * [new branch]          kettenis-i386newframe-20030308-branch -> refs/west/kettenis-i386newframe-20030308-branch
 * [new branch]          kettenis_i386newframe-20030406-branch -> refs/west/kettenis_i386newframe-20030406-branch
 * [new branch]          kettenis_i386newframe-20030419-branch -> refs/west/kettenis_i386newframe-20030419-branch
 * [new branch]          kettenis_sparc-20030918-branch -> refs/west/kettenis_sparc-20030918-branch
 * [new branch]          kseitz_interps-20020528-branch -> refs/west/kseitz_interps-20020528-branch
 * [new branch]          locking-docs                -> refs/west/locking-docs
 * [new branch]          mingw-std-ns-branch         -> refs/west/mingw-std-ns-branch
 * [new branch]          mingwex                     -> refs/west/mingwex
 * [new branch]          msnyder-checkpoint-072509-branch -> refs/west/msnyder-checkpoint-072509-branch
 * [new branch]          msnyder-fork-checkpoint-branch -> refs/west/msnyder-fork-checkpoint-branch
 * [new branch]          msnyder-reverse-20060331-branch -> refs/west/msnyder-reverse-20060331-branch
 * [new branch]          msnyder-reverse-20060502-branch -> refs/west/msnyder-reverse-20060502-branch
 * [new branch]          msnyder-reverse-20080609-branch -> refs/west/msnyder-reverse-20080609-branch
 * [new branch]          msnyder-tracepoint-checkpoint-branch -> refs/west/msnyder-tracepoint-checkpoint-branch
 * [new branch]          msp430                      -> refs/west/msp430
 * [new branch]          multiprocess-20081120-branch -> refs/west/multiprocess-20081120-branch
 * [new branch]          newlib                      -> refs/west/newlib
 * [new branch]          newlib-1_17_0-arc           -> refs/west/newlib-1_17_0-arc
 * [new branch]          newlib-autotools-branch     -> refs/west/newlib-autotools-branch
 * [new branch]          newlib-csl-20060320-branch  -> refs/west/newlib-csl-20060320-branch
 * [new branch]          nickrob-async-20060513-branch -> refs/west/nickrob-async-20060513-branch
 * [new branch]          non-linux-ln                -> refs/west/non-linux-ln
 * [new branch]          noreparent                  -> refs/west/noreparent
 * [new branch]          offbyone-20030313-branch    -> refs/west/offbyone-20030313-branch
 * [new branch]          pre-regex                   -> refs/west/pre-regex
 * [new branch]          pregp02r1                   -> refs/west/pregp02r1
 * [new branch]          readline_4_3-import-branch  -> refs/west/readline_4_3-import-branch
 * [new branch]          readline_5_1-import-branch  -> refs/west/readline_5_1-import-branch
 * [new branch]          reverse-20080717-branch     -> refs/west/reverse-20080717-branch
 * [new branch]          reverse-20080930-branch     -> refs/west/reverse-20080930-branch
 * [new branch]          reverse-20081226-branch     -> refs/west/reverse-20081226-branch
 * [new branch]          riscv-zicsr                 -> refs/west/riscv-zicsr
 * [new branch]          semihost-2.0-all            -> refs/west/semihost-2.0-all
 * [new branch]          sid-20020905-branch         -> refs/west/sid-20020905-branch
 * [new branch]          signal-rewrite              -> refs/west/signal-rewrite
 * [new branch]          sysroot-skip-checks         -> refs/west/sysroot-skip-checks
 * [new branch]          tcltk840-20020924-branch    -> refs/west/tcltk840-20020924-branch
 * [new branch]          tls                         -> refs/west/tls
 * [new branch]          topic/af_unix               -> refs/west/topic/af_unix
 * [new branch]          topic/ansification          -> refs/west/topic/ansification
 * [new branch]          topic/fifo                  -> refs/west/topic/fifo
 * [new branch]          topic/forkables             -> refs/west/topic/forkables
 * [new branch]          topic/locales               -> refs/west/topic/locales
 * [new branch]          topic/posix_acl_funcs       -> refs/west/topic/posix_acl_funcs
 * [new branch]          topic/ssp                   -> refs/west/topic/ssp
 * [new branch]          unlabeled-1.1.1.1.2         -> refs/west/unlabeled-1.1.1.1.2
 * [new branch]          unlabeled-1.100.2           -> refs/west/unlabeled-1.100.2
 * [new branch]          unlabeled-1.1010.2          -> refs/west/unlabeled-1.1010.2
 * [new branch]          unlabeled-1.1019.2          -> refs/west/unlabeled-1.1019.2
 * [new branch]          unlabeled-1.1042.2          -> refs/west/unlabeled-1.1042.2
 * [new branch]          unlabeled-1.1042.2.1.4      -> refs/west/unlabeled-1.1042.2.1.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4  -> refs/west/unlabeled-1.1042.2.1.4.2.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4.2.2 -> refs/west/unlabeled-1.1042.2.1.4.2.4.2.2
 * [new branch]          unlabeled-1.105.2           -> refs/west/unlabeled-1.105.2
 * [new branch]          unlabeled-1.106.2           -> refs/west/unlabeled-1.106.2
 * [new branch]          unlabeled-1.106.8           -> refs/west/unlabeled-1.106.8
 * [new branch]          unlabeled-1.107.12          -> refs/west/unlabeled-1.107.12
 * [new branch]          unlabeled-1.11.2            -> refs/west/unlabeled-1.11.2
 * [new branch]          unlabeled-1.112.4           -> refs/west/unlabeled-1.112.4
 * [new branch]          unlabeled-1.116.4           -> refs/west/unlabeled-1.116.4
 * [new branch]          unlabeled-1.12.20           -> refs/west/unlabeled-1.12.20
 * [new branch]          unlabeled-1.12.30           -> refs/west/unlabeled-1.12.30
 * [new branch]          unlabeled-1.12.4            -> refs/west/unlabeled-1.12.4
 * [new branch]          unlabeled-1.120.2           -> refs/west/unlabeled-1.120.2
 * [new branch]          unlabeled-1.125.2           -> refs/west/unlabeled-1.125.2
 * [new branch]          unlabeled-1.13.10           -> refs/west/unlabeled-1.13.10
 * [new branch]          unlabeled-1.13.2            -> refs/west/unlabeled-1.13.2
 * [new branch]          unlabeled-1.13.30           -> refs/west/unlabeled-1.13.30
 * [new branch]          unlabeled-1.13.4            -> refs/west/unlabeled-1.13.4
 * [new branch]          unlabeled-1.133.2           -> refs/west/unlabeled-1.133.2
 * [new branch]          unlabeled-1.134.4           -> refs/west/unlabeled-1.134.4
 * [new branch]          unlabeled-1.135.4           -> refs/west/unlabeled-1.135.4
 * [new branch]          unlabeled-1.1370.2          -> refs/west/unlabeled-1.1370.2
 * [new branch]          unlabeled-1.142.2           -> refs/west/unlabeled-1.142.2
 * [new branch]          unlabeled-1.143.4           -> refs/west/unlabeled-1.143.4
 * [new branch]          unlabeled-1.144.2           -> refs/west/unlabeled-1.144.2
 * [new branch]          unlabeled-1.15.10           -> refs/west/unlabeled-1.15.10
 * [new branch]          unlabeled-1.15.2            -> refs/west/unlabeled-1.15.2
 * [new branch]          unlabeled-1.1527.4          -> refs/west/unlabeled-1.1527.4
 * [new branch]          unlabeled-1.153.2           -> refs/west/unlabeled-1.153.2
 * [new branch]          unlabeled-1.1563.2          -> refs/west/unlabeled-1.1563.2
 * [new branch]          unlabeled-1.1656.2          -> refs/west/unlabeled-1.1656.2
 * [new branch]          unlabeled-1.167.4           -> refs/west/unlabeled-1.167.4
 * [new branch]          unlabeled-1.17.2            -> refs/west/unlabeled-1.17.2
 * [new branch]          unlabeled-1.17.4            -> refs/west/unlabeled-1.17.4
 * [new branch]          unlabeled-1.1710.2          -> refs/west/unlabeled-1.1710.2
 * [new branch]          unlabeled-1.172.4           -> refs/west/unlabeled-1.172.4
 * [new branch]          unlabeled-1.18.10           -> refs/west/unlabeled-1.18.10
 * [new branch]          unlabeled-1.18.2            -> refs/west/unlabeled-1.18.2
 * [new branch]          unlabeled-1.1806.2          -> refs/west/unlabeled-1.1806.2
 * [new branch]          unlabeled-1.1856.2          -> refs/west/unlabeled-1.1856.2
 * [new branch]          unlabeled-1.188.2           -> refs/west/unlabeled-1.188.2
 * [new branch]          unlabeled-1.188.2.1.8       -> refs/west/unlabeled-1.188.2.1.8
 * [new branch]          unlabeled-1.188.2.1.8.2.2   -> refs/west/unlabeled-1.188.2.1.8.2.2
 * [new branch]          unlabeled-1.19.12           -> refs/west/unlabeled-1.19.12
 * [new branch]          unlabeled-1.2.2             -> refs/west/unlabeled-1.2.2
 * [new branch]          unlabeled-1.20.4            -> refs/west/unlabeled-1.20.4
 * [new branch]          unlabeled-1.21.2            -> refs/west/unlabeled-1.21.2
 * [new branch]          unlabeled-1.21.4            -> refs/west/unlabeled-1.21.4
 * [new branch]          unlabeled-1.22.2            -> refs/west/unlabeled-1.22.2
 * [new branch]          unlabeled-1.22.4            -> refs/west/unlabeled-1.22.4
 * [new branch]          unlabeled-1.226.2           -> refs/west/unlabeled-1.226.2
 * [new branch]          unlabeled-1.23.16           -> refs/west/unlabeled-1.23.16
 * [new branch]          unlabeled-1.23.2            -> refs/west/unlabeled-1.23.2
 * [new branch]          unlabeled-1.23.4            -> refs/west/unlabeled-1.23.4
 * [new branch]          unlabeled-1.231.4           -> refs/west/unlabeled-1.231.4
 * [new branch]          unlabeled-1.234.16          -> refs/west/unlabeled-1.234.16
 * [new branch]          unlabeled-1.235.2           -> refs/west/unlabeled-1.235.2
 * [new branch]          unlabeled-1.238.4           -> refs/west/unlabeled-1.238.4
 * [new branch]          unlabeled-1.24.16           -> refs/west/unlabeled-1.24.16
 * [new branch]          unlabeled-1.24.2            -> refs/west/unlabeled-1.24.2
 * [new branch]          unlabeled-1.24.4            -> refs/west/unlabeled-1.24.4
 * [new branch]          unlabeled-1.248.2           -> refs/west/unlabeled-1.248.2
 * [new branch]          unlabeled-1.253.2           -> refs/west/unlabeled-1.253.2
 * [new branch]          unlabeled-1.27.12           -> refs/west/unlabeled-1.27.12
 * [new branch]          unlabeled-1.27.8            -> refs/west/unlabeled-1.27.8
 * [new branch]          unlabeled-1.30.4            -> refs/west/unlabeled-1.30.4
 * [new branch]          unlabeled-1.31.4            -> refs/west/unlabeled-1.31.4
 * [new branch]          unlabeled-1.32.16           -> refs/west/unlabeled-1.32.16
 * [new branch]          unlabeled-1.32.2            -> refs/west/unlabeled-1.32.2
 * [new branch]          unlabeled-1.35.12           -> refs/west/unlabeled-1.35.12
 * [new branch]          unlabeled-1.38.4            -> refs/west/unlabeled-1.38.4
 * [new branch]          unlabeled-1.39.2            -> refs/west/unlabeled-1.39.2
 * [new branch]          unlabeled-1.44.2            -> refs/west/unlabeled-1.44.2
 * [new branch]          unlabeled-1.44.4            -> refs/west/unlabeled-1.44.4
 * [new branch]          unlabeled-1.45.2            -> refs/west/unlabeled-1.45.2
 * [new branch]          unlabeled-1.45.8            -> refs/west/unlabeled-1.45.8
 * [new branch]          unlabeled-1.46.4            -> refs/west/unlabeled-1.46.4
 * [new branch]          unlabeled-1.48.16           -> refs/west/unlabeled-1.48.16
 * [new branch]          unlabeled-1.5.16            -> refs/west/unlabeled-1.5.16
 * [new branch]          unlabeled-1.5.2             -> refs/west/unlabeled-1.5.2
 * [new branch]          unlabeled-1.50.2            -> refs/west/unlabeled-1.50.2
 * [new branch]          unlabeled-1.50.6            -> refs/west/unlabeled-1.50.6
 * [new branch]          unlabeled-1.52.2            -> refs/west/unlabeled-1.52.2
 * [new branch]          unlabeled-1.53.6            -> refs/west/unlabeled-1.53.6
 * [new branch]          unlabeled-1.54.4            -> refs/west/unlabeled-1.54.4
 * [new branch]          unlabeled-1.64.2            -> refs/west/unlabeled-1.64.2
 * [new branch]          unlabeled-1.65.12           -> refs/west/unlabeled-1.65.12
 * [new branch]          unlabeled-1.65.4            -> refs/west/unlabeled-1.65.4
 * [new branch]          unlabeled-1.66.2            -> refs/west/unlabeled-1.66.2
 * [new branch]          unlabeled-1.69.4            -> refs/west/unlabeled-1.69.4
 * [new branch]          unlabeled-1.74.4            -> refs/west/unlabeled-1.74.4
 * [new branch]          unlabeled-1.75.4            -> refs/west/unlabeled-1.75.4
 * [new branch]          unlabeled-1.8.2             -> refs/west/unlabeled-1.8.2
 * [new branch]          unlabeled-1.81.2            -> refs/west/unlabeled-1.81.2
 * [new branch]          unlabeled-1.83.4            -> refs/west/unlabeled-1.83.4
 * [new branch]          unlabeled-1.86.2            -> refs/west/unlabeled-1.86.2
 * [new branch]          unlabeled-1.88.2            -> refs/west/unlabeled-1.88.2
 * [new branch]          unlabeled-1.90.2            -> refs/west/unlabeled-1.90.2
 * [new branch]          unlabeled-1.90.2.1.4        -> refs/west/unlabeled-1.90.2.1.4
 * [new branch]          unlabeled-1.93.2            -> refs/west/unlabeled-1.93.2
 * [new branch]          vendor                      -> refs/west/vendor
 * [new branch]          x86-more-32                 -> refs/west/x86-more-32
 * [new branch]          zephyr-add-library          -> refs/west/zephyr-add-library
 * [new branch]          zephyr-deprecated           -> refs/west/zephyr-deprecated
 * [new branch]          zephyr-hacks                -> refs/west/zephyr-hacks
 * [new branch]          zephyr-no-posix-define      -> refs/west/zephyr-no-posix-define
 * [new branch]          zephyr-posix                -> refs/west/zephyr-posix
 * [new branch]          zephyr-source               -> refs/west/zephyr-source
 * [new tag]             1.0                         -> 1.0
 * [new tag]             1.0-1                       -> 1.0-1
 * [new tag]             1.1                         -> 1.1
 * [new tag]             1.1-1                       -> 1.1-1
 * [new tag]             1.1-2                       -> 1.1-2
 * [new tag]             1.1.1-1                     -> 1.1.1-1
 * [new tag]             1.2                         -> 1.2
 * [new tag]             1.2-1                       -> 1.2-1
 * [new tag]             1.2.1-1                     -> 1.2.1-1
 * [new tag]             1.3                         -> 1.3
 * [new tag]             1.3-1                       -> 1.3-1
 * [new tag]             1.4                         -> 1.4
 * [new tag]             1.4-1                       -> 1.4-1
 * [new tag]             1.4.1-1                     -> 1.4.1-1
 * [new tag]             1.4.1-2                     -> 1.4.1-2
 * [new tag]             1.4.2-1                     -> 1.4.2-1
 * [new tag]             1.4.2-2                     -> 1.4.2-2
 * [new tag]             1.4.2-3                     -> 1.4.2-3
 * [new tag]             1.4.3-1                     -> 1.4.3-1
 * [new tag]             1.4.4-1                     -> 1.4.4-1
 * [new tag]             1.4.5                       -> 1.4.5
 * [new tag]             1.4.5-1                     -> 1.4.5-1
 * [new tag]             1.4.6                       -> 1.4.6
 * [new tag]             1.4.6-1                     -> 1.4.6-1
 * [new tag]             1.4.7                       -> 1.4.7
 * [new tag]             1.4.7-1                     -> 1.4.7-1
 * [new tag]             1.4.7-2                     -> 1.4.7-2
 * [new tag]             1.5                         -> 1.5
 * [new tag]             1.5-1                       -> 1.5-1
 * [new tag]             1.5.1-1                     -> 1.5.1-1
 * [new tag]             1.5.1-2                     -> 1.5.1-2
 * [new tag]             1.6                         -> 1.6
 * [new tag]             1.6-1                       -> 1.6-1
 * [new tag]             1.6.1-1                     -> 1.6.1-1
 * [new tag]             1.6.2-1                     -> 1.6.2-1
 * [new tag]             1.7                         -> 1.7
 * [new tag]             1.7-1                       -> 1.7-1
 * [new tag]             1.7.1-1                     -> 1.7.1-1
 * [new tag]             1.7.2-1                     -> 1.7.2-1
 * [new tag]             1.7.2-2                     -> 1.7.2-2
 * [new tag]             1.7.3-1                     -> 1.7.3-1
 * [new tag]             1.7.3-2                     -> 1.7.3-2
 * [new tag]             1.7.4-1                     -> 1.7.4-1
 * [new tag]             1.7.5-1                     -> 1.7.5-1
 * [new tag]             1.7.6-1                     -> 1.7.6-1
 * [new tag]             1.7.8                       -> 1.7.8
 * [new tag]             1.7.9                       -> 1.7.9
 * [new tag]             1.8.2                       -> 1.8.2
 * [new tag]             1.8.2-1                     -> 1.8.2-1
 * [new tag]             1.8.4                       -> 1.8.4
 * [new tag]             1.8.6                       -> 1.8.6
 * [new tag]             3.1.0.2019.08.08            -> 3.1.0.2019.08.08
 * [new tag]             3.1.0.2019.08.08-1          -> 3.1.0.2019.08.08-1
 * [new tag]             3.1.0.2019.08.14            -> 3.1.0.2019.08.14
 * [new tag]             3.1.0.2019.08.14-1          -> 3.1.0.2019.08.14-1
 * [new tag]             EOL_registry_mounts         -> EOL_registry_mounts
 * [new tag]             Z-cygwin_daemon_merge-new_HEAD -> Z-cygwin_daemon_merge-new_HEAD
 * [new tag]             Z-cygwin_daemon_merge_HEAD  -> Z-cygwin_daemon_merge_HEAD
 * [new tag]             after-mmap-privanon-noreserve -> after-mmap-privanon-noreserve
 * [new tag]             after-mmap-revamp           -> after-mmap-revamp
 * [new tag]             arc-20081103-branchpoint    -> arc-20081103-branchpoint
 * [new tag]             arc-insight_6_8-branchpoint -> arc-insight_6_8-branchpoint
 * [new tag]             arc-sim-20090309            -> arc-sim-20090309
 * [new tag]             before-mmap-revamp          -> before-mmap-revamp
 * [new tag]             binu_ss_19990502            -> binu_ss_19990502
 * [new tag]             binu_ss_19990602            -> binu_ss_19990602
 * [new tag]             binu_ss_19990721            -> binu_ss_19990721
 * [new tag]             binutils-2_10               -> binutils-2_10
 * [new tag]             binutils-2_10-branchpoint   -> binutils-2_10-branchpoint
 * [new tag]             binutils-2_10_1             -> binutils-2_10_1
 * [new tag]             binutils-2_11               -> binutils-2_11
 * [new tag]             binutils-2_11_1             -> binutils-2_11_1
 * [new tag]             binutils-2_11_2             -> binutils-2_11_2
 * [new tag]             binutils-2_12               -> binutils-2_12
 * [new tag]             binutils-2_12-branchpoint   -> binutils-2_12-branchpoint
 * [new tag]             binutils-2_12_1             -> binutils-2_12_1
 * [new tag]             binutils-2_13               -> binutils-2_13
 * [new tag]             binutils-2_13-branchpoint   -> binutils-2_13-branchpoint
 * [new tag]             binutils-2_13_1             -> binutils-2_13_1
 * [new tag]             binutils-2_13_2             -> binutils-2_13_2
 * [new tag]             binutils-2_13_2_1           -> binutils-2_13_2_1
 * [new tag]             binutils-2_14               -> binutils-2_14
 * [new tag]             binutils-2_14-branchpoint   -> binutils-2_14-branchpoint
 * [new tag]             binutils-2_15               -> binutils-2_15
 * [new tag]             binutils-2_15-branchpoint   -> binutils-2_15-branchpoint
 * [new tag]             binutils-2_16               -> binutils-2_16
 * [new tag]             binutils-2_16-branchpoint   -> binutils-2_16-branchpoint
 * [new tag]             binutils-2_16_1             -> binutils-2_16_1
 * [new tag]             binutils-2_17               -> binutils-2_17
 * [new tag]             binutils-2_17-branchpoint   -> binutils-2_17-branchpoint
 * [new tag]             binutils-2_18               -> binutils-2_18
 * [new tag]             binutils-2_18-branchpoint   -> binutils-2_18-branchpoint
 * [new tag]             binutils-2_19               -> binutils-2_19
 * [new tag]             binutils-2_19-branchpoint   -> binutils-2_19-branchpoint
 * [new tag]             binutils-2_19_1             -> binutils-2_19_1
 * [new tag]             binutils-2_20               -> binutils-2_20
 * [new tag]             binutils-2_20-branchpoint   -> binutils-2_20-branchpoint
 * [new tag]             binutils-2_20_1             -> binutils-2_20_1
 * [new tag]             binutils-2_21               -> binutils-2_21
 * [new tag]             binutils-2_21-branchpoint   -> binutils-2_21-branchpoint
 * [new tag]             binutils-2_21_1             -> binutils-2_21_1
 * [new tag]             binutils-2_22               -> binutils-2_22
 * [new tag]             binutils-2_22-branchpoint   -> binutils-2_22-branchpoint
 * [new tag]             binutils-2_23               -> binutils-2_23
 * [new tag]             binutils-2_23-branchpoint   -> binutils-2_23-branchpoint
 * [new tag]             binutils-2_23_1             -> binutils-2_23_1
 * [new tag]             binutils-2_23_2             -> binutils-2_23_2
 * [new tag]             binutils-2_24-branchpoint   -> binutils-2_24-branchpoint
 * [new tag]             binutils-arc-20080908-branchpoint -> binutils-arc-20080908-branchpoint
 * [new tag]             binutils-arc-20081103-branchpoint -> binutils-arc-20081103-branchpoint
 * [new tag]             binutils-csl-2_17-branchpoint -> binutils-csl-2_17-branchpoint
 * [new tag]             binutils-csl-arm-2005q1-branchpoint -> binutils-csl-arm-2005q1-branchpoint
 * [new tag]             binutils-csl-arm-2005q1a    -> binutils-csl-arm-2005q1a
 * [new tag]             binutils-csl-arm-2005q1b    -> binutils-csl-arm-2005q1b
 * [new tag]             binutils-csl-arm-2006q1-6   -> binutils-csl-arm-2006q1-6
 * [new tag]             binutils-csl-arm-2006q3-19  -> binutils-csl-arm-2006q3-19
 * [new tag]             binutils-csl-arm-2006q3-21  -> binutils-csl-arm-2006q3-21
 * [new tag]             binutils-csl-arm-2006q3-26  -> binutils-csl-arm-2006q3-26
 * [new tag]             binutils-csl-arm-2006q3-27  -> binutils-csl-arm-2006q3-27
 * [new tag]             binutils-csl-coldfire-4_1-10 -> binutils-csl-coldfire-4_1-10
 * [new tag]             binutils-csl-coldfire-4_1-11 -> binutils-csl-coldfire-4_1-11
 * [new tag]             binutils-csl-coldfire-4_1-28 -> binutils-csl-coldfire-4_1-28
 * [new tag]             binutils-csl-coldfire-4_1-30 -> binutils-csl-coldfire-4_1-30
 * [new tag]             binutils-csl-coldfire-4_1-32 -> binutils-csl-coldfire-4_1-32
 * [new tag]             binutils-csl-gxxpro-3_4-branchpoint -> binutils-csl-gxxpro-3_4-branchpoint
 * [new tag]             binutils-csl-innovasic-fido-3_4_4-33 -> binutils-csl-innovasic-fido-3_4_4-33
 * [new tag]             binutils-csl-morpho-4_1-4   -> binutils-csl-morpho-4_1-4
 * [new tag]             binutils-csl-palmsource-arm-prelinker-1_0-1 -> binutils-csl-palmsource-arm-prelinker-1_0-1
 * [new tag]             binutils-csl-renesas-4_1-6  -> binutils-csl-renesas-4_1-6
 * [new tag]             binutils-csl-renesas-4_1-7  -> binutils-csl-renesas-4_1-7
 * [new tag]             binutils-csl-renesas-4_1-8  -> binutils-csl-renesas-4_1-8
 * [new tag]             binutils-csl-renesas-4_1-9  -> binutils-csl-renesas-4_1-9
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-17 -> binutils-csl-sourcerygxx-3_4_4-17
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-19 -> binutils-csl-sourcerygxx-3_4_4-19
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-21 -> binutils-csl-sourcerygxx-3_4_4-21
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-25 -> binutils-csl-sourcerygxx-3_4_4-25
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-32 -> binutils-csl-sourcerygxx-3_4_4-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-12 -> binutils-csl-sourcerygxx-4_1-12
 * [new tag]             binutils-csl-sourcerygxx-4_1-13 -> binutils-csl-sourcerygxx-4_1-13
 * [new tag]             binutils-csl-sourcerygxx-4_1-14 -> binutils-csl-sourcerygxx-4_1-14
 * [new tag]             binutils-csl-sourcerygxx-4_1-15 -> binutils-csl-sourcerygxx-4_1-15
 * [new tag]             binutils-csl-sourcerygxx-4_1-17 -> binutils-csl-sourcerygxx-4_1-17
 * [new tag]             binutils-csl-sourcerygxx-4_1-18 -> binutils-csl-sourcerygxx-4_1-18
 * [new tag]             binutils-csl-sourcerygxx-4_1-19 -> binutils-csl-sourcerygxx-4_1-19
 * [new tag]             binutils-csl-sourcerygxx-4_1-20 -> binutils-csl-sourcerygxx-4_1-20
 * [new tag]             binutils-csl-sourcerygxx-4_1-21 -> binutils-csl-sourcerygxx-4_1-21
 * [new tag]             binutils-csl-sourcerygxx-4_1-22 -> binutils-csl-sourcerygxx-4_1-22
 * [new tag]             binutils-csl-sourcerygxx-4_1-23 -> binutils-csl-sourcerygxx-4_1-23
 * [new tag]             binutils-csl-sourcerygxx-4_1-24 -> binutils-csl-sourcerygxx-4_1-24
 * [new tag]             binutils-csl-sourcerygxx-4_1-25 -> binutils-csl-sourcerygxx-4_1-25
 * [new tag]             binutils-csl-sourcerygxx-4_1-26 -> binutils-csl-sourcerygxx-4_1-26
 * [new tag]             binutils-csl-sourcerygxx-4_1-27 -> binutils-csl-sourcerygxx-4_1-27
 * [new tag]             binutils-csl-sourcerygxx-4_1-28 -> binutils-csl-sourcerygxx-4_1-28
 * [new tag]             binutils-csl-sourcerygxx-4_1-29 -> binutils-csl-sourcerygxx-4_1-29
 * [new tag]             binutils-csl-sourcerygxx-4_1-30 -> binutils-csl-sourcerygxx-4_1-30
 * [new tag]             binutils-csl-sourcerygxx-4_1-32 -> binutils-csl-sourcerygxx-4_1-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-4 -> binutils-csl-sourcerygxx-4_1-4
 * [new tag]             binutils-csl-sourcerygxx-4_1-5 -> binutils-csl-sourcerygxx-4_1-5
 * [new tag]             binutils-csl-sourcerygxx-4_1-6 -> binutils-csl-sourcerygxx-4_1-6
 * [new tag]             binutils-csl-sourcerygxx-4_1-7 -> binutils-csl-sourcerygxx-4_1-7
 * [new tag]             binutils-csl-sourcerygxx-4_1-8 -> binutils-csl-sourcerygxx-4_1-8
 * [new tag]             binutils-csl-sourcerygxx-4_1-9 -> binutils-csl-sourcerygxx-4_1-9
 * [new tag]             binutils-csl-wrs-linux-3_4_4-20 -> binutils-csl-wrs-linux-3_4_4-20
 * [new tag]             binutils-csl-wrs-linux-3_4_4-21 -> binutils-csl-wrs-linux-3_4_4-21
 * [new tag]             binutils-csl-wrs-linux-3_4_4-22 -> binutils-csl-wrs-linux-3_4_4-22
 * [new tag]             binutils-csl-wrs-linux-3_4_4-23 -> binutils-csl-wrs-linux-3_4_4-23
 * [new tag]             binutils-csl-wrs-linux-3_4_4-24 -> binutils-csl-wrs-linux-3_4_4-24
 * [new tag]             binutils_latest_snapshot    -> binutils_latest_snapshot
 * [new tag]             cagney-unwind-20030108-branchpoint -> cagney-unwind-20030108-branchpoint
 * [new tag]             cagney_bfdfile-20040213-branchpoint -> cagney_bfdfile-20040213-branchpoint
 * [new tag]             cagney_bigcore-20040122-branchpoint -> cagney_bigcore-20040122-branchpoint
 * [new tag]             cagney_convert-20030606-branchpoint -> cagney_convert-20030606-branchpoint
 * [new tag]             cagney_fileio-20030521-branchpoint -> cagney_fileio-20030521-branchpoint
 * [new tag]             cagney_frameaddr-20030403-branchpoint -> cagney_frameaddr-20030403-branchpoint
 * [new tag]             cagney_frameaddr-20030409-mergepoint -> cagney_frameaddr-20030409-mergepoint
 * [new tag]             cagney_framebase-20030326-branchpoint -> cagney_framebase-20030326-branchpoint
 * [new tag]             cagney_framebase-20030330-mergepoint -> cagney_framebase-20030330-mergepoint
 * [new tag]             cagney_lazyid-20030317-branchpoint -> cagney_lazyid-20030317-branchpoint
 * [new tag]             cagney_offbyone-20030303-branchpoint -> cagney_offbyone-20030303-branchpoint
 * [new tag]             cagney_regbuf-20020515-branchpoint -> cagney_regbuf-20020515-branchpoint
 * [new tag]             cagney_sysregs-20020825-branchpoint -> cagney_sysregs-20020825-branchpoint
 * [new tag]             cagney_tramp-20040309-branchpoint -> cagney_tramp-20040309-branchpoint
 * [new tag]             cagney_tramp-20040321-mergepoint -> cagney_tramp-20040321-mergepoint
 * [new tag]             cagney_writestrings-20030508-branchpoint -> cagney_writestrings-20030508-branchpoint
 * [new tag]             cagney_x86i386-20030821-branchpoint -> cagney_x86i386-20030821-branchpoint
 * [new tag]             carlton-dictionary-20031111-merge -> carlton-dictionary-20031111-merge
 * [new tag]             carlton_dictionary-20020920-branchpoint -> carlton_dictionary-20020920-branchpoint
 * [new tag]             carlton_dictionary-20020927-merge -> carlton_dictionary-20020927-merge
 * [new tag]             carlton_dictionary-20021011-merge -> carlton_dictionary-20021011-merge
 * [new tag]             carlton_dictionary-20021025-merge -> carlton_dictionary-20021025-merge
 * [new tag]             carlton_dictionary-20021115-merge -> carlton_dictionary-20021115-merge
 * [new tag]             carlton_dictionary-20021223-merge -> carlton_dictionary-20021223-merge
 * [new tag]             carlton_dictionary-20030207-merge -> carlton_dictionary-20030207-merge
 * [new tag]             carlton_dictionary-20030305-merge -> carlton_dictionary-20030305-merge
 * [new tag]             carlton_dictionary-20030416-merge -> carlton_dictionary-20030416-merge
 * [new tag]             carlton_dictionary-20030430-merge -> carlton_dictionary-20030430-merge
 * [new tag]             carlton_dictionary-20030523-merge -> carlton_dictionary-20030523-merge
 * [new tag]             carlton_dictionary-20030627-merge -> carlton_dictionary-20030627-merge
 * [new tag]             carlton_dictionary-20030805-merge -> carlton_dictionary-20030805-merge
 * [new tag]             carlton_dictionary-20030917-merge -> carlton_dictionary-20030917-merge
 * [new tag]             carlton_dictionary-20031215-merge -> carlton_dictionary-20031215-merge
 * [new tag]             carlton_dictionary-20040126-merge -> carlton_dictionary-20040126-merge
 * [new tag]             cgen-1_1-branchpoint        -> cgen-1_1-branchpoint
 * [new tag]             cgen-snapshot-20071001      -> cgen-snapshot-20071001
 * [new tag]             cgen-snapshot-20071101      -> cgen-snapshot-20071101
 * [new tag]             cgen-snapshot-20071201      -> cgen-snapshot-20071201
 * [new tag]             cgen-snapshot-20080101      -> cgen-snapshot-20080101
 * [new tag]             cgen-snapshot-20080201      -> cgen-snapshot-20080201
 * [new tag]             cgen-snapshot-20080301      -> cgen-snapshot-20080301
 * [new tag]             cgen-snapshot-20080401      -> cgen-snapshot-20080401
 * [new tag]             cgen-snapshot-20080501      -> cgen-snapshot-20080501
 * [new tag]             cgen-snapshot-20080601      -> cgen-snapshot-20080601
 * [new tag]             cgen-snapshot-20080701      -> cgen-snapshot-20080701
 * [new tag]             cgen-snapshot-20080801      -> cgen-snapshot-20080801
 * [new tag]             cgen-snapshot-20080901      -> cgen-snapshot-20080901
 * [new tag]             cgen-snapshot-20081001      -> cgen-snapshot-20081001
 * [new tag]             cgen-snapshot-20081101      -> cgen-snapshot-20081101
 * [new tag]             cgen-snapshot-20081201      -> cgen-snapshot-20081201
 * [new tag]             cgen-snapshot-20090101      -> cgen-snapshot-20090101
 * [new tag]             cgen-snapshot-20090201      -> cgen-snapshot-20090201
 * [new tag]             cgen-snapshot-20090301      -> cgen-snapshot-20090301
 * [new tag]             cgen-snapshot-20090401      -> cgen-snapshot-20090401
 * [new tag]             cgen-snapshot-20090501      -> cgen-snapshot-20090501
 * [new tag]             cgen-snapshot-20090601      -> cgen-snapshot-20090601
 * [new tag]             cgen-snapshot-20090701      -> cgen-snapshot-20090701
 * [new tag]             cgen-snapshot-20090801      -> cgen-snapshot-20090801
 * [new tag]             cgen-snapshot-20090901      -> cgen-snapshot-20090901
 * [new tag]             cgen-snapshot-20091001      -> cgen-snapshot-20091001
 * [new tag]             cgen-snapshot-20091101      -> cgen-snapshot-20091101
 * [new tag]             cgen-snapshot-20091201      -> cgen-snapshot-20091201
 * [new tag]             cgen-snapshot-20100101      -> cgen-snapshot-20100101
 * [new tag]             cgen-snapshot-20100201      -> cgen-snapshot-20100201
 * [new tag]             cgen-snapshot-20100301      -> cgen-snapshot-20100301
 * [new tag]             cgen-snapshot-20100401      -> cgen-snapshot-20100401
 * [new tag]             cgen-snapshot-20100501      -> cgen-snapshot-20100501
 * [new tag]             cgen-snapshot-20100601      -> cgen-snapshot-20100601
 * [new tag]             cgen-snapshot-20100701      -> cgen-snapshot-20100701
 * [new tag]             cgen-snapshot-20100801      -> cgen-snapshot-20100801
 * [new tag]             cgen-snapshot-20100901      -> cgen-snapshot-20100901
 * [new tag]             cgen-snapshot-20101001      -> cgen-snapshot-20101001
 * [new tag]             cgen-snapshot-20101101      -> cgen-snapshot-20101101
 * [new tag]             cgen-snapshot-20101201      -> cgen-snapshot-20101201
 * [new tag]             cgen-snapshot-20110101      -> cgen-snapshot-20110101
 * [new tag]             cgen-snapshot-20110201      -> cgen-snapshot-20110201
 * [new tag]             cgen-snapshot-20110301      -> cgen-snapshot-20110301
 * [new tag]             cgen-snapshot-20110401      -> cgen-snapshot-20110401
 * [new tag]             cgen-snapshot-20110501      -> cgen-snapshot-20110501
 * [new tag]             cgen-snapshot-20110601      -> cgen-snapshot-20110601
 * [new tag]             cgen-snapshot-20110701      -> cgen-snapshot-20110701
 * [new tag]             cgen-snapshot-20110801      -> cgen-snapshot-20110801
 * [new tag]             cgen-snapshot-20110901      -> cgen-snapshot-20110901
 * [new tag]             cgen-snapshot-20111001      -> cgen-snapshot-20111001
 * [new tag]             cgen-snapshot-20111101      -> cgen-snapshot-20111101
 * [new tag]             cgen-snapshot-20111201      -> cgen-snapshot-20111201
 * [new tag]             cgen-snapshot-20120101      -> cgen-snapshot-20120101
 * [new tag]             cgen-snapshot-20120201      -> cgen-snapshot-20120201
 * [new tag]             cgen-snapshot-20120301      -> cgen-snapshot-20120301
 * [new tag]             cgen-snapshot-20120401      -> cgen-snapshot-20120401
 * [new tag]             cgen-snapshot-20120501      -> cgen-snapshot-20120501
 * [new tag]             cgen-snapshot-20120601      -> cgen-snapshot-20120601
 * [new tag]             cgen-snapshot-20120701      -> cgen-snapshot-20120701
 * [new tag]             cgen-snapshot-20120801      -> cgen-snapshot-20120801
 * [new tag]             cgen-snapshot-20120901      -> cgen-snapshot-20120901
 * [new tag]             cgen-snapshot-20121001      -> cgen-snapshot-20121001
 * [new tag]             cgen-snapshot-20121101      -> cgen-snapshot-20121101
 * [new tag]             cgen-snapshot-20121201      -> cgen-snapshot-20121201
 * [new tag]             cgen-snapshot-20130101      -> cgen-snapshot-20130101
 * [new tag]             cgen-snapshot-20130201      -> cgen-snapshot-20130201
 * [new tag]             cgen-snapshot-20130301      -> cgen-snapshot-20130301
 * [new tag]             cgen-snapshot-20130401      -> cgen-snapshot-20130401
 * [new tag]             cgen-snapshot-20130501      -> cgen-snapshot-20130501
 * [new tag]             cgen-snapshot-20130601      -> cgen-snapshot-20130601
 * [new tag]             cgen-snapshot-20130701      -> cgen-snapshot-20130701
 * [new tag]             cgen-snapshot-20130801      -> cgen-snapshot-20130801
 * [new tag]             cgen-snapshot-20130901      -> cgen-snapshot-20130901
 * [new tag]             cgen-snapshot-20131001      -> cgen-snapshot-20131001
 * [new tag]             cgen-snapshot-20131101      -> cgen-snapshot-20131101
 * [new tag]             cgen-snapshot-20131201      -> cgen-snapshot-20131201
 * [new tag]             cgen-snapshot-20140101      -> cgen-snapshot-20140101
 * [new tag]             cgen-snapshot-20140201      -> cgen-snapshot-20140201
 * [new tag]             cgen-snapshot-20140301      -> cgen-snapshot-20140301
 * [new tag]             cgen-snapshot-20140401      -> cgen-snapshot-20140401
 * [new tag]             cgen-snapshot-20140501      -> cgen-snapshot-20140501
 * [new tag]             cgen-snapshot-20140601      -> cgen-snapshot-20140601
 * [new tag]             cgen-snapshot-20140701      -> cgen-snapshot-20140701
 * [new tag]             cgen-snapshot-20140801      -> cgen-snapshot-20140801
 * [new tag]             cgen-snapshot-20140901      -> cgen-snapshot-20140901
 * [new tag]             cgen-snapshot-20141001      -> cgen-snapshot-20141001
 * [new tag]             cgen-snapshot-20141101      -> cgen-snapshot-20141101
 * [new tag]             cgen-snapshot-20141201      -> cgen-snapshot-20141201
 * [new tag]             cgen-snapshot-20150101      -> cgen-snapshot-20150101
 * [new tag]             cgen-snapshot-20150201      -> cgen-snapshot-20150201
 * [new tag]             cgen-snapshot-20150301      -> cgen-snapshot-20150301
 * [new tag]             cgf-more-exit-sync          -> cgf-more-exit-sync
 * [new tag]             corinna-01                  -> corinna-01
 * [new tag]             cr-0x99                     -> cr-0x99
 * [new tag]             csl-arm-2003-q4             -> csl-arm-2003-q4
 * [new tag]             csl-arm-2004-q1             -> csl-arm-2004-q1
 * [new tag]             csl-arm-2004-q1a            -> csl-arm-2004-q1a
 * [new tag]             csl-arm-2004-q3             -> csl-arm-2004-q3
 * [new tag]             csl-arm-2004-q3d            -> csl-arm-2004-q3d
 * [new tag]             csl-arm-20050325-branchpoint -> csl-arm-20050325-branchpoint
 * [new tag]             cygnus_cvs_20020108_pre     -> cygnus_cvs_20020108_pre
 * [new tag]             cygwin-1-1-5                -> cygwin-1-1-5
 * [new tag]             cygwin-1-1-6                -> cygwin-1-1-6
 * [new tag]             cygwin-1-1-7                -> cygwin-1-1-7
 * [new tag]             cygwin-1-1-8                -> cygwin-1-1-8
 * [new tag]             cygwin-1-3-19-1-branchpoint -> cygwin-1-3-19-1-branchpoint
 * [new tag]             cygwin-1_1_1                -> cygwin-1_1_1
 * [new tag]             cygwin-1_7_1-release        -> cygwin-1_7_1-release
 * [new tag]             cygwin-1_7_10-release       -> cygwin-1_7_10-release
 * [new tag]             cygwin-1_7_11-release       -> cygwin-1_7_11-release
 * [new tag]             cygwin-1_7_12-release       -> cygwin-1_7_12-release
 * [new tag]             cygwin-1_7_14-release       -> cygwin-1_7_14-release
 * [new tag]             cygwin-1_7_14_2-release     -> cygwin-1_7_14_2-release
 * [new tag]             cygwin-1_7_15-release       -> cygwin-1_7_15-release
 * [new tag]             cygwin-1_7_16-release       -> cygwin-1_7_16-release
 * [new tag]             cygwin-1_7_17-release       -> cygwin-1_7_17-release
 * [new tag]             cygwin-1_7_18-release       -> cygwin-1_7_18-release
 * [new tag]             cygwin-1_7_19-release       -> cygwin-1_7_19-release
 * [new tag]             cygwin-1_7_2-release        -> cygwin-1_7_2-release
 * [new tag]             cygwin-1_7_20-release       -> cygwin-1_7_20-release
 * [new tag]             cygwin-1_7_21-release       -> cygwin-1_7_21-release
 * [new tag]             cygwin-1_7_22-release       -> cygwin-1_7_22-release
 * [new tag]             cygwin-1_7_23-release       -> cygwin-1_7_23-release
 * [new tag]             cygwin-1_7_24-release       -> cygwin-1_7_24-release
 * [new tag]             cygwin-1_7_25-release       -> cygwin-1_7_25-release
 * [new tag]             cygwin-1_7_26-release       -> cygwin-1_7_26-release
 * [new tag]             cygwin-1_7_27-release       -> cygwin-1_7_27-release
 * [new tag]             cygwin-1_7_28-release       -> cygwin-1_7_28-release
 * [new tag]             cygwin-1_7_29-release       -> cygwin-1_7_29-release
 * [new tag]             cygwin-1_7_3-release        -> cygwin-1_7_3-release
 * [new tag]             cygwin-1_7_30-release       -> cygwin-1_7_30-release
 * [new tag]             cygwin-1_7_31-release       -> cygwin-1_7_31-release
 * [new tag]             cygwin-1_7_32-release       -> cygwin-1_7_32-release
 * [new tag]             cygwin-1_7_33-release       -> cygwin-1_7_33-release
 * [new tag]             cygwin-1_7_34-release       -> cygwin-1_7_34-release
 * [new tag]             cygwin-1_7_35-release       -> cygwin-1_7_35-release
 * [new tag]             cygwin-1_7_4-release        -> cygwin-1_7_4-release
 * [new tag]             cygwin-1_7_5-release        -> cygwin-1_7_5-release
 * [new tag]             cygwin-1_7_7-release        -> cygwin-1_7_7-release
 * [new tag]             cygwin-1_7_8-release        -> cygwin-1_7_8-release
 * [new tag]             cygwin-1_7_9-release        -> cygwin-1_7_9-release
 * [new tag]             cygwin-2_0_0-release        -> cygwin-2_0_0-release
 * [new tag]             cygwin-2_0_1-release        -> cygwin-2_0_1-release
 * [new tag]             cygwin-2_0_2-release        -> cygwin-2_0_2-release
 * [new tag]             cygwin-2_0_3-release        -> cygwin-2_0_3-release
 * [new tag]             cygwin-2_0_4-release        -> cygwin-2_0_4-release
 * [new tag]             cygwin-2_10_0-release       -> cygwin-2_10_0-release
 * [new tag]             cygwin-2_11_0-release       -> cygwin-2_11_0-release
 * [new tag]             cygwin-2_11_1-release       -> cygwin-2_11_1-release
 * [new tag]             cygwin-2_11_2-release       -> cygwin-2_11_2-release
 * [new tag]             cygwin-2_1_0-release        -> cygwin-2_1_0-release
 * [new tag]             cygwin-2_2_0-release        -> cygwin-2_2_0-release
 * [new tag]             cygwin-2_2_1-release        -> cygwin-2_2_1-release
 * [new tag]             cygwin-2_3_0-release        -> cygwin-2_3_0-release
 * [new tag]             cygwin-2_3_1-relase         -> cygwin-2_3_1-relase
 * [new tag]             cygwin-2_3_1-release        -> cygwin-2_3_1-release
 * [new tag]             cygwin-2_4_0-release        -> cygwin-2_4_0-release
 * [new tag]             cygwin-2_4_1-release        -> cygwin-2_4_1-release
 * [new tag]             cygwin-2_5_0-release        -> cygwin-2_5_0-release
 * [new tag]             cygwin-2_5_1-release        -> cygwin-2_5_1-release
 * [new tag]             cygwin-2_5_2-release        -> cygwin-2_5_2-release
 * [new tag]             cygwin-2_6_0-release        -> cygwin-2_6_0-release
 * [new tag]             cygwin-2_6_1-release        -> cygwin-2_6_1-release
 * [new tag]             cygwin-2_7_0-release        -> cygwin-2_7_0-release
 * [new tag]             cygwin-2_8_0-release        -> cygwin-2_8_0-release
 * [new tag]             cygwin-2_8_1-release        -> cygwin-2_8_1-release
 * [new tag]             cygwin-2_8_2-release        -> cygwin-2_8_2-release
 * [new tag]             cygwin-2_9_0-release        -> cygwin-2_9_0-release
 * [new tag]             cygwin-3_0_0-release        -> cygwin-3_0_0-release
 * [new tag]             cygwin-3_0_1-release        -> cygwin-3_0_1-release
 * [new tag]             cygwin-3_0_2-release        -> cygwin-3_0_2-release
 * [new tag]             cygwin-3_0_3-release        -> cygwin-3_0_3-release
 * [new tag]             cygwin-3_0_4-release        -> cygwin-3_0_4-release
 * [new tag]             cygwin-3_0_5-release        -> cygwin-3_0_5-release
 * [new tag]             cygwin-3_0_6-release        -> cygwin-3_0_6-release
 * [new tag]             cygwin-3_0_7-release        -> cygwin-3_0_7-release
 * [new tag]             cygwin-3_1_0-release        -> cygwin-3_1_0-release
 * [new tag]             cygwin-3_1_1-release        -> cygwin-3_1_1-release
 * [new tag]             cygwin-3_1_2-release        -> cygwin-3_1_2-release
 * [new tag]             cygwin-3_1_3-release        -> cygwin-3_1_3-release
 * [new tag]             cygwin-3_1_4-release        -> cygwin-3_1_4-release
 * [new tag]             cygwin-64bit-postmerge      -> cygwin-64bit-postmerge
 * [new tag]             cygwin-64bit-premerge       -> cygwin-64bit-premerge
 * [new tag]             cygwin-pre-user-db          -> cygwin-pre-user-db
 * [new tag]             cygwin_daemon_merge_HEAD    -> cygwin_daemon_merge_HEAD
 * [new tag]             debian-2.10.0-1             -> debian-2.10.0-1
 * [new tag]             dje-cgen-play1-branchpoint  -> dje-cgen-play1-branchpoint
 * [new tag]             drop_9x_support_start       -> drop_9x_support_start
 * [new tag]             drow-cplus-branchpoint      -> drow-cplus-branchpoint
 * [new tag]             drow-cplus-merge-20021020   -> drow-cplus-merge-20021020
 * [new tag]             drow-cplus-merge-20021025   -> drow-cplus-merge-20021025
 * [new tag]             drow-cplus-merge-20031214   -> drow-cplus-merge-20031214
 * [new tag]             drow-cplus-merge-20031220   -> drow-cplus-merge-20031220
 * [new tag]             drow-cplus-merge-20031224   -> drow-cplus-merge-20031224
 * [new tag]             drow-cplus-merge-20040113   -> drow-cplus-merge-20040113
 * [new tag]             drow-cplus-merge-20040208   -> drow-cplus-merge-20040208
 * [new tag]             drow-reverse-20070409-branchpoint -> drow-reverse-20070409-branchpoint
 * [new tag]             drow_intercu-20040221-branchpoint -> drow_intercu-20040221-branchpoint
 * [new tag]             drow_intercu-merge-20040327 -> drow_intercu-merge-20040327
 * [new tag]             drow_intercu-merge-20040402 -> drow_intercu-merge-20040402
 * [new tag]             drow_intercu-merge-20040915 -> drow_intercu-merge-20040915
 * [new tag]             drow_intercu-merge-20040921 -> drow_intercu-merge-20040921
 * [new tag]             egcs_20000222               -> egcs_20000222
 * [new tag]             ezannoni_pie-20030916-branchpoint -> ezannoni_pie-20030916-branchpoint
 * [new tag]             ezannoni_pie-20040323-branchpoint -> ezannoni_pie-20040323-branchpoint
 * [new tag]             gdb-csl-20060226-branch-local-2 -> gdb-csl-20060226-branch-local-2
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-local-1 -> gdb-csl-20060226-branch-merge-to-csl-local-1
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-symbian-1 -> gdb-csl-20060226-branch-merge-to-csl-symbian-1
 * [new tag]             gdb-csl-20060226-branchpoint -> gdb-csl-20060226-branchpoint
 * [new tag]             gdb-csl-arm-20050325-2005-q1a -> gdb-csl-arm-20050325-2005-q1a
 * [new tag]             gdb-csl-arm-20050325-2005-q1b -> gdb-csl-arm-20050325-2005-q1b
 * [new tag]             gdb-csl-arm-20051020-branchpoint -> gdb-csl-arm-20051020-branchpoint
 * [new tag]             gdb-csl-arm-2006q1-6        -> gdb-csl-arm-2006q1-6
 * [new tag]             gdb-csl-available-20060303-branchpoint -> gdb-csl-available-20060303-branchpoint
 * [new tag]             gdb-csl-coldfire-4_1-10     -> gdb-csl-coldfire-4_1-10
 * [new tag]             gdb-csl-coldfire-4_1-11     -> gdb-csl-coldfire-4_1-11
 * [new tag]             gdb-csl-gxxpro-6_3-branchpoint -> gdb-csl-gxxpro-6_3-branchpoint
 * [new tag]             gdb-csl-morpho-4_1-4        -> gdb-csl-morpho-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-17 -> gdb-csl-sourcerygxx-3_4_4-17
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-19 -> gdb-csl-sourcerygxx-3_4_4-19
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-21 -> gdb-csl-sourcerygxx-3_4_4-21
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-25 -> gdb-csl-sourcerygxx-3_4_4-25
 * [new tag]             gdb-csl-sourcerygxx-4_1-12  -> gdb-csl-sourcerygxx-4_1-12
 * [new tag]             gdb-csl-sourcerygxx-4_1-13  -> gdb-csl-sourcerygxx-4_1-13
 * [new tag]             gdb-csl-sourcerygxx-4_1-14  -> gdb-csl-sourcerygxx-4_1-14
 * [new tag]             gdb-csl-sourcerygxx-4_1-17  -> gdb-csl-sourcerygxx-4_1-17
 * [new tag]             gdb-csl-sourcerygxx-4_1-4   -> gdb-csl-sourcerygxx-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-4_1-5   -> gdb-csl-sourcerygxx-4_1-5
 * [new tag]             gdb-csl-sourcerygxx-4_1-6   -> gdb-csl-sourcerygxx-4_1-6
 * [new tag]             gdb-csl-sourcerygxx-4_1-7   -> gdb-csl-sourcerygxx-4_1-7
 * [new tag]             gdb-csl-sourcerygxx-4_1-8   -> gdb-csl-sourcerygxx-4_1-8
 * [new tag]             gdb-csl-sourcerygxx-4_1-9   -> gdb-csl-sourcerygxx-4_1-9
 * [new tag]             gdb-csl-symbian-20060226-branchpoint -> gdb-csl-symbian-20060226-branchpoint
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-10 -> gdb-csl-symbian-6_4_50_20060226-10
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-11 -> gdb-csl-symbian-6_4_50_20060226-11
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-12 -> gdb-csl-symbian-6_4_50_20060226-12
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-8 -> gdb-csl-symbian-6_4_50_20060226-8
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-9 -> gdb-csl-symbian-6_4_50_20060226-9
 * [new tag]             gdb-premipsmulti-2000-06-06-branchpoint -> gdb-premipsmulti-2000-06-06-branchpoint
 * [new tag]             gdb_4_18_2-2000-05-18-release -> gdb_4_18_2-2000-05-18-release
 * [new tag]             gdb_4_95_0-2000-04-27-snapshot -> gdb_4_95_0-2000-04-27-snapshot
 * [new tag]             gdb_4_95_1-2000-05-11-snapshot -> gdb_4_95_1-2000-05-11-snapshot
 * [new tag]             gdb_5_0-2000-04-10-branchpoint -> gdb_5_0-2000-04-10-branchpoint
 * [new tag]             gdb_5_0-2000-05-19-release  -> gdb_5_0-2000-05-19-release
 * [new tag]             gdb_5_1-2001-07-29-branchpoint -> gdb_5_1-2001-07-29-branchpoint
 * [new tag]             gdb_5_1-2001-11-21-release  -> gdb_5_1-2001-11-21-release
 * [new tag]             gdb_5_1_0_1-2002-01-03-branchpoint -> gdb_5_1_0_1-2002-01-03-branchpoint
 * [new tag]             gdb_5_1_0_1-2002-01-03-release -> gdb_5_1_0_1-2002-01-03-release
 * [new tag]             gdb_5_1_1-2002-01-24-release -> gdb_5_1_1-2002-01-24-release
 * [new tag]             gdb_5_2-2002-03-03-branchpoint -> gdb_5_2-2002-03-03-branchpoint
 * [new tag]             gdb_5_2-2002-04-29-release  -> gdb_5_2-2002-04-29-release
 * [new tag]             gdb_5_2_1-2002-07-23-release -> gdb_5_2_1-2002-07-23-release
 * [new tag]             gdb_5_3-2002-09-04-branchpoint -> gdb_5_3-2002-09-04-branchpoint
 * [new tag]             gdb_5_3-2002-12-12-release  -> gdb_5_3-2002-12-12-release
 * [new tag]             gdb_6_0-2003-06-23-branchpoint -> gdb_6_0-2003-06-23-branchpoint
 * [new tag]             gdb_6_0-2003-10-04-release  -> gdb_6_0-2003-10-04-release
 * [new tag]             gdb_6_1-2004-03-01-gmt-branchpoint -> gdb_6_1-2004-03-01-gmt-branchpoint
 * [new tag]             gdb_6_1-2004-04-05-release  -> gdb_6_1-2004-04-05-release
 * [new tag]             gdb_6_1_1-20040616-release  -> gdb_6_1_1-20040616-release
 * [new tag]             gdb_6_2-2004-07-10-gmt-branchpoint -> gdb_6_2-2004-07-10-gmt-branchpoint
 * [new tag]             gdb_6_2-20040730-release    -> gdb_6_2-20040730-release
 * [new tag]             gdb_6_3-20041019-branchpoint -> gdb_6_3-20041019-branchpoint
 * [new tag]             gdb_6_3-20041109-release    -> gdb_6_3-20041109-release
 * [new tag]             gdb_6_4-2005-11-01-branchpoint -> gdb_6_4-2005-11-01-branchpoint
 * [new tag]             gdb_6_4-20051202-release    -> gdb_6_4-20051202-release
 * [new tag]             gdb_6_5-2006-05-14-branchpoint -> gdb_6_5-2006-05-14-branchpoint
 * [new tag]             gdb_6_5-20060621-release    -> gdb_6_5-20060621-release
 * [new tag]             gdb_6_6-2006-11-15-branchpoint -> gdb_6_6-2006-11-15-branchpoint
 * [new tag]             gdb_6_6-2006-12-18-release  -> gdb_6_6-2006-12-18-release
 * [new tag]             gdb_6_7-2007-09-07-branchpoint -> gdb_6_7-2007-09-07-branchpoint
 * [new tag]             gdb_6_7-2007-10-10-release  -> gdb_6_7-2007-10-10-release
 * [new tag]             gdb_6_7_1-2007-10-29-release -> gdb_6_7_1-2007-10-29-release
 * [new tag]             gdb_6_8-2008-02-26-branchpoint -> gdb_6_8-2008-02-26-branchpoint
 * [new tag]             gdb_6_8-2008-03-27-release  -> gdb_6_8-2008-03-27-release
 * [new tag]             gdb_7_0-2009-09-16-branchpoint -> gdb_7_0-2009-09-16-branchpoint
 * [new tag]             gdb_7_0-2009-10-06-release  -> gdb_7_0-2009-10-06-release
 * [new tag]             gdb_7_0_1-2009-12-22-release -> gdb_7_0_1-2009-12-22-release
 * [new tag]             gdb_7_1-2010-02-18-branchpoint -> gdb_7_1-2010-02-18-branchpoint
 * [new tag]             gdb_7_1-2010-03-18-release  -> gdb_7_1-2010-03-18-release
 * [new tag]             gdb_7_2-2010-07-07-branchpoint -> gdb_7_2-2010-07-07-branchpoint
 * [new tag]             gdb_7_2-2010-09-02-release  -> gdb_7_2-2010-09-02-release
 * [new tag]             gdb_7_3-2011-04-01-branchpoint -> gdb_7_3-2011-04-01-branchpoint
 * [new tag]             gdb_7_3-2011-07-26-release  -> gdb_7_3-2011-07-26-release
 * [new tag]             gdb_7_3_1-2011-09-04-release -> gdb_7_3_1-2011-09-04-release
 * [new tag]             gdb_7_4-2011-12-13-branchpoint -> gdb_7_4-2011-12-13-branchpoint
 * [new tag]             gdb_7_4-2012-01-24-release  -> gdb_7_4-2012-01-24-release
 * [new tag]             gdb_7_4_1-2012-04-26-release -> gdb_7_4_1-2012-04-26-release
 * [new tag]             gdb_7_5-2012-07-18-branchpoint -> gdb_7_5-2012-07-18-branchpoint
 * [new tag]             gdb_7_5-2012-08-17-release  -> gdb_7_5-2012-08-17-release
 * [new tag]             gdb_7_5_1-2012-11-29-release -> gdb_7_5_1-2012-11-29-release
 * [new tag]             gdb_7_6-2013-03-12-branchpoint -> gdb_7_6-2013-03-12-branchpoint
 * [new tag]             gdb_7_6-2013-04-26-release  -> gdb_7_6-2013-04-26-release
 * [new tag]             gdb_7_6_1-2013-08-30-release -> gdb_7_6_1-2013-08-30-release
 * [new tag]             gdb_s390-2001-09-26-branchpoint -> gdb_s390-2001-09-26-branchpoint
 * [new tag]             hmm                         -> hmm
 * [new tag]             insight-precleanup-2001-01-01 -> insight-precleanup-2001-01-01
 * [new tag]             insight_6_5-20061003-release -> insight_6_5-20061003-release
 * [new tag]             insight_6_6-20070208-release -> insight_6_6-20070208-release
 * [new tag]             insight_6_8-branchpoint     -> insight_6_8-branchpoint
 * [new tag]             interps-20030202-branchpoint -> interps-20030202-branchpoint
 * [new tag]             jimb-gdb_6_2-e500-branchpoint -> jimb-gdb_6_2-e500-branchpoint
 * [new tag]             jimb-macro-020506-branchpoint -> jimb-macro-020506-branchpoint
 * [new tag]             jimb-ppc64-linux-20030509-branchpoint -> jimb-ppc64-linux-20030509-branchpoint
 * [new tag]             jimb-ppc64-linux-20030528-branchpoint -> jimb-ppc64-linux-20030528-branchpoint
 * [new tag]             jimb-ppc64-linux-20030613-branchpoint -> jimb-ppc64-linux-20030613-branchpoint
 * [new tag]             jimb-rda-nptl-branchpoint   -> jimb-rda-nptl-branchpoint
 * [new tag]             kettenis-i386newframe-20030308-branchpoint -> kettenis-i386newframe-20030308-branchpoint
 * [new tag]             kettenis-i386newframe-20030316-mergepoint -> kettenis-i386newframe-20030316-mergepoint
 * [new tag]             kettenis_i386newframe-20030406-branchpoint -> kettenis_i386newframe-20030406-branchpoint
 * [new tag]             kettenis_i386newframe-20030419-branchpoint -> kettenis_i386newframe-20030419-branchpoint
 * [new tag]             kettenis_i386newframe-20030504-mergepoint -> kettenis_i386newframe-20030504-mergepoint
 * [new tag]             kettenis_i386newframe-20030517-mergepoint -> kettenis_i386newframe-20030517-mergepoint
 * [new tag]             kettenis_sparc-20030918-branchpoint -> kettenis_sparc-20030918-branchpoint
 * [new tag]             kseitz_interps-20020528-branchpoint -> kseitz_interps-20020528-branchpoint
 * [new tag]             kseitz_interps-20020829-merge -> kseitz_interps-20020829-merge
 * [new tag]             kseitz_interps-20020930-merge -> kseitz_interps-20020930-merge
 * [new tag]             kseitz_interps-20021103-merge -> kseitz_interps-20021103-merge
 * [new tag]             kseitz_interps-20021105-merge -> kseitz_interps-20021105-merge
 * [new tag]             mingw-runtime-2_0           -> mingw-runtime-2_0
 * [new tag]             mingw-runtime-2_4           -> mingw-runtime-2_4
 * [new tag]             msnyder-checkpoint-072509-branchpoint -> msnyder-checkpoint-072509-branchpoint
 * [new tag]             msnyder-fork-checkpoint-branchpoint -> msnyder-fork-checkpoint-branchpoint
 * [new tag]             msnyder-reverse-20060331-branchpoint -> msnyder-reverse-20060331-branchpoint
 * [new tag]             msnyder-reverse-20060502-branchpoint -> msnyder-reverse-20060502-branchpoint
 * [new tag]             msnyder-reverse-20080609-branchpoint -> msnyder-reverse-20080609-branchpoint
 * [new tag]             msnyder-tracepoint-checkpoint-branchpoint -> msnyder-tracepoint-checkpoint-branchpoint
 * [new tag]             multiprocess-20081120-branchpoint -> multiprocess-20081120-branchpoint
 * [new tag]             newlib-1_10_0               -> newlib-1_10_0
 * [new tag]             newlib-1_11_0               -> newlib-1_11_0
 * [new tag]             newlib-1_12_0               -> newlib-1_12_0
 * [new tag]             newlib-1_13_0               -> newlib-1_13_0
 * [new tag]             newlib-1_14_0               -> newlib-1_14_0
 * [new tag]             newlib-1_15_0               -> newlib-1_15_0
 * [new tag]             newlib-1_16_0               -> newlib-1_16_0
 * [new tag]             newlib-1_17_0               -> newlib-1_17_0
 * [new tag]             newlib-1_18_0               -> newlib-1_18_0
 * [new tag]             newlib-1_19_0               -> newlib-1_19_0
 * [new tag]             newlib-1_20_0               -> newlib-1_20_0
 * [new tag]             newlib-1_9_0                -> newlib-1_9_0
 * [new tag]             newlib-2000-02-17           -> newlib-2000-02-17
 * [new tag]             newlib-2_0_0                -> newlib-2_0_0
 * [new tag]             newlib-2_1_0                -> newlib-2_1_0
 * [new tag]             newlib-2_2_0                -> newlib-2_2_0
 * [new tag]             newlib-2_3_0                -> newlib-2_3_0
 * [new tag]             newlib-2_4_0                -> newlib-2_4_0
 * [new tag]             newlib-2_5_0                -> newlib-2_5_0
 * [new tag]             newlib-3.0.0                -> newlib-3.0.0
 * [new tag]             newlib-3.1.0                -> newlib-3.1.0
 * [new tag]             newlib-3.2.0                -> newlib-3.2.0
 * [new tag]             newlib-3.3.0                -> newlib-3.3.0
 * [new tag]             newlib-csl-20060320-branchpoint -> newlib-csl-20060320-branchpoint
 * [new tag]             newlib-csl-arm-2005-q1a     -> newlib-csl-arm-2005-q1a
 * [new tag]             newlib-csl-arm-2005-q1b     -> newlib-csl-arm-2005-q1b
 * [new tag]             newlib-csl-arm-2006q1-6     -> newlib-csl-arm-2006q1-6
 * [new tag]             newlib-csl-arm-2006q3-19    -> newlib-csl-arm-2006q3-19
 * [new tag]             newlib-csl-arm-2006q3-21    -> newlib-csl-arm-2006q3-21
 * [new tag]             newlib-csl-arm-2006q3-26    -> newlib-csl-arm-2006q3-26
 * [new tag]             newlib-csl-arm-2006q3-27    -> newlib-csl-arm-2006q3-27
 * [new tag]             newlib-csl-coldfire-4_1-28  -> newlib-csl-coldfire-4_1-28
 * [new tag]             newlib-csl-coldfire-4_1-30  -> newlib-csl-coldfire-4_1-30
 * [new tag]             newlib-csl-coldfire-4_1-32  -> newlib-csl-coldfire-4_1-32
 * [new tag]             newlib-csl-innovasic-fido-3_4_4-33 -> newlib-csl-innovasic-fido-3_4_4-33
 * [new tag]             newlib-csl-sourcerygxx-3_4_4-25 -> newlib-csl-sourcerygxx-3_4_4-25
 * [new tag]             newlib-csl-sourcerygxx-4_1-12 -> newlib-csl-sourcerygxx-4_1-12
 * [new tag]             newlib-csl-sourcerygxx-4_1-13 -> newlib-csl-sourcerygxx-4_1-13
 * [new tag]             newlib-csl-sourcerygxx-4_1-14 -> newlib-csl-sourcerygxx-4_1-14
 * [new tag]             newlib-csl-sourcerygxx-4_1-17 -> newlib-csl-sourcerygxx-4_1-17
 * [new tag]             newlib-csl-sourcerygxx-4_1-18 -> newlib-csl-sourcerygxx-4_1-18
 * [new tag]             newlib-csl-sourcerygxx-4_1-19 -> newlib-csl-sourcerygxx-4_1-19
 * [new tag]             newlib-csl-sourcerygxx-4_1-21 -> newlib-csl-sourcerygxx-4_1-21
 * [new tag]             newlib-csl-sourcerygxx-4_1-23 -> newlib-csl-sourcerygxx-4_1-23
 * [new tag]             newlib-csl-sourcerygxx-4_1-24 -> newlib-csl-sourcerygxx-4_1-24
 * [new tag]             newlib-csl-sourcerygxx-4_1-26 -> newlib-csl-sourcerygxx-4_1-26
 * [new tag]             newlib-csl-sourcerygxx-4_1-27 -> newlib-csl-sourcerygxx-4_1-27
 * [new tag]             newlib-csl-sourcerygxx-4_1-28 -> newlib-csl-sourcerygxx-4_1-28
 * [new tag]             newlib-csl-sourcerygxx-4_1-30 -> newlib-csl-sourcerygxx-4_1-30
 * [new tag]             newlib-csl-sourcerygxx-4_1-32 -> newlib-csl-sourcerygxx-4_1-32
 * [new tag]             newlib-csl-sourcerygxx-4_1-4 -> newlib-csl-sourcerygxx-4_1-4
 * [new tag]             newlib-csl-sourcerygxx-4_1-5 -> newlib-csl-sourcerygxx-4_1-5
 * [new tag]             newlib-csl-sourcerygxx-4_1-6 -> newlib-csl-sourcerygxx-4_1-6
 * [new tag]             newlib-csl-sourcerygxx-4_1-7 -> newlib-csl-sourcerygxx-4_1-7
 * [new tag]             newlib-csl-sourcerygxx-4_1-8 -> newlib-csl-sourcerygxx-4_1-8
 * [new tag]             newlib-csl-sourcerygxx-4_1-9 -> newlib-csl-sourcerygxx-4_1-9
 * [new tag]             newlib-snapshot-20150323    -> newlib-snapshot-20150323
 * [new tag]             newlib-snapshot-20150423    -> newlib-snapshot-20150423
 * [new tag]             newlib-snapshot-20150526    -> newlib-snapshot-20150526
 * [new tag]             newlib-snapshot-20150623    -> newlib-snapshot-20150623
 * [new tag]             newlib-snapshot-20150723    -> newlib-snapshot-20150723
 * [new tag]             newlib-snapshot-20150824    -> newlib-snapshot-20150824
 * [new tag]             newlib-snapshot-20150924    -> newlib-snapshot-20150924
 * [new tag]             newlib-snapshot-20151023    -> newlib-snapshot-20151023
 * [new tag]             newlib-snapshot-20160104    -> newlib-snapshot-20160104
 * [new tag]             newlib-snapshot-20160226    -> newlib-snapshot-20160226
 * [new tag]             newlib-snapshot-20160527    -> newlib-snapshot-20160527
 * [new tag]             newlib-snapshot-20160923    -> newlib-snapshot-20160923
 * [new tag]             newlib-snapshot-20170228    -> newlib-snapshot-20170228
 * [new tag]             newlib-snapshot-20170323    -> newlib-snapshot-20170323
 * [new tag]             newlib-snapshot-20170421    -> newlib-snapshot-20170421
 * [new tag]             newlib-snapshot-20170519    -> newlib-snapshot-20170519
 * [new tag]             newlib-snapshot-20170623    -> newlib-snapshot-20170623
 * [new tag]             newlib-snapshot-20170720    -> newlib-snapshot-20170720
 * [new tag]             newlib-snapshot-20170818    -> newlib-snapshot-20170818
 * [new tag]             newlib-snapshot-20170922    -> newlib-snapshot-20170922
 * [new tag]             newlib-snapshot-20171222    -> newlib-snapshot-20171222
 * [new tag]             newlib-snapshot-20180118    -> newlib-snapshot-20180118
 * [new tag]             newlib-snapshot-20180226    -> newlib-snapshot-20180226
 * [new tag]             newlib-snapshot-20180720    -> newlib-snapshot-20180720
 * [new tag]             newlib-snapshot-20180802    -> newlib-snapshot-20180802
 * [new tag]             newlib-snapshot-20180831    -> newlib-snapshot-20180831
 * [new tag]             newlib-snapshot-20181231    -> newlib-snapshot-20181231
 * [new tag]             newlib-snapshot-20200102    -> newlib-snapshot-20200102
 * [new tag]             nickrob-async-20060513-branchpoint -> nickrob-async-20060513-branchpoint
 * [new tag]             nickrob-async-20060828-mergepoint -> nickrob-async-20060828-mergepoint
 * [new tag]             offbyone-20030313-branchpoint -> offbyone-20030313-branchpoint
 * [new tag]             post-ptmalloc3              -> post-ptmalloc3
 * [new tag]             post_wait_sig_exit          -> post_wait_sig_exit
 * [new tag]             pre-cgf-merge               -> pre-cgf-merge
 * [new tag]             pre-cygwin-heap             -> pre-cygwin-heap
 * [new tag]             pre-no-this                 -> pre-no-this
 * [new tag]             pre-notty                   -> pre-notty
 * [new tag]             pre-posix-scan              -> pre-posix-scan
 * [new tag]             pre-ptmalloc3               -> pre-ptmalloc3
 * [new tag]             pre-ptymaster-archetype     -> pre-ptymaster-archetype
 * [new tag]             pre-ripout-set_console_state_for_spawn -> pre-ripout-set_console_state_for_spawn
 * [new tag]             pre-sigrewrite              -> pre-sigrewrite
 * [new tag]             pre_wait_sig_exit           -> pre_wait_sig_exit
 * [new tag]             predaemon                   -> predaemon
 * [new tag]             prefifo                     -> prefifo
 * [new tag]             preoverlapped               -> preoverlapped
 * [new tag]             readline_4_3-import-branchpoint -> readline_4_3-import-branchpoint
 * [new tag]             readline_5_1-import-branchpoint -> readline_5_1-import-branchpoint
 * [new tag]             reparent-point              -> reparent-point
 * [new tag]             repo-unification-2000-02-06 -> repo-unification-2000-02-06
 * [new tag]             reverse-20080717-branchpoint -> reverse-20080717-branchpoint
 * [new tag]             reverse-20080930-branchpoint -> reverse-20080930-branchpoint
 * [new tag]             reverse-20081226-branchpoint -> reverse-20081226-branchpoint
 * [new tag]             sid-20020905-branchpoint    -> sid-20020905-branchpoint
 * [new tag]             sid-snapshot-20071001       -> sid-snapshot-20071001
 * [new tag]             sid-snapshot-20071101       -> sid-snapshot-20071101
 * [new tag]             sid-snapshot-20071201       -> sid-snapshot-20071201
 * [new tag]             sid-snapshot-20080101       -> sid-snapshot-20080101
 * [new tag]             sid-snapshot-20080201       -> sid-snapshot-20080201
 * [new tag]             sid-snapshot-20080301       -> sid-snapshot-20080301
 * [new tag]             sid-snapshot-20080401       -> sid-snapshot-20080401
 * [new tag]             sid-snapshot-20080403       -> sid-snapshot-20080403
 * [new tag]             sid-snapshot-20080501       -> sid-snapshot-20080501
 * [new tag]             sid-snapshot-20080601       -> sid-snapshot-20080601
 * [new tag]             sid-snapshot-20080701       -> sid-snapshot-20080701
 * [new tag]             sid-snapshot-20080801       -> sid-snapshot-20080801
 * [new tag]             sid-snapshot-20080901       -> sid-snapshot-20080901
 * [new tag]             sid-snapshot-20081001       -> sid-snapshot-20081001
 * [new tag]             sid-snapshot-20081101       -> sid-snapshot-20081101
 * [new tag]             sid-snapshot-20081201       -> sid-snapshot-20081201
 * [new tag]             sid-snapshot-20090101       -> sid-snapshot-20090101
 * [new tag]             sid-snapshot-20090201       -> sid-snapshot-20090201
 * [new tag]             sid-snapshot-20090301       -> sid-snapshot-20090301
 * [new tag]             sid-snapshot-20090401       -> sid-snapshot-20090401
 * [new tag]             sid-snapshot-20090501       -> sid-snapshot-20090501
 * [new tag]             sid-snapshot-20090601       -> sid-snapshot-20090601
 * [new tag]             sid-snapshot-20090701       -> sid-snapshot-20090701
 * [new tag]             sid-snapshot-20090801       -> sid-snapshot-20090801
 * [new tag]             sid-snapshot-20090901       -> sid-snapshot-20090901
 * [new tag]             sid-snapshot-20091001       -> sid-snapshot-20091001
 * [new tag]             sid-snapshot-20091101       -> sid-snapshot-20091101
 * [new tag]             sid-snapshot-20091201       -> sid-snapshot-20091201
 * [new tag]             sid-snapshot-20100101       -> sid-snapshot-20100101
 * [new tag]             sid-snapshot-20100201       -> sid-snapshot-20100201
 * [new tag]             sid-snapshot-20100301       -> sid-snapshot-20100301
 * [new tag]             sid-snapshot-20100401       -> sid-snapshot-20100401
 * [new tag]             sid-snapshot-20100501       -> sid-snapshot-20100501
 * [new tag]             sid-snapshot-20100601       -> sid-snapshot-20100601
 * [new tag]             sid-snapshot-20100701       -> sid-snapshot-20100701
 * [new tag]             sid-snapshot-20100801       -> sid-snapshot-20100801
 * [new tag]             sid-snapshot-20100901       -> sid-snapshot-20100901
 * [new tag]             sid-snapshot-20101001       -> sid-snapshot-20101001
 * [new tag]             sid-snapshot-20101101       -> sid-snapshot-20101101
 * [new tag]             sid-snapshot-20101201       -> sid-snapshot-20101201
 * [new tag]             sid-snapshot-20110101       -> sid-snapshot-20110101
 * [new tag]             sid-snapshot-20110201       -> sid-snapshot-20110201
 * [new tag]             sid-snapshot-20110301       -> sid-snapshot-20110301
 * [new tag]             sid-snapshot-20110401       -> sid-snapshot-20110401
 * [new tag]             sid-snapshot-20110501       -> sid-snapshot-20110501
 * [new tag]             sid-snapshot-20110601       -> sid-snapshot-20110601
 * [new tag]             sid-snapshot-20110701       -> sid-snapshot-20110701
 * [new tag]             sid-snapshot-20110801       -> sid-snapshot-20110801
 * [new tag]             sid-snapshot-20110901       -> sid-snapshot-20110901
 * [new tag]             sid-snapshot-20111001       -> sid-snapshot-20111001
 * [new tag]             sid-snapshot-20111101       -> sid-snapshot-20111101
 * [new tag]             sid-snapshot-20111201       -> sid-snapshot-20111201
 * [new tag]             sid-snapshot-20120101       -> sid-snapshot-20120101
 * [new tag]             sid-snapshot-20120201       -> sid-snapshot-20120201
 * [new tag]             sid-snapshot-20120301       -> sid-snapshot-20120301
 * [new tag]             sid-snapshot-20120401       -> sid-snapshot-20120401
 * [new tag]             sid-snapshot-20120501       -> sid-snapshot-20120501
 * [new tag]             sid-snapshot-20120601       -> sid-snapshot-20120601
 * [new tag]             sid-snapshot-20120701       -> sid-snapshot-20120701
 * [new tag]             sid-snapshot-20120801       -> sid-snapshot-20120801
 * [new tag]             sid-snapshot-20120901       -> sid-snapshot-20120901
 * [new tag]             sid-snapshot-20121001       -> sid-snapshot-20121001
 * [new tag]             sid-snapshot-20121101       -> sid-snapshot-20121101
 * [new tag]             sid-snapshot-20121201       -> sid-snapshot-20121201
 * [new tag]             sid-snapshot-20130101       -> sid-snapshot-20130101
 * [new tag]             sid-snapshot-20130201       -> sid-snapshot-20130201
 * [new tag]             sid-snapshot-20130301       -> sid-snapshot-20130301
 * [new tag]             sid-snapshot-20130401       -> sid-snapshot-20130401
 * [new tag]             sid-snapshot-20130501       -> sid-snapshot-20130501
 * [new tag]             sid-snapshot-20130601       -> sid-snapshot-20130601
 * [new tag]             sid-snapshot-20130701       -> sid-snapshot-20130701
 * [new tag]             sid-snapshot-20130801       -> sid-snapshot-20130801
 * [new tag]             sid-snapshot-20130901       -> sid-snapshot-20130901
 * [new tag]             sid-snapshot-20131001       -> sid-snapshot-20131001
 * [new tag]             sid-snapshot-20131101       -> sid-snapshot-20131101
 * [new tag]             sid-snapshot-20131201       -> sid-snapshot-20131201
 * [new tag]             sid-snapshot-20140101       -> sid-snapshot-20140101
 * [new tag]             sid-snapshot-20140201       -> sid-snapshot-20140201
 * [new tag]             sid-snapshot-20140301       -> sid-snapshot-20140301
 * [new tag]             sid-snapshot-20140401       -> sid-snapshot-20140401
 * [new tag]             sid-snapshot-20140501       -> sid-snapshot-20140501
 * [new tag]             sid-snapshot-20140601       -> sid-snapshot-20140601
 * [new tag]             sid-snapshot-20140701       -> sid-snapshot-20140701
 * [new tag]             sid-snapshot-20140801       -> sid-snapshot-20140801
 * [new tag]             sid-snapshot-20140901       -> sid-snapshot-20140901
 * [new tag]             sid-snapshot-20141001       -> sid-snapshot-20141001
 * [new tag]             sid-snapshot-20141101       -> sid-snapshot-20141101
 * [new tag]             sid-snapshot-20141201       -> sid-snapshot-20141201
 * [new tag]             sid-snapshot-20150101       -> sid-snapshot-20150101
 * [new tag]             sid-snapshot-20150201       -> sid-snapshot-20150201
 * [new tag]             sid-snapshot-20150301       -> sid-snapshot-20150301
 * [new tag]             tcltk840-20020924-branchpoint -> tcltk840-20020924-branchpoint
 * [new tag]             w32api-1_5                  -> w32api-1_5
 * [new tag]             w32api-2_2                  -> w32api-2_2
 * [new tag]             winsup-2000-02-17           -> winsup-2000-02-17
 * [new tag]             x86_64versiong3             -> x86_64versiong3
HEAD is now at 764ef4e40 Version 1.8.6
From https://github.com/zephyrproject-rtos/segger
 * [new branch]      master       -> refs/west/master
 * [new branch]      v1.14-branch -> refs/west/v1.14-branch
HEAD is now at b011c45 segger: config: Add CCM option for linker sections
From https://github.com/zephyrproject-rtos/tinycrypt
HEAD is now at 1012a3e Fix warnings reported by UBSAN
From https://github.com/zephyrproject-rtos/uoscore-uedhoc
 * [new branch]      zephyr     -> refs/west/zephyr
HEAD is now at 150f4eb [zephyr fromlist] Adapt to changes in name generation in zcbor 0.8.0
From https://github.com/zephyrproject-rtos/zcbor
 * [new branch]      main              -> refs/west/main
 * [new branch]      release/0.6.1     -> refs/west/release/0.6.1
 * [new branch]      release/0.8.2     -> refs/west/release/0.8.2
 * [new tag]         0.1.0             -> 0.1.0
 * [new tag]         0.2.0             -> 0.2.0
 * [new tag]         0.3.0             -> 0.3.0
 * [new tag]         0.3.1             -> 0.3.1
 * [new tag]         0.4.0             -> 0.4.0
 * [new tag]         0.5.0             -> 0.5.0
 * [new tag]         0.5.1             -> 0.5.1
 * [new tag]         0.6.0             -> 0.6.0
 * [new tag]         0.8.0             -> 0.8.0
 * [new tag]         0.8.1             -> 0.8.1
 * [new tag]         0.9.0             -> 0.9.0
 * [new tag]         deprecated-master -> deprecated-master
 * [new tag]         inital-pr         -> inital-pr
 * [new tag]         old-structure     -> old-structure
HEAD is now at 75d0880 tests: Update mps2 board name
ERROR: update failed for projects: matter, cmock
Error: Launched process exited with non-zero status: 1
2024-09-07T15:21:11.882Z ERROR Error: From https://github.com/nrfconnect/sdk-zephyr
 * tag                       v3.6.99-ncs2              -> FETCH_HEAD
 * [new tag]                 v1.13.99-ncs1             -> v1.13.99-ncs1
 * [new tag]                 v1.13.99-ncs1-rc1         -> v1.13.99-ncs1-rc1
 * [new tag]                 v1.13.99-ncs2             -> v1.13.99-ncs2
 * [new tag]                 v1.13.99-ncs2-rc1         -> v1.13.99-ncs2-rc1
 * [new tag]                 v1.13.99-ncs2-rc2         -> v1.13.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs1             -> v1.14.99-ncs1
 * [new tag]                 v1.14.99-ncs1-rc1         -> v1.14.99-ncs1-rc1
 * [new tag]                 v1.14.99-ncs1-rc2         -> v1.14.99-ncs1-rc2
 * [new tag]                 v1.14.99-ncs2             -> v1.14.99-ncs2
 * [new tag]                 v1.14.99-ncs2-rc1         -> v1.14.99-ncs2-rc1
 * [new tag]                 v1.14.99-ncs2-rc2         -> v1.14.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs2-rc3         -> v1.14.99-ncs2-rc3
 * [new tag]                 v1.14.99-ncs2-rc4         -> v1.14.99-ncs2-rc4
 * [new tag]                 v1.14.99-ncs3-snapshot1   -> v1.14.99-ncs3-snapshot1
 * [new tag]                 v1.14.99-ncs3-snapshot2   -> v1.14.99-ncs3-snapshot2
 * [new tag]                 v2.0.99-ncs1              -> v2.0.99-ncs1
 * [new tag]                 v2.0.99-ncs1-rc1          -> v2.0.99-ncs1-rc1
 * [new tag]                 v2.0.99-ncs1-rc2          -> v2.0.99-ncs1-rc2
 * [new tag]                 v2.0.99-ncs1-rc3          -> v2.0.99-ncs1-rc3
 * [new tag]                 v2.0.99-ncs1-snapshot1    -> v2.0.99-ncs1-snapshot1
 * [new tag]                 v2.1.0-ncs1-snapshot1     -> v2.1.0-ncs1-snapshot1
 * [new tag]                 v2.1.99-ncs1              -> v2.1.99-ncs1
 * [new tag]                 v2.1.99-ncs1-rc1          -> v2.1.99-ncs1-rc1
 * [new tag]                 v2.1.99-ncs1-rc2          -> v2.1.99-ncs1-rc2
 * [new tag]                 v2.1.99-ncs1-snapshot1    -> v2.1.99-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs1           -> v2.3.0-rc1-ncs1
 * [new tag]                 v2.3.0-rc1-ncs1-rc1       -> v2.3.0-rc1-ncs1-rc1
 * [new tag]                 v2.3.0-rc1-ncs1-rc2       -> v2.3.0-rc1-ncs1-rc2
 * [new tag]                 v2.3.0-rc1-ncs1-rc3       -> v2.3.0-rc1-ncs1-rc3
 * [new tag]                 v2.3.0-rc1-ncs1-snapshot1 -> v2.3.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs2           -> v2.3.0-rc1-ncs2
 * [new tag]                 v2.3.0-rc1-ncs3           -> v2.3.0-rc1-ncs3
 * [new tag]                 v2.4.0-ncs1               -> v2.4.0-ncs1
 * [new tag]                 v2.4.0-ncs1-rc1           -> v2.4.0-ncs1-rc1
 * [new tag]                 v2.4.0-ncs1-rc2           -> v2.4.0-ncs1-rc2
 * [new tag]                 v2.4.0-ncs1-snapshot1     -> v2.4.0-ncs1-snapshot1
 * [new tag]                 v2.4.0-ncs2               -> v2.4.0-ncs2
 * [new tag]                 v2.4.0-ncs2-rc1           -> v2.4.0-ncs2-rc1
 * [new tag]                 v2.4.99-ncs1              -> v2.4.99-ncs1
 * [new tag]                 v2.4.99-ncs1-rc1          -> v2.4.99-ncs1-rc1
 * [new tag]                 v2.4.99-ncs1-snapshot1    -> v2.4.99-ncs1-snapshot1
 * [new tag]                 v2.4.99-ncs2              -> v2.4.99-ncs2
 * [new tag]                 v2.4.99-ncs2-1            -> v2.4.99-ncs2-1
 * [new tag]                 v2.4.99-ncs2-rc1          -> v2.4.99-ncs2-rc1
 * [new tag]                 v2.6.0-ncs1-rc3           -> v2.6.0-ncs1-rc3
 * [new tag]                 v2.6.0-rc1-ncs1           -> v2.6.0-rc1-ncs1
 * [new tag]                 v2.6.0-rc1-ncs1-rc1       -> v2.6.0-rc1-ncs1-rc1
 * [new tag]                 v2.6.0-rc1-ncs1-snapshot1 -> v2.6.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.6.99-ncs1              -> v2.6.99-ncs1
 * [new tag]                 v2.6.99-ncs1-1            -> v2.6.99-ncs1-1
 * [new tag]                 v2.6.99-ncs1-rc1          -> v2.6.99-ncs1-rc1
 * [new tag]                 v2.6.99-ncs1-rc2          -> v2.6.99-ncs1-rc2
 * [new tag]                 v2.6.99-ncs1-snapshot1    -> v2.6.99-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1               -> v2.7.0-ncs1
 * [new tag]                 v2.7.0-ncs1-rc1           -> v2.7.0-ncs1-rc1
 * [new tag]                 v2.7.0-ncs1-rc2           -> v2.7.0-ncs1-rc2
 * [new tag]                 v2.7.0-ncs1-snapshot1     -> v2.7.0-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1-snapshot2     -> v2.7.0-ncs1-snapshot2
 * [new tag]                 v2.7.99-ncs1              -> v2.7.99-ncs1
 * [new tag]                 v2.7.99-ncs1-1            -> v2.7.99-ncs1-1
 * [new tag]                 v2.7.99-ncs1-rc1          -> v2.7.99-ncs1-rc1
 * [new tag]                 v2.7.99-ncs1-rc2          -> v2.7.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1              -> v3.0.99-ncs1
 * [new tag]                 v3.0.99-ncs1-1            -> v3.0.99-ncs1-1
 * [new tag]                 v3.0.99-ncs1-rc1          -> v3.0.99-ncs1-rc1
 * [new tag]                 v3.0.99-ncs1-rc2          -> v3.0.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1-snapshot1    -> v3.0.99-ncs1-snapshot1
 * [new tag]                 v3.1.99-ncs1              -> v3.1.99-ncs1
 * [new tag]                 v3.1.99-ncs1-1            -> v3.1.99-ncs1-1
 * [new tag]                 v3.1.99-ncs1-2            -> v3.1.99-ncs1-2
 * [new tag]                 v3.1.99-ncs1-3            -> v3.1.99-ncs1-3
 * [new tag]                 v3.1.99-ncs1-rc1          -> v3.1.99-ncs1-rc1
 * [new tag]                 v3.1.99-ncs1-rc2          -> v3.1.99-ncs1-rc2
 * [new tag]                 v3.1.99-ncs1-snapshot1    -> v3.1.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs1              -> v3.2.99-ncs1
 * [new tag]                 v3.2.99-ncs1-rc1          -> v3.2.99-ncs1-rc1
 * [new tag]                 v3.2.99-ncs1-rc2          -> v3.2.99-ncs1-rc2
 * [new tag]                 v3.2.99-ncs1-snapshot1    -> v3.2.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs2              -> v3.2.99-ncs2
 * [new tag]                 v3.2.99-ncs2-rc1          -> v3.2.99-ncs2-rc1
 * [new tag]                 v3.2.99-ncs2-rc2          -> v3.2.99-ncs2-rc2
 * [new tag]                 v3.2.99-ncs2-snapshot1    -> v3.2.99-ncs2-snapshot1
 * [new tag]                 v3.3.99-ncs1              -> v3.3.99-ncs1
 * [new tag]                 v3.3.99-ncs1-1            -> v3.3.99-ncs1-1
 * [new tag]                 v3.3.99-ncs1-2            -> v3.3.99-ncs1-2
 * [new tag]                 v3.3.99-ncs1-3            -> v3.3.99-ncs1-3
 * [new tag]                 v3.3.99-ncs1-rc1          -> v3.3.99-ncs1-rc1
 * [new tag]                 v3.3.99-ncs1-rc2          -> v3.3.99-ncs1-rc2
 * [new tag]                 v3.3.99-ncs1-snapshot1    -> v3.3.99-ncs1-snapshot1
 * [new tag]                 v3.4.99-ncs1              -> v3.4.99-ncs1
 * [new tag]                 v3.4.99-ncs1-1            -> v3.4.99-ncs1-1
 * [new tag]                 v3.4.99-ncs1-1-rc1        -> v3.4.99-ncs1-1-rc1
 * [new tag]                 v3.4.99-ncs1-2            -> v3.4.99-ncs1-2
 * [new tag]                 v3.4.99-ncs1-3            -> v3.4.99-ncs1-3
 * [new tag]                 v3.4.99-ncs1-rc1          -> v3.4.99-ncs1-rc1
 * [new tag]                 v3.4.99-ncs1-rc2          -> v3.4.99-ncs1-rc2
 * [new tag]                 v3.4.99-ncs1-snapshot1    -> v3.4.99-ncs1-snapshot1
 * [new tag]                 v3.5.99-ncs1              -> v3.5.99-ncs1
 * [new tag]                 v3.5.99-ncs1-1            -> v3.5.99-ncs1-1
 * [new tag]                 v3.5.99-ncs1-rc1          -> v3.5.99-ncs1-rc1
 * [new tag]                 v3.5.99-ncs1-rc2          -> v3.5.99-ncs1-rc2
 * [new tag]                 v3.5.99-ncs1-snapshot1    -> v3.5.99-ncs1-snapshot1
 * [new tag]                 v3.6.99-ncs2              -> v3.6.99-ncs2
 * [new tag]                 v3.6.99-ncs2-rc1          -> v3.6.99-ncs2-rc1
 * [new tag]                 v3.6.99-ncs2-rc2          -> v3.6.99-ncs2-rc2
 * [new tag]                 v3.6.99-ncs2-rc3          -> v3.6.99-ncs2-rc3
 * [new tag]                 v3.6.99-ncs2-snapshot1    -> v3.6.99-ncs2-snapshot1
HEAD is now at 100befc70c7 [nrf fromtree] sysbuild: introduce sysbuild_root for root adjustment
From https://github.com/BabbleSim/bsim_west
 * [new branch]      v2.1       -> refs/west/v2.1
 * [new branch]      v2.1.1     -> refs/west/v2.1.1
 * [new branch]      v2.2       -> refs/west/v2.2
 * [new branch]      v2.2.1     -> refs/west/v2.2.1
 * [new branch]      v2.3       -> refs/west/v2.3
HEAD is now at 68f6282 developer_set: Remove .git suffix in paths
From https://github.com/nrfconnect/sdk-hostap
 * [new branch]          hcs                      -> refs/west/hcs
 * [new branch]          hostap_2_11_devel-ncs1-branch -> refs/west/hostap_2_11_devel-ncs1-branch
 * [new branch]          nrf700x-dev              -> refs/west/nrf700x-dev
 * [new branch]          nrf700x-test             -> refs/west/nrf700x-test
 * [new branch]          v2.5-branch              -> refs/west/v2.5-branch
 * [new branch]          v2.6-branch              -> refs/west/v2.6-branch
 * [new tag]             fix_sauce_tag_snapshot   -> fix_sauce_tag_snapshot
 * [new tag]             hostap_2_11_devel-ncs1   -> hostap_2_11_devel-ncs1
 * [new tag]             prepare_upmerge_snapshot -> prepare_upmerge_snapshot
HEAD is now at 6311fde66 [nrf noup] mbedtls: Fix memory leak
From https://github.com/nrfconnect/sdk-wi-fiquicktrack-controlappc
 * [new branch]      qt_v2.5.1      -> refs/west/qt_v2.5.1
 * [new tag]         R2.1-snapshot1 -> R2.1-snapshot1
 * [new tag]         pre_zephyr_separation_snapshot -> pre_zephyr_separation_snapshot
HEAD is now at 9f91589 [nrf noup] zephyr: Fix POSIX failures
From https://github.com/nrfconnect/sdk-mcuboot
 * tag                 v2.1.0-ncs1             -> FETCH_HEAD
 * [new tag]           v1.10.0-ncs1            -> v1.10.0-ncs1
 * [new tag]           v1.10.0-ncs1-1          -> v1.10.0-ncs1-1
 * [new tag]           v1.10.0-ncs1-rc1        -> v1.10.0-ncs1-rc1
 * [new tag]           v1.10.0-ncs1-rc2        -> v1.10.0-ncs1-rc2
 * [new tag]           v1.10.0-ncs1-snapshot1  -> v1.10.0-ncs1-snapshot1
 * [new tag]           v1.10.99-ncs1           -> v1.10.99-ncs1
 * [new tag]           v1.10.99-ncs1-1         -> v1.10.99-ncs1-1
 * [new tag]           v1.10.99-ncs1-1-rc1     -> v1.10.99-ncs1-1-rc1
 * [new tag]           v1.10.99-ncs1-2         -> v1.10.99-ncs1-2
 * [new tag]           v1.10.99-ncs1-3         -> v1.10.99-ncs1-3
 * [new tag]           v1.10.99-ncs1-rc1       -> v1.10.99-ncs1-rc1
 * [new tag]           v1.10.99-ncs1-rc2       -> v1.10.99-ncs1-rc2
 * [new tag]           v1.10.99-ncs1-snapshot1 -> v1.10.99-ncs1-snapshot1
 * [new tag]           v1.2.99-ncs1            -> v1.2.99-ncs1
 * [new tag]           v1.2.99-ncs1-rc1        -> v1.2.99-ncs1-rc1
 * [new tag]           v1.2.99-ncs2            -> v1.2.99-ncs2
 * [new tag]           v1.2.99-ncs2-rc1        -> v1.2.99-ncs2-rc1
 * [new tag]           v1.2.99-ncs2-rc2        -> v1.2.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs1            -> v1.3.99-ncs1
 * [new tag]           v1.3.99-ncs1-rc1        -> v1.3.99-ncs1-rc1
 * [new tag]           v1.3.99-ncs1-rc2        -> v1.3.99-ncs1-rc2
 * [new tag]           v1.3.99-ncs2            -> v1.3.99-ncs2
 * [new tag]           v1.3.99-ncs2-rc1        -> v1.3.99-ncs2-rc1
 * [new tag]           v1.3.99-ncs2-rc2        -> v1.3.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs2-rc3        -> v1.3.99-ncs2-rc3
 * [new tag]           v1.3.99-ncs2-rc4        -> v1.3.99-ncs2-rc4
 * [new tag]           v1.3.99-ncs3-snapshot1  -> v1.3.99-ncs3-snapshot1
 * [new tag]           v1.3.99-ncs3-snapshot2  -> v1.3.99-ncs3-snapshot2
 * [new tag]           v1.4.99-ncs1            -> v1.4.99-ncs1
 * [new tag]           v1.4.99-ncs1-rc1        -> v1.4.99-ncs1-rc1
 * [new tag]           v1.4.99-ncs1-rc2        -> v1.4.99-ncs1-rc2
 * [new tag]           v1.4.99-ncs1-rc3        -> v1.4.99-ncs1-rc3
 * [new tag]           v1.4.99-ncs1-snapshot1  -> v1.4.99-ncs1-snapshot1
 * [new tag]           v1.4.99-ncs2            -> v1.4.99-ncs2
 * [new tag]           v1.4.99-ncs2-rc1        -> v1.4.99-ncs2-rc1
 * [new tag]           v1.4.99-ncs2-rc2        -> v1.4.99-ncs2-rc2
 * [new tag]           v1.4.99-ncs2-snapshot1  -> v1.4.99-ncs2-snapshot1
 * [new tag]           v1.5.99-ncs1-rc1        -> v1.5.99-ncs1-rc1
 * [new tag]           v1.5.99-ncs1-rc2        -> v1.5.99-ncs1-rc2
 * [new tag]           v1.5.99-ncs1-rc3        -> v1.5.99-ncs1-rc3
 * [new tag]           v1.5.99-ncs1-snapshot1  -> v1.5.99-ncs1-snapshot1
 * [new tag]           v1.6.0-rc2-ncs1         -> v1.6.0-rc2-ncs1
 * [new tag]           v1.6.99-ncs1            -> v1.6.99-ncs1
 * [new tag]           v1.6.99-ncs1-rc1        -> v1.6.99-ncs1-rc1
 * [new tag]           v1.6.99-ncs1-rc2        -> v1.6.99-ncs1-rc2
 * [new tag]           v1.6.99-ncs1-snapshot1  -> v1.6.99-ncs1-snapshot1
 * [new tag]           v1.7.0-ncs1-rc1         -> v1.7.0-ncs1-rc1
 * [new tag]           v1.7.0-ncs1-rc3         -> v1.7.0-ncs1-rc3
 * [new tag]           v1.7.0-ncs1-snapshot1   -> v1.7.0-ncs1-snapshot1
 * [new tag]           v1.7.2                  -> v1.7.2
 * [new tag]           v1.7.2-ncs1             -> v1.7.2-ncs1
 * [new tag]           v1.7.2-ncs1-rc2         -> v1.7.2-ncs1-rc2
 * [new tag]           v1.7.2-ncs2             -> v1.7.2-ncs2
 * [new tag]           v1.7.2-ncs2-rc1         -> v1.7.2-ncs2-rc1
 * [new tag]           v1.7.2-ncs2-rc2         -> v1.7.2-ncs2-rc2
 * [new tag]           v1.7.2-ncs3             -> v1.7.2-ncs3
 * [new tag]           v1.7.2-ncs3-rc1         -> v1.7.2-ncs3-rc1
 * [new tag]           v1.7.2-ncs3-rc2         -> v1.7.2-ncs3-rc2
 * [new tag]           v1.7.99-ncs1            -> v1.7.99-ncs1
 * [new tag]           v1.7.99-ncs1-1          -> v1.7.99-ncs1-1
 * [new tag]           v1.7.99-ncs1-rc1        -> v1.7.99-ncs1-rc1
 * [new tag]           v1.7.99-ncs2            -> v1.7.99-ncs2
 * [new tag]           v1.7.99-ncs2-snapshot1  -> v1.7.99-ncs2-snapshot1
 * [new tag]           v1.7.99-ncs3            -> v1.7.99-ncs3
 * [new tag]           v1.7.99-ncs3-1          -> v1.7.99-ncs3-1
 * [new tag]           v1.7.99-ncs3-rc1        -> v1.7.99-ncs3-rc1
 * [new tag]           v1.7.99-ncs3-rc2        -> v1.7.99-ncs3-rc2
 * [new tag]           v1.7.99-ncs4            -> v1.7.99-ncs4
 * [new tag]           v1.7.99-ncs4-rc1        -> v1.7.99-ncs4-rc1
 * [new tag]           v1.7.99-ncs4-rc2        -> v1.7.99-ncs4-rc2
 * [new tag]           v1.8.99-ncs1            -> v1.8.99-ncs1
 * [new tag]           v1.8.99-ncs1-rc1        -> v1.8.99-ncs1-rc1
 * [new tag]           v1.8.99-ncs1-rc2        -> v1.8.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1            -> v1.9.99-ncs1
 * [new tag]           v1.9.99-ncs1-rc1        -> v1.9.99-ncs1-rc1
 * [new tag]           v1.9.99-ncs1-rc2        -> v1.9.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1-snapshot1  -> v1.9.99-ncs1-snapshot1
 * [new tag]           v1.9.99-ncs2            -> v1.9.99-ncs2
 * [new tag]           v1.9.99-ncs2-rc1        -> v1.9.99-ncs2-rc1
 * [new tag]           v1.9.99-ncs2-rc2        -> v1.9.99-ncs2-rc2
 * [new tag]           v1.9.99-ncs2-snapshot1  -> v1.9.99-ncs2-snapshot1
 * [new tag]           v1.9.99-ncs3            -> v1.9.99-ncs3
 * [new tag]           v1.9.99-ncs3-rc1        -> v1.9.99-ncs3-rc1
 * [new tag]           v1.9.99-ncs3-rc2        -> v1.9.99-ncs3-rc2
 * [new tag]           v1.9.99-ncs4            -> v1.9.99-ncs4
 * [new tag]           v1.9.99-ncs4-rc1        -> v1.9.99-ncs4-rc1
 * [new tag]           v1.9.99-ncs4-rc2        -> v1.9.99-ncs4-rc2
 * [new tag]           v1.9.99-ncs4-snapshot1  -> v1.9.99-ncs4-snapshot1
 * [new tag]           v1.9.99-ncs4-snapshot2  -> v1.9.99-ncs4-snapshot2
 * [new tag]           v2.0.99-ncs1-1          -> v2.0.99-ncs1-1
 * [new tag]           v2.1.0-ncs1             -> v2.1.0-ncs1
 * [new tag]           v2.1.0-ncs1-rc1         -> v2.1.0-ncs1-rc1
 * [new tag]           v2.1.0-ncs1-rc2         -> v2.1.0-ncs1-rc2
 * [new tag]           v2.1.0-ncs1-rc3         -> v2.1.0-ncs1-rc3
HEAD is now at daf2946a [nrf noup] boot/../loader: reboot after updating s0/s1
From https://github.com/laurencelundblade/QCBOR
 * [new branch]      BeforeSpiffyDecode -> refs/west/BeforeSpiffyDecode
 * [new branch]      CDE                -> refs/west/CDE
 * [new branch]      NaN                -> refs/west/NaN
 * [new branch]      arrays             -> refs/west/arrays
 * [new branch]      better_big_num     -> refs/west/better_big_num
 * [new branch]      const              -> refs/west/const
 * [new branch]      dev                -> refs/west/dev
 * [new branch]      disable            -> refs/west/disable
 * [new branch]      enter-array        -> refs/west/enter-array
 * [new branch]      makewarn           -> refs/west/makewarn
 * [new branch]      mappie             -> refs/west/mappie
 * [new branch]      newtag             -> refs/west/newtag
 * [new branch]      ub-example         -> refs/west/ub-example
 * [new branch]      versioning         -> refs/west/versioning
 * [new branch]      warn_in_tests      -> refs/west/warn_in_tests
 * [new tag]         v1.0               -> v1.0
 * [new tag]         v1.1               -> v1.1
 * [new tag]         v1.2               -> v1.2
 * [new tag]         v1.3               -> v1.3
 * [new tag]         v1.4               -> v1.4
 * [new tag]         v1.4.1             -> v1.4.1
HEAD is now at 751d365 restore inc/qcbor.h for backwards compatibility (#181)
From https://github.com/nrfconnect/sdk-mbedtls
 * tag                   v3.5.2-ncs2           -> FETCH_HEAD
 * [new tag]             mbedtls-2.26.0        -> mbedtls-2.26.0
 * [new tag]             v3.0.0-ncs1           -> v3.0.0-ncs1
 * [new tag]             v3.0.0-ncs1-rc2       -> v3.0.0-ncs1-rc2
 * [new tag]             v3.0.0-ncs2           -> v3.0.0-ncs2
 * [new tag]             v3.0.0-ncs2-rc1       -> v3.0.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs1           -> v3.1.0-ncs1
 * [new tag]             v3.1.0-ncs1-rc1       -> v3.1.0-ncs1-rc1
 * [new tag]             v3.1.0-ncs1-rc2       -> v3.1.0-ncs1-rc2
 * [new tag]             v3.1.0-ncs2           -> v3.1.0-ncs2
 * [new tag]             v3.1.0-ncs2-rc1       -> v3.1.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs2-rc2       -> v3.1.0-ncs2-rc2
 * [new tag]             v3.1.0-ncs3           -> v3.1.0-ncs3
 * [new tag]             v3.1.0-ncs3-rc1       -> v3.1.0-ncs3-rc1
 * [new tag]             v3.1.0-ncs3-rc2       -> v3.1.0-ncs3-rc2
 * [new tag]             v3.3.0-ncs1           -> v3.3.0-ncs1
 * [new tag]             v3.3.0-ncs1-1         -> v3.3.0-ncs1-1
 * [new tag]             v3.3.0-ncs1-rc1       -> v3.3.0-ncs1-rc1
 * [new tag]             v3.3.0-ncs1-rc2       -> v3.3.0-ncs1-rc2
 * [new tag]             v3.3.0-ncs1-snapshot1 -> v3.3.0-ncs1-snapshot1
 * [new tag]             v3.3.0-ncs2           -> v3.3.0-ncs2
 * [new tag]             v3.3.0-ncs2-1         -> v3.3.0-ncs2-1
 * [new tag]             v3.3.0-ncs2-1-rc1     -> v3.3.0-ncs2-1-rc1
 * [new tag]             v3.3.0-ncs2-2         -> v3.3.0-ncs2-2
 * [new tag]             v3.3.0-ncs2-3         -> v3.3.0-ncs2-3
 * [new tag]             v3.3.0-ncs2-rc1       -> v3.3.0-ncs2-rc1
 * [new tag]             v3.3.0-ncs2-rc2       -> v3.3.0-ncs2-rc2
 * [new tag]             v3.5.2-ncs1           -> v3.5.2-ncs1
 * [new tag]             v3.5.2-ncs1-1         -> v3.5.2-ncs1-1
 * [new tag]             v3.5.2-ncs1-rc1       -> v3.5.2-ncs1-rc1
 * [new tag]             v3.5.2-ncs1-rc2       -> v3.5.2-ncs1-rc2
 * [new tag]             v3.5.2-ncs1-snapshot1 -> v3.5.2-ncs1-snapshot1
 * [new tag]             v3.5.2-ncs2           -> v3.5.2-ncs2
 * [new tag]             v3.5.2-ncs2-rc1       -> v3.5.2-ncs2-rc1
 * [new tag]             v3.5.2-ncs2-rc2       -> v3.5.2-ncs2-rc2
 * [new tag]             v3.5.2-ncs2-rc3       -> v3.5.2-ncs2-rc3
 * [new tag]             v3.5.2-ncs2-snapshot1 -> v3.5.2-ncs2-snapshot1
HEAD is now at 72868c6f1 [nrf noup] Add MBEDTLS_PSA_CRYPTO_CLIENT support for TLS/DTLS and X.509
From https://github.com/nrfconnect/sdk-oberon-psa-crypto
 * [new branch]      add_test_spec -> refs/west/add_test_spec
 * [new branch]      oberon_west   -> refs/west/oberon_west
 * [new branch]      test          -> refs/west/test
HEAD is now at e0800ec [nrf noup] Allow import and destroy of builtin keys
From https://github.com/nrfconnect/sdk-nrfxlib
 * tag                 v2.7.0       -> FETCH_HEAD
 * [new tag]           v0.1.0       -> v0.1.0
 * [new tag]           v0.1.0-rc1   -> v0.1.0-rc1
 * [new tag]           v0.3.0       -> v0.3.0
 * [new tag]           v0.3.0-rc1   -> v0.3.0-rc1
 * [new tag]           v0.3.0-rc2   -> v0.3.0-rc2
 * [new tag]           v0.4.0       -> v0.4.0
 * [new tag]           v0.4.0-rc1   -> v0.4.0-rc1
 * [new tag]           v0.4.0-rc2   -> v0.4.0-rc2
 * [new tag]           v1.0.0       -> v1.0.0
 * [new tag]           v1.0.0-rc1   -> v1.0.0-rc1
 * [new tag]           v1.0.0-rc2   -> v1.0.0-rc2
 * [new tag]           v1.0.0-rc3   -> v1.0.0-rc3
 * [new tag]           v1.0.0-rc4   -> v1.0.0-rc4
 * [new tag]           v1.1.0       -> v1.1.0
 * [new tag]           v1.1.0-rc1   -> v1.1.0-rc1
 * [new tag]           v1.1.0-rc2   -> v1.1.0-rc2
 * [new tag]           v1.1.0-rc3   -> v1.1.0-rc3
 * [new tag]           v1.2.0       -> v1.2.0
 * [new tag]           v1.2.0-rc1   -> v1.2.0-rc1
 * [new tag]           v1.2.0-rc2   -> v1.2.0-rc2
 * [new tag]           v1.2.1       -> v1.2.1
 * [new tag]           v1.3.0       -> v1.3.0
 * [new tag]           v1.3.0-rc1   -> v1.3.0-rc1
 * [new tag]           v1.3.0-rc2   -> v1.3.0-rc2
 * [new tag]           v1.3.0-rc3   -> v1.3.0-rc3
 * [new tag]           v1.3.1       -> v1.3.1
 * [new tag]           v1.4.0       -> v1.4.0
 * [new tag]           v1.4.0-rc1   -> v1.4.0-rc1
 * [new tag]           v1.4.2       -> v1.4.2
 * [new tag]           v1.5.0       -> v1.5.0
 * [new tag]           v1.5.0-rc1   -> v1.5.0-rc1
 * [new tag]           v1.5.1       -> v1.5.1
 * [new tag]           v1.5.1-rc1   -> v1.5.1-rc1
 * [new tag]           v1.5.2       -> v1.5.2
 * [new tag]           v1.6.0       -> v1.6.0
 * [new tag]           v1.6.0-rc3   -> v1.6.0-rc3
 * [new tag]           v1.6.1       -> v1.6.1
 * [new tag]           v1.7.0       -> v1.7.0
 * [new tag]           v1.7.0-rc1   -> v1.7.0-rc1
 * [new tag]           v1.7.0-rc2   -> v1.7.0-rc2
 * [new tag]           v1.7.1       -> v1.7.1
 * [new tag]           v1.8.0       -> v1.8.0
 * [new tag]           v1.8.0-rc1   -> v1.8.0-rc1
 * [new tag]           v1.8.0-rc2   -> v1.8.0-rc2
 * [new tag]           v1.9.0       -> v1.9.0
 * [new tag]           v1.9.0-rc1   -> v1.9.0-rc1
 * [new tag]           v1.9.0-rc2   -> v1.9.0-rc2
 * [new tag]           v1.9.1       -> v1.9.1
 * [new tag]           v1.9.2       -> v1.9.2
 * [new tag]           v1.9.2-dev1  -> v1.9.2-dev1
 * [new tag]           v2.0.0       -> v2.0.0
 * [new tag]           v2.0.0-rc1   -> v2.0.0-rc1
 * [new tag]           v2.0.0-rc2   -> v2.0.0-rc2
 * [new tag]           v2.0.0-rc2-1 -> v2.0.0-rc2-1
 * [new tag]           v2.0.1       -> v2.0.1
 * [new tag]           v2.0.2       -> v2.0.2
 * [new tag]           v2.1.0       -> v2.1.0
 * [new tag]           v2.1.0-rc1   -> v2.1.0-rc1
 * [new tag]           v2.1.0-rc2   -> v2.1.0-rc2
 * [new tag]           v2.1.1       -> v2.1.1
 * [new tag]           v2.1.2       -> v2.1.2
 * [new tag]           v2.1.3       -> v2.1.3
 * [new tag]           v2.1.4       -> v2.1.4
 * [new tag]           v2.2.0       -> v2.2.0
 * [new tag]           v2.2.0-rc1   -> v2.2.0-rc1
 * [new tag]           v2.2.0-rc2   -> v2.2.0-rc2
 * [new tag]           v2.3.0       -> v2.3.0
 * [new tag]           v2.3.0-rc1   -> v2.3.0-rc1
 * [new tag]           v2.3.0-rc2   -> v2.3.0-rc2
 * [new tag]           v2.4.0       -> v2.4.0
 * [new tag]           v2.4.0-rc1   -> v2.4.0-rc1
 * [new tag]           v2.4.0-rc2   -> v2.4.0-rc2
 * [new tag]           v2.4.1       -> v2.4.1
 * [new tag]           v2.4.2       -> v2.4.2
 * [new tag]           v2.4.3       -> v2.4.3
 * [new tag]           v2.4.4       -> v2.4.4
 * [new tag]           v2.5.0       -> v2.5.0
 * [new tag]           v2.5.0-rc1   -> v2.5.0-rc1
 * [new tag]           v2.5.0-rc2   -> v2.5.0-rc2
 * [new tag]           v2.5.1       -> v2.5.1
 * [new tag]           v2.5.1-rc1   -> v2.5.1-rc1
 * [new tag]           v2.5.2       -> v2.5.2
 * [new tag]           v2.5.3       -> v2.5.3
 * [new tag]           v2.6.0       -> v2.6.0
 * [new tag]           v2.6.0-rc1   -> v2.6.0-rc1
 * [new tag]           v2.6.0-rc2   -> v2.6.0-rc2
 * [new tag]           v2.6.1       -> v2.6.1
 * [new tag]           v2.7.0       -> v2.7.0
 * [new tag]           v2.7.0-rc1   -> v2.7.0-rc1
 * [new tag]           v2.7.0-rc2   -> v2.7.0-rc2
 * [new tag]           v2.7.0-rc3   -> v2.7.0-rc3
HEAD is now at 37e2ac22 nrf_modem: doc: add info about PDN down when NRF_SO_KEEPOPEN is used
From https://github.com/nrfconnect/sdk-trusted-firmware-m
 * tag                   v2.0.0-ncs2            -> FETCH_HEAD
 * [new tag]             v1.2.99-ncs1-1         -> v1.2.99-ncs1-1
 * [new tag]             v1.3.99-ncs1-rc3       -> v1.3.99-ncs1-rc3
 * [new tag]             v1.3.99-ncs1-snapshot1 -> v1.3.99-ncs1-snapshot1
 * [new tag]             v1.3.99-ncs1-snapshot2 -> v1.3.99-ncs1-snapshot2
 * [new tag]             v1.3.99-ncs2-1         -> v1.3.99-ncs2-1
 * [new tag]             v1.3.99-ncs3           -> v1.3.99-ncs3
 * [new tag]             v1.3.99-ncs3-rc1       -> v1.3.99-ncs3-rc1
 * [new tag]             v1.3.99-ncs3-rc2       -> v1.3.99-ncs3-rc2
 * [new tag]             v1.5.0-ncs1            -> v1.5.0-ncs1
 * [new tag]             v1.5.0-ncs1-1          -> v1.5.0-ncs1-1
 * [new tag]             v1.5.0-ncs1-rc1        -> v1.5.0-ncs1-rc1
 * [new tag]             v1.5.0-ncs1-rc2        -> v1.5.0-ncs1-rc2
 * [new tag]             v1.5.0-ncs2            -> v1.5.0-ncs2
 * [new tag]             v1.5.0-ncs2-rc1        -> v1.5.0-ncs2-rc1
 * [new tag]             v1.5.0-ncs2-rc2        -> v1.5.0-ncs2-rc2
 * [new tag]             v1.5.0-ncs2-snapshot1  -> v1.5.0-ncs2-snapshot1
 * [new tag]             v1.6.0-ncs1            -> v1.6.0-ncs1
 * [new tag]             v1.6.0-ncs1-rc1        -> v1.6.0-ncs1-rc1
 * [new tag]             v1.6.0-ncs1-rc2        -> v1.6.0-ncs1-rc2
 * [new tag]             v1.6.0-ncs1-snapshot1  -> v1.6.0-ncs1-snapshot1
 * [new tag]             v1.6.0-ncs2            -> v1.6.0-ncs2
 * [new tag]             v1.6.0-ncs2-rc1        -> v1.6.0-ncs2-rc1
 * [new tag]             v1.6.0-ncs2-rc2        -> v1.6.0-ncs2-rc2
 * [new tag]             v1.6.0-ncs3            -> v1.6.0-ncs3
 * [new tag]             v1.6.0-ncs3-rc1        -> v1.6.0-ncs3-rc1
 * [new tag]             v1.6.0-ncs3-rc2        -> v1.6.0-ncs3-rc2
 * [new tag]             v1.7.0-ncs1            -> v1.7.0-ncs1
 * [new tag]             v1.7.0-ncs1-1          -> v1.7.0-ncs1-1
 * [new tag]             v1.7.0-ncs1-rc2        -> v1.7.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1            -> v1.8.0-ncs1
 * [new tag]             v1.8.0-ncs1-1          -> v1.8.0-ncs1-1
 * [new tag]             v1.8.0-ncs1-1-rc1      -> v1.8.0-ncs1-1-rc1
 * [new tag]             v1.8.0-ncs1-2          -> v1.8.0-ncs1-2
 * [new tag]             v1.8.0-ncs1-3          -> v1.8.0-ncs1-3
 * [new tag]             v1.8.0-ncs1-rc1        -> v1.8.0-ncs1-rc1
 * [new tag]             v1.8.0-ncs1-rc2        -> v1.8.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1-snapshot1  -> v1.8.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs1            -> v2.0.0-ncs1
 * [new tag]             v2.0.0-ncs1-1          -> v2.0.0-ncs1-1
 * [new tag]             v2.0.0-ncs1-rc1        -> v2.0.0-ncs1-rc1
 * [new tag]             v2.0.0-ncs1-rc2        -> v2.0.0-ncs1-rc2
 * [new tag]             v2.0.0-ncs1-snapshot1  -> v2.0.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs2            -> v2.0.0-ncs2
 * [new tag]             v2.0.0-ncs2-rc1        -> v2.0.0-ncs2-rc1
 * [new tag]             v2.0.0-ncs2-rc2        -> v2.0.0-ncs2-rc2
 * [new tag]             v2.0.0-ncs2-rc3        -> v2.0.0-ncs2-rc3
 * [new tag]             v2.0.0-ncs2-snapshot1  -> v2.0.0-ncs2-snapshot1
HEAD is now at 553c47a6a [nrf noup] Fix version warning
From https://github.com/nrfconnect/sdk-psa-arch-tests
 * [new branch]      54l_its         -> refs/west/54l_its
 * [new branch]      fix_wdt_address -> refs/west/fix_wdt_address
HEAD is now at 94a349d [nrf fromlist] Fix base address for the nrf watchdog
From https://github.com/nrfconnect/sdk-connectedhomeip
 * [new tag]               v1.6.99-20210901    -> v1.6.99-20210901
 * [new tag]               v1.6.99-snapshot1   -> v1.6.99-snapshot1
 * [new tag]               v1.7.99-20211125    -> v1.7.99-20211125
 * [new tag]               v1.9.99-matter-dev1 -> v1.9.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev1 -> v2.0.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev2 -> v2.0.99-matter-dev2
 * [new tag]               v2.1.0-snapshot1    -> v2.1.0-snapshot1
 * [new tag]               v2.2.0-snapshot1    -> v2.2.0-snapshot1
 * [new tag]               v2.3.0-snapshot1    -> v2.3.0-snapshot1
 * [new tag]               v2.4.99-snapshot1   -> v2.4.99-snapshot1
 * [new tag]               v2.5.99-dev1        -> v2.5.99-dev1
HEAD is now at 022f2c92f6 [nrf toup] Fix missing network band in scan response.
      2 [main] sh (13652) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x13A1408/0x1151408.
This problem is probably due to using incompatible versions of the cygwin DLL.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version.  The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution.  Rebooting is also suggested if you
are unable to find another cygwin DLL.
      2 [main] sh 1382 dofork: child -1 - forked process 13652 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/ce3b5ff664/mingw64/libexec/git-core\git-submodule: fork: retry: Resource temporarily unavailable
1142856 [main] sh 1382 dofork: child -1 - forked process 14804 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (8240) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x13A1408/0x1091408.
3276331 [main] sh 1382 dofork: child -1 - forked process 8240 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (2008) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x13A1408/0x11E1408.
7409807 [main] sh 1382 dofork: child -1 - forked process 2008 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (9732) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x13A1408/0x10F1408.
15564735 [main] sh 1382 dofork: child -1 - forked process 9732 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/ce3b5ff664/mingw64/libexec/git-core\git-submodule: fork: Resource temporarily unavailable
From https://github.com/nrfconnect/sdk-soc-hwmv1
HEAD is now at 32b1ee3 soc: Update Kconfig.peripherals from sdk-zephyr bdda11b
From https://github.com/nrfconnect/sdk-cjson
 * [new tag]         v1.7.14    -> v1.7.14
HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
From https://github.com/nrfconnect/azure-sdk-for-c
HEAD is now at 308c171c [nrf fromlist] Make repository a Zephyr module
From https://github.com/nrfconnect/sdk-mcu-drivers
HEAD is now at 3873a08 Added missing curly brace for #ifdef __cplusplus
From https://github.com/nrfconnect/sdk-openthread
 * [new branch]          debug/tomaszkob89/key-rotation -> refs/west/debug/tomaszkob89/key-rotation
 * [new branch]          for-testing       -> refs/west/for-testing
 * [new branch]          v1.7-branch       -> refs/west/v1.7-branch
 * [new branch]          v1.9-branch       -> refs/west/v1.9-branch
 * [new branch]          v2.0-branch       -> refs/west/v2.0-branch
 * [new branch]          v2.4-branch       -> refs/west/v2.4-branch
 * [new tag]             thread-reference-20200818-ncs1-rc1 -> thread-reference-20200818-ncs1-rc1
 * [new tag]             thread-reference-20200818-ncs1-rc3 -> thread-reference-20200818-ncs1-rc3
 * [new tag]             v1.8.99-snapshot1 -> v1.8.99-snapshot1
 * [new tag]             v1.9.99-snapshot1 -> v1.9.99-snapshot1
HEAD is now at a57d927b0 [string] add `ParseDigit()`, `ParseHexDigit()`, and other helper functions (#10282)
From https://github.com/nrfconnect/suit-generator
HEAD is now at 3458313 feat: add binary file name value to template generator
From https://github.com/nrfconnect/suit-processor
HEAD is now at 4505925 Fix coverity issues for 2.7 release
From https://github.com/ThrowTheSwitch/cmock
 * [new branch]      branch_2_5_1           -> refs/west/branch_2_5_1
 * [new branch]      cmock_2_6_rc           -> refs/west/cmock_2_6_rc
 * [new branch]      feature/only_config_is_shared -> refs/west/feature/only_config_is_shared
 * [new branch]      reapply_329            -> refs/west/reapply_329
 * [new branch]      revert-329-master      -> refs/west/revert-329-master
 * [new branch]      test/switch_to_actions -> refs/west/test/switch_to_actions
 * [new tag]         v2.4.5                 -> v2.4.5
 * [new tag]         v2.4.6                 -> v2.4.6
HEAD is now at f65066f Merge pull request #404 from tz18/patch-1
      2 [main] sh (9048) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1001408/0x1201408.
      2 [main] sh 1392 dofork: child -1 - forked process 9048 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (9564) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1001408/0x11C1408.
1129745 [main] sh 1392 dofork: child -1 - forked process 9564 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (10160) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1001408/0x10F1408.
3256649 [main] sh 1392 dofork: child -1 - forked process 10160 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (2976) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1001408/0x1091408.
7383241 [main] sh 1392 dofork: child -1 - forked process 2976 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
15523633 [main] sh 1392 dofork: child -1 - forked process 6136 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
From https://github.com/memfault/memfault-firmware-sdk
 * tag               1.6.0      -> FETCH_HEAD
 * [new tag]         0.0.10     -> 0.0.10
 * [new tag]         0.0.11     -> 0.0.11
 * [new tag]         0.0.12     -> 0.0.12
 * [new tag]         0.0.13     -> 0.0.13
 * [new tag]         0.0.14     -> 0.0.14
 * [new tag]         0.0.15     -> 0.0.15
 * [new tag]         0.0.16     -> 0.0.16
 * [new tag]         0.0.17     -> 0.0.17
 * [new tag]         0.0.18     -> 0.0.18
 * [new tag]         0.0.2      -> 0.0.2
 * [new tag]         0.0.3      -> 0.0.3
 * [new tag]         0.0.4      -> 0.0.4
 * [new tag]         0.0.5      -> 0.0.5
 * [new tag]         0.0.6      -> 0.0.6
 * [new tag]         0.0.7      -> 0.0.7
 * [new tag]         0.0.8      -> 0.0.8
 * [new tag]         0.0.9      -> 0.0.9
 * [new tag]         0.10.0     -> 0.10.0
 * [new tag]         0.10.1     -> 0.10.1
 * [new tag]         0.11.0     -> 0.11.0
 * [new tag]         0.11.1     -> 0.11.1
 * [new tag]         0.11.2     -> 0.11.2
 * [new tag]         0.11.3     -> 0.11.3
 * [new tag]         0.11.4     -> 0.11.4
 * [new tag]         0.12.0     -> 0.12.0
 * [new tag]         0.13.0     -> 0.13.0
 * [new tag]         0.13.1     -> 0.13.1
 * [new tag]         0.14.0     -> 0.14.0
 * [new tag]         0.15.0     -> 0.15.0
 * [new tag]         0.16.0     -> 0.16.0
 * [new tag]         0.16.1     -> 0.16.1
 * [new tag]         0.17.0     -> 0.17.0
 * [new tag]         0.17.1     -> 0.17.1
 * [new tag]         0.18.0     -> 0.18.0
 * [new tag]         0.19.0     -> 0.19.0
 * [new tag]         0.2.1      -> 0.2.1
 * [new tag]         0.2.2      -> 0.2.2
 * [new tag]         0.2.3      -> 0.2.3
 * [new tag]         0.2.4      -> 0.2.4
 * [new tag]         0.2.5      -> 0.2.5
 * [new tag]         0.20.0     -> 0.20.0
 * [new tag]         0.20.1     -> 0.20.1
 * [new tag]         0.20.2     -> 0.20.2
 * [new tag]         0.21.0     -> 0.21.0
 * [new tag]         0.21.1     -> 0.21.1
 * [new tag]         0.22.0     -> 0.22.0
 * [new tag]         0.23.0     -> 0.23.0
 * [new tag]         0.24.0     -> 0.24.0
 * [new tag]         0.24.1     -> 0.24.1
 * [new tag]         0.24.2     -> 0.24.2
 * [new tag]         0.25.0     -> 0.25.0
 * [new tag]         0.26.0     -> 0.26.0
 * [new tag]         0.26.1     -> 0.26.1
 * [new tag]         0.27.0     -> 0.27.0
 * [new tag]         0.27.1     -> 0.27.1
 * [new tag]         0.27.2     -> 0.27.2
 * [new tag]         0.27.3     -> 0.27.3
 * [new tag]         0.28.0     -> 0.28.0
 * [new tag]         0.28.1     -> 0.28.1
 * [new tag]         0.28.2     -> 0.28.2
 * [new tag]         0.29.0     -> 0.29.0
 * [new tag]         0.29.1     -> 0.29.1
 * [new tag]         0.3.2      -> 0.3.2
 * [new tag]         0.3.3      -> 0.3.3
 * [new tag]         0.3.4      -> 0.3.4
 * [new tag]         0.30.0     -> 0.30.0
 * [new tag]         0.30.1     -> 0.30.1
 * [new tag]         0.30.2     -> 0.30.2
 * [new tag]         0.30.3     -> 0.30.3
 * [new tag]         0.30.4     -> 0.30.4
 * [new tag]         0.30.5     -> 0.30.5
 * [new tag]         0.31.0     -> 0.31.0
 * [new tag]         0.31.1     -> 0.31.1
 * [new tag]         0.31.2     -> 0.31.2
 * [new tag]         0.31.3     -> 0.31.3
 * [new tag]         0.31.4     -> 0.31.4
 * [new tag]         0.31.5     -> 0.31.5
 * [new tag]         0.32.0     -> 0.32.0
 * [new tag]         0.32.1     -> 0.32.1
 * [new tag]         0.32.2     -> 0.32.2
 * [new tag]         0.33.0     -> 0.33.0
 * [new tag]         0.33.1     -> 0.33.1
 * [new tag]         0.33.2     -> 0.33.2
 * [new tag]         0.33.3     -> 0.33.3
 * [new tag]         0.33.4     -> 0.33.4
 * [new tag]         0.33.5     -> 0.33.5
 * [new tag]         0.34.0     -> 0.34.0
 * [new tag]         0.34.1     -> 0.34.1
 * [new tag]         0.34.2     -> 0.34.2
 * [new tag]         0.35.0     -> 0.35.0
 * [new tag]         0.36.0     -> 0.36.0
 * [new tag]         0.36.1     -> 0.36.1
 * [new tag]         0.37.0     -> 0.37.0
 * [new tag]         0.37.1     -> 0.37.1
 * [new tag]         0.37.2     -> 0.37.2
 * [new tag]         0.38.0     -> 0.38.0
 * [new tag]         0.39.0     -> 0.39.0
 * [new tag]         0.39.1     -> 0.39.1
 * [new tag]         0.4.1      -> 0.4.1
 * [new tag]         0.4.2      -> 0.4.2
 * [new tag]         0.40.0     -> 0.40.0
 * [new tag]         0.41.0     -> 0.41.0
 * [new tag]         0.41.1     -> 0.41.1
 * [new tag]         0.41.2     -> 0.41.2
 * [new tag]         0.42.0     -> 0.42.0
 * [new tag]         0.42.1     -> 0.42.1
 * [new tag]         0.43.0     -> 0.43.0
 * [new tag]         0.43.1     -> 0.43.1
 * [new tag]         0.43.2     -> 0.43.2
 * [new tag]         0.43.3     -> 0.43.3
 * [new tag]         0.6.1      -> 0.6.1
 * [new tag]         0.7.0      -> 0.7.0
 * [new tag]         0.7.1      -> 0.7.1
 * [new tag]         0.7.2      -> 0.7.2
 * [new tag]         0.7.3      -> 0.7.3
 * [new tag]         0.8.2      -> 0.8.2
 * [new tag]         0.9.1      -> 0.9.1
 * [new tag]         0.9.2      -> 0.9.2
 * [new tag]         0.9.3      -> 0.9.3
 * [new tag]         1.0.0      -> 1.0.0
 * [new tag]         1.0.1      -> 1.0.1
 * [new tag]         1.1.0      -> 1.1.0
 * [new tag]         1.1.1      -> 1.1.1
 * [new tag]         1.1.2      -> 1.1.2
 * [new tag]         1.1.3      -> 1.1.3
 * [new tag]         1.10.0     -> 1.10.0
 * [new tag]         1.10.1     -> 1.10.1
 * [new tag]         1.11.0     -> 1.11.0
 * [new tag]         1.11.1     -> 1.11.1
 * [new tag]         1.11.2     -> 1.11.2
 * [new tag]         1.11.3     -> 1.11.3
 * [new tag]         1.2.0      -> 1.2.0
 * [new tag]         1.2.1      -> 1.2.1
 * [new tag]         1.2.2      -> 1.2.2
 * [new tag]         1.2.3      -> 1.2.3
 * [new tag]         1.2.4      -> 1.2.4
 * [new tag]         1.2.5      -> 1.2.5
 * [new tag]         1.3.0      -> 1.3.0
 * [new tag]         1.3.1      -> 1.3.1
 * [new tag]         1.3.2      -> 1.3.2
 * [new tag]         1.3.3      -> 1.3.3
 * [new tag]         1.3.4      -> 1.3.4
 * [new tag]         1.3.5      -> 1.3.5
 * [new tag]         1.4.0      -> 1.4.0
 * [new tag]         1.4.1      -> 1.4.1
 * [new tag]         1.4.2      -> 1.4.2
 * [new tag]         1.4.3      -> 1.4.3
 * [new tag]         1.4.4      -> 1.4.4
 * [new tag]         1.5.0      -> 1.5.0
 * [new tag]         1.5.1      -> 1.5.1
 * [new tag]         1.5.2      -> 1.5.2
 * [new tag]         1.6.0      -> 1.6.0
 * [new tag]         1.6.1      -> 1.6.1
 * [new tag]         1.6.2      -> 1.6.2
 * [new tag]         1.7.0      -> 1.7.0
 * [new tag]         1.7.1      -> 1.7.1
 * [new tag]         1.7.2      -> 1.7.2
 * [new tag]         1.7.3      -> 1.7.3
 * [new tag]         1.7.4      -> 1.7.4
 * [new tag]         1.7.5      -> 1.7.5
 * [new tag]         1.7.6      -> 1.7.6
 * [new tag]         1.7.7      -> 1.7.7
 * [new tag]         1.8.0      -> 1.8.0
 * [new tag]         1.8.1      -> 1.8.1
 * [new tag]         1.9.0      -> 1.9.0
 * [new tag]         1.9.1      -> 1.9.1
 * [new tag]         1.9.2      -> 1.9.2
 * [new tag]         1.9.3      -> 1.9.3
 * [new tag]         1.9.4      -> 1.9.4
HEAD is now at 3d51c80 Memfault Firmware SDK 1.6.0 (Build 5464)
From https://github.com/eembc/coremark
 * [new branch]      128b-pointer -> refs/west/128b-pointer
 * [new branch]      posix-make   -> refs/west/posix-make
 * [new tag]         v1.01        -> v1.01
HEAD is now at d5fad6b Merge pull request #51 from volodymyr-bondarchuk/zephyr
From https://github.com/zephyrproject-rtos/canopennode
 * [new tag]         zephyr-snapshot-1 -> zephyr-snapshot-1
HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t()
From https://github.com/zephyrproject-rtos/chre
HEAD is now at 3b32c76e zephyr: link the .unstable_id data in ROM
From https://github.com/zephyrproject-rtos/lz4
 * [new tag]         lz4-r130   -> lz4-r130
 * [new tag]         r116       -> r116
 * [new tag]         r117       -> r117
 * [new tag]         r118       -> r118
 * [new tag]         r119       -> r119
 * [new tag]         r120       -> r120
 * [new tag]         r121       -> r121
 * [new tag]         r122       -> r122
 * [new tag]         r123       -> r123
 * [new tag]         r124       -> r124
 * [new tag]         r125       -> r125
 * [new tag]         r126       -> r126
 * [new tag]         r127       -> r127
 * [new tag]         r128       -> r128
 * [new tag]         r129       -> r129
 * [new tag]         r130       -> r130
 * [new tag]         r131       -> r131
 * [new tag]         rc129v0    -> rc129v0
 * [new tag]         v1.7.3     -> v1.7.3
 * [new tag]         v1.7.4     -> v1.7.4
 * [new tag]         v1.7.4.2   -> v1.7.4.2
 * [new tag]         v1.7.5     -> v1.7.5
 * [new tag]         v1.8.1     -> v1.8.1
 * [new tag]         v1.8.1.2   -> v1.8.1.2
 * [new tag]         v1.8.2     -> v1.8.2
 * [new tag]         v1.8.3     -> v1.8.3
 * [new tag]         v1.9.3     -> v1.9.3
HEAD is now at 8e303c2 zephyr: make this repo a zephyr module
From https://github.com/zephyrproject-rtos/nanopb
 * [new branch]      cifuzz_test4           -> refs/west/cifuzz_test4
 * [new branch]      dev_dynamic_nanopb_pb2 -> refs/west/dev_dynamic_nanopb_pb2
 * [new branch]      dev_markdown_docs      -> refs/west/dev_markdown_docs
 * [new branch]      maintenance_0.1        -> refs/west/maintenance_0.1
 * [new branch]      maintenance_0.2        -> refs/west/maintenance_0.2
 * [new branch]      maintenance_0.3        -> refs/west/maintenance_0.3
 * [new tag]         0.2.9.5                -> 0.2.9.5
 * [new tag]         0.3.6                  -> 0.3.6
 * [new tag]         0.3.7                  -> 0.3.7
 * [new tag]         0.3.8                  -> 0.3.8
 * [new tag]         0.3.9                  -> 0.3.9
 * [new tag]         0.3.9.1                -> 0.3.9.1
 * [new tag]         0.3.9.2                -> 0.3.9.2
 * [new tag]         0.3.9.3                -> 0.3.9.3
 * [new tag]         0.3.9.4                -> 0.3.9.4
 * [new tag]         0.3.9.5                -> 0.3.9.5
 * [new tag]         0.3.9.6                -> 0.3.9.6
 * [new tag]         0.3.9.7                -> 0.3.9.7
 * [new tag]         0.3.9.8                -> 0.3.9.8
 * [new tag]         0.4.3                  -> 0.4.3
 * [new tag]         0.4.4                  -> 0.4.4
 * [new tag]         0.4.5                  -> 0.4.5
 * [new tag]         nanopb-0.1.0           -> nanopb-0.1.0
 * [new tag]         nanopb-0.1.1           -> nanopb-0.1.1
 * [new tag]         nanopb-0.1.2           -> nanopb-0.1.2
 * [new tag]         nanopb-0.1.3           -> nanopb-0.1.3
 * [new tag]         nanopb-0.1.4           -> nanopb-0.1.4
 * [new tag]         nanopb-0.1.5           -> nanopb-0.1.5
 * [new tag]         nanopb-0.1.6           -> nanopb-0.1.6
 * [new tag]         nanopb-0.1.7           -> nanopb-0.1.7
 * [new tag]         nanopb-0.1.8           -> nanopb-0.1.8
 * [new tag]         nanopb-0.1.9           -> nanopb-0.1.9
 * [new tag]         nanopb-0.1.9.1         -> nanopb-0.1.9.1
 * [new tag]         nanopb-0.2.0           -> nanopb-0.2.0
 * [new tag]         nanopb-0.2.1           -> nanopb-0.2.1
 * [new tag]         nanopb-0.2.2           -> nanopb-0.2.2
 * [new tag]         nanopb-0.2.3           -> nanopb-0.2.3
 * [new tag]         nanopb-0.2.4           -> nanopb-0.2.4
 * [new tag]         nanopb-0.2.5           -> nanopb-0.2.5
 * [new tag]         nanopb-0.2.6           -> nanopb-0.2.6
 * [new tag]         nanopb-0.2.7           -> nanopb-0.2.7
 * [new tag]         nanopb-0.2.8           -> nanopb-0.2.8
 * [new tag]         nanopb-0.2.9           -> nanopb-0.2.9
 * [new tag]         nanopb-0.2.9.1         -> nanopb-0.2.9.1
 * [new tag]         nanopb-0.2.9.2         -> nanopb-0.2.9.2
 * [new tag]         nanopb-0.2.9.3         -> nanopb-0.2.9.3
 * [new tag]         nanopb-0.2.9.4         -> nanopb-0.2.9.4
 * [new tag]         nanopb-0.2.9.5         -> nanopb-0.2.9.5
 * [new tag]         nanopb-0.3.0           -> nanopb-0.3.0
 * [new tag]         nanopb-0.3.1           -> nanopb-0.3.1
 * [new tag]         nanopb-0.3.2           -> nanopb-0.3.2
 * [new tag]         nanopb-0.3.3           -> nanopb-0.3.3
 * [new tag]         nanopb-0.3.4           -> nanopb-0.3.4
 * [new tag]         nanopb-0.3.5           -> nanopb-0.3.5
 * [new tag]         nanopb-0.3.6           -> nanopb-0.3.6
 * [new tag]         nanopb-0.3.7           -> nanopb-0.3.7
 * [new tag]         nanopb-0.3.8           -> nanopb-0.3.8
 * [new tag]         nanopb-0.3.9           -> nanopb-0.3.9
 * [new tag]         nanopb-0.3.9.1         -> nanopb-0.3.9.1
 * [new tag]         nanopb-0.3.9.2         -> nanopb-0.3.9.2
 * [new tag]         nanopb-0.3.9.3         -> nanopb-0.3.9.3
 * [new tag]         nanopb-0.3.9.4         -> nanopb-0.3.9.4
 * [new tag]         nanopb-0.3.9.5         -> nanopb-0.3.9.5
 * [new tag]         nanopb-0.3.9.6         -> nanopb-0.3.9.6
 * [new tag]         nanopb-0.3.9.7         -> nanopb-0.3.9.7
 * [new tag]         nanopb-0.3.9.8         -> nanopb-0.3.9.8
 * [new tag]         nanopb-0.4.0           -> nanopb-0.4.0
 * [new tag]         nanopb-0.4.0-dev       -> nanopb-0.4.0-dev
 * [new tag]         nanopb-0.4.1           -> nanopb-0.4.1
 * [new tag]         nanopb-0.4.2           -> nanopb-0.4.2
 * [new tag]         nanopb-0.4.3           -> nanopb-0.4.3
 * [new tag]         nanopb-0.4.4           -> nanopb-0.4.4
 * [new tag]         nanopb-0.4.5           -> nanopb-0.4.5
HEAD is now at 7f88274 Add migration note about CMake protoc default (#958)
From https://github.com/zephyrproject-rtos/tf-m-tests
 * [new branch]      release/1.7.x -> refs/west/release/1.7.x
HEAD is now at 85f533a Crypto: Use RSA key in PSA format
From https://github.com/zephyrproject-rtos/zscilib
 * [new branch]      gh-pages   -> refs/west/gh-pages
 * [new branch]      revert-38-fix_zephyr_3_1 -> refs/west/revert-38-fix_zephyr_3_1
 * [new tag]         v0.2.0-rc1 -> v0.2.0-rc1
HEAD is now at ee1b287 samples/tests: Update for hwmv2 board names
From https://github.com/zephyrproject-rtos/cmsis
HEAD is now at 4b96cbb doc: Update documentations for CMSIS 5.9.0
From https://github.com/zephyrproject-rtos/cmsis-dsp
HEAD is now at 6489e771 do not generate warnings when scalar functions are used with MVE
From https://github.com/zephyrproject-rtos/cmsis-nn
 * [new branch]      zephyr-v6.0.0 -> refs/west/zephyr-v6.0.0
HEAD is now at 0c8669d Merge pull request #1 from XenuIsWatching/zephyr
From https://github.com/zephyrproject-rtos/edtt
 * [new branch]      le-audio      -> refs/west/le-audio
 * [new branch]      public_master -> refs/west/public_master
HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop
From https://github.com/zephyrproject-rtos/fatfs
HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE
From https://github.com/zephyrproject-rtos/hal_nordic
 * [new branch]      dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3 -> refs/west/dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3
 * [new tag]         nrfx-2.10.0  -> nrfx-2.10.0
 * [new tag]         nrfx-2.11.0  -> nrfx-2.11.0
 * [new tag]         nrfx-3.0.0   -> nrfx-3.0.0
HEAD is now at ab5cb2e nrfx: drivers: nrfx_gpiote: move enabling GPIOTE port interrupt
From https://github.com/zephyrproject-rtos/hal_st
HEAD is now at b77157f drivers: sensor: st: Move to vendor subdirectory
From https://github.com/zephyrproject-rtos/hal_wurthelektronik
HEAD is now at e5bcb2e Update WE sensors SDK to version 2.5.0
From https://github.com/zephyrproject-rtos/libmetal
HEAD is now at 243eed5 lib: update libmetal to SHA f55c02a7b582
From https://github.com/zephyrproject-rtos/liblc3
HEAD is now at 1a5938e meson: Bump to version 1.0.4
From https://github.com/zephyrproject-rtos/littlefs
 * [new tag]         littlefs-v2.1.0 -> littlefs-v2.1.0
 * [new tag]         littlefs-v2.1.1 -> littlefs-v2.1.1
 * [new tag]         littlefs-v2.1.2 -> littlefs-v2.1.2
 * [new tag]         littlefs-v2.1.3 -> littlefs-v2.1.3
 * [new tag]         littlefs-v2.1.4 -> littlefs-v2.1.4
 * [new tag]         littlefs-v2.2.0 -> littlefs-v2.2.0
HEAD is now at 408c16a Merge pull request #14 from de-nordic/update-to-v2.8.1
From https://github.com/zephyrproject-rtos/loramac-node
 * [new branch]        v4.5.2-zephyr -> refs/west/v4.5.2-zephyr
 * [new branch]        v4.6.0-zephyr -> refs/west/v4.6.0-zephyr
 * [new branch]        v4.7.0-zephyr -> refs/west/v4.7.0-zephyr
 * [new branch]        zephyr-v2.6   -> refs/west/zephyr-v2.6
 * [new tag]           4.4.2-rc.4    -> 4.4.2-rc.4
 * [new tag]           V3.4          -> V3.4
 * [new tag]           v2.0          -> v2.0
 * [new tag]           v2.1          -> v2.1
 * [new tag]           v2.2          -> v2.2
 * [new tag]           v2.3.RC1      -> v2.3.RC1
 * [new tag]           v2.3.RC2      -> v2.3.RC2
 * [new tag]           v3.0          -> v3.0
 * [new tag]           v3.1          -> v3.1
 * [new tag]           v3.2          -> v3.2
 * [new tag]           v3.3          -> v3.3
 * [new tag]           v3.4.1        -> v3.4.1
 * [new tag]           v4.0.0        -> v4.0.0
 * [new tag]           v4.1.0        -> v4.1.0
 * [new tag]           v4.2.0        -> v4.2.0
 * [new tag]           v4.3.0        -> v4.3.0
 * [new tag]           v4.3.1        -> v4.3.1
 * [new tag]           v4.3.2        -> v4.3.2
 * [new tag]           v4.4.0        -> v4.4.0
 * [new tag]           v4.4.1        -> v4.4.1
 * [new tag]           v4.4.2        -> v4.4.2
 * [new tag]           v4.4.2-rc.1   -> v4.4.2-rc.1
 * [new tag]           v4.4.2-rc.2   -> v4.4.2-rc.2
 * [new tag]           v4.4.2-rc.3   -> v4.4.2-rc.3
 * [new tag]           v4.4.2-rc.5   -> v4.4.2-rc.5
 * [new tag]           v4.4.2-rc.6   -> v4.4.2-rc.6
 * [new tag]           v4.4.2-rc.7   -> v4.4.2-rc.7
 * [new tag]           v4.4.3        -> v4.4.3
 * [new tag]           v4.4.3_zephyr -> v4.4.3_zephyr
HEAD is now at fb00b383 zephyr: configure FragDecoder using Kconfig
From https://github.com/zephyrproject-rtos/lvgl
HEAD is now at 2b498e6f Merge pull request #51 from faxe1008/upddate_lvgl_840
From https://github.com/zephyrproject-rtos/mipi-sys-t
HEAD is now at 71ace1f mipi_syst: fix build error when having protocol timestamp disabled
From https://github.com/zephyrproject-rtos/net-tools
HEAD is now at 7c7a856 websocket-console: Add a helper script for websocket console
From https://github.com/zephyrproject-rtos/nrf_hw_models
HEAD is now at 36b1271 54L15: Added RRAMC, RRAM & UICR
From https://github.com/zephyrproject-rtos/open-amp
 * [new branch]      bump_v2024.05.0 -> refs/west/bump_v2024.05.0
 * [new tag]         old_master      -> old_master
HEAD is now at da78aea lib: update open-amp lib to release v2023.10.0
From https://github.com/zephyrproject-rtos/picolibc
 * [new branch]          Z-emcb-cygwin_daemon        -> refs/west/Z-emcb-cygwin_daemon
 * [new branch]          aarch64                     -> refs/west/aarch64
 * [new branch]          add-fakeroots-dir           -> refs/west/add-fakeroots-dir
 * [new branch]          amd64_to_x86_64             -> refs/west/amd64_to_x86_64
 * [new branch]          ancient-clang               -> refs/west/ancient-clang
 * [new branch]          arc-20081103-branch         -> refs/west/arc-20081103-branch
 * [new branch]          arc-insight_6_8-branch      -> refs/west/arc-insight_6_8-branch
 * [new branch]          arm-read-tp-cleanup         -> refs/west/arm-read-tp-cleanup
 * [new branch]          binutils-2_10-branch        -> refs/west/binutils-2_10-branch
 * [new branch]          binutils-2_11-branch        -> refs/west/binutils-2_11-branch
 * [new branch]          binutils-2_12-branch        -> refs/west/binutils-2_12-branch
 * [new branch]          binutils-2_13-branch        -> refs/west/binutils-2_13-branch
 * [new branch]          binutils-2_14-branch        -> refs/west/binutils-2_14-branch
 * [new branch]          binutils-2_15-branch        -> refs/west/binutils-2_15-branch
 * [new branch]          binutils-2_16-branch        -> refs/west/binutils-2_16-branch
 * [new branch]          binutils-2_17-branch        -> refs/west/binutils-2_17-branch
 * [new branch]          binutils-2_18-branch        -> refs/west/binutils-2_18-branch
 * [new branch]          binutils-2_19-branch        -> refs/west/binutils-2_19-branch
 * [new branch]          binutils-2_20-branch        -> refs/west/binutils-2_20-branch
 * [new branch]          binutils-2_21-branch        -> refs/west/binutils-2_21-branch
 * [new branch]          binutils-2_22-branch        -> refs/west/binutils-2_22-branch
 * [new branch]          binutils-2_22_branch        -> refs/west/binutils-2_22_branch
 * [new branch]          binutils-2_23-branch        -> refs/west/binutils-2_23-branch
 * [new branch]          binutils-2_24-branch        -> refs/west/binutils-2_24-branch
 * [new branch]          binutils-arc-20080908-branch -> refs/west/binutils-arc-20080908-branch
 * [new branch]          binutils-arc-20081103-branch -> refs/west/binutils-arc-20081103-branch
 * [new branch]          binutils-csl-2_17-branch    -> refs/west/binutils-csl-2_17-branch
 * [new branch]          binutils-csl-arm-2005q1-branch -> refs/west/binutils-csl-arm-2005q1-branch
 * [new branch]          binutils-csl-gxxpro-3_4-branch -> refs/west/binutils-csl-gxxpro-3_4-branch
 * [new branch]          branch-1.4.6                -> refs/west/branch-1.4.6
 * [new branch]          branch-1.8.4                -> refs/west/branch-1.8.4
 * [new branch]          c-sky                       -> refs/west/c-sky
 * [new branch]          cagney-unwind-20030108-branch -> refs/west/cagney-unwind-20030108-branch
 * [new branch]          cagney_bfdfile-20040213-branch -> refs/west/cagney_bfdfile-20040213-branch
 * [new branch]          cagney_bigcore-20040122-branch -> refs/west/cagney_bigcore-20040122-branch
 * [new branch]          cagney_convert-20030606-branch -> refs/west/cagney_convert-20030606-branch
 * [new branch]          cagney_fileio-20030521-branch -> refs/west/cagney_fileio-20030521-branch
 * [new branch]          cagney_frameaddr-20030403-branch -> refs/west/cagney_frameaddr-20030403-branch
 * [new branch]          cagney_framebase-20030326-branch -> refs/west/cagney_framebase-20030326-branch
 * [new branch]          cagney_lazyid-20030317-branch -> refs/west/cagney_lazyid-20030317-branch
 * [new branch]          cagney_offbyone-20030303-branch -> refs/west/cagney_offbyone-20030303-branch
 * [new branch]          cagney_regbuf-20020515-branch -> refs/west/cagney_regbuf-20020515-branch
 * [new branch]          cagney_sysregs-20020825-branch -> refs/west/cagney_sysregs-20020825-branch
 * [new branch]          cagney_tramp-20040309-branch -> refs/west/cagney_tramp-20040309-branch
 * [new branch]          cagney_writestrings-20030508-branch -> refs/west/cagney_writestrings-20030508-branch
 * [new branch]          cagney_x86i386-20030821-branch -> refs/west/cagney_x86i386-20030821-branch
 * [new branch]          callout                     -> refs/west/callout
 * [new branch]          carlton_dictionary-branch   -> refs/west/carlton_dictionary-branch
 * [new branch]          cgen-1_1-branch             -> refs/west/cgen-1_1-branch
 * [new branch]          cgf-deleteme                -> refs/west/cgf-deleteme
 * [new branch]          cgf-dev-branch              -> refs/west/cgf-dev-branch
 * [new branch]          cmake                       -> refs/west/cmake
 * [new branch]          cmake-no-tls                -> refs/west/cmake-no-tls
 * [new branch]          cmake-small-ultoa           -> refs/west/cmake-small-ultoa
 * [new branch]          cr-0x3b58                   -> refs/west/cr-0x3b58
 * [new branch]          cr-0x5e6                    -> refs/west/cr-0x5e6
 * [new branch]          cr-0x5ef                    -> refs/west/cr-0x5ef
 * [new branch]          cr-0x5f1                    -> refs/west/cr-0x5f1
 * [new branch]          cr-0x9b                     -> refs/west/cr-0x9b
 * [new branch]          cr-0x9c                     -> refs/west/cr-0x9c
 * [new branch]          cr-0x9d                     -> refs/west/cr-0x9d
 * [new branch]          cr-0x9e                     -> refs/west/cr-0x9e
 * [new branch]          csl-arm-20050325-branch     -> refs/west/csl-arm-20050325-branch
 * [new branch]          cv-branch                   -> refs/west/cv-branch
 * [new branch]          cv-branch-2                 -> refs/west/cv-branch-2
 * [new branch]          cv-post-1_7_9               -> refs/west/cv-post-1_7_9
 * [new branch]          cygnus                      -> refs/west/cygnus
 * [new branch]          cygwin-1-1-4                -> refs/west/cygwin-1-1-4
 * [new branch]          cygwin-1-3-1                -> refs/west/cygwin-1-3-1
 * [new branch]          cygwin-1-3-10-1             -> refs/west/cygwin-1-3-10-1
 * [new branch]          cygwin-1-3-11-3             -> refs/west/cygwin-1-3-11-3
 * [new branch]          cygwin-1-3-12-1             -> refs/west/cygwin-1-3-12-1
 * [new branch]          cygwin-1-3-13-1             -> refs/west/cygwin-1-3-13-1
 * [new branch]          cygwin-1-3-13-2             -> refs/west/cygwin-1-3-13-2
 * [new branch]          cygwin-1-3-14-1             -> refs/west/cygwin-1-3-14-1
 * [new branch]          cygwin-1-3-15-1             -> refs/west/cygwin-1-3-15-1
 * [new branch]          cygwin-1-3-16-1             -> refs/west/cygwin-1-3-16-1
 * [new branch]          cygwin-1-3-17-1             -> refs/west/cygwin-1-3-17-1
 * [new branch]          cygwin-1-3-18-1             -> refs/west/cygwin-1-3-18-1
 * [new branch]          cygwin-1-3-19-1             -> refs/west/cygwin-1-3-19-1
 * [new branch]          cygwin-1-3-2                -> refs/west/cygwin-1-3-2
 * [new branch]          cygwin-1-3-3                -> refs/west/cygwin-1-3-3
 * [new branch]          cygwin-1-3-4                -> refs/west/cygwin-1-3-4
 * [new branch]          cygwin-1-3-5                -> refs/west/cygwin-1-3-5
 * [new branch]          cygwin-1-3-5-2              -> refs/west/cygwin-1-3-5-2
 * [new branch]          cygwin-1-3-5-3              -> refs/west/cygwin-1-3-5-3
 * [new branch]          cygwin-1-3-6-1              -> refs/west/cygwin-1-3-6-1
 * [new branch]          cygwin-1-3-6-2              -> refs/west/cygwin-1-3-6-2
 * [new branch]          cygwin-1-3-6-3              -> refs/west/cygwin-1-3-6-3
 * [new branch]          cygwin-1-3-6-4              -> refs/west/cygwin-1-3-6-4
 * [new branch]          cygwin-1-3-6-5              -> refs/west/cygwin-1-3-6-5
 * [new branch]          cygwin-1-3-6-6              -> refs/west/cygwin-1-3-6-6
 * [new branch]          cygwin-1-3-7-1              -> refs/west/cygwin-1-3-7-1
 * [new branch]          cygwin-1-3-8-1              -> refs/west/cygwin-1-3-8-1
 * [new branch]          cygwin-1-3-9                -> refs/west/cygwin-1-3-9
 * [new branch]          cygwin-1_7_29-release-branchpoint -> refs/west/cygwin-1_7_29-release-branchpoint
 * [new branch]          cygwin-2.0                  -> refs/west/cygwin-2.0
 * [new branch]          cygwin-3_0-branch           -> refs/west/cygwin-3_0-branch
 * [new branch]          cygwin-64bit-branch         -> refs/west/cygwin-64bit-branch
 * [new branch]          cygwin-64bit-premerge-branch -> refs/west/cygwin-64bit-premerge-branch
 * [new branch]          cygwin-acl                  -> refs/west/cygwin-acl
 * [new branch]          cygwin_daemon               -> refs/west/cygwin_daemon
 * [new branch]          debian                      -> refs/west/debian
 * [new branch]          dje-cgen-play1-branch       -> refs/west/dje-cgen-play1-branch
 * [new branch]          docker-builder-packages.txt-hash -> refs/west/docker-builder-packages.txt-hash
 * [new branch]          drow-cplus-branch           -> refs/west/drow-cplus-branch
 * [new branch]          drow-reverse-20070409-branch -> refs/west/drow-reverse-20070409-branch
 * [new branch]          drow_intercu-20040221-branch -> refs/west/drow_intercu-20040221-branch
 * [new branch]          ezannoni_pie-20030916-branch -> refs/west/ezannoni_pie-20030916-branch
 * [new branch]          ezannoni_pie-20040323-branch -> refs/west/ezannoni_pie-20040323-branch
 * [new branch]          fifo_doover3                -> refs/west/fifo_doover3
 * [new branch]          fixes-newlib                -> refs/west/fixes-newlib
 * [new branch]          float-inlines               -> refs/west/float-inlines
 * [new branch]          fp-zeuch                    -> refs/west/fp-zeuch
 * [new branch]          gdb-csl-20060226-branch     -> refs/west/gdb-csl-20060226-branch
 * [new branch]          gdb-csl-arm-20051020-branch -> refs/west/gdb-csl-arm-20051020-branch
 * [new branch]          gdb-csl-available-20060303-branch -> refs/west/gdb-csl-available-20060303-branch
 * [new branch]          gdb-csl-gxxpro-6_3-branch   -> refs/west/gdb-csl-gxxpro-6_3-branch
 * [new branch]          gdb-csl-symbian-20060226-branch -> refs/west/gdb-csl-symbian-20060226-branch
 * [new branch]          gdb-premipsmulti-2000-06-06-branch -> refs/west/gdb-premipsmulti-2000-06-06-branch
 * [new branch]          gdb_5_0-2000-04-10-branch   -> refs/west/gdb_5_0-2000-04-10-branch
 * [new branch]          gdb_5_1-2001-07-29-branch   -> refs/west/gdb_5_1-2001-07-29-branch
 * [new branch]          gdb_5_1_0_1-2002-01-03-branch -> refs/west/gdb_5_1_0_1-2002-01-03-branch
 * [new branch]          gdb_5_2-branch              -> refs/west/gdb_5_2-branch
 * [new branch]          gdb_5_3-branch              -> refs/west/gdb_5_3-branch
 * [new branch]          gdb_6_0-branch              -> refs/west/gdb_6_0-branch
 * [new branch]          gdb_6_1-branch              -> refs/west/gdb_6_1-branch
 * [new branch]          gdb_6_2-branch              -> refs/west/gdb_6_2-branch
 * [new branch]          gdb_6_3-branch              -> refs/west/gdb_6_3-branch
 * [new branch]          gdb_6_4-branch              -> refs/west/gdb_6_4-branch
 * [new branch]          gdb_6_5-branch              -> refs/west/gdb_6_5-branch
 * [new branch]          gdb_6_6-branch              -> refs/west/gdb_6_6-branch
 * [new branch]          gdb_6_7-branch              -> refs/west/gdb_6_7-branch
 * [new branch]          gdb_6_8-branch              -> refs/west/gdb_6_8-branch
 * [new branch]          gdb_7_0-branch              -> refs/west/gdb_7_0-branch
 * [new branch]          gdb_7_1-branch              -> refs/west/gdb_7_1-branch
 * [new branch]          gdb_7_2-branch              -> refs/west/gdb_7_2-branch
 * [new branch]          gdb_7_3-branch              -> refs/west/gdb_7_3-branch
 * [new branch]          gdb_7_4-branch              -> refs/west/gdb_7_4-branch
 * [new branch]          gdb_7_5-branch              -> refs/west/gdb_7_5-branch
 * [new branch]          gdb_7_6-branch              -> refs/west/gdb_7_6-branch
 * [new branch]          gdb_s390-2001-09-26-branch  -> refs/west/gdb_s390-2001-09-26-branch
 * [new branch]          gh                          -> refs/west/gh
 * [new branch]          insight_6_8-branch          -> refs/west/insight_6_8-branch
 * [new branch]          interps-20030202-branch     -> refs/west/interps-20030202-branch
 * [new branch]          isblank-extern-inline       -> refs/west/isblank-extern-inline
 * [new branch]          jimb-gdb_6_2-e500-branch    -> refs/west/jimb-gdb_6_2-e500-branch
 * [new branch]          jimb-macro-020506-branch    -> refs/west/jimb-macro-020506-branch
 * [new branch]          jimb-ppc64-linux-20030509-branch -> refs/west/jimb-ppc64-linux-20030509-branch
 * [new branch]          jimb-ppc64-linux-20030528-branch -> refs/west/jimb-ppc64-linux-20030528-branch
 * [new branch]          jimb-ppc64-linux-20030613-branch -> refs/west/jimb-ppc64-linux-20030613-branch
 * [new branch]          jimb-rda-nptl-branch        -> refs/west/jimb-rda-nptl-branch
 * [new branch]          kettenis-i386newframe-20030308-branch -> refs/west/kettenis-i386newframe-20030308-branch
 * [new branch]          kettenis_i386newframe-20030406-branch -> refs/west/kettenis_i386newframe-20030406-branch
 * [new branch]          kettenis_i386newframe-20030419-branch -> refs/west/kettenis_i386newframe-20030419-branch
 * [new branch]          kettenis_sparc-20030918-branch -> refs/west/kettenis_sparc-20030918-branch
 * [new branch]          kseitz_interps-20020528-branch -> refs/west/kseitz_interps-20020528-branch
 * [new branch]          locking-docs                -> refs/west/locking-docs
 * [new branch]          mingw-std-ns-branch         -> refs/west/mingw-std-ns-branch
 * [new branch]          mingwex                     -> refs/west/mingwex
 * [new branch]          msnyder-checkpoint-072509-branch -> refs/west/msnyder-checkpoint-072509-branch
 * [new branch]          msnyder-fork-checkpoint-branch -> refs/west/msnyder-fork-checkpoint-branch
 * [new branch]          msnyder-reverse-20060331-branch -> refs/west/msnyder-reverse-20060331-branch
 * [new branch]          msnyder-reverse-20060502-branch -> refs/west/msnyder-reverse-20060502-branch
 * [new branch]          msnyder-reverse-20080609-branch -> refs/west/msnyder-reverse-20080609-branch
 * [new branch]          msnyder-tracepoint-checkpoint-branch -> refs/west/msnyder-tracepoint-checkpoint-branch
 * [new branch]          msp430                      -> refs/west/msp430
 * [new branch]          multiprocess-20081120-branch -> refs/west/multiprocess-20081120-branch
 * [new branch]          newlib                      -> refs/west/newlib
 * [new branch]          newlib-1_17_0-arc           -> refs/west/newlib-1_17_0-arc
 * [new branch]          newlib-autotools-branch     -> refs/west/newlib-autotools-branch
 * [new branch]          newlib-csl-20060320-branch  -> refs/west/newlib-csl-20060320-branch
 * [new branch]          nickrob-async-20060513-branch -> refs/west/nickrob-async-20060513-branch
 * [new branch]          non-linux-ln                -> refs/west/non-linux-ln
 * [new branch]          noreparent                  -> refs/west/noreparent
 * [new branch]          offbyone-20030313-branch    -> refs/west/offbyone-20030313-branch
 * [new branch]          pre-regex                   -> refs/west/pre-regex
 * [new branch]          pregp02r1                   -> refs/west/pregp02r1
 * [new branch]          readline_4_3-import-branch  -> refs/west/readline_4_3-import-branch
 * [new branch]          readline_5_1-import-branch  -> refs/west/readline_5_1-import-branch
 * [new branch]          reverse-20080717-branch     -> refs/west/reverse-20080717-branch
 * [new branch]          reverse-20080930-branch     -> refs/west/reverse-20080930-branch
 * [new branch]          reverse-20081226-branch     -> refs/west/reverse-20081226-branch
 * [new branch]          riscv-zicsr                 -> refs/west/riscv-zicsr
 * [new branch]          semihost-2.0-all            -> refs/west/semihost-2.0-all
 * [new branch]          sid-20020905-branch         -> refs/west/sid-20020905-branch
 * [new branch]          signal-rewrite              -> refs/west/signal-rewrite
 * [new branch]          sysroot-skip-checks         -> refs/west/sysroot-skip-checks
 * [new branch]          tcltk840-20020924-branch    -> refs/west/tcltk840-20020924-branch
 * [new branch]          tls                         -> refs/west/tls
 * [new branch]          topic/af_unix               -> refs/west/topic/af_unix
 * [new branch]          topic/ansification          -> refs/west/topic/ansification
 * [new branch]          topic/fifo                  -> refs/west/topic/fifo
 * [new branch]          topic/forkables             -> refs/west/topic/forkables
 * [new branch]          topic/locales               -> refs/west/topic/locales
 * [new branch]          topic/posix_acl_funcs       -> refs/west/topic/posix_acl_funcs
 * [new branch]          topic/ssp                   -> refs/west/topic/ssp
 * [new branch]          unlabeled-1.1.1.1.2         -> refs/west/unlabeled-1.1.1.1.2
 * [new branch]          unlabeled-1.100.2           -> refs/west/unlabeled-1.100.2
 * [new branch]          unlabeled-1.1010.2          -> refs/west/unlabeled-1.1010.2
 * [new branch]          unlabeled-1.1019.2          -> refs/west/unlabeled-1.1019.2
 * [new branch]          unlabeled-1.1042.2          -> refs/west/unlabeled-1.1042.2
 * [new branch]          unlabeled-1.1042.2.1.4      -> refs/west/unlabeled-1.1042.2.1.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4  -> refs/west/unlabeled-1.1042.2.1.4.2.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4.2.2 -> refs/west/unlabeled-1.1042.2.1.4.2.4.2.2
 * [new branch]          unlabeled-1.105.2           -> refs/west/unlabeled-1.105.2
 * [new branch]          unlabeled-1.106.2           -> refs/west/unlabeled-1.106.2
 * [new branch]          unlabeled-1.106.8           -> refs/west/unlabeled-1.106.8
 * [new branch]          unlabeled-1.107.12          -> refs/west/unlabeled-1.107.12
 * [new branch]          unlabeled-1.11.2            -> refs/west/unlabeled-1.11.2
 * [new branch]          unlabeled-1.112.4           -> refs/west/unlabeled-1.112.4
 * [new branch]          unlabeled-1.116.4           -> refs/west/unlabeled-1.116.4
 * [new branch]          unlabeled-1.12.20           -> refs/west/unlabeled-1.12.20
 * [new branch]          unlabeled-1.12.30           -> refs/west/unlabeled-1.12.30
 * [new branch]          unlabeled-1.12.4            -> refs/west/unlabeled-1.12.4
 * [new branch]          unlabeled-1.120.2           -> refs/west/unlabeled-1.120.2
 * [new branch]          unlabeled-1.125.2           -> refs/west/unlabeled-1.125.2
 * [new branch]          unlabeled-1.13.10           -> refs/west/unlabeled-1.13.10
 * [new branch]          unlabeled-1.13.2            -> refs/west/unlabeled-1.13.2
 * [new branch]          unlabeled-1.13.30           -> refs/west/unlabeled-1.13.30
 * [new branch]          unlabeled-1.13.4            -> refs/west/unlabeled-1.13.4
 * [new branch]          unlabeled-1.133.2           -> refs/west/unlabeled-1.133.2
 * [new branch]          unlabeled-1.134.4           -> refs/west/unlabeled-1.134.4
 * [new branch]          unlabeled-1.135.4           -> refs/west/unlabeled-1.135.4
 * [new branch]          unlabeled-1.1370.2          -> refs/west/unlabeled-1.1370.2
 * [new branch]          unlabeled-1.142.2           -> refs/west/unlabeled-1.142.2
 * [new branch]          unlabeled-1.143.4           -> refs/west/unlabeled-1.143.4
 * [new branch]          unlabeled-1.144.2           -> refs/west/unlabeled-1.144.2
 * [new branch]          unlabeled-1.15.10           -> refs/west/unlabeled-1.15.10
 * [new branch]          unlabeled-1.15.2            -> refs/west/unlabeled-1.15.2
 * [new branch]          unlabeled-1.1527.4          -> refs/west/unlabeled-1.1527.4
 * [new branch]          unlabeled-1.153.2           -> refs/west/unlabeled-1.153.2
 * [new branch]          unlabeled-1.1563.2          -> refs/west/unlabeled-1.1563.2
 * [new branch]          unlabeled-1.1656.2          -> refs/west/unlabeled-1.1656.2
 * [new branch]          unlabeled-1.167.4           -> refs/west/unlabeled-1.167.4
 * [new branch]          unlabeled-1.17.2            -> refs/west/unlabeled-1.17.2
 * [new branch]          unlabeled-1.17.4            -> refs/west/unlabeled-1.17.4
 * [new branch]          unlabeled-1.1710.2          -> refs/west/unlabeled-1.1710.2
 * [new branch]          unlabeled-1.172.4           -> refs/west/unlabeled-1.172.4
 * [new branch]          unlabeled-1.18.10           -> refs/west/unlabeled-1.18.10
 * [new branch]          unlabeled-1.18.2            -> refs/west/unlabeled-1.18.2
 * [new branch]          unlabeled-1.1806.2          -> refs/west/unlabeled-1.1806.2
 * [new branch]          unlabeled-1.1856.2          -> refs/west/unlabeled-1.1856.2
 * [new branch]          unlabeled-1.188.2           -> refs/west/unlabeled-1.188.2
 * [new branch]          unlabeled-1.188.2.1.8       -> refs/west/unlabeled-1.188.2.1.8
 * [new branch]          unlabeled-1.188.2.1.8.2.2   -> refs/west/unlabeled-1.188.2.1.8.2.2
 * [new branch]          unlabeled-1.19.12           -> refs/west/unlabeled-1.19.12
 * [new branch]          unlabeled-1.2.2             -> refs/west/unlabeled-1.2.2
 * [new branch]          unlabeled-1.20.4            -> refs/west/unlabeled-1.20.4
 * [new branch]          unlabeled-1.21.2            -> refs/west/unlabeled-1.21.2
 * [new branch]          unlabeled-1.21.4            -> refs/west/unlabeled-1.21.4
 * [new branch]          unlabeled-1.22.2            -> refs/west/unlabeled-1.22.2
 * [new branch]          unlabeled-1.22.4            -> refs/west/unlabeled-1.22.4
 * [new branch]          unlabeled-1.226.2           -> refs/west/unlabeled-1.226.2
 * [new branch]          unlabeled-1.23.16           -> refs/west/unlabeled-1.23.16
 * [new branch]          unlabeled-1.23.2            -> refs/west/unlabeled-1.23.2
 * [new branch]          unlabeled-1.23.4            -> refs/west/unlabeled-1.23.4
 * [new branch]          unlabeled-1.231.4           -> refs/west/unlabeled-1.231.4
 * [new branch]          unlabeled-1.234.16          -> refs/west/unlabeled-1.234.16
 * [new branch]          unlabeled-1.235.2           -> refs/west/unlabeled-1.235.2
 * [new branch]          unlabeled-1.238.4           -> refs/west/unlabeled-1.238.4
 * [new branch]          unlabeled-1.24.16           -> refs/west/unlabeled-1.24.16
 * [new branch]          unlabeled-1.24.2            -> refs/west/unlabeled-1.24.2
 * [new branch]          unlabeled-1.24.4            -> refs/west/unlabeled-1.24.4
 * [new branch]          unlabeled-1.248.2           -> refs/west/unlabeled-1.248.2
 * [new branch]          unlabeled-1.253.2           -> refs/west/unlabeled-1.253.2
 * [new branch]          unlabeled-1.27.12           -> refs/west/unlabeled-1.27.12
 * [new branch]          unlabeled-1.27.8            -> refs/west/unlabeled-1.27.8
 * [new branch]          unlabeled-1.30.4            -> refs/west/unlabeled-1.30.4
 * [new branch]          unlabeled-1.31.4            -> refs/west/unlabeled-1.31.4
 * [new branch]          unlabeled-1.32.16           -> refs/west/unlabeled-1.32.16
 * [new branch]          unlabeled-1.32.2            -> refs/west/unlabeled-1.32.2
 * [new branch]          unlabeled-1.35.12           -> refs/west/unlabeled-1.35.12
 * [new branch]          unlabeled-1.38.4            -> refs/west/unlabeled-1.38.4
 * [new branch]          unlabeled-1.39.2            -> refs/west/unlabeled-1.39.2
 * [new branch]          unlabeled-1.44.2            -> refs/west/unlabeled-1.44.2
 * [new branch]          unlabeled-1.44.4            -> refs/west/unlabeled-1.44.4
 * [new branch]          unlabeled-1.45.2            -> refs/west/unlabeled-1.45.2
 * [new branch]          unlabeled-1.45.8            -> refs/west/unlabeled-1.45.8
 * [new branch]          unlabeled-1.46.4            -> refs/west/unlabeled-1.46.4
 * [new branch]          unlabeled-1.48.16           -> refs/west/unlabeled-1.48.16
 * [new branch]          unlabeled-1.5.16            -> refs/west/unlabeled-1.5.16
 * [new branch]          unlabeled-1.5.2             -> refs/west/unlabeled-1.5.2
 * [new branch]          unlabeled-1.50.2            -> refs/west/unlabeled-1.50.2
 * [new branch]          unlabeled-1.50.6            -> refs/west/unlabeled-1.50.6
 * [new branch]          unlabeled-1.52.2            -> refs/west/unlabeled-1.52.2
 * [new branch]          unlabeled-1.53.6            -> refs/west/unlabeled-1.53.6
 * [new branch]          unlabeled-1.54.4            -> refs/west/unlabeled-1.54.4
 * [new branch]          unlabeled-1.64.2            -> refs/west/unlabeled-1.64.2
 * [new branch]          unlabeled-1.65.12           -> refs/west/unlabeled-1.65.12
 * [new branch]          unlabeled-1.65.4            -> refs/west/unlabeled-1.65.4
 * [new branch]          unlabeled-1.66.2            -> refs/west/unlabeled-1.66.2
 * [new branch]          unlabeled-1.69.4            -> refs/west/unlabeled-1.69.4
 * [new branch]          unlabeled-1.74.4            -> refs/west/unlabeled-1.74.4
 * [new branch]          unlabeled-1.75.4            -> refs/west/unlabeled-1.75.4
 * [new branch]          unlabeled-1.8.2             -> refs/west/unlabeled-1.8.2
 * [new branch]          unlabeled-1.81.2            -> refs/west/unlabeled-1.81.2
 * [new branch]          unlabeled-1.83.4            -> refs/west/unlabeled-1.83.4
 * [new branch]          unlabeled-1.86.2            -> refs/west/unlabeled-1.86.2
 * [new branch]          unlabeled-1.88.2            -> refs/west/unlabeled-1.88.2
 * [new branch]          unlabeled-1.90.2            -> refs/west/unlabeled-1.90.2
 * [new branch]          unlabeled-1.90.2.1.4        -> refs/west/unlabeled-1.90.2.1.4
 * [new branch]          unlabeled-1.93.2            -> refs/west/unlabeled-1.93.2
 * [new branch]          vendor                      -> refs/west/vendor
 * [new branch]          x86-more-32                 -> refs/west/x86-more-32
 * [new branch]          zephyr-add-library          -> refs/west/zephyr-add-library
 * [new branch]          zephyr-deprecated           -> refs/west/zephyr-deprecated
 * [new branch]          zephyr-hacks                -> refs/west/zephyr-hacks
 * [new branch]          zephyr-no-posix-define      -> refs/west/zephyr-no-posix-define
 * [new branch]          zephyr-posix                -> refs/west/zephyr-posix
 * [new branch]          zephyr-source               -> refs/west/zephyr-source
 * [new tag]             1.0                         -> 1.0
 * [new tag]             1.0-1                       -> 1.0-1
 * [new tag]             1.1                         -> 1.1
 * [new tag]             1.1-1                       -> 1.1-1
 * [new tag]             1.1-2                       -> 1.1-2
 * [new tag]             1.1.1-1                     -> 1.1.1-1
 * [new tag]             1.2                         -> 1.2
 * [new tag]             1.2-1                       -> 1.2-1
 * [new tag]             1.2.1-1                     -> 1.2.1-1
 * [new tag]             1.3                         -> 1.3
 * [new tag]             1.3-1                       -> 1.3-1
 * [new tag]             1.4                         -> 1.4
 * [new tag]             1.4-1                       -> 1.4-1
 * [new tag]             1.4.1-1                     -> 1.4.1-1
 * [new tag]             1.4.1-2                     -> 1.4.1-2
 * [new tag]             1.4.2-1                     -> 1.4.2-1
 * [new tag]             1.4.2-2                     -> 1.4.2-2
 * [new tag]             1.4.2-3                     -> 1.4.2-3
 * [new tag]             1.4.3-1                     -> 1.4.3-1
 * [new tag]             1.4.4-1                     -> 1.4.4-1
 * [new tag]             1.4.5                       -> 1.4.5
 * [new tag]             1.4.5-1                     -> 1.4.5-1
 * [new tag]             1.4.6                       -> 1.4.6
 * [new tag]             1.4.6-1                     -> 1.4.6-1
 * [new tag]             1.4.7                       -> 1.4.7
 * [new tag]             1.4.7-1                     -> 1.4.7-1
 * [new tag]             1.4.7-2                     -> 1.4.7-2
 * [new tag]             1.5                         -> 1.5
 * [new tag]             1.5-1                       -> 1.5-1
 * [new tag]             1.5.1-1                     -> 1.5.1-1
 * [new tag]             1.5.1-2                     -> 1.5.1-2
 * [new tag]             1.6                         -> 1.6
 * [new tag]             1.6-1                       -> 1.6-1
 * [new tag]             1.6.1-1                     -> 1.6.1-1
 * [new tag]             1.6.2-1                     -> 1.6.2-1
 * [new tag]             1.7                         -> 1.7
 * [new tag]             1.7-1                       -> 1.7-1
 * [new tag]             1.7.1-1                     -> 1.7.1-1
 * [new tag]             1.7.2-1                     -> 1.7.2-1
 * [new tag]             1.7.2-2                     -> 1.7.2-2
 * [new tag]             1.7.3-1                     -> 1.7.3-1
 * [new tag]             1.7.3-2                     -> 1.7.3-2
 * [new tag]             1.7.4-1                     -> 1.7.4-1
 * [new tag]             1.7.5-1                     -> 1.7.5-1
 * [new tag]             1.7.6-1                     -> 1.7.6-1
 * [new tag]             1.7.8                       -> 1.7.8
 * [new tag]             1.7.9                       -> 1.7.9
 * [new tag]             1.8.2                       -> 1.8.2
 * [new tag]             1.8.2-1                     -> 1.8.2-1
 * [new tag]             1.8.4                       -> 1.8.4
 * [new tag]             1.8.6                       -> 1.8.6
 * [new tag]             3.1.0.2019.08.08            -> 3.1.0.2019.08.08
 * [new tag]             3.1.0.2019.08.08-1          -> 3.1.0.2019.08.08-1
 * [new tag]             3.1.0.2019.08.14            -> 3.1.0.2019.08.14
 * [new tag]             3.1.0.2019.08.14-1          -> 3.1.0.2019.08.14-1
 * [new tag]             EOL_registry_mounts         -> EOL_registry_mounts
 * [new tag]             Z-cygwin_daemon_merge-new_HEAD -> Z-cygwin_daemon_merge-new_HEAD
 * [new tag]             Z-cygwin_daemon_merge_HEAD  -> Z-cygwin_daemon_merge_HEAD
 * [new tag]             after-mmap-privanon-noreserve -> after-mmap-privanon-noreserve
 * [new tag]             after-mmap-revamp           -> after-mmap-revamp
 * [new tag]             arc-20081103-branchpoint    -> arc-20081103-branchpoint
 * [new tag]             arc-insight_6_8-branchpoint -> arc-insight_6_8-branchpoint
 * [new tag]             arc-sim-20090309            -> arc-sim-20090309
 * [new tag]             before-mmap-revamp          -> before-mmap-revamp
 * [new tag]             binu_ss_19990502            -> binu_ss_19990502
 * [new tag]             binu_ss_19990602            -> binu_ss_19990602
 * [new tag]             binu_ss_19990721            -> binu_ss_19990721
 * [new tag]             binutils-2_10               -> binutils-2_10
 * [new tag]             binutils-2_10-branchpoint   -> binutils-2_10-branchpoint
 * [new tag]             binutils-2_10_1             -> binutils-2_10_1
 * [new tag]             binutils-2_11               -> binutils-2_11
 * [new tag]             binutils-2_11_1             -> binutils-2_11_1
 * [new tag]             binutils-2_11_2             -> binutils-2_11_2
 * [new tag]             binutils-2_12               -> binutils-2_12
 * [new tag]             binutils-2_12-branchpoint   -> binutils-2_12-branchpoint
 * [new tag]             binutils-2_12_1             -> binutils-2_12_1
 * [new tag]             binutils-2_13               -> binutils-2_13
 * [new tag]             binutils-2_13-branchpoint   -> binutils-2_13-branchpoint
 * [new tag]             binutils-2_13_1             -> binutils-2_13_1
 * [new tag]             binutils-2_13_2             -> binutils-2_13_2
 * [new tag]             binutils-2_13_2_1           -> binutils-2_13_2_1
 * [new tag]             binutils-2_14               -> binutils-2_14
 * [new tag]             binutils-2_14-branchpoint   -> binutils-2_14-branchpoint
 * [new tag]             binutils-2_15               -> binutils-2_15
 * [new tag]             binutils-2_15-branchpoint   -> binutils-2_15-branchpoint
 * [new tag]             binutils-2_16               -> binutils-2_16
 * [new tag]             binutils-2_16-branchpoint   -> binutils-2_16-branchpoint
 * [new tag]             binutils-2_16_1             -> binutils-2_16_1
 * [new tag]             binutils-2_17               -> binutils-2_17
 * [new tag]             binutils-2_17-branchpoint   -> binutils-2_17-branchpoint
 * [new tag]             binutils-2_18               -> binutils-2_18
 * [new tag]             binutils-2_18-branchpoint   -> binutils-2_18-branchpoint
 * [new tag]             binutils-2_19               -> binutils-2_19
 * [new tag]             binutils-2_19-branchpoint   -> binutils-2_19-branchpoint
 * [new tag]             binutils-2_19_1             -> binutils-2_19_1
 * [new tag]             binutils-2_20               -> binutils-2_20
 * [new tag]             binutils-2_20-branchpoint   -> binutils-2_20-branchpoint
 * [new tag]             binutils-2_20_1             -> binutils-2_20_1
 * [new tag]             binutils-2_21               -> binutils-2_21
 * [new tag]             binutils-2_21-branchpoint   -> binutils-2_21-branchpoint
 * [new tag]             binutils-2_21_1             -> binutils-2_21_1
 * [new tag]             binutils-2_22               -> binutils-2_22
 * [new tag]             binutils-2_22-branchpoint   -> binutils-2_22-branchpoint
 * [new tag]             binutils-2_23               -> binutils-2_23
 * [new tag]             binutils-2_23-branchpoint   -> binutils-2_23-branchpoint
 * [new tag]             binutils-2_23_1             -> binutils-2_23_1
 * [new tag]             binutils-2_23_2             -> binutils-2_23_2
 * [new tag]             binutils-2_24-branchpoint   -> binutils-2_24-branchpoint
 * [new tag]             binutils-arc-20080908-branchpoint -> binutils-arc-20080908-branchpoint
 * [new tag]             binutils-arc-20081103-branchpoint -> binutils-arc-20081103-branchpoint
 * [new tag]             binutils-csl-2_17-branchpoint -> binutils-csl-2_17-branchpoint
 * [new tag]             binutils-csl-arm-2005q1-branchpoint -> binutils-csl-arm-2005q1-branchpoint
 * [new tag]             binutils-csl-arm-2005q1a    -> binutils-csl-arm-2005q1a
 * [new tag]             binutils-csl-arm-2005q1b    -> binutils-csl-arm-2005q1b
 * [new tag]             binutils-csl-arm-2006q1-6   -> binutils-csl-arm-2006q1-6
 * [new tag]             binutils-csl-arm-2006q3-19  -> binutils-csl-arm-2006q3-19
 * [new tag]             binutils-csl-arm-2006q3-21  -> binutils-csl-arm-2006q3-21
 * [new tag]             binutils-csl-arm-2006q3-26  -> binutils-csl-arm-2006q3-26
 * [new tag]             binutils-csl-arm-2006q3-27  -> binutils-csl-arm-2006q3-27
 * [new tag]             binutils-csl-coldfire-4_1-10 -> binutils-csl-coldfire-4_1-10
 * [new tag]             binutils-csl-coldfire-4_1-11 -> binutils-csl-coldfire-4_1-11
 * [new tag]             binutils-csl-coldfire-4_1-28 -> binutils-csl-coldfire-4_1-28
 * [new tag]             binutils-csl-coldfire-4_1-30 -> binutils-csl-coldfire-4_1-30
 * [new tag]             binutils-csl-coldfire-4_1-32 -> binutils-csl-coldfire-4_1-32
 * [new tag]             binutils-csl-gxxpro-3_4-branchpoint -> binutils-csl-gxxpro-3_4-branchpoint
 * [new tag]             binutils-csl-innovasic-fido-3_4_4-33 -> binutils-csl-innovasic-fido-3_4_4-33
 * [new tag]             binutils-csl-morpho-4_1-4   -> binutils-csl-morpho-4_1-4
 * [new tag]             binutils-csl-palmsource-arm-prelinker-1_0-1 -> binutils-csl-palmsource-arm-prelinker-1_0-1
 * [new tag]             binutils-csl-renesas-4_1-6  -> binutils-csl-renesas-4_1-6
 * [new tag]             binutils-csl-renesas-4_1-7  -> binutils-csl-renesas-4_1-7
 * [new tag]             binutils-csl-renesas-4_1-8  -> binutils-csl-renesas-4_1-8
 * [new tag]             binutils-csl-renesas-4_1-9  -> binutils-csl-renesas-4_1-9
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-17 -> binutils-csl-sourcerygxx-3_4_4-17
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-19 -> binutils-csl-sourcerygxx-3_4_4-19
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-21 -> binutils-csl-sourcerygxx-3_4_4-21
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-25 -> binutils-csl-sourcerygxx-3_4_4-25
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-32 -> binutils-csl-sourcerygxx-3_4_4-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-12 -> binutils-csl-sourcerygxx-4_1-12
 * [new tag]             binutils-csl-sourcerygxx-4_1-13 -> binutils-csl-sourcerygxx-4_1-13
 * [new tag]             binutils-csl-sourcerygxx-4_1-14 -> binutils-csl-sourcerygxx-4_1-14
 * [new tag]             binutils-csl-sourcerygxx-4_1-15 -> binutils-csl-sourcerygxx-4_1-15
 * [new tag]             binutils-csl-sourcerygxx-4_1-17 -> binutils-csl-sourcerygxx-4_1-17
 * [new tag]             binutils-csl-sourcerygxx-4_1-18 -> binutils-csl-sourcerygxx-4_1-18
 * [new tag]             binutils-csl-sourcerygxx-4_1-19 -> binutils-csl-sourcerygxx-4_1-19
 * [new tag]             binutils-csl-sourcerygxx-4_1-20 -> binutils-csl-sourcerygxx-4_1-20
 * [new tag]             binutils-csl-sourcerygxx-4_1-21 -> binutils-csl-sourcerygxx-4_1-21
 * [new tag]             binutils-csl-sourcerygxx-4_1-22 -> binutils-csl-sourcerygxx-4_1-22
 * [new tag]             binutils-csl-sourcerygxx-4_1-23 -> binutils-csl-sourcerygxx-4_1-23
 * [new tag]             binutils-csl-sourcerygxx-4_1-24 -> binutils-csl-sourcerygxx-4_1-24
 * [new tag]             binutils-csl-sourcerygxx-4_1-25 -> binutils-csl-sourcerygxx-4_1-25
 * [new tag]             binutils-csl-sourcerygxx-4_1-26 -> binutils-csl-sourcerygxx-4_1-26
 * [new tag]             binutils-csl-sourcerygxx-4_1-27 -> binutils-csl-sourcerygxx-4_1-27
 * [new tag]             binutils-csl-sourcerygxx-4_1-28 -> binutils-csl-sourcerygxx-4_1-28
 * [new tag]             binutils-csl-sourcerygxx-4_1-29 -> binutils-csl-sourcerygxx-4_1-29
 * [new tag]             binutils-csl-sourcerygxx-4_1-30 -> binutils-csl-sourcerygxx-4_1-30
 * [new tag]             binutils-csl-sourcerygxx-4_1-32 -> binutils-csl-sourcerygxx-4_1-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-4 -> binutils-csl-sourcerygxx-4_1-4
 * [new tag]             binutils-csl-sourcerygxx-4_1-5 -> binutils-csl-sourcerygxx-4_1-5
 * [new tag]             binutils-csl-sourcerygxx-4_1-6 -> binutils-csl-sourcerygxx-4_1-6
 * [new tag]             binutils-csl-sourcerygxx-4_1-7 -> binutils-csl-sourcerygxx-4_1-7
 * [new tag]             binutils-csl-sourcerygxx-4_1-8 -> binutils-csl-sourcerygxx-4_1-8
 * [new tag]             binutils-csl-sourcerygxx-4_1-9 -> binutils-csl-sourcerygxx-4_1-9
 * [new tag]             binutils-csl-wrs-linux-3_4_4-20 -> binutils-csl-wrs-linux-3_4_4-20
 * [new tag]             binutils-csl-wrs-linux-3_4_4-21 -> binutils-csl-wrs-linux-3_4_4-21
 * [new tag]             binutils-csl-wrs-linux-3_4_4-22 -> binutils-csl-wrs-linux-3_4_4-22
 * [new tag]             binutils-csl-wrs-linux-3_4_4-23 -> binutils-csl-wrs-linux-3_4_4-23
 * [new tag]             binutils-csl-wrs-linux-3_4_4-24 -> binutils-csl-wrs-linux-3_4_4-24
 * [new tag]             binutils_latest_snapshot    -> binutils_latest_snapshot
 * [new tag]             cagney-unwind-20030108-branchpoint -> cagney-unwind-20030108-branchpoint
 * [new tag]             cagney_bfdfile-20040213-branchpoint -> cagney_bfdfile-20040213-branchpoint
 * [new tag]             cagney_bigcore-20040122-branchpoint -> cagney_bigcore-20040122-branchpoint
 * [new tag]             cagney_convert-20030606-branchpoint -> cagney_convert-20030606-branchpoint
 * [new tag]             cagney_fileio-20030521-branchpoint -> cagney_fileio-20030521-branchpoint
 * [new tag]             cagney_frameaddr-20030403-branchpoint -> cagney_frameaddr-20030403-branchpoint
 * [new tag]             cagney_frameaddr-20030409-mergepoint -> cagney_frameaddr-20030409-mergepoint
 * [new tag]             cagney_framebase-20030326-branchpoint -> cagney_framebase-20030326-branchpoint
 * [new tag]             cagney_framebase-20030330-mergepoint -> cagney_framebase-20030330-mergepoint
 * [new tag]             cagney_lazyid-20030317-branchpoint -> cagney_lazyid-20030317-branchpoint
 * [new tag]             cagney_offbyone-20030303-branchpoint -> cagney_offbyone-20030303-branchpoint
 * [new tag]             cagney_regbuf-20020515-branchpoint -> cagney_regbuf-20020515-branchpoint
 * [new tag]             cagney_sysregs-20020825-branchpoint -> cagney_sysregs-20020825-branchpoint
 * [new tag]             cagney_tramp-20040309-branchpoint -> cagney_tramp-20040309-branchpoint
 * [new tag]             cagney_tramp-20040321-mergepoint -> cagney_tramp-20040321-mergepoint
 * [new tag]             cagney_writestrings-20030508-branchpoint -> cagney_writestrings-20030508-branchpoint
 * [new tag]             cagney_x86i386-20030821-branchpoint -> cagney_x86i386-20030821-branchpoint
 * [new tag]             carlton-dictionary-20031111-merge -> carlton-dictionary-20031111-merge
 * [new tag]             carlton_dictionary-20020920-branchpoint -> carlton_dictionary-20020920-branchpoint
 * [new tag]             carlton_dictionary-20020927-merge -> carlton_dictionary-20020927-merge
 * [new tag]             carlton_dictionary-20021011-merge -> carlton_dictionary-20021011-merge
 * [new tag]             carlton_dictionary-20021025-merge -> carlton_dictionary-20021025-merge
 * [new tag]             carlton_dictionary-20021115-merge -> carlton_dictionary-20021115-merge
 * [new tag]             carlton_dictionary-20021223-merge -> carlton_dictionary-20021223-merge
 * [new tag]             carlton_dictionary-20030207-merge -> carlton_dictionary-20030207-merge
 * [new tag]             carlton_dictionary-20030305-merge -> carlton_dictionary-20030305-merge
 * [new tag]             carlton_dictionary-20030416-merge -> carlton_dictionary-20030416-merge
 * [new tag]             carlton_dictionary-20030430-merge -> carlton_dictionary-20030430-merge
 * [new tag]             carlton_dictionary-20030523-merge -> carlton_dictionary-20030523-merge
 * [new tag]             carlton_dictionary-20030627-merge -> carlton_dictionary-20030627-merge
 * [new tag]             carlton_dictionary-20030805-merge -> carlton_dictionary-20030805-merge
 * [new tag]             carlton_dictionary-20030917-merge -> carlton_dictionary-20030917-merge
 * [new tag]             carlton_dictionary-20031215-merge -> carlton_dictionary-20031215-merge
 * [new tag]             carlton_dictionary-20040126-merge -> carlton_dictionary-20040126-merge
 * [new tag]             cgen-1_1-branchpoint        -> cgen-1_1-branchpoint
 * [new tag]             cgen-snapshot-20071001      -> cgen-snapshot-20071001
 * [new tag]             cgen-snapshot-20071101      -> cgen-snapshot-20071101
 * [new tag]             cgen-snapshot-20071201      -> cgen-snapshot-20071201
 * [new tag]             cgen-snapshot-20080101      -> cgen-snapshot-20080101
 * [new tag]             cgen-snapshot-20080201      -> cgen-snapshot-20080201
 * [new tag]             cgen-snapshot-20080301      -> cgen-snapshot-20080301
 * [new tag]             cgen-snapshot-20080401      -> cgen-snapshot-20080401
 * [new tag]             cgen-snapshot-20080501      -> cgen-snapshot-20080501
 * [new tag]             cgen-snapshot-20080601      -> cgen-snapshot-20080601
 * [new tag]             cgen-snapshot-20080701      -> cgen-snapshot-20080701
 * [new tag]             cgen-snapshot-20080801      -> cgen-snapshot-20080801
 * [new tag]             cgen-snapshot-20080901      -> cgen-snapshot-20080901
 * [new tag]             cgen-snapshot-20081001      -> cgen-snapshot-20081001
 * [new tag]             cgen-snapshot-20081101      -> cgen-snapshot-20081101
 * [new tag]             cgen-snapshot-20081201      -> cgen-snapshot-20081201
 * [new tag]             cgen-snapshot-20090101      -> cgen-snapshot-20090101
 * [new tag]             cgen-snapshot-20090201      -> cgen-snapshot-20090201
 * [new tag]             cgen-snapshot-20090301      -> cgen-snapshot-20090301
 * [new tag]             cgen-snapshot-20090401      -> cgen-snapshot-20090401
 * [new tag]             cgen-snapshot-20090501      -> cgen-snapshot-20090501
 * [new tag]             cgen-snapshot-20090601      -> cgen-snapshot-20090601
 * [new tag]             cgen-snapshot-20090701      -> cgen-snapshot-20090701
 * [new tag]             cgen-snapshot-20090801      -> cgen-snapshot-20090801
 * [new tag]             cgen-snapshot-20090901      -> cgen-snapshot-20090901
 * [new tag]             cgen-snapshot-20091001      -> cgen-snapshot-20091001
 * [new tag]             cgen-snapshot-20091101      -> cgen-snapshot-20091101
 * [new tag]             cgen-snapshot-20091201      -> cgen-snapshot-20091201
 * [new tag]             cgen-snapshot-20100101      -> cgen-snapshot-20100101
 * [new tag]             cgen-snapshot-20100201      -> cgen-snapshot-20100201
 * [new tag]             cgen-snapshot-20100301      -> cgen-snapshot-20100301
 * [new tag]             cgen-snapshot-20100401      -> cgen-snapshot-20100401
 * [new tag]             cgen-snapshot-20100501      -> cgen-snapshot-20100501
 * [new tag]             cgen-snapshot-20100601      -> cgen-snapshot-20100601
 * [new tag]             cgen-snapshot-20100701      -> cgen-snapshot-20100701
 * [new tag]             cgen-snapshot-20100801      -> cgen-snapshot-20100801
 * [new tag]             cgen-snapshot-20100901      -> cgen-snapshot-20100901
 * [new tag]             cgen-snapshot-20101001      -> cgen-snapshot-20101001
 * [new tag]             cgen-snapshot-20101101      -> cgen-snapshot-20101101
 * [new tag]             cgen-snapshot-20101201      -> cgen-snapshot-20101201
 * [new tag]             cgen-snapshot-20110101      -> cgen-snapshot-20110101
 * [new tag]             cgen-snapshot-20110201      -> cgen-snapshot-20110201
 * [new tag]             cgen-snapshot-20110301      -> cgen-snapshot-20110301
 * [new tag]             cgen-snapshot-20110401      -> cgen-snapshot-20110401
 * [new tag]             cgen-snapshot-20110501      -> cgen-snapshot-20110501
 * [new tag]             cgen-snapshot-20110601      -> cgen-snapshot-20110601
 * [new tag]             cgen-snapshot-20110701      -> cgen-snapshot-20110701
 * [new tag]             cgen-snapshot-20110801      -> cgen-snapshot-20110801
 * [new tag]             cgen-snapshot-20110901      -> cgen-snapshot-20110901
 * [new tag]             cgen-snapshot-20111001      -> cgen-snapshot-20111001
 * [new tag]             cgen-snapshot-20111101      -> cgen-snapshot-20111101
 * [new tag]             cgen-snapshot-20111201      -> cgen-snapshot-20111201
 * [new tag]             cgen-snapshot-20120101      -> cgen-snapshot-20120101
 * [new tag]             cgen-snapshot-20120201      -> cgen-snapshot-20120201
 * [new tag]             cgen-snapshot-20120301      -> cgen-snapshot-20120301
 * [new tag]             cgen-snapshot-20120401      -> cgen-snapshot-20120401
 * [new tag]             cgen-snapshot-20120501      -> cgen-snapshot-20120501
 * [new tag]             cgen-snapshot-20120601      -> cgen-snapshot-20120601
 * [new tag]             cgen-snapshot-20120701      -> cgen-snapshot-20120701
 * [new tag]             cgen-snapshot-20120801      -> cgen-snapshot-20120801
 * [new tag]             cgen-snapshot-20120901      -> cgen-snapshot-20120901
 * [new tag]             cgen-snapshot-20121001      -> cgen-snapshot-20121001
 * [new tag]             cgen-snapshot-20121101      -> cgen-snapshot-20121101
 * [new tag]             cgen-snapshot-20121201      -> cgen-snapshot-20121201
 * [new tag]             cgen-snapshot-20130101      -> cgen-snapshot-20130101
 * [new tag]             cgen-snapshot-20130201      -> cgen-snapshot-20130201
 * [new tag]             cgen-snapshot-20130301      -> cgen-snapshot-20130301
 * [new tag]             cgen-snapshot-20130401      -> cgen-snapshot-20130401
 * [new tag]             cgen-snapshot-20130501      -> cgen-snapshot-20130501
 * [new tag]             cgen-snapshot-20130601      -> cgen-snapshot-20130601
 * [new tag]             cgen-snapshot-20130701      -> cgen-snapshot-20130701
 * [new tag]             cgen-snapshot-20130801      -> cgen-snapshot-20130801
 * [new tag]             cgen-snapshot-20130901      -> cgen-snapshot-20130901
 * [new tag]             cgen-snapshot-20131001      -> cgen-snapshot-20131001
 * [new tag]             cgen-snapshot-20131101      -> cgen-snapshot-20131101
 * [new tag]             cgen-snapshot-20131201      -> cgen-snapshot-20131201
 * [new tag]             cgen-snapshot-20140101      -> cgen-snapshot-20140101
 * [new tag]             cgen-snapshot-20140201      -> cgen-snapshot-20140201
 * [new tag]             cgen-snapshot-20140301      -> cgen-snapshot-20140301
 * [new tag]             cgen-snapshot-20140401      -> cgen-snapshot-20140401
 * [new tag]             cgen-snapshot-20140501      -> cgen-snapshot-20140501
 * [new tag]             cgen-snapshot-20140601      -> cgen-snapshot-20140601
 * [new tag]             cgen-snapshot-20140701      -> cgen-snapshot-20140701
 * [new tag]             cgen-snapshot-20140801      -> cgen-snapshot-20140801
 * [new tag]             cgen-snapshot-20140901      -> cgen-snapshot-20140901
 * [new tag]             cgen-snapshot-20141001      -> cgen-snapshot-20141001
 * [new tag]             cgen-snapshot-20141101      -> cgen-snapshot-20141101
 * [new tag]             cgen-snapshot-20141201      -> cgen-snapshot-20141201
 * [new tag]             cgen-snapshot-20150101      -> cgen-snapshot-20150101
 * [new tag]             cgen-snapshot-20150201      -> cgen-snapshot-20150201
 * [new tag]             cgen-snapshot-20150301      -> cgen-snapshot-20150301
 * [new tag]             cgf-more-exit-sync          -> cgf-more-exit-sync
 * [new tag]             corinna-01                  -> corinna-01
 * [new tag]             cr-0x99                     -> cr-0x99
 * [new tag]             csl-arm-2003-q4             -> csl-arm-2003-q4
 * [new tag]             csl-arm-2004-q1             -> csl-arm-2004-q1
 * [new tag]             csl-arm-2004-q1a            -> csl-arm-2004-q1a
 * [new tag]             csl-arm-2004-q3             -> csl-arm-2004-q3
 * [new tag]             csl-arm-2004-q3d            -> csl-arm-2004-q3d
 * [new tag]             csl-arm-20050325-branchpoint -> csl-arm-20050325-branchpoint
 * [new tag]             cygnus_cvs_20020108_pre     -> cygnus_cvs_20020108_pre
 * [new tag]             cygwin-1-1-5                -> cygwin-1-1-5
 * [new tag]             cygwin-1-1-6                -> cygwin-1-1-6
 * [new tag]             cygwin-1-1-7                -> cygwin-1-1-7
 * [new tag]             cygwin-1-1-8                -> cygwin-1-1-8
 * [new tag]             cygwin-1-3-19-1-branchpoint -> cygwin-1-3-19-1-branchpoint
 * [new tag]             cygwin-1_1_1                -> cygwin-1_1_1
 * [new tag]             cygwin-1_7_1-release        -> cygwin-1_7_1-release
 * [new tag]             cygwin-1_7_10-release       -> cygwin-1_7_10-release
 * [new tag]             cygwin-1_7_11-release       -> cygwin-1_7_11-release
 * [new tag]             cygwin-1_7_12-release       -> cygwin-1_7_12-release
 * [new tag]             cygwin-1_7_14-release       -> cygwin-1_7_14-release
 * [new tag]             cygwin-1_7_14_2-release     -> cygwin-1_7_14_2-release
 * [new tag]             cygwin-1_7_15-release       -> cygwin-1_7_15-release
 * [new tag]             cygwin-1_7_16-release       -> cygwin-1_7_16-release
 * [new tag]             cygwin-1_7_17-release       -> cygwin-1_7_17-release
 * [new tag]             cygwin-1_7_18-release       -> cygwin-1_7_18-release
 * [new tag]             cygwin-1_7_19-release       -> cygwin-1_7_19-release
 * [new tag]             cygwin-1_7_2-release        -> cygwin-1_7_2-release
 * [new tag]             cygwin-1_7_20-release       -> cygwin-1_7_20-release
 * [new tag]             cygwin-1_7_21-release       -> cygwin-1_7_21-release
 * [new tag]             cygwin-1_7_22-release       -> cygwin-1_7_22-release
 * [new tag]             cygwin-1_7_23-release       -> cygwin-1_7_23-release
 * [new tag]             cygwin-1_7_24-release       -> cygwin-1_7_24-release
 * [new tag]             cygwin-1_7_25-release       -> cygwin-1_7_25-release
 * [new tag]             cygwin-1_7_26-release       -> cygwin-1_7_26-release
 * [new tag]             cygwin-1_7_27-release       -> cygwin-1_7_27-release
 * [new tag]             cygwin-1_7_28-release       -> cygwin-1_7_28-release
 * [new tag]             cygwin-1_7_29-release       -> cygwin-1_7_29-release
 * [new tag]             cygwin-1_7_3-release        -> cygwin-1_7_3-release
 * [new tag]             cygwin-1_7_30-release       -> cygwin-1_7_30-release
 * [new tag]             cygwin-1_7_31-release       -> cygwin-1_7_31-release
 * [new tag]             cygwin-1_7_32-release       -> cygwin-1_7_32-release
 * [new tag]             cygwin-1_7_33-release       -> cygwin-1_7_33-release
 * [new tag]             cygwin-1_7_34-release       -> cygwin-1_7_34-release
 * [new tag]             cygwin-1_7_35-release       -> cygwin-1_7_35-release
 * [new tag]             cygwin-1_7_4-release        -> cygwin-1_7_4-release
 * [new tag]             cygwin-1_7_5-release        -> cygwin-1_7_5-release
 * [new tag]             cygwin-1_7_7-release        -> cygwin-1_7_7-release
 * [new tag]             cygwin-1_7_8-release        -> cygwin-1_7_8-release
 * [new tag]             cygwin-1_7_9-release        -> cygwin-1_7_9-release
 * [new tag]             cygwin-2_0_0-release        -> cygwin-2_0_0-release
 * [new tag]             cygwin-2_0_1-release        -> cygwin-2_0_1-release
 * [new tag]             cygwin-2_0_2-release        -> cygwin-2_0_2-release
 * [new tag]             cygwin-2_0_3-release        -> cygwin-2_0_3-release
 * [new tag]             cygwin-2_0_4-release        -> cygwin-2_0_4-release
 * [new tag]             cygwin-2_10_0-release       -> cygwin-2_10_0-release
 * [new tag]             cygwin-2_11_0-release       -> cygwin-2_11_0-release
 * [new tag]             cygwin-2_11_1-release       -> cygwin-2_11_1-release
 * [new tag]             cygwin-2_11_2-release       -> cygwin-2_11_2-release
 * [new tag]             cygwin-2_1_0-release        -> cygwin-2_1_0-release
 * [new tag]             cygwin-2_2_0-release        -> cygwin-2_2_0-release
 * [new tag]             cygwin-2_2_1-release        -> cygwin-2_2_1-release
 * [new tag]             cygwin-2_3_0-release        -> cygwin-2_3_0-release
 * [new tag]             cygwin-2_3_1-relase         -> cygwin-2_3_1-relase
 * [new tag]             cygwin-2_3_1-release        -> cygwin-2_3_1-release
 * [new tag]             cygwin-2_4_0-release        -> cygwin-2_4_0-release
 * [new tag]             cygwin-2_4_1-release        -> cygwin-2_4_1-release
 * [new tag]             cygwin-2_5_0-release        -> cygwin-2_5_0-release
 * [new tag]             cygwin-2_5_1-release        -> cygwin-2_5_1-release
 * [new tag]             cygwin-2_5_2-release        -> cygwin-2_5_2-release
 * [new tag]             cygwin-2_6_0-release        -> cygwin-2_6_0-release
 * [new tag]             cygwin-2_6_1-release        -> cygwin-2_6_1-release
 * [new tag]             cygwin-2_7_0-release        -> cygwin-2_7_0-release
 * [new tag]             cygwin-2_8_0-release        -> cygwin-2_8_0-release
 * [new tag]             cygwin-2_8_1-release        -> cygwin-2_8_1-release
 * [new tag]             cygwin-2_8_2-release        -> cygwin-2_8_2-release
 * [new tag]             cygwin-2_9_0-release        -> cygwin-2_9_0-release
 * [new tag]             cygwin-3_0_0-release        -> cygwin-3_0_0-release
 * [new tag]             cygwin-3_0_1-release        -> cygwin-3_0_1-release
 * [new tag]             cygwin-3_0_2-release        -> cygwin-3_0_2-release
 * [new tag]             cygwin-3_0_3-release        -> cygwin-3_0_3-release
 * [new tag]             cygwin-3_0_4-release        -> cygwin-3_0_4-release
 * [new tag]             cygwin-3_0_5-release        -> cygwin-3_0_5-release
 * [new tag]             cygwin-3_0_6-release        -> cygwin-3_0_6-release
 * [new tag]             cygwin-3_0_7-release        -> cygwin-3_0_7-release
 * [new tag]             cygwin-3_1_0-release        -> cygwin-3_1_0-release
 * [new tag]             cygwin-3_1_1-release        -> cygwin-3_1_1-release
 * [new tag]             cygwin-3_1_2-release        -> cygwin-3_1_2-release
 * [new tag]             cygwin-3_1_3-release        -> cygwin-3_1_3-release
 * [new tag]             cygwin-3_1_4-release        -> cygwin-3_1_4-release
 * [new tag]             cygwin-64bit-postmerge      -> cygwin-64bit-postmerge
 * [new tag]             cygwin-64bit-premerge       -> cygwin-64bit-premerge
 * [new tag]             cygwin-pre-user-db          -> cygwin-pre-user-db
 * [new tag]             cygwin_daemon_merge_HEAD    -> cygwin_daemon_merge_HEAD
 * [new tag]             debian-2.10.0-1             -> debian-2.10.0-1
 * [new tag]             dje-cgen-play1-branchpoint  -> dje-cgen-play1-branchpoint
 * [new tag]             drop_9x_support_start       -> drop_9x_support_start
 * [new tag]             drow-cplus-branchpoint      -> drow-cplus-branchpoint
 * [new tag]             drow-cplus-merge-20021020   -> drow-cplus-merge-20021020
 * [new tag]             drow-cplus-merge-20021025   -> drow-cplus-merge-20021025
 * [new tag]             drow-cplus-merge-20031214   -> drow-cplus-merge-20031214
 * [new tag]             drow-cplus-merge-20031220   -> drow-cplus-merge-20031220
 * [new tag]             drow-cplus-merge-20031224   -> drow-cplus-merge-20031224
 * [new tag]             drow-cplus-merge-20040113   -> drow-cplus-merge-20040113
 * [new tag]             drow-cplus-merge-20040208   -> drow-cplus-merge-20040208
 * [new tag]             drow-reverse-20070409-branchpoint -> drow-reverse-20070409-branchpoint
 * [new tag]             drow_intercu-20040221-branchpoint -> drow_intercu-20040221-branchpoint
 * [new tag]             drow_intercu-merge-20040327 -> drow_intercu-merge-20040327
 * [new tag]             drow_intercu-merge-20040402 -> drow_intercu-merge-20040402
 * [new tag]             drow_intercu-merge-20040915 -> drow_intercu-merge-20040915
 * [new tag]             drow_intercu-merge-20040921 -> drow_intercu-merge-20040921
 * [new tag]             egcs_20000222               -> egcs_20000222
 * [new tag]             ezannoni_pie-20030916-branchpoint -> ezannoni_pie-20030916-branchpoint
 * [new tag]             ezannoni_pie-20040323-branchpoint -> ezannoni_pie-20040323-branchpoint
 * [new tag]             gdb-csl-20060226-branch-local-2 -> gdb-csl-20060226-branch-local-2
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-local-1 -> gdb-csl-20060226-branch-merge-to-csl-local-1
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-symbian-1 -> gdb-csl-20060226-branch-merge-to-csl-symbian-1
 * [new tag]             gdb-csl-20060226-branchpoint -> gdb-csl-20060226-branchpoint
 * [new tag]             gdb-csl-arm-20050325-2005-q1a -> gdb-csl-arm-20050325-2005-q1a
 * [new tag]             gdb-csl-arm-20050325-2005-q1b -> gdb-csl-arm-20050325-2005-q1b
 * [new tag]             gdb-csl-arm-20051020-branchpoint -> gdb-csl-arm-20051020-branchpoint
 * [new tag]             gdb-csl-arm-2006q1-6        -> gdb-csl-arm-2006q1-6
 * [new tag]             gdb-csl-available-20060303-branchpoint -> gdb-csl-available-20060303-branchpoint
 * [new tag]             gdb-csl-coldfire-4_1-10     -> gdb-csl-coldfire-4_1-10
 * [new tag]             gdb-csl-coldfire-4_1-11     -> gdb-csl-coldfire-4_1-11
 * [new tag]             gdb-csl-gxxpro-6_3-branchpoint -> gdb-csl-gxxpro-6_3-branchpoint
 * [new tag]             gdb-csl-morpho-4_1-4        -> gdb-csl-morpho-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-17 -> gdb-csl-sourcerygxx-3_4_4-17
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-19 -> gdb-csl-sourcerygxx-3_4_4-19
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-21 -> gdb-csl-sourcerygxx-3_4_4-21
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-25 -> gdb-csl-sourcerygxx-3_4_4-25
 * [new tag]             gdb-csl-sourcerygxx-4_1-12  -> gdb-csl-sourcerygxx-4_1-12
 * [new tag]             gdb-csl-sourcerygxx-4_1-13  -> gdb-csl-sourcerygxx-4_1-13
 * [new tag]             gdb-csl-sourcerygxx-4_1-14  -> gdb-csl-sourcerygxx-4_1-14
 * [new tag]             gdb-csl-sourcerygxx-4_1-17  -> gdb-csl-sourcerygxx-4_1-17
 * [new tag]             gdb-csl-sourcerygxx-4_1-4   -> gdb-csl-sourcerygxx-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-4_1-5   -> gdb-csl-sourcerygxx-4_1-5
 * [new tag]             gdb-csl-sourcerygxx-4_1-6   -> gdb-csl-sourcerygxx-4_1-6
 * [new tag]             gdb-csl-sourcerygxx-4_1-7   -> gdb-csl-sourcerygxx-4_1-7
 * [new tag]             gdb-csl-sourcerygxx-4_1-8   -> gdb-csl-sourcerygxx-4_1-8
 * [new tag]             gdb-csl-sourcerygxx-4_1-9   -> gdb-csl-sourcerygxx-4_1-9
 * [new tag]             gdb-csl-symbian-20060226-branchpoint -> gdb-csl-symbian-20060226-branchpoint
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-10 -> gdb-csl-symbian-6_4_50_20060226-10
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-11 -> gdb-csl-symbian-6_4_50_20060226-11
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-12 -> gdb-csl-symbian-6_4_50_20060226-12
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-8 -> gdb-csl-symbian-6_4_50_20060226-8
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-9 -> gdb-csl-symbian-6_4_50_20060226-9
 * [new tag]             gdb-premipsmulti-2000-06-06-branchpoint -> gdb-premipsmulti-2000-06-06-branchpoint
 * [new tag]             gdb_4_18_2-2000-05-18-release -> gdb_4_18_2-2000-05-18-release
 * [new tag]             gdb_4_95_0-2000-04-27-snapshot -> gdb_4_95_0-2000-04-27-snapshot
 * [new tag]             gdb_4_95_1-2000-05-11-snapshot -> gdb_4_95_1-2000-05-11-snapshot
 * [new tag]             gdb_5_0-2000-04-10-branchpoint -> gdb_5_0-2000-04-10-branchpoint
 * [new tag]             gdb_5_0-2000-05-19-release  -> gdb_5_0-2000-05-19-release
 * [new tag]             gdb_5_1-2001-07-29-branchpoint -> gdb_5_1-2001-07-29-branchpoint
 * [new tag]             gdb_5_1-2001-11-21-release  -> gdb_5_1-2001-11-21-release
 * [new tag]             gdb_5_1_0_1-2002-01-03-branchpoint -> gdb_5_1_0_1-2002-01-03-branchpoint
 * [new tag]             gdb_5_1_0_1-2002-01-03-release -> gdb_5_1_0_1-2002-01-03-release
 * [new tag]             gdb_5_1_1-2002-01-24-release -> gdb_5_1_1-2002-01-24-release
 * [new tag]             gdb_5_2-2002-03-03-branchpoint -> gdb_5_2-2002-03-03-branchpoint
 * [new tag]             gdb_5_2-2002-04-29-release  -> gdb_5_2-2002-04-29-release
 * [new tag]             gdb_5_2_1-2002-07-23-release -> gdb_5_2_1-2002-07-23-release
 * [new tag]             gdb_5_3-2002-09-04-branchpoint -> gdb_5_3-2002-09-04-branchpoint
 * [new tag]             gdb_5_3-2002-12-12-release  -> gdb_5_3-2002-12-12-release
 * [new tag]             gdb_6_0-2003-06-23-branchpoint -> gdb_6_0-2003-06-23-branchpoint
 * [new tag]             gdb_6_0-2003-10-04-release  -> gdb_6_0-2003-10-04-release
 * [new tag]             gdb_6_1-2004-03-01-gmt-branchpoint -> gdb_6_1-2004-03-01-gmt-branchpoint
 * [new tag]             gdb_6_1-2004-04-05-release  -> gdb_6_1-2004-04-05-release
 * [new tag]             gdb_6_1_1-20040616-release  -> gdb_6_1_1-20040616-release
 * [new tag]             gdb_6_2-2004-07-10-gmt-branchpoint -> gdb_6_2-2004-07-10-gmt-branchpoint
 * [new tag]             gdb_6_2-20040730-release    -> gdb_6_2-20040730-release
 * [new tag]             gdb_6_3-20041019-branchpoint -> gdb_6_3-20041019-branchpoint
 * [new tag]             gdb_6_3-20041109-release    -> gdb_6_3-20041109-release
 * [new tag]             gdb_6_4-2005-11-01-branchpoint -> gdb_6_4-2005-11-01-branchpoint
 * [new tag]             gdb_6_4-20051202-release    -> gdb_6_4-20051202-release
 * [new tag]             gdb_6_5-2006-05-14-branchpoint -> gdb_6_5-2006-05-14-branchpoint
 * [new tag]             gdb_6_5-20060621-release    -> gdb_6_5-20060621-release
 * [new tag]             gdb_6_6-2006-11-15-branchpoint -> gdb_6_6-2006-11-15-branchpoint
 * [new tag]             gdb_6_6-2006-12-18-release  -> gdb_6_6-2006-12-18-release
 * [new tag]             gdb_6_7-2007-09-07-branchpoint -> gdb_6_7-2007-09-07-branchpoint
 * [new tag]             gdb_6_7-2007-10-10-release  -> gdb_6_7-2007-10-10-release
 * [new tag]             gdb_6_7_1-2007-10-29-release -> gdb_6_7_1-2007-10-29-release
 * [new tag]             gdb_6_8-2008-02-26-branchpoint -> gdb_6_8-2008-02-26-branchpoint
 * [new tag]             gdb_6_8-2008-03-27-release  -> gdb_6_8-2008-03-27-release
 * [new tag]             gdb_7_0-2009-09-16-branchpoint -> gdb_7_0-2009-09-16-branchpoint
 * [new tag]             gdb_7_0-2009-10-06-release  -> gdb_7_0-2009-10-06-release
 * [new tag]             gdb_7_0_1-2009-12-22-release -> gdb_7_0_1-2009-12-22-release
 * [new tag]             gdb_7_1-2010-02-18-branchpoint -> gdb_7_1-2010-02-18-branchpoint
 * [new tag]             gdb_7_1-2010-03-18-release  -> gdb_7_1-2010-03-18-release
 * [new tag]             gdb_7_2-2010-07-07-branchpoint -> gdb_7_2-2010-07-07-branchpoint
 * [new tag]             gdb_7_2-2010-09-02-release  -> gdb_7_2-2010-09-02-release
 * [new tag]             gdb_7_3-2011-04-01-branchpoint -> gdb_7_3-2011-04-01-branchpoint
 * [new tag]             gdb_7_3-2011-07-26-release  -> gdb_7_3-2011-07-26-release
 * [new tag]             gdb_7_3_1-2011-09-04-release -> gdb_7_3_1-2011-09-04-release
 * [new tag]             gdb_7_4-2011-12-13-branchpoint -> gdb_7_4-2011-12-13-branchpoint
 * [new tag]             gdb_7_4-2012-01-24-release  -> gdb_7_4-2012-01-24-release
 * [new tag]             gdb_7_4_1-2012-04-26-release -> gdb_7_4_1-2012-04-26-release
 * [new tag]             gdb_7_5-2012-07-18-branchpoint -> gdb_7_5-2012-07-18-branchpoint
 * [new tag]             gdb_7_5-2012-08-17-release  -> gdb_7_5-2012-08-17-release
 * [new tag]             gdb_7_5_1-2012-11-29-release -> gdb_7_5_1-2012-11-29-release
 * [new tag]             gdb_7_6-2013-03-12-branchpoint -> gdb_7_6-2013-03-12-branchpoint
 * [new tag]             gdb_7_6-2013-04-26-release  -> gdb_7_6-2013-04-26-release
 * [new tag]             gdb_7_6_1-2013-08-30-release -> gdb_7_6_1-2013-08-30-release
 * [new tag]             gdb_s390-2001-09-26-branchpoint -> gdb_s390-2001-09-26-branchpoint
 * [new tag]             hmm                         -> hmm
 * [new tag]             insight-precleanup-2001-01-01 -> insight-precleanup-2001-01-01
 * [new tag]             insight_6_5-20061003-release -> insight_6_5-20061003-release
 * [new tag]             insight_6_6-20070208-release -> insight_6_6-20070208-release
 * [new tag]             insight_6_8-branchpoint     -> insight_6_8-branchpoint
 * [new tag]             interps-20030202-branchpoint -> interps-20030202-branchpoint
 * [new tag]             jimb-gdb_6_2-e500-branchpoint -> jimb-gdb_6_2-e500-branchpoint
 * [new tag]             jimb-macro-020506-branchpoint -> jimb-macro-020506-branchpoint
 * [new tag]             jimb-ppc64-linux-20030509-branchpoint -> jimb-ppc64-linux-20030509-branchpoint
 * [new tag]             jimb-ppc64-linux-20030528-branchpoint -> jimb-ppc64-linux-20030528-branchpoint
 * [new tag]             jimb-ppc64-linux-20030613-branchpoint -> jimb-ppc64-linux-20030613-branchpoint
 * [new tag]             jimb-rda-nptl-branchpoint   -> jimb-rda-nptl-branchpoint
 * [new tag]             kettenis-i386newframe-20030308-branchpoint -> kettenis-i386newframe-20030308-branchpoint
 * [new tag]             kettenis-i386newframe-20030316-mergepoint -> kettenis-i386newframe-20030316-mergepoint
 * [new tag]             kettenis_i386newframe-20030406-branchpoint -> kettenis_i386newframe-20030406-branchpoint
 * [new tag]             kettenis_i386newframe-20030419-branchpoint -> kettenis_i386newframe-20030419-branchpoint
 * [new tag]             kettenis_i386newframe-20030504-mergepoint -> kettenis_i386newframe-20030504-mergepoint
 * [new tag]             kettenis_i386newframe-20030517-mergepoint -> kettenis_i386newframe-20030517-mergepoint
 * [new tag]             kettenis_sparc-20030918-branchpoint -> kettenis_sparc-20030918-branchpoint
 * [new tag]             kseitz_interps-20020528-branchpoint -> kseitz_interps-20020528-branchpoint
 * [new tag]             kseitz_interps-20020829-merge -> kseitz_interps-20020829-merge
 * [new tag]             kseitz_interps-20020930-merge -> kseitz_interps-20020930-merge
 * [new tag]             kseitz_interps-20021103-merge -> kseitz_interps-20021103-merge
 * [new tag]             kseitz_interps-20021105-merge -> kseitz_interps-20021105-merge
 * [new tag]             mingw-runtime-2_0           -> mingw-runtime-2_0
 * [new tag]             mingw-runtime-2_4           -> mingw-runtime-2_4
 * [new tag]             msnyder-checkpoint-072509-branchpoint -> msnyder-checkpoint-072509-branchpoint
 * [new tag]             msnyder-fork-checkpoint-branchpoint -> msnyder-fork-checkpoint-branchpoint
 * [new tag]             msnyder-reverse-20060331-branchpoint -> msnyder-reverse-20060331-branchpoint
 * [new tag]             msnyder-reverse-20060502-branchpoint -> msnyder-reverse-20060502-branchpoint
 * [new tag]             msnyder-reverse-20080609-branchpoint -> msnyder-reverse-20080609-branchpoint
 * [new tag]             msnyder-tracepoint-checkpoint-branchpoint -> msnyder-tracepoint-checkpoint-branchpoint
 * [new tag]             multiprocess-20081120-branchpoint -> multiprocess-20081120-branchpoint
 * [new tag]             newlib-1_10_0               -> newlib-1_10_0
 * [new tag]             newlib-1_11_0               -> newlib-1_11_0
 * [new tag]             newlib-1_12_0               -> newlib-1_12_0
 * [new tag]             newlib-1_13_0               -> newlib-1_13_0
 * [new tag]             newlib-1_14_0               -> newlib-1_14_0
 * [new tag]             newlib-1_15_0               -> newlib-1_15_0
 * [new tag]             newlib-1_16_0               -> newlib-1_16_0
 * [new tag]             newlib-1_17_0               -> newlib-1_17_0
 * [new tag]             newlib-1_18_0               -> newlib-1_18_0
 * [new tag]             newlib-1_19_0               -> newlib-1_19_0
 * [new tag]             newlib-1_20_0               -> newlib-1_20_0
 * [new tag]             newlib-1_9_0                -> newlib-1_9_0
 * [new tag]             newlib-2000-02-17           -> newlib-2000-02-17
 * [new tag]             newlib-2_0_0                -> newlib-2_0_0
 * [new tag]             newlib-2_1_0                -> newlib-2_1_0
 * [new tag]             newlib-2_2_0                -> newlib-2_2_0
 * [new tag]             newlib-2_3_0                -> newlib-2_3_0
 * [new tag]             newlib-2_4_0                -> newlib-2_4_0
 * [new tag]             newlib-2_5_0                -> newlib-2_5_0
 * [new tag]             newlib-3.0.0                -> newlib-3.0.0
 * [new tag]             newlib-3.1.0                -> newlib-3.1.0
 * [new tag]             newlib-3.2.0                -> newlib-3.2.0
 * [new tag]             newlib-3.3.0                -> newlib-3.3.0
 * [new tag]             newlib-csl-20060320-branchpoint -> newlib-csl-20060320-branchpoint
 * [new tag]             newlib-csl-arm-2005-q1a     -> newlib-csl-arm-2005-q1a
 * [new tag]             newlib-csl-arm-2005-q1b     -> newlib-csl-arm-2005-q1b
 * [new tag]             newlib-csl-arm-2006q1-6     -> newlib-csl-arm-2006q1-6
 * [new tag]             newlib-csl-arm-2006q3-19    -> newlib-csl-arm-2006q3-19
 * [new tag]             newlib-csl-arm-2006q3-21    -> newlib-csl-arm-2006q3-21
 * [new tag]             newlib-csl-arm-2006q3-26    -> newlib-csl-arm-2006q3-26
 * [new tag]             newlib-csl-arm-2006q3-27    -> newlib-csl-arm-2006q3-27
 * [new tag]             newlib-csl-coldfire-4_1-28  -> newlib-csl-coldfire-4_1-28
 * [new tag]             newlib-csl-coldfire-4_1-30  -> newlib-csl-coldfire-4_1-30
 * [new tag]             newlib-csl-coldfire-4_1-32  -> newlib-csl-coldfire-4_1-32
 * [new tag]             newlib-csl-innovasic-fido-3_4_4-33 -> newlib-csl-innovasic-fido-3_4_4-33
 * [new tag]             newlib-csl-sourcerygxx-3_4_4-25 -> newlib-csl-sourcerygxx-3_4_4-25
 * [new tag]             newlib-csl-sourcerygxx-4_1-12 -> newlib-csl-sourcerygxx-4_1-12
 * [new tag]             newlib-csl-sourcerygxx-4_1-13 -> newlib-csl-sourcerygxx-4_1-13
 * [new tag]             newlib-csl-sourcerygxx-4_1-14 -> newlib-csl-sourcerygxx-4_1-14
 * [new tag]             newlib-csl-sourcerygxx-4_1-17 -> newlib-csl-sourcerygxx-4_1-17
 * [new tag]             newlib-csl-sourcerygxx-4_1-18 -> newlib-csl-sourcerygxx-4_1-18
 * [new tag]             newlib-csl-sourcerygxx-4_1-19 -> newlib-csl-sourcerygxx-4_1-19
 * [new tag]             newlib-csl-sourcerygxx-4_1-21 -> newlib-csl-sourcerygxx-4_1-21
 * [new tag]             newlib-csl-sourcerygxx-4_1-23 -> newlib-csl-sourcerygxx-4_1-23
 * [new tag]             newlib-csl-sourcerygxx-4_1-24 -> newlib-csl-sourcerygxx-4_1-24
 * [new tag]             newlib-csl-sourcerygxx-4_1-26 -> newlib-csl-sourcerygxx-4_1-26
 * [new tag]             newlib-csl-sourcerygxx-4_1-27 -> newlib-csl-sourcerygxx-4_1-27
 * [new tag]             newlib-csl-sourcerygxx-4_1-28 -> newlib-csl-sourcerygxx-4_1-28
 * [new tag]             newlib-csl-sourcerygxx-4_1-30 -> newlib-csl-sourcerygxx-4_1-30
 * [new tag]             newlib-csl-sourcerygxx-4_1-32 -> newlib-csl-sourcerygxx-4_1-32
 * [new tag]             newlib-csl-sourcerygxx-4_1-4 -> newlib-csl-sourcerygxx-4_1-4
 * [new tag]             newlib-csl-sourcerygxx-4_1-5 -> newlib-csl-sourcerygxx-4_1-5
 * [new tag]             newlib-csl-sourcerygxx-4_1-6 -> newlib-csl-sourcerygxx-4_1-6
 * [new tag]             newlib-csl-sourcerygxx-4_1-7 -> newlib-csl-sourcerygxx-4_1-7
 * [new tag]             newlib-csl-sourcerygxx-4_1-8 -> newlib-csl-sourcerygxx-4_1-8
 * [new tag]             newlib-csl-sourcerygxx-4_1-9 -> newlib-csl-sourcerygxx-4_1-9
 * [new tag]             newlib-snapshot-20150323    -> newlib-snapshot-20150323
 * [new tag]             newlib-snapshot-20150423    -> newlib-snapshot-20150423
 * [new tag]             newlib-snapshot-20150526    -> newlib-snapshot-20150526
 * [new tag]             newlib-snapshot-20150623    -> newlib-snapshot-20150623
 * [new tag]             newlib-snapshot-20150723    -> newlib-snapshot-20150723
 * [new tag]             newlib-snapshot-20150824    -> newlib-snapshot-20150824
 * [new tag]             newlib-snapshot-20150924    -> newlib-snapshot-20150924
 * [new tag]             newlib-snapshot-20151023    -> newlib-snapshot-20151023
 * [new tag]             newlib-snapshot-20160104    -> newlib-snapshot-20160104
 * [new tag]             newlib-snapshot-20160226    -> newlib-snapshot-20160226
 * [new tag]             newlib-snapshot-20160527    -> newlib-snapshot-20160527
 * [new tag]             newlib-snapshot-20160923    -> newlib-snapshot-20160923
 * [new tag]             newlib-snapshot-20170228    -> newlib-snapshot-20170228
 * [new tag]             newlib-snapshot-20170323    -> newlib-snapshot-20170323
 * [new tag]             newlib-snapshot-20170421    -> newlib-snapshot-20170421
 * [new tag]             newlib-snapshot-20170519    -> newlib-snapshot-20170519
 * [new tag]             newlib-snapshot-20170623    -> newlib-snapshot-20170623
 * [new tag]             newlib-snapshot-20170720    -> newlib-snapshot-20170720
 * [new tag]             newlib-snapshot-20170818    -> newlib-snapshot-20170818
 * [new tag]             newlib-snapshot-20170922    -> newlib-snapshot-20170922
 * [new tag]             newlib-snapshot-20171222    -> newlib-snapshot-20171222
 * [new tag]             newlib-snapshot-20180118    -> newlib-snapshot-20180118
 * [new tag]             newlib-snapshot-20180226    -> newlib-snapshot-20180226
 * [new tag]             newlib-snapshot-20180720    -> newlib-snapshot-20180720
 * [new tag]             newlib-snapshot-20180802    -> newlib-snapshot-20180802
 * [new tag]             newlib-snapshot-20180831    -> newlib-snapshot-20180831
 * [new tag]             newlib-snapshot-20181231    -> newlib-snapshot-20181231
 * [new tag]             newlib-snapshot-20200102    -> newlib-snapshot-20200102
 * [new tag]             nickrob-async-20060513-branchpoint -> nickrob-async-20060513-branchpoint
 * [new tag]             nickrob-async-20060828-mergepoint -> nickrob-async-20060828-mergepoint
 * [new tag]             offbyone-20030313-branchpoint -> offbyone-20030313-branchpoint
 * [new tag]             post-ptmalloc3              -> post-ptmalloc3
 * [new tag]             post_wait_sig_exit          -> post_wait_sig_exit
 * [new tag]             pre-cgf-merge               -> pre-cgf-merge
 * [new tag]             pre-cygwin-heap             -> pre-cygwin-heap
 * [new tag]             pre-no-this                 -> pre-no-this
 * [new tag]             pre-notty                   -> pre-notty
 * [new tag]             pre-posix-scan              -> pre-posix-scan
 * [new tag]             pre-ptmalloc3               -> pre-ptmalloc3
 * [new tag]             pre-ptymaster-archetype     -> pre-ptymaster-archetype
 * [new tag]             pre-ripout-set_console_state_for_spawn -> pre-ripout-set_console_state_for_spawn
 * [new tag]             pre-sigrewrite              -> pre-sigrewrite
 * [new tag]             pre_wait_sig_exit           -> pre_wait_sig_exit
 * [new tag]             predaemon                   -> predaemon
 * [new tag]             prefifo                     -> prefifo
 * [new tag]             preoverlapped               -> preoverlapped
 * [new tag]             readline_4_3-import-branchpoint -> readline_4_3-import-branchpoint
 * [new tag]             readline_5_1-import-branchpoint -> readline_5_1-import-branchpoint
 * [new tag]             reparent-point              -> reparent-point
 * [new tag]             repo-unification-2000-02-06 -> repo-unification-2000-02-06
 * [new tag]             reverse-20080717-branchpoint -> reverse-20080717-branchpoint
 * [new tag]             reverse-20080930-branchpoint -> reverse-20080930-branchpoint
 * [new tag]             reverse-20081226-branchpoint -> reverse-20081226-branchpoint
 * [new tag]             sid-20020905-branchpoint    -> sid-20020905-branchpoint
 * [new tag]             sid-snapshot-20071001       -> sid-snapshot-20071001
 * [new tag]             sid-snapshot-20071101       -> sid-snapshot-20071101
 * [new tag]             sid-snapshot-20071201       -> sid-snapshot-20071201
 * [new tag]             sid-snapshot-20080101       -> sid-snapshot-20080101
 * [new tag]             sid-snapshot-20080201       -> sid-snapshot-20080201
 * [new tag]             sid-snapshot-20080301       -> sid-snapshot-20080301
 * [new tag]             sid-snapshot-20080401       -> sid-snapshot-20080401
 * [new tag]             sid-snapshot-20080403       -> sid-snapshot-20080403
 * [new tag]             sid-snapshot-20080501       -> sid-snapshot-20080501
 * [new tag]             sid-snapshot-20080601       -> sid-snapshot-20080601
 * [new tag]             sid-snapshot-20080701       -> sid-snapshot-20080701
 * [new tag]             sid-snapshot-20080801       -> sid-snapshot-20080801
 * [new tag]             sid-snapshot-20080901       -> sid-snapshot-20080901
 * [new tag]             sid-snapshot-20081001       -> sid-snapshot-20081001
 * [new tag]             sid-snapshot-20081101       -> sid-snapshot-20081101
 * [new tag]             sid-snapshot-20081201       -> sid-snapshot-20081201
 * [new tag]             sid-snapshot-20090101       -> sid-snapshot-20090101
 * [new tag]             sid-snapshot-20090201       -> sid-snapshot-20090201
 * [new tag]             sid-snapshot-20090301       -> sid-snapshot-20090301
 * [new tag]             sid-snapshot-20090401       -> sid-snapshot-20090401
 * [new tag]             sid-snapshot-20090501       -> sid-snapshot-20090501
 * [new tag]             sid-snapshot-20090601       -> sid-snapshot-20090601
 * [new tag]             sid-snapshot-20090701       -> sid-snapshot-20090701
 * [new tag]             sid-snapshot-20090801       -> sid-snapshot-20090801
 * [new tag]             sid-snapshot-20090901       -> sid-snapshot-20090901
 * [new tag]             sid-snapshot-20091001       -> sid-snapshot-20091001
 * [new tag]             sid-snapshot-20091101       -> sid-snapshot-20091101
 * [new tag]             sid-snapshot-20091201       -> sid-snapshot-20091201
 * [new tag]             sid-snapshot-20100101       -> sid-snapshot-20100101
 * [new tag]             sid-snapshot-20100201       -> sid-snapshot-20100201
 * [new tag]             sid-snapshot-20100301       -> sid-snapshot-20100301
 * [new tag]             sid-snapshot-20100401       -> sid-snapshot-20100401
 * [new tag]             sid-snapshot-20100501       -> sid-snapshot-20100501
 * [new tag]             sid-snapshot-20100601       -> sid-snapshot-20100601
 * [new tag]             sid-snapshot-20100701       -> sid-snapshot-20100701
 * [new tag]             sid-snapshot-20100801       -> sid-snapshot-20100801
 * [new tag]             sid-snapshot-20100901       -> sid-snapshot-20100901
 * [new tag]             sid-snapshot-20101001       -> sid-snapshot-20101001
 * [new tag]             sid-snapshot-20101101       -> sid-snapshot-20101101
 * [new tag]             sid-snapshot-20101201       -> sid-snapshot-20101201
 * [new tag]             sid-snapshot-20110101       -> sid-snapshot-20110101
 * [new tag]             sid-snapshot-20110201       -> sid-snapshot-20110201
 * [new tag]             sid-snapshot-20110301       -> sid-snapshot-20110301
 * [new tag]             sid-snapshot-20110401       -> sid-snapshot-20110401
 * [new tag]             sid-snapshot-20110501       -> sid-snapshot-20110501
 * [new tag]             sid-snapshot-20110601       -> sid-snapshot-20110601
 * [new tag]             sid-snapshot-20110701       -> sid-snapshot-20110701
 * [new tag]             sid-snapshot-20110801       -> sid-snapshot-20110801
 * [new tag]             sid-snapshot-20110901       -> sid-snapshot-20110901
 * [new tag]             sid-snapshot-20111001       -> sid-snapshot-20111001
 * [new tag]             sid-snapshot-20111101       -> sid-snapshot-20111101
 * [new tag]             sid-snapshot-20111201       -> sid-snapshot-20111201
 * [new tag]             sid-snapshot-20120101       -> sid-snapshot-20120101
 * [new tag]             sid-snapshot-20120201       -> sid-snapshot-20120201
 * [new tag]             sid-snapshot-20120301       -> sid-snapshot-20120301
 * [new tag]             sid-snapshot-20120401       -> sid-snapshot-20120401
 * [new tag]             sid-snapshot-20120501       -> sid-snapshot-20120501
 * [new tag]             sid-snapshot-20120601       -> sid-snapshot-20120601
 * [new tag]             sid-snapshot-20120701       -> sid-snapshot-20120701
 * [new tag]             sid-snapshot-20120801       -> sid-snapshot-20120801
 * [new tag]             sid-snapshot-20120901       -> sid-snapshot-20120901
 * [new tag]             sid-snapshot-20121001       -> sid-snapshot-20121001
 * [new tag]             sid-snapshot-20121101       -> sid-snapshot-20121101
 * [new tag]             sid-snapshot-20121201       -> sid-snapshot-20121201
 * [new tag]             sid-snapshot-20130101       -> sid-snapshot-20130101
 * [new tag]             sid-snapshot-20130201       -> sid-snapshot-20130201
 * [new tag]             sid-snapshot-20130301       -> sid-snapshot-20130301
 * [new tag]             sid-snapshot-20130401       -> sid-snapshot-20130401
 * [new tag]             sid-snapshot-20130501       -> sid-snapshot-20130501
 * [new tag]             sid-snapshot-20130601       -> sid-snapshot-20130601
 * [new tag]             sid-snapshot-20130701       -> sid-snapshot-20130701
 * [new tag]             sid-snapshot-20130801       -> sid-snapshot-20130801
 * [new tag]             sid-snapshot-20130901       -> sid-snapshot-20130901
 * [new tag]             sid-snapshot-20131001       -> sid-snapshot-20131001
 * [new tag]             sid-snapshot-20131101       -> sid-snapshot-20131101
 * [new tag]             sid-snapshot-20131201       -> sid-snapshot-20131201
 * [new tag]             sid-snapshot-20140101       -> sid-snapshot-20140101
 * [new tag]             sid-snapshot-20140201       -> sid-snapshot-20140201
 * [new tag]             sid-snapshot-20140301       -> sid-snapshot-20140301
 * [new tag]             sid-snapshot-20140401       -> sid-snapshot-20140401
 * [new tag]             sid-snapshot-20140501       -> sid-snapshot-20140501
 * [new tag]             sid-snapshot-20140601       -> sid-snapshot-20140601
 * [new tag]             sid-snapshot-20140701       -> sid-snapshot-20140701
 * [new tag]             sid-snapshot-20140801       -> sid-snapshot-20140801
 * [new tag]             sid-snapshot-20140901       -> sid-snapshot-20140901
 * [new tag]             sid-snapshot-20141001       -> sid-snapshot-20141001
 * [new tag]             sid-snapshot-20141101       -> sid-snapshot-20141101
 * [new tag]             sid-snapshot-20141201       -> sid-snapshot-20141201
 * [new tag]             sid-snapshot-20150101       -> sid-snapshot-20150101
 * [new tag]             sid-snapshot-20150201       -> sid-snapshot-20150201
 * [new tag]             sid-snapshot-20150301       -> sid-snapshot-20150301
 * [new tag]             tcltk840-20020924-branchpoint -> tcltk840-20020924-branchpoint
 * [new tag]             w32api-1_5                  -> w32api-1_5
 * [new tag]             w32api-2_2                  -> w32api-2_2
 * [new tag]             winsup-2000-02-17           -> winsup-2000-02-17
 * [new tag]             x86_64versiong3             -> x86_64versiong3
HEAD is now at 764ef4e40 Version 1.8.6
From https://github.com/zephyrproject-rtos/segger
 * [new branch]      master       -> refs/west/master
 * [new branch]      v1.14-branch -> refs/west/v1.14-branch
HEAD is now at b011c45 segger: config: Add CCM option for linker sections
From https://github.com/zephyrproject-rtos/tinycrypt
HEAD is now at 1012a3e Fix warnings reported by UBSAN
From https://github.com/zephyrproject-rtos/uoscore-uedhoc
 * [new branch]      zephyr     -> refs/west/zephyr
HEAD is now at 150f4eb [zephyr fromlist] Adapt to changes in name generation in zcbor 0.8.0
From https://github.com/zephyrproject-rtos/zcbor
 * [new branch]      main              -> refs/west/main
 * [new branch]      release/0.6.1     -> refs/west/release/0.6.1
 * [new branch]      release/0.8.2     -> refs/west/release/0.8.2
 * [new tag]         0.1.0             -> 0.1.0
 * [new tag]         0.2.0             -> 0.2.0
 * [new tag]         0.3.0             -> 0.3.0
 * [new tag]         0.3.1             -> 0.3.1
 * [new tag]         0.4.0             -> 0.4.0
 * [new tag]         0.5.0             -> 0.5.0
 * [new tag]         0.5.1             -> 0.5.1
 * [new tag]         0.6.0             -> 0.6.0
 * [new tag]         0.8.0             -> 0.8.0
 * [new tag]         0.8.1             -> 0.8.1
 * [new tag]         0.9.0             -> 0.9.0
 * [new tag]         deprecated-master -> deprecated-master
 * [new tag]         inital-pr         -> inital-pr
 * [new tag]         old-structure     -> old-structure
HEAD is now at 75d0880 tests: Update mps2 board name
ERROR: update failed for projects: matter, cmock
Error: Launched process exited with non-zero status: 1
2024-09-07T15:24:35.543Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T15:25:10.779Z INFO Successfully removed toolchain directory: C:\ncs\toolchains\ce3b5ff664
2024-09-07T15:37:52.153Z INFO Start to install toolchain v2.7.0
2024-09-07T15:37:52.202Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T15:43:23.629Z DEBUG Sending event "toolchain-manager: Install toolchain from nrfutil"
2024-09-07T15:43:23.631Z INFO Cloning nRF Connect SDK v2.7.0
2024-09-07T15:43:23.633Z DEBUG Sending event "toolchain-manager: Clone nRF Connect SDK"
2024-09-07T15:43:23.671Z INFO Initializing environment for v2.7.0
2024-09-07T15:43:23.684Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T15:43:26.459Z DEBUG === Initializing in C:\ncs\v2.7.0
2024-09-07T15:43:26.460Z DEBUG --- Cloning manifest repository from https://github.com/nrfconnect/sdk-nrf, rev. v2.7.0
2024-09-07T15:44:35.453Z DEBUG --- setting manifest.path to nrf
2024-09-07T15:44:35.494Z DEBUG === Initialized. Now run "west update" inside C:\ncs\v2.7.0.
2024-09-07T15:44:35.558Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T15:44:36.453Z DEBUG === updating zephyr (zephyr):
2024-09-07T15:44:36.455Z INFO Updating zephyr repository for v2.7.0
2024-09-07T15:44:36.483Z DEBUG --- zephyr: initializing
2024-09-07T15:44:37.349Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/zephyr/.git/
2024-09-07T15:44:37.460Z DEBUG --- zephyr: fetching, need revision v3.6.99-ncs2
2024-09-07T15:48:37.776Z DEBUG === updating bsim (tools/bsim):
2024-09-07T15:48:37.825Z INFO Updating bsim repository for v2.7.0
2024-09-07T15:48:37.852Z DEBUG --- bsim: initializing
2024-09-07T15:48:37.940Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/tools/bsim/.git/
2024-09-07T15:48:38.032Z DEBUG --- bsim: fetching, need revision 68f6282c6a7f54641b75f5f9fc953c85e272a983
2024-09-07T15:48:43.647Z DEBUG === updating hostap (modules/lib/hostap):
2024-09-07T15:48:43.693Z INFO Updating hostap repository for v2.7.0
2024-09-07T15:48:43.730Z DEBUG --- hostap: initializing
2024-09-07T15:48:43.744Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/hostap/.git/
2024-09-07T15:48:43.888Z DEBUG --- hostap: fetching, need revision 6311fde66f87ac8c8838a2d5fcfe55a498a8682a
2024-09-07T15:49:08.116Z DEBUG === updating wfa-qt-control-app (modules/lib/wfa-qt-control-app):
2024-09-07T15:49:08.171Z INFO Updating wfa-qt-control-app repository for v2.7.0
2024-09-07T15:49:08.212Z DEBUG --- wfa-qt-control-app: initializing
2024-09-07T15:49:08.308Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/wfa-qt-control-app/.git/
2024-09-07T15:49:08.375Z DEBUG --- wfa-qt-control-app: fetching, need revision 9f91589a5be2b95a77a2b109901aad3298255315
2024-09-07T15:49:11.359Z DEBUG === updating mcuboot (bootloader/mcuboot):
2024-09-07T15:49:11.360Z INFO Updating mcuboot repository for v2.7.0
2024-09-07T15:49:11.385Z DEBUG --- mcuboot: initializing
2024-09-07T15:49:11.492Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/bootloader/mcuboot/.git/
2024-09-07T15:49:11.569Z DEBUG --- mcuboot: fetching, need revision v2.1.0-ncs1
2024-09-07T15:49:18.416Z DEBUG === updating qcbor (modules/tee/tf-m/qcbor):
2024-09-07T15:49:18.466Z INFO Updating qcbor repository for v2.7.0
2024-09-07T15:49:18.501Z DEBUG --- qcbor: initializing
2024-09-07T15:49:18.529Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/tee/tf-m/qcbor/.git/
2024-09-07T15:49:18.675Z DEBUG --- qcbor: fetching, need revision 751d36583a9ce1a640900c57e13c9b6b8f3a2ba2
2024-09-07T15:49:23.502Z DEBUG === updating mbedtls (modules/crypto/mbedtls):
2024-09-07T15:49:23.546Z INFO Updating mbedtls repository for v2.7.0
2024-09-07T15:49:23.578Z DEBUG --- mbedtls: initializing
2024-09-07T15:49:23.600Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/crypto/mbedtls/.git/
2024-09-07T15:49:23.696Z DEBUG --- mbedtls: fetching, need revision v3.5.2-ncs2
2024-09-07T15:50:04.420Z DEBUG === updating oberon-psa-crypto (modules/crypto/oberon-psa-crypto):
2024-09-07T15:50:04.472Z INFO Updating oberon-psa-crypto repository for v2.7.0
2024-09-07T15:50:04.508Z DEBUG --- oberon-psa-crypto: initializing
2024-09-07T15:50:04.534Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto/.git/
2024-09-07T15:50:04.699Z DEBUG --- oberon-psa-crypto: fetching, need revision e0800ec5283ba89b2619919ef1889d98a9a79132
2024-09-07T15:50:12.533Z DEBUG === updating nrfxlib (nrfxlib):
2024-09-07T15:50:12.587Z INFO Updating nrfxlib repository for v2.7.0
2024-09-07T15:50:12.624Z DEBUG --- nrfxlib: initializing
2024-09-07T15:50:12.700Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/nrfxlib/.git/
2024-09-07T15:50:12.748Z DEBUG --- nrfxlib: fetching, need revision v2.7.0
2024-09-07T15:51:31.803Z DEBUG === updating trusted-firmware-m (modules/tee/tf-m/trusted-firmware-m):
2024-09-07T15:51:31.853Z INFO Updating trusted-firmware-m repository for v2.7.0
2024-09-07T15:51:31.887Z DEBUG --- trusted-firmware-m: initializing
2024-09-07T15:51:31.976Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m/.git/
2024-09-07T15:51:32.066Z DEBUG --- trusted-firmware-m: fetching, need revision v2.0.0-ncs2
2024-09-07T15:51:59.943Z DEBUG === updating psa-arch-tests (modules/tee/tf-m/psa-arch-tests):
2024-09-07T15:52:00.002Z INFO Updating psa-arch-tests repository for v2.7.0
2024-09-07T15:52:00.040Z DEBUG --- psa-arch-tests: initializing
2024-09-07T15:52:00.073Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/tee/tf-m/psa-arch-tests/.git/
2024-09-07T15:52:00.180Z DEBUG --- psa-arch-tests: fetching, need revision 94a349db22cd0e44136c281724ffc71b6e7391c3
2024-09-07T15:52:15.167Z DEBUG === updating matter (modules/lib/matter):
2024-09-07T15:52:15.218Z INFO Updating matter repository for v2.7.0
2024-09-07T15:52:15.255Z DEBUG --- matter: initializing
2024-09-07T15:52:15.308Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/matter/.git/
2024-09-07T15:52:15.411Z DEBUG --- matter: fetching, need revision v2.7.0
2024-09-07T15:55:22.725Z DEBUG nrf-802154: skipping inactive project
2024-09-07T15:55:22.774Z DEBUG === updating soc-hwmv1 (modules/soc-hwmv1):
2024-09-07T15:55:22.775Z INFO Updating soc-hwmv1 repository for v2.7.0
2024-09-07T15:55:22.776Z DEBUG --- soc-hwmv1: initializing
2024-09-07T15:55:22.835Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/soc-hwmv1/.git/
2024-09-07T15:55:22.939Z DEBUG --- soc-hwmv1: fetching, need revision 32b1ee3e4576815bebf9ce3e8d63efe73bd89c62
2024-09-07T15:55:25.761Z DEBUG dragoon: skipping inactive project
2024-09-07T15:55:25.762Z DEBUG === updating cjson (modules/lib/cjson):
2024-09-07T15:55:25.763Z INFO Updating cjson repository for v2.7.0
2024-09-07T15:55:25.764Z DEBUG --- cjson: initializing
2024-09-07T15:55:25.888Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/cjson/.git/
2024-09-07T15:55:25.982Z DEBUG --- cjson: fetching, need revision c6af068b7f05207b28d68880740e4b9ec1e4b50a
2024-09-07T15:55:30.024Z DEBUG sidewalk: skipping inactive project
2024-09-07T15:55:30.066Z DEBUG find-my: skipping inactive project
2024-09-07T15:55:30.068Z DEBUG === updating azure-sdk-for-c (modules/lib/azure-sdk-for-c):
2024-09-07T15:55:30.069Z INFO Updating azure-sdk-for-c repository for v2.7.0
2024-09-07T15:55:30.069Z DEBUG --- azure-sdk-for-c: initializing
2024-09-07T15:55:30.122Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c/.git/
2024-09-07T15:55:30.290Z DEBUG --- azure-sdk-for-c: fetching, need revision 308c171cb4b5eed266649012a68406487ec81fb2
2024-09-07T15:55:36.509Z DEBUG === updating cirrus (modules/hal/cirrus-logic):
2024-09-07T15:55:36.553Z INFO Updating cirrus repository for v2.7.0
2024-09-07T15:55:36.584Z DEBUG --- cirrus: initializing
2024-09-07T15:55:36.697Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/cirrus-logic/.git/
2024-09-07T15:55:36.733Z DEBUG --- cirrus: fetching, need revision 3873a08377d93a479105a75ac390d3bbcd31d690
2024-09-07T15:55:44.479Z DEBUG === updating openthread (modules/lib/openthread):
2024-09-07T15:55:44.526Z INFO Updating openthread repository for v2.7.0
2024-09-07T15:55:44.563Z DEBUG --- openthread: initializing
2024-09-07T15:55:44.571Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/openthread/.git/
2024-09-07T15:55:44.698Z DEBUG --- openthread: fetching, need revision a57d927b0ace94972a49ea2672c9073b88b86377
2024-09-07T15:56:13.431Z DEBUG === updating suit-generator (modules/lib/suit-generator):
2024-09-07T15:56:13.475Z INFO Updating suit-generator repository for v2.7.0
2024-09-07T15:56:13.497Z DEBUG --- suit-generator: initializing
2024-09-07T15:56:13.788Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/suit-generator/.git/
2024-09-07T15:56:13.895Z DEBUG --- suit-generator: fetching, need revision v2.7.0
2024-09-07T15:56:17.653Z DEBUG === updating suit-processor (modules/lib/suit-processor):
2024-09-07T15:56:17.697Z INFO Updating suit-processor repository for v2.7.0
2024-09-07T15:56:17.735Z DEBUG --- suit-processor: initializing
2024-09-07T15:56:17.785Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/suit-processor/.git/
2024-09-07T15:56:17.886Z DEBUG --- suit-processor: fetching, need revision v2.7.0
2024-09-07T15:56:21.446Z DEBUG === updating cmock (test/cmock):
2024-09-07T15:56:21.447Z INFO Updating cmock repository for v2.7.0
2024-09-07T15:56:21.479Z DEBUG --- cmock: initializing
2024-09-07T15:56:21.547Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/test/cmock/.git/
2024-09-07T15:56:21.642Z DEBUG --- cmock: fetching, need revision f65066f15d8248e6dcb778efb8739904a4512087
2024-09-07T15:56:43.531Z DEBUG === updating memfault-firmware-sdk (modules/lib/memfault-firmware-sdk):
2024-09-07T15:56:43.578Z INFO Updating memfault-firmware-sdk repository for v2.7.0
2024-09-07T15:56:43.611Z DEBUG --- memfault-firmware-sdk: initializing
2024-09-07T15:56:43.643Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk/.git/
2024-09-07T15:56:43.757Z DEBUG --- memfault-firmware-sdk: fetching, need revision 1.6.0
2024-09-07T15:56:51.729Z DEBUG ant: skipping inactive project
2024-09-07T15:56:51.777Z DEBUG bme68x: skipping inactive project
2024-09-07T15:56:51.778Z DEBUG bsec: skipping inactive project
2024-09-07T15:56:51.778Z DEBUG === updating coremark (modules/benchmark/coremark):
2024-09-07T15:56:51.780Z INFO Updating coremark repository for v2.7.0
2024-09-07T15:56:51.780Z DEBUG --- coremark: initializing
2024-09-07T15:56:51.893Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/benchmark/coremark/.git/
2024-09-07T15:56:51.961Z DEBUG --- coremark: fetching, need revision d5fad6bd094899101a4e5fd53af7298160ced6ab
2024-09-07T15:56:57.495Z DEBUG === updating canopennode (modules/lib/canopennode):
2024-09-07T15:56:57.544Z INFO Updating canopennode repository for v2.7.0
2024-09-07T15:56:57.581Z DEBUG --- canopennode: initializing
2024-09-07T15:56:57.598Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/canopennode/.git/
2024-09-07T15:56:57.695Z DEBUG --- canopennode: fetching, need revision dec12fa3f0d790cafa8414a4c2930ea71ab72ffd
2024-09-07T15:57:01.155Z DEBUG === updating chre (modules/lib/chre):
2024-09-07T15:57:01.200Z INFO Updating chre repository for v2.7.0
2024-09-07T15:57:01.234Z DEBUG --- chre: initializing
2024-09-07T15:57:01.252Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/chre/.git/
2024-09-07T15:57:01.349Z DEBUG --- chre: fetching, need revision 3b32c76efee705af146124fb4190f71be5a4e36e
2024-09-07T15:57:11.308Z DEBUG === updating lz4 (modules/lib/lz4):
2024-09-07T15:57:11.356Z INFO Updating lz4 repository for v2.7.0
2024-09-07T15:57:11.389Z DEBUG --- lz4: initializing
2024-09-07T15:57:11.421Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/lz4/.git/
2024-09-07T15:57:11.546Z DEBUG --- lz4: fetching, need revision 8e303c264fc21c2116dc612658003a22e933124d
2024-09-07T15:57:17.901Z DEBUG === updating nanopb (modules/lib/nanopb):
2024-09-07T15:57:17.944Z INFO Updating nanopb repository for v2.7.0
2024-09-07T15:57:17.981Z DEBUG --- nanopb: initializing
2024-09-07T15:57:17.997Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/nanopb/.git/
2024-09-07T15:57:18.099Z DEBUG --- nanopb: fetching, need revision 7f88274070afa5edfaf608f4d8e32f3d3c1de139
2024-09-07T15:57:26.454Z DEBUG === updating tf-m-tests (modules/tee/tf-m/tf-m-tests):
2024-09-07T15:57:26.506Z INFO Updating tf-m-tests repository for v2.7.0
2024-09-07T15:57:26.541Z DEBUG --- tf-m-tests: initializing
2024-09-07T15:57:26.553Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/tee/tf-m/tf-m-tests/.git/
2024-09-07T15:57:26.698Z DEBUG --- tf-m-tests: fetching, need revision 85f533a4aa5b4fe31247676a923db7453eb4429c
2024-09-07T15:57:34.583Z DEBUG === updating zscilib (modules/lib/zscilib):
2024-09-07T15:57:34.633Z INFO Updating zscilib repository for v2.7.0
2024-09-07T15:57:34.672Z DEBUG --- zscilib: initializing
2024-09-07T15:57:34.750Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/zscilib/.git/
2024-09-07T15:57:34.807Z DEBUG --- zscilib: fetching, need revision ee1b287d9dd07208d2cc52284240ac25bb66eae3
2024-09-07T15:57:41.246Z DEBUG === updating cmsis (modules/hal/cmsis):
2024-09-07T15:57:41.290Z INFO Updating cmsis repository for v2.7.0
2024-09-07T15:57:41.327Z DEBUG --- cmsis: initializing
2024-09-07T15:57:41.348Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/cmsis/.git/
2024-09-07T15:57:41.495Z DEBUG --- cmsis: fetching, need revision 4b96cbb174678dcd3ca86e11e1f24bc5f8726da0
2024-09-07T15:57:46.802Z DEBUG === updating cmsis-dsp (modules/lib/cmsis-dsp):
2024-09-07T15:57:46.849Z INFO Updating cmsis-dsp repository for v2.7.0
2024-09-07T15:57:46.883Z DEBUG --- cmsis-dsp: initializing
2024-09-07T15:57:46.897Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/cmsis-dsp/.git/
2024-09-07T15:57:47.004Z DEBUG --- cmsis-dsp: fetching, need revision 6489e771e9c405f1763b52d64a3f17a1ec488ace
2024-09-07T15:58:11.797Z DEBUG === updating cmsis-nn (modules/lib/cmsis-nn):
2024-09-07T15:58:11.848Z INFO Updating cmsis-nn repository for v2.7.0
2024-09-07T15:58:11.876Z DEBUG --- cmsis-nn: initializing
2024-09-07T15:58:11.963Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/cmsis-nn/.git/
2024-09-07T15:58:12.058Z DEBUG --- cmsis-nn: fetching, need revision 0c8669d81381ccf3b1a01d699f3b68b50134a99f
2024-09-07T15:58:21.979Z DEBUG === updating edtt (tools/edtt):
2024-09-07T15:58:22.028Z INFO Updating edtt repository for v2.7.0
2024-09-07T15:58:22.064Z DEBUG --- edtt: initializing
2024-09-07T15:58:22.100Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/tools/edtt/.git/
2024-09-07T15:58:22.202Z DEBUG --- edtt: fetching, need revision 64e5105ad82390164fb73fc654be3f73a608209a
2024-09-07T15:58:26.000Z DEBUG === updating fatfs (modules/fs/fatfs):
2024-09-07T15:58:26.001Z INFO Updating fatfs repository for v2.7.0
2024-09-07T15:58:26.033Z DEBUG --- fatfs: initializing
2024-09-07T15:58:26.097Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/fs/fatfs/.git/
2024-09-07T15:58:26.196Z DEBUG --- fatfs: fetching, need revision 427159bf95ea49b7680facffaa29ad506b42709b
2024-09-07T15:58:28.639Z DEBUG === updating hal_nordic (modules/hal/nordic):
2024-09-07T15:58:28.640Z INFO Updating hal_nordic repository for v2.7.0
2024-09-07T15:58:28.671Z DEBUG --- hal_nordic: initializing
2024-09-07T15:58:28.733Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/nordic/.git/
2024-09-07T15:58:28.828Z DEBUG --- hal_nordic: fetching, need revision ab5cb2e2faeb1edfad7a25286dcb513929ae55da
2024-09-07T15:58:49.140Z DEBUG === updating hal_st (modules/hal/st):
2024-09-07T15:58:49.186Z INFO Updating hal_st repository for v2.7.0
2024-09-07T15:58:49.220Z DEBUG --- hal_st: initializing
2024-09-07T15:58:49.254Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/st/.git/
2024-09-07T15:58:49.363Z DEBUG --- hal_st: fetching, need revision b77157f6bc4395e398d90ab02a7d2cbc01ab2ce7
2024-09-07T15:59:03.378Z DEBUG === updating hal_wurthelektronik (modules/hal/wurthelektronik):
2024-09-07T15:59:03.424Z INFO Updating hal_wurthelektronik repository for v2.7.0
2024-09-07T15:59:03.458Z DEBUG --- hal_wurthelektronik: initializing
2024-09-07T15:59:03.561Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/wurthelektronik/.git/
2024-09-07T15:59:03.613Z DEBUG --- hal_wurthelektronik: fetching, need revision e5bcb2eac1bb9639ce13b4dafc78eb254e014342
2024-09-07T15:59:05.779Z DEBUG === updating libmetal (modules/hal/libmetal):
2024-09-07T15:59:05.781Z INFO Updating libmetal repository for v2.7.0
2024-09-07T15:59:05.814Z DEBUG --- libmetal: initializing
2024-09-07T15:59:05.897Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/hal/libmetal/.git/
2024-09-07T15:59:05.992Z DEBUG --- libmetal: fetching, need revision 243eed541b9c211a2ce8841c788e62ddce84425e
2024-09-07T15:59:10.365Z DEBUG === updating liblc3 (modules/lib/liblc3):
2024-09-07T15:59:10.411Z INFO Updating liblc3 repository for v2.7.0
2024-09-07T15:59:10.442Z DEBUG --- liblc3: initializing
2024-09-07T15:59:10.462Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/liblc3/.git/
2024-09-07T15:59:10.571Z DEBUG --- liblc3: fetching, need revision 1a5938ebaca4f13fe79ce074f5dee079783aa29f
2024-09-07T15:59:13.721Z DEBUG === updating littlefs (modules/fs/littlefs):
2024-09-07T15:59:13.768Z INFO Updating littlefs repository for v2.7.0
2024-09-07T15:59:13.803Z DEBUG --- littlefs: initializing
2024-09-07T15:59:13.916Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/fs/littlefs/.git/
2024-09-07T15:59:13.974Z DEBUG --- littlefs: fetching, need revision 408c16a909dd6cf128874a76f21c793798c9e423
2024-09-07T15:59:17.944Z DEBUG === updating loramac-node (modules/lib/loramac-node):
2024-09-07T15:59:17.989Z INFO Updating loramac-node repository for v2.7.0
2024-09-07T15:59:18.021Z DEBUG --- loramac-node: initializing
2024-09-07T15:59:18.051Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/loramac-node/.git/
2024-09-07T15:59:18.152Z DEBUG --- loramac-node: fetching, need revision fb00b383072518c918e2258b0916c996f2d4eebe
2024-09-07T15:59:30.753Z DEBUG === updating lvgl (modules/lib/gui/lvgl):
2024-09-07T15:59:30.801Z INFO Updating lvgl repository for v2.7.0
2024-09-07T15:59:30.835Z DEBUG --- lvgl: initializing
2024-09-07T15:59:30.852Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/gui/lvgl/.git/
2024-09-07T15:59:30.954Z DEBUG --- lvgl: fetching, need revision 2b498e6f36d6b82ae1da12c8b7742e318624ecf5
2024-09-07T16:00:03.394Z DEBUG === updating mipi-sys-t (modules/debug/mipi-sys-t):
2024-09-07T16:00:03.441Z INFO Updating mipi-sys-t repository for v2.7.0
2024-09-07T16:00:03.479Z DEBUG --- mipi-sys-t: initializing
2024-09-07T16:00:03.574Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/debug/mipi-sys-t/.git/
2024-09-07T16:00:03.639Z DEBUG --- mipi-sys-t: fetching, need revision 71ace1f5caa03e56c8740a09863e685efb4b2360
2024-09-07T16:00:07.723Z DEBUG === updating net-tools (tools/net-tools):
2024-09-07T16:00:07.766Z INFO Updating net-tools repository for v2.7.0
2024-09-07T16:00:07.801Z DEBUG --- net-tools: initializing
2024-09-07T16:00:07.887Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/tools/net-tools/.git/
2024-09-07T16:00:07.933Z DEBUG --- net-tools: fetching, need revision 7c7a856814d7f27509c8511fef14cec21f7d0c30
2024-09-07T16:00:13.940Z DEBUG === updating nrf_hw_models (modules/bsim_hw_models/nrf_hw_models):
2024-09-07T16:00:13.983Z INFO Updating nrf_hw_models repository for v2.7.0
2024-09-07T16:00:14.001Z DEBUG --- nrf_hw_models: initializing
2024-09-07T16:00:14.369Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/bsim_hw_models/nrf_hw_models/.git/
2024-09-07T16:00:14.464Z DEBUG --- nrf_hw_models: fetching, need revision 36b12714a5ed32450d907c89bb118f6280da3483
2024-09-07T16:00:19.679Z DEBUG === updating open-amp (modules/lib/open-amp):
2024-09-07T16:00:19.729Z INFO Updating open-amp repository for v2.7.0
2024-09-07T16:00:19.764Z DEBUG --- open-amp: initializing
2024-09-07T16:00:19.792Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/open-amp/.git/
2024-09-07T16:00:19.914Z DEBUG --- open-amp: fetching, need revision da78aea63159771956fe0c9263f2e6985b66e9d5
2024-09-07T16:00:23.550Z DEBUG === updating picolibc (modules/lib/picolibc):
2024-09-07T16:00:23.552Z INFO Updating picolibc repository for v2.7.0
2024-09-07T16:00:23.581Z DEBUG --- picolibc: initializing
2024-09-07T16:00:23.665Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/picolibc/.git/
2024-09-07T16:00:23.767Z DEBUG --- picolibc: fetching, need revision 764ef4e401a8f4c6a86ab723533841f072885a5b
2024-09-07T16:01:48.384Z DEBUG === updating segger (modules/debug/segger):
2024-09-07T16:01:48.434Z INFO Updating segger repository for v2.7.0
2024-09-07T16:01:48.471Z DEBUG --- segger: initializing
2024-09-07T16:01:48.508Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/debug/segger/.git/
2024-09-07T16:01:48.711Z DEBUG --- segger: fetching, need revision b011c45b585e097d95d9cf93edf4f2e01588d3cd
2024-09-07T16:01:50.859Z DEBUG === updating tinycrypt (modules/crypto/tinycrypt):
2024-09-07T16:01:50.860Z INFO Updating tinycrypt repository for v2.7.0
2024-09-07T16:01:50.891Z DEBUG --- tinycrypt: initializing
2024-09-07T16:01:50.955Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/crypto/tinycrypt/.git/
2024-09-07T16:01:51.091Z DEBUG --- tinycrypt: fetching, need revision 1012a3ebee18c15ede5efc8332ee2fc37817670f
2024-09-07T16:01:55.620Z DEBUG === updating uoscore-uedhoc (modules/lib/uoscore-uedhoc):
2024-09-07T16:01:55.668Z INFO Updating uoscore-uedhoc repository for v2.7.0
2024-09-07T16:01:55.712Z DEBUG --- uoscore-uedhoc: initializing
2024-09-07T16:01:55.741Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc/.git/
2024-09-07T16:01:55.886Z DEBUG --- uoscore-uedhoc: fetching, need revision 150f4eb2955eaf36ac0f9519d4f4f58d5ade5740
2024-09-07T16:02:00.626Z DEBUG === updating zcbor (modules/lib/zcbor):
2024-09-07T16:02:00.674Z INFO Updating zcbor repository for v2.7.0
2024-09-07T16:02:00.710Z DEBUG --- zcbor: initializing
2024-09-07T16:02:00.742Z DEBUG Initialized empty Git repository in C:/ncs/v2.7.0/modules/lib/zcbor/.git/
2024-09-07T16:02:00.851Z DEBUG --- zcbor: fetching, need revision 75d088037eb237b18e7ec1f47c9ce494b9b95aab
2024-09-07T16:02:06.145Z DEBUG babblesim_base: skipping inactive project
2024-09-07T16:02:06.179Z DEBUG babblesim_ext_2G4_libPhyComv1: skipping inactive project
2024-09-07T16:02:06.180Z DEBUG babblesim_ext_2G4_phy_v1: skipping inactive project
2024-09-07T16:02:06.180Z DEBUG babblesim_ext_2G4_channel_NtNcable: skipping inactive project
2024-09-07T16:02:06.181Z DEBUG babblesim_ext_2G4_channel_multiatt: skipping inactive project
2024-09-07T16:02:06.181Z DEBUG babblesim_ext_2G4_modem_magic: skipping inactive project
2024-09-07T16:02:06.182Z DEBUG babblesim_ext_2G4_modem_BLE_simple: skipping inactive project
2024-09-07T16:02:06.182Z DEBUG babblesim_ext_2G4_device_burst_interferer: skipping inactive project
2024-09-07T16:02:06.182Z DEBUG babblesim_ext_2G4_device_WLAN_actmod: skipping inactive project
2024-09-07T16:02:06.183Z DEBUG babblesim_ext_2G4_device_playback: skipping inactive project
2024-09-07T16:02:06.183Z DEBUG babblesim_ext_2G4_device_playbackv2: skipping inactive project
2024-09-07T16:02:06.184Z DEBUG babblesim_ext_libCryptov1: skipping inactive project
2024-09-07T16:02:06.247Z ERROR Failed to clone the repositories: Error: From https://github.com/nrfconnect/sdk-zephyr
 * tag                       v3.6.99-ncs2              -> FETCH_HEAD
 * [new tag]                 v1.13.99-ncs1             -> v1.13.99-ncs1
 * [new tag]                 v1.13.99-ncs1-rc1         -> v1.13.99-ncs1-rc1
 * [new tag]                 v1.13.99-ncs2             -> v1.13.99-ncs2
 * [new tag]                 v1.13.99-ncs2-rc1         -> v1.13.99-ncs2-rc1
 * [new tag]                 v1.13.99-ncs2-rc2         -> v1.13.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs1             -> v1.14.99-ncs1
 * [new tag]                 v1.14.99-ncs1-rc1         -> v1.14.99-ncs1-rc1
 * [new tag]                 v1.14.99-ncs1-rc2         -> v1.14.99-ncs1-rc2
 * [new tag]                 v1.14.99-ncs2             -> v1.14.99-ncs2
 * [new tag]                 v1.14.99-ncs2-rc1         -> v1.14.99-ncs2-rc1
 * [new tag]                 v1.14.99-ncs2-rc2         -> v1.14.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs2-rc3         -> v1.14.99-ncs2-rc3
 * [new tag]                 v1.14.99-ncs2-rc4         -> v1.14.99-ncs2-rc4
 * [new tag]                 v1.14.99-ncs3-snapshot1   -> v1.14.99-ncs3-snapshot1
 * [new tag]                 v1.14.99-ncs3-snapshot2   -> v1.14.99-ncs3-snapshot2
 * [new tag]                 v2.0.99-ncs1              -> v2.0.99-ncs1
 * [new tag]                 v2.0.99-ncs1-rc1          -> v2.0.99-ncs1-rc1
 * [new tag]                 v2.0.99-ncs1-rc2          -> v2.0.99-ncs1-rc2
 * [new tag]                 v2.0.99-ncs1-rc3          -> v2.0.99-ncs1-rc3
 * [new tag]                 v2.0.99-ncs1-snapshot1    -> v2.0.99-ncs1-snapshot1
 * [new tag]                 v2.1.0-ncs1-snapshot1     -> v2.1.0-ncs1-snapshot1
 * [new tag]                 v2.1.99-ncs1              -> v2.1.99-ncs1
 * [new tag]                 v2.1.99-ncs1-rc1          -> v2.1.99-ncs1-rc1
 * [new tag]                 v2.1.99-ncs1-rc2          -> v2.1.99-ncs1-rc2
 * [new tag]                 v2.1.99-ncs1-snapshot1    -> v2.1.99-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs1           -> v2.3.0-rc1-ncs1
 * [new tag]                 v2.3.0-rc1-ncs1-rc1       -> v2.3.0-rc1-ncs1-rc1
 * [new tag]                 v2.3.0-rc1-ncs1-rc2       -> v2.3.0-rc1-ncs1-rc2
 * [new tag]                 v2.3.0-rc1-ncs1-rc3       -> v2.3.0-rc1-ncs1-rc3
 * [new tag]                 v2.3.0-rc1-ncs1-snapshot1 -> v2.3.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs2           -> v2.3.0-rc1-ncs2
 * [new tag]                 v2.3.0-rc1-ncs3           -> v2.3.0-rc1-ncs3
 * [new tag]                 v2.4.0-ncs1               -> v2.4.0-ncs1
 * [new tag]                 v2.4.0-ncs1-rc1           -> v2.4.0-ncs1-rc1
 * [new tag]                 v2.4.0-ncs1-rc2           -> v2.4.0-ncs1-rc2
 * [new tag]                 v2.4.0-ncs1-snapshot1     -> v2.4.0-ncs1-snapshot1
 * [new tag]                 v2.4.0-ncs2               -> v2.4.0-ncs2
 * [new tag]                 v2.4.0-ncs2-rc1           -> v2.4.0-ncs2-rc1
 * [new tag]                 v2.4.99-ncs1              -> v2.4.99-ncs1
 * [new tag]                 v2.4.99-ncs1-rc1          -> v2.4.99-ncs1-rc1
 * [new tag]                 v2.4.99-ncs1-snapshot1    -> v2.4.99-ncs1-snapshot1
 * [new tag]                 v2.4.99-ncs2              -> v2.4.99-ncs2
 * [new tag]                 v2.4.99-ncs2-1            -> v2.4.99-ncs2-1
 * [new tag]                 v2.4.99-ncs2-rc1          -> v2.4.99-ncs2-rc1
 * [new tag]                 v2.6.0-ncs1-rc3           -> v2.6.0-ncs1-rc3
 * [new tag]                 v2.6.0-rc1-ncs1           -> v2.6.0-rc1-ncs1
 * [new tag]                 v2.6.0-rc1-ncs1-rc1       -> v2.6.0-rc1-ncs1-rc1
 * [new tag]                 v2.6.0-rc1-ncs1-snapshot1 -> v2.6.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.6.99-ncs1              -> v2.6.99-ncs1
 * [new tag]                 v2.6.99-ncs1-1            -> v2.6.99-ncs1-1
 * [new tag]                 v2.6.99-ncs1-rc1          -> v2.6.99-ncs1-rc1
 * [new tag]                 v2.6.99-ncs1-rc2          -> v2.6.99-ncs1-rc2
 * [new tag]                 v2.6.99-ncs1-snapshot1    -> v2.6.99-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1               -> v2.7.0-ncs1
 * [new tag]                 v2.7.0-ncs1-rc1           -> v2.7.0-ncs1-rc1
 * [new tag]                 v2.7.0-ncs1-rc2           -> v2.7.0-ncs1-rc2
 * [new tag]                 v2.7.0-ncs1-snapshot1     -> v2.7.0-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1-snapshot2     -> v2.7.0-ncs1-snapshot2
 * [new tag]                 v2.7.99-ncs1              -> v2.7.99-ncs1
 * [new tag]                 v2.7.99-ncs1-1            -> v2.7.99-ncs1-1
 * [new tag]                 v2.7.99-ncs1-rc1          -> v2.7.99-ncs1-rc1
 * [new tag]                 v2.7.99-ncs1-rc2          -> v2.7.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1              -> v3.0.99-ncs1
 * [new tag]                 v3.0.99-ncs1-1            -> v3.0.99-ncs1-1
 * [new tag]                 v3.0.99-ncs1-rc1          -> v3.0.99-ncs1-rc1
 * [new tag]                 v3.0.99-ncs1-rc2          -> v3.0.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1-snapshot1    -> v3.0.99-ncs1-snapshot1
 * [new tag]                 v3.1.99-ncs1              -> v3.1.99-ncs1
 * [new tag]                 v3.1.99-ncs1-1            -> v3.1.99-ncs1-1
 * [new tag]                 v3.1.99-ncs1-2            -> v3.1.99-ncs1-2
 * [new tag]                 v3.1.99-ncs1-3            -> v3.1.99-ncs1-3
 * [new tag]                 v3.1.99-ncs1-rc1          -> v3.1.99-ncs1-rc1
 * [new tag]                 v3.1.99-ncs1-rc2          -> v3.1.99-ncs1-rc2
 * [new tag]                 v3.1.99-ncs1-snapshot1    -> v3.1.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs1              -> v3.2.99-ncs1
 * [new tag]                 v3.2.99-ncs1-rc1          -> v3.2.99-ncs1-rc1
 * [new tag]                 v3.2.99-ncs1-rc2          -> v3.2.99-ncs1-rc2
 * [new tag]                 v3.2.99-ncs1-snapshot1    -> v3.2.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs2              -> v3.2.99-ncs2
 * [new tag]                 v3.2.99-ncs2-rc1          -> v3.2.99-ncs2-rc1
 * [new tag]                 v3.2.99-ncs2-rc2          -> v3.2.99-ncs2-rc2
 * [new tag]                 v3.2.99-ncs2-snapshot1    -> v3.2.99-ncs2-snapshot1
 * [new tag]                 v3.3.99-ncs1              -> v3.3.99-ncs1
 * [new tag]                 v3.3.99-ncs1-1            -> v3.3.99-ncs1-1
 * [new tag]                 v3.3.99-ncs1-2            -> v3.3.99-ncs1-2
 * [new tag]                 v3.3.99-ncs1-3            -> v3.3.99-ncs1-3
 * [new tag]                 v3.3.99-ncs1-rc1          -> v3.3.99-ncs1-rc1
 * [new tag]                 v3.3.99-ncs1-rc2          -> v3.3.99-ncs1-rc2
 * [new tag]                 v3.3.99-ncs1-snapshot1    -> v3.3.99-ncs1-snapshot1
 * [new tag]                 v3.4.99-ncs1              -> v3.4.99-ncs1
 * [new tag]                 v3.4.99-ncs1-1            -> v3.4.99-ncs1-1
 * [new tag]                 v3.4.99-ncs1-1-rc1        -> v3.4.99-ncs1-1-rc1
 * [new tag]                 v3.4.99-ncs1-2            -> v3.4.99-ncs1-2
 * [new tag]                 v3.4.99-ncs1-3            -> v3.4.99-ncs1-3
 * [new tag]                 v3.4.99-ncs1-rc1          -> v3.4.99-ncs1-rc1
 * [new tag]                 v3.4.99-ncs1-rc2          -> v3.4.99-ncs1-rc2
 * [new tag]                 v3.4.99-ncs1-snapshot1    -> v3.4.99-ncs1-snapshot1
 * [new tag]                 v3.5.99-ncs1              -> v3.5.99-ncs1
 * [new tag]                 v3.5.99-ncs1-1            -> v3.5.99-ncs1-1
 * [new tag]                 v3.5.99-ncs1-rc1          -> v3.5.99-ncs1-rc1
 * [new tag]                 v3.5.99-ncs1-rc2          -> v3.5.99-ncs1-rc2
 * [new tag]                 v3.5.99-ncs1-snapshot1    -> v3.5.99-ncs1-snapshot1
 * [new tag]                 v3.6.99-ncs2              -> v3.6.99-ncs2
 * [new tag]                 v3.6.99-ncs2-rc1          -> v3.6.99-ncs2-rc1
 * [new tag]                 v3.6.99-ncs2-rc2          -> v3.6.99-ncs2-rc2
 * [new tag]                 v3.6.99-ncs2-rc3          -> v3.6.99-ncs2-rc3
 * [new tag]                 v3.6.99-ncs2-snapshot1    -> v3.6.99-ncs2-snapshot1
HEAD is now at 100befc70c7 [nrf fromtree] sysbuild: introduce sysbuild_root for root adjustment
From https://github.com/BabbleSim/bsim_west
 * [new branch]      v2.1       -> refs/west/v2.1
 * [new branch]      v2.1.1     -> refs/west/v2.1.1
 * [new branch]      v2.2       -> refs/west/v2.2
 * [new branch]      v2.2.1     -> refs/west/v2.2.1
 * [new branch]      v2.3       -> refs/west/v2.3
HEAD is now at 68f6282 developer_set: Remove .git suffix in paths
From https://github.com/nrfconnect/sdk-hostap
 * [new branch]          hcs                      -> refs/west/hcs
 * [new branch]          hostap_2_11_devel-ncs1-branch -> refs/west/hostap_2_11_devel-ncs1-branch
 * [new branch]          nrf700x-dev              -> refs/west/nrf700x-dev
 * [new branch]          nrf700x-test             -> refs/west/nrf700x-test
 * [new branch]          v2.5-branch              -> refs/west/v2.5-branch
 * [new branch]          v2.6-branch              -> refs/west/v2.6-branch
 * [new tag]             fix_sauce_tag_snapshot   -> fix_sauce_tag_snapshot
 * [new tag]             hostap_2_11_devel-ncs1   -> hostap_2_11_devel-ncs1
 * [new tag]             prepare_upmerge_snapshot -> prepare_upmerge_snapshot
HEAD is now at 6311fde66 [nrf noup] mbedtls: Fix memory leak
From https://github.com/nrfconnect/sdk-wi-fiquicktrack-controlappc
 * [new branch]      qt_v2.5.1      -> refs/west/qt_v2.5.1
 * [new tag]         R2.1-snapshot1 -> R2.1-snapshot1
 * [new tag]         pre_zephyr_separation_snapshot -> pre_zephyr_separation_snapshot
HEAD is now at 9f91589 [nrf noup] zephyr: Fix POSIX failures
From https://github.com/nrfconnect/sdk-mcuboot
 * tag                 v2.1.0-ncs1             -> FETCH_HEAD
 * [new tag]           v1.10.0-ncs1            -> v1.10.0-ncs1
 * [new tag]           v1.10.0-ncs1-1          -> v1.10.0-ncs1-1
 * [new tag]           v1.10.0-ncs1-rc1        -> v1.10.0-ncs1-rc1
 * [new tag]           v1.10.0-ncs1-rc2        -> v1.10.0-ncs1-rc2
 * [new tag]           v1.10.0-ncs1-snapshot1  -> v1.10.0-ncs1-snapshot1
 * [new tag]           v1.10.99-ncs1           -> v1.10.99-ncs1
 * [new tag]           v1.10.99-ncs1-1         -> v1.10.99-ncs1-1
 * [new tag]           v1.10.99-ncs1-1-rc1     -> v1.10.99-ncs1-1-rc1
 * [new tag]           v1.10.99-ncs1-2         -> v1.10.99-ncs1-2
 * [new tag]           v1.10.99-ncs1-3         -> v1.10.99-ncs1-3
 * [new tag]           v1.10.99-ncs1-rc1       -> v1.10.99-ncs1-rc1
 * [new tag]           v1.10.99-ncs1-rc2       -> v1.10.99-ncs1-rc2
 * [new tag]           v1.10.99-ncs1-snapshot1 -> v1.10.99-ncs1-snapshot1
 * [new tag]           v1.2.99-ncs1            -> v1.2.99-ncs1
 * [new tag]           v1.2.99-ncs1-rc1        -> v1.2.99-ncs1-rc1
 * [new tag]           v1.2.99-ncs2            -> v1.2.99-ncs2
 * [new tag]           v1.2.99-ncs2-rc1        -> v1.2.99-ncs2-rc1
 * [new tag]           v1.2.99-ncs2-rc2        -> v1.2.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs1            -> v1.3.99-ncs1
 * [new tag]           v1.3.99-ncs1-rc1        -> v1.3.99-ncs1-rc1
 * [new tag]           v1.3.99-ncs1-rc2        -> v1.3.99-ncs1-rc2
 * [new tag]           v1.3.99-ncs2            -> v1.3.99-ncs2
 * [new tag]           v1.3.99-ncs2-rc1        -> v1.3.99-ncs2-rc1
 * [new tag]           v1.3.99-ncs2-rc2        -> v1.3.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs2-rc3        -> v1.3.99-ncs2-rc3
 * [new tag]           v1.3.99-ncs2-rc4        -> v1.3.99-ncs2-rc4
 * [new tag]           v1.3.99-ncs3-snapshot1  -> v1.3.99-ncs3-snapshot1
 * [new tag]           v1.3.99-ncs3-snapshot2  -> v1.3.99-ncs3-snapshot2
 * [new tag]           v1.4.99-ncs1            -> v1.4.99-ncs1
 * [new tag]           v1.4.99-ncs1-rc1        -> v1.4.99-ncs1-rc1
 * [new tag]           v1.4.99-ncs1-rc2        -> v1.4.99-ncs1-rc2
 * [new tag]           v1.4.99-ncs1-rc3        -> v1.4.99-ncs1-rc3
 * [new tag]           v1.4.99-ncs1-snapshot1  -> v1.4.99-ncs1-snapshot1
 * [new tag]           v1.4.99-ncs2            -> v1.4.99-ncs2
 * [new tag]           v1.4.99-ncs2-rc1        -> v1.4.99-ncs2-rc1
 * [new tag]           v1.4.99-ncs2-rc2        -> v1.4.99-ncs2-rc2
 * [new tag]           v1.4.99-ncs2-snapshot1  -> v1.4.99-ncs2-snapshot1
 * [new tag]           v1.5.99-ncs1-rc1        -> v1.5.99-ncs1-rc1
 * [new tag]           v1.5.99-ncs1-rc2        -> v1.5.99-ncs1-rc2
 * [new tag]           v1.5.99-ncs1-rc3        -> v1.5.99-ncs1-rc3
 * [new tag]           v1.5.99-ncs1-snapshot1  -> v1.5.99-ncs1-snapshot1
 * [new tag]           v1.6.0-rc2-ncs1         -> v1.6.0-rc2-ncs1
 * [new tag]           v1.6.99-ncs1            -> v1.6.99-ncs1
 * [new tag]           v1.6.99-ncs1-rc1        -> v1.6.99-ncs1-rc1
 * [new tag]           v1.6.99-ncs1-rc2        -> v1.6.99-ncs1-rc2
 * [new tag]           v1.6.99-ncs1-snapshot1  -> v1.6.99-ncs1-snapshot1
 * [new tag]           v1.7.0-ncs1-rc1         -> v1.7.0-ncs1-rc1
 * [new tag]           v1.7.0-ncs1-rc3         -> v1.7.0-ncs1-rc3
 * [new tag]           v1.7.0-ncs1-snapshot1   -> v1.7.0-ncs1-snapshot1
 * [new tag]           v1.7.2                  -> v1.7.2
 * [new tag]           v1.7.2-ncs1             -> v1.7.2-ncs1
 * [new tag]           v1.7.2-ncs1-rc2         -> v1.7.2-ncs1-rc2
 * [new tag]           v1.7.2-ncs2             -> v1.7.2-ncs2
 * [new tag]           v1.7.2-ncs2-rc1         -> v1.7.2-ncs2-rc1
 * [new tag]           v1.7.2-ncs2-rc2         -> v1.7.2-ncs2-rc2
 * [new tag]           v1.7.2-ncs3             -> v1.7.2-ncs3
 * [new tag]           v1.7.2-ncs3-rc1         -> v1.7.2-ncs3-rc1
 * [new tag]           v1.7.2-ncs3-rc2         -> v1.7.2-ncs3-rc2
 * [new tag]           v1.7.99-ncs1            -> v1.7.99-ncs1
 * [new tag]           v1.7.99-ncs1-1          -> v1.7.99-ncs1-1
 * [new tag]           v1.7.99-ncs1-rc1        -> v1.7.99-ncs1-rc1
 * [new tag]           v1.7.99-ncs2            -> v1.7.99-ncs2
 * [new tag]           v1.7.99-ncs2-snapshot1  -> v1.7.99-ncs2-snapshot1
 * [new tag]           v1.7.99-ncs3            -> v1.7.99-ncs3
 * [new tag]           v1.7.99-ncs3-1          -> v1.7.99-ncs3-1
 * [new tag]           v1.7.99-ncs3-rc1        -> v1.7.99-ncs3-rc1
 * [new tag]           v1.7.99-ncs3-rc2        -> v1.7.99-ncs3-rc2
 * [new tag]           v1.7.99-ncs4            -> v1.7.99-ncs4
 * [new tag]           v1.7.99-ncs4-rc1        -> v1.7.99-ncs4-rc1
 * [new tag]           v1.7.99-ncs4-rc2        -> v1.7.99-ncs4-rc2
 * [new tag]           v1.8.99-ncs1            -> v1.8.99-ncs1
 * [new tag]           v1.8.99-ncs1-rc1        -> v1.8.99-ncs1-rc1
 * [new tag]           v1.8.99-ncs1-rc2        -> v1.8.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1            -> v1.9.99-ncs1
 * [new tag]           v1.9.99-ncs1-rc1        -> v1.9.99-ncs1-rc1
 * [new tag]           v1.9.99-ncs1-rc2        -> v1.9.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1-snapshot1  -> v1.9.99-ncs1-snapshot1
 * [new tag]           v1.9.99-ncs2            -> v1.9.99-ncs2
 * [new tag]           v1.9.99-ncs2-rc1        -> v1.9.99-ncs2-rc1
 * [new tag]           v1.9.99-ncs2-rc2        -> v1.9.99-ncs2-rc2
 * [new tag]           v1.9.99-ncs2-snapshot1  -> v1.9.99-ncs2-snapshot1
 * [new tag]           v1.9.99-ncs3            -> v1.9.99-ncs3
 * [new tag]           v1.9.99-ncs3-rc1        -> v1.9.99-ncs3-rc1
 * [new tag]           v1.9.99-ncs3-rc2        -> v1.9.99-ncs3-rc2
 * [new tag]           v1.9.99-ncs4            -> v1.9.99-ncs4
 * [new tag]           v1.9.99-ncs4-rc1        -> v1.9.99-ncs4-rc1
 * [new tag]           v1.9.99-ncs4-rc2        -> v1.9.99-ncs4-rc2
 * [new tag]           v1.9.99-ncs4-snapshot1  -> v1.9.99-ncs4-snapshot1
 * [new tag]           v1.9.99-ncs4-snapshot2  -> v1.9.99-ncs4-snapshot2
 * [new tag]           v2.0.99-ncs1-1          -> v2.0.99-ncs1-1
 * [new tag]           v2.1.0-ncs1             -> v2.1.0-ncs1
 * [new tag]           v2.1.0-ncs1-rc1         -> v2.1.0-ncs1-rc1
 * [new tag]           v2.1.0-ncs1-rc2         -> v2.1.0-ncs1-rc2
 * [new tag]           v2.1.0-ncs1-rc3         -> v2.1.0-ncs1-rc3
HEAD is now at daf2946a [nrf noup] boot/../loader: reboot after updating s0/s1
From https://github.com/laurencelundblade/QCBOR
 * [new branch]      BeforeSpiffyDecode -> refs/west/BeforeSpiffyDecode
 * [new branch]      CDE                -> refs/west/CDE
 * [new branch]      NaN                -> refs/west/NaN
 * [new branch]      arrays             -> refs/west/arrays
 * [new branch]      better_big_num     -> refs/west/better_big_num
 * [new branch]      const              -> refs/west/const
 * [new branch]      dev                -> refs/west/dev
 * [new branch]      disable            -> refs/west/disable
 * [new branch]      enter-array        -> refs/west/enter-array
 * [new branch]      makewarn           -> refs/west/makewarn
 * [new branch]      mappie             -> refs/west/mappie
 * [new branch]      newtag             -> refs/west/newtag
 * [new branch]      ub-example         -> refs/west/ub-example
 * [new branch]      versioning         -> refs/west/versioning
 * [new branch]      warn_in_tests      -> refs/west/warn_in_tests
 * [new tag]         v1.0               -> v1.0
 * [new tag]         v1.1               -> v1.1
 * [new tag]         v1.2               -> v1.2
 * [new tag]         v1.3               -> v1.3
 * [new tag]         v1.4               -> v1.4
 * [new tag]         v1.4.1             -> v1.4.1
HEAD is now at 751d365 restore inc/qcbor.h for backwards compatibility (#181)
From https://github.com/nrfconnect/sdk-mbedtls
 * tag                   v3.5.2-ncs2           -> FETCH_HEAD
 * [new tag]             mbedtls-2.26.0        -> mbedtls-2.26.0
 * [new tag]             v3.0.0-ncs1           -> v3.0.0-ncs1
 * [new tag]             v3.0.0-ncs1-rc2       -> v3.0.0-ncs1-rc2
 * [new tag]             v3.0.0-ncs2           -> v3.0.0-ncs2
 * [new tag]             v3.0.0-ncs2-rc1       -> v3.0.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs1           -> v3.1.0-ncs1
 * [new tag]             v3.1.0-ncs1-rc1       -> v3.1.0-ncs1-rc1
 * [new tag]             v3.1.0-ncs1-rc2       -> v3.1.0-ncs1-rc2
 * [new tag]             v3.1.0-ncs2           -> v3.1.0-ncs2
 * [new tag]             v3.1.0-ncs2-rc1       -> v3.1.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs2-rc2       -> v3.1.0-ncs2-rc2
 * [new tag]             v3.1.0-ncs3           -> v3.1.0-ncs3
 * [new tag]             v3.1.0-ncs3-rc1       -> v3.1.0-ncs3-rc1
 * [new tag]             v3.1.0-ncs3-rc2       -> v3.1.0-ncs3-rc2
 * [new tag]             v3.3.0-ncs1           -> v3.3.0-ncs1
 * [new tag]             v3.3.0-ncs1-1         -> v3.3.0-ncs1-1
 * [new tag]             v3.3.0-ncs1-rc1       -> v3.3.0-ncs1-rc1
 * [new tag]             v3.3.0-ncs1-rc2       -> v3.3.0-ncs1-rc2
 * [new tag]             v3.3.0-ncs1-snapshot1 -> v3.3.0-ncs1-snapshot1
 * [new tag]             v3.3.0-ncs2           -> v3.3.0-ncs2
 * [new tag]             v3.3.0-ncs2-1         -> v3.3.0-ncs2-1
 * [new tag]             v3.3.0-ncs2-1-rc1     -> v3.3.0-ncs2-1-rc1
 * [new tag]             v3.3.0-ncs2-2         -> v3.3.0-ncs2-2
 * [new tag]             v3.3.0-ncs2-3         -> v3.3.0-ncs2-3
 * [new tag]             v3.3.0-ncs2-rc1       -> v3.3.0-ncs2-rc1
 * [new tag]             v3.3.0-ncs2-rc2       -> v3.3.0-ncs2-rc2
 * [new tag]             v3.5.2-ncs1           -> v3.5.2-ncs1
 * [new tag]             v3.5.2-ncs1-1         -> v3.5.2-ncs1-1
 * [new tag]             v3.5.2-ncs1-rc1       -> v3.5.2-ncs1-rc1
 * [new tag]             v3.5.2-ncs1-rc2       -> v3.5.2-ncs1-rc2
 * [new tag]             v3.5.2-ncs1-snapshot1 -> v3.5.2-ncs1-snapshot1
 * [new tag]             v3.5.2-ncs2           -> v3.5.2-ncs2
 * [new tag]             v3.5.2-ncs2-rc1       -> v3.5.2-ncs2-rc1
 * [new tag]             v3.5.2-ncs2-rc2       -> v3.5.2-ncs2-rc2
 * [new tag]             v3.5.2-ncs2-rc3       -> v3.5.2-ncs2-rc3
 * [new tag]             v3.5.2-ncs2-snapshot1 -> v3.5.2-ncs2-snapshot1
HEAD is now at 72868c6f1 [nrf noup] Add MBEDTLS_PSA_CRYPTO_CLIENT support for TLS/DTLS and X.509
From https://github.com/nrfconnect/sdk-oberon-psa-crypto
 * [new branch]      add_test_spec -> refs/west/add_test_spec
 * [new branch]      oberon_west   -> refs/west/oberon_west
 * [new branch]      test          -> refs/west/test
HEAD is now at e0800ec [nrf noup] Allow import and destroy of builtin keys
From https://github.com/nrfconnect/sdk-nrfxlib
 * tag                 v2.7.0       -> FETCH_HEAD
 * [new tag]           v0.1.0       -> v0.1.0
 * [new tag]           v0.1.0-rc1   -> v0.1.0-rc1
 * [new tag]           v0.3.0       -> v0.3.0
 * [new tag]           v0.3.0-rc1   -> v0.3.0-rc1
 * [new tag]           v0.3.0-rc2   -> v0.3.0-rc2
 * [new tag]           v0.4.0       -> v0.4.0
 * [new tag]           v0.4.0-rc1   -> v0.4.0-rc1
 * [new tag]           v0.4.0-rc2   -> v0.4.0-rc2
 * [new tag]           v1.0.0       -> v1.0.0
 * [new tag]           v1.0.0-rc1   -> v1.0.0-rc1
 * [new tag]           v1.0.0-rc2   -> v1.0.0-rc2
 * [new tag]           v1.0.0-rc3   -> v1.0.0-rc3
 * [new tag]           v1.0.0-rc4   -> v1.0.0-rc4
 * [new tag]           v1.1.0       -> v1.1.0
 * [new tag]           v1.1.0-rc1   -> v1.1.0-rc1
 * [new tag]           v1.1.0-rc2   -> v1.1.0-rc2
 * [new tag]           v1.1.0-rc3   -> v1.1.0-rc3
 * [new tag]           v1.2.0       -> v1.2.0
 * [new tag]           v1.2.0-rc1   -> v1.2.0-rc1
 * [new tag]           v1.2.0-rc2   -> v1.2.0-rc2
 * [new tag]           v1.2.1       -> v1.2.1
 * [new tag]           v1.3.0       -> v1.3.0
 * [new tag]           v1.3.0-rc1   -> v1.3.0-rc1
 * [new tag]           v1.3.0-rc2   -> v1.3.0-rc2
 * [new tag]           v1.3.0-rc3   -> v1.3.0-rc3
 * [new tag]           v1.3.1       -> v1.3.1
 * [new tag]           v1.4.0       -> v1.4.0
 * [new tag]           v1.4.0-rc1   -> v1.4.0-rc1
 * [new tag]           v1.4.2       -> v1.4.2
 * [new tag]           v1.5.0       -> v1.5.0
 * [new tag]           v1.5.0-rc1   -> v1.5.0-rc1
 * [new tag]           v1.5.1       -> v1.5.1
 * [new tag]           v1.5.1-rc1   -> v1.5.1-rc1
 * [new tag]           v1.5.2       -> v1.5.2
 * [new tag]           v1.6.0       -> v1.6.0
 * [new tag]           v1.6.0-rc3   -> v1.6.0-rc3
 * [new tag]           v1.6.1       -> v1.6.1
 * [new tag]           v1.7.0       -> v1.7.0
 * [new tag]           v1.7.0-rc1   -> v1.7.0-rc1
 * [new tag]           v1.7.0-rc2   -> v1.7.0-rc2
 * [new tag]           v1.7.1       -> v1.7.1
 * [new tag]           v1.8.0       -> v1.8.0
 * [new tag]           v1.8.0-rc1   -> v1.8.0-rc1
 * [new tag]           v1.8.0-rc2   -> v1.8.0-rc2
 * [new tag]           v1.9.0       -> v1.9.0
 * [new tag]           v1.9.0-rc1   -> v1.9.0-rc1
 * [new tag]           v1.9.0-rc2   -> v1.9.0-rc2
 * [new tag]           v1.9.1       -> v1.9.1
 * [new tag]           v1.9.2       -> v1.9.2
 * [new tag]           v1.9.2-dev1  -> v1.9.2-dev1
 * [new tag]           v2.0.0       -> v2.0.0
 * [new tag]           v2.0.0-rc1   -> v2.0.0-rc1
 * [new tag]           v2.0.0-rc2   -> v2.0.0-rc2
 * [new tag]           v2.0.0-rc2-1 -> v2.0.0-rc2-1
 * [new tag]           v2.0.1       -> v2.0.1
 * [new tag]           v2.0.2       -> v2.0.2
 * [new tag]           v2.1.0       -> v2.1.0
 * [new tag]           v2.1.0-rc1   -> v2.1.0-rc1
 * [new tag]           v2.1.0-rc2   -> v2.1.0-rc2
 * [new tag]           v2.1.1       -> v2.1.1
 * [new tag]           v2.1.2       -> v2.1.2
 * [new tag]           v2.1.3       -> v2.1.3
 * [new tag]           v2.1.4       -> v2.1.4
 * [new tag]           v2.2.0       -> v2.2.0
 * [new tag]           v2.2.0-rc1   -> v2.2.0-rc1
 * [new tag]           v2.2.0-rc2   -> v2.2.0-rc2
 * [new tag]           v2.3.0       -> v2.3.0
 * [new tag]           v2.3.0-rc1   -> v2.3.0-rc1
 * [new tag]           v2.3.0-rc2   -> v2.3.0-rc2
 * [new tag]           v2.4.0       -> v2.4.0
 * [new tag]           v2.4.0-rc1   -> v2.4.0-rc1
 * [new tag]           v2.4.0-rc2   -> v2.4.0-rc2
 * [new tag]           v2.4.1       -> v2.4.1
 * [new tag]           v2.4.2       -> v2.4.2
 * [new tag]           v2.4.3       -> v2.4.3
 * [new tag]           v2.4.4       -> v2.4.4
 * [new tag]           v2.5.0       -> v2.5.0
 * [new tag]           v2.5.0-rc1   -> v2.5.0-rc1
 * [new tag]           v2.5.0-rc2   -> v2.5.0-rc2
 * [new tag]           v2.5.1       -> v2.5.1
 * [new tag]           v2.5.1-rc1   -> v2.5.1-rc1
 * [new tag]           v2.5.2       -> v2.5.2
 * [new tag]           v2.5.3       -> v2.5.3
 * [new tag]           v2.6.0       -> v2.6.0
 * [new tag]           v2.6.0-rc1   -> v2.6.0-rc1
 * [new tag]           v2.6.0-rc2   -> v2.6.0-rc2
 * [new tag]           v2.6.1       -> v2.6.1
 * [new tag]           v2.7.0       -> v2.7.0
 * [new tag]           v2.7.0-rc1   -> v2.7.0-rc1
 * [new tag]           v2.7.0-rc2   -> v2.7.0-rc2
 * [new tag]           v2.7.0-rc3   -> v2.7.0-rc3
HEAD is now at 37e2ac22 nrf_modem: doc: add info about PDN down when NRF_SO_KEEPOPEN is used
From https://github.com/nrfconnect/sdk-trusted-firmware-m
 * tag                   v2.0.0-ncs2            -> FETCH_HEAD
 * [new tag]             v1.2.99-ncs1-1         -> v1.2.99-ncs1-1
 * [new tag]             v1.3.99-ncs1-rc3       -> v1.3.99-ncs1-rc3
 * [new tag]             v1.3.99-ncs1-snapshot1 -> v1.3.99-ncs1-snapshot1
 * [new tag]             v1.3.99-ncs1-snapshot2 -> v1.3.99-ncs1-snapshot2
 * [new tag]             v1.3.99-ncs2-1         -> v1.3.99-ncs2-1
 * [new tag]             v1.3.99-ncs3           -> v1.3.99-ncs3
 * [new tag]             v1.3.99-ncs3-rc1       -> v1.3.99-ncs3-rc1
 * [new tag]             v1.3.99-ncs3-rc2       -> v1.3.99-ncs3-rc2
 * [new tag]             v1.5.0-ncs1            -> v1.5.0-ncs1
 * [new tag]             v1.5.0-ncs1-1          -> v1.5.0-ncs1-1
 * [new tag]             v1.5.0-ncs1-rc1        -> v1.5.0-ncs1-rc1
 * [new tag]             v1.5.0-ncs1-rc2        -> v1.5.0-ncs1-rc2
 * [new tag]             v1.5.0-ncs2            -> v1.5.0-ncs2
 * [new tag]             v1.5.0-ncs2-rc1        -> v1.5.0-ncs2-rc1
 * [new tag]             v1.5.0-ncs2-rc2        -> v1.5.0-ncs2-rc2
 * [new tag]             v1.5.0-ncs2-snapshot1  -> v1.5.0-ncs2-snapshot1
 * [new tag]             v1.6.0-ncs1            -> v1.6.0-ncs1
 * [new tag]             v1.6.0-ncs1-rc1        -> v1.6.0-ncs1-rc1
 * [new tag]             v1.6.0-ncs1-rc2        -> v1.6.0-ncs1-rc2
 * [new tag]             v1.6.0-ncs1-snapshot1  -> v1.6.0-ncs1-snapshot1
 * [new tag]             v1.6.0-ncs2            -> v1.6.0-ncs2
 * [new tag]             v1.6.0-ncs2-rc1        -> v1.6.0-ncs2-rc1
 * [new tag]             v1.6.0-ncs2-rc2        -> v1.6.0-ncs2-rc2
 * [new tag]             v1.6.0-ncs3            -> v1.6.0-ncs3
 * [new tag]             v1.6.0-ncs3-rc1        -> v1.6.0-ncs3-rc1
 * [new tag]             v1.6.0-ncs3-rc2        -> v1.6.0-ncs3-rc2
 * [new tag]             v1.7.0-ncs1            -> v1.7.0-ncs1
 * [new tag]             v1.7.0-ncs1-1          -> v1.7.0-ncs1-1
 * [new tag]             v1.7.0-ncs1-rc2        -> v1.7.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1            -> v1.8.0-ncs1
 * [new tag]             v1.8.0-ncs1-1          -> v1.8.0-ncs1-1
 * [new tag]             v1.8.0-ncs1-1-rc1      -> v1.8.0-ncs1-1-rc1
 * [new tag]             v1.8.0-ncs1-2          -> v1.8.0-ncs1-2
 * [new tag]             v1.8.0-ncs1-3          -> v1.8.0-ncs1-3
 * [new tag]             v1.8.0-ncs1-rc1        -> v1.8.0-ncs1-rc1
 * [new tag]             v1.8.0-ncs1-rc2        -> v1.8.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1-snapshot1  -> v1.8.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs1            -> v2.0.0-ncs1
 * [new tag]             v2.0.0-ncs1-1          -> v2.0.0-ncs1-1
 * [new tag]             v2.0.0-ncs1-rc1        -> v2.0.0-ncs1-rc1
 * [new tag]             v2.0.0-ncs1-rc2        -> v2.0.0-ncs1-rc2
 * [new tag]             v2.0.0-ncs1-snapshot1  -> v2.0.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs2            -> v2.0.0-ncs2
 * [new tag]             v2.0.0-ncs2-rc1        -> v2.0.0-ncs2-rc1
 * [new tag]             v2.0.0-ncs2-rc2        -> v2.0.0-ncs2-rc2
 * [new tag]             v2.0.0-ncs2-rc3        -> v2.0.0-ncs2-rc3
 * [new tag]             v2.0.0-ncs2-snapshot1  -> v2.0.0-ncs2-snapshot1
HEAD is now at 553c47a6a [nrf noup] Fix version warning
From https://github.com/nrfconnect/sdk-psa-arch-tests
 * [new branch]      54l_its         -> refs/west/54l_its
 * [new branch]      fix_wdt_address -> refs/west/fix_wdt_address
HEAD is now at 94a349d [nrf fromlist] Fix base address for the nrf watchdog
From https://github.com/nrfconnect/sdk-connectedhomeip
 * [new tag]               v1.6.99-20210901    -> v1.6.99-20210901
 * [new tag]               v1.6.99-snapshot1   -> v1.6.99-snapshot1
 * [new tag]               v1.7.99-20211125    -> v1.7.99-20211125
 * [new tag]               v1.9.99-matter-dev1 -> v1.9.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev1 -> v2.0.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev2 -> v2.0.99-matter-dev2
 * [new tag]               v2.1.0-snapshot1    -> v2.1.0-snapshot1
 * [new tag]               v2.2.0-snapshot1    -> v2.2.0-snapshot1
 * [new tag]               v2.3.0-snapshot1    -> v2.3.0-snapshot1
 * [new tag]               v2.4.99-snapshot1   -> v2.4.99-snapshot1
 * [new tag]               v2.5.99-dev1        -> v2.5.99-dev1
HEAD is now at 022f2c92f6 [nrf toup] Fix missing network band in scan response.
      4 [main] sh 802 dofork: child -1 - forked process 14856 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/ce3b5ff664/mingw64/libexec/git-core\git-submodule: fork: retry: Resource temporarily unavailable
      2 [main] sh (13364) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1351408/0x11E1408.
This problem is probably due to using incompatible versions of the cygwin DLL.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version.  The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution.  Rebooting is also suggested if you
are unable to find another cygwin DLL.
1136180 [main] sh 802 dofork: child -1 - forked process 13364 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (7712) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1351408/0x11E1408.
3280389 [main] sh 802 dofork: child -1 - forked process 7712 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      4 [main] sh (11948) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1351408/0x1111408.
7421927 [main] sh 802 dofork: child -1 - forked process 11948 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (10052) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1351408/0x1061408.
15560971 [main] sh 802 dofork: child -1 - forked process 10052 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/ce3b5ff664/mingw64/libexec/git-core\git-submodule: fork: Resource temporarily unavailable
From https://github.com/nrfconnect/sdk-soc-hwmv1
HEAD is now at 32b1ee3 soc: Update Kconfig.peripherals from sdk-zephyr bdda11b
From https://github.com/nrfconnect/sdk-cjson
 * [new tag]         v1.7.14    -> v1.7.14
HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
From https://github.com/nrfconnect/azure-sdk-for-c
HEAD is now at 308c171c [nrf fromlist] Make repository a Zephyr module
From https://github.com/nrfconnect/sdk-mcu-drivers
HEAD is now at 3873a08 Added missing curly brace for #ifdef __cplusplus
From https://github.com/nrfconnect/sdk-openthread
 * [new branch]          debug/tomaszkob89/key-rotation -> refs/west/debug/tomaszkob89/key-rotation
 * [new branch]          for-testing       -> refs/west/for-testing
 * [new branch]          v1.7-branch       -> refs/west/v1.7-branch
 * [new branch]          v1.9-branch       -> refs/west/v1.9-branch
 * [new branch]          v2.0-branch       -> refs/west/v2.0-branch
 * [new branch]          v2.4-branch       -> refs/west/v2.4-branch
 * [new tag]             thread-reference-20200818-ncs1-rc1 -> thread-reference-20200818-ncs1-rc1
 * [new tag]             thread-reference-20200818-ncs1-rc3 -> thread-reference-20200818-ncs1-rc3
 * [new tag]             v1.8.99-snapshot1 -> v1.8.99-snapshot1
 * [new tag]             v1.9.99-snapshot1 -> v1.9.99-snapshot1
HEAD is now at a57d927b0 [string] add `ParseDigit()`, `ParseHexDigit()`, and other helper functions (#10282)
From https://github.com/nrfconnect/suit-generator
HEAD is now at 3458313 feat: add binary file name value to template generator
From https://github.com/nrfconnect/suit-processor
HEAD is now at 4505925 Fix coverity issues for 2.7 release
From https://github.com/ThrowTheSwitch/cmock
 * [new branch]      branch_2_5_1           -> refs/west/branch_2_5_1
 * [new branch]      cmock_2_6_rc           -> refs/west/cmock_2_6_rc
 * [new branch]      feature/only_config_is_shared -> refs/west/feature/only_config_is_shared
 * [new branch]      reapply_329            -> refs/west/reapply_329
 * [new branch]      revert-329-master      -> refs/west/revert-329-master
 * [new branch]      test/switch_to_actions -> refs/west/test/switch_to_actions
 * [new tag]         v2.4.5                 -> v2.4.5
 * [new tag]         v2.4.6                 -> v2.4.6
HEAD is now at f65066f Merge pull request #404 from tz18/patch-1
      2 [main] sh (6748) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11B1408/0x1201408.
      2 [main] sh 128 dofork: child -1 - forked process 6748 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (3636) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11B1408/0x10E1408.
1154138 [main] sh 128 dofork: child -1 - forked process 3636 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (13440) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11B1408/0x1141408.
3284299 [main] sh 128 dofork: child -1 - forked process 13440 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (9560) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11B1408/0x1001408.
7412931 [main] sh 128 dofork: child -1 - forked process 9560 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (6088) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11B1408/0x1151408.
15562804 [main] sh 128 dofork: child -1 - forked process 6088 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
From https://github.com/memfault/memfault-firmware-sdk
 * tag               1.6.0      -> FETCH_HEAD
 * [new tag]         0.0.10     -> 0.0.10
 * [new tag]         0.0.11     -> 0.0.11
 * [new tag]         0.0.12     -> 0.0.12
 * [new tag]         0.0.13     -> 0.0.13
 * [new tag]         0.0.14     -> 0.0.14
 * [new tag]         0.0.15     -> 0.0.15
 * [new tag]         0.0.16     -> 0.0.16
 * [new tag]         0.0.17     -> 0.0.17
 * [new tag]         0.0.18     -> 0.0.18
 * [new tag]         0.0.2      -> 0.0.2
 * [new tag]         0.0.3      -> 0.0.3
 * [new tag]         0.0.4      -> 0.0.4
 * [new tag]         0.0.5      -> 0.0.5
 * [new tag]         0.0.6      -> 0.0.6
 * [new tag]         0.0.7      -> 0.0.7
 * [new tag]         0.0.8      -> 0.0.8
 * [new tag]         0.0.9      -> 0.0.9
 * [new tag]         0.10.0     -> 0.10.0
 * [new tag]         0.10.1     -> 0.10.1
 * [new tag]         0.11.0     -> 0.11.0
 * [new tag]         0.11.1     -> 0.11.1
 * [new tag]         0.11.2     -> 0.11.2
 * [new tag]         0.11.3     -> 0.11.3
 * [new tag]         0.11.4     -> 0.11.4
 * [new tag]         0.12.0     -> 0.12.0
 * [new tag]         0.13.0     -> 0.13.0
 * [new tag]         0.13.1     -> 0.13.1
 * [new tag]         0.14.0     -> 0.14.0
 * [new tag]         0.15.0     -> 0.15.0
 * [new tag]         0.16.0     -> 0.16.0
 * [new tag]         0.16.1     -> 0.16.1
 * [new tag]         0.17.0     -> 0.17.0
 * [new tag]         0.17.1     -> 0.17.1
 * [new tag]         0.18.0     -> 0.18.0
 * [new tag]         0.19.0     -> 0.19.0
 * [new tag]         0.2.1      -> 0.2.1
 * [new tag]         0.2.2      -> 0.2.2
 * [new tag]         0.2.3      -> 0.2.3
 * [new tag]         0.2.4      -> 0.2.4
 * [new tag]         0.2.5      -> 0.2.5
 * [new tag]         0.20.0     -> 0.20.0
 * [new tag]         0.20.1     -> 0.20.1
 * [new tag]         0.20.2     -> 0.20.2
 * [new tag]         0.21.0     -> 0.21.0
 * [new tag]         0.21.1     -> 0.21.1
 * [new tag]         0.22.0     -> 0.22.0
 * [new tag]         0.23.0     -> 0.23.0
 * [new tag]         0.24.0     -> 0.24.0
 * [new tag]         0.24.1     -> 0.24.1
 * [new tag]         0.24.2     -> 0.24.2
 * [new tag]         0.25.0     -> 0.25.0
 * [new tag]         0.26.0     -> 0.26.0
 * [new tag]         0.26.1     -> 0.26.1
 * [new tag]         0.27.0     -> 0.27.0
 * [new tag]         0.27.1     -> 0.27.1
 * [new tag]         0.27.2     -> 0.27.2
 * [new tag]         0.27.3     -> 0.27.3
 * [new tag]         0.28.0     -> 0.28.0
 * [new tag]         0.28.1     -> 0.28.1
 * [new tag]         0.28.2     -> 0.28.2
 * [new tag]         0.29.0     -> 0.29.0
 * [new tag]         0.29.1     -> 0.29.1
 * [new tag]         0.3.2      -> 0.3.2
 * [new tag]         0.3.3      -> 0.3.3
 * [new tag]         0.3.4      -> 0.3.4
 * [new tag]         0.30.0     -> 0.30.0
 * [new tag]         0.30.1     -> 0.30.1
 * [new tag]         0.30.2     -> 0.30.2
 * [new tag]         0.30.3     -> 0.30.3
 * [new tag]         0.30.4     -> 0.30.4
 * [new tag]         0.30.5     -> 0.30.5
 * [new tag]         0.31.0     -> 0.31.0
 * [new tag]         0.31.1     -> 0.31.1
 * [new tag]         0.31.2     -> 0.31.2
 * [new tag]         0.31.3     -> 0.31.3
 * [new tag]         0.31.4     -> 0.31.4
 * [new tag]         0.31.5     -> 0.31.5
 * [new tag]         0.32.0     -> 0.32.0
 * [new tag]         0.32.1     -> 0.32.1
 * [new tag]         0.32.2     -> 0.32.2
 * [new tag]         0.33.0     -> 0.33.0
 * [new tag]         0.33.1     -> 0.33.1
 * [new tag]         0.33.2     -> 0.33.2
 * [new tag]         0.33.3     -> 0.33.3
 * [new tag]         0.33.4     -> 0.33.4
 * [new tag]         0.33.5     -> 0.33.5
 * [new tag]         0.34.0     -> 0.34.0
 * [new tag]         0.34.1     -> 0.34.1
 * [new tag]         0.34.2     -> 0.34.2
 * [new tag]         0.35.0     -> 0.35.0
 * [new tag]         0.36.0     -> 0.36.0
 * [new tag]         0.36.1     -> 0.36.1
 * [new tag]         0.37.0     -> 0.37.0
 * [new tag]         0.37.1     -> 0.37.1
 * [new tag]         0.37.2     -> 0.37.2
 * [new tag]         0.38.0     -> 0.38.0
 * [new tag]         0.39.0     -> 0.39.0
 * [new tag]         0.39.1     -> 0.39.1
 * [new tag]         0.4.1      -> 0.4.1
 * [new tag]         0.4.2      -> 0.4.2
 * [new tag]         0.40.0     -> 0.40.0
 * [new tag]         0.41.0     -> 0.41.0
 * [new tag]         0.41.1     -> 0.41.1
 * [new tag]         0.41.2     -> 0.41.2
 * [new tag]         0.42.0     -> 0.42.0
 * [new tag]         0.42.1     -> 0.42.1
 * [new tag]         0.43.0     -> 0.43.0
 * [new tag]         0.43.1     -> 0.43.1
 * [new tag]         0.43.2     -> 0.43.2
 * [new tag]         0.43.3     -> 0.43.3
 * [new tag]         0.6.1      -> 0.6.1
 * [new tag]         0.7.0      -> 0.7.0
 * [new tag]         0.7.1      -> 0.7.1
 * [new tag]         0.7.2      -> 0.7.2
 * [new tag]         0.7.3      -> 0.7.3
 * [new tag]         0.8.2      -> 0.8.2
 * [new tag]         0.9.1      -> 0.9.1
 * [new tag]         0.9.2      -> 0.9.2
 * [new tag]         0.9.3      -> 0.9.3
 * [new tag]         1.0.0      -> 1.0.0
 * [new tag]         1.0.1      -> 1.0.1
 * [new tag]         1.1.0      -> 1.1.0
 * [new tag]         1.1.1      -> 1.1.1
 * [new tag]         1.1.2      -> 1.1.2
 * [new tag]         1.1.3      -> 1.1.3
 * [new tag]         1.10.0     -> 1.10.0
 * [new tag]         1.10.1     -> 1.10.1
 * [new tag]         1.11.0     -> 1.11.0
 * [new tag]         1.11.1     -> 1.11.1
 * [new tag]         1.11.2     -> 1.11.2
 * [new tag]         1.11.3     -> 1.11.3
 * [new tag]         1.2.0      -> 1.2.0
 * [new tag]         1.2.1      -> 1.2.1
 * [new tag]         1.2.2      -> 1.2.2
 * [new tag]         1.2.3      -> 1.2.3
 * [new tag]         1.2.4      -> 1.2.4
 * [new tag]         1.2.5      -> 1.2.5
 * [new tag]         1.3.0      -> 1.3.0
 * [new tag]         1.3.1      -> 1.3.1
 * [new tag]         1.3.2      -> 1.3.2
 * [new tag]         1.3.3      -> 1.3.3
 * [new tag]         1.3.4      -> 1.3.4
 * [new tag]         1.3.5      -> 1.3.5
 * [new tag]         1.4.0      -> 1.4.0
 * [new tag]         1.4.1      -> 1.4.1
 * [new tag]         1.4.2      -> 1.4.2
 * [new tag]         1.4.3      -> 1.4.3
 * [new tag]         1.4.4      -> 1.4.4
 * [new tag]         1.5.0      -> 1.5.0
 * [new tag]         1.5.1      -> 1.5.1
 * [new tag]         1.5.2      -> 1.5.2
 * [new tag]         1.6.0      -> 1.6.0
 * [new tag]         1.6.1      -> 1.6.1
 * [new tag]         1.6.2      -> 1.6.2
 * [new tag]         1.7.0      -> 1.7.0
 * [new tag]         1.7.1      -> 1.7.1
 * [new tag]         1.7.2      -> 1.7.2
 * [new tag]         1.7.3      -> 1.7.3
 * [new tag]         1.7.4      -> 1.7.4
 * [new tag]         1.7.5      -> 1.7.5
 * [new tag]         1.7.6      -> 1.7.6
 * [new tag]         1.7.7      -> 1.7.7
 * [new tag]         1.8.0      -> 1.8.0
 * [new tag]         1.8.1      -> 1.8.1
 * [new tag]         1.9.0      -> 1.9.0
 * [new tag]         1.9.1      -> 1.9.1
 * [new tag]         1.9.2      -> 1.9.2
 * [new tag]         1.9.3      -> 1.9.3
 * [new tag]         1.9.4      -> 1.9.4
HEAD is now at 3d51c80 Memfault Firmware SDK 1.6.0 (Build 5464)
From https://github.com/eembc/coremark
 * [new branch]      128b-pointer -> refs/west/128b-pointer
 * [new branch]      posix-make   -> refs/west/posix-make
 * [new tag]         v1.01        -> v1.01
HEAD is now at d5fad6b Merge pull request #51 from volodymyr-bondarchuk/zephyr
From https://github.com/zephyrproject-rtos/canopennode
 * [new tag]         zephyr-snapshot-1 -> zephyr-snapshot-1
HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t()
From https://github.com/zephyrproject-rtos/chre
HEAD is now at 3b32c76e zephyr: link the .unstable_id data in ROM
From https://github.com/zephyrproject-rtos/lz4
 * [new tag]         lz4-r130   -> lz4-r130
 * [new tag]         r116       -> r116
 * [new tag]         r117       -> r117
 * [new tag]         r118       -> r118
 * [new tag]         r119       -> r119
 * [new tag]         r120       -> r120
 * [new tag]         r121       -> r121
 * [new tag]         r122       -> r122
 * [new tag]         r123       -> r123
 * [new tag]         r124       -> r124
 * [new tag]         r125       -> r125
 * [new tag]         r126       -> r126
 * [new tag]         r127       -> r127
 * [new tag]         r128       -> r128
 * [new tag]         r129       -> r129
 * [new tag]         r130       -> r130
 * [new tag]         r131       -> r131
 * [new tag]         rc129v0    -> rc129v0
 * [new tag]         v1.7.3     -> v1.7.3
 * [new tag]         v1.7.4     -> v1.7.4
 * [new tag]         v1.7.4.2   -> v1.7.4.2
 * [new tag]         v1.7.5     -> v1.7.5
 * [new tag]         v1.8.1     -> v1.8.1
 * [new tag]         v1.8.1.2   -> v1.8.1.2
 * [new tag]         v1.8.2     -> v1.8.2
 * [new tag]         v1.8.3     -> v1.8.3
 * [new tag]         v1.9.3     -> v1.9.3
HEAD is now at 8e303c2 zephyr: make this repo a zephyr module
From https://github.com/zephyrproject-rtos/nanopb
 * [new branch]      cifuzz_test4           -> refs/west/cifuzz_test4
 * [new branch]      dev_dynamic_nanopb_pb2 -> refs/west/dev_dynamic_nanopb_pb2
 * [new branch]      dev_markdown_docs      -> refs/west/dev_markdown_docs
 * [new branch]      maintenance_0.1        -> refs/west/maintenance_0.1
 * [new branch]      maintenance_0.2        -> refs/west/maintenance_0.2
 * [new branch]      maintenance_0.3        -> refs/west/maintenance_0.3
 * [new tag]         0.2.9.5                -> 0.2.9.5
 * [new tag]         0.3.6                  -> 0.3.6
 * [new tag]         0.3.7                  -> 0.3.7
 * [new tag]         0.3.8                  -> 0.3.8
 * [new tag]         0.3.9                  -> 0.3.9
 * [new tag]         0.3.9.1                -> 0.3.9.1
 * [new tag]         0.3.9.2                -> 0.3.9.2
 * [new tag]         0.3.9.3                -> 0.3.9.3
 * [new tag]         0.3.9.4                -> 0.3.9.4
 * [new tag]         0.3.9.5                -> 0.3.9.5
 * [new tag]         0.3.9.6                -> 0.3.9.6
 * [new tag]         0.3.9.7                -> 0.3.9.7
 * [new tag]         0.3.9.8                -> 0.3.9.8
 * [new tag]         0.4.3                  -> 0.4.3
 * [new tag]         0.4.4                  -> 0.4.4
 * [new tag]         0.4.5                  -> 0.4.5
 * [new tag]         nanopb-0.1.0           -> nanopb-0.1.0
 * [new tag]         nanopb-0.1.1           -> nanopb-0.1.1
 * [new tag]         nanopb-0.1.2           -> nanopb-0.1.2
 * [new tag]         nanopb-0.1.3           -> nanopb-0.1.3
 * [new tag]         nanopb-0.1.4           -> nanopb-0.1.4
 * [new tag]         nanopb-0.1.5           -> nanopb-0.1.5
 * [new tag]         nanopb-0.1.6           -> nanopb-0.1.6
 * [new tag]         nanopb-0.1.7           -> nanopb-0.1.7
 * [new tag]         nanopb-0.1.8           -> nanopb-0.1.8
 * [new tag]         nanopb-0.1.9           -> nanopb-0.1.9
 * [new tag]         nanopb-0.1.9.1         -> nanopb-0.1.9.1
 * [new tag]         nanopb-0.2.0           -> nanopb-0.2.0
 * [new tag]         nanopb-0.2.1           -> nanopb-0.2.1
 * [new tag]         nanopb-0.2.2           -> nanopb-0.2.2
 * [new tag]         nanopb-0.2.3           -> nanopb-0.2.3
 * [new tag]         nanopb-0.2.4           -> nanopb-0.2.4
 * [new tag]         nanopb-0.2.5           -> nanopb-0.2.5
 * [new tag]         nanopb-0.2.6           -> nanopb-0.2.6
 * [new tag]         nanopb-0.2.7           -> nanopb-0.2.7
 * [new tag]         nanopb-0.2.8           -> nanopb-0.2.8
 * [new tag]         nanopb-0.2.9           -> nanopb-0.2.9
 * [new tag]         nanopb-0.2.9.1         -> nanopb-0.2.9.1
 * [new tag]         nanopb-0.2.9.2         -> nanopb-0.2.9.2
 * [new tag]         nanopb-0.2.9.3         -> nanopb-0.2.9.3
 * [new tag]         nanopb-0.2.9.4         -> nanopb-0.2.9.4
 * [new tag]         nanopb-0.2.9.5         -> nanopb-0.2.9.5
 * [new tag]         nanopb-0.3.0           -> nanopb-0.3.0
 * [new tag]         nanopb-0.3.1           -> nanopb-0.3.1
 * [new tag]         nanopb-0.3.2           -> nanopb-0.3.2
 * [new tag]         nanopb-0.3.3           -> nanopb-0.3.3
 * [new tag]         nanopb-0.3.4           -> nanopb-0.3.4
 * [new tag]         nanopb-0.3.5           -> nanopb-0.3.5
 * [new tag]         nanopb-0.3.6           -> nanopb-0.3.6
 * [new tag]         nanopb-0.3.7           -> nanopb-0.3.7
 * [new tag]         nanopb-0.3.8           -> nanopb-0.3.8
 * [new tag]         nanopb-0.3.9           -> nanopb-0.3.9
 * [new tag]         nanopb-0.3.9.1         -> nanopb-0.3.9.1
 * [new tag]         nanopb-0.3.9.2         -> nanopb-0.3.9.2
 * [new tag]         nanopb-0.3.9.3         -> nanopb-0.3.9.3
 * [new tag]         nanopb-0.3.9.4         -> nanopb-0.3.9.4
 * [new tag]         nanopb-0.3.9.5         -> nanopb-0.3.9.5
 * [new tag]         nanopb-0.3.9.6         -> nanopb-0.3.9.6
 * [new tag]         nanopb-0.3.9.7         -> nanopb-0.3.9.7
 * [new tag]         nanopb-0.3.9.8         -> nanopb-0.3.9.8
 * [new tag]         nanopb-0.4.0           -> nanopb-0.4.0
 * [new tag]         nanopb-0.4.0-dev       -> nanopb-0.4.0-dev
 * [new tag]         nanopb-0.4.1           -> nanopb-0.4.1
 * [new tag]         nanopb-0.4.2           -> nanopb-0.4.2
 * [new tag]         nanopb-0.4.3           -> nanopb-0.4.3
 * [new tag]         nanopb-0.4.4           -> nanopb-0.4.4
 * [new tag]         nanopb-0.4.5           -> nanopb-0.4.5
HEAD is now at 7f88274 Add migration note about CMake protoc default (#958)
From https://github.com/zephyrproject-rtos/tf-m-tests
 * [new branch]      main          -> refs/west/main
 * [new branch]      release/1.7.x -> refs/west/release/1.7.x
HEAD is now at 85f533a Crypto: Use RSA key in PSA format
From https://github.com/zephyrproject-rtos/zscilib
 * [new branch]      gh-pages   -> refs/west/gh-pages
 * [new branch]      master     -> refs/west/master
 * [new branch]      revert-38-fix_zephyr_3_1 -> refs/west/revert-38-fix_zephyr_3_1
 * [new tag]         v0.2.0-rc1 -> v0.2.0-rc1
HEAD is now at ee1b287 samples/tests: Update for hwmv2 board names
From https://github.com/zephyrproject-rtos/cmsis
HEAD is now at 4b96cbb doc: Update documentations for CMSIS 5.9.0
From https://github.com/zephyrproject-rtos/cmsis-dsp
 * [new branch]        zephyr     -> refs/west/zephyr
HEAD is now at 6489e771 do not generate warnings when scalar functions are used with MVE
From https://github.com/zephyrproject-rtos/cmsis-nn
 * [new branch]      zephyr-v6.0.0 -> refs/west/zephyr-v6.0.0
HEAD is now at 0c8669d Merge pull request #1 from XenuIsWatching/zephyr
From https://github.com/zephyrproject-rtos/edtt
 * [new branch]      le-audio      -> refs/west/le-audio
 * [new branch]      public_master -> refs/west/public_master
HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop
From https://github.com/zephyrproject-rtos/fatfs
 * [new branch]      v1.14-branch -> refs/west/v1.14-branch
HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE
From https://github.com/zephyrproject-rtos/hal_nordic
 * [new branch]      dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3 -> refs/west/dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3
 * [new tag]         nrfx-2.10.0  -> nrfx-2.10.0
 * [new tag]         nrfx-2.11.0  -> nrfx-2.11.0
 * [new tag]         nrfx-3.0.0   -> nrfx-3.0.0
HEAD is now at ab5cb2e nrfx: drivers: nrfx_gpiote: move enabling GPIOTE port interrupt
From https://github.com/zephyrproject-rtos/hal_st
HEAD is now at b77157f drivers: sensor: st: Move to vendor subdirectory
From https://github.com/zephyrproject-rtos/hal_wurthelektronik
HEAD is now at e5bcb2e Update WE sensors SDK to version 2.5.0
From https://github.com/zephyrproject-rtos/libmetal
HEAD is now at 243eed5 lib: update libmetal to SHA f55c02a7b582
From https://github.com/zephyrproject-rtos/liblc3
HEAD is now at 1a5938e meson: Bump to version 1.0.4
From https://github.com/zephyrproject-rtos/littlefs
 * [new tag]         littlefs-v2.1.0 -> littlefs-v2.1.0
 * [new tag]         littlefs-v2.1.1 -> littlefs-v2.1.1
 * [new tag]         littlefs-v2.1.2 -> littlefs-v2.1.2
 * [new tag]         littlefs-v2.1.3 -> littlefs-v2.1.3
 * [new tag]         littlefs-v2.1.4 -> littlefs-v2.1.4
 * [new tag]         littlefs-v2.2.0 -> littlefs-v2.2.0
HEAD is now at 408c16a Merge pull request #14 from de-nordic/update-to-v2.8.1
From https://github.com/zephyrproject-rtos/loramac-node
 * [new branch]        v4.5.2-zephyr -> refs/west/v4.5.2-zephyr
 * [new branch]        v4.6.0-zephyr -> refs/west/v4.6.0-zephyr
 * [new branch]        v4.7.0-zephyr -> refs/west/v4.7.0-zephyr
 * [new branch]        zephyr-v2.6   -> refs/west/zephyr-v2.6
 * [new tag]           4.4.2-rc.4    -> 4.4.2-rc.4
 * [new tag]           V3.4          -> V3.4
 * [new tag]           v2.0          -> v2.0
 * [new tag]           v2.1          -> v2.1
 * [new tag]           v2.2          -> v2.2
 * [new tag]           v2.3.RC1      -> v2.3.RC1
 * [new tag]           v2.3.RC2      -> v2.3.RC2
 * [new tag]           v3.0          -> v3.0
 * [new tag]           v3.1          -> v3.1
 * [new tag]           v3.2          -> v3.2
 * [new tag]           v3.3          -> v3.3
 * [new tag]           v3.4.1        -> v3.4.1
 * [new tag]           v4.0.0        -> v4.0.0
 * [new tag]           v4.1.0        -> v4.1.0
 * [new tag]           v4.2.0        -> v4.2.0
 * [new tag]           v4.3.0        -> v4.3.0
 * [new tag]           v4.3.1        -> v4.3.1
 * [new tag]           v4.3.2        -> v4.3.2
 * [new tag]           v4.4.0        -> v4.4.0
 * [new tag]           v4.4.1        -> v4.4.1
 * [new tag]           v4.4.2        -> v4.4.2
 * [new tag]           v4.4.2-rc.1   -> v4.4.2-rc.1
 * [new tag]           v4.4.2-rc.2   -> v4.4.2-rc.2
 * [new tag]           v4.4.2-rc.3   -> v4.4.2-rc.3
 * [new tag]           v4.4.2-rc.5   -> v4.4.2-rc.5
 * [new tag]           v4.4.2-rc.6   -> v4.4.2-rc.6
 * [new tag]           v4.4.2-rc.7   -> v4.4.2-rc.7
 * [new tag]           v4.4.3        -> v4.4.3
 * [new tag]           v4.4.3_zephyr -> v4.4.3_zephyr
HEAD is now at fb00b383 zephyr: configure FragDecoder using Kconfig
From https://github.com/zephyrproject-rtos/lvgl
HEAD is now at 2b498e6f Merge pull request #51 from faxe1008/upddate_lvgl_840
From https://github.com/zephyrproject-rtos/mipi-sys-t
HEAD is now at 71ace1f mipi_syst: fix build error when having protocol timestamp disabled
From https://github.com/zephyrproject-rtos/net-tools
HEAD is now at 7c7a856 websocket-console: Add a helper script for websocket console
From https://github.com/zephyrproject-rtos/nrf_hw_models
HEAD is now at 36b1271 54L15: Added RRAMC, RRAM & UICR
From https://github.com/zephyrproject-rtos/open-amp
 * [new branch]      bump_v2024.05.0 -> refs/west/bump_v2024.05.0
 * [new tag]         old_master      -> old_master
HEAD is now at da78aea lib: update open-amp lib to release v2023.10.0
From https://github.com/zephyrproject-rtos/picolibc
 * [new branch]          Z-emcb-cygwin_daemon        -> refs/west/Z-emcb-cygwin_daemon
 * [new branch]          aarch64                     -> refs/west/aarch64
 * [new branch]          add-fakeroots-dir           -> refs/west/add-fakeroots-dir
 * [new branch]          amd64_to_x86_64             -> refs/west/amd64_to_x86_64
 * [new branch]          ancient-clang               -> refs/west/ancient-clang
 * [new branch]          arc-20081103-branch         -> refs/west/arc-20081103-branch
 * [new branch]          arc-insight_6_8-branch      -> refs/west/arc-insight_6_8-branch
 * [new branch]          arm-read-tp-cleanup         -> refs/west/arm-read-tp-cleanup
 * [new branch]          binutils-2_10-branch        -> refs/west/binutils-2_10-branch
 * [new branch]          binutils-2_11-branch        -> refs/west/binutils-2_11-branch
 * [new branch]          binutils-2_12-branch        -> refs/west/binutils-2_12-branch
 * [new branch]          binutils-2_13-branch        -> refs/west/binutils-2_13-branch
 * [new branch]          binutils-2_14-branch        -> refs/west/binutils-2_14-branch
 * [new branch]          binutils-2_15-branch        -> refs/west/binutils-2_15-branch
 * [new branch]          binutils-2_16-branch        -> refs/west/binutils-2_16-branch
 * [new branch]          binutils-2_17-branch        -> refs/west/binutils-2_17-branch
 * [new branch]          binutils-2_18-branch        -> refs/west/binutils-2_18-branch
 * [new branch]          binutils-2_19-branch        -> refs/west/binutils-2_19-branch
 * [new branch]          binutils-2_20-branch        -> refs/west/binutils-2_20-branch
 * [new branch]          binutils-2_21-branch        -> refs/west/binutils-2_21-branch
 * [new branch]          binutils-2_22-branch        -> refs/west/binutils-2_22-branch
 * [new branch]          binutils-2_22_branch        -> refs/west/binutils-2_22_branch
 * [new branch]          binutils-2_23-branch        -> refs/west/binutils-2_23-branch
 * [new branch]          binutils-2_24-branch        -> refs/west/binutils-2_24-branch
 * [new branch]          binutils-arc-20080908-branch -> refs/west/binutils-arc-20080908-branch
 * [new branch]          binutils-arc-20081103-branch -> refs/west/binutils-arc-20081103-branch
 * [new branch]          binutils-csl-2_17-branch    -> refs/west/binutils-csl-2_17-branch
 * [new branch]          binutils-csl-arm-2005q1-branch -> refs/west/binutils-csl-arm-2005q1-branch
 * [new branch]          binutils-csl-gxxpro-3_4-branch -> refs/west/binutils-csl-gxxpro-3_4-branch
 * [new branch]          branch-1.4.6                -> refs/west/branch-1.4.6
 * [new branch]          branch-1.8.4                -> refs/west/branch-1.8.4
 * [new branch]          c-sky                       -> refs/west/c-sky
 * [new branch]          cagney-unwind-20030108-branch -> refs/west/cagney-unwind-20030108-branch
 * [new branch]          cagney_bfdfile-20040213-branch -> refs/west/cagney_bfdfile-20040213-branch
 * [new branch]          cagney_bigcore-20040122-branch -> refs/west/cagney_bigcore-20040122-branch
 * [new branch]          cagney_convert-20030606-branch -> refs/west/cagney_convert-20030606-branch
 * [new branch]          cagney_fileio-20030521-branch -> refs/west/cagney_fileio-20030521-branch
 * [new branch]          cagney_frameaddr-20030403-branch -> refs/west/cagney_frameaddr-20030403-branch
 * [new branch]          cagney_framebase-20030326-branch -> refs/west/cagney_framebase-20030326-branch
 * [new branch]          cagney_lazyid-20030317-branch -> refs/west/cagney_lazyid-20030317-branch
 * [new branch]          cagney_offbyone-20030303-branch -> refs/west/cagney_offbyone-20030303-branch
 * [new branch]          cagney_regbuf-20020515-branch -> refs/west/cagney_regbuf-20020515-branch
 * [new branch]          cagney_sysregs-20020825-branch -> refs/west/cagney_sysregs-20020825-branch
 * [new branch]          cagney_tramp-20040309-branch -> refs/west/cagney_tramp-20040309-branch
 * [new branch]          cagney_writestrings-20030508-branch -> refs/west/cagney_writestrings-20030508-branch
 * [new branch]          cagney_x86i386-20030821-branch -> refs/west/cagney_x86i386-20030821-branch
 * [new branch]          callout                     -> refs/west/callout
 * [new branch]          carlton_dictionary-branch   -> refs/west/carlton_dictionary-branch
 * [new branch]          cgen-1_1-branch             -> refs/west/cgen-1_1-branch
 * [new branch]          cgf-deleteme                -> refs/west/cgf-deleteme
 * [new branch]          cgf-dev-branch              -> refs/west/cgf-dev-branch
 * [new branch]          cmake                       -> refs/west/cmake
 * [new branch]          cmake-no-tls                -> refs/west/cmake-no-tls
 * [new branch]          cmake-small-ultoa           -> refs/west/cmake-small-ultoa
 * [new branch]          cr-0x3b58                   -> refs/west/cr-0x3b58
 * [new branch]          cr-0x5e6                    -> refs/west/cr-0x5e6
 * [new branch]          cr-0x5ef                    -> refs/west/cr-0x5ef
 * [new branch]          cr-0x5f1                    -> refs/west/cr-0x5f1
 * [new branch]          cr-0x9b                     -> refs/west/cr-0x9b
 * [new branch]          cr-0x9c                     -> refs/west/cr-0x9c
 * [new branch]          cr-0x9d                     -> refs/west/cr-0x9d
 * [new branch]          cr-0x9e                     -> refs/west/cr-0x9e
 * [new branch]          csl-arm-20050325-branch     -> refs/west/csl-arm-20050325-branch
 * [new branch]          cv-branch                   -> refs/west/cv-branch
 * [new branch]          cv-branch-2                 -> refs/west/cv-branch-2
 * [new branch]          cv-post-1_7_9               -> refs/west/cv-post-1_7_9
 * [new branch]          cygnus                      -> refs/west/cygnus
 * [new branch]          cygwin-1-1-4                -> refs/west/cygwin-1-1-4
 * [new branch]          cygwin-1-3-1                -> refs/west/cygwin-1-3-1
 * [new branch]          cygwin-1-3-10-1             -> refs/west/cygwin-1-3-10-1
 * [new branch]          cygwin-1-3-11-3             -> refs/west/cygwin-1-3-11-3
 * [new branch]          cygwin-1-3-12-1             -> refs/west/cygwin-1-3-12-1
 * [new branch]          cygwin-1-3-13-1             -> refs/west/cygwin-1-3-13-1
 * [new branch]          cygwin-1-3-13-2             -> refs/west/cygwin-1-3-13-2
 * [new branch]          cygwin-1-3-14-1             -> refs/west/cygwin-1-3-14-1
 * [new branch]          cygwin-1-3-15-1             -> refs/west/cygwin-1-3-15-1
 * [new branch]          cygwin-1-3-16-1             -> refs/west/cygwin-1-3-16-1
 * [new branch]          cygwin-1-3-17-1             -> refs/west/cygwin-1-3-17-1
 * [new branch]          cygwin-1-3-18-1             -> refs/west/cygwin-1-3-18-1
 * [new branch]          cygwin-1-3-19-1             -> refs/west/cygwin-1-3-19-1
 * [new branch]          cygwin-1-3-2                -> refs/west/cygwin-1-3-2
 * [new branch]          cygwin-1-3-3                -> refs/west/cygwin-1-3-3
 * [new branch]          cygwin-1-3-4                -> refs/west/cygwin-1-3-4
 * [new branch]          cygwin-1-3-5                -> refs/west/cygwin-1-3-5
 * [new branch]          cygwin-1-3-5-2              -> refs/west/cygwin-1-3-5-2
 * [new branch]          cygwin-1-3-5-3              -> refs/west/cygwin-1-3-5-3
 * [new branch]          cygwin-1-3-6-1              -> refs/west/cygwin-1-3-6-1
 * [new branch]          cygwin-1-3-6-2              -> refs/west/cygwin-1-3-6-2
 * [new branch]          cygwin-1-3-6-3              -> refs/west/cygwin-1-3-6-3
 * [new branch]          cygwin-1-3-6-4              -> refs/west/cygwin-1-3-6-4
 * [new branch]          cygwin-1-3-6-5              -> refs/west/cygwin-1-3-6-5
 * [new branch]          cygwin-1-3-6-6              -> refs/west/cygwin-1-3-6-6
 * [new branch]          cygwin-1-3-7-1              -> refs/west/cygwin-1-3-7-1
 * [new branch]          cygwin-1-3-8-1              -> refs/west/cygwin-1-3-8-1
 * [new branch]          cygwin-1-3-9                -> refs/west/cygwin-1-3-9
 * [new branch]          cygwin-1_7_29-release-branchpoint -> refs/west/cygwin-1_7_29-release-branchpoint
 * [new branch]          cygwin-2.0                  -> refs/west/cygwin-2.0
 * [new branch]          cygwin-3_0-branch           -> refs/west/cygwin-3_0-branch
 * [new branch]          cygwin-64bit-branch         -> refs/west/cygwin-64bit-branch
 * [new branch]          cygwin-64bit-premerge-branch -> refs/west/cygwin-64bit-premerge-branch
 * [new branch]          cygwin-acl                  -> refs/west/cygwin-acl
 * [new branch]          cygwin_daemon               -> refs/west/cygwin_daemon
 * [new branch]          debian                      -> refs/west/debian
 * [new branch]          dje-cgen-play1-branch       -> refs/west/dje-cgen-play1-branch
 * [new branch]          docker-builder-packages.txt-hash -> refs/west/docker-builder-packages.txt-hash
 * [new branch]          drow-cplus-branch           -> refs/west/drow-cplus-branch
 * [new branch]          drow-reverse-20070409-branch -> refs/west/drow-reverse-20070409-branch
 * [new branch]          drow_intercu-20040221-branch -> refs/west/drow_intercu-20040221-branch
 * [new branch]          ezannoni_pie-20030916-branch -> refs/west/ezannoni_pie-20030916-branch
 * [new branch]          ezannoni_pie-20040323-branch -> refs/west/ezannoni_pie-20040323-branch
 * [new branch]          fifo_doover3                -> refs/west/fifo_doover3
 * [new branch]          fixes-newlib                -> refs/west/fixes-newlib
 * [new branch]          float-inlines               -> refs/west/float-inlines
 * [new branch]          fp-zeuch                    -> refs/west/fp-zeuch
 * [new branch]          gdb-csl-20060226-branch     -> refs/west/gdb-csl-20060226-branch
 * [new branch]          gdb-csl-arm-20051020-branch -> refs/west/gdb-csl-arm-20051020-branch
 * [new branch]          gdb-csl-available-20060303-branch -> refs/west/gdb-csl-available-20060303-branch
 * [new branch]          gdb-csl-gxxpro-6_3-branch   -> refs/west/gdb-csl-gxxpro-6_3-branch
 * [new branch]          gdb-csl-symbian-20060226-branch -> refs/west/gdb-csl-symbian-20060226-branch
 * [new branch]          gdb-premipsmulti-2000-06-06-branch -> refs/west/gdb-premipsmulti-2000-06-06-branch
 * [new branch]          gdb_5_0-2000-04-10-branch   -> refs/west/gdb_5_0-2000-04-10-branch
 * [new branch]          gdb_5_1-2001-07-29-branch   -> refs/west/gdb_5_1-2001-07-29-branch
 * [new branch]          gdb_5_1_0_1-2002-01-03-branch -> refs/west/gdb_5_1_0_1-2002-01-03-branch
 * [new branch]          gdb_5_2-branch              -> refs/west/gdb_5_2-branch
 * [new branch]          gdb_5_3-branch              -> refs/west/gdb_5_3-branch
 * [new branch]          gdb_6_0-branch              -> refs/west/gdb_6_0-branch
 * [new branch]          gdb_6_1-branch              -> refs/west/gdb_6_1-branch
 * [new branch]          gdb_6_2-branch              -> refs/west/gdb_6_2-branch
 * [new branch]          gdb_6_3-branch              -> refs/west/gdb_6_3-branch
 * [new branch]          gdb_6_4-branch              -> refs/west/gdb_6_4-branch
 * [new branch]          gdb_6_5-branch              -> refs/west/gdb_6_5-branch
 * [new branch]          gdb_6_6-branch              -> refs/west/gdb_6_6-branch
 * [new branch]          gdb_6_7-branch              -> refs/west/gdb_6_7-branch
 * [new branch]          gdb_6_8-branch              -> refs/west/gdb_6_8-branch
 * [new branch]          gdb_7_0-branch              -> refs/west/gdb_7_0-branch
 * [new branch]          gdb_7_1-branch              -> refs/west/gdb_7_1-branch
 * [new branch]          gdb_7_2-branch              -> refs/west/gdb_7_2-branch
 * [new branch]          gdb_7_3-branch              -> refs/west/gdb_7_3-branch
 * [new branch]          gdb_7_4-branch              -> refs/west/gdb_7_4-branch
 * [new branch]          gdb_7_5-branch              -> refs/west/gdb_7_5-branch
 * [new branch]          gdb_7_6-branch              -> refs/west/gdb_7_6-branch
 * [new branch]          gdb_s390-2001-09-26-branch  -> refs/west/gdb_s390-2001-09-26-branch
 * [new branch]          gh                          -> refs/west/gh
 * [new branch]          insight_6_8-branch          -> refs/west/insight_6_8-branch
 * [new branch]          interps-20030202-branch     -> refs/west/interps-20030202-branch
 * [new branch]          isblank-extern-inline       -> refs/west/isblank-extern-inline
 * [new branch]          jimb-gdb_6_2-e500-branch    -> refs/west/jimb-gdb_6_2-e500-branch
 * [new branch]          jimb-macro-020506-branch    -> refs/west/jimb-macro-020506-branch
 * [new branch]          jimb-ppc64-linux-20030509-branch -> refs/west/jimb-ppc64-linux-20030509-branch
 * [new branch]          jimb-ppc64-linux-20030528-branch -> refs/west/jimb-ppc64-linux-20030528-branch
 * [new branch]          jimb-ppc64-linux-20030613-branch -> refs/west/jimb-ppc64-linux-20030613-branch
 * [new branch]          jimb-rda-nptl-branch        -> refs/west/jimb-rda-nptl-branch
 * [new branch]          kettenis-i386newframe-20030308-branch -> refs/west/kettenis-i386newframe-20030308-branch
 * [new branch]          kettenis_i386newframe-20030406-branch -> refs/west/kettenis_i386newframe-20030406-branch
 * [new branch]          kettenis_i386newframe-20030419-branch -> refs/west/kettenis_i386newframe-20030419-branch
 * [new branch]          kettenis_sparc-20030918-branch -> refs/west/kettenis_sparc-20030918-branch
 * [new branch]          kseitz_interps-20020528-branch -> refs/west/kseitz_interps-20020528-branch
 * [new branch]          locking-docs                -> refs/west/locking-docs
 * [new branch]          mingw-std-ns-branch         -> refs/west/mingw-std-ns-branch
 * [new branch]          mingwex                     -> refs/west/mingwex
 * [new branch]          msnyder-checkpoint-072509-branch -> refs/west/msnyder-checkpoint-072509-branch
 * [new branch]          msnyder-fork-checkpoint-branch -> refs/west/msnyder-fork-checkpoint-branch
 * [new branch]          msnyder-reverse-20060331-branch -> refs/west/msnyder-reverse-20060331-branch
 * [new branch]          msnyder-reverse-20060502-branch -> refs/west/msnyder-reverse-20060502-branch
 * [new branch]          msnyder-reverse-20080609-branch -> refs/west/msnyder-reverse-20080609-branch
 * [new branch]          msnyder-tracepoint-checkpoint-branch -> refs/west/msnyder-tracepoint-checkpoint-branch
 * [new branch]          msp430                      -> refs/west/msp430
 * [new branch]          multiprocess-20081120-branch -> refs/west/multiprocess-20081120-branch
 * [new branch]          newlib                      -> refs/west/newlib
 * [new branch]          newlib-1_17_0-arc           -> refs/west/newlib-1_17_0-arc
 * [new branch]          newlib-autotools-branch     -> refs/west/newlib-autotools-branch
 * [new branch]          newlib-csl-20060320-branch  -> refs/west/newlib-csl-20060320-branch
 * [new branch]          nickrob-async-20060513-branch -> refs/west/nickrob-async-20060513-branch
 * [new branch]          non-linux-ln                -> refs/west/non-linux-ln
 * [new branch]          noreparent                  -> refs/west/noreparent
 * [new branch]          offbyone-20030313-branch    -> refs/west/offbyone-20030313-branch
 * [new branch]          pre-regex                   -> refs/west/pre-regex
 * [new branch]          pregp02r1                   -> refs/west/pregp02r1
 * [new branch]          readline_4_3-import-branch  -> refs/west/readline_4_3-import-branch
 * [new branch]          readline_5_1-import-branch  -> refs/west/readline_5_1-import-branch
 * [new branch]          reverse-20080717-branch     -> refs/west/reverse-20080717-branch
 * [new branch]          reverse-20080930-branch     -> refs/west/reverse-20080930-branch
 * [new branch]          reverse-20081226-branch     -> refs/west/reverse-20081226-branch
 * [new branch]          riscv-zicsr                 -> refs/west/riscv-zicsr
 * [new branch]          semihost-2.0-all            -> refs/west/semihost-2.0-all
 * [new branch]          sid-20020905-branch         -> refs/west/sid-20020905-branch
 * [new branch]          signal-rewrite              -> refs/west/signal-rewrite
 * [new branch]          sysroot-skip-checks         -> refs/west/sysroot-skip-checks
 * [new branch]          tcltk840-20020924-branch    -> refs/west/tcltk840-20020924-branch
 * [new branch]          tls                         -> refs/west/tls
 * [new branch]          topic/af_unix               -> refs/west/topic/af_unix
 * [new branch]          topic/ansification          -> refs/west/topic/ansification
 * [new branch]          topic/fifo                  -> refs/west/topic/fifo
 * [new branch]          topic/forkables             -> refs/west/topic/forkables
 * [new branch]          topic/locales               -> refs/west/topic/locales
 * [new branch]          topic/posix_acl_funcs       -> refs/west/topic/posix_acl_funcs
 * [new branch]          topic/ssp                   -> refs/west/topic/ssp
 * [new branch]          unlabeled-1.1.1.1.2         -> refs/west/unlabeled-1.1.1.1.2
 * [new branch]          unlabeled-1.100.2           -> refs/west/unlabeled-1.100.2
 * [new branch]          unlabeled-1.1010.2          -> refs/west/unlabeled-1.1010.2
 * [new branch]          unlabeled-1.1019.2          -> refs/west/unlabeled-1.1019.2
 * [new branch]          unlabeled-1.1042.2          -> refs/west/unlabeled-1.1042.2
 * [new branch]          unlabeled-1.1042.2.1.4      -> refs/west/unlabeled-1.1042.2.1.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4  -> refs/west/unlabeled-1.1042.2.1.4.2.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4.2.2 -> refs/west/unlabeled-1.1042.2.1.4.2.4.2.2
 * [new branch]          unlabeled-1.105.2           -> refs/west/unlabeled-1.105.2
 * [new branch]          unlabeled-1.106.2           -> refs/west/unlabeled-1.106.2
 * [new branch]          unlabeled-1.106.8           -> refs/west/unlabeled-1.106.8
 * [new branch]          unlabeled-1.107.12          -> refs/west/unlabeled-1.107.12
 * [new branch]          unlabeled-1.11.2            -> refs/west/unlabeled-1.11.2
 * [new branch]          unlabeled-1.112.4           -> refs/west/unlabeled-1.112.4
 * [new branch]          unlabeled-1.116.4           -> refs/west/unlabeled-1.116.4
 * [new branch]          unlabeled-1.12.20           -> refs/west/unlabeled-1.12.20
 * [new branch]          unlabeled-1.12.30           -> refs/west/unlabeled-1.12.30
 * [new branch]          unlabeled-1.12.4            -> refs/west/unlabeled-1.12.4
 * [new branch]          unlabeled-1.120.2           -> refs/west/unlabeled-1.120.2
 * [new branch]          unlabeled-1.125.2           -> refs/west/unlabeled-1.125.2
 * [new branch]          unlabeled-1.13.10           -> refs/west/unlabeled-1.13.10
 * [new branch]          unlabeled-1.13.2            -> refs/west/unlabeled-1.13.2
 * [new branch]          unlabeled-1.13.30           -> refs/west/unlabeled-1.13.30
 * [new branch]          unlabeled-1.13.4            -> refs/west/unlabeled-1.13.4
 * [new branch]          unlabeled-1.133.2           -> refs/west/unlabeled-1.133.2
 * [new branch]          unlabeled-1.134.4           -> refs/west/unlabeled-1.134.4
 * [new branch]          unlabeled-1.135.4           -> refs/west/unlabeled-1.135.4
 * [new branch]          unlabeled-1.1370.2          -> refs/west/unlabeled-1.1370.2
 * [new branch]          unlabeled-1.142.2           -> refs/west/unlabeled-1.142.2
 * [new branch]          unlabeled-1.143.4           -> refs/west/unlabeled-1.143.4
 * [new branch]          unlabeled-1.144.2           -> refs/west/unlabeled-1.144.2
 * [new branch]          unlabeled-1.15.10           -> refs/west/unlabeled-1.15.10
 * [new branch]          unlabeled-1.15.2            -> refs/west/unlabeled-1.15.2
 * [new branch]          unlabeled-1.1527.4          -> refs/west/unlabeled-1.1527.4
 * [new branch]          unlabeled-1.153.2           -> refs/west/unlabeled-1.153.2
 * [new branch]          unlabeled-1.1563.2          -> refs/west/unlabeled-1.1563.2
 * [new branch]          unlabeled-1.1656.2          -> refs/west/unlabeled-1.1656.2
 * [new branch]          unlabeled-1.167.4           -> refs/west/unlabeled-1.167.4
 * [new branch]          unlabeled-1.17.2            -> refs/west/unlabeled-1.17.2
 * [new branch]          unlabeled-1.17.4            -> refs/west/unlabeled-1.17.4
 * [new branch]          unlabeled-1.1710.2          -> refs/west/unlabeled-1.1710.2
 * [new branch]          unlabeled-1.172.4           -> refs/west/unlabeled-1.172.4
 * [new branch]          unlabeled-1.18.10           -> refs/west/unlabeled-1.18.10
 * [new branch]          unlabeled-1.18.2            -> refs/west/unlabeled-1.18.2
 * [new branch]          unlabeled-1.1806.2          -> refs/west/unlabeled-1.1806.2
 * [new branch]          unlabeled-1.1856.2          -> refs/west/unlabeled-1.1856.2
 * [new branch]          unlabeled-1.188.2           -> refs/west/unlabeled-1.188.2
 * [new branch]          unlabeled-1.188.2.1.8       -> refs/west/unlabeled-1.188.2.1.8
 * [new branch]          unlabeled-1.188.2.1.8.2.2   -> refs/west/unlabeled-1.188.2.1.8.2.2
 * [new branch]          unlabeled-1.19.12           -> refs/west/unlabeled-1.19.12
 * [new branch]          unlabeled-1.2.2             -> refs/west/unlabeled-1.2.2
 * [new branch]          unlabeled-1.20.4            -> refs/west/unlabeled-1.20.4
 * [new branch]          unlabeled-1.21.2            -> refs/west/unlabeled-1.21.2
 * [new branch]          unlabeled-1.21.4            -> refs/west/unlabeled-1.21.4
 * [new branch]          unlabeled-1.22.2            -> refs/west/unlabeled-1.22.2
 * [new branch]          unlabeled-1.22.4            -> refs/west/unlabeled-1.22.4
 * [new branch]          unlabeled-1.226.2           -> refs/west/unlabeled-1.226.2
 * [new branch]          unlabeled-1.23.16           -> refs/west/unlabeled-1.23.16
 * [new branch]          unlabeled-1.23.2            -> refs/west/unlabeled-1.23.2
 * [new branch]          unlabeled-1.23.4            -> refs/west/unlabeled-1.23.4
 * [new branch]          unlabeled-1.231.4           -> refs/west/unlabeled-1.231.4
 * [new branch]          unlabeled-1.234.16          -> refs/west/unlabeled-1.234.16
 * [new branch]          unlabeled-1.235.2           -> refs/west/unlabeled-1.235.2
 * [new branch]          unlabeled-1.238.4           -> refs/west/unlabeled-1.238.4
 * [new branch]          unlabeled-1.24.16           -> refs/west/unlabeled-1.24.16
 * [new branch]          unlabeled-1.24.2            -> refs/west/unlabeled-1.24.2
 * [new branch]          unlabeled-1.24.4            -> refs/west/unlabeled-1.24.4
 * [new branch]          unlabeled-1.248.2           -> refs/west/unlabeled-1.248.2
 * [new branch]          unlabeled-1.253.2           -> refs/west/unlabeled-1.253.2
 * [new branch]          unlabeled-1.27.12           -> refs/west/unlabeled-1.27.12
 * [new branch]          unlabeled-1.27.8            -> refs/west/unlabeled-1.27.8
 * [new branch]          unlabeled-1.30.4            -> refs/west/unlabeled-1.30.4
 * [new branch]          unlabeled-1.31.4            -> refs/west/unlabeled-1.31.4
 * [new branch]          unlabeled-1.32.16           -> refs/west/unlabeled-1.32.16
 * [new branch]          unlabeled-1.32.2            -> refs/west/unlabeled-1.32.2
 * [new branch]          unlabeled-1.35.12           -> refs/west/unlabeled-1.35.12
 * [new branch]          unlabeled-1.38.4            -> refs/west/unlabeled-1.38.4
 * [new branch]          unlabeled-1.39.2            -> refs/west/unlabeled-1.39.2
 * [new branch]          unlabeled-1.44.2            -> refs/west/unlabeled-1.44.2
 * [new branch]          unlabeled-1.44.4            -> refs/west/unlabeled-1.44.4
 * [new branch]          unlabeled-1.45.2            -> refs/west/unlabeled-1.45.2
 * [new branch]          unlabeled-1.45.8            -> refs/west/unlabeled-1.45.8
 * [new branch]          unlabeled-1.46.4            -> refs/west/unlabeled-1.46.4
 * [new branch]          unlabeled-1.48.16           -> refs/west/unlabeled-1.48.16
 * [new branch]          unlabeled-1.5.16            -> refs/west/unlabeled-1.5.16
 * [new branch]          unlabeled-1.5.2             -> refs/west/unlabeled-1.5.2
 * [new branch]          unlabeled-1.50.2            -> refs/west/unlabeled-1.50.2
 * [new branch]          unlabeled-1.50.6            -> refs/west/unlabeled-1.50.6
 * [new branch]          unlabeled-1.52.2            -> refs/west/unlabeled-1.52.2
 * [new branch]          unlabeled-1.53.6            -> refs/west/unlabeled-1.53.6
 * [new branch]          unlabeled-1.54.4            -> refs/west/unlabeled-1.54.4
 * [new branch]          unlabeled-1.64.2            -> refs/west/unlabeled-1.64.2
 * [new branch]          unlabeled-1.65.12           -> refs/west/unlabeled-1.65.12
 * [new branch]          unlabeled-1.65.4            -> refs/west/unlabeled-1.65.4
 * [new branch]          unlabeled-1.66.2            -> refs/west/unlabeled-1.66.2
 * [new branch]          unlabeled-1.69.4            -> refs/west/unlabeled-1.69.4
 * [new branch]          unlabeled-1.74.4            -> refs/west/unlabeled-1.74.4
 * [new branch]          unlabeled-1.75.4            -> refs/west/unlabeled-1.75.4
 * [new branch]          unlabeled-1.8.2             -> refs/west/unlabeled-1.8.2
 * [new branch]          unlabeled-1.81.2            -> refs/west/unlabeled-1.81.2
 * [new branch]          unlabeled-1.83.4            -> refs/west/unlabeled-1.83.4
 * [new branch]          unlabeled-1.86.2            -> refs/west/unlabeled-1.86.2
 * [new branch]          unlabeled-1.88.2            -> refs/west/unlabeled-1.88.2
 * [new branch]          unlabeled-1.90.2            -> refs/west/unlabeled-1.90.2
 * [new branch]          unlabeled-1.90.2.1.4        -> refs/west/unlabeled-1.90.2.1.4
 * [new branch]          unlabeled-1.93.2            -> refs/west/unlabeled-1.93.2
 * [new branch]          vendor                      -> refs/west/vendor
 * [new branch]          x86-more-32                 -> refs/west/x86-more-32
 * [new branch]          zephyr-add-library          -> refs/west/zephyr-add-library
 * [new branch]          zephyr-deprecated           -> refs/west/zephyr-deprecated
 * [new branch]          zephyr-hacks                -> refs/west/zephyr-hacks
 * [new branch]          zephyr-no-posix-define      -> refs/west/zephyr-no-posix-define
 * [new branch]          zephyr-posix                -> refs/west/zephyr-posix
 * [new branch]          zephyr-source               -> refs/west/zephyr-source
 * [new tag]             1.0                         -> 1.0
 * [new tag]             1.0-1                       -> 1.0-1
 * [new tag]             1.1                         -> 1.1
 * [new tag]             1.1-1                       -> 1.1-1
 * [new tag]             1.1-2                       -> 1.1-2
 * [new tag]             1.1.1-1                     -> 1.1.1-1
 * [new tag]             1.2                         -> 1.2
 * [new tag]             1.2-1                       -> 1.2-1
 * [new tag]             1.2.1-1                     -> 1.2.1-1
 * [new tag]             1.3                         -> 1.3
 * [new tag]             1.3-1                       -> 1.3-1
 * [new tag]             1.4                         -> 1.4
 * [new tag]             1.4-1                       -> 1.4-1
 * [new tag]             1.4.1-1                     -> 1.4.1-1
 * [new tag]             1.4.1-2                     -> 1.4.1-2
 * [new tag]             1.4.2-1                     -> 1.4.2-1
 * [new tag]             1.4.2-2                     -> 1.4.2-2
 * [new tag]             1.4.2-3                     -> 1.4.2-3
 * [new tag]             1.4.3-1                     -> 1.4.3-1
 * [new tag]             1.4.4-1                     -> 1.4.4-1
 * [new tag]             1.4.5                       -> 1.4.5
 * [new tag]             1.4.5-1                     -> 1.4.5-1
 * [new tag]             1.4.6                       -> 1.4.6
 * [new tag]             1.4.6-1                     -> 1.4.6-1
 * [new tag]             1.4.7                       -> 1.4.7
 * [new tag]             1.4.7-1                     -> 1.4.7-1
 * [new tag]             1.4.7-2                     -> 1.4.7-2
 * [new tag]             1.5                         -> 1.5
 * [new tag]             1.5-1                       -> 1.5-1
 * [new tag]             1.5.1-1                     -> 1.5.1-1
 * [new tag]             1.5.1-2                     -> 1.5.1-2
 * [new tag]             1.6                         -> 1.6
 * [new tag]             1.6-1                       -> 1.6-1
 * [new tag]             1.6.1-1                     -> 1.6.1-1
 * [new tag]             1.6.2-1                     -> 1.6.2-1
 * [new tag]             1.7                         -> 1.7
 * [new tag]             1.7-1                       -> 1.7-1
 * [new tag]             1.7.1-1                     -> 1.7.1-1
 * [new tag]             1.7.2-1                     -> 1.7.2-1
 * [new tag]             1.7.2-2                     -> 1.7.2-2
 * [new tag]             1.7.3-1                     -> 1.7.3-1
 * [new tag]             1.7.3-2                     -> 1.7.3-2
 * [new tag]             1.7.4-1                     -> 1.7.4-1
 * [new tag]             1.7.5-1                     -> 1.7.5-1
 * [new tag]             1.7.6-1                     -> 1.7.6-1
 * [new tag]             1.7.8                       -> 1.7.8
 * [new tag]             1.7.9                       -> 1.7.9
 * [new tag]             1.8.2                       -> 1.8.2
 * [new tag]             1.8.2-1                     -> 1.8.2-1
 * [new tag]             1.8.4                       -> 1.8.4
 * [new tag]             1.8.6                       -> 1.8.6
 * [new tag]             3.1.0.2019.08.08            -> 3.1.0.2019.08.08
 * [new tag]             3.1.0.2019.08.08-1          -> 3.1.0.2019.08.08-1
 * [new tag]             3.1.0.2019.08.14            -> 3.1.0.2019.08.14
 * [new tag]             3.1.0.2019.08.14-1          -> 3.1.0.2019.08.14-1
 * [new tag]             EOL_registry_mounts         -> EOL_registry_mounts
 * [new tag]             Z-cygwin_daemon_merge-new_HEAD -> Z-cygwin_daemon_merge-new_HEAD
 * [new tag]             Z-cygwin_daemon_merge_HEAD  -> Z-cygwin_daemon_merge_HEAD
 * [new tag]             after-mmap-privanon-noreserve -> after-mmap-privanon-noreserve
 * [new tag]             after-mmap-revamp           -> after-mmap-revamp
 * [new tag]             arc-20081103-branchpoint    -> arc-20081103-branchpoint
 * [new tag]             arc-insight_6_8-branchpoint -> arc-insight_6_8-branchpoint
 * [new tag]             arc-sim-20090309            -> arc-sim-20090309
 * [new tag]             before-mmap-revamp          -> before-mmap-revamp
 * [new tag]             binu_ss_19990502            -> binu_ss_19990502
 * [new tag]             binu_ss_19990602            -> binu_ss_19990602
 * [new tag]             binu_ss_19990721            -> binu_ss_19990721
 * [new tag]             binutils-2_10               -> binutils-2_10
 * [new tag]             binutils-2_10-branchpoint   -> binutils-2_10-branchpoint
 * [new tag]             binutils-2_10_1             -> binutils-2_10_1
 * [new tag]             binutils-2_11               -> binutils-2_11
 * [new tag]             binutils-2_11_1             -> binutils-2_11_1
 * [new tag]             binutils-2_11_2             -> binutils-2_11_2
 * [new tag]             binutils-2_12               -> binutils-2_12
 * [new tag]             binutils-2_12-branchpoint   -> binutils-2_12-branchpoint
 * [new tag]             binutils-2_12_1             -> binutils-2_12_1
 * [new tag]             binutils-2_13               -> binutils-2_13
 * [new tag]             binutils-2_13-branchpoint   -> binutils-2_13-branchpoint
 * [new tag]             binutils-2_13_1             -> binutils-2_13_1
 * [new tag]             binutils-2_13_2             -> binutils-2_13_2
 * [new tag]             binutils-2_13_2_1           -> binutils-2_13_2_1
 * [new tag]             binutils-2_14               -> binutils-2_14
 * [new tag]             binutils-2_14-branchpoint   -> binutils-2_14-branchpoint
 * [new tag]             binutils-2_15               -> binutils-2_15
 * [new tag]             binutils-2_15-branchpoint   -> binutils-2_15-branchpoint
 * [new tag]             binutils-2_16               -> binutils-2_16
 * [new tag]             binutils-2_16-branchpoint   -> binutils-2_16-branchpoint
 * [new tag]             binutils-2_16_1             -> binutils-2_16_1
 * [new tag]             binutils-2_17               -> binutils-2_17
 * [new tag]             binutils-2_17-branchpoint   -> binutils-2_17-branchpoint
 * [new tag]             binutils-2_18               -> binutils-2_18
 * [new tag]             binutils-2_18-branchpoint   -> binutils-2_18-branchpoint
 * [new tag]             binutils-2_19               -> binutils-2_19
 * [new tag]             binutils-2_19-branchpoint   -> binutils-2_19-branchpoint
 * [new tag]             binutils-2_19_1             -> binutils-2_19_1
 * [new tag]             binutils-2_20               -> binutils-2_20
 * [new tag]             binutils-2_20-branchpoint   -> binutils-2_20-branchpoint
 * [new tag]             binutils-2_20_1             -> binutils-2_20_1
 * [new tag]             binutils-2_21               -> binutils-2_21
 * [new tag]             binutils-2_21-branchpoint   -> binutils-2_21-branchpoint
 * [new tag]             binutils-2_21_1             -> binutils-2_21_1
 * [new tag]             binutils-2_22               -> binutils-2_22
 * [new tag]             binutils-2_22-branchpoint   -> binutils-2_22-branchpoint
 * [new tag]             binutils-2_23               -> binutils-2_23
 * [new tag]             binutils-2_23-branchpoint   -> binutils-2_23-branchpoint
 * [new tag]             binutils-2_23_1             -> binutils-2_23_1
 * [new tag]             binutils-2_23_2             -> binutils-2_23_2
 * [new tag]             binutils-2_24-branchpoint   -> binutils-2_24-branchpoint
 * [new tag]             binutils-arc-20080908-branchpoint -> binutils-arc-20080908-branchpoint
 * [new tag]             binutils-arc-20081103-branchpoint -> binutils-arc-20081103-branchpoint
 * [new tag]             binutils-csl-2_17-branchpoint -> binutils-csl-2_17-branchpoint
 * [new tag]             binutils-csl-arm-2005q1-branchpoint -> binutils-csl-arm-2005q1-branchpoint
 * [new tag]             binutils-csl-arm-2005q1a    -> binutils-csl-arm-2005q1a
 * [new tag]             binutils-csl-arm-2005q1b    -> binutils-csl-arm-2005q1b
 * [new tag]             binutils-csl-arm-2006q1-6   -> binutils-csl-arm-2006q1-6
 * [new tag]             binutils-csl-arm-2006q3-19  -> binutils-csl-arm-2006q3-19
 * [new tag]             binutils-csl-arm-2006q3-21  -> binutils-csl-arm-2006q3-21
 * [new tag]             binutils-csl-arm-2006q3-26  -> binutils-csl-arm-2006q3-26
 * [new tag]             binutils-csl-arm-2006q3-27  -> binutils-csl-arm-2006q3-27
 * [new tag]             binutils-csl-coldfire-4_1-10 -> binutils-csl-coldfire-4_1-10
 * [new tag]             binutils-csl-coldfire-4_1-11 -> binutils-csl-coldfire-4_1-11
 * [new tag]             binutils-csl-coldfire-4_1-28 -> binutils-csl-coldfire-4_1-28
 * [new tag]             binutils-csl-coldfire-4_1-30 -> binutils-csl-coldfire-4_1-30
 * [new tag]             binutils-csl-coldfire-4_1-32 -> binutils-csl-coldfire-4_1-32
 * [new tag]             binutils-csl-gxxpro-3_4-branchpoint -> binutils-csl-gxxpro-3_4-branchpoint
 * [new tag]             binutils-csl-innovasic-fido-3_4_4-33 -> binutils-csl-innovasic-fido-3_4_4-33
 * [new tag]             binutils-csl-morpho-4_1-4   -> binutils-csl-morpho-4_1-4
 * [new tag]             binutils-csl-palmsource-arm-prelinker-1_0-1 -> binutils-csl-palmsource-arm-prelinker-1_0-1
 * [new tag]             binutils-csl-renesas-4_1-6  -> binutils-csl-renesas-4_1-6
 * [new tag]             binutils-csl-renesas-4_1-7  -> binutils-csl-renesas-4_1-7
 * [new tag]             binutils-csl-renesas-4_1-8  -> binutils-csl-renesas-4_1-8
 * [new tag]             binutils-csl-renesas-4_1-9  -> binutils-csl-renesas-4_1-9
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-17 -> binutils-csl-sourcerygxx-3_4_4-17
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-19 -> binutils-csl-sourcerygxx-3_4_4-19
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-21 -> binutils-csl-sourcerygxx-3_4_4-21
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-25 -> binutils-csl-sourcerygxx-3_4_4-25
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-32 -> binutils-csl-sourcerygxx-3_4_4-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-12 -> binutils-csl-sourcerygxx-4_1-12
 * [new tag]             binutils-csl-sourcerygxx-4_1-13 -> binutils-csl-sourcerygxx-4_1-13
 * [new tag]             binutils-csl-sourcerygxx-4_1-14 -> binutils-csl-sourcerygxx-4_1-14
 * [new tag]             binutils-csl-sourcerygxx-4_1-15 -> binutils-csl-sourcerygxx-4_1-15
 * [new tag]             binutils-csl-sourcerygxx-4_1-17 -> binutils-csl-sourcerygxx-4_1-17
 * [new tag]             binutils-csl-sourcerygxx-4_1-18 -> binutils-csl-sourcerygxx-4_1-18
 * [new tag]             binutils-csl-sourcerygxx-4_1-19 -> binutils-csl-sourcerygxx-4_1-19
 * [new tag]             binutils-csl-sourcerygxx-4_1-20 -> binutils-csl-sourcerygxx-4_1-20
 * [new tag]             binutils-csl-sourcerygxx-4_1-21 -> binutils-csl-sourcerygxx-4_1-21
 * [new tag]             binutils-csl-sourcerygxx-4_1-22 -> binutils-csl-sourcerygxx-4_1-22
 * [new tag]             binutils-csl-sourcerygxx-4_1-23 -> binutils-csl-sourcerygxx-4_1-23
 * [new tag]             binutils-csl-sourcerygxx-4_1-24 -> binutils-csl-sourcerygxx-4_1-24
 * [new tag]             binutils-csl-sourcerygxx-4_1-25 -> binutils-csl-sourcerygxx-4_1-25
 * [new tag]             binutils-csl-sourcerygxx-4_1-26 -> binutils-csl-sourcerygxx-4_1-26
 * [new tag]             binutils-csl-sourcerygxx-4_1-27 -> binutils-csl-sourcerygxx-4_1-27
 * [new tag]             binutils-csl-sourcerygxx-4_1-28 -> binutils-csl-sourcerygxx-4_1-28
 * [new tag]             binutils-csl-sourcerygxx-4_1-29 -> binutils-csl-sourcerygxx-4_1-29
 * [new tag]             binutils-csl-sourcerygxx-4_1-30 -> binutils-csl-sourcerygxx-4_1-30
 * [new tag]             binutils-csl-sourcerygxx-4_1-32 -> binutils-csl-sourcerygxx-4_1-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-4 -> binutils-csl-sourcerygxx-4_1-4
 * [new tag]             binutils-csl-sourcerygxx-4_1-5 -> binutils-csl-sourcerygxx-4_1-5
 * [new tag]             binutils-csl-sourcerygxx-4_1-6 -> binutils-csl-sourcerygxx-4_1-6
 * [new tag]             binutils-csl-sourcerygxx-4_1-7 -> binutils-csl-sourcerygxx-4_1-7
 * [new tag]             binutils-csl-sourcerygxx-4_1-8 -> binutils-csl-sourcerygxx-4_1-8
 * [new tag]             binutils-csl-sourcerygxx-4_1-9 -> binutils-csl-sourcerygxx-4_1-9
 * [new tag]             binutils-csl-wrs-linux-3_4_4-20 -> binutils-csl-wrs-linux-3_4_4-20
 * [new tag]             binutils-csl-wrs-linux-3_4_4-21 -> binutils-csl-wrs-linux-3_4_4-21
 * [new tag]             binutils-csl-wrs-linux-3_4_4-22 -> binutils-csl-wrs-linux-3_4_4-22
 * [new tag]             binutils-csl-wrs-linux-3_4_4-23 -> binutils-csl-wrs-linux-3_4_4-23
 * [new tag]             binutils-csl-wrs-linux-3_4_4-24 -> binutils-csl-wrs-linux-3_4_4-24
 * [new tag]             binutils_latest_snapshot    -> binutils_latest_snapshot
 * [new tag]             cagney-unwind-20030108-branchpoint -> cagney-unwind-20030108-branchpoint
 * [new tag]             cagney_bfdfile-20040213-branchpoint -> cagney_bfdfile-20040213-branchpoint
 * [new tag]             cagney_bigcore-20040122-branchpoint -> cagney_bigcore-20040122-branchpoint
 * [new tag]             cagney_convert-20030606-branchpoint -> cagney_convert-20030606-branchpoint
 * [new tag]             cagney_fileio-20030521-branchpoint -> cagney_fileio-20030521-branchpoint
 * [new tag]             cagney_frameaddr-20030403-branchpoint -> cagney_frameaddr-20030403-branchpoint
 * [new tag]             cagney_frameaddr-20030409-mergepoint -> cagney_frameaddr-20030409-mergepoint
 * [new tag]             cagney_framebase-20030326-branchpoint -> cagney_framebase-20030326-branchpoint
 * [new tag]             cagney_framebase-20030330-mergepoint -> cagney_framebase-20030330-mergepoint
 * [new tag]             cagney_lazyid-20030317-branchpoint -> cagney_lazyid-20030317-branchpoint
 * [new tag]             cagney_offbyone-20030303-branchpoint -> cagney_offbyone-20030303-branchpoint
 * [new tag]             cagney_regbuf-20020515-branchpoint -> cagney_regbuf-20020515-branchpoint
 * [new tag]             cagney_sysregs-20020825-branchpoint -> cagney_sysregs-20020825-branchpoint
 * [new tag]             cagney_tramp-20040309-branchpoint -> cagney_tramp-20040309-branchpoint
 * [new tag]             cagney_tramp-20040321-mergepoint -> cagney_tramp-20040321-mergepoint
 * [new tag]             cagney_writestrings-20030508-branchpoint -> cagney_writestrings-20030508-branchpoint
 * [new tag]             cagney_x86i386-20030821-branchpoint -> cagney_x86i386-20030821-branchpoint
 * [new tag]             carlton-dictionary-20031111-merge -> carlton-dictionary-20031111-merge
 * [new tag]             carlton_dictionary-20020920-branchpoint -> carlton_dictionary-20020920-branchpoint
 * [new tag]             carlton_dictionary-20020927-merge -> carlton_dictionary-20020927-merge
 * [new tag]             carlton_dictionary-20021011-merge -> carlton_dictionary-20021011-merge
 * [new tag]             carlton_dictionary-20021025-merge -> carlton_dictionary-20021025-merge
 * [new tag]             carlton_dictionary-20021115-merge -> carlton_dictionary-20021115-merge
 * [new tag]             carlton_dictionary-20021223-merge -> carlton_dictionary-20021223-merge
 * [new tag]             carlton_dictionary-20030207-merge -> carlton_dictionary-20030207-merge
 * [new tag]             carlton_dictionary-20030305-merge -> carlton_dictionary-20030305-merge
 * [new tag]             carlton_dictionary-20030416-merge -> carlton_dictionary-20030416-merge
 * [new tag]             carlton_dictionary-20030430-merge -> carlton_dictionary-20030430-merge
 * [new tag]             carlton_dictionary-20030523-merge -> carlton_dictionary-20030523-merge
 * [new tag]             carlton_dictionary-20030627-merge -> carlton_dictionary-20030627-merge
 * [new tag]             carlton_dictionary-20030805-merge -> carlton_dictionary-20030805-merge
 * [new tag]             carlton_dictionary-20030917-merge -> carlton_dictionary-20030917-merge
 * [new tag]             carlton_dictionary-20031215-merge -> carlton_dictionary-20031215-merge
 * [new tag]             carlton_dictionary-20040126-merge -> carlton_dictionary-20040126-merge
 * [new tag]             cgen-1_1-branchpoint        -> cgen-1_1-branchpoint
 * [new tag]             cgen-snapshot-20071001      -> cgen-snapshot-20071001
 * [new tag]             cgen-snapshot-20071101      -> cgen-snapshot-20071101
 * [new tag]             cgen-snapshot-20071201      -> cgen-snapshot-20071201
 * [new tag]             cgen-snapshot-20080101      -> cgen-snapshot-20080101
 * [new tag]             cgen-snapshot-20080201      -> cgen-snapshot-20080201
 * [new tag]             cgen-snapshot-20080301      -> cgen-snapshot-20080301
 * [new tag]             cgen-snapshot-20080401      -> cgen-snapshot-20080401
 * [new tag]             cgen-snapshot-20080501      -> cgen-snapshot-20080501
 * [new tag]             cgen-snapshot-20080601      -> cgen-snapshot-20080601
 * [new tag]             cgen-snapshot-20080701      -> cgen-snapshot-20080701
 * [new tag]             cgen-snapshot-20080801      -> cgen-snapshot-20080801
 * [new tag]             cgen-snapshot-20080901      -> cgen-snapshot-20080901
 * [new tag]             cgen-snapshot-20081001      -> cgen-snapshot-20081001
 * [new tag]             cgen-snapshot-20081101      -> cgen-snapshot-20081101
 * [new tag]             cgen-snapshot-20081201      -> cgen-snapshot-20081201
 * [new tag]             cgen-snapshot-20090101      -> cgen-snapshot-20090101
 * [new tag]             cgen-snapshot-20090201      -> cgen-snapshot-20090201
 * [new tag]             cgen-snapshot-20090301      -> cgen-snapshot-20090301
 * [new tag]             cgen-snapshot-20090401      -> cgen-snapshot-20090401
 * [new tag]             cgen-snapshot-20090501      -> cgen-snapshot-20090501
 * [new tag]             cgen-snapshot-20090601      -> cgen-snapshot-20090601
 * [new tag]             cgen-snapshot-20090701      -> cgen-snapshot-20090701
 * [new tag]             cgen-snapshot-20090801      -> cgen-snapshot-20090801
 * [new tag]             cgen-snapshot-20090901      -> cgen-snapshot-20090901
 * [new tag]             cgen-snapshot-20091001      -> cgen-snapshot-20091001
 * [new tag]             cgen-snapshot-20091101      -> cgen-snapshot-20091101
 * [new tag]             cgen-snapshot-20091201      -> cgen-snapshot-20091201
 * [new tag]             cgen-snapshot-20100101      -> cgen-snapshot-20100101
 * [new tag]             cgen-snapshot-20100201      -> cgen-snapshot-20100201
 * [new tag]             cgen-snapshot-20100301      -> cgen-snapshot-20100301
 * [new tag]             cgen-snapshot-20100401      -> cgen-snapshot-20100401
 * [new tag]             cgen-snapshot-20100501      -> cgen-snapshot-20100501
 * [new tag]             cgen-snapshot-20100601      -> cgen-snapshot-20100601
 * [new tag]             cgen-snapshot-20100701      -> cgen-snapshot-20100701
 * [new tag]             cgen-snapshot-20100801      -> cgen-snapshot-20100801
 * [new tag]             cgen-snapshot-20100901      -> cgen-snapshot-20100901
 * [new tag]             cgen-snapshot-20101001      -> cgen-snapshot-20101001
 * [new tag]             cgen-snapshot-20101101      -> cgen-snapshot-20101101
 * [new tag]             cgen-snapshot-20101201      -> cgen-snapshot-20101201
 * [new tag]             cgen-snapshot-20110101      -> cgen-snapshot-20110101
 * [new tag]             cgen-snapshot-20110201      -> cgen-snapshot-20110201
 * [new tag]             cgen-snapshot-20110301      -> cgen-snapshot-20110301
 * [new tag]             cgen-snapshot-20110401      -> cgen-snapshot-20110401
 * [new tag]             cgen-snapshot-20110501      -> cgen-snapshot-20110501
 * [new tag]             cgen-snapshot-20110601      -> cgen-snapshot-20110601
 * [new tag]             cgen-snapshot-20110701      -> cgen-snapshot-20110701
 * [new tag]             cgen-snapshot-20110801      -> cgen-snapshot-20110801
 * [new tag]             cgen-snapshot-20110901      -> cgen-snapshot-20110901
 * [new tag]             cgen-snapshot-20111001      -> cgen-snapshot-20111001
 * [new tag]             cgen-snapshot-20111101      -> cgen-snapshot-20111101
 * [new tag]             cgen-snapshot-20111201      -> cgen-snapshot-20111201
 * [new tag]             cgen-snapshot-20120101      -> cgen-snapshot-20120101
 * [new tag]             cgen-snapshot-20120201      -> cgen-snapshot-20120201
 * [new tag]             cgen-snapshot-20120301      -> cgen-snapshot-20120301
 * [new tag]             cgen-snapshot-20120401      -> cgen-snapshot-20120401
 * [new tag]             cgen-snapshot-20120501      -> cgen-snapshot-20120501
 * [new tag]             cgen-snapshot-20120601      -> cgen-snapshot-20120601
 * [new tag]             cgen-snapshot-20120701      -> cgen-snapshot-20120701
 * [new tag]             cgen-snapshot-20120801      -> cgen-snapshot-20120801
 * [new tag]             cgen-snapshot-20120901      -> cgen-snapshot-20120901
 * [new tag]             cgen-snapshot-20121001      -> cgen-snapshot-20121001
 * [new tag]             cgen-snapshot-20121101      -> cgen-snapshot-20121101
 * [new tag]             cgen-snapshot-20121201      -> cgen-snapshot-20121201
 * [new tag]             cgen-snapshot-20130101      -> cgen-snapshot-20130101
 * [new tag]             cgen-snapshot-20130201      -> cgen-snapshot-20130201
 * [new tag]             cgen-snapshot-20130301      -> cgen-snapshot-20130301
 * [new tag]             cgen-snapshot-20130401      -> cgen-snapshot-20130401
 * [new tag]             cgen-snapshot-20130501      -> cgen-snapshot-20130501
 * [new tag]             cgen-snapshot-20130601      -> cgen-snapshot-20130601
 * [new tag]             cgen-snapshot-20130701      -> cgen-snapshot-20130701
 * [new tag]             cgen-snapshot-20130801      -> cgen-snapshot-20130801
 * [new tag]             cgen-snapshot-20130901      -> cgen-snapshot-20130901
 * [new tag]             cgen-snapshot-20131001      -> cgen-snapshot-20131001
 * [new tag]             cgen-snapshot-20131101      -> cgen-snapshot-20131101
 * [new tag]             cgen-snapshot-20131201      -> cgen-snapshot-20131201
 * [new tag]             cgen-snapshot-20140101      -> cgen-snapshot-20140101
 * [new tag]             cgen-snapshot-20140201      -> cgen-snapshot-20140201
 * [new tag]             cgen-snapshot-20140301      -> cgen-snapshot-20140301
 * [new tag]             cgen-snapshot-20140401      -> cgen-snapshot-20140401
 * [new tag]             cgen-snapshot-20140501      -> cgen-snapshot-20140501
 * [new tag]             cgen-snapshot-20140601      -> cgen-snapshot-20140601
 * [new tag]             cgen-snapshot-20140701      -> cgen-snapshot-20140701
 * [new tag]             cgen-snapshot-20140801      -> cgen-snapshot-20140801
 * [new tag]             cgen-snapshot-20140901      -> cgen-snapshot-20140901
 * [new tag]             cgen-snapshot-20141001      -> cgen-snapshot-20141001
 * [new tag]             cgen-snapshot-20141101      -> cgen-snapshot-20141101
 * [new tag]             cgen-snapshot-20141201      -> cgen-snapshot-20141201
 * [new tag]             cgen-snapshot-20150101      -> cgen-snapshot-20150101
 * [new tag]             cgen-snapshot-20150201      -> cgen-snapshot-20150201
 * [new tag]             cgen-snapshot-20150301      -> cgen-snapshot-20150301
 * [new tag]             cgf-more-exit-sync          -> cgf-more-exit-sync
 * [new tag]             corinna-01                  -> corinna-01
 * [new tag]             cr-0x99                     -> cr-0x99
 * [new tag]             csl-arm-2003-q4             -> csl-arm-2003-q4
 * [new tag]             csl-arm-2004-q1             -> csl-arm-2004-q1
 * [new tag]             csl-arm-2004-q1a            -> csl-arm-2004-q1a
 * [new tag]             csl-arm-2004-q3             -> csl-arm-2004-q3
 * [new tag]             csl-arm-2004-q3d            -> csl-arm-2004-q3d
 * [new tag]             csl-arm-20050325-branchpoint -> csl-arm-20050325-branchpoint
 * [new tag]             cygnus_cvs_20020108_pre     -> cygnus_cvs_20020108_pre
 * [new tag]             cygwin-1-1-5                -> cygwin-1-1-5
 * [new tag]             cygwin-1-1-6                -> cygwin-1-1-6
 * [new tag]             cygwin-1-1-7                -> cygwin-1-1-7
 * [new tag]             cygwin-1-1-8                -> cygwin-1-1-8
 * [new tag]             cygwin-1-3-19-1-branchpoint -> cygwin-1-3-19-1-branchpoint
 * [new tag]             cygwin-1_1_1                -> cygwin-1_1_1
 * [new tag]             cygwin-1_7_1-release        -> cygwin-1_7_1-release
 * [new tag]             cygwin-1_7_10-release       -> cygwin-1_7_10-release
 * [new tag]             cygwin-1_7_11-release       -> cygwin-1_7_11-release
 * [new tag]             cygwin-1_7_12-release       -> cygwin-1_7_12-release
 * [new tag]             cygwin-1_7_14-release       -> cygwin-1_7_14-release
 * [new tag]             cygwin-1_7_14_2-release     -> cygwin-1_7_14_2-release
 * [new tag]             cygwin-1_7_15-release       -> cygwin-1_7_15-release
 * [new tag]             cygwin-1_7_16-release       -> cygwin-1_7_16-release
 * [new tag]             cygwin-1_7_17-release       -> cygwin-1_7_17-release
 * [new tag]             cygwin-1_7_18-release       -> cygwin-1_7_18-release
 * [new tag]             cygwin-1_7_19-release       -> cygwin-1_7_19-release
 * [new tag]             cygwin-1_7_2-release        -> cygwin-1_7_2-release
 * [new tag]             cygwin-1_7_20-release       -> cygwin-1_7_20-release
 * [new tag]             cygwin-1_7_21-release       -> cygwin-1_7_21-release
 * [new tag]             cygwin-1_7_22-release       -> cygwin-1_7_22-release
 * [new tag]             cygwin-1_7_23-release       -> cygwin-1_7_23-release
 * [new tag]             cygwin-1_7_24-release       -> cygwin-1_7_24-release
 * [new tag]             cygwin-1_7_25-release       -> cygwin-1_7_25-release
 * [new tag]             cygwin-1_7_26-release       -> cygwin-1_7_26-release
 * [new tag]             cygwin-1_7_27-release       -> cygwin-1_7_27-release
 * [new tag]             cygwin-1_7_28-release       -> cygwin-1_7_28-release
 * [new tag]             cygwin-1_7_29-release       -> cygwin-1_7_29-release
 * [new tag]             cygwin-1_7_3-release        -> cygwin-1_7_3-release
 * [new tag]             cygwin-1_7_30-release       -> cygwin-1_7_30-release
 * [new tag]             cygwin-1_7_31-release       -> cygwin-1_7_31-release
 * [new tag]             cygwin-1_7_32-release       -> cygwin-1_7_32-release
 * [new tag]             cygwin-1_7_33-release       -> cygwin-1_7_33-release
 * [new tag]             cygwin-1_7_34-release       -> cygwin-1_7_34-release
 * [new tag]             cygwin-1_7_35-release       -> cygwin-1_7_35-release
 * [new tag]             cygwin-1_7_4-release        -> cygwin-1_7_4-release
 * [new tag]             cygwin-1_7_5-release        -> cygwin-1_7_5-release
 * [new tag]             cygwin-1_7_7-release        -> cygwin-1_7_7-release
 * [new tag]             cygwin-1_7_8-release        -> cygwin-1_7_8-release
 * [new tag]             cygwin-1_7_9-release        -> cygwin-1_7_9-release
 * [new tag]             cygwin-2_0_0-release        -> cygwin-2_0_0-release
 * [new tag]             cygwin-2_0_1-release        -> cygwin-2_0_1-release
 * [new tag]             cygwin-2_0_2-release        -> cygwin-2_0_2-release
 * [new tag]             cygwin-2_0_3-release        -> cygwin-2_0_3-release
 * [new tag]             cygwin-2_0_4-release        -> cygwin-2_0_4-release
 * [new tag]             cygwin-2_10_0-release       -> cygwin-2_10_0-release
 * [new tag]             cygwin-2_11_0-release       -> cygwin-2_11_0-release
 * [new tag]             cygwin-2_11_1-release       -> cygwin-2_11_1-release
 * [new tag]             cygwin-2_11_2-release       -> cygwin-2_11_2-release
 * [new tag]             cygwin-2_1_0-release        -> cygwin-2_1_0-release
 * [new tag]             cygwin-2_2_0-release        -> cygwin-2_2_0-release
 * [new tag]             cygwin-2_2_1-release        -> cygwin-2_2_1-release
 * [new tag]             cygwin-2_3_0-release        -> cygwin-2_3_0-release
 * [new tag]             cygwin-2_3_1-relase         -> cygwin-2_3_1-relase
 * [new tag]             cygwin-2_3_1-release        -> cygwin-2_3_1-release
 * [new tag]             cygwin-2_4_0-release        -> cygwin-2_4_0-release
 * [new tag]             cygwin-2_4_1-release        -> cygwin-2_4_1-release
 * [new tag]             cygwin-2_5_0-release        -> cygwin-2_5_0-release
 * [new tag]             cygwin-2_5_1-release        -> cygwin-2_5_1-release
 * [new tag]             cygwin-2_5_2-release        -> cygwin-2_5_2-release
 * [new tag]             cygwin-2_6_0-release        -> cygwin-2_6_0-release
 * [new tag]             cygwin-2_6_1-release        -> cygwin-2_6_1-release
 * [new tag]             cygwin-2_7_0-release        -> cygwin-2_7_0-release
 * [new tag]             cygwin-2_8_0-release        -> cygwin-2_8_0-release
 * [new tag]             cygwin-2_8_1-release        -> cygwin-2_8_1-release
 * [new tag]             cygwin-2_8_2-release        -> cygwin-2_8_2-release
 * [new tag]             cygwin-2_9_0-release        -> cygwin-2_9_0-release
 * [new tag]             cygwin-3_0_0-release        -> cygwin-3_0_0-release
 * [new tag]             cygwin-3_0_1-release        -> cygwin-3_0_1-release
 * [new tag]             cygwin-3_0_2-release        -> cygwin-3_0_2-release
 * [new tag]             cygwin-3_0_3-release        -> cygwin-3_0_3-release
 * [new tag]             cygwin-3_0_4-release        -> cygwin-3_0_4-release
 * [new tag]             cygwin-3_0_5-release        -> cygwin-3_0_5-release
 * [new tag]             cygwin-3_0_6-release        -> cygwin-3_0_6-release
 * [new tag]             cygwin-3_0_7-release        -> cygwin-3_0_7-release
 * [new tag]             cygwin-3_1_0-release        -> cygwin-3_1_0-release
 * [new tag]             cygwin-3_1_1-release        -> cygwin-3_1_1-release
 * [new tag]             cygwin-3_1_2-release        -> cygwin-3_1_2-release
 * [new tag]             cygwin-3_1_3-release        -> cygwin-3_1_3-release
 * [new tag]             cygwin-3_1_4-release        -> cygwin-3_1_4-release
 * [new tag]             cygwin-64bit-postmerge      -> cygwin-64bit-postmerge
 * [new tag]             cygwin-64bit-premerge       -> cygwin-64bit-premerge
 * [new tag]             cygwin-pre-user-db          -> cygwin-pre-user-db
 * [new tag]             cygwin_daemon_merge_HEAD    -> cygwin_daemon_merge_HEAD
 * [new tag]             debian-2.10.0-1             -> debian-2.10.0-1
 * [new tag]             dje-cgen-play1-branchpoint  -> dje-cgen-play1-branchpoint
 * [new tag]             drop_9x_support_start       -> drop_9x_support_start
 * [new tag]             drow-cplus-branchpoint      -> drow-cplus-branchpoint
 * [new tag]             drow-cplus-merge-20021020   -> drow-cplus-merge-20021020
 * [new tag]             drow-cplus-merge-20021025   -> drow-cplus-merge-20021025
 * [new tag]             drow-cplus-merge-20031214   -> drow-cplus-merge-20031214
 * [new tag]             drow-cplus-merge-20031220   -> drow-cplus-merge-20031220
 * [new tag]             drow-cplus-merge-20031224   -> drow-cplus-merge-20031224
 * [new tag]             drow-cplus-merge-20040113   -> drow-cplus-merge-20040113
 * [new tag]             drow-cplus-merge-20040208   -> drow-cplus-merge-20040208
 * [new tag]             drow-reverse-20070409-branchpoint -> drow-reverse-20070409-branchpoint
 * [new tag]             drow_intercu-20040221-branchpoint -> drow_intercu-20040221-branchpoint
 * [new tag]             drow_intercu-merge-20040327 -> drow_intercu-merge-20040327
 * [new tag]             drow_intercu-merge-20040402 -> drow_intercu-merge-20040402
 * [new tag]             drow_intercu-merge-20040915 -> drow_intercu-merge-20040915
 * [new tag]             drow_intercu-merge-20040921 -> drow_intercu-merge-20040921
 * [new tag]             egcs_20000222               -> egcs_20000222
 * [new tag]             ezannoni_pie-20030916-branchpoint -> ezannoni_pie-20030916-branchpoint
 * [new tag]             ezannoni_pie-20040323-branchpoint -> ezannoni_pie-20040323-branchpoint
 * [new tag]             gdb-csl-20060226-branch-local-2 -> gdb-csl-20060226-branch-local-2
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-local-1 -> gdb-csl-20060226-branch-merge-to-csl-local-1
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-symbian-1 -> gdb-csl-20060226-branch-merge-to-csl-symbian-1
 * [new tag]             gdb-csl-20060226-branchpoint -> gdb-csl-20060226-branchpoint
 * [new tag]             gdb-csl-arm-20050325-2005-q1a -> gdb-csl-arm-20050325-2005-q1a
 * [new tag]             gdb-csl-arm-20050325-2005-q1b -> gdb-csl-arm-20050325-2005-q1b
 * [new tag]             gdb-csl-arm-20051020-branchpoint -> gdb-csl-arm-20051020-branchpoint
 * [new tag]             gdb-csl-arm-2006q1-6        -> gdb-csl-arm-2006q1-6
 * [new tag]             gdb-csl-available-20060303-branchpoint -> gdb-csl-available-20060303-branchpoint
 * [new tag]             gdb-csl-coldfire-4_1-10     -> gdb-csl-coldfire-4_1-10
 * [new tag]             gdb-csl-coldfire-4_1-11     -> gdb-csl-coldfire-4_1-11
 * [new tag]             gdb-csl-gxxpro-6_3-branchpoint -> gdb-csl-gxxpro-6_3-branchpoint
 * [new tag]             gdb-csl-morpho-4_1-4        -> gdb-csl-morpho-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-17 -> gdb-csl-sourcerygxx-3_4_4-17
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-19 -> gdb-csl-sourcerygxx-3_4_4-19
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-21 -> gdb-csl-sourcerygxx-3_4_4-21
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-25 -> gdb-csl-sourcerygxx-3_4_4-25
 * [new tag]             gdb-csl-sourcerygxx-4_1-12  -> gdb-csl-sourcerygxx-4_1-12
 * [new tag]             gdb-csl-sourcerygxx-4_1-13  -> gdb-csl-sourcerygxx-4_1-13
 * [new tag]             gdb-csl-sourcerygxx-4_1-14  -> gdb-csl-sourcerygxx-4_1-14
 * [new tag]             gdb-csl-sourcerygxx-4_1-17  -> gdb-csl-sourcerygxx-4_1-17
 * [new tag]             gdb-csl-sourcerygxx-4_1-4   -> gdb-csl-sourcerygxx-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-4_1-5   -> gdb-csl-sourcerygxx-4_1-5
 * [new tag]             gdb-csl-sourcerygxx-4_1-6   -> gdb-csl-sourcerygxx-4_1-6
 * [new tag]             gdb-csl-sourcerygxx-4_1-7   -> gdb-csl-sourcerygxx-4_1-7
 * [new tag]             gdb-csl-sourcerygxx-4_1-8   -> gdb-csl-sourcerygxx-4_1-8
 * [new tag]             gdb-csl-sourcerygxx-4_1-9   -> gdb-csl-sourcerygxx-4_1-9
 * [new tag]             gdb-csl-symbian-20060226-branchpoint -> gdb-csl-symbian-20060226-branchpoint
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-10 -> gdb-csl-symbian-6_4_50_20060226-10
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-11 -> gdb-csl-symbian-6_4_50_20060226-11
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-12 -> gdb-csl-symbian-6_4_50_20060226-12
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-8 -> gdb-csl-symbian-6_4_50_20060226-8
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-9 -> gdb-csl-symbian-6_4_50_20060226-9
 * [new tag]             gdb-premipsmulti-2000-06-06-branchpoint -> gdb-premipsmulti-2000-06-06-branchpoint
 * [new tag]             gdb_4_18_2-2000-05-18-release -> gdb_4_18_2-2000-05-18-release
 * [new tag]             gdb_4_95_0-2000-04-27-snapshot -> gdb_4_95_0-2000-04-27-snapshot
 * [new tag]             gdb_4_95_1-2000-05-11-snapshot -> gdb_4_95_1-2000-05-11-snapshot
 * [new tag]             gdb_5_0-2000-04-10-branchpoint -> gdb_5_0-2000-04-10-branchpoint
 * [new tag]             gdb_5_0-2000-05-19-release  -> gdb_5_0-2000-05-19-release
 * [new tag]             gdb_5_1-2001-07-29-branchpoint -> gdb_5_1-2001-07-29-branchpoint
 * [new tag]             gdb_5_1-2001-11-21-release  -> gdb_5_1-2001-11-21-release
 * [new tag]             gdb_5_1_0_1-2002-01-03-branchpoint -> gdb_5_1_0_1-2002-01-03-branchpoint
 * [new tag]             gdb_5_1_0_1-2002-01-03-release -> gdb_5_1_0_1-2002-01-03-release
 * [new tag]             gdb_5_1_1-2002-01-24-release -> gdb_5_1_1-2002-01-24-release
 * [new tag]             gdb_5_2-2002-03-03-branchpoint -> gdb_5_2-2002-03-03-branchpoint
 * [new tag]             gdb_5_2-2002-04-29-release  -> gdb_5_2-2002-04-29-release
 * [new tag]             gdb_5_2_1-2002-07-23-release -> gdb_5_2_1-2002-07-23-release
 * [new tag]             gdb_5_3-2002-09-04-branchpoint -> gdb_5_3-2002-09-04-branchpoint
 * [new tag]             gdb_5_3-2002-12-12-release  -> gdb_5_3-2002-12-12-release
 * [new tag]             gdb_6_0-2003-06-23-branchpoint -> gdb_6_0-2003-06-23-branchpoint
 * [new tag]             gdb_6_0-2003-10-04-release  -> gdb_6_0-2003-10-04-release
 * [new tag]             gdb_6_1-2004-03-01-gmt-branchpoint -> gdb_6_1-2004-03-01-gmt-branchpoint
 * [new tag]             gdb_6_1-2004-04-05-release  -> gdb_6_1-2004-04-05-release
 * [new tag]             gdb_6_1_1-20040616-release  -> gdb_6_1_1-20040616-release
 * [new tag]             gdb_6_2-2004-07-10-gmt-branchpoint -> gdb_6_2-2004-07-10-gmt-branchpoint
 * [new tag]             gdb_6_2-20040730-release    -> gdb_6_2-20040730-release
 * [new tag]             gdb_6_3-20041019-branchpoint -> gdb_6_3-20041019-branchpoint
 * [new tag]             gdb_6_3-20041109-release    -> gdb_6_3-20041109-release
 * [new tag]             gdb_6_4-2005-11-01-branchpoint -> gdb_6_4-2005-11-01-branchpoint
 * [new tag]             gdb_6_4-20051202-release    -> gdb_6_4-20051202-release
 * [new tag]             gdb_6_5-2006-05-14-branchpoint -> gdb_6_5-2006-05-14-branchpoint
 * [new tag]             gdb_6_5-20060621-release    -> gdb_6_5-20060621-release
 * [new tag]             gdb_6_6-2006-11-15-branchpoint -> gdb_6_6-2006-11-15-branchpoint
 * [new tag]             gdb_6_6-2006-12-18-release  -> gdb_6_6-2006-12-18-release
 * [new tag]             gdb_6_7-2007-09-07-branchpoint -> gdb_6_7-2007-09-07-branchpoint
 * [new tag]             gdb_6_7-2007-10-10-release  -> gdb_6_7-2007-10-10-release
 * [new tag]             gdb_6_7_1-2007-10-29-release -> gdb_6_7_1-2007-10-29-release
 * [new tag]             gdb_6_8-2008-02-26-branchpoint -> gdb_6_8-2008-02-26-branchpoint
 * [new tag]             gdb_6_8-2008-03-27-release  -> gdb_6_8-2008-03-27-release
 * [new tag]             gdb_7_0-2009-09-16-branchpoint -> gdb_7_0-2009-09-16-branchpoint
 * [new tag]             gdb_7_0-2009-10-06-release  -> gdb_7_0-2009-10-06-release
 * [new tag]             gdb_7_0_1-2009-12-22-release -> gdb_7_0_1-2009-12-22-release
 * [new tag]             gdb_7_1-2010-02-18-branchpoint -> gdb_7_1-2010-02-18-branchpoint
 * [new tag]             gdb_7_1-2010-03-18-release  -> gdb_7_1-2010-03-18-release
 * [new tag]             gdb_7_2-2010-07-07-branchpoint -> gdb_7_2-2010-07-07-branchpoint
 * [new tag]             gdb_7_2-2010-09-02-release  -> gdb_7_2-2010-09-02-release
 * [new tag]             gdb_7_3-2011-04-01-branchpoint -> gdb_7_3-2011-04-01-branchpoint
 * [new tag]             gdb_7_3-2011-07-26-release  -> gdb_7_3-2011-07-26-release
 * [new tag]             gdb_7_3_1-2011-09-04-release -> gdb_7_3_1-2011-09-04-release
 * [new tag]             gdb_7_4-2011-12-13-branchpoint -> gdb_7_4-2011-12-13-branchpoint
 * [new tag]             gdb_7_4-2012-01-24-release  -> gdb_7_4-2012-01-24-release
 * [new tag]             gdb_7_4_1-2012-04-26-release -> gdb_7_4_1-2012-04-26-release
 * [new tag]             gdb_7_5-2012-07-18-branchpoint -> gdb_7_5-2012-07-18-branchpoint
 * [new tag]             gdb_7_5-2012-08-17-release  -> gdb_7_5-2012-08-17-release
 * [new tag]             gdb_7_5_1-2012-11-29-release -> gdb_7_5_1-2012-11-29-release
 * [new tag]             gdb_7_6-2013-03-12-branchpoint -> gdb_7_6-2013-03-12-branchpoint
 * [new tag]             gdb_7_6-2013-04-26-release  -> gdb_7_6-2013-04-26-release
 * [new tag]             gdb_7_6_1-2013-08-30-release -> gdb_7_6_1-2013-08-30-release
 * [new tag]             gdb_s390-2001-09-26-branchpoint -> gdb_s390-2001-09-26-branchpoint
 * [new tag]             hmm                         -> hmm
 * [new tag]             insight-precleanup-2001-01-01 -> insight-precleanup-2001-01-01
 * [new tag]             insight_6_5-20061003-release -> insight_6_5-20061003-release
 * [new tag]             insight_6_6-20070208-release -> insight_6_6-20070208-release
 * [new tag]             insight_6_8-branchpoint     -> insight_6_8-branchpoint
 * [new tag]             interps-20030202-branchpoint -> interps-20030202-branchpoint
 * [new tag]             jimb-gdb_6_2-e500-branchpoint -> jimb-gdb_6_2-e500-branchpoint
 * [new tag]             jimb-macro-020506-branchpoint -> jimb-macro-020506-branchpoint
 * [new tag]             jimb-ppc64-linux-20030509-branchpoint -> jimb-ppc64-linux-20030509-branchpoint
 * [new tag]             jimb-ppc64-linux-20030528-branchpoint -> jimb-ppc64-linux-20030528-branchpoint
 * [new tag]             jimb-ppc64-linux-20030613-branchpoint -> jimb-ppc64-linux-20030613-branchpoint
 * [new tag]             jimb-rda-nptl-branchpoint   -> jimb-rda-nptl-branchpoint
 * [new tag]             kettenis-i386newframe-20030308-branchpoint -> kettenis-i386newframe-20030308-branchpoint
 * [new tag]             kettenis-i386newframe-20030316-mergepoint -> kettenis-i386newframe-20030316-mergepoint
 * [new tag]             kettenis_i386newframe-20030406-branchpoint -> kettenis_i386newframe-20030406-branchpoint
 * [new tag]             kettenis_i386newframe-20030419-branchpoint -> kettenis_i386newframe-20030419-branchpoint
 * [new tag]             kettenis_i386newframe-20030504-mergepoint -> kettenis_i386newframe-20030504-mergepoint
 * [new tag]             kettenis_i386newframe-20030517-mergepoint -> kettenis_i386newframe-20030517-mergepoint
 * [new tag]             kettenis_sparc-20030918-branchpoint -> kettenis_sparc-20030918-branchpoint
 * [new tag]             kseitz_interps-20020528-branchpoint -> kseitz_interps-20020528-branchpoint
 * [new tag]             kseitz_interps-20020829-merge -> kseitz_interps-20020829-merge
 * [new tag]             kseitz_interps-20020930-merge -> kseitz_interps-20020930-merge
 * [new tag]             kseitz_interps-20021103-merge -> kseitz_interps-20021103-merge
 * [new tag]             kseitz_interps-20021105-merge -> kseitz_interps-20021105-merge
 * [new tag]             mingw-runtime-2_0           -> mingw-runtime-2_0
 * [new tag]             mingw-runtime-2_4           -> mingw-runtime-2_4
 * [new tag]             msnyder-checkpoint-072509-branchpoint -> msnyder-checkpoint-072509-branchpoint
 * [new tag]             msnyder-fork-checkpoint-branchpoint -> msnyder-fork-checkpoint-branchpoint
 * [new tag]             msnyder-reverse-20060331-branchpoint -> msnyder-reverse-20060331-branchpoint
 * [new tag]             msnyder-reverse-20060502-branchpoint -> msnyder-reverse-20060502-branchpoint
 * [new tag]             msnyder-reverse-20080609-branchpoint -> msnyder-reverse-20080609-branchpoint
 * [new tag]             msnyder-tracepoint-checkpoint-branchpoint -> msnyder-tracepoint-checkpoint-branchpoint
 * [new tag]             multiprocess-20081120-branchpoint -> multiprocess-20081120-branchpoint
 * [new tag]             newlib-1_10_0               -> newlib-1_10_0
 * [new tag]             newlib-1_11_0               -> newlib-1_11_0
 * [new tag]             newlib-1_12_0               -> newlib-1_12_0
 * [new tag]             newlib-1_13_0               -> newlib-1_13_0
 * [new tag]             newlib-1_14_0               -> newlib-1_14_0
 * [new tag]             newlib-1_15_0               -> newlib-1_15_0
 * [new tag]             newlib-1_16_0               -> newlib-1_16_0
 * [new tag]             newlib-1_17_0               -> newlib-1_17_0
 * [new tag]             newlib-1_18_0               -> newlib-1_18_0
 * [new tag]             newlib-1_19_0               -> newlib-1_19_0
 * [new tag]             newlib-1_20_0               -> newlib-1_20_0
 * [new tag]             newlib-1_9_0                -> newlib-1_9_0
 * [new tag]             newlib-2000-02-17           -> newlib-2000-02-17
 * [new tag]             newlib-2_0_0                -> newlib-2_0_0
 * [new tag]             newlib-2_1_0                -> newlib-2_1_0
 * [new tag]             newlib-2_2_0                -> newlib-2_2_0
 * [new tag]             newlib-2_3_0                -> newlib-2_3_0
 * [new tag]             newlib-2_4_0                -> newlib-2_4_0
 * [new tag]             newlib-2_5_0                -> newlib-2_5_0
 * [new tag]             newlib-3.0.0                -> newlib-3.0.0
 * [new tag]             newlib-3.1.0                -> newlib-3.1.0
 * [new tag]             newlib-3.2.0                -> newlib-3.2.0
 * [new tag]             newlib-3.3.0                -> newlib-3.3.0
 * [new tag]             newlib-csl-20060320-branchpoint -> newlib-csl-20060320-branchpoint
 * [new tag]             newlib-csl-arm-2005-q1a     -> newlib-csl-arm-2005-q1a
 * [new tag]             newlib-csl-arm-2005-q1b     -> newlib-csl-arm-2005-q1b
 * [new tag]             newlib-csl-arm-2006q1-6     -> newlib-csl-arm-2006q1-6
 * [new tag]             newlib-csl-arm-2006q3-19    -> newlib-csl-arm-2006q3-19
 * [new tag]             newlib-csl-arm-2006q3-21    -> newlib-csl-arm-2006q3-21
 * [new tag]             newlib-csl-arm-2006q3-26    -> newlib-csl-arm-2006q3-26
 * [new tag]             newlib-csl-arm-2006q3-27    -> newlib-csl-arm-2006q3-27
 * [new tag]             newlib-csl-coldfire-4_1-28  -> newlib-csl-coldfire-4_1-28
 * [new tag]             newlib-csl-coldfire-4_1-30  -> newlib-csl-coldfire-4_1-30
 * [new tag]             newlib-csl-coldfire-4_1-32  -> newlib-csl-coldfire-4_1-32
 * [new tag]             newlib-csl-innovasic-fido-3_4_4-33 -> newlib-csl-innovasic-fido-3_4_4-33
 * [new tag]             newlib-csl-sourcerygxx-3_4_4-25 -> newlib-csl-sourcerygxx-3_4_4-25
 * [new tag]             newlib-csl-sourcerygxx-4_1-12 -> newlib-csl-sourcerygxx-4_1-12
 * [new tag]             newlib-csl-sourcerygxx-4_1-13 -> newlib-csl-sourcerygxx-4_1-13
 * [new tag]             newlib-csl-sourcerygxx-4_1-14 -> newlib-csl-sourcerygxx-4_1-14
 * [new tag]             newlib-csl-sourcerygxx-4_1-17 -> newlib-csl-sourcerygxx-4_1-17
 * [new tag]             newlib-csl-sourcerygxx-4_1-18 -> newlib-csl-sourcerygxx-4_1-18
 * [new tag]             newlib-csl-sourcerygxx-4_1-19 -> newlib-csl-sourcerygxx-4_1-19
 * [new tag]             newlib-csl-sourcerygxx-4_1-21 -> newlib-csl-sourcerygxx-4_1-21
 * [new tag]             newlib-csl-sourcerygxx-4_1-23 -> newlib-csl-sourcerygxx-4_1-23
 * [new tag]             newlib-csl-sourcerygxx-4_1-24 -> newlib-csl-sourcerygxx-4_1-24
 * [new tag]             newlib-csl-sourcerygxx-4_1-26 -> newlib-csl-sourcerygxx-4_1-26
 * [new tag]             newlib-csl-sourcerygxx-4_1-27 -> newlib-csl-sourcerygxx-4_1-27
 * [new tag]             newlib-csl-sourcerygxx-4_1-28 -> newlib-csl-sourcerygxx-4_1-28
 * [new tag]             newlib-csl-sourcerygxx-4_1-30 -> newlib-csl-sourcerygxx-4_1-30
 * [new tag]             newlib-csl-sourcerygxx-4_1-32 -> newlib-csl-sourcerygxx-4_1-32
 * [new tag]             newlib-csl-sourcerygxx-4_1-4 -> newlib-csl-sourcerygxx-4_1-4
 * [new tag]             newlib-csl-sourcerygxx-4_1-5 -> newlib-csl-sourcerygxx-4_1-5
 * [new tag]             newlib-csl-sourcerygxx-4_1-6 -> newlib-csl-sourcerygxx-4_1-6
 * [new tag]             newlib-csl-sourcerygxx-4_1-7 -> newlib-csl-sourcerygxx-4_1-7
 * [new tag]             newlib-csl-sourcerygxx-4_1-8 -> newlib-csl-sourcerygxx-4_1-8
 * [new tag]             newlib-csl-sourcerygxx-4_1-9 -> newlib-csl-sourcerygxx-4_1-9
 * [new tag]             newlib-snapshot-20150323    -> newlib-snapshot-20150323
 * [new tag]             newlib-snapshot-20150423    -> newlib-snapshot-20150423
 * [new tag]             newlib-snapshot-20150526    -> newlib-snapshot-20150526
 * [new tag]             newlib-snapshot-20150623    -> newlib-snapshot-20150623
 * [new tag]             newlib-snapshot-20150723    -> newlib-snapshot-20150723
 * [new tag]             newlib-snapshot-20150824    -> newlib-snapshot-20150824
 * [new tag]             newlib-snapshot-20150924    -> newlib-snapshot-20150924
 * [new tag]             newlib-snapshot-20151023    -> newlib-snapshot-20151023
 * [new tag]             newlib-snapshot-20160104    -> newlib-snapshot-20160104
 * [new tag]             newlib-snapshot-20160226    -> newlib-snapshot-20160226
 * [new tag]             newlib-snapshot-20160527    -> newlib-snapshot-20160527
 * [new tag]             newlib-snapshot-20160923    -> newlib-snapshot-20160923
 * [new tag]             newlib-snapshot-20170228    -> newlib-snapshot-20170228
 * [new tag]             newlib-snapshot-20170323    -> newlib-snapshot-20170323
 * [new tag]             newlib-snapshot-20170421    -> newlib-snapshot-20170421
 * [new tag]             newlib-snapshot-20170519    -> newlib-snapshot-20170519
 * [new tag]             newlib-snapshot-20170623    -> newlib-snapshot-20170623
 * [new tag]             newlib-snapshot-20170720    -> newlib-snapshot-20170720
 * [new tag]             newlib-snapshot-20170818    -> newlib-snapshot-20170818
 * [new tag]             newlib-snapshot-20170922    -> newlib-snapshot-20170922
 * [new tag]             newlib-snapshot-20171222    -> newlib-snapshot-20171222
 * [new tag]             newlib-snapshot-20180118    -> newlib-snapshot-20180118
 * [new tag]             newlib-snapshot-20180226    -> newlib-snapshot-20180226
 * [new tag]             newlib-snapshot-20180720    -> newlib-snapshot-20180720
 * [new tag]             newlib-snapshot-20180802    -> newlib-snapshot-20180802
 * [new tag]             newlib-snapshot-20180831    -> newlib-snapshot-20180831
 * [new tag]             newlib-snapshot-20181231    -> newlib-snapshot-20181231
 * [new tag]             newlib-snapshot-20200102    -> newlib-snapshot-20200102
 * [new tag]             nickrob-async-20060513-branchpoint -> nickrob-async-20060513-branchpoint
 * [new tag]             nickrob-async-20060828-mergepoint -> nickrob-async-20060828-mergepoint
 * [new tag]             offbyone-20030313-branchpoint -> offbyone-20030313-branchpoint
 * [new tag]             post-ptmalloc3              -> post-ptmalloc3
 * [new tag]             post_wait_sig_exit          -> post_wait_sig_exit
 * [new tag]             pre-cgf-merge               -> pre-cgf-merge
 * [new tag]             pre-cygwin-heap             -> pre-cygwin-heap
 * [new tag]             pre-no-this                 -> pre-no-this
 * [new tag]             pre-notty                   -> pre-notty
 * [new tag]             pre-posix-scan              -> pre-posix-scan
 * [new tag]             pre-ptmalloc3               -> pre-ptmalloc3
 * [new tag]             pre-ptymaster-archetype     -> pre-ptymaster-archetype
 * [new tag]             pre-ripout-set_console_state_for_spawn -> pre-ripout-set_console_state_for_spawn
 * [new tag]             pre-sigrewrite              -> pre-sigrewrite
 * [new tag]             pre_wait_sig_exit           -> pre_wait_sig_exit
 * [new tag]             predaemon                   -> predaemon
 * [new tag]             prefifo                     -> prefifo
 * [new tag]             preoverlapped               -> preoverlapped
 * [new tag]             readline_4_3-import-branchpoint -> readline_4_3-import-branchpoint
 * [new tag]             readline_5_1-import-branchpoint -> readline_5_1-import-branchpoint
 * [new tag]             reparent-point              -> reparent-point
 * [new tag]             repo-unification-2000-02-06 -> repo-unification-2000-02-06
 * [new tag]             reverse-20080717-branchpoint -> reverse-20080717-branchpoint
 * [new tag]             reverse-20080930-branchpoint -> reverse-20080930-branchpoint
 * [new tag]             reverse-20081226-branchpoint -> reverse-20081226-branchpoint
 * [new tag]             sid-20020905-branchpoint    -> sid-20020905-branchpoint
 * [new tag]             sid-snapshot-20071001       -> sid-snapshot-20071001
 * [new tag]             sid-snapshot-20071101       -> sid-snapshot-20071101
 * [new tag]             sid-snapshot-20071201       -> sid-snapshot-20071201
 * [new tag]             sid-snapshot-20080101       -> sid-snapshot-20080101
 * [new tag]             sid-snapshot-20080201       -> sid-snapshot-20080201
 * [new tag]             sid-snapshot-20080301       -> sid-snapshot-20080301
 * [new tag]             sid-snapshot-20080401       -> sid-snapshot-20080401
 * [new tag]             sid-snapshot-20080403       -> sid-snapshot-20080403
 * [new tag]             sid-snapshot-20080501       -> sid-snapshot-20080501
 * [new tag]             sid-snapshot-20080601       -> sid-snapshot-20080601
 * [new tag]             sid-snapshot-20080701       -> sid-snapshot-20080701
 * [new tag]             sid-snapshot-20080801       -> sid-snapshot-20080801
 * [new tag]             sid-snapshot-20080901       -> sid-snapshot-20080901
 * [new tag]             sid-snapshot-20081001       -> sid-snapshot-20081001
 * [new tag]             sid-snapshot-20081101       -> sid-snapshot-20081101
 * [new tag]             sid-snapshot-20081201       -> sid-snapshot-20081201
 * [new tag]             sid-snapshot-20090101       -> sid-snapshot-20090101
 * [new tag]             sid-snapshot-20090201       -> sid-snapshot-20090201
 * [new tag]             sid-snapshot-20090301       -> sid-snapshot-20090301
 * [new tag]             sid-snapshot-20090401       -> sid-snapshot-20090401
 * [new tag]             sid-snapshot-20090501       -> sid-snapshot-20090501
 * [new tag]             sid-snapshot-20090601       -> sid-snapshot-20090601
 * [new tag]             sid-snapshot-20090701       -> sid-snapshot-20090701
 * [new tag]             sid-snapshot-20090801       -> sid-snapshot-20090801
 * [new tag]             sid-snapshot-20090901       -> sid-snapshot-20090901
 * [new tag]             sid-snapshot-20091001       -> sid-snapshot-20091001
 * [new tag]             sid-snapshot-20091101       -> sid-snapshot-20091101
 * [new tag]             sid-snapshot-20091201       -> sid-snapshot-20091201
 * [new tag]             sid-snapshot-20100101       -> sid-snapshot-20100101
 * [new tag]             sid-snapshot-20100201       -> sid-snapshot-20100201
 * [new tag]             sid-snapshot-20100301       -> sid-snapshot-20100301
 * [new tag]             sid-snapshot-20100401       -> sid-snapshot-20100401
 * [new tag]             sid-snapshot-20100501       -> sid-snapshot-20100501
 * [new tag]             sid-snapshot-20100601       -> sid-snapshot-20100601
 * [new tag]             sid-snapshot-20100701       -> sid-snapshot-20100701
 * [new tag]             sid-snapshot-20100801       -> sid-snapshot-20100801
 * [new tag]             sid-snapshot-20100901       -> sid-snapshot-20100901
 * [new tag]             sid-snapshot-20101001       -> sid-snapshot-20101001
 * [new tag]             sid-snapshot-20101101       -> sid-snapshot-20101101
 * [new tag]             sid-snapshot-20101201       -> sid-snapshot-20101201
 * [new tag]             sid-snapshot-20110101       -> sid-snapshot-20110101
 * [new tag]             sid-snapshot-20110201       -> sid-snapshot-20110201
 * [new tag]             sid-snapshot-20110301       -> sid-snapshot-20110301
 * [new tag]             sid-snapshot-20110401       -> sid-snapshot-20110401
 * [new tag]             sid-snapshot-20110501       -> sid-snapshot-20110501
 * [new tag]             sid-snapshot-20110601       -> sid-snapshot-20110601
 * [new tag]             sid-snapshot-20110701       -> sid-snapshot-20110701
 * [new tag]             sid-snapshot-20110801       -> sid-snapshot-20110801
 * [new tag]             sid-snapshot-20110901       -> sid-snapshot-20110901
 * [new tag]             sid-snapshot-20111001       -> sid-snapshot-20111001
 * [new tag]             sid-snapshot-20111101       -> sid-snapshot-20111101
 * [new tag]             sid-snapshot-20111201       -> sid-snapshot-20111201
 * [new tag]             sid-snapshot-20120101       -> sid-snapshot-20120101
 * [new tag]             sid-snapshot-20120201       -> sid-snapshot-20120201
 * [new tag]             sid-snapshot-20120301       -> sid-snapshot-20120301
 * [new tag]             sid-snapshot-20120401       -> sid-snapshot-20120401
 * [new tag]             sid-snapshot-20120501       -> sid-snapshot-20120501
 * [new tag]             sid-snapshot-20120601       -> sid-snapshot-20120601
 * [new tag]             sid-snapshot-20120701       -> sid-snapshot-20120701
 * [new tag]             sid-snapshot-20120801       -> sid-snapshot-20120801
 * [new tag]             sid-snapshot-20120901       -> sid-snapshot-20120901
 * [new tag]             sid-snapshot-20121001       -> sid-snapshot-20121001
 * [new tag]             sid-snapshot-20121101       -> sid-snapshot-20121101
 * [new tag]             sid-snapshot-20121201       -> sid-snapshot-20121201
 * [new tag]             sid-snapshot-20130101       -> sid-snapshot-20130101
 * [new tag]             sid-snapshot-20130201       -> sid-snapshot-20130201
 * [new tag]             sid-snapshot-20130301       -> sid-snapshot-20130301
 * [new tag]             sid-snapshot-20130401       -> sid-snapshot-20130401
 * [new tag]             sid-snapshot-20130501       -> sid-snapshot-20130501
 * [new tag]             sid-snapshot-20130601       -> sid-snapshot-20130601
 * [new tag]             sid-snapshot-20130701       -> sid-snapshot-20130701
 * [new tag]             sid-snapshot-20130801       -> sid-snapshot-20130801
 * [new tag]             sid-snapshot-20130901       -> sid-snapshot-20130901
 * [new tag]             sid-snapshot-20131001       -> sid-snapshot-20131001
 * [new tag]             sid-snapshot-20131101       -> sid-snapshot-20131101
 * [new tag]             sid-snapshot-20131201       -> sid-snapshot-20131201
 * [new tag]             sid-snapshot-20140101       -> sid-snapshot-20140101
 * [new tag]             sid-snapshot-20140201       -> sid-snapshot-20140201
 * [new tag]             sid-snapshot-20140301       -> sid-snapshot-20140301
 * [new tag]             sid-snapshot-20140401       -> sid-snapshot-20140401
 * [new tag]             sid-snapshot-20140501       -> sid-snapshot-20140501
 * [new tag]             sid-snapshot-20140601       -> sid-snapshot-20140601
 * [new tag]             sid-snapshot-20140701       -> sid-snapshot-20140701
 * [new tag]             sid-snapshot-20140801       -> sid-snapshot-20140801
 * [new tag]             sid-snapshot-20140901       -> sid-snapshot-20140901
 * [new tag]             sid-snapshot-20141001       -> sid-snapshot-20141001
 * [new tag]             sid-snapshot-20141101       -> sid-snapshot-20141101
 * [new tag]             sid-snapshot-20141201       -> sid-snapshot-20141201
 * [new tag]             sid-snapshot-20150101       -> sid-snapshot-20150101
 * [new tag]             sid-snapshot-20150201       -> sid-snapshot-20150201
 * [new tag]             sid-snapshot-20150301       -> sid-snapshot-20150301
 * [new tag]             tcltk840-20020924-branchpoint -> tcltk840-20020924-branchpoint
 * [new tag]             w32api-1_5                  -> w32api-1_5
 * [new tag]             w32api-2_2                  -> w32api-2_2
 * [new tag]             winsup-2000-02-17           -> winsup-2000-02-17
 * [new tag]             x86_64versiong3             -> x86_64versiong3
HEAD is now at 764ef4e40 Version 1.8.6
From https://github.com/zephyrproject-rtos/segger
 * [new branch]      master       -> refs/west/master
 * [new branch]      v1.14-branch -> refs/west/v1.14-branch
HEAD is now at b011c45 segger: config: Add CCM option for linker sections
From https://github.com/zephyrproject-rtos/tinycrypt
HEAD is now at 1012a3e Fix warnings reported by UBSAN
From https://github.com/zephyrproject-rtos/uoscore-uedhoc
 * [new branch]      zephyr     -> refs/west/zephyr
HEAD is now at 150f4eb [zephyr fromlist] Adapt to changes in name generation in zcbor 0.8.0
From https://github.com/zephyrproject-rtos/zcbor
 * [new branch]      main              -> refs/west/main
 * [new branch]      release/0.6.1     -> refs/west/release/0.6.1
 * [new branch]      release/0.8.2     -> refs/west/release/0.8.2
 * [new tag]         0.1.0             -> 0.1.0
 * [new tag]         0.2.0             -> 0.2.0
 * [new tag]         0.3.0             -> 0.3.0
 * [new tag]         0.3.1             -> 0.3.1
 * [new tag]         0.4.0             -> 0.4.0
 * [new tag]         0.5.0             -> 0.5.0
 * [new tag]         0.5.1             -> 0.5.1
 * [new tag]         0.6.0             -> 0.6.0
 * [new tag]         0.8.0             -> 0.8.0
 * [new tag]         0.8.1             -> 0.8.1
 * [new tag]         0.9.0             -> 0.9.0
 * [new tag]         deprecated-master -> deprecated-master
 * [new tag]         inital-pr         -> inital-pr
 * [new tag]         old-structure     -> old-structure
HEAD is now at 75d0880 tests: Update mps2 board name
ERROR: update failed for projects: matter, cmock
Error: Launched process exited with non-zero status: 1
2024-09-07T16:02:06.275Z ERROR Error: From https://github.com/nrfconnect/sdk-zephyr
 * tag                       v3.6.99-ncs2              -> FETCH_HEAD
 * [new tag]                 v1.13.99-ncs1             -> v1.13.99-ncs1
 * [new tag]                 v1.13.99-ncs1-rc1         -> v1.13.99-ncs1-rc1
 * [new tag]                 v1.13.99-ncs2             -> v1.13.99-ncs2
 * [new tag]                 v1.13.99-ncs2-rc1         -> v1.13.99-ncs2-rc1
 * [new tag]                 v1.13.99-ncs2-rc2         -> v1.13.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs1             -> v1.14.99-ncs1
 * [new tag]                 v1.14.99-ncs1-rc1         -> v1.14.99-ncs1-rc1
 * [new tag]                 v1.14.99-ncs1-rc2         -> v1.14.99-ncs1-rc2
 * [new tag]                 v1.14.99-ncs2             -> v1.14.99-ncs2
 * [new tag]                 v1.14.99-ncs2-rc1         -> v1.14.99-ncs2-rc1
 * [new tag]                 v1.14.99-ncs2-rc2         -> v1.14.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs2-rc3         -> v1.14.99-ncs2-rc3
 * [new tag]                 v1.14.99-ncs2-rc4         -> v1.14.99-ncs2-rc4
 * [new tag]                 v1.14.99-ncs3-snapshot1   -> v1.14.99-ncs3-snapshot1
 * [new tag]                 v1.14.99-ncs3-snapshot2   -> v1.14.99-ncs3-snapshot2
 * [new tag]                 v2.0.99-ncs1              -> v2.0.99-ncs1
 * [new tag]                 v2.0.99-ncs1-rc1          -> v2.0.99-ncs1-rc1
 * [new tag]                 v2.0.99-ncs1-rc2          -> v2.0.99-ncs1-rc2
 * [new tag]                 v2.0.99-ncs1-rc3          -> v2.0.99-ncs1-rc3
 * [new tag]                 v2.0.99-ncs1-snapshot1    -> v2.0.99-ncs1-snapshot1
 * [new tag]                 v2.1.0-ncs1-snapshot1     -> v2.1.0-ncs1-snapshot1
 * [new tag]                 v2.1.99-ncs1              -> v2.1.99-ncs1
 * [new tag]                 v2.1.99-ncs1-rc1          -> v2.1.99-ncs1-rc1
 * [new tag]                 v2.1.99-ncs1-rc2          -> v2.1.99-ncs1-rc2
 * [new tag]                 v2.1.99-ncs1-snapshot1    -> v2.1.99-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs1           -> v2.3.0-rc1-ncs1
 * [new tag]                 v2.3.0-rc1-ncs1-rc1       -> v2.3.0-rc1-ncs1-rc1
 * [new tag]                 v2.3.0-rc1-ncs1-rc2       -> v2.3.0-rc1-ncs1-rc2
 * [new tag]                 v2.3.0-rc1-ncs1-rc3       -> v2.3.0-rc1-ncs1-rc3
 * [new tag]                 v2.3.0-rc1-ncs1-snapshot1 -> v2.3.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs2           -> v2.3.0-rc1-ncs2
 * [new tag]                 v2.3.0-rc1-ncs3           -> v2.3.0-rc1-ncs3
 * [new tag]                 v2.4.0-ncs1               -> v2.4.0-ncs1
 * [new tag]                 v2.4.0-ncs1-rc1           -> v2.4.0-ncs1-rc1
 * [new tag]                 v2.4.0-ncs1-rc2           -> v2.4.0-ncs1-rc2
 * [new tag]                 v2.4.0-ncs1-snapshot1     -> v2.4.0-ncs1-snapshot1
 * [new tag]                 v2.4.0-ncs2               -> v2.4.0-ncs2
 * [new tag]                 v2.4.0-ncs2-rc1           -> v2.4.0-ncs2-rc1
 * [new tag]                 v2.4.99-ncs1              -> v2.4.99-ncs1
 * [new tag]                 v2.4.99-ncs1-rc1          -> v2.4.99-ncs1-rc1
 * [new tag]                 v2.4.99-ncs1-snapshot1    -> v2.4.99-ncs1-snapshot1
 * [new tag]                 v2.4.99-ncs2              -> v2.4.99-ncs2
 * [new tag]                 v2.4.99-ncs2-1            -> v2.4.99-ncs2-1
 * [new tag]                 v2.4.99-ncs2-rc1          -> v2.4.99-ncs2-rc1
 * [new tag]                 v2.6.0-ncs1-rc3           -> v2.6.0-ncs1-rc3
 * [new tag]                 v2.6.0-rc1-ncs1           -> v2.6.0-rc1-ncs1
 * [new tag]                 v2.6.0-rc1-ncs1-rc1       -> v2.6.0-rc1-ncs1-rc1
 * [new tag]                 v2.6.0-rc1-ncs1-snapshot1 -> v2.6.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.6.99-ncs1              -> v2.6.99-ncs1
 * [new tag]                 v2.6.99-ncs1-1            -> v2.6.99-ncs1-1
 * [new tag]                 v2.6.99-ncs1-rc1          -> v2.6.99-ncs1-rc1
 * [new tag]                 v2.6.99-ncs1-rc2          -> v2.6.99-ncs1-rc2
 * [new tag]                 v2.6.99-ncs1-snapshot1    -> v2.6.99-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1               -> v2.7.0-ncs1
 * [new tag]                 v2.7.0-ncs1-rc1           -> v2.7.0-ncs1-rc1
 * [new tag]                 v2.7.0-ncs1-rc2           -> v2.7.0-ncs1-rc2
 * [new tag]                 v2.7.0-ncs1-snapshot1     -> v2.7.0-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1-snapshot2     -> v2.7.0-ncs1-snapshot2
 * [new tag]                 v2.7.99-ncs1              -> v2.7.99-ncs1
 * [new tag]                 v2.7.99-ncs1-1            -> v2.7.99-ncs1-1
 * [new tag]                 v2.7.99-ncs1-rc1          -> v2.7.99-ncs1-rc1
 * [new tag]                 v2.7.99-ncs1-rc2          -> v2.7.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1              -> v3.0.99-ncs1
 * [new tag]                 v3.0.99-ncs1-1            -> v3.0.99-ncs1-1
 * [new tag]                 v3.0.99-ncs1-rc1          -> v3.0.99-ncs1-rc1
 * [new tag]                 v3.0.99-ncs1-rc2          -> v3.0.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1-snapshot1    -> v3.0.99-ncs1-snapshot1
 * [new tag]                 v3.1.99-ncs1              -> v3.1.99-ncs1
 * [new tag]                 v3.1.99-ncs1-1            -> v3.1.99-ncs1-1
 * [new tag]                 v3.1.99-ncs1-2            -> v3.1.99-ncs1-2
 * [new tag]                 v3.1.99-ncs1-3            -> v3.1.99-ncs1-3
 * [new tag]                 v3.1.99-ncs1-rc1          -> v3.1.99-ncs1-rc1
 * [new tag]                 v3.1.99-ncs1-rc2          -> v3.1.99-ncs1-rc2
 * [new tag]                 v3.1.99-ncs1-snapshot1    -> v3.1.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs1              -> v3.2.99-ncs1
 * [new tag]                 v3.2.99-ncs1-rc1          -> v3.2.99-ncs1-rc1
 * [new tag]                 v3.2.99-ncs1-rc2          -> v3.2.99-ncs1-rc2
 * [new tag]                 v3.2.99-ncs1-snapshot1    -> v3.2.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs2              -> v3.2.99-ncs2
 * [new tag]                 v3.2.99-ncs2-rc1          -> v3.2.99-ncs2-rc1
 * [new tag]                 v3.2.99-ncs2-rc2          -> v3.2.99-ncs2-rc2
 * [new tag]                 v3.2.99-ncs2-snapshot1    -> v3.2.99-ncs2-snapshot1
 * [new tag]                 v3.3.99-ncs1              -> v3.3.99-ncs1
 * [new tag]                 v3.3.99-ncs1-1            -> v3.3.99-ncs1-1
 * [new tag]                 v3.3.99-ncs1-2            -> v3.3.99-ncs1-2
 * [new tag]                 v3.3.99-ncs1-3            -> v3.3.99-ncs1-3
 * [new tag]                 v3.3.99-ncs1-rc1          -> v3.3.99-ncs1-rc1
 * [new tag]                 v3.3.99-ncs1-rc2          -> v3.3.99-ncs1-rc2
 * [new tag]                 v3.3.99-ncs1-snapshot1    -> v3.3.99-ncs1-snapshot1
 * [new tag]                 v3.4.99-ncs1              -> v3.4.99-ncs1
 * [new tag]                 v3.4.99-ncs1-1            -> v3.4.99-ncs1-1
 * [new tag]                 v3.4.99-ncs1-1-rc1        -> v3.4.99-ncs1-1-rc1
 * [new tag]                 v3.4.99-ncs1-2            -> v3.4.99-ncs1-2
 * [new tag]                 v3.4.99-ncs1-3            -> v3.4.99-ncs1-3
 * [new tag]                 v3.4.99-ncs1-rc1          -> v3.4.99-ncs1-rc1
 * [new tag]                 v3.4.99-ncs1-rc2          -> v3.4.99-ncs1-rc2
 * [new tag]                 v3.4.99-ncs1-snapshot1    -> v3.4.99-ncs1-snapshot1
 * [new tag]                 v3.5.99-ncs1              -> v3.5.99-ncs1
 * [new tag]                 v3.5.99-ncs1-1            -> v3.5.99-ncs1-1
 * [new tag]                 v3.5.99-ncs1-rc1          -> v3.5.99-ncs1-rc1
 * [new tag]                 v3.5.99-ncs1-rc2          -> v3.5.99-ncs1-rc2
 * [new tag]                 v3.5.99-ncs1-snapshot1    -> v3.5.99-ncs1-snapshot1
 * [new tag]                 v3.6.99-ncs2              -> v3.6.99-ncs2
 * [new tag]                 v3.6.99-ncs2-rc1          -> v3.6.99-ncs2-rc1
 * [new tag]                 v3.6.99-ncs2-rc2          -> v3.6.99-ncs2-rc2
 * [new tag]                 v3.6.99-ncs2-rc3          -> v3.6.99-ncs2-rc3
 * [new tag]                 v3.6.99-ncs2-snapshot1    -> v3.6.99-ncs2-snapshot1
HEAD is now at 100befc70c7 [nrf fromtree] sysbuild: introduce sysbuild_root for root adjustment
From https://github.com/BabbleSim/bsim_west
 * [new branch]      v2.1       -> refs/west/v2.1
 * [new branch]      v2.1.1     -> refs/west/v2.1.1
 * [new branch]      v2.2       -> refs/west/v2.2
 * [new branch]      v2.2.1     -> refs/west/v2.2.1
 * [new branch]      v2.3       -> refs/west/v2.3
HEAD is now at 68f6282 developer_set: Remove .git suffix in paths
From https://github.com/nrfconnect/sdk-hostap
 * [new branch]          hcs                      -> refs/west/hcs
 * [new branch]          hostap_2_11_devel-ncs1-branch -> refs/west/hostap_2_11_devel-ncs1-branch
 * [new branch]          nrf700x-dev              -> refs/west/nrf700x-dev
 * [new branch]          nrf700x-test             -> refs/west/nrf700x-test
 * [new branch]          v2.5-branch              -> refs/west/v2.5-branch
 * [new branch]          v2.6-branch              -> refs/west/v2.6-branch
 * [new tag]             fix_sauce_tag_snapshot   -> fix_sauce_tag_snapshot
 * [new tag]             hostap_2_11_devel-ncs1   -> hostap_2_11_devel-ncs1
 * [new tag]             prepare_upmerge_snapshot -> prepare_upmerge_snapshot
HEAD is now at 6311fde66 [nrf noup] mbedtls: Fix memory leak
From https://github.com/nrfconnect/sdk-wi-fiquicktrack-controlappc
 * [new branch]      qt_v2.5.1      -> refs/west/qt_v2.5.1
 * [new tag]         R2.1-snapshot1 -> R2.1-snapshot1
 * [new tag]         pre_zephyr_separation_snapshot -> pre_zephyr_separation_snapshot
HEAD is now at 9f91589 [nrf noup] zephyr: Fix POSIX failures
From https://github.com/nrfconnect/sdk-mcuboot
 * tag                 v2.1.0-ncs1             -> FETCH_HEAD
 * [new tag]           v1.10.0-ncs1            -> v1.10.0-ncs1
 * [new tag]           v1.10.0-ncs1-1          -> v1.10.0-ncs1-1
 * [new tag]           v1.10.0-ncs1-rc1        -> v1.10.0-ncs1-rc1
 * [new tag]           v1.10.0-ncs1-rc2        -> v1.10.0-ncs1-rc2
 * [new tag]           v1.10.0-ncs1-snapshot1  -> v1.10.0-ncs1-snapshot1
 * [new tag]           v1.10.99-ncs1           -> v1.10.99-ncs1
 * [new tag]           v1.10.99-ncs1-1         -> v1.10.99-ncs1-1
 * [new tag]           v1.10.99-ncs1-1-rc1     -> v1.10.99-ncs1-1-rc1
 * [new tag]           v1.10.99-ncs1-2         -> v1.10.99-ncs1-2
 * [new tag]           v1.10.99-ncs1-3         -> v1.10.99-ncs1-3
 * [new tag]           v1.10.99-ncs1-rc1       -> v1.10.99-ncs1-rc1
 * [new tag]           v1.10.99-ncs1-rc2       -> v1.10.99-ncs1-rc2
 * [new tag]           v1.10.99-ncs1-snapshot1 -> v1.10.99-ncs1-snapshot1
 * [new tag]           v1.2.99-ncs1            -> v1.2.99-ncs1
 * [new tag]           v1.2.99-ncs1-rc1        -> v1.2.99-ncs1-rc1
 * [new tag]           v1.2.99-ncs2            -> v1.2.99-ncs2
 * [new tag]           v1.2.99-ncs2-rc1        -> v1.2.99-ncs2-rc1
 * [new tag]           v1.2.99-ncs2-rc2        -> v1.2.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs1            -> v1.3.99-ncs1
 * [new tag]           v1.3.99-ncs1-rc1        -> v1.3.99-ncs1-rc1
 * [new tag]           v1.3.99-ncs1-rc2        -> v1.3.99-ncs1-rc2
 * [new tag]           v1.3.99-ncs2            -> v1.3.99-ncs2
 * [new tag]           v1.3.99-ncs2-rc1        -> v1.3.99-ncs2-rc1
 * [new tag]           v1.3.99-ncs2-rc2        -> v1.3.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs2-rc3        -> v1.3.99-ncs2-rc3
 * [new tag]           v1.3.99-ncs2-rc4        -> v1.3.99-ncs2-rc4
 * [new tag]           v1.3.99-ncs3-snapshot1  -> v1.3.99-ncs3-snapshot1
 * [new tag]           v1.3.99-ncs3-snapshot2  -> v1.3.99-ncs3-snapshot2
 * [new tag]           v1.4.99-ncs1            -> v1.4.99-ncs1
 * [new tag]           v1.4.99-ncs1-rc1        -> v1.4.99-ncs1-rc1
 * [new tag]           v1.4.99-ncs1-rc2        -> v1.4.99-ncs1-rc2
 * [new tag]           v1.4.99-ncs1-rc3        -> v1.4.99-ncs1-rc3
 * [new tag]           v1.4.99-ncs1-snapshot1  -> v1.4.99-ncs1-snapshot1
 * [new tag]           v1.4.99-ncs2            -> v1.4.99-ncs2
 * [new tag]           v1.4.99-ncs2-rc1        -> v1.4.99-ncs2-rc1
 * [new tag]           v1.4.99-ncs2-rc2        -> v1.4.99-ncs2-rc2
 * [new tag]           v1.4.99-ncs2-snapshot1  -> v1.4.99-ncs2-snapshot1
 * [new tag]           v1.5.99-ncs1-rc1        -> v1.5.99-ncs1-rc1
 * [new tag]           v1.5.99-ncs1-rc2        -> v1.5.99-ncs1-rc2
 * [new tag]           v1.5.99-ncs1-rc3        -> v1.5.99-ncs1-rc3
 * [new tag]           v1.5.99-ncs1-snapshot1  -> v1.5.99-ncs1-snapshot1
 * [new tag]           v1.6.0-rc2-ncs1         -> v1.6.0-rc2-ncs1
 * [new tag]           v1.6.99-ncs1            -> v1.6.99-ncs1
 * [new tag]           v1.6.99-ncs1-rc1        -> v1.6.99-ncs1-rc1
 * [new tag]           v1.6.99-ncs1-rc2        -> v1.6.99-ncs1-rc2
 * [new tag]           v1.6.99-ncs1-snapshot1  -> v1.6.99-ncs1-snapshot1
 * [new tag]           v1.7.0-ncs1-rc1         -> v1.7.0-ncs1-rc1
 * [new tag]           v1.7.0-ncs1-rc3         -> v1.7.0-ncs1-rc3
 * [new tag]           v1.7.0-ncs1-snapshot1   -> v1.7.0-ncs1-snapshot1
 * [new tag]           v1.7.2                  -> v1.7.2
 * [new tag]           v1.7.2-ncs1             -> v1.7.2-ncs1
 * [new tag]           v1.7.2-ncs1-rc2         -> v1.7.2-ncs1-rc2
 * [new tag]           v1.7.2-ncs2             -> v1.7.2-ncs2
 * [new tag]           v1.7.2-ncs2-rc1         -> v1.7.2-ncs2-rc1
 * [new tag]           v1.7.2-ncs2-rc2         -> v1.7.2-ncs2-rc2
 * [new tag]           v1.7.2-ncs3             -> v1.7.2-ncs3
 * [new tag]           v1.7.2-ncs3-rc1         -> v1.7.2-ncs3-rc1
 * [new tag]           v1.7.2-ncs3-rc2         -> v1.7.2-ncs3-rc2
 * [new tag]           v1.7.99-ncs1            -> v1.7.99-ncs1
 * [new tag]           v1.7.99-ncs1-1          -> v1.7.99-ncs1-1
 * [new tag]           v1.7.99-ncs1-rc1        -> v1.7.99-ncs1-rc1
 * [new tag]           v1.7.99-ncs2            -> v1.7.99-ncs2
 * [new tag]           v1.7.99-ncs2-snapshot1  -> v1.7.99-ncs2-snapshot1
 * [new tag]           v1.7.99-ncs3            -> v1.7.99-ncs3
 * [new tag]           v1.7.99-ncs3-1          -> v1.7.99-ncs3-1
 * [new tag]           v1.7.99-ncs3-rc1        -> v1.7.99-ncs3-rc1
 * [new tag]           v1.7.99-ncs3-rc2        -> v1.7.99-ncs3-rc2
 * [new tag]           v1.7.99-ncs4            -> v1.7.99-ncs4
 * [new tag]           v1.7.99-ncs4-rc1        -> v1.7.99-ncs4-rc1
 * [new tag]           v1.7.99-ncs4-rc2        -> v1.7.99-ncs4-rc2
 * [new tag]           v1.8.99-ncs1            -> v1.8.99-ncs1
 * [new tag]           v1.8.99-ncs1-rc1        -> v1.8.99-ncs1-rc1
 * [new tag]           v1.8.99-ncs1-rc2        -> v1.8.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1            -> v1.9.99-ncs1
 * [new tag]           v1.9.99-ncs1-rc1        -> v1.9.99-ncs1-rc1
 * [new tag]           v1.9.99-ncs1-rc2        -> v1.9.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1-snapshot1  -> v1.9.99-ncs1-snapshot1
 * [new tag]           v1.9.99-ncs2            -> v1.9.99-ncs2
 * [new tag]           v1.9.99-ncs2-rc1        -> v1.9.99-ncs2-rc1
 * [new tag]           v1.9.99-ncs2-rc2        -> v1.9.99-ncs2-rc2
 * [new tag]           v1.9.99-ncs2-snapshot1  -> v1.9.99-ncs2-snapshot1
 * [new tag]           v1.9.99-ncs3            -> v1.9.99-ncs3
 * [new tag]           v1.9.99-ncs3-rc1        -> v1.9.99-ncs3-rc1
 * [new tag]           v1.9.99-ncs3-rc2        -> v1.9.99-ncs3-rc2
 * [new tag]           v1.9.99-ncs4            -> v1.9.99-ncs4
 * [new tag]           v1.9.99-ncs4-rc1        -> v1.9.99-ncs4-rc1
 * [new tag]           v1.9.99-ncs4-rc2        -> v1.9.99-ncs4-rc2
 * [new tag]           v1.9.99-ncs4-snapshot1  -> v1.9.99-ncs4-snapshot1
 * [new tag]           v1.9.99-ncs4-snapshot2  -> v1.9.99-ncs4-snapshot2
 * [new tag]           v2.0.99-ncs1-1          -> v2.0.99-ncs1-1
 * [new tag]           v2.1.0-ncs1             -> v2.1.0-ncs1
 * [new tag]           v2.1.0-ncs1-rc1         -> v2.1.0-ncs1-rc1
 * [new tag]           v2.1.0-ncs1-rc2         -> v2.1.0-ncs1-rc2
 * [new tag]           v2.1.0-ncs1-rc3         -> v2.1.0-ncs1-rc3
HEAD is now at daf2946a [nrf noup] boot/../loader: reboot after updating s0/s1
From https://github.com/laurencelundblade/QCBOR
 * [new branch]      BeforeSpiffyDecode -> refs/west/BeforeSpiffyDecode
 * [new branch]      CDE                -> refs/west/CDE
 * [new branch]      NaN                -> refs/west/NaN
 * [new branch]      arrays             -> refs/west/arrays
 * [new branch]      better_big_num     -> refs/west/better_big_num
 * [new branch]      const              -> refs/west/const
 * [new branch]      dev                -> refs/west/dev
 * [new branch]      disable            -> refs/west/disable
 * [new branch]      enter-array        -> refs/west/enter-array
 * [new branch]      makewarn           -> refs/west/makewarn
 * [new branch]      mappie             -> refs/west/mappie
 * [new branch]      newtag             -> refs/west/newtag
 * [new branch]      ub-example         -> refs/west/ub-example
 * [new branch]      versioning         -> refs/west/versioning
 * [new branch]      warn_in_tests      -> refs/west/warn_in_tests
 * [new tag]         v1.0               -> v1.0
 * [new tag]         v1.1               -> v1.1
 * [new tag]         v1.2               -> v1.2
 * [new tag]         v1.3               -> v1.3
 * [new tag]         v1.4               -> v1.4
 * [new tag]         v1.4.1             -> v1.4.1
HEAD is now at 751d365 restore inc/qcbor.h for backwards compatibility (#181)
From https://github.com/nrfconnect/sdk-mbedtls
 * tag                   v3.5.2-ncs2           -> FETCH_HEAD
 * [new tag]             mbedtls-2.26.0        -> mbedtls-2.26.0
 * [new tag]             v3.0.0-ncs1           -> v3.0.0-ncs1
 * [new tag]             v3.0.0-ncs1-rc2       -> v3.0.0-ncs1-rc2
 * [new tag]             v3.0.0-ncs2           -> v3.0.0-ncs2
 * [new tag]             v3.0.0-ncs2-rc1       -> v3.0.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs1           -> v3.1.0-ncs1
 * [new tag]             v3.1.0-ncs1-rc1       -> v3.1.0-ncs1-rc1
 * [new tag]             v3.1.0-ncs1-rc2       -> v3.1.0-ncs1-rc2
 * [new tag]             v3.1.0-ncs2           -> v3.1.0-ncs2
 * [new tag]             v3.1.0-ncs2-rc1       -> v3.1.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs2-rc2       -> v3.1.0-ncs2-rc2
 * [new tag]             v3.1.0-ncs3           -> v3.1.0-ncs3
 * [new tag]             v3.1.0-ncs3-rc1       -> v3.1.0-ncs3-rc1
 * [new tag]             v3.1.0-ncs3-rc2       -> v3.1.0-ncs3-rc2
 * [new tag]             v3.3.0-ncs1           -> v3.3.0-ncs1
 * [new tag]             v3.3.0-ncs1-1         -> v3.3.0-ncs1-1
 * [new tag]             v3.3.0-ncs1-rc1       -> v3.3.0-ncs1-rc1
 * [new tag]             v3.3.0-ncs1-rc2       -> v3.3.0-ncs1-rc2
 * [new tag]             v3.3.0-ncs1-snapshot1 -> v3.3.0-ncs1-snapshot1
 * [new tag]             v3.3.0-ncs2           -> v3.3.0-ncs2
 * [new tag]             v3.3.0-ncs2-1         -> v3.3.0-ncs2-1
 * [new tag]             v3.3.0-ncs2-1-rc1     -> v3.3.0-ncs2-1-rc1
 * [new tag]             v3.3.0-ncs2-2         -> v3.3.0-ncs2-2
 * [new tag]             v3.3.0-ncs2-3         -> v3.3.0-ncs2-3
 * [new tag]             v3.3.0-ncs2-rc1       -> v3.3.0-ncs2-rc1
 * [new tag]             v3.3.0-ncs2-rc2       -> v3.3.0-ncs2-rc2
 * [new tag]             v3.5.2-ncs1           -> v3.5.2-ncs1
 * [new tag]             v3.5.2-ncs1-1         -> v3.5.2-ncs1-1
 * [new tag]             v3.5.2-ncs1-rc1       -> v3.5.2-ncs1-rc1
 * [new tag]             v3.5.2-ncs1-rc2       -> v3.5.2-ncs1-rc2
 * [new tag]             v3.5.2-ncs1-snapshot1 -> v3.5.2-ncs1-snapshot1
 * [new tag]             v3.5.2-ncs2           -> v3.5.2-ncs2
 * [new tag]             v3.5.2-ncs2-rc1       -> v3.5.2-ncs2-rc1
 * [new tag]             v3.5.2-ncs2-rc2       -> v3.5.2-ncs2-rc2
 * [new tag]             v3.5.2-ncs2-rc3       -> v3.5.2-ncs2-rc3
 * [new tag]             v3.5.2-ncs2-snapshot1 -> v3.5.2-ncs2-snapshot1
HEAD is now at 72868c6f1 [nrf noup] Add MBEDTLS_PSA_CRYPTO_CLIENT support for TLS/DTLS and X.509
From https://github.com/nrfconnect/sdk-oberon-psa-crypto
 * [new branch]      add_test_spec -> refs/west/add_test_spec
 * [new branch]      oberon_west   -> refs/west/oberon_west
 * [new branch]      test          -> refs/west/test
HEAD is now at e0800ec [nrf noup] Allow import and destroy of builtin keys
From https://github.com/nrfconnect/sdk-nrfxlib
 * tag                 v2.7.0       -> FETCH_HEAD
 * [new tag]           v0.1.0       -> v0.1.0
 * [new tag]           v0.1.0-rc1   -> v0.1.0-rc1
 * [new tag]           v0.3.0       -> v0.3.0
 * [new tag]           v0.3.0-rc1   -> v0.3.0-rc1
 * [new tag]           v0.3.0-rc2   -> v0.3.0-rc2
 * [new tag]           v0.4.0       -> v0.4.0
 * [new tag]           v0.4.0-rc1   -> v0.4.0-rc1
 * [new tag]           v0.4.0-rc2   -> v0.4.0-rc2
 * [new tag]           v1.0.0       -> v1.0.0
 * [new tag]           v1.0.0-rc1   -> v1.0.0-rc1
 * [new tag]           v1.0.0-rc2   -> v1.0.0-rc2
 * [new tag]           v1.0.0-rc3   -> v1.0.0-rc3
 * [new tag]           v1.0.0-rc4   -> v1.0.0-rc4
 * [new tag]           v1.1.0       -> v1.1.0
 * [new tag]           v1.1.0-rc1   -> v1.1.0-rc1
 * [new tag]           v1.1.0-rc2   -> v1.1.0-rc2
 * [new tag]           v1.1.0-rc3   -> v1.1.0-rc3
 * [new tag]           v1.2.0       -> v1.2.0
 * [new tag]           v1.2.0-rc1   -> v1.2.0-rc1
 * [new tag]           v1.2.0-rc2   -> v1.2.0-rc2
 * [new tag]           v1.2.1       -> v1.2.1
 * [new tag]           v1.3.0       -> v1.3.0
 * [new tag]           v1.3.0-rc1   -> v1.3.0-rc1
 * [new tag]           v1.3.0-rc2   -> v1.3.0-rc2
 * [new tag]           v1.3.0-rc3   -> v1.3.0-rc3
 * [new tag]           v1.3.1       -> v1.3.1
 * [new tag]           v1.4.0       -> v1.4.0
 * [new tag]           v1.4.0-rc1   -> v1.4.0-rc1
 * [new tag]           v1.4.2       -> v1.4.2
 * [new tag]           v1.5.0       -> v1.5.0
 * [new tag]           v1.5.0-rc1   -> v1.5.0-rc1
 * [new tag]           v1.5.1       -> v1.5.1
 * [new tag]           v1.5.1-rc1   -> v1.5.1-rc1
 * [new tag]           v1.5.2       -> v1.5.2
 * [new tag]           v1.6.0       -> v1.6.0
 * [new tag]           v1.6.0-rc3   -> v1.6.0-rc3
 * [new tag]           v1.6.1       -> v1.6.1
 * [new tag]           v1.7.0       -> v1.7.0
 * [new tag]           v1.7.0-rc1   -> v1.7.0-rc1
 * [new tag]           v1.7.0-rc2   -> v1.7.0-rc2
 * [new tag]           v1.7.1       -> v1.7.1
 * [new tag]           v1.8.0       -> v1.8.0
 * [new tag]           v1.8.0-rc1   -> v1.8.0-rc1
 * [new tag]           v1.8.0-rc2   -> v1.8.0-rc2
 * [new tag]           v1.9.0       -> v1.9.0
 * [new tag]           v1.9.0-rc1   -> v1.9.0-rc1
 * [new tag]           v1.9.0-rc2   -> v1.9.0-rc2
 * [new tag]           v1.9.1       -> v1.9.1
 * [new tag]           v1.9.2       -> v1.9.2
 * [new tag]           v1.9.2-dev1  -> v1.9.2-dev1
 * [new tag]           v2.0.0       -> v2.0.0
 * [new tag]           v2.0.0-rc1   -> v2.0.0-rc1
 * [new tag]           v2.0.0-rc2   -> v2.0.0-rc2
 * [new tag]           v2.0.0-rc2-1 -> v2.0.0-rc2-1
 * [new tag]           v2.0.1       -> v2.0.1
 * [new tag]           v2.0.2       -> v2.0.2
 * [new tag]           v2.1.0       -> v2.1.0
 * [new tag]           v2.1.0-rc1   -> v2.1.0-rc1
 * [new tag]           v2.1.0-rc2   -> v2.1.0-rc2
 * [new tag]           v2.1.1       -> v2.1.1
 * [new tag]           v2.1.2       -> v2.1.2
 * [new tag]           v2.1.3       -> v2.1.3
 * [new tag]           v2.1.4       -> v2.1.4
 * [new tag]           v2.2.0       -> v2.2.0
 * [new tag]           v2.2.0-rc1   -> v2.2.0-rc1
 * [new tag]           v2.2.0-rc2   -> v2.2.0-rc2
 * [new tag]           v2.3.0       -> v2.3.0
 * [new tag]           v2.3.0-rc1   -> v2.3.0-rc1
 * [new tag]           v2.3.0-rc2   -> v2.3.0-rc2
 * [new tag]           v2.4.0       -> v2.4.0
 * [new tag]           v2.4.0-rc1   -> v2.4.0-rc1
 * [new tag]           v2.4.0-rc2   -> v2.4.0-rc2
 * [new tag]           v2.4.1       -> v2.4.1
 * [new tag]           v2.4.2       -> v2.4.2
 * [new tag]           v2.4.3       -> v2.4.3
 * [new tag]           v2.4.4       -> v2.4.4
 * [new tag]           v2.5.0       -> v2.5.0
 * [new tag]           v2.5.0-rc1   -> v2.5.0-rc1
 * [new tag]           v2.5.0-rc2   -> v2.5.0-rc2
 * [new tag]           v2.5.1       -> v2.5.1
 * [new tag]           v2.5.1-rc1   -> v2.5.1-rc1
 * [new tag]           v2.5.2       -> v2.5.2
 * [new tag]           v2.5.3       -> v2.5.3
 * [new tag]           v2.6.0       -> v2.6.0
 * [new tag]           v2.6.0-rc1   -> v2.6.0-rc1
 * [new tag]           v2.6.0-rc2   -> v2.6.0-rc2
 * [new tag]           v2.6.1       -> v2.6.1
 * [new tag]           v2.7.0       -> v2.7.0
 * [new tag]           v2.7.0-rc1   -> v2.7.0-rc1
 * [new tag]           v2.7.0-rc2   -> v2.7.0-rc2
 * [new tag]           v2.7.0-rc3   -> v2.7.0-rc3
HEAD is now at 37e2ac22 nrf_modem: doc: add info about PDN down when NRF_SO_KEEPOPEN is used
From https://github.com/nrfconnect/sdk-trusted-firmware-m
 * tag                   v2.0.0-ncs2            -> FETCH_HEAD
 * [new tag]             v1.2.99-ncs1-1         -> v1.2.99-ncs1-1
 * [new tag]             v1.3.99-ncs1-rc3       -> v1.3.99-ncs1-rc3
 * [new tag]             v1.3.99-ncs1-snapshot1 -> v1.3.99-ncs1-snapshot1
 * [new tag]             v1.3.99-ncs1-snapshot2 -> v1.3.99-ncs1-snapshot2
 * [new tag]             v1.3.99-ncs2-1         -> v1.3.99-ncs2-1
 * [new tag]             v1.3.99-ncs3           -> v1.3.99-ncs3
 * [new tag]             v1.3.99-ncs3-rc1       -> v1.3.99-ncs3-rc1
 * [new tag]             v1.3.99-ncs3-rc2       -> v1.3.99-ncs3-rc2
 * [new tag]             v1.5.0-ncs1            -> v1.5.0-ncs1
 * [new tag]             v1.5.0-ncs1-1          -> v1.5.0-ncs1-1
 * [new tag]             v1.5.0-ncs1-rc1        -> v1.5.0-ncs1-rc1
 * [new tag]             v1.5.0-ncs1-rc2        -> v1.5.0-ncs1-rc2
 * [new tag]             v1.5.0-ncs2            -> v1.5.0-ncs2
 * [new tag]             v1.5.0-ncs2-rc1        -> v1.5.0-ncs2-rc1
 * [new tag]             v1.5.0-ncs2-rc2        -> v1.5.0-ncs2-rc2
 * [new tag]             v1.5.0-ncs2-snapshot1  -> v1.5.0-ncs2-snapshot1
 * [new tag]             v1.6.0-ncs1            -> v1.6.0-ncs1
 * [new tag]             v1.6.0-ncs1-rc1        -> v1.6.0-ncs1-rc1
 * [new tag]             v1.6.0-ncs1-rc2        -> v1.6.0-ncs1-rc2
 * [new tag]             v1.6.0-ncs1-snapshot1  -> v1.6.0-ncs1-snapshot1
 * [new tag]             v1.6.0-ncs2            -> v1.6.0-ncs2
 * [new tag]             v1.6.0-ncs2-rc1        -> v1.6.0-ncs2-rc1
 * [new tag]             v1.6.0-ncs2-rc2        -> v1.6.0-ncs2-rc2
 * [new tag]             v1.6.0-ncs3            -> v1.6.0-ncs3
 * [new tag]             v1.6.0-ncs3-rc1        -> v1.6.0-ncs3-rc1
 * [new tag]             v1.6.0-ncs3-rc2        -> v1.6.0-ncs3-rc2
 * [new tag]             v1.7.0-ncs1            -> v1.7.0-ncs1
 * [new tag]             v1.7.0-ncs1-1          -> v1.7.0-ncs1-1
 * [new tag]             v1.7.0-ncs1-rc2        -> v1.7.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1            -> v1.8.0-ncs1
 * [new tag]             v1.8.0-ncs1-1          -> v1.8.0-ncs1-1
 * [new tag]             v1.8.0-ncs1-1-rc1      -> v1.8.0-ncs1-1-rc1
 * [new tag]             v1.8.0-ncs1-2          -> v1.8.0-ncs1-2
 * [new tag]             v1.8.0-ncs1-3          -> v1.8.0-ncs1-3
 * [new tag]             v1.8.0-ncs1-rc1        -> v1.8.0-ncs1-rc1
 * [new tag]             v1.8.0-ncs1-rc2        -> v1.8.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1-snapshot1  -> v1.8.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs1            -> v2.0.0-ncs1
 * [new tag]             v2.0.0-ncs1-1          -> v2.0.0-ncs1-1
 * [new tag]             v2.0.0-ncs1-rc1        -> v2.0.0-ncs1-rc1
 * [new tag]             v2.0.0-ncs1-rc2        -> v2.0.0-ncs1-rc2
 * [new tag]             v2.0.0-ncs1-snapshot1  -> v2.0.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs2            -> v2.0.0-ncs2
 * [new tag]             v2.0.0-ncs2-rc1        -> v2.0.0-ncs2-rc1
 * [new tag]             v2.0.0-ncs2-rc2        -> v2.0.0-ncs2-rc2
 * [new tag]             v2.0.0-ncs2-rc3        -> v2.0.0-ncs2-rc3
 * [new tag]             v2.0.0-ncs2-snapshot1  -> v2.0.0-ncs2-snapshot1
HEAD is now at 553c47a6a [nrf noup] Fix version warning
From https://github.com/nrfconnect/sdk-psa-arch-tests
 * [new branch]      54l_its         -> refs/west/54l_its
 * [new branch]      fix_wdt_address -> refs/west/fix_wdt_address
HEAD is now at 94a349d [nrf fromlist] Fix base address for the nrf watchdog
From https://github.com/nrfconnect/sdk-connectedhomeip
 * [new tag]               v1.6.99-20210901    -> v1.6.99-20210901
 * [new tag]               v1.6.99-snapshot1   -> v1.6.99-snapshot1
 * [new tag]               v1.7.99-20211125    -> v1.7.99-20211125
 * [new tag]               v1.9.99-matter-dev1 -> v1.9.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev1 -> v2.0.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev2 -> v2.0.99-matter-dev2
 * [new tag]               v2.1.0-snapshot1    -> v2.1.0-snapshot1
 * [new tag]               v2.2.0-snapshot1    -> v2.2.0-snapshot1
 * [new tag]               v2.3.0-snapshot1    -> v2.3.0-snapshot1
 * [new tag]               v2.4.99-snapshot1   -> v2.4.99-snapshot1
 * [new tag]               v2.5.99-dev1        -> v2.5.99-dev1
HEAD is now at 022f2c92f6 [nrf toup] Fix missing network band in scan response.
      4 [main] sh 802 dofork: child -1 - forked process 14856 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/ce3b5ff664/mingw64/libexec/git-core\git-submodule: fork: retry: Resource temporarily unavailable
      2 [main] sh (13364) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1351408/0x11E1408.
This problem is probably due to using incompatible versions of the cygwin DLL.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version.  The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution.  Rebooting is also suggested if you
are unable to find another cygwin DLL.
1136180 [main] sh 802 dofork: child -1 - forked process 13364 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (7712) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1351408/0x11E1408.
3280389 [main] sh 802 dofork: child -1 - forked process 7712 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      4 [main] sh (11948) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1351408/0x1111408.
7421927 [main] sh 802 dofork: child -1 - forked process 11948 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (10052) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1351408/0x1061408.
15560971 [main] sh 802 dofork: child -1 - forked process 10052 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/ce3b5ff664/mingw64/libexec/git-core\git-submodule: fork: Resource temporarily unavailable
From https://github.com/nrfconnect/sdk-soc-hwmv1
HEAD is now at 32b1ee3 soc: Update Kconfig.peripherals from sdk-zephyr bdda11b
From https://github.com/nrfconnect/sdk-cjson
 * [new tag]         v1.7.14    -> v1.7.14
HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
From https://github.com/nrfconnect/azure-sdk-for-c
HEAD is now at 308c171c [nrf fromlist] Make repository a Zephyr module
From https://github.com/nrfconnect/sdk-mcu-drivers
HEAD is now at 3873a08 Added missing curly brace for #ifdef __cplusplus
From https://github.com/nrfconnect/sdk-openthread
 * [new branch]          debug/tomaszkob89/key-rotation -> refs/west/debug/tomaszkob89/key-rotation
 * [new branch]          for-testing       -> refs/west/for-testing
 * [new branch]          v1.7-branch       -> refs/west/v1.7-branch
 * [new branch]          v1.9-branch       -> refs/west/v1.9-branch
 * [new branch]          v2.0-branch       -> refs/west/v2.0-branch
 * [new branch]          v2.4-branch       -> refs/west/v2.4-branch
 * [new tag]             thread-reference-20200818-ncs1-rc1 -> thread-reference-20200818-ncs1-rc1
 * [new tag]             thread-reference-20200818-ncs1-rc3 -> thread-reference-20200818-ncs1-rc3
 * [new tag]             v1.8.99-snapshot1 -> v1.8.99-snapshot1
 * [new tag]             v1.9.99-snapshot1 -> v1.9.99-snapshot1
HEAD is now at a57d927b0 [string] add `ParseDigit()`, `ParseHexDigit()`, and other helper functions (#10282)
From https://github.com/nrfconnect/suit-generator
HEAD is now at 3458313 feat: add binary file name value to template generator
From https://github.com/nrfconnect/suit-processor
HEAD is now at 4505925 Fix coverity issues for 2.7 release
From https://github.com/ThrowTheSwitch/cmock
 * [new branch]      branch_2_5_1           -> refs/west/branch_2_5_1
 * [new branch]      cmock_2_6_rc           -> refs/west/cmock_2_6_rc
 * [new branch]      feature/only_config_is_shared -> refs/west/feature/only_config_is_shared
 * [new branch]      reapply_329            -> refs/west/reapply_329
 * [new branch]      revert-329-master      -> refs/west/revert-329-master
 * [new branch]      test/switch_to_actions -> refs/west/test/switch_to_actions
 * [new tag]         v2.4.5                 -> v2.4.5
 * [new tag]         v2.4.6                 -> v2.4.6
HEAD is now at f65066f Merge pull request #404 from tz18/patch-1
      2 [main] sh (6748) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11B1408/0x1201408.
      2 [main] sh 128 dofork: child -1 - forked process 6748 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (3636) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11B1408/0x10E1408.
1154138 [main] sh 128 dofork: child -1 - forked process 3636 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (13440) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11B1408/0x1141408.
3284299 [main] sh 128 dofork: child -1 - forked process 13440 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (9560) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11B1408/0x1001408.
7412931 [main] sh 128 dofork: child -1 - forked process 9560 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (6088) C:\ncs\toolchains\ce3b5ff664\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x11B1408/0x1151408.
15562804 [main] sh 128 dofork: child -1 - forked process 6088 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
From https://github.com/memfault/memfault-firmware-sdk
 * tag               1.6.0      -> FETCH_HEAD
 * [new tag]         0.0.10     -> 0.0.10
 * [new tag]         0.0.11     -> 0.0.11
 * [new tag]         0.0.12     -> 0.0.12
 * [new tag]         0.0.13     -> 0.0.13
 * [new tag]         0.0.14     -> 0.0.14
 * [new tag]         0.0.15     -> 0.0.15
 * [new tag]         0.0.16     -> 0.0.16
 * [new tag]         0.0.17     -> 0.0.17
 * [new tag]         0.0.18     -> 0.0.18
 * [new tag]         0.0.2      -> 0.0.2
 * [new tag]         0.0.3      -> 0.0.3
 * [new tag]         0.0.4      -> 0.0.4
 * [new tag]         0.0.5      -> 0.0.5
 * [new tag]         0.0.6      -> 0.0.6
 * [new tag]         0.0.7      -> 0.0.7
 * [new tag]         0.0.8      -> 0.0.8
 * [new tag]         0.0.9      -> 0.0.9
 * [new tag]         0.10.0     -> 0.10.0
 * [new tag]         0.10.1     -> 0.10.1
 * [new tag]         0.11.0     -> 0.11.0
 * [new tag]         0.11.1     -> 0.11.1
 * [new tag]         0.11.2     -> 0.11.2
 * [new tag]         0.11.3     -> 0.11.3
 * [new tag]         0.11.4     -> 0.11.4
 * [new tag]         0.12.0     -> 0.12.0
 * [new tag]         0.13.0     -> 0.13.0
 * [new tag]         0.13.1     -> 0.13.1
 * [new tag]         0.14.0     -> 0.14.0
 * [new tag]         0.15.0     -> 0.15.0
 * [new tag]         0.16.0     -> 0.16.0
 * [new tag]         0.16.1     -> 0.16.1
 * [new tag]         0.17.0     -> 0.17.0
 * [new tag]         0.17.1     -> 0.17.1
 * [new tag]         0.18.0     -> 0.18.0
 * [new tag]         0.19.0     -> 0.19.0
 * [new tag]         0.2.1      -> 0.2.1
 * [new tag]         0.2.2      -> 0.2.2
 * [new tag]         0.2.3      -> 0.2.3
 * [new tag]         0.2.4      -> 0.2.4
 * [new tag]         0.2.5      -> 0.2.5
 * [new tag]         0.20.0     -> 0.20.0
 * [new tag]         0.20.1     -> 0.20.1
 * [new tag]         0.20.2     -> 0.20.2
 * [new tag]         0.21.0     -> 0.21.0
 * [new tag]         0.21.1     -> 0.21.1
 * [new tag]         0.22.0     -> 0.22.0
 * [new tag]         0.23.0     -> 0.23.0
 * [new tag]         0.24.0     -> 0.24.0
 * [new tag]         0.24.1     -> 0.24.1
 * [new tag]         0.24.2     -> 0.24.2
 * [new tag]         0.25.0     -> 0.25.0
 * [new tag]         0.26.0     -> 0.26.0
 * [new tag]         0.26.1     -> 0.26.1
 * [new tag]         0.27.0     -> 0.27.0
 * [new tag]         0.27.1     -> 0.27.1
 * [new tag]         0.27.2     -> 0.27.2
 * [new tag]         0.27.3     -> 0.27.3
 * [new tag]         0.28.0     -> 0.28.0
 * [new tag]         0.28.1     -> 0.28.1
 * [new tag]         0.28.2     -> 0.28.2
 * [new tag]         0.29.0     -> 0.29.0
 * [new tag]         0.29.1     -> 0.29.1
 * [new tag]         0.3.2      -> 0.3.2
 * [new tag]         0.3.3      -> 0.3.3
 * [new tag]         0.3.4      -> 0.3.4
 * [new tag]         0.30.0     -> 0.30.0
 * [new tag]         0.30.1     -> 0.30.1
 * [new tag]         0.30.2     -> 0.30.2
 * [new tag]         0.30.3     -> 0.30.3
 * [new tag]         0.30.4     -> 0.30.4
 * [new tag]         0.30.5     -> 0.30.5
 * [new tag]         0.31.0     -> 0.31.0
 * [new tag]         0.31.1     -> 0.31.1
 * [new tag]         0.31.2     -> 0.31.2
 * [new tag]         0.31.3     -> 0.31.3
 * [new tag]         0.31.4     -> 0.31.4
 * [new tag]         0.31.5     -> 0.31.5
 * [new tag]         0.32.0     -> 0.32.0
 * [new tag]         0.32.1     -> 0.32.1
 * [new tag]         0.32.2     -> 0.32.2
 * [new tag]         0.33.0     -> 0.33.0
 * [new tag]         0.33.1     -> 0.33.1
 * [new tag]         0.33.2     -> 0.33.2
 * [new tag]         0.33.3     -> 0.33.3
 * [new tag]         0.33.4     -> 0.33.4
 * [new tag]         0.33.5     -> 0.33.5
 * [new tag]         0.34.0     -> 0.34.0
 * [new tag]         0.34.1     -> 0.34.1
 * [new tag]         0.34.2     -> 0.34.2
 * [new tag]         0.35.0     -> 0.35.0
 * [new tag]         0.36.0     -> 0.36.0
 * [new tag]         0.36.1     -> 0.36.1
 * [new tag]         0.37.0     -> 0.37.0
 * [new tag]         0.37.1     -> 0.37.1
 * [new tag]         0.37.2     -> 0.37.2
 * [new tag]         0.38.0     -> 0.38.0
 * [new tag]         0.39.0     -> 0.39.0
 * [new tag]         0.39.1     -> 0.39.1
 * [new tag]         0.4.1      -> 0.4.1
 * [new tag]         0.4.2      -> 0.4.2
 * [new tag]         0.40.0     -> 0.40.0
 * [new tag]         0.41.0     -> 0.41.0
 * [new tag]         0.41.1     -> 0.41.1
 * [new tag]         0.41.2     -> 0.41.2
 * [new tag]         0.42.0     -> 0.42.0
 * [new tag]         0.42.1     -> 0.42.1
 * [new tag]         0.43.0     -> 0.43.0
 * [new tag]         0.43.1     -> 0.43.1
 * [new tag]         0.43.2     -> 0.43.2
 * [new tag]         0.43.3     -> 0.43.3
 * [new tag]         0.6.1      -> 0.6.1
 * [new tag]         0.7.0      -> 0.7.0
 * [new tag]         0.7.1      -> 0.7.1
 * [new tag]         0.7.2      -> 0.7.2
 * [new tag]         0.7.3      -> 0.7.3
 * [new tag]         0.8.2      -> 0.8.2
 * [new tag]         0.9.1      -> 0.9.1
 * [new tag]         0.9.2      -> 0.9.2
 * [new tag]         0.9.3      -> 0.9.3
 * [new tag]         1.0.0      -> 1.0.0
 * [new tag]         1.0.1      -> 1.0.1
 * [new tag]         1.1.0      -> 1.1.0
 * [new tag]         1.1.1      -> 1.1.1
 * [new tag]         1.1.2      -> 1.1.2
 * [new tag]         1.1.3      -> 1.1.3
 * [new tag]         1.10.0     -> 1.10.0
 * [new tag]         1.10.1     -> 1.10.1
 * [new tag]         1.11.0     -> 1.11.0
 * [new tag]         1.11.1     -> 1.11.1
 * [new tag]         1.11.2     -> 1.11.2
 * [new tag]         1.11.3     -> 1.11.3
 * [new tag]         1.2.0      -> 1.2.0
 * [new tag]         1.2.1      -> 1.2.1
 * [new tag]         1.2.2      -> 1.2.2
 * [new tag]         1.2.3      -> 1.2.3
 * [new tag]         1.2.4      -> 1.2.4
 * [new tag]         1.2.5      -> 1.2.5
 * [new tag]         1.3.0      -> 1.3.0
 * [new tag]         1.3.1      -> 1.3.1
 * [new tag]         1.3.2      -> 1.3.2
 * [new tag]         1.3.3      -> 1.3.3
 * [new tag]         1.3.4      -> 1.3.4
 * [new tag]         1.3.5      -> 1.3.5
 * [new tag]         1.4.0      -> 1.4.0
 * [new tag]         1.4.1      -> 1.4.1
 * [new tag]         1.4.2      -> 1.4.2
 * [new tag]         1.4.3      -> 1.4.3
 * [new tag]         1.4.4      -> 1.4.4
 * [new tag]         1.5.0      -> 1.5.0
 * [new tag]         1.5.1      -> 1.5.1
 * [new tag]         1.5.2      -> 1.5.2
 * [new tag]         1.6.0      -> 1.6.0
 * [new tag]         1.6.1      -> 1.6.1
 * [new tag]         1.6.2      -> 1.6.2
 * [new tag]         1.7.0      -> 1.7.0
 * [new tag]         1.7.1      -> 1.7.1
 * [new tag]         1.7.2      -> 1.7.2
 * [new tag]         1.7.3      -> 1.7.3
 * [new tag]         1.7.4      -> 1.7.4
 * [new tag]         1.7.5      -> 1.7.5
 * [new tag]         1.7.6      -> 1.7.6
 * [new tag]         1.7.7      -> 1.7.7
 * [new tag]         1.8.0      -> 1.8.0
 * [new tag]         1.8.1      -> 1.8.1
 * [new tag]         1.9.0      -> 1.9.0
 * [new tag]         1.9.1      -> 1.9.1
 * [new tag]         1.9.2      -> 1.9.2
 * [new tag]         1.9.3      -> 1.9.3
 * [new tag]         1.9.4      -> 1.9.4
HEAD is now at 3d51c80 Memfault Firmware SDK 1.6.0 (Build 5464)
From https://github.com/eembc/coremark
 * [new branch]      128b-pointer -> refs/west/128b-pointer
 * [new branch]      posix-make   -> refs/west/posix-make
 * [new tag]         v1.01        -> v1.01
HEAD is now at d5fad6b Merge pull request #51 from volodymyr-bondarchuk/zephyr
From https://github.com/zephyrproject-rtos/canopennode
 * [new tag]         zephyr-snapshot-1 -> zephyr-snapshot-1
HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t()
From https://github.com/zephyrproject-rtos/chre
HEAD is now at 3b32c76e zephyr: link the .unstable_id data in ROM
From https://github.com/zephyrproject-rtos/lz4
 * [new tag]         lz4-r130   -> lz4-r130
 * [new tag]         r116       -> r116
 * [new tag]         r117       -> r117
 * [new tag]         r118       -> r118
 * [new tag]         r119       -> r119
 * [new tag]         r120       -> r120
 * [new tag]         r121       -> r121
 * [new tag]         r122       -> r122
 * [new tag]         r123       -> r123
 * [new tag]         r124       -> r124
 * [new tag]         r125       -> r125
 * [new tag]         r126       -> r126
 * [new tag]         r127       -> r127
 * [new tag]         r128       -> r128
 * [new tag]         r129       -> r129
 * [new tag]         r130       -> r130
 * [new tag]         r131       -> r131
 * [new tag]         rc129v0    -> rc129v0
 * [new tag]         v1.7.3     -> v1.7.3
 * [new tag]         v1.7.4     -> v1.7.4
 * [new tag]         v1.7.4.2   -> v1.7.4.2
 * [new tag]         v1.7.5     -> v1.7.5
 * [new tag]         v1.8.1     -> v1.8.1
 * [new tag]         v1.8.1.2   -> v1.8.1.2
 * [new tag]         v1.8.2     -> v1.8.2
 * [new tag]         v1.8.3     -> v1.8.3
 * [new tag]         v1.9.3     -> v1.9.3
HEAD is now at 8e303c2 zephyr: make this repo a zephyr module
From https://github.com/zephyrproject-rtos/nanopb
 * [new branch]      cifuzz_test4           -> refs/west/cifuzz_test4
 * [new branch]      dev_dynamic_nanopb_pb2 -> refs/west/dev_dynamic_nanopb_pb2
 * [new branch]      dev_markdown_docs      -> refs/west/dev_markdown_docs
 * [new branch]      maintenance_0.1        -> refs/west/maintenance_0.1
 * [new branch]      maintenance_0.2        -> refs/west/maintenance_0.2
 * [new branch]      maintenance_0.3        -> refs/west/maintenance_0.3
 * [new tag]         0.2.9.5                -> 0.2.9.5
 * [new tag]         0.3.6                  -> 0.3.6
 * [new tag]         0.3.7                  -> 0.3.7
 * [new tag]         0.3.8                  -> 0.3.8
 * [new tag]         0.3.9                  -> 0.3.9
 * [new tag]         0.3.9.1                -> 0.3.9.1
 * [new tag]         0.3.9.2                -> 0.3.9.2
 * [new tag]         0.3.9.3                -> 0.3.9.3
 * [new tag]         0.3.9.4                -> 0.3.9.4
 * [new tag]         0.3.9.5                -> 0.3.9.5
 * [new tag]         0.3.9.6                -> 0.3.9.6
 * [new tag]         0.3.9.7                -> 0.3.9.7
 * [new tag]         0.3.9.8                -> 0.3.9.8
 * [new tag]         0.4.3                  -> 0.4.3
 * [new tag]         0.4.4                  -> 0.4.4
 * [new tag]         0.4.5                  -> 0.4.5
 * [new tag]         nanopb-0.1.0           -> nanopb-0.1.0
 * [new tag]         nanopb-0.1.1           -> nanopb-0.1.1
 * [new tag]         nanopb-0.1.2           -> nanopb-0.1.2
 * [new tag]         nanopb-0.1.3           -> nanopb-0.1.3
 * [new tag]         nanopb-0.1.4           -> nanopb-0.1.4
 * [new tag]         nanopb-0.1.5           -> nanopb-0.1.5
 * [new tag]         nanopb-0.1.6           -> nanopb-0.1.6
 * [new tag]         nanopb-0.1.7           -> nanopb-0.1.7
 * [new tag]         nanopb-0.1.8           -> nanopb-0.1.8
 * [new tag]         nanopb-0.1.9           -> nanopb-0.1.9
 * [new tag]         nanopb-0.1.9.1         -> nanopb-0.1.9.1
 * [new tag]         nanopb-0.2.0           -> nanopb-0.2.0
 * [new tag]         nanopb-0.2.1           -> nanopb-0.2.1
 * [new tag]         nanopb-0.2.2           -> nanopb-0.2.2
 * [new tag]         nanopb-0.2.3           -> nanopb-0.2.3
 * [new tag]         nanopb-0.2.4           -> nanopb-0.2.4
 * [new tag]         nanopb-0.2.5           -> nanopb-0.2.5
 * [new tag]         nanopb-0.2.6           -> nanopb-0.2.6
 * [new tag]         nanopb-0.2.7           -> nanopb-0.2.7
 * [new tag]         nanopb-0.2.8           -> nanopb-0.2.8
 * [new tag]         nanopb-0.2.9           -> nanopb-0.2.9
 * [new tag]         nanopb-0.2.9.1         -> nanopb-0.2.9.1
 * [new tag]         nanopb-0.2.9.2         -> nanopb-0.2.9.2
 * [new tag]         nanopb-0.2.9.3         -> nanopb-0.2.9.3
 * [new tag]         nanopb-0.2.9.4         -> nanopb-0.2.9.4
 * [new tag]         nanopb-0.2.9.5         -> nanopb-0.2.9.5
 * [new tag]         nanopb-0.3.0           -> nanopb-0.3.0
 * [new tag]         nanopb-0.3.1           -> nanopb-0.3.1
 * [new tag]         nanopb-0.3.2           -> nanopb-0.3.2
 * [new tag]         nanopb-0.3.3           -> nanopb-0.3.3
 * [new tag]         nanopb-0.3.4           -> nanopb-0.3.4
 * [new tag]         nanopb-0.3.5           -> nanopb-0.3.5
 * [new tag]         nanopb-0.3.6           -> nanopb-0.3.6
 * [new tag]         nanopb-0.3.7           -> nanopb-0.3.7
 * [new tag]         nanopb-0.3.8           -> nanopb-0.3.8
 * [new tag]         nanopb-0.3.9           -> nanopb-0.3.9
 * [new tag]         nanopb-0.3.9.1         -> nanopb-0.3.9.1
 * [new tag]         nanopb-0.3.9.2         -> nanopb-0.3.9.2
 * [new tag]         nanopb-0.3.9.3         -> nanopb-0.3.9.3
 * [new tag]         nanopb-0.3.9.4         -> nanopb-0.3.9.4
 * [new tag]         nanopb-0.3.9.5         -> nanopb-0.3.9.5
 * [new tag]         nanopb-0.3.9.6         -> nanopb-0.3.9.6
 * [new tag]         nanopb-0.3.9.7         -> nanopb-0.3.9.7
 * [new tag]         nanopb-0.3.9.8         -> nanopb-0.3.9.8
 * [new tag]         nanopb-0.4.0           -> nanopb-0.4.0
 * [new tag]         nanopb-0.4.0-dev       -> nanopb-0.4.0-dev
 * [new tag]         nanopb-0.4.1           -> nanopb-0.4.1
 * [new tag]         nanopb-0.4.2           -> nanopb-0.4.2
 * [new tag]         nanopb-0.4.3           -> nanopb-0.4.3
 * [new tag]         nanopb-0.4.4           -> nanopb-0.4.4
 * [new tag]         nanopb-0.4.5           -> nanopb-0.4.5
HEAD is now at 7f88274 Add migration note about CMake protoc default (#958)
From https://github.com/zephyrproject-rtos/tf-m-tests
 * [new branch]      release/1.7.x -> refs/west/release/1.7.x
HEAD is now at 85f533a Crypto: Use RSA key in PSA format
From https://github.com/zephyrproject-rtos/zscilib
 * [new branch]      gh-pages   -> refs/west/gh-pages
 * [new branch]      revert-38-fix_zephyr_3_1 -> refs/west/revert-38-fix_zephyr_3_1
 * [new tag]         v0.2.0-rc1 -> v0.2.0-rc1
HEAD is now at ee1b287 samples/tests: Update for hwmv2 board names
From https://github.com/zephyrproject-rtos/cmsis
HEAD is now at 4b96cbb doc: Update documentations for CMSIS 5.9.0
From https://github.com/zephyrproject-rtos/cmsis-dsp
HEAD is now at 6489e771 do not generate warnings when scalar functions are used with MVE
From https://github.com/zephyrproject-rtos/cmsis-nn
 * [new branch]      zephyr-v6.0.0 -> refs/west/zephyr-v6.0.0
HEAD is now at 0c8669d Merge pull request #1 from XenuIsWatching/zephyr
From https://github.com/zephyrproject-rtos/edtt
 * [new branch]      le-audio      -> refs/west/le-audio
 * [new branch]      public_master -> refs/west/public_master
HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop
From https://github.com/zephyrproject-rtos/fatfs
HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE
From https://github.com/zephyrproject-rtos/hal_nordic
 * [new branch]      dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3 -> refs/west/dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3
 * [new tag]         nrfx-2.10.0  -> nrfx-2.10.0
 * [new tag]         nrfx-2.11.0  -> nrfx-2.11.0
 * [new tag]         nrfx-3.0.0   -> nrfx-3.0.0
HEAD is now at ab5cb2e nrfx: drivers: nrfx_gpiote: move enabling GPIOTE port interrupt
From https://github.com/zephyrproject-rtos/hal_st
HEAD is now at b77157f drivers: sensor: st: Move to vendor subdirectory
From https://github.com/zephyrproject-rtos/hal_wurthelektronik
HEAD is now at e5bcb2e Update WE sensors SDK to version 2.5.0
From https://github.com/zephyrproject-rtos/libmetal
HEAD is now at 243eed5 lib: update libmetal to SHA f55c02a7b582
From https://github.com/zephyrproject-rtos/liblc3
HEAD is now at 1a5938e meson: Bump to version 1.0.4
From https://github.com/zephyrproject-rtos/littlefs
 * [new tag]         littlefs-v2.1.0 -> littlefs-v2.1.0
 * [new tag]         littlefs-v2.1.1 -> littlefs-v2.1.1
 * [new tag]         littlefs-v2.1.2 -> littlefs-v2.1.2
 * [new tag]         littlefs-v2.1.3 -> littlefs-v2.1.3
 * [new tag]         littlefs-v2.1.4 -> littlefs-v2.1.4
 * [new tag]         littlefs-v2.2.0 -> littlefs-v2.2.0
HEAD is now at 408c16a Merge pull request #14 from de-nordic/update-to-v2.8.1
From https://github.com/zephyrproject-rtos/loramac-node
 * [new branch]        v4.5.2-zephyr -> refs/west/v4.5.2-zephyr
 * [new branch]        v4.6.0-zephyr -> refs/west/v4.6.0-zephyr
 * [new branch]        v4.7.0-zephyr -> refs/west/v4.7.0-zephyr
 * [new branch]        zephyr-v2.6   -> refs/west/zephyr-v2.6
 * [new tag]           4.4.2-rc.4    -> 4.4.2-rc.4
 * [new tag]           V3.4          -> V3.4
 * [new tag]           v2.0          -> v2.0
 * [new tag]           v2.1          -> v2.1
 * [new tag]           v2.2          -> v2.2
 * [new tag]           v2.3.RC1      -> v2.3.RC1
 * [new tag]           v2.3.RC2      -> v2.3.RC2
 * [new tag]           v3.0          -> v3.0
 * [new tag]           v3.1          -> v3.1
 * [new tag]           v3.2          -> v3.2
 * [new tag]           v3.3          -> v3.3
 * [new tag]           v3.4.1        -> v3.4.1
 * [new tag]           v4.0.0        -> v4.0.0
 * [new tag]           v4.1.0        -> v4.1.0
 * [new tag]           v4.2.0        -> v4.2.0
 * [new tag]           v4.3.0        -> v4.3.0
 * [new tag]           v4.3.1        -> v4.3.1
 * [new tag]           v4.3.2        -> v4.3.2
 * [new tag]           v4.4.0        -> v4.4.0
 * [new tag]           v4.4.1        -> v4.4.1
 * [new tag]           v4.4.2        -> v4.4.2
 * [new tag]           v4.4.2-rc.1   -> v4.4.2-rc.1
 * [new tag]           v4.4.2-rc.2   -> v4.4.2-rc.2
 * [new tag]           v4.4.2-rc.3   -> v4.4.2-rc.3
 * [new tag]           v4.4.2-rc.5   -> v4.4.2-rc.5
 * [new tag]           v4.4.2-rc.6   -> v4.4.2-rc.6
 * [new tag]           v4.4.2-rc.7   -> v4.4.2-rc.7
 * [new tag]           v4.4.3        -> v4.4.3
 * [new tag]           v4.4.3_zephyr -> v4.4.3_zephyr
HEAD is now at fb00b383 zephyr: configure FragDecoder using Kconfig
From https://github.com/zephyrproject-rtos/lvgl
HEAD is now at 2b498e6f Merge pull request #51 from faxe1008/upddate_lvgl_840
From https://github.com/zephyrproject-rtos/mipi-sys-t
HEAD is now at 71ace1f mipi_syst: fix build error when having protocol timestamp disabled
From https://github.com/zephyrproject-rtos/net-tools
HEAD is now at 7c7a856 websocket-console: Add a helper script for websocket console
From https://github.com/zephyrproject-rtos/nrf_hw_models
HEAD is now at 36b1271 54L15: Added RRAMC, RRAM & UICR
From https://github.com/zephyrproject-rtos/open-amp
 * [new branch]      bump_v2024.05.0 -> refs/west/bump_v2024.05.0
 * [new tag]         old_master      -> old_master
HEAD is now at da78aea lib: update open-amp lib to release v2023.10.0
From https://github.com/zephyrproject-rtos/picolibc
 * [new branch]          Z-emcb-cygwin_daemon        -> refs/west/Z-emcb-cygwin_daemon
 * [new branch]          aarch64                     -> refs/west/aarch64
 * [new branch]          add-fakeroots-dir           -> refs/west/add-fakeroots-dir
 * [new branch]          amd64_to_x86_64             -> refs/west/amd64_to_x86_64
 * [new branch]          ancient-clang               -> refs/west/ancient-clang
 * [new branch]          arc-20081103-branch         -> refs/west/arc-20081103-branch
 * [new branch]          arc-insight_6_8-branch      -> refs/west/arc-insight_6_8-branch
 * [new branch]          arm-read-tp-cleanup         -> refs/west/arm-read-tp-cleanup
 * [new branch]          binutils-2_10-branch        -> refs/west/binutils-2_10-branch
 * [new branch]          binutils-2_11-branch        -> refs/west/binutils-2_11-branch
 * [new branch]          binutils-2_12-branch        -> refs/west/binutils-2_12-branch
 * [new branch]          binutils-2_13-branch        -> refs/west/binutils-2_13-branch
 * [new branch]          binutils-2_14-branch        -> refs/west/binutils-2_14-branch
 * [new branch]          binutils-2_15-branch        -> refs/west/binutils-2_15-branch
 * [new branch]          binutils-2_16-branch        -> refs/west/binutils-2_16-branch
 * [new branch]          binutils-2_17-branch        -> refs/west/binutils-2_17-branch
 * [new branch]          binutils-2_18-branch        -> refs/west/binutils-2_18-branch
 * [new branch]          binutils-2_19-branch        -> refs/west/binutils-2_19-branch
 * [new branch]          binutils-2_20-branch        -> refs/west/binutils-2_20-branch
 * [new branch]          binutils-2_21-branch        -> refs/west/binutils-2_21-branch
 * [new branch]          binutils-2_22-branch        -> refs/west/binutils-2_22-branch
 * [new branch]          binutils-2_22_branch        -> refs/west/binutils-2_22_branch
 * [new branch]          binutils-2_23-branch        -> refs/west/binutils-2_23-branch
 * [new branch]          binutils-2_24-branch        -> refs/west/binutils-2_24-branch
 * [new branch]          binutils-arc-20080908-branch -> refs/west/binutils-arc-20080908-branch
 * [new branch]          binutils-arc-20081103-branch -> refs/west/binutils-arc-20081103-branch
 * [new branch]          binutils-csl-2_17-branch    -> refs/west/binutils-csl-2_17-branch
 * [new branch]          binutils-csl-arm-2005q1-branch -> refs/west/binutils-csl-arm-2005q1-branch
 * [new branch]          binutils-csl-gxxpro-3_4-branch -> refs/west/binutils-csl-gxxpro-3_4-branch
 * [new branch]          branch-1.4.6                -> refs/west/branch-1.4.6
 * [new branch]          branch-1.8.4                -> refs/west/branch-1.8.4
 * [new branch]          c-sky                       -> refs/west/c-sky
 * [new branch]          cagney-unwind-20030108-branch -> refs/west/cagney-unwind-20030108-branch
 * [new branch]          cagney_bfdfile-20040213-branch -> refs/west/cagney_bfdfile-20040213-branch
 * [new branch]          cagney_bigcore-20040122-branch -> refs/west/cagney_bigcore-20040122-branch
 * [new branch]          cagney_convert-20030606-branch -> refs/west/cagney_convert-20030606-branch
 * [new branch]          cagney_fileio-20030521-branch -> refs/west/cagney_fileio-20030521-branch
 * [new branch]          cagney_frameaddr-20030403-branch -> refs/west/cagney_frameaddr-20030403-branch
 * [new branch]          cagney_framebase-20030326-branch -> refs/west/cagney_framebase-20030326-branch
 * [new branch]          cagney_lazyid-20030317-branch -> refs/west/cagney_lazyid-20030317-branch
 * [new branch]          cagney_offbyone-20030303-branch -> refs/west/cagney_offbyone-20030303-branch
 * [new branch]          cagney_regbuf-20020515-branch -> refs/west/cagney_regbuf-20020515-branch
 * [new branch]          cagney_sysregs-20020825-branch -> refs/west/cagney_sysregs-20020825-branch
 * [new branch]          cagney_tramp-20040309-branch -> refs/west/cagney_tramp-20040309-branch
 * [new branch]          cagney_writestrings-20030508-branch -> refs/west/cagney_writestrings-20030508-branch
 * [new branch]          cagney_x86i386-20030821-branch -> refs/west/cagney_x86i386-20030821-branch
 * [new branch]          callout                     -> refs/west/callout
 * [new branch]          carlton_dictionary-branch   -> refs/west/carlton_dictionary-branch
 * [new branch]          cgen-1_1-branch             -> refs/west/cgen-1_1-branch
 * [new branch]          cgf-deleteme                -> refs/west/cgf-deleteme
 * [new branch]          cgf-dev-branch              -> refs/west/cgf-dev-branch
 * [new branch]          cmake                       -> refs/west/cmake
 * [new branch]          cmake-no-tls                -> refs/west/cmake-no-tls
 * [new branch]          cmake-small-ultoa           -> refs/west/cmake-small-ultoa
 * [new branch]          cr-0x3b58                   -> refs/west/cr-0x3b58
 * [new branch]          cr-0x5e6                    -> refs/west/cr-0x5e6
 * [new branch]          cr-0x5ef                    -> refs/west/cr-0x5ef
 * [new branch]          cr-0x5f1                    -> refs/west/cr-0x5f1
 * [new branch]          cr-0x9b                     -> refs/west/cr-0x9b
 * [new branch]          cr-0x9c                     -> refs/west/cr-0x9c
 * [new branch]          cr-0x9d                     -> refs/west/cr-0x9d
 * [new branch]          cr-0x9e                     -> refs/west/cr-0x9e
 * [new branch]          csl-arm-20050325-branch     -> refs/west/csl-arm-20050325-branch
 * [new branch]          cv-branch                   -> refs/west/cv-branch
 * [new branch]          cv-branch-2                 -> refs/west/cv-branch-2
 * [new branch]          cv-post-1_7_9               -> refs/west/cv-post-1_7_9
 * [new branch]          cygnus                      -> refs/west/cygnus
 * [new branch]          cygwin-1-1-4                -> refs/west/cygwin-1-1-4
 * [new branch]          cygwin-1-3-1                -> refs/west/cygwin-1-3-1
 * [new branch]          cygwin-1-3-10-1             -> refs/west/cygwin-1-3-10-1
 * [new branch]          cygwin-1-3-11-3             -> refs/west/cygwin-1-3-11-3
 * [new branch]          cygwin-1-3-12-1             -> refs/west/cygwin-1-3-12-1
 * [new branch]          cygwin-1-3-13-1             -> refs/west/cygwin-1-3-13-1
 * [new branch]          cygwin-1-3-13-2             -> refs/west/cygwin-1-3-13-2
 * [new branch]          cygwin-1-3-14-1             -> refs/west/cygwin-1-3-14-1
 * [new branch]          cygwin-1-3-15-1             -> refs/west/cygwin-1-3-15-1
 * [new branch]          cygwin-1-3-16-1             -> refs/west/cygwin-1-3-16-1
 * [new branch]          cygwin-1-3-17-1             -> refs/west/cygwin-1-3-17-1
 * [new branch]          cygwin-1-3-18-1             -> refs/west/cygwin-1-3-18-1
 * [new branch]          cygwin-1-3-19-1             -> refs/west/cygwin-1-3-19-1
 * [new branch]          cygwin-1-3-2                -> refs/west/cygwin-1-3-2
 * [new branch]          cygwin-1-3-3                -> refs/west/cygwin-1-3-3
 * [new branch]          cygwin-1-3-4                -> refs/west/cygwin-1-3-4
 * [new branch]          cygwin-1-3-5                -> refs/west/cygwin-1-3-5
 * [new branch]          cygwin-1-3-5-2              -> refs/west/cygwin-1-3-5-2
 * [new branch]          cygwin-1-3-5-3              -> refs/west/cygwin-1-3-5-3
 * [new branch]          cygwin-1-3-6-1              -> refs/west/cygwin-1-3-6-1
 * [new branch]          cygwin-1-3-6-2              -> refs/west/cygwin-1-3-6-2
 * [new branch]          cygwin-1-3-6-3              -> refs/west/cygwin-1-3-6-3
 * [new branch]          cygwin-1-3-6-4              -> refs/west/cygwin-1-3-6-4
 * [new branch]          cygwin-1-3-6-5              -> refs/west/cygwin-1-3-6-5
 * [new branch]          cygwin-1-3-6-6              -> refs/west/cygwin-1-3-6-6
 * [new branch]          cygwin-1-3-7-1              -> refs/west/cygwin-1-3-7-1
 * [new branch]          cygwin-1-3-8-1              -> refs/west/cygwin-1-3-8-1
 * [new branch]          cygwin-1-3-9                -> refs/west/cygwin-1-3-9
 * [new branch]          cygwin-1_7_29-release-branchpoint -> refs/west/cygwin-1_7_29-release-branchpoint
 * [new branch]          cygwin-2.0                  -> refs/west/cygwin-2.0
 * [new branch]          cygwin-3_0-branch           -> refs/west/cygwin-3_0-branch
 * [new branch]          cygwin-64bit-branch         -> refs/west/cygwin-64bit-branch
 * [new branch]          cygwin-64bit-premerge-branch -> refs/west/cygwin-64bit-premerge-branch
 * [new branch]          cygwin-acl                  -> refs/west/cygwin-acl
 * [new branch]          cygwin_daemon               -> refs/west/cygwin_daemon
 * [new branch]          debian                      -> refs/west/debian
 * [new branch]          dje-cgen-play1-branch       -> refs/west/dje-cgen-play1-branch
 * [new branch]          docker-builder-packages.txt-hash -> refs/west/docker-builder-packages.txt-hash
 * [new branch]          drow-cplus-branch           -> refs/west/drow-cplus-branch
 * [new branch]          drow-reverse-20070409-branch -> refs/west/drow-reverse-20070409-branch
 * [new branch]          drow_intercu-20040221-branch -> refs/west/drow_intercu-20040221-branch
 * [new branch]          ezannoni_pie-20030916-branch -> refs/west/ezannoni_pie-20030916-branch
 * [new branch]          ezannoni_pie-20040323-branch -> refs/west/ezannoni_pie-20040323-branch
 * [new branch]          fifo_doover3                -> refs/west/fifo_doover3
 * [new branch]          fixes-newlib                -> refs/west/fixes-newlib
 * [new branch]          float-inlines               -> refs/west/float-inlines
 * [new branch]          fp-zeuch                    -> refs/west/fp-zeuch
 * [new branch]          gdb-csl-20060226-branch     -> refs/west/gdb-csl-20060226-branch
 * [new branch]          gdb-csl-arm-20051020-branch -> refs/west/gdb-csl-arm-20051020-branch
 * [new branch]          gdb-csl-available-20060303-branch -> refs/west/gdb-csl-available-20060303-branch
 * [new branch]          gdb-csl-gxxpro-6_3-branch   -> refs/west/gdb-csl-gxxpro-6_3-branch
 * [new branch]          gdb-csl-symbian-20060226-branch -> refs/west/gdb-csl-symbian-20060226-branch
 * [new branch]          gdb-premipsmulti-2000-06-06-branch -> refs/west/gdb-premipsmulti-2000-06-06-branch
 * [new branch]          gdb_5_0-2000-04-10-branch   -> refs/west/gdb_5_0-2000-04-10-branch
 * [new branch]          gdb_5_1-2001-07-29-branch   -> refs/west/gdb_5_1-2001-07-29-branch
 * [new branch]          gdb_5_1_0_1-2002-01-03-branch -> refs/west/gdb_5_1_0_1-2002-01-03-branch
 * [new branch]          gdb_5_2-branch              -> refs/west/gdb_5_2-branch
 * [new branch]          gdb_5_3-branch              -> refs/west/gdb_5_3-branch
 * [new branch]          gdb_6_0-branch              -> refs/west/gdb_6_0-branch
 * [new branch]          gdb_6_1-branch              -> refs/west/gdb_6_1-branch
 * [new branch]          gdb_6_2-branch              -> refs/west/gdb_6_2-branch
 * [new branch]          gdb_6_3-branch              -> refs/west/gdb_6_3-branch
 * [new branch]          gdb_6_4-branch              -> refs/west/gdb_6_4-branch
 * [new branch]          gdb_6_5-branch              -> refs/west/gdb_6_5-branch
 * [new branch]          gdb_6_6-branch              -> refs/west/gdb_6_6-branch
 * [new branch]          gdb_6_7-branch              -> refs/west/gdb_6_7-branch
 * [new branch]          gdb_6_8-branch              -> refs/west/gdb_6_8-branch
 * [new branch]          gdb_7_0-branch              -> refs/west/gdb_7_0-branch
 * [new branch]          gdb_7_1-branch              -> refs/west/gdb_7_1-branch
 * [new branch]          gdb_7_2-branch              -> refs/west/gdb_7_2-branch
 * [new branch]          gdb_7_3-branch              -> refs/west/gdb_7_3-branch
 * [new branch]          gdb_7_4-branch              -> refs/west/gdb_7_4-branch
 * [new branch]          gdb_7_5-branch              -> refs/west/gdb_7_5-branch
 * [new branch]          gdb_7_6-branch              -> refs/west/gdb_7_6-branch
 * [new branch]          gdb_s390-2001-09-26-branch  -> refs/west/gdb_s390-2001-09-26-branch
 * [new branch]          gh                          -> refs/west/gh
 * [new branch]          insight_6_8-branch          -> refs/west/insight_6_8-branch
 * [new branch]          interps-20030202-branch     -> refs/west/interps-20030202-branch
 * [new branch]          isblank-extern-inline       -> refs/west/isblank-extern-inline
 * [new branch]          jimb-gdb_6_2-e500-branch    -> refs/west/jimb-gdb_6_2-e500-branch
 * [new branch]          jimb-macro-020506-branch    -> refs/west/jimb-macro-020506-branch
 * [new branch]          jimb-ppc64-linux-20030509-branch -> refs/west/jimb-ppc64-linux-20030509-branch
 * [new branch]          jimb-ppc64-linux-20030528-branch -> refs/west/jimb-ppc64-linux-20030528-branch
 * [new branch]          jimb-ppc64-linux-20030613-branch -> refs/west/jimb-ppc64-linux-20030613-branch
 * [new branch]          jimb-rda-nptl-branch        -> refs/west/jimb-rda-nptl-branch
 * [new branch]          kettenis-i386newframe-20030308-branch -> refs/west/kettenis-i386newframe-20030308-branch
 * [new branch]          kettenis_i386newframe-20030406-branch -> refs/west/kettenis_i386newframe-20030406-branch
 * [new branch]          kettenis_i386newframe-20030419-branch -> refs/west/kettenis_i386newframe-20030419-branch
 * [new branch]          kettenis_sparc-20030918-branch -> refs/west/kettenis_sparc-20030918-branch
 * [new branch]          kseitz_interps-20020528-branch -> refs/west/kseitz_interps-20020528-branch
 * [new branch]          locking-docs                -> refs/west/locking-docs
 * [new branch]          mingw-std-ns-branch         -> refs/west/mingw-std-ns-branch
 * [new branch]          mingwex                     -> refs/west/mingwex
 * [new branch]          msnyder-checkpoint-072509-branch -> refs/west/msnyder-checkpoint-072509-branch
 * [new branch]          msnyder-fork-checkpoint-branch -> refs/west/msnyder-fork-checkpoint-branch
 * [new branch]          msnyder-reverse-20060331-branch -> refs/west/msnyder-reverse-20060331-branch
 * [new branch]          msnyder-reverse-20060502-branch -> refs/west/msnyder-reverse-20060502-branch
 * [new branch]          msnyder-reverse-20080609-branch -> refs/west/msnyder-reverse-20080609-branch
 * [new branch]          msnyder-tracepoint-checkpoint-branch -> refs/west/msnyder-tracepoint-checkpoint-branch
 * [new branch]          msp430                      -> refs/west/msp430
 * [new branch]          multiprocess-20081120-branch -> refs/west/multiprocess-20081120-branch
 * [new branch]          newlib                      -> refs/west/newlib
 * [new branch]          newlib-1_17_0-arc           -> refs/west/newlib-1_17_0-arc
 * [new branch]          newlib-autotools-branch     -> refs/west/newlib-autotools-branch
 * [new branch]          newlib-csl-20060320-branch  -> refs/west/newlib-csl-20060320-branch
 * [new branch]          nickrob-async-20060513-branch -> refs/west/nickrob-async-20060513-branch
 * [new branch]          non-linux-ln                -> refs/west/non-linux-ln
 * [new branch]          noreparent                  -> refs/west/noreparent
 * [new branch]          offbyone-20030313-branch    -> refs/west/offbyone-20030313-branch
 * [new branch]          pre-regex                   -> refs/west/pre-regex
 * [new branch]          pregp02r1                   -> refs/west/pregp02r1
 * [new branch]          readline_4_3-import-branch  -> refs/west/readline_4_3-import-branch
 * [new branch]          readline_5_1-import-branch  -> refs/west/readline_5_1-import-branch
 * [new branch]          reverse-20080717-branch     -> refs/west/reverse-20080717-branch
 * [new branch]          reverse-20080930-branch     -> refs/west/reverse-20080930-branch
 * [new branch]          reverse-20081226-branch     -> refs/west/reverse-20081226-branch
 * [new branch]          riscv-zicsr                 -> refs/west/riscv-zicsr
 * [new branch]          semihost-2.0-all            -> refs/west/semihost-2.0-all
 * [new branch]          sid-20020905-branch         -> refs/west/sid-20020905-branch
 * [new branch]          signal-rewrite              -> refs/west/signal-rewrite
 * [new branch]          sysroot-skip-checks         -> refs/west/sysroot-skip-checks
 * [new branch]          tcltk840-20020924-branch    -> refs/west/tcltk840-20020924-branch
 * [new branch]          tls                         -> refs/west/tls
 * [new branch]          topic/af_unix               -> refs/west/topic/af_unix
 * [new branch]          topic/ansification          -> refs/west/topic/ansification
 * [new branch]          topic/fifo                  -> refs/west/topic/fifo
 * [new branch]          topic/forkables             -> refs/west/topic/forkables
 * [new branch]          topic/locales               -> refs/west/topic/locales
 * [new branch]          topic/posix_acl_funcs       -> refs/west/topic/posix_acl_funcs
 * [new branch]          topic/ssp                   -> refs/west/topic/ssp
 * [new branch]          unlabeled-1.1.1.1.2         -> refs/west/unlabeled-1.1.1.1.2
 * [new branch]          unlabeled-1.100.2           -> refs/west/unlabeled-1.100.2
 * [new branch]          unlabeled-1.1010.2          -> refs/west/unlabeled-1.1010.2
 * [new branch]          unlabeled-1.1019.2          -> refs/west/unlabeled-1.1019.2
 * [new branch]          unlabeled-1.1042.2          -> refs/west/unlabeled-1.1042.2
 * [new branch]          unlabeled-1.1042.2.1.4      -> refs/west/unlabeled-1.1042.2.1.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4  -> refs/west/unlabeled-1.1042.2.1.4.2.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4.2.2 -> refs/west/unlabeled-1.1042.2.1.4.2.4.2.2
 * [new branch]          unlabeled-1.105.2           -> refs/west/unlabeled-1.105.2
 * [new branch]          unlabeled-1.106.2           -> refs/west/unlabeled-1.106.2
 * [new branch]          unlabeled-1.106.8           -> refs/west/unlabeled-1.106.8
 * [new branch]          unlabeled-1.107.12          -> refs/west/unlabeled-1.107.12
 * [new branch]          unlabeled-1.11.2            -> refs/west/unlabeled-1.11.2
 * [new branch]          unlabeled-1.112.4           -> refs/west/unlabeled-1.112.4
 * [new branch]          unlabeled-1.116.4           -> refs/west/unlabeled-1.116.4
 * [new branch]          unlabeled-1.12.20           -> refs/west/unlabeled-1.12.20
 * [new branch]          unlabeled-1.12.30           -> refs/west/unlabeled-1.12.30
 * [new branch]          unlabeled-1.12.4            -> refs/west/unlabeled-1.12.4
 * [new branch]          unlabeled-1.120.2           -> refs/west/unlabeled-1.120.2
 * [new branch]          unlabeled-1.125.2           -> refs/west/unlabeled-1.125.2
 * [new branch]          unlabeled-1.13.10           -> refs/west/unlabeled-1.13.10
 * [new branch]          unlabeled-1.13.2            -> refs/west/unlabeled-1.13.2
 * [new branch]          unlabeled-1.13.30           -> refs/west/unlabeled-1.13.30
 * [new branch]          unlabeled-1.13.4            -> refs/west/unlabeled-1.13.4
 * [new branch]          unlabeled-1.133.2           -> refs/west/unlabeled-1.133.2
 * [new branch]          unlabeled-1.134.4           -> refs/west/unlabeled-1.134.4
 * [new branch]          unlabeled-1.135.4           -> refs/west/unlabeled-1.135.4
 * [new branch]          unlabeled-1.1370.2          -> refs/west/unlabeled-1.1370.2
 * [new branch]          unlabeled-1.142.2           -> refs/west/unlabeled-1.142.2
 * [new branch]          unlabeled-1.143.4           -> refs/west/unlabeled-1.143.4
 * [new branch]          unlabeled-1.144.2           -> refs/west/unlabeled-1.144.2
 * [new branch]          unlabeled-1.15.10           -> refs/west/unlabeled-1.15.10
 * [new branch]          unlabeled-1.15.2            -> refs/west/unlabeled-1.15.2
 * [new branch]          unlabeled-1.1527.4          -> refs/west/unlabeled-1.1527.4
 * [new branch]          unlabeled-1.153.2           -> refs/west/unlabeled-1.153.2
 * [new branch]          unlabeled-1.1563.2          -> refs/west/unlabeled-1.1563.2
 * [new branch]          unlabeled-1.1656.2          -> refs/west/unlabeled-1.1656.2
 * [new branch]          unlabeled-1.167.4           -> refs/west/unlabeled-1.167.4
 * [new branch]          unlabeled-1.17.2            -> refs/west/unlabeled-1.17.2
 * [new branch]          unlabeled-1.17.4            -> refs/west/unlabeled-1.17.4
 * [new branch]          unlabeled-1.1710.2          -> refs/west/unlabeled-1.1710.2
 * [new branch]          unlabeled-1.172.4           -> refs/west/unlabeled-1.172.4
 * [new branch]          unlabeled-1.18.10           -> refs/west/unlabeled-1.18.10
 * [new branch]          unlabeled-1.18.2            -> refs/west/unlabeled-1.18.2
 * [new branch]          unlabeled-1.1806.2          -> refs/west/unlabeled-1.1806.2
 * [new branch]          unlabeled-1.1856.2          -> refs/west/unlabeled-1.1856.2
 * [new branch]          unlabeled-1.188.2           -> refs/west/unlabeled-1.188.2
 * [new branch]          unlabeled-1.188.2.1.8       -> refs/west/unlabeled-1.188.2.1.8
 * [new branch]          unlabeled-1.188.2.1.8.2.2   -> refs/west/unlabeled-1.188.2.1.8.2.2
 * [new branch]          unlabeled-1.19.12           -> refs/west/unlabeled-1.19.12
 * [new branch]          unlabeled-1.2.2             -> refs/west/unlabeled-1.2.2
 * [new branch]          unlabeled-1.20.4            -> refs/west/unlabeled-1.20.4
 * [new branch]          unlabeled-1.21.2            -> refs/west/unlabeled-1.21.2
 * [new branch]          unlabeled-1.21.4            -> refs/west/unlabeled-1.21.4
 * [new branch]          unlabeled-1.22.2            -> refs/west/unlabeled-1.22.2
 * [new branch]          unlabeled-1.22.4            -> refs/west/unlabeled-1.22.4
 * [new branch]          unlabeled-1.226.2           -> refs/west/unlabeled-1.226.2
 * [new branch]          unlabeled-1.23.16           -> refs/west/unlabeled-1.23.16
 * [new branch]          unlabeled-1.23.2            -> refs/west/unlabeled-1.23.2
 * [new branch]          unlabeled-1.23.4            -> refs/west/unlabeled-1.23.4
 * [new branch]          unlabeled-1.231.4           -> refs/west/unlabeled-1.231.4
 * [new branch]          unlabeled-1.234.16          -> refs/west/unlabeled-1.234.16
 * [new branch]          unlabeled-1.235.2           -> refs/west/unlabeled-1.235.2
 * [new branch]          unlabeled-1.238.4           -> refs/west/unlabeled-1.238.4
 * [new branch]          unlabeled-1.24.16           -> refs/west/unlabeled-1.24.16
 * [new branch]          unlabeled-1.24.2            -> refs/west/unlabeled-1.24.2
 * [new branch]          unlabeled-1.24.4            -> refs/west/unlabeled-1.24.4
 * [new branch]          unlabeled-1.248.2           -> refs/west/unlabeled-1.248.2
 * [new branch]          unlabeled-1.253.2           -> refs/west/unlabeled-1.253.2
 * [new branch]          unlabeled-1.27.12           -> refs/west/unlabeled-1.27.12
 * [new branch]          unlabeled-1.27.8            -> refs/west/unlabeled-1.27.8
 * [new branch]          unlabeled-1.30.4            -> refs/west/unlabeled-1.30.4
 * [new branch]          unlabeled-1.31.4            -> refs/west/unlabeled-1.31.4
 * [new branch]          unlabeled-1.32.16           -> refs/west/unlabeled-1.32.16
 * [new branch]          unlabeled-1.32.2            -> refs/west/unlabeled-1.32.2
 * [new branch]          unlabeled-1.35.12           -> refs/west/unlabeled-1.35.12
 * [new branch]          unlabeled-1.38.4            -> refs/west/unlabeled-1.38.4
 * [new branch]          unlabeled-1.39.2            -> refs/west/unlabeled-1.39.2
 * [new branch]          unlabeled-1.44.2            -> refs/west/unlabeled-1.44.2
 * [new branch]          unlabeled-1.44.4            -> refs/west/unlabeled-1.44.4
 * [new branch]          unlabeled-1.45.2            -> refs/west/unlabeled-1.45.2
 * [new branch]          unlabeled-1.45.8            -> refs/west/unlabeled-1.45.8
 * [new branch]          unlabeled-1.46.4            -> refs/west/unlabeled-1.46.4
 * [new branch]          unlabeled-1.48.16           -> refs/west/unlabeled-1.48.16
 * [new branch]          unlabeled-1.5.16            -> refs/west/unlabeled-1.5.16
 * [new branch]          unlabeled-1.5.2             -> refs/west/unlabeled-1.5.2
 * [new branch]          unlabeled-1.50.2            -> refs/west/unlabeled-1.50.2
 * [new branch]          unlabeled-1.50.6            -> refs/west/unlabeled-1.50.6
 * [new branch]          unlabeled-1.52.2            -> refs/west/unlabeled-1.52.2
 * [new branch]          unlabeled-1.53.6            -> refs/west/unlabeled-1.53.6
 * [new branch]          unlabeled-1.54.4            -> refs/west/unlabeled-1.54.4
 * [new branch]          unlabeled-1.64.2            -> refs/west/unlabeled-1.64.2
 * [new branch]          unlabeled-1.65.12           -> refs/west/unlabeled-1.65.12
 * [new branch]          unlabeled-1.65.4            -> refs/west/unlabeled-1.65.4
 * [new branch]          unlabeled-1.66.2            -> refs/west/unlabeled-1.66.2
 * [new branch]          unlabeled-1.69.4            -> refs/west/unlabeled-1.69.4
 * [new branch]          unlabeled-1.74.4            -> refs/west/unlabeled-1.74.4
 * [new branch]          unlabeled-1.75.4            -> refs/west/unlabeled-1.75.4
 * [new branch]          unlabeled-1.8.2             -> refs/west/unlabeled-1.8.2
 * [new branch]          unlabeled-1.81.2            -> refs/west/unlabeled-1.81.2
 * [new branch]          unlabeled-1.83.4            -> refs/west/unlabeled-1.83.4
 * [new branch]          unlabeled-1.86.2            -> refs/west/unlabeled-1.86.2
 * [new branch]          unlabeled-1.88.2            -> refs/west/unlabeled-1.88.2
 * [new branch]          unlabeled-1.90.2            -> refs/west/unlabeled-1.90.2
 * [new branch]          unlabeled-1.90.2.1.4        -> refs/west/unlabeled-1.90.2.1.4
 * [new branch]          unlabeled-1.93.2            -> refs/west/unlabeled-1.93.2
 * [new branch]          vendor                      -> refs/west/vendor
 * [new branch]          x86-more-32                 -> refs/west/x86-more-32
 * [new branch]          zephyr-add-library          -> refs/west/zephyr-add-library
 * [new branch]          zephyr-deprecated           -> refs/west/zephyr-deprecated
 * [new branch]          zephyr-hacks                -> refs/west/zephyr-hacks
 * [new branch]          zephyr-no-posix-define      -> refs/west/zephyr-no-posix-define
 * [new branch]          zephyr-posix                -> refs/west/zephyr-posix
 * [new branch]          zephyr-source               -> refs/west/zephyr-source
 * [new tag]             1.0                         -> 1.0
 * [new tag]             1.0-1                       -> 1.0-1
 * [new tag]             1.1                         -> 1.1
 * [new tag]             1.1-1                       -> 1.1-1
 * [new tag]             1.1-2                       -> 1.1-2
 * [new tag]             1.1.1-1                     -> 1.1.1-1
 * [new tag]             1.2                         -> 1.2
 * [new tag]             1.2-1                       -> 1.2-1
 * [new tag]             1.2.1-1                     -> 1.2.1-1
 * [new tag]             1.3                         -> 1.3
 * [new tag]             1.3-1                       -> 1.3-1
 * [new tag]             1.4                         -> 1.4
 * [new tag]             1.4-1                       -> 1.4-1
 * [new tag]             1.4.1-1                     -> 1.4.1-1
 * [new tag]             1.4.1-2                     -> 1.4.1-2
 * [new tag]             1.4.2-1                     -> 1.4.2-1
 * [new tag]             1.4.2-2                     -> 1.4.2-2
 * [new tag]             1.4.2-3                     -> 1.4.2-3
 * [new tag]             1.4.3-1                     -> 1.4.3-1
 * [new tag]             1.4.4-1                     -> 1.4.4-1
 * [new tag]             1.4.5                       -> 1.4.5
 * [new tag]             1.4.5-1                     -> 1.4.5-1
 * [new tag]             1.4.6                       -> 1.4.6
 * [new tag]             1.4.6-1                     -> 1.4.6-1
 * [new tag]             1.4.7                       -> 1.4.7
 * [new tag]             1.4.7-1                     -> 1.4.7-1
 * [new tag]             1.4.7-2                     -> 1.4.7-2
 * [new tag]             1.5                         -> 1.5
 * [new tag]             1.5-1                       -> 1.5-1
 * [new tag]             1.5.1-1                     -> 1.5.1-1
 * [new tag]             1.5.1-2                     -> 1.5.1-2
 * [new tag]             1.6                         -> 1.6
 * [new tag]             1.6-1                       -> 1.6-1
 * [new tag]             1.6.1-1                     -> 1.6.1-1
 * [new tag]             1.6.2-1                     -> 1.6.2-1
 * [new tag]             1.7                         -> 1.7
 * [new tag]             1.7-1                       -> 1.7-1
 * [new tag]             1.7.1-1                     -> 1.7.1-1
 * [new tag]             1.7.2-1                     -> 1.7.2-1
 * [new tag]             1.7.2-2                     -> 1.7.2-2
 * [new tag]             1.7.3-1                     -> 1.7.3-1
 * [new tag]             1.7.3-2                     -> 1.7.3-2
 * [new tag]             1.7.4-1                     -> 1.7.4-1
 * [new tag]             1.7.5-1                     -> 1.7.5-1
 * [new tag]             1.7.6-1                     -> 1.7.6-1
 * [new tag]             1.7.8                       -> 1.7.8
 * [new tag]             1.7.9                       -> 1.7.9
 * [new tag]             1.8.2                       -> 1.8.2
 * [new tag]             1.8.2-1                     -> 1.8.2-1
 * [new tag]             1.8.4                       -> 1.8.4
 * [new tag]             1.8.6                       -> 1.8.6
 * [new tag]             3.1.0.2019.08.08            -> 3.1.0.2019.08.08
 * [new tag]             3.1.0.2019.08.08-1          -> 3.1.0.2019.08.08-1
 * [new tag]             3.1.0.2019.08.14            -> 3.1.0.2019.08.14
 * [new tag]             3.1.0.2019.08.14-1          -> 3.1.0.2019.08.14-1
 * [new tag]             EOL_registry_mounts         -> EOL_registry_mounts
 * [new tag]             Z-cygwin_daemon_merge-new_HEAD -> Z-cygwin_daemon_merge-new_HEAD
 * [new tag]             Z-cygwin_daemon_merge_HEAD  -> Z-cygwin_daemon_merge_HEAD
 * [new tag]             after-mmap-privanon-noreserve -> after-mmap-privanon-noreserve
 * [new tag]             after-mmap-revamp           -> after-mmap-revamp
 * [new tag]             arc-20081103-branchpoint    -> arc-20081103-branchpoint
 * [new tag]             arc-insight_6_8-branchpoint -> arc-insight_6_8-branchpoint
 * [new tag]             arc-sim-20090309            -> arc-sim-20090309
 * [new tag]             before-mmap-revamp          -> before-mmap-revamp
 * [new tag]             binu_ss_19990502            -> binu_ss_19990502
 * [new tag]             binu_ss_19990602            -> binu_ss_19990602
 * [new tag]             binu_ss_19990721            -> binu_ss_19990721
 * [new tag]             binutils-2_10               -> binutils-2_10
 * [new tag]             binutils-2_10-branchpoint   -> binutils-2_10-branchpoint
 * [new tag]             binutils-2_10_1             -> binutils-2_10_1
 * [new tag]             binutils-2_11               -> binutils-2_11
 * [new tag]             binutils-2_11_1             -> binutils-2_11_1
 * [new tag]             binutils-2_11_2             -> binutils-2_11_2
 * [new tag]             binutils-2_12               -> binutils-2_12
 * [new tag]             binutils-2_12-branchpoint   -> binutils-2_12-branchpoint
 * [new tag]             binutils-2_12_1             -> binutils-2_12_1
 * [new tag]             binutils-2_13               -> binutils-2_13
 * [new tag]             binutils-2_13-branchpoint   -> binutils-2_13-branchpoint
 * [new tag]             binutils-2_13_1             -> binutils-2_13_1
 * [new tag]             binutils-2_13_2             -> binutils-2_13_2
 * [new tag]             binutils-2_13_2_1           -> binutils-2_13_2_1
 * [new tag]             binutils-2_14               -> binutils-2_14
 * [new tag]             binutils-2_14-branchpoint   -> binutils-2_14-branchpoint
 * [new tag]             binutils-2_15               -> binutils-2_15
 * [new tag]             binutils-2_15-branchpoint   -> binutils-2_15-branchpoint
 * [new tag]             binutils-2_16               -> binutils-2_16
 * [new tag]             binutils-2_16-branchpoint   -> binutils-2_16-branchpoint
 * [new tag]             binutils-2_16_1             -> binutils-2_16_1
 * [new tag]             binutils-2_17               -> binutils-2_17
 * [new tag]             binutils-2_17-branchpoint   -> binutils-2_17-branchpoint
 * [new tag]             binutils-2_18               -> binutils-2_18
 * [new tag]             binutils-2_18-branchpoint   -> binutils-2_18-branchpoint
 * [new tag]             binutils-2_19               -> binutils-2_19
 * [new tag]             binutils-2_19-branchpoint   -> binutils-2_19-branchpoint
 * [new tag]             binutils-2_19_1             -> binutils-2_19_1
 * [new tag]             binutils-2_20               -> binutils-2_20
 * [new tag]             binutils-2_20-branchpoint   -> binutils-2_20-branchpoint
 * [new tag]             binutils-2_20_1             -> binutils-2_20_1
 * [new tag]             binutils-2_21               -> binutils-2_21
 * [new tag]             binutils-2_21-branchpoint   -> binutils-2_21-branchpoint
 * [new tag]             binutils-2_21_1             -> binutils-2_21_1
 * [new tag]             binutils-2_22               -> binutils-2_22
 * [new tag]             binutils-2_22-branchpoint   -> binutils-2_22-branchpoint
 * [new tag]             binutils-2_23               -> binutils-2_23
 * [new tag]             binutils-2_23-branchpoint   -> binutils-2_23-branchpoint
 * [new tag]             binutils-2_23_1             -> binutils-2_23_1
 * [new tag]             binutils-2_23_2             -> binutils-2_23_2
 * [new tag]             binutils-2_24-branchpoint   -> binutils-2_24-branchpoint
 * [new tag]             binutils-arc-20080908-branchpoint -> binutils-arc-20080908-branchpoint
 * [new tag]             binutils-arc-20081103-branchpoint -> binutils-arc-20081103-branchpoint
 * [new tag]             binutils-csl-2_17-branchpoint -> binutils-csl-2_17-branchpoint
 * [new tag]             binutils-csl-arm-2005q1-branchpoint -> binutils-csl-arm-2005q1-branchpoint
 * [new tag]             binutils-csl-arm-2005q1a    -> binutils-csl-arm-2005q1a
 * [new tag]             binutils-csl-arm-2005q1b    -> binutils-csl-arm-2005q1b
 * [new tag]             binutils-csl-arm-2006q1-6   -> binutils-csl-arm-2006q1-6
 * [new tag]             binutils-csl-arm-2006q3-19  -> binutils-csl-arm-2006q3-19
 * [new tag]             binutils-csl-arm-2006q3-21  -> binutils-csl-arm-2006q3-21
 * [new tag]             binutils-csl-arm-2006q3-26  -> binutils-csl-arm-2006q3-26
 * [new tag]             binutils-csl-arm-2006q3-27  -> binutils-csl-arm-2006q3-27
 * [new tag]             binutils-csl-coldfire-4_1-10 -> binutils-csl-coldfire-4_1-10
 * [new tag]             binutils-csl-coldfire-4_1-11 -> binutils-csl-coldfire-4_1-11
 * [new tag]             binutils-csl-coldfire-4_1-28 -> binutils-csl-coldfire-4_1-28
 * [new tag]             binutils-csl-coldfire-4_1-30 -> binutils-csl-coldfire-4_1-30
 * [new tag]             binutils-csl-coldfire-4_1-32 -> binutils-csl-coldfire-4_1-32
 * [new tag]             binutils-csl-gxxpro-3_4-branchpoint -> binutils-csl-gxxpro-3_4-branchpoint
 * [new tag]             binutils-csl-innovasic-fido-3_4_4-33 -> binutils-csl-innovasic-fido-3_4_4-33
 * [new tag]             binutils-csl-morpho-4_1-4   -> binutils-csl-morpho-4_1-4
 * [new tag]             binutils-csl-palmsource-arm-prelinker-1_0-1 -> binutils-csl-palmsource-arm-prelinker-1_0-1
 * [new tag]             binutils-csl-renesas-4_1-6  -> binutils-csl-renesas-4_1-6
 * [new tag]             binutils-csl-renesas-4_1-7  -> binutils-csl-renesas-4_1-7
 * [new tag]             binutils-csl-renesas-4_1-8  -> binutils-csl-renesas-4_1-8
 * [new tag]             binutils-csl-renesas-4_1-9  -> binutils-csl-renesas-4_1-9
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-17 -> binutils-csl-sourcerygxx-3_4_4-17
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-19 -> binutils-csl-sourcerygxx-3_4_4-19
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-21 -> binutils-csl-sourcerygxx-3_4_4-21
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-25 -> binutils-csl-sourcerygxx-3_4_4-25
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-32 -> binutils-csl-sourcerygxx-3_4_4-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-12 -> binutils-csl-sourcerygxx-4_1-12
 * [new tag]             binutils-csl-sourcerygxx-4_1-13 -> binutils-csl-sourcerygxx-4_1-13
 * [new tag]             binutils-csl-sourcerygxx-4_1-14 -> binutils-csl-sourcerygxx-4_1-14
 * [new tag]             binutils-csl-sourcerygxx-4_1-15 -> binutils-csl-sourcerygxx-4_1-15
 * [new tag]             binutils-csl-sourcerygxx-4_1-17 -> binutils-csl-sourcerygxx-4_1-17
 * [new tag]             binutils-csl-sourcerygxx-4_1-18 -> binutils-csl-sourcerygxx-4_1-18
 * [new tag]             binutils-csl-sourcerygxx-4_1-19 -> binutils-csl-sourcerygxx-4_1-19
 * [new tag]             binutils-csl-sourcerygxx-4_1-20 -> binutils-csl-sourcerygxx-4_1-20
 * [new tag]             binutils-csl-sourcerygxx-4_1-21 -> binutils-csl-sourcerygxx-4_1-21
 * [new tag]             binutils-csl-sourcerygxx-4_1-22 -> binutils-csl-sourcerygxx-4_1-22
 * [new tag]             binutils-csl-sourcerygxx-4_1-23 -> binutils-csl-sourcerygxx-4_1-23
 * [new tag]             binutils-csl-sourcerygxx-4_1-24 -> binutils-csl-sourcerygxx-4_1-24
 * [new tag]             binutils-csl-sourcerygxx-4_1-25 -> binutils-csl-sourcerygxx-4_1-25
 * [new tag]             binutils-csl-sourcerygxx-4_1-26 -> binutils-csl-sourcerygxx-4_1-26
 * [new tag]             binutils-csl-sourcerygxx-4_1-27 -> binutils-csl-sourcerygxx-4_1-27
 * [new tag]             binutils-csl-sourcerygxx-4_1-28 -> binutils-csl-sourcerygxx-4_1-28
 * [new tag]             binutils-csl-sourcerygxx-4_1-29 -> binutils-csl-sourcerygxx-4_1-29
 * [new tag]             binutils-csl-sourcerygxx-4_1-30 -> binutils-csl-sourcerygxx-4_1-30
 * [new tag]             binutils-csl-sourcerygxx-4_1-32 -> binutils-csl-sourcerygxx-4_1-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-4 -> binutils-csl-sourcerygxx-4_1-4
 * [new tag]             binutils-csl-sourcerygxx-4_1-5 -> binutils-csl-sourcerygxx-4_1-5
 * [new tag]             binutils-csl-sourcerygxx-4_1-6 -> binutils-csl-sourcerygxx-4_1-6
 * [new tag]             binutils-csl-sourcerygxx-4_1-7 -> binutils-csl-sourcerygxx-4_1-7
 * [new tag]             binutils-csl-sourcerygxx-4_1-8 -> binutils-csl-sourcerygxx-4_1-8
 * [new tag]             binutils-csl-sourcerygxx-4_1-9 -> binutils-csl-sourcerygxx-4_1-9
 * [new tag]             binutils-csl-wrs-linux-3_4_4-20 -> binutils-csl-wrs-linux-3_4_4-20
 * [new tag]             binutils-csl-wrs-linux-3_4_4-21 -> binutils-csl-wrs-linux-3_4_4-21
 * [new tag]             binutils-csl-wrs-linux-3_4_4-22 -> binutils-csl-wrs-linux-3_4_4-22
 * [new tag]             binutils-csl-wrs-linux-3_4_4-23 -> binutils-csl-wrs-linux-3_4_4-23
 * [new tag]             binutils-csl-wrs-linux-3_4_4-24 -> binutils-csl-wrs-linux-3_4_4-24
 * [new tag]             binutils_latest_snapshot    -> binutils_latest_snapshot
 * [new tag]             cagney-unwind-20030108-branchpoint -> cagney-unwind-20030108-branchpoint
 * [new tag]             cagney_bfdfile-20040213-branchpoint -> cagney_bfdfile-20040213-branchpoint
 * [new tag]             cagney_bigcore-20040122-branchpoint -> cagney_bigcore-20040122-branchpoint
 * [new tag]             cagney_convert-20030606-branchpoint -> cagney_convert-20030606-branchpoint
 * [new tag]             cagney_fileio-20030521-branchpoint -> cagney_fileio-20030521-branchpoint
 * [new tag]             cagney_frameaddr-20030403-branchpoint -> cagney_frameaddr-20030403-branchpoint
 * [new tag]             cagney_frameaddr-20030409-mergepoint -> cagney_frameaddr-20030409-mergepoint
 * [new tag]             cagney_framebase-20030326-branchpoint -> cagney_framebase-20030326-branchpoint
 * [new tag]             cagney_framebase-20030330-mergepoint -> cagney_framebase-20030330-mergepoint
 * [new tag]             cagney_lazyid-20030317-branchpoint -> cagney_lazyid-20030317-branchpoint
 * [new tag]             cagney_offbyone-20030303-branchpoint -> cagney_offbyone-20030303-branchpoint
 * [new tag]             cagney_regbuf-20020515-branchpoint -> cagney_regbuf-20020515-branchpoint
 * [new tag]             cagney_sysregs-20020825-branchpoint -> cagney_sysregs-20020825-branchpoint
 * [new tag]             cagney_tramp-20040309-branchpoint -> cagney_tramp-20040309-branchpoint
 * [new tag]             cagney_tramp-20040321-mergepoint -> cagney_tramp-20040321-mergepoint
 * [new tag]             cagney_writestrings-20030508-branchpoint -> cagney_writestrings-20030508-branchpoint
 * [new tag]             cagney_x86i386-20030821-branchpoint -> cagney_x86i386-20030821-branchpoint
 * [new tag]             carlton-dictionary-20031111-merge -> carlton-dictionary-20031111-merge
 * [new tag]             carlton_dictionary-20020920-branchpoint -> carlton_dictionary-20020920-branchpoint
 * [new tag]             carlton_dictionary-20020927-merge -> carlton_dictionary-20020927-merge
 * [new tag]             carlton_dictionary-20021011-merge -> carlton_dictionary-20021011-merge
 * [new tag]             carlton_dictionary-20021025-merge -> carlton_dictionary-20021025-merge
 * [new tag]             carlton_dictionary-20021115-merge -> carlton_dictionary-20021115-merge
 * [new tag]             carlton_dictionary-20021223-merge -> carlton_dictionary-20021223-merge
 * [new tag]             carlton_dictionary-20030207-merge -> carlton_dictionary-20030207-merge
 * [new tag]             carlton_dictionary-20030305-merge -> carlton_dictionary-20030305-merge
 * [new tag]             carlton_dictionary-20030416-merge -> carlton_dictionary-20030416-merge
 * [new tag]             carlton_dictionary-20030430-merge -> carlton_dictionary-20030430-merge
 * [new tag]             carlton_dictionary-20030523-merge -> carlton_dictionary-20030523-merge
 * [new tag]             carlton_dictionary-20030627-merge -> carlton_dictionary-20030627-merge
 * [new tag]             carlton_dictionary-20030805-merge -> carlton_dictionary-20030805-merge
 * [new tag]             carlton_dictionary-20030917-merge -> carlton_dictionary-20030917-merge
 * [new tag]             carlton_dictionary-20031215-merge -> carlton_dictionary-20031215-merge
 * [new tag]             carlton_dictionary-20040126-merge -> carlton_dictionary-20040126-merge
 * [new tag]             cgen-1_1-branchpoint        -> cgen-1_1-branchpoint
 * [new tag]             cgen-snapshot-20071001      -> cgen-snapshot-20071001
 * [new tag]             cgen-snapshot-20071101      -> cgen-snapshot-20071101
 * [new tag]             cgen-snapshot-20071201      -> cgen-snapshot-20071201
 * [new tag]             cgen-snapshot-20080101      -> cgen-snapshot-20080101
 * [new tag]             cgen-snapshot-20080201      -> cgen-snapshot-20080201
 * [new tag]             cgen-snapshot-20080301      -> cgen-snapshot-20080301
 * [new tag]             cgen-snapshot-20080401      -> cgen-snapshot-20080401
 * [new tag]             cgen-snapshot-20080501      -> cgen-snapshot-20080501
 * [new tag]             cgen-snapshot-20080601      -> cgen-snapshot-20080601
 * [new tag]             cgen-snapshot-20080701      -> cgen-snapshot-20080701
 * [new tag]             cgen-snapshot-20080801      -> cgen-snapshot-20080801
 * [new tag]             cgen-snapshot-20080901      -> cgen-snapshot-20080901
 * [new tag]             cgen-snapshot-20081001      -> cgen-snapshot-20081001
 * [new tag]             cgen-snapshot-20081101      -> cgen-snapshot-20081101
 * [new tag]             cgen-snapshot-20081201      -> cgen-snapshot-20081201
 * [new tag]             cgen-snapshot-20090101      -> cgen-snapshot-20090101
 * [new tag]             cgen-snapshot-20090201      -> cgen-snapshot-20090201
 * [new tag]             cgen-snapshot-20090301      -> cgen-snapshot-20090301
 * [new tag]             cgen-snapshot-20090401      -> cgen-snapshot-20090401
 * [new tag]             cgen-snapshot-20090501      -> cgen-snapshot-20090501
 * [new tag]             cgen-snapshot-20090601      -> cgen-snapshot-20090601
 * [new tag]             cgen-snapshot-20090701      -> cgen-snapshot-20090701
 * [new tag]             cgen-snapshot-20090801      -> cgen-snapshot-20090801
 * [new tag]             cgen-snapshot-20090901      -> cgen-snapshot-20090901
 * [new tag]             cgen-snapshot-20091001      -> cgen-snapshot-20091001
 * [new tag]             cgen-snapshot-20091101      -> cgen-snapshot-20091101
 * [new tag]             cgen-snapshot-20091201      -> cgen-snapshot-20091201
 * [new tag]             cgen-snapshot-20100101      -> cgen-snapshot-20100101
 * [new tag]             cgen-snapshot-20100201      -> cgen-snapshot-20100201
 * [new tag]             cgen-snapshot-20100301      -> cgen-snapshot-20100301
 * [new tag]             cgen-snapshot-20100401      -> cgen-snapshot-20100401
 * [new tag]             cgen-snapshot-20100501      -> cgen-snapshot-20100501
 * [new tag]             cgen-snapshot-20100601      -> cgen-snapshot-20100601
 * [new tag]             cgen-snapshot-20100701      -> cgen-snapshot-20100701
 * [new tag]             cgen-snapshot-20100801      -> cgen-snapshot-20100801
 * [new tag]             cgen-snapshot-20100901      -> cgen-snapshot-20100901
 * [new tag]             cgen-snapshot-20101001      -> cgen-snapshot-20101001
 * [new tag]             cgen-snapshot-20101101      -> cgen-snapshot-20101101
 * [new tag]             cgen-snapshot-20101201      -> cgen-snapshot-20101201
 * [new tag]             cgen-snapshot-20110101      -> cgen-snapshot-20110101
 * [new tag]             cgen-snapshot-20110201      -> cgen-snapshot-20110201
 * [new tag]             cgen-snapshot-20110301      -> cgen-snapshot-20110301
 * [new tag]             cgen-snapshot-20110401      -> cgen-snapshot-20110401
 * [new tag]             cgen-snapshot-20110501      -> cgen-snapshot-20110501
 * [new tag]             cgen-snapshot-20110601      -> cgen-snapshot-20110601
 * [new tag]             cgen-snapshot-20110701      -> cgen-snapshot-20110701
 * [new tag]             cgen-snapshot-20110801      -> cgen-snapshot-20110801
 * [new tag]             cgen-snapshot-20110901      -> cgen-snapshot-20110901
 * [new tag]             cgen-snapshot-20111001      -> cgen-snapshot-20111001
 * [new tag]             cgen-snapshot-20111101      -> cgen-snapshot-20111101
 * [new tag]             cgen-snapshot-20111201      -> cgen-snapshot-20111201
 * [new tag]             cgen-snapshot-20120101      -> cgen-snapshot-20120101
 * [new tag]             cgen-snapshot-20120201      -> cgen-snapshot-20120201
 * [new tag]             cgen-snapshot-20120301      -> cgen-snapshot-20120301
 * [new tag]             cgen-snapshot-20120401      -> cgen-snapshot-20120401
 * [new tag]             cgen-snapshot-20120501      -> cgen-snapshot-20120501
 * [new tag]             cgen-snapshot-20120601      -> cgen-snapshot-20120601
 * [new tag]             cgen-snapshot-20120701      -> cgen-snapshot-20120701
 * [new tag]             cgen-snapshot-20120801      -> cgen-snapshot-20120801
 * [new tag]             cgen-snapshot-20120901      -> cgen-snapshot-20120901
 * [new tag]             cgen-snapshot-20121001      -> cgen-snapshot-20121001
 * [new tag]             cgen-snapshot-20121101      -> cgen-snapshot-20121101
 * [new tag]             cgen-snapshot-20121201      -> cgen-snapshot-20121201
 * [new tag]             cgen-snapshot-20130101      -> cgen-snapshot-20130101
 * [new tag]             cgen-snapshot-20130201      -> cgen-snapshot-20130201
 * [new tag]             cgen-snapshot-20130301      -> cgen-snapshot-20130301
 * [new tag]             cgen-snapshot-20130401      -> cgen-snapshot-20130401
 * [new tag]             cgen-snapshot-20130501      -> cgen-snapshot-20130501
 * [new tag]             cgen-snapshot-20130601      -> cgen-snapshot-20130601
 * [new tag]             cgen-snapshot-20130701      -> cgen-snapshot-20130701
 * [new tag]             cgen-snapshot-20130801      -> cgen-snapshot-20130801
 * [new tag]             cgen-snapshot-20130901      -> cgen-snapshot-20130901
 * [new tag]             cgen-snapshot-20131001      -> cgen-snapshot-20131001
 * [new tag]             cgen-snapshot-20131101      -> cgen-snapshot-20131101
 * [new tag]             cgen-snapshot-20131201      -> cgen-snapshot-20131201
 * [new tag]             cgen-snapshot-20140101      -> cgen-snapshot-20140101
 * [new tag]             cgen-snapshot-20140201      -> cgen-snapshot-20140201
 * [new tag]             cgen-snapshot-20140301      -> cgen-snapshot-20140301
 * [new tag]             cgen-snapshot-20140401      -> cgen-snapshot-20140401
 * [new tag]             cgen-snapshot-20140501      -> cgen-snapshot-20140501
 * [new tag]             cgen-snapshot-20140601      -> cgen-snapshot-20140601
 * [new tag]             cgen-snapshot-20140701      -> cgen-snapshot-20140701
 * [new tag]             cgen-snapshot-20140801      -> cgen-snapshot-20140801
 * [new tag]             cgen-snapshot-20140901      -> cgen-snapshot-20140901
 * [new tag]             cgen-snapshot-20141001      -> cgen-snapshot-20141001
 * [new tag]             cgen-snapshot-20141101      -> cgen-snapshot-20141101
 * [new tag]             cgen-snapshot-20141201      -> cgen-snapshot-20141201
 * [new tag]             cgen-snapshot-20150101      -> cgen-snapshot-20150101
 * [new tag]             cgen-snapshot-20150201      -> cgen-snapshot-20150201
 * [new tag]             cgen-snapshot-20150301      -> cgen-snapshot-20150301
 * [new tag]             cgf-more-exit-sync          -> cgf-more-exit-sync
 * [new tag]             corinna-01                  -> corinna-01
 * [new tag]             cr-0x99                     -> cr-0x99
 * [new tag]             csl-arm-2003-q4             -> csl-arm-2003-q4
 * [new tag]             csl-arm-2004-q1             -> csl-arm-2004-q1
 * [new tag]             csl-arm-2004-q1a            -> csl-arm-2004-q1a
 * [new tag]             csl-arm-2004-q3             -> csl-arm-2004-q3
 * [new tag]             csl-arm-2004-q3d            -> csl-arm-2004-q3d
 * [new tag]             csl-arm-20050325-branchpoint -> csl-arm-20050325-branchpoint
 * [new tag]             cygnus_cvs_20020108_pre     -> cygnus_cvs_20020108_pre
 * [new tag]             cygwin-1-1-5                -> cygwin-1-1-5
 * [new tag]             cygwin-1-1-6                -> cygwin-1-1-6
 * [new tag]             cygwin-1-1-7                -> cygwin-1-1-7
 * [new tag]             cygwin-1-1-8                -> cygwin-1-1-8
 * [new tag]             cygwin-1-3-19-1-branchpoint -> cygwin-1-3-19-1-branchpoint
 * [new tag]             cygwin-1_1_1                -> cygwin-1_1_1
 * [new tag]             cygwin-1_7_1-release        -> cygwin-1_7_1-release
 * [new tag]             cygwin-1_7_10-release       -> cygwin-1_7_10-release
 * [new tag]             cygwin-1_7_11-release       -> cygwin-1_7_11-release
 * [new tag]             cygwin-1_7_12-release       -> cygwin-1_7_12-release
 * [new tag]             cygwin-1_7_14-release       -> cygwin-1_7_14-release
 * [new tag]             cygwin-1_7_14_2-release     -> cygwin-1_7_14_2-release
 * [new tag]             cygwin-1_7_15-release       -> cygwin-1_7_15-release
 * [new tag]             cygwin-1_7_16-release       -> cygwin-1_7_16-release
 * [new tag]             cygwin-1_7_17-release       -> cygwin-1_7_17-release
 * [new tag]             cygwin-1_7_18-release       -> cygwin-1_7_18-release
 * [new tag]             cygwin-1_7_19-release       -> cygwin-1_7_19-release
 * [new tag]             cygwin-1_7_2-release        -> cygwin-1_7_2-release
 * [new tag]             cygwin-1_7_20-release       -> cygwin-1_7_20-release
 * [new tag]             cygwin-1_7_21-release       -> cygwin-1_7_21-release
 * [new tag]             cygwin-1_7_22-release       -> cygwin-1_7_22-release
 * [new tag]             cygwin-1_7_23-release       -> cygwin-1_7_23-release
 * [new tag]             cygwin-1_7_24-release       -> cygwin-1_7_24-release
 * [new tag]             cygwin-1_7_25-release       -> cygwin-1_7_25-release
 * [new tag]             cygwin-1_7_26-release       -> cygwin-1_7_26-release
 * [new tag]             cygwin-1_7_27-release       -> cygwin-1_7_27-release
 * [new tag]             cygwin-1_7_28-release       -> cygwin-1_7_28-release
 * [new tag]             cygwin-1_7_29-release       -> cygwin-1_7_29-release
 * [new tag]             cygwin-1_7_3-release        -> cygwin-1_7_3-release
 * [new tag]             cygwin-1_7_30-release       -> cygwin-1_7_30-release
 * [new tag]             cygwin-1_7_31-release       -> cygwin-1_7_31-release
 * [new tag]             cygwin-1_7_32-release       -> cygwin-1_7_32-release
 * [new tag]             cygwin-1_7_33-release       -> cygwin-1_7_33-release
 * [new tag]             cygwin-1_7_34-release       -> cygwin-1_7_34-release
 * [new tag]             cygwin-1_7_35-release       -> cygwin-1_7_35-release
 * [new tag]             cygwin-1_7_4-release        -> cygwin-1_7_4-release
 * [new tag]             cygwin-1_7_5-release        -> cygwin-1_7_5-release
 * [new tag]             cygwin-1_7_7-release        -> cygwin-1_7_7-release
 * [new tag]             cygwin-1_7_8-release        -> cygwin-1_7_8-release
 * [new tag]             cygwin-1_7_9-release        -> cygwin-1_7_9-release
 * [new tag]             cygwin-2_0_0-release        -> cygwin-2_0_0-release
 * [new tag]             cygwin-2_0_1-release        -> cygwin-2_0_1-release
 * [new tag]             cygwin-2_0_2-release        -> cygwin-2_0_2-release
 * [new tag]             cygwin-2_0_3-release        -> cygwin-2_0_3-release
 * [new tag]             cygwin-2_0_4-release        -> cygwin-2_0_4-release
 * [new tag]             cygwin-2_10_0-release       -> cygwin-2_10_0-release
 * [new tag]             cygwin-2_11_0-release       -> cygwin-2_11_0-release
 * [new tag]             cygwin-2_11_1-release       -> cygwin-2_11_1-release
 * [new tag]             cygwin-2_11_2-release       -> cygwin-2_11_2-release
 * [new tag]             cygwin-2_1_0-release        -> cygwin-2_1_0-release
 * [new tag]             cygwin-2_2_0-release        -> cygwin-2_2_0-release
 * [new tag]             cygwin-2_2_1-release        -> cygwin-2_2_1-release
 * [new tag]             cygwin-2_3_0-release        -> cygwin-2_3_0-release
 * [new tag]             cygwin-2_3_1-relase         -> cygwin-2_3_1-relase
 * [new tag]             cygwin-2_3_1-release        -> cygwin-2_3_1-release
 * [new tag]             cygwin-2_4_0-release        -> cygwin-2_4_0-release
 * [new tag]             cygwin-2_4_1-release        -> cygwin-2_4_1-release
 * [new tag]             cygwin-2_5_0-release        -> cygwin-2_5_0-release
 * [new tag]             cygwin-2_5_1-release        -> cygwin-2_5_1-release
 * [new tag]             cygwin-2_5_2-release        -> cygwin-2_5_2-release
 * [new tag]             cygwin-2_6_0-release        -> cygwin-2_6_0-release
 * [new tag]             cygwin-2_6_1-release        -> cygwin-2_6_1-release
 * [new tag]             cygwin-2_7_0-release        -> cygwin-2_7_0-release
 * [new tag]             cygwin-2_8_0-release        -> cygwin-2_8_0-release
 * [new tag]             cygwin-2_8_1-release        -> cygwin-2_8_1-release
 * [new tag]             cygwin-2_8_2-release        -> cygwin-2_8_2-release
 * [new tag]             cygwin-2_9_0-release        -> cygwin-2_9_0-release
 * [new tag]             cygwin-3_0_0-release        -> cygwin-3_0_0-release
 * [new tag]             cygwin-3_0_1-release        -> cygwin-3_0_1-release
 * [new tag]             cygwin-3_0_2-release        -> cygwin-3_0_2-release
 * [new tag]             cygwin-3_0_3-release        -> cygwin-3_0_3-release
 * [new tag]             cygwin-3_0_4-release        -> cygwin-3_0_4-release
 * [new tag]             cygwin-3_0_5-release        -> cygwin-3_0_5-release
 * [new tag]             cygwin-3_0_6-release        -> cygwin-3_0_6-release
 * [new tag]             cygwin-3_0_7-release        -> cygwin-3_0_7-release
 * [new tag]             cygwin-3_1_0-release        -> cygwin-3_1_0-release
 * [new tag]             cygwin-3_1_1-release        -> cygwin-3_1_1-release
 * [new tag]             cygwin-3_1_2-release        -> cygwin-3_1_2-release
 * [new tag]             cygwin-3_1_3-release        -> cygwin-3_1_3-release
 * [new tag]             cygwin-3_1_4-release        -> cygwin-3_1_4-release
 * [new tag]             cygwin-64bit-postmerge      -> cygwin-64bit-postmerge
 * [new tag]             cygwin-64bit-premerge       -> cygwin-64bit-premerge
 * [new tag]             cygwin-pre-user-db          -> cygwin-pre-user-db
 * [new tag]             cygwin_daemon_merge_HEAD    -> cygwin_daemon_merge_HEAD
 * [new tag]             debian-2.10.0-1             -> debian-2.10.0-1
 * [new tag]             dje-cgen-play1-branchpoint  -> dje-cgen-play1-branchpoint
 * [new tag]             drop_9x_support_start       -> drop_9x_support_start
 * [new tag]             drow-cplus-branchpoint      -> drow-cplus-branchpoint
 * [new tag]             drow-cplus-merge-20021020   -> drow-cplus-merge-20021020
 * [new tag]             drow-cplus-merge-20021025   -> drow-cplus-merge-20021025
 * [new tag]             drow-cplus-merge-20031214   -> drow-cplus-merge-20031214
 * [new tag]             drow-cplus-merge-20031220   -> drow-cplus-merge-20031220
 * [new tag]             drow-cplus-merge-20031224   -> drow-cplus-merge-20031224
 * [new tag]             drow-cplus-merge-20040113   -> drow-cplus-merge-20040113
 * [new tag]             drow-cplus-merge-20040208   -> drow-cplus-merge-20040208
 * [new tag]             drow-reverse-20070409-branchpoint -> drow-reverse-20070409-branchpoint
 * [new tag]             drow_intercu-20040221-branchpoint -> drow_intercu-20040221-branchpoint
 * [new tag]             drow_intercu-merge-20040327 -> drow_intercu-merge-20040327
 * [new tag]             drow_intercu-merge-20040402 -> drow_intercu-merge-20040402
 * [new tag]             drow_intercu-merge-20040915 -> drow_intercu-merge-20040915
 * [new tag]             drow_intercu-merge-20040921 -> drow_intercu-merge-20040921
 * [new tag]             egcs_20000222               -> egcs_20000222
 * [new tag]             ezannoni_pie-20030916-branchpoint -> ezannoni_pie-20030916-branchpoint
 * [new tag]             ezannoni_pie-20040323-branchpoint -> ezannoni_pie-20040323-branchpoint
 * [new tag]             gdb-csl-20060226-branch-local-2 -> gdb-csl-20060226-branch-local-2
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-local-1 -> gdb-csl-20060226-branch-merge-to-csl-local-1
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-symbian-1 -> gdb-csl-20060226-branch-merge-to-csl-symbian-1
 * [new tag]             gdb-csl-20060226-branchpoint -> gdb-csl-20060226-branchpoint
 * [new tag]             gdb-csl-arm-20050325-2005-q1a -> gdb-csl-arm-20050325-2005-q1a
 * [new tag]             gdb-csl-arm-20050325-2005-q1b -> gdb-csl-arm-20050325-2005-q1b
 * [new tag]             gdb-csl-arm-20051020-branchpoint -> gdb-csl-arm-20051020-branchpoint
 * [new tag]             gdb-csl-arm-2006q1-6        -> gdb-csl-arm-2006q1-6
 * [new tag]             gdb-csl-available-20060303-branchpoint -> gdb-csl-available-20060303-branchpoint
 * [new tag]             gdb-csl-coldfire-4_1-10     -> gdb-csl-coldfire-4_1-10
 * [new tag]             gdb-csl-coldfire-4_1-11     -> gdb-csl-coldfire-4_1-11
 * [new tag]             gdb-csl-gxxpro-6_3-branchpoint -> gdb-csl-gxxpro-6_3-branchpoint
 * [new tag]             gdb-csl-morpho-4_1-4        -> gdb-csl-morpho-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-17 -> gdb-csl-sourcerygxx-3_4_4-17
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-19 -> gdb-csl-sourcerygxx-3_4_4-19
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-21 -> gdb-csl-sourcerygxx-3_4_4-21
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-25 -> gdb-csl-sourcerygxx-3_4_4-25
 * [new tag]             gdb-csl-sourcerygxx-4_1-12  -> gdb-csl-sourcerygxx-4_1-12
 * [new tag]             gdb-csl-sourcerygxx-4_1-13  -> gdb-csl-sourcerygxx-4_1-13
 * [new tag]             gdb-csl-sourcerygxx-4_1-14  -> gdb-csl-sourcerygxx-4_1-14
 * [new tag]             gdb-csl-sourcerygxx-4_1-17  -> gdb-csl-sourcerygxx-4_1-17
 * [new tag]             gdb-csl-sourcerygxx-4_1-4   -> gdb-csl-sourcerygxx-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-4_1-5   -> gdb-csl-sourcerygxx-4_1-5
 * [new tag]             gdb-csl-sourcerygxx-4_1-6   -> gdb-csl-sourcerygxx-4_1-6
 * [new tag]             gdb-csl-sourcerygxx-4_1-7   -> gdb-csl-sourcerygxx-4_1-7
 * [new tag]             gdb-csl-sourcerygxx-4_1-8   -> gdb-csl-sourcerygxx-4_1-8
 * [new tag]             gdb-csl-sourcerygxx-4_1-9   -> gdb-csl-sourcerygxx-4_1-9
 * [new tag]             gdb-csl-symbian-20060226-branchpoint -> gdb-csl-symbian-20060226-branchpoint
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-10 -> gdb-csl-symbian-6_4_50_20060226-10
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-11 -> gdb-csl-symbian-6_4_50_20060226-11
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-12 -> gdb-csl-symbian-6_4_50_20060226-12
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-8 -> gdb-csl-symbian-6_4_50_20060226-8
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-9 -> gdb-csl-symbian-6_4_50_20060226-9
 * [new tag]             gdb-premipsmulti-2000-06-06-branchpoint -> gdb-premipsmulti-2000-06-06-branchpoint
 * [new tag]             gdb_4_18_2-2000-05-18-release -> gdb_4_18_2-2000-05-18-release
 * [new tag]             gdb_4_95_0-2000-04-27-snapshot -> gdb_4_95_0-2000-04-27-snapshot
 * [new tag]             gdb_4_95_1-2000-05-11-snapshot -> gdb_4_95_1-2000-05-11-snapshot
 * [new tag]             gdb_5_0-2000-04-10-branchpoint -> gdb_5_0-2000-04-10-branchpoint
 * [new tag]             gdb_5_0-2000-05-19-release  -> gdb_5_0-2000-05-19-release
 * [new tag]             gdb_5_1-2001-07-29-branchpoint -> gdb_5_1-2001-07-29-branchpoint
 * [new tag]             gdb_5_1-2001-11-21-release  -> gdb_5_1-2001-11-21-release
 * [new tag]             gdb_5_1_0_1-2002-01-03-branchpoint -> gdb_5_1_0_1-2002-01-03-branchpoint
 * [new tag]             gdb_5_1_0_1-2002-01-03-release -> gdb_5_1_0_1-2002-01-03-release
 * [new tag]             gdb_5_1_1-2002-01-24-release -> gdb_5_1_1-2002-01-24-release
 * [new tag]             gdb_5_2-2002-03-03-branchpoint -> gdb_5_2-2002-03-03-branchpoint
 * [new tag]             gdb_5_2-2002-04-29-release  -> gdb_5_2-2002-04-29-release
 * [new tag]             gdb_5_2_1-2002-07-23-release -> gdb_5_2_1-2002-07-23-release
 * [new tag]             gdb_5_3-2002-09-04-branchpoint -> gdb_5_3-2002-09-04-branchpoint
 * [new tag]             gdb_5_3-2002-12-12-release  -> gdb_5_3-2002-12-12-release
 * [new tag]             gdb_6_0-2003-06-23-branchpoint -> gdb_6_0-2003-06-23-branchpoint
 * [new tag]             gdb_6_0-2003-10-04-release  -> gdb_6_0-2003-10-04-release
 * [new tag]             gdb_6_1-2004-03-01-gmt-branchpoint -> gdb_6_1-2004-03-01-gmt-branchpoint
 * [new tag]             gdb_6_1-2004-04-05-release  -> gdb_6_1-2004-04-05-release
 * [new tag]             gdb_6_1_1-20040616-release  -> gdb_6_1_1-20040616-release
 * [new tag]             gdb_6_2-2004-07-10-gmt-branchpoint -> gdb_6_2-2004-07-10-gmt-branchpoint
 * [new tag]             gdb_6_2-20040730-release    -> gdb_6_2-20040730-release
 * [new tag]             gdb_6_3-20041019-branchpoint -> gdb_6_3-20041019-branchpoint
 * [new tag]             gdb_6_3-20041109-release    -> gdb_6_3-20041109-release
 * [new tag]             gdb_6_4-2005-11-01-branchpoint -> gdb_6_4-2005-11-01-branchpoint
 * [new tag]             gdb_6_4-20051202-release    -> gdb_6_4-20051202-release
 * [new tag]             gdb_6_5-2006-05-14-branchpoint -> gdb_6_5-2006-05-14-branchpoint
 * [new tag]             gdb_6_5-20060621-release    -> gdb_6_5-20060621-release
 * [new tag]             gdb_6_6-2006-11-15-branchpoint -> gdb_6_6-2006-11-15-branchpoint
 * [new tag]             gdb_6_6-2006-12-18-release  -> gdb_6_6-2006-12-18-release
 * [new tag]             gdb_6_7-2007-09-07-branchpoint -> gdb_6_7-2007-09-07-branchpoint
 * [new tag]             gdb_6_7-2007-10-10-release  -> gdb_6_7-2007-10-10-release
 * [new tag]             gdb_6_7_1-2007-10-29-release -> gdb_6_7_1-2007-10-29-release
 * [new tag]             gdb_6_8-2008-02-26-branchpoint -> gdb_6_8-2008-02-26-branchpoint
 * [new tag]             gdb_6_8-2008-03-27-release  -> gdb_6_8-2008-03-27-release
 * [new tag]             gdb_7_0-2009-09-16-branchpoint -> gdb_7_0-2009-09-16-branchpoint
 * [new tag]             gdb_7_0-2009-10-06-release  -> gdb_7_0-2009-10-06-release
 * [new tag]             gdb_7_0_1-2009-12-22-release -> gdb_7_0_1-2009-12-22-release
 * [new tag]             gdb_7_1-2010-02-18-branchpoint -> gdb_7_1-2010-02-18-branchpoint
 * [new tag]             gdb_7_1-2010-03-18-release  -> gdb_7_1-2010-03-18-release
 * [new tag]             gdb_7_2-2010-07-07-branchpoint -> gdb_7_2-2010-07-07-branchpoint
 * [new tag]             gdb_7_2-2010-09-02-release  -> gdb_7_2-2010-09-02-release
 * [new tag]             gdb_7_3-2011-04-01-branchpoint -> gdb_7_3-2011-04-01-branchpoint
 * [new tag]             gdb_7_3-2011-07-26-release  -> gdb_7_3-2011-07-26-release
 * [new tag]             gdb_7_3_1-2011-09-04-release -> gdb_7_3_1-2011-09-04-release
 * [new tag]             gdb_7_4-2011-12-13-branchpoint -> gdb_7_4-2011-12-13-branchpoint
 * [new tag]             gdb_7_4-2012-01-24-release  -> gdb_7_4-2012-01-24-release
 * [new tag]             gdb_7_4_1-2012-04-26-release -> gdb_7_4_1-2012-04-26-release
 * [new tag]             gdb_7_5-2012-07-18-branchpoint -> gdb_7_5-2012-07-18-branchpoint
 * [new tag]             gdb_7_5-2012-08-17-release  -> gdb_7_5-2012-08-17-release
 * [new tag]             gdb_7_5_1-2012-11-29-release -> gdb_7_5_1-2012-11-29-release
 * [new tag]             gdb_7_6-2013-03-12-branchpoint -> gdb_7_6-2013-03-12-branchpoint
 * [new tag]             gdb_7_6-2013-04-26-release  -> gdb_7_6-2013-04-26-release
 * [new tag]             gdb_7_6_1-2013-08-30-release -> gdb_7_6_1-2013-08-30-release
 * [new tag]             gdb_s390-2001-09-26-branchpoint -> gdb_s390-2001-09-26-branchpoint
 * [new tag]             hmm                         -> hmm
 * [new tag]             insight-precleanup-2001-01-01 -> insight-precleanup-2001-01-01
 * [new tag]             insight_6_5-20061003-release -> insight_6_5-20061003-release
 * [new tag]             insight_6_6-20070208-release -> insight_6_6-20070208-release
 * [new tag]             insight_6_8-branchpoint     -> insight_6_8-branchpoint
 * [new tag]             interps-20030202-branchpoint -> interps-20030202-branchpoint
 * [new tag]             jimb-gdb_6_2-e500-branchpoint -> jimb-gdb_6_2-e500-branchpoint
 * [new tag]             jimb-macro-020506-branchpoint -> jimb-macro-020506-branchpoint
 * [new tag]             jimb-ppc64-linux-20030509-branchpoint -> jimb-ppc64-linux-20030509-branchpoint
 * [new tag]             jimb-ppc64-linux-20030528-branchpoint -> jimb-ppc64-linux-20030528-branchpoint
 * [new tag]             jimb-ppc64-linux-20030613-branchpoint -> jimb-ppc64-linux-20030613-branchpoint
 * [new tag]             jimb-rda-nptl-branchpoint   -> jimb-rda-nptl-branchpoint
 * [new tag]             kettenis-i386newframe-20030308-branchpoint -> kettenis-i386newframe-20030308-branchpoint
 * [new tag]             kettenis-i386newframe-20030316-mergepoint -> kettenis-i386newframe-20030316-mergepoint
 * [new tag]             kettenis_i386newframe-20030406-branchpoint -> kettenis_i386newframe-20030406-branchpoint
 * [new tag]             kettenis_i386newframe-20030419-branchpoint -> kettenis_i386newframe-20030419-branchpoint
 * [new tag]             kettenis_i386newframe-20030504-mergepoint -> kettenis_i386newframe-20030504-mergepoint
 * [new tag]             kettenis_i386newframe-20030517-mergepoint -> kettenis_i386newframe-20030517-mergepoint
 * [new tag]             kettenis_sparc-20030918-branchpoint -> kettenis_sparc-20030918-branchpoint
 * [new tag]             kseitz_interps-20020528-branchpoint -> kseitz_interps-20020528-branchpoint
 * [new tag]             kseitz_interps-20020829-merge -> kseitz_interps-20020829-merge
 * [new tag]             kseitz_interps-20020930-merge -> kseitz_interps-20020930-merge
 * [new tag]             kseitz_interps-20021103-merge -> kseitz_interps-20021103-merge
 * [new tag]             kseitz_interps-20021105-merge -> kseitz_interps-20021105-merge
 * [new tag]             mingw-runtime-2_0           -> mingw-runtime-2_0
 * [new tag]             mingw-runtime-2_4           -> mingw-runtime-2_4
 * [new tag]             msnyder-checkpoint-072509-branchpoint -> msnyder-checkpoint-072509-branchpoint
 * [new tag]             msnyder-fork-checkpoint-branchpoint -> msnyder-fork-checkpoint-branchpoint
 * [new tag]             msnyder-reverse-20060331-branchpoint -> msnyder-reverse-20060331-branchpoint
 * [new tag]             msnyder-reverse-20060502-branchpoint -> msnyder-reverse-20060502-branchpoint
 * [new tag]             msnyder-reverse-20080609-branchpoint -> msnyder-reverse-20080609-branchpoint
 * [new tag]             msnyder-tracepoint-checkpoint-branchpoint -> msnyder-tracepoint-checkpoint-branchpoint
 * [new tag]             multiprocess-20081120-branchpoint -> multiprocess-20081120-branchpoint
 * [new tag]             newlib-1_10_0               -> newlib-1_10_0
 * [new tag]             newlib-1_11_0               -> newlib-1_11_0
 * [new tag]             newlib-1_12_0               -> newlib-1_12_0
 * [new tag]             newlib-1_13_0               -> newlib-1_13_0
 * [new tag]             newlib-1_14_0               -> newlib-1_14_0
 * [new tag]             newlib-1_15_0               -> newlib-1_15_0
 * [new tag]             newlib-1_16_0               -> newlib-1_16_0
 * [new tag]             newlib-1_17_0               -> newlib-1_17_0
 * [new tag]             newlib-1_18_0               -> newlib-1_18_0
 * [new tag]             newlib-1_19_0               -> newlib-1_19_0
 * [new tag]             newlib-1_20_0               -> newlib-1_20_0
 * [new tag]             newlib-1_9_0                -> newlib-1_9_0
 * [new tag]             newlib-2000-02-17           -> newlib-2000-02-17
 * [new tag]             newlib-2_0_0                -> newlib-2_0_0
 * [new tag]             newlib-2_1_0                -> newlib-2_1_0
 * [new tag]             newlib-2_2_0                -> newlib-2_2_0
 * [new tag]             newlib-2_3_0                -> newlib-2_3_0
 * [new tag]             newlib-2_4_0                -> newlib-2_4_0
 * [new tag]             newlib-2_5_0                -> newlib-2_5_0
 * [new tag]             newlib-3.0.0                -> newlib-3.0.0
 * [new tag]             newlib-3.1.0                -> newlib-3.1.0
 * [new tag]             newlib-3.2.0                -> newlib-3.2.0
 * [new tag]             newlib-3.3.0                -> newlib-3.3.0
 * [new tag]             newlib-csl-20060320-branchpoint -> newlib-csl-20060320-branchpoint
 * [new tag]             newlib-csl-arm-2005-q1a     -> newlib-csl-arm-2005-q1a
 * [new tag]             newlib-csl-arm-2005-q1b     -> newlib-csl-arm-2005-q1b
 * [new tag]             newlib-csl-arm-2006q1-6     -> newlib-csl-arm-2006q1-6
 * [new tag]             newlib-csl-arm-2006q3-19    -> newlib-csl-arm-2006q3-19
 * [new tag]             newlib-csl-arm-2006q3-21    -> newlib-csl-arm-2006q3-21
 * [new tag]             newlib-csl-arm-2006q3-26    -> newlib-csl-arm-2006q3-26
 * [new tag]             newlib-csl-arm-2006q3-27    -> newlib-csl-arm-2006q3-27
 * [new tag]             newlib-csl-coldfire-4_1-28  -> newlib-csl-coldfire-4_1-28
 * [new tag]             newlib-csl-coldfire-4_1-30  -> newlib-csl-coldfire-4_1-30
 * [new tag]             newlib-csl-coldfire-4_1-32  -> newlib-csl-coldfire-4_1-32
 * [new tag]             newlib-csl-innovasic-fido-3_4_4-33 -> newlib-csl-innovasic-fido-3_4_4-33
 * [new tag]             newlib-csl-sourcerygxx-3_4_4-25 -> newlib-csl-sourcerygxx-3_4_4-25
 * [new tag]             newlib-csl-sourcerygxx-4_1-12 -> newlib-csl-sourcerygxx-4_1-12
 * [new tag]             newlib-csl-sourcerygxx-4_1-13 -> newlib-csl-sourcerygxx-4_1-13
 * [new tag]             newlib-csl-sourcerygxx-4_1-14 -> newlib-csl-sourcerygxx-4_1-14
 * [new tag]             newlib-csl-sourcerygxx-4_1-17 -> newlib-csl-sourcerygxx-4_1-17
 * [new tag]             newlib-csl-sourcerygxx-4_1-18 -> newlib-csl-sourcerygxx-4_1-18
 * [new tag]             newlib-csl-sourcerygxx-4_1-19 -> newlib-csl-sourcerygxx-4_1-19
 * [new tag]             newlib-csl-sourcerygxx-4_1-21 -> newlib-csl-sourcerygxx-4_1-21
 * [new tag]             newlib-csl-sourcerygxx-4_1-23 -> newlib-csl-sourcerygxx-4_1-23
 * [new tag]             newlib-csl-sourcerygxx-4_1-24 -> newlib-csl-sourcerygxx-4_1-24
 * [new tag]             newlib-csl-sourcerygxx-4_1-26 -> newlib-csl-sourcerygxx-4_1-26
 * [new tag]             newlib-csl-sourcerygxx-4_1-27 -> newlib-csl-sourcerygxx-4_1-27
 * [new tag]             newlib-csl-sourcerygxx-4_1-28 -> newlib-csl-sourcerygxx-4_1-28
 * [new tag]             newlib-csl-sourcerygxx-4_1-30 -> newlib-csl-sourcerygxx-4_1-30
 * [new tag]             newlib-csl-sourcerygxx-4_1-32 -> newlib-csl-sourcerygxx-4_1-32
 * [new tag]             newlib-csl-sourcerygxx-4_1-4 -> newlib-csl-sourcerygxx-4_1-4
 * [new tag]             newlib-csl-sourcerygxx-4_1-5 -> newlib-csl-sourcerygxx-4_1-5
 * [new tag]             newlib-csl-sourcerygxx-4_1-6 -> newlib-csl-sourcerygxx-4_1-6
 * [new tag]             newlib-csl-sourcerygxx-4_1-7 -> newlib-csl-sourcerygxx-4_1-7
 * [new tag]             newlib-csl-sourcerygxx-4_1-8 -> newlib-csl-sourcerygxx-4_1-8
 * [new tag]             newlib-csl-sourcerygxx-4_1-9 -> newlib-csl-sourcerygxx-4_1-9
 * [new tag]             newlib-snapshot-20150323    -> newlib-snapshot-20150323
 * [new tag]             newlib-snapshot-20150423    -> newlib-snapshot-20150423
 * [new tag]             newlib-snapshot-20150526    -> newlib-snapshot-20150526
 * [new tag]             newlib-snapshot-20150623    -> newlib-snapshot-20150623
 * [new tag]             newlib-snapshot-20150723    -> newlib-snapshot-20150723
 * [new tag]             newlib-snapshot-20150824    -> newlib-snapshot-20150824
 * [new tag]             newlib-snapshot-20150924    -> newlib-snapshot-20150924
 * [new tag]             newlib-snapshot-20151023    -> newlib-snapshot-20151023
 * [new tag]             newlib-snapshot-20160104    -> newlib-snapshot-20160104
 * [new tag]             newlib-snapshot-20160226    -> newlib-snapshot-20160226
 * [new tag]             newlib-snapshot-20160527    -> newlib-snapshot-20160527
 * [new tag]             newlib-snapshot-20160923    -> newlib-snapshot-20160923
 * [new tag]             newlib-snapshot-20170228    -> newlib-snapshot-20170228
 * [new tag]             newlib-snapshot-20170323    -> newlib-snapshot-20170323
 * [new tag]             newlib-snapshot-20170421    -> newlib-snapshot-20170421
 * [new tag]             newlib-snapshot-20170519    -> newlib-snapshot-20170519
 * [new tag]             newlib-snapshot-20170623    -> newlib-snapshot-20170623
 * [new tag]             newlib-snapshot-20170720    -> newlib-snapshot-20170720
 * [new tag]             newlib-snapshot-20170818    -> newlib-snapshot-20170818
 * [new tag]             newlib-snapshot-20170922    -> newlib-snapshot-20170922
 * [new tag]             newlib-snapshot-20171222    -> newlib-snapshot-20171222
 * [new tag]             newlib-snapshot-20180118    -> newlib-snapshot-20180118
 * [new tag]             newlib-snapshot-20180226    -> newlib-snapshot-20180226
 * [new tag]             newlib-snapshot-20180720    -> newlib-snapshot-20180720
 * [new tag]             newlib-snapshot-20180802    -> newlib-snapshot-20180802
 * [new tag]             newlib-snapshot-20180831    -> newlib-snapshot-20180831
 * [new tag]             newlib-snapshot-20181231    -> newlib-snapshot-20181231
 * [new tag]             newlib-snapshot-20200102    -> newlib-snapshot-20200102
 * [new tag]             nickrob-async-20060513-branchpoint -> nickrob-async-20060513-branchpoint
 * [new tag]             nickrob-async-20060828-mergepoint -> nickrob-async-20060828-mergepoint
 * [new tag]             offbyone-20030313-branchpoint -> offbyone-20030313-branchpoint
 * [new tag]             post-ptmalloc3              -> post-ptmalloc3
 * [new tag]             post_wait_sig_exit          -> post_wait_sig_exit
 * [new tag]             pre-cgf-merge               -> pre-cgf-merge
 * [new tag]             pre-cygwin-heap             -> pre-cygwin-heap
 * [new tag]             pre-no-this                 -> pre-no-this
 * [new tag]             pre-notty                   -> pre-notty
 * [new tag]             pre-posix-scan              -> pre-posix-scan
 * [new tag]             pre-ptmalloc3               -> pre-ptmalloc3
 * [new tag]             pre-ptymaster-archetype     -> pre-ptymaster-archetype
 * [new tag]             pre-ripout-set_console_state_for_spawn -> pre-ripout-set_console_state_for_spawn
 * [new tag]             pre-sigrewrite              -> pre-sigrewrite
 * [new tag]             pre_wait_sig_exit           -> pre_wait_sig_exit
 * [new tag]             predaemon                   -> predaemon
 * [new tag]             prefifo                     -> prefifo
 * [new tag]             preoverlapped               -> preoverlapped
 * [new tag]             readline_4_3-import-branchpoint -> readline_4_3-import-branchpoint
 * [new tag]             readline_5_1-import-branchpoint -> readline_5_1-import-branchpoint
 * [new tag]             reparent-point              -> reparent-point
 * [new tag]             repo-unification-2000-02-06 -> repo-unification-2000-02-06
 * [new tag]             reverse-20080717-branchpoint -> reverse-20080717-branchpoint
 * [new tag]             reverse-20080930-branchpoint -> reverse-20080930-branchpoint
 * [new tag]             reverse-20081226-branchpoint -> reverse-20081226-branchpoint
 * [new tag]             sid-20020905-branchpoint    -> sid-20020905-branchpoint
 * [new tag]             sid-snapshot-20071001       -> sid-snapshot-20071001
 * [new tag]             sid-snapshot-20071101       -> sid-snapshot-20071101
 * [new tag]             sid-snapshot-20071201       -> sid-snapshot-20071201
 * [new tag]             sid-snapshot-20080101       -> sid-snapshot-20080101
 * [new tag]             sid-snapshot-20080201       -> sid-snapshot-20080201
 * [new tag]             sid-snapshot-20080301       -> sid-snapshot-20080301
 * [new tag]             sid-snapshot-20080401       -> sid-snapshot-20080401
 * [new tag]             sid-snapshot-20080403       -> sid-snapshot-20080403
 * [new tag]             sid-snapshot-20080501       -> sid-snapshot-20080501
 * [new tag]             sid-snapshot-20080601       -> sid-snapshot-20080601
 * [new tag]             sid-snapshot-20080701       -> sid-snapshot-20080701
 * [new tag]             sid-snapshot-20080801       -> sid-snapshot-20080801
 * [new tag]             sid-snapshot-20080901       -> sid-snapshot-20080901
 * [new tag]             sid-snapshot-20081001       -> sid-snapshot-20081001
 * [new tag]             sid-snapshot-20081101       -> sid-snapshot-20081101
 * [new tag]             sid-snapshot-20081201       -> sid-snapshot-20081201
 * [new tag]             sid-snapshot-20090101       -> sid-snapshot-20090101
 * [new tag]             sid-snapshot-20090201       -> sid-snapshot-20090201
 * [new tag]             sid-snapshot-20090301       -> sid-snapshot-20090301
 * [new tag]             sid-snapshot-20090401       -> sid-snapshot-20090401
 * [new tag]             sid-snapshot-20090501       -> sid-snapshot-20090501
 * [new tag]             sid-snapshot-20090601       -> sid-snapshot-20090601
 * [new tag]             sid-snapshot-20090701       -> sid-snapshot-20090701
 * [new tag]             sid-snapshot-20090801       -> sid-snapshot-20090801
 * [new tag]             sid-snapshot-20090901       -> sid-snapshot-20090901
 * [new tag]             sid-snapshot-20091001       -> sid-snapshot-20091001
 * [new tag]             sid-snapshot-20091101       -> sid-snapshot-20091101
 * [new tag]             sid-snapshot-20091201       -> sid-snapshot-20091201
 * [new tag]             sid-snapshot-20100101       -> sid-snapshot-20100101
 * [new tag]             sid-snapshot-20100201       -> sid-snapshot-20100201
 * [new tag]             sid-snapshot-20100301       -> sid-snapshot-20100301
 * [new tag]             sid-snapshot-20100401       -> sid-snapshot-20100401
 * [new tag]             sid-snapshot-20100501       -> sid-snapshot-20100501
 * [new tag]             sid-snapshot-20100601       -> sid-snapshot-20100601
 * [new tag]             sid-snapshot-20100701       -> sid-snapshot-20100701
 * [new tag]             sid-snapshot-20100801       -> sid-snapshot-20100801
 * [new tag]             sid-snapshot-20100901       -> sid-snapshot-20100901
 * [new tag]             sid-snapshot-20101001       -> sid-snapshot-20101001
 * [new tag]             sid-snapshot-20101101       -> sid-snapshot-20101101
 * [new tag]             sid-snapshot-20101201       -> sid-snapshot-20101201
 * [new tag]             sid-snapshot-20110101       -> sid-snapshot-20110101
 * [new tag]             sid-snapshot-20110201       -> sid-snapshot-20110201
 * [new tag]             sid-snapshot-20110301       -> sid-snapshot-20110301
 * [new tag]             sid-snapshot-20110401       -> sid-snapshot-20110401
 * [new tag]             sid-snapshot-20110501       -> sid-snapshot-20110501
 * [new tag]             sid-snapshot-20110601       -> sid-snapshot-20110601
 * [new tag]             sid-snapshot-20110701       -> sid-snapshot-20110701
 * [new tag]             sid-snapshot-20110801       -> sid-snapshot-20110801
 * [new tag]             sid-snapshot-20110901       -> sid-snapshot-20110901
 * [new tag]             sid-snapshot-20111001       -> sid-snapshot-20111001
 * [new tag]             sid-snapshot-20111101       -> sid-snapshot-20111101
 * [new tag]             sid-snapshot-20111201       -> sid-snapshot-20111201
 * [new tag]             sid-snapshot-20120101       -> sid-snapshot-20120101
 * [new tag]             sid-snapshot-20120201       -> sid-snapshot-20120201
 * [new tag]             sid-snapshot-20120301       -> sid-snapshot-20120301
 * [new tag]             sid-snapshot-20120401       -> sid-snapshot-20120401
 * [new tag]             sid-snapshot-20120501       -> sid-snapshot-20120501
 * [new tag]             sid-snapshot-20120601       -> sid-snapshot-20120601
 * [new tag]             sid-snapshot-20120701       -> sid-snapshot-20120701
 * [new tag]             sid-snapshot-20120801       -> sid-snapshot-20120801
 * [new tag]             sid-snapshot-20120901       -> sid-snapshot-20120901
 * [new tag]             sid-snapshot-20121001       -> sid-snapshot-20121001
 * [new tag]             sid-snapshot-20121101       -> sid-snapshot-20121101
 * [new tag]             sid-snapshot-20121201       -> sid-snapshot-20121201
 * [new tag]             sid-snapshot-20130101       -> sid-snapshot-20130101
 * [new tag]             sid-snapshot-20130201       -> sid-snapshot-20130201
 * [new tag]             sid-snapshot-20130301       -> sid-snapshot-20130301
 * [new tag]             sid-snapshot-20130401       -> sid-snapshot-20130401
 * [new tag]             sid-snapshot-20130501       -> sid-snapshot-20130501
 * [new tag]             sid-snapshot-20130601       -> sid-snapshot-20130601
 * [new tag]             sid-snapshot-20130701       -> sid-snapshot-20130701
 * [new tag]             sid-snapshot-20130801       -> sid-snapshot-20130801
 * [new tag]             sid-snapshot-20130901       -> sid-snapshot-20130901
 * [new tag]             sid-snapshot-20131001       -> sid-snapshot-20131001
 * [new tag]             sid-snapshot-20131101       -> sid-snapshot-20131101
 * [new tag]             sid-snapshot-20131201       -> sid-snapshot-20131201
 * [new tag]             sid-snapshot-20140101       -> sid-snapshot-20140101
 * [new tag]             sid-snapshot-20140201       -> sid-snapshot-20140201
 * [new tag]             sid-snapshot-20140301       -> sid-snapshot-20140301
 * [new tag]             sid-snapshot-20140401       -> sid-snapshot-20140401
 * [new tag]             sid-snapshot-20140501       -> sid-snapshot-20140501
 * [new tag]             sid-snapshot-20140601       -> sid-snapshot-20140601
 * [new tag]             sid-snapshot-20140701       -> sid-snapshot-20140701
 * [new tag]             sid-snapshot-20140801       -> sid-snapshot-20140801
 * [new tag]             sid-snapshot-20140901       -> sid-snapshot-20140901
 * [new tag]             sid-snapshot-20141001       -> sid-snapshot-20141001
 * [new tag]             sid-snapshot-20141101       -> sid-snapshot-20141101
 * [new tag]             sid-snapshot-20141201       -> sid-snapshot-20141201
 * [new tag]             sid-snapshot-20150101       -> sid-snapshot-20150101
 * [new tag]             sid-snapshot-20150201       -> sid-snapshot-20150201
 * [new tag]             sid-snapshot-20150301       -> sid-snapshot-20150301
 * [new tag]             tcltk840-20020924-branchpoint -> tcltk840-20020924-branchpoint
 * [new tag]             w32api-1_5                  -> w32api-1_5
 * [new tag]             w32api-2_2                  -> w32api-2_2
 * [new tag]             winsup-2000-02-17           -> winsup-2000-02-17
 * [new tag]             x86_64versiong3             -> x86_64versiong3
HEAD is now at 764ef4e40 Version 1.8.6
From https://github.com/zephyrproject-rtos/segger
 * [new branch]      master       -> refs/west/master
 * [new branch]      v1.14-branch -> refs/west/v1.14-branch
HEAD is now at b011c45 segger: config: Add CCM option for linker sections
From https://github.com/zephyrproject-rtos/tinycrypt
HEAD is now at 1012a3e Fix warnings reported by UBSAN
From https://github.com/zephyrproject-rtos/uoscore-uedhoc
 * [new branch]      zephyr     -> refs/west/zephyr
HEAD is now at 150f4eb [zephyr fromlist] Adapt to changes in name generation in zcbor 0.8.0
From https://github.com/zephyrproject-rtos/zcbor
 * [new branch]      main              -> refs/west/main
 * [new branch]      release/0.6.1     -> refs/west/release/0.6.1
 * [new branch]      release/0.8.2     -> refs/west/release/0.8.2
 * [new tag]         0.1.0             -> 0.1.0
 * [new tag]         0.2.0             -> 0.2.0
 * [new tag]         0.3.0             -> 0.3.0
 * [new tag]         0.3.1             -> 0.3.1
 * [new tag]         0.4.0             -> 0.4.0
 * [new tag]         0.5.0             -> 0.5.0
 * [new tag]         0.5.1             -> 0.5.1
 * [new tag]         0.6.0             -> 0.6.0
 * [new tag]         0.8.0             -> 0.8.0
 * [new tag]         0.8.1             -> 0.8.1
 * [new tag]         0.9.0             -> 0.9.0
 * [new tag]         deprecated-master -> deprecated-master
 * [new tag]         inital-pr         -> inital-pr
 * [new tag]         old-structure     -> old-structure
HEAD is now at 75d0880 tests: Update mps2 board name
ERROR: update failed for projects: matter, cmock
Error: Launched process exited with non-zero status: 1
2024-09-07T16:05:18.443Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T16:06:08.263Z INFO Successfully removed toolchain directory: C:\ncs\toolchains\ce3b5ff664
2024-09-07T16:10:55.609Z INFO Start to install toolchain v2.6.1
2024-09-07T16:10:55.663Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T16:20:01.944Z DEBUG Sending event "toolchain-manager: Install toolchain from nrfutil"
2024-09-07T16:20:01.946Z INFO Cloning nRF Connect SDK v2.6.1
2024-09-07T16:20:01.948Z DEBUG Sending event "toolchain-manager: Clone nRF Connect SDK"
2024-09-07T16:20:01.986Z INFO Initializing environment for v2.6.1
2024-09-07T16:20:02.003Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T16:20:04.774Z DEBUG === Initializing in C:\ncs\v2.6.1
2024-09-07T16:20:04.775Z DEBUG --- Cloning manifest repository from https://github.com/nrfconnect/sdk-nrf, rev. v2.6.1
2024-09-07T16:21:02.567Z DEBUG --- setting manifest.path to nrf
2024-09-07T16:21:02.605Z DEBUG === Initialized. Now run "west update" inside C:\ncs\v2.6.1.
2024-09-07T16:21:02.669Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T16:21:03.546Z DEBUG === updating zephyr (zephyr):
2024-09-07T16:21:03.548Z INFO Updating zephyr repository for v2.6.1
2024-09-07T16:21:03.576Z DEBUG --- zephyr: initializing
2024-09-07T16:21:04.007Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/zephyr/.git/
2024-09-07T16:21:04.116Z DEBUG --- zephyr: fetching, need revision v3.5.99-ncs1-1
2024-09-07T16:24:46.631Z DEBUG === updating bsim (tools/bsim):
2024-09-07T16:24:46.682Z INFO Updating bsim repository for v2.6.1
2024-09-07T16:24:46.711Z DEBUG --- bsim: initializing
2024-09-07T16:24:46.775Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/tools/bsim/.git/
2024-09-07T16:24:46.872Z DEBUG --- bsim: fetching, need revision 384a091445c57b44ac8cbd18ebd245b47c71db94
2024-09-07T16:24:52.950Z DEBUG === updating hostap (modules/lib/hostap):
2024-09-07T16:24:52.997Z INFO Updating hostap repository for v2.6.1
2024-09-07T16:24:53.034Z DEBUG --- hostap: initializing
2024-09-07T16:24:53.155Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/hostap/.git/
2024-09-07T16:24:53.171Z DEBUG --- hostap: fetching, need revision e080aa8d0c7706ec5ab74785b3c8accc4973cd86
2024-09-07T16:25:16.054Z DEBUG === updating wfa-qt-control-app (modules/lib/wfa-qt-control-app):
2024-09-07T16:25:16.100Z INFO Updating wfa-qt-control-app repository for v2.6.1
2024-09-07T16:25:16.137Z DEBUG --- wfa-qt-control-app: initializing
2024-09-07T16:25:16.148Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/wfa-qt-control-app/.git/
2024-09-07T16:25:16.333Z DEBUG --- wfa-qt-control-app: fetching, need revision d649bd1342215e089d4211757186705cda179013
2024-09-07T16:25:19.529Z DEBUG === updating mcuboot (bootloader/mcuboot):
2024-09-07T16:25:19.530Z INFO Updating mcuboot repository for v2.6.1
2024-09-07T16:25:19.555Z DEBUG --- mcuboot: initializing
2024-09-07T16:25:19.618Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/bootloader/mcuboot/.git/
2024-09-07T16:25:19.710Z DEBUG --- mcuboot: fetching, need revision v2.0.99-ncs1-1
2024-09-07T16:25:26.513Z DEBUG === updating qcbor (modules/tee/tf-m/qcbor):
2024-09-07T16:25:26.561Z INFO Updating qcbor repository for v2.6.1
2024-09-07T16:25:26.595Z DEBUG --- qcbor: initializing
2024-09-07T16:25:26.726Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/tee/tf-m/qcbor/.git/
2024-09-07T16:25:26.771Z DEBUG --- qcbor: fetching, need revision 751d36583a9ce1a640900c57e13c9b6b8f3a2ba2
2024-09-07T16:25:32.058Z DEBUG === updating mbedtls (modules/crypto/mbedtls):
2024-09-07T16:25:32.099Z INFO Updating mbedtls repository for v2.6.1
2024-09-07T16:25:32.126Z DEBUG --- mbedtls: initializing
2024-09-07T16:25:32.166Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/crypto/mbedtls/.git/
2024-09-07T16:25:32.331Z DEBUG --- mbedtls: fetching, need revision v3.5.2-ncs1-1
2024-09-07T16:26:11.414Z DEBUG === updating nrfxlib (nrfxlib):
2024-09-07T16:26:11.462Z INFO Updating nrfxlib repository for v2.6.1
2024-09-07T16:26:11.494Z DEBUG --- nrfxlib: initializing
2024-09-07T16:26:11.516Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/nrfxlib/.git/
2024-09-07T16:26:11.614Z DEBUG --- nrfxlib: fetching, need revision v2.6.1
2024-09-07T16:27:36.315Z DEBUG === updating trusted-firmware-m (modules/tee/tf-m/trusted-firmware-m):
2024-09-07T16:27:36.366Z INFO Updating trusted-firmware-m repository for v2.6.1
2024-09-07T16:27:36.401Z DEBUG --- trusted-firmware-m: initializing
2024-09-07T16:27:36.431Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m/.git/
2024-09-07T16:27:36.539Z DEBUG --- trusted-firmware-m: fetching, need revision v2.0.0-ncs1-1
2024-09-07T16:28:00.090Z DEBUG === updating psa-arch-tests (modules/tee/tf-m/psa-arch-tests):
2024-09-07T16:28:00.141Z INFO Updating psa-arch-tests repository for v2.6.1
2024-09-07T16:28:00.158Z DEBUG --- psa-arch-tests: initializing
2024-09-07T16:28:00.316Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/tee/tf-m/psa-arch-tests/.git/
2024-09-07T16:28:00.418Z DEBUG --- psa-arch-tests: fetching, need revision 94a349db22cd0e44136c281724ffc71b6e7391c3
2024-09-07T16:28:11.937Z DEBUG === updating matter (modules/lib/matter):
2024-09-07T16:28:11.984Z INFO Updating matter repository for v2.6.1
2024-09-07T16:28:12.018Z DEBUG --- matter: initializing
2024-09-07T16:28:12.054Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/matter/.git/
2024-09-07T16:28:12.149Z DEBUG --- matter: fetching, need revision v2.6.1
2024-09-07T16:30:56.172Z DEBUG nrf-802154: skipping inactive project
2024-09-07T16:30:56.222Z DEBUG dragoon: skipping inactive project
2024-09-07T16:30:56.223Z DEBUG === updating cjson (modules/lib/cjson):
2024-09-07T16:30:56.225Z INFO Updating cjson repository for v2.6.1
2024-09-07T16:30:56.225Z DEBUG --- cjson: initializing
2024-09-07T16:30:56.289Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/cjson/.git/
2024-09-07T16:30:56.391Z DEBUG --- cjson: fetching, need revision c6af068b7f05207b28d68880740e4b9ec1e4b50a
2024-09-07T16:31:01.461Z DEBUG sidewalk: skipping inactive project
2024-09-07T16:31:01.501Z DEBUG find-my: skipping inactive project
2024-09-07T16:31:01.502Z DEBUG === updating azure-sdk-for-c (modules/lib/azure-sdk-for-c):
2024-09-07T16:31:01.502Z INFO Updating azure-sdk-for-c repository for v2.6.1
2024-09-07T16:31:01.503Z DEBUG --- azure-sdk-for-c: initializing
2024-09-07T16:31:01.578Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/azure-sdk-for-c/.git/
2024-09-07T16:31:01.676Z DEBUG --- azure-sdk-for-c: fetching, need revision 308c171cb4b5eed266649012a68406487ec81fb2
2024-09-07T16:31:10.126Z DEBUG === updating cirrus (modules/hal/cirrus-logic):
2024-09-07T16:31:10.178Z INFO Updating cirrus repository for v2.6.1
2024-09-07T16:31:10.214Z DEBUG --- cirrus: initializing
2024-09-07T16:31:10.349Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/hal/cirrus-logic/.git/
2024-09-07T16:31:10.362Z DEBUG --- cirrus: fetching, need revision 3873a08377d93a479105a75ac390d3bbcd31d690
2024-09-07T16:31:22.266Z DEBUG === updating openthread (modules/lib/openthread):
2024-09-07T16:31:22.313Z INFO Updating openthread repository for v2.6.1
2024-09-07T16:31:22.345Z DEBUG --- openthread: initializing
2024-09-07T16:31:22.365Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/openthread/.git/
2024-09-07T16:31:22.475Z DEBUG --- openthread: fetching, need revision b9dcdbca4edd348e924d7579a2bada48bf085645
2024-09-07T16:31:51.262Z DEBUG === updating cmock (test/cmock):
2024-09-07T16:31:51.315Z INFO Updating cmock repository for v2.6.1
2024-09-07T16:31:51.348Z DEBUG --- cmock: initializing
2024-09-07T16:31:51.363Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/test/cmock/.git/
2024-09-07T16:31:51.547Z DEBUG --- cmock: fetching, need revision f65066f15d8248e6dcb778efb8739904a4512087
2024-09-07T16:32:20.310Z DEBUG === updating memfault-firmware-sdk (modules/lib/memfault-firmware-sdk):
2024-09-07T16:32:20.359Z INFO Updating memfault-firmware-sdk repository for v2.6.1
2024-09-07T16:32:20.384Z DEBUG --- memfault-firmware-sdk: initializing
2024-09-07T16:32:20.422Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/memfault-firmware-sdk/.git/
2024-09-07T16:32:20.528Z DEBUG --- memfault-firmware-sdk: fetching, need revision 1.6.0
2024-09-07T16:32:31.530Z DEBUG ant: skipping inactive project
2024-09-07T16:32:31.575Z DEBUG bme68x: skipping inactive project
2024-09-07T16:32:31.577Z DEBUG bsec: skipping inactive project
2024-09-07T16:32:31.578Z DEBUG === updating canopennode (modules/lib/canopennode):
2024-09-07T16:32:31.579Z INFO Updating canopennode repository for v2.6.1
2024-09-07T16:32:31.579Z DEBUG --- canopennode: initializing
2024-09-07T16:32:31.700Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/canopennode/.git/
2024-09-07T16:32:31.806Z DEBUG --- canopennode: fetching, need revision dec12fa3f0d790cafa8414a4c2930ea71ab72ffd
2024-09-07T16:32:35.466Z DEBUG === updating chre (modules/lib/chre):
2024-09-07T16:32:35.467Z INFO Updating chre repository for v2.6.1
2024-09-07T16:32:35.495Z DEBUG --- chre: initializing
2024-09-07T16:32:35.564Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/chre/.git/
2024-09-07T16:32:35.663Z DEBUG --- chre: fetching, need revision 3b32c76efee705af146124fb4190f71be5a4e36e
2024-09-07T16:32:46.402Z DEBUG === updating lz4 (modules/lib/lz4):
2024-09-07T16:32:46.454Z INFO Updating lz4 repository for v2.6.1
2024-09-07T16:32:46.487Z DEBUG --- lz4: initializing
2024-09-07T16:32:46.509Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/lz4/.git/
2024-09-07T16:32:46.736Z DEBUG --- lz4: fetching, need revision 8e303c264fc21c2116dc612658003a22e933124d
2024-09-07T16:32:54.089Z DEBUG === updating nanopb (modules/lib/nanopb):
2024-09-07T16:32:54.140Z INFO Updating nanopb repository for v2.6.1
2024-09-07T16:32:54.172Z DEBUG --- nanopb: initializing
2024-09-07T16:32:54.191Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/nanopb/.git/
2024-09-07T16:32:54.340Z DEBUG --- nanopb: fetching, need revision 42fa8b211e946b90b9d968523fce7b1cfe27617e
2024-09-07T16:33:02.969Z DEBUG === updating tf-m-tests (modules/tee/tf-m/tf-m-tests):
2024-09-07T16:33:03.021Z INFO Updating tf-m-tests repository for v2.6.1
2024-09-07T16:33:03.056Z DEBUG --- tf-m-tests: initializing
2024-09-07T16:33:03.201Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/tee/tf-m/tf-m-tests/.git/
2024-09-07T16:33:03.251Z DEBUG --- tf-m-tests: fetching, need revision 08a3158f0623a4205608a52d880b17ae394e31d2
2024-09-07T16:33:09.681Z DEBUG === updating zscilib (modules/lib/zscilib):
2024-09-07T16:33:09.731Z INFO Updating zscilib repository for v2.6.1
2024-09-07T16:33:09.767Z DEBUG --- zscilib: initializing
2024-09-07T16:33:09.779Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/zscilib/.git/
2024-09-07T16:33:09.939Z DEBUG --- zscilib: fetching, need revision 34a94b0995683822fa3626dcd5d838301c94c350
2024-09-07T16:33:15.554Z DEBUG === updating cmsis (modules/hal/cmsis):
2024-09-07T16:33:15.598Z INFO Updating cmsis repository for v2.6.1
2024-09-07T16:33:15.633Z DEBUG --- cmsis: initializing
2024-09-07T16:33:15.658Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/hal/cmsis/.git/
2024-09-07T16:33:15.756Z DEBUG --- cmsis: fetching, need revision 4b96cbb174678dcd3ca86e11e1f24bc5f8726da0
2024-09-07T16:33:21.222Z DEBUG === updating cmsis-dsp (modules/lib/cmsis-dsp):
2024-09-07T16:33:21.266Z INFO Updating cmsis-dsp repository for v2.6.1
2024-09-07T16:33:21.303Z DEBUG --- cmsis-dsp: initializing
2024-09-07T16:33:21.326Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/cmsis-dsp/.git/
2024-09-07T16:33:21.520Z DEBUG --- cmsis-dsp: fetching, need revision ff7b5fd1ea5f094665c090c343ec44e74dc0b193
2024-09-07T16:33:48.482Z DEBUG === updating cmsis-nn (modules/lib/cmsis-nn):
2024-09-07T16:33:48.537Z INFO Updating cmsis-nn repository for v2.6.1
2024-09-07T16:33:48.575Z DEBUG --- cmsis-nn: initializing
2024-09-07T16:33:48.597Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/cmsis-nn/.git/
2024-09-07T16:33:48.758Z DEBUG --- cmsis-nn: fetching, need revision 0c8669d81381ccf3b1a01d699f3b68b50134a99f
2024-09-07T16:33:58.543Z DEBUG === updating edtt (tools/edtt):
2024-09-07T16:33:58.593Z INFO Updating edtt repository for v2.6.1
2024-09-07T16:33:58.621Z DEBUG --- edtt: initializing
2024-09-07T16:33:58.763Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/tools/edtt/.git/
2024-09-07T16:33:58.809Z DEBUG --- edtt: fetching, need revision 64e5105ad82390164fb73fc654be3f73a608209a
2024-09-07T16:34:01.884Z DEBUG === updating fatfs (modules/fs/fatfs):
2024-09-07T16:34:01.886Z INFO Updating fatfs repository for v2.6.1
2024-09-07T16:34:01.911Z DEBUG --- fatfs: initializing
2024-09-07T16:34:01.980Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/fs/fatfs/.git/
2024-09-07T16:34:02.079Z DEBUG --- fatfs: fetching, need revision 427159bf95ea49b7680facffaa29ad506b42709b
2024-09-07T16:34:04.590Z DEBUG === updating hal_nordic (modules/hal/nordic):
2024-09-07T16:34:04.591Z INFO Updating hal_nordic repository for v2.6.1
2024-09-07T16:34:04.625Z DEBUG --- hal_nordic: initializing
2024-09-07T16:34:04.766Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/hal/nordic/.git/
2024-09-07T16:34:04.810Z DEBUG --- hal_nordic: fetching, need revision 5470822384781624efb2fda28cbc6a895a227677
2024-09-07T16:34:19.621Z DEBUG === updating hal_st (modules/hal/st):
2024-09-07T16:34:19.669Z INFO Updating hal_st repository for v2.6.1
2024-09-07T16:34:19.693Z DEBUG --- hal_st: initializing
2024-09-07T16:34:19.774Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/hal/st/.git/
2024-09-07T16:34:19.935Z DEBUG --- hal_st: fetching, need revision fb8e79d1a261fd02aadff7c142729f1954163cf3
2024-09-07T16:34:32.211Z DEBUG === updating hal_wurthelektronik (modules/hal/wurthelektronik):
2024-09-07T16:34:32.261Z INFO Updating hal_wurthelektronik repository for v2.6.1
2024-09-07T16:34:32.297Z DEBUG --- hal_wurthelektronik: initializing
2024-09-07T16:34:32.307Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/hal/wurthelektronik/.git/
2024-09-07T16:34:32.414Z DEBUG --- hal_wurthelektronik: fetching, need revision 24ca9873c3d608fad1fea0431836bc8f144c132e
2024-09-07T16:34:34.873Z DEBUG === updating libmetal (modules/hal/libmetal):
2024-09-07T16:34:34.874Z INFO Updating libmetal repository for v2.6.1
2024-09-07T16:34:34.901Z DEBUG --- libmetal: initializing
2024-09-07T16:34:34.973Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/hal/libmetal/.git/
2024-09-07T16:34:35.105Z DEBUG --- libmetal: fetching, need revision 03140d7f4bd9ba474ebfbb6256e84a9089248e67
2024-09-07T16:34:38.918Z DEBUG === updating liblc3 (modules/lib/liblc3):
2024-09-07T16:34:38.963Z INFO Updating liblc3 repository for v2.6.1
2024-09-07T16:34:39.007Z DEBUG --- liblc3: initializing
2024-09-07T16:34:39.150Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/liblc3/.git/
2024-09-07T16:34:39.162Z DEBUG --- liblc3: fetching, need revision 448f3de31f49a838988a162ef1e23a89ddf2d2ed
2024-09-07T16:34:42.339Z DEBUG === updating littlefs (modules/fs/littlefs):
2024-09-07T16:34:42.382Z INFO Updating littlefs repository for v2.6.1
2024-09-07T16:34:42.417Z DEBUG --- littlefs: initializing
2024-09-07T16:34:42.435Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/fs/littlefs/.git/
2024-09-07T16:34:42.545Z DEBUG --- littlefs: fetching, need revision ca583fd297ceb48bced3c2548600dc615d67af24
2024-09-07T16:34:45.892Z DEBUG === updating loramac-node (modules/lib/loramac-node):
2024-09-07T16:34:45.893Z INFO Updating loramac-node repository for v2.6.1
2024-09-07T16:34:45.918Z DEBUG --- loramac-node: initializing
2024-09-07T16:34:45.991Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/loramac-node/.git/
2024-09-07T16:34:46.087Z DEBUG --- loramac-node: fetching, need revision 842413c5fb98707eb5f26e619e8e792453877897
2024-09-07T16:35:07.131Z DEBUG === updating lvgl (modules/lib/gui/lvgl):
2024-09-07T16:35:07.179Z INFO Updating lvgl repository for v2.6.1
2024-09-07T16:35:07.213Z DEBUG --- lvgl: initializing
2024-09-07T16:35:07.230Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/gui/lvgl/.git/
2024-09-07T16:35:07.338Z DEBUG --- lvgl: fetching, need revision 7c61a4cec26402d20c845c95dcad0e39dcd319f8
2024-09-07T16:35:29.210Z DEBUG === updating mipi-sys-t (modules/debug/mipi-sys-t):
2024-09-07T16:35:29.259Z INFO Updating mipi-sys-t repository for v2.6.1
2024-09-07T16:35:29.297Z DEBUG --- mipi-sys-t: initializing
2024-09-07T16:35:29.315Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/debug/mipi-sys-t/.git/
2024-09-07T16:35:29.520Z DEBUG --- mipi-sys-t: fetching, need revision a819419603a2dfcb47f7f39092e1bc112e45d1ef
2024-09-07T16:35:32.576Z DEBUG === updating net-tools (tools/net-tools):
2024-09-07T16:35:32.577Z INFO Updating net-tools repository for v2.6.1
2024-09-07T16:35:32.601Z DEBUG --- net-tools: initializing
2024-09-07T16:35:32.737Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/tools/net-tools/.git/
2024-09-07T16:35:32.788Z DEBUG --- net-tools: fetching, need revision d68ee9d17648a1bb3729c2023abfcb735dfe92fa
2024-09-07T16:35:40.773Z DEBUG === updating nrf_hw_models (modules/bsim_hw_models/nrf_hw_models):
2024-09-07T16:35:40.822Z INFO Updating nrf_hw_models repository for v2.6.1
2024-09-07T16:35:40.858Z DEBUG --- nrf_hw_models: initializing
2024-09-07T16:35:40.876Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/bsim_hw_models/nrf_hw_models/.git/
2024-09-07T16:35:40.977Z DEBUG --- nrf_hw_models: fetching, need revision 52d0b4b7b7431d8da6222cc3b17a8afdcb099baf
2024-09-07T16:35:45.211Z DEBUG === updating open-amp (modules/lib/open-amp):
2024-09-07T16:35:45.261Z INFO Updating open-amp repository for v2.6.1
2024-09-07T16:35:45.292Z DEBUG --- open-amp: initializing
2024-09-07T16:35:45.313Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/open-amp/.git/
2024-09-07T16:35:45.408Z DEBUG --- open-amp: fetching, need revision 214f9fc1539f8e5937c0474cb6ee29b6dcb2d4b8
2024-09-07T16:35:48.683Z DEBUG === updating picolibc (modules/lib/picolibc):
2024-09-07T16:35:48.684Z INFO Updating picolibc repository for v2.6.1
2024-09-07T16:35:48.720Z DEBUG --- picolibc: initializing
2024-09-07T16:35:48.799Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/picolibc/.git/
2024-09-07T16:35:48.905Z DEBUG --- picolibc: fetching, need revision 1a5c603b9f8e228f9459bdafedad15ea28efc700
2024-09-07T16:37:16.324Z DEBUG === updating segger (modules/debug/segger):
2024-09-07T16:37:16.375Z INFO Updating segger repository for v2.6.1
2024-09-07T16:37:16.407Z DEBUG --- segger: initializing
2024-09-07T16:37:16.439Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/debug/segger/.git/
2024-09-07T16:37:16.542Z DEBUG --- segger: fetching, need revision 9d0191285956cef43daf411edc2f1a7788346def
2024-09-07T16:37:18.771Z DEBUG === updating tinycrypt (modules/crypto/tinycrypt):
2024-09-07T16:37:18.773Z INFO Updating tinycrypt repository for v2.6.1
2024-09-07T16:37:18.799Z DEBUG --- tinycrypt: initializing
2024-09-07T16:37:18.861Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/crypto/tinycrypt/.git/
2024-09-07T16:37:18.958Z DEBUG --- tinycrypt: fetching, need revision 3e9a49d2672ec01435ffbf0d788db6d95ef28de0
2024-09-07T16:37:23.215Z DEBUG === updating uoscore-uedhoc (modules/lib/uoscore-uedhoc):
2024-09-07T16:37:23.259Z INFO Updating uoscore-uedhoc repository for v2.6.1
2024-09-07T16:37:23.299Z DEBUG --- uoscore-uedhoc: initializing
2024-09-07T16:37:23.323Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/uoscore-uedhoc/.git/
2024-09-07T16:37:23.525Z DEBUG --- uoscore-uedhoc: fetching, need revision 150f4eb2955eaf36ac0f9519d4f4f58d5ade5740
2024-09-07T16:37:28.473Z DEBUG === updating zcbor (modules/lib/zcbor):
2024-09-07T16:37:28.518Z INFO Updating zcbor repository for v2.6.1
2024-09-07T16:37:28.549Z DEBUG --- zcbor: initializing
2024-09-07T16:37:28.581Z DEBUG Initialized empty Git repository in C:/ncs/v2.6.1/modules/lib/zcbor/.git/
2024-09-07T16:37:28.723Z DEBUG --- zcbor: fetching, need revision d3093b5684f62268c7f27f8a5079f166772619de
2024-09-07T16:37:33.509Z DEBUG babblesim_base: skipping inactive project
2024-09-07T16:37:33.545Z DEBUG babblesim_ext_2G4_libPhyComv1: skipping inactive project
2024-09-07T16:37:33.546Z DEBUG babblesim_ext_2G4_phy_v1: skipping inactive project
2024-09-07T16:37:33.547Z DEBUG babblesim_ext_2G4_channel_NtNcable: skipping inactive project
2024-09-07T16:37:33.547Z DEBUG babblesim_ext_2G4_channel_multiatt: skipping inactive project
2024-09-07T16:37:33.548Z DEBUG babblesim_ext_2G4_modem_magic: skipping inactive project
2024-09-07T16:37:33.548Z DEBUG babblesim_ext_2G4_modem_BLE_simple: skipping inactive project
2024-09-07T16:37:33.549Z DEBUG babblesim_ext_2G4_device_burst_interferer: skipping inactive project
2024-09-07T16:37:33.549Z DEBUG babblesim_ext_2G4_device_WLAN_actmod: skipping inactive project
2024-09-07T16:37:33.550Z DEBUG babblesim_ext_2G4_device_playback: skipping inactive project
2024-09-07T16:37:33.550Z DEBUG babblesim_ext_libCryptov1: skipping inactive project
2024-09-07T16:37:33.614Z ERROR Failed to clone the repositories: Error: From https://github.com/nrfconnect/sdk-zephyr
 * tag                       v3.5.99-ncs1-1            -> FETCH_HEAD
 * [new tag]                 v1.13.99-ncs1             -> v1.13.99-ncs1
 * [new tag]                 v1.13.99-ncs1-rc1         -> v1.13.99-ncs1-rc1
 * [new tag]                 v1.13.99-ncs2             -> v1.13.99-ncs2
 * [new tag]                 v1.13.99-ncs2-rc1         -> v1.13.99-ncs2-rc1
 * [new tag]                 v1.13.99-ncs2-rc2         -> v1.13.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs1             -> v1.14.99-ncs1
 * [new tag]                 v1.14.99-ncs1-rc1         -> v1.14.99-ncs1-rc1
 * [new tag]                 v1.14.99-ncs1-rc2         -> v1.14.99-ncs1-rc2
 * [new tag]                 v1.14.99-ncs2             -> v1.14.99-ncs2
 * [new tag]                 v1.14.99-ncs2-rc1         -> v1.14.99-ncs2-rc1
 * [new tag]                 v1.14.99-ncs2-rc2         -> v1.14.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs2-rc3         -> v1.14.99-ncs2-rc3
 * [new tag]                 v1.14.99-ncs2-rc4         -> v1.14.99-ncs2-rc4
 * [new tag]                 v1.14.99-ncs3-snapshot1   -> v1.14.99-ncs3-snapshot1
 * [new tag]                 v1.14.99-ncs3-snapshot2   -> v1.14.99-ncs3-snapshot2
 * [new tag]                 v2.0.99-ncs1              -> v2.0.99-ncs1
 * [new tag]                 v2.0.99-ncs1-rc1          -> v2.0.99-ncs1-rc1
 * [new tag]                 v2.0.99-ncs1-rc2          -> v2.0.99-ncs1-rc2
 * [new tag]                 v2.0.99-ncs1-rc3          -> v2.0.99-ncs1-rc3
 * [new tag]                 v2.0.99-ncs1-snapshot1    -> v2.0.99-ncs1-snapshot1
 * [new tag]                 v2.1.0-ncs1-snapshot1     -> v2.1.0-ncs1-snapshot1
 * [new tag]                 v2.1.99-ncs1              -> v2.1.99-ncs1
 * [new tag]                 v2.1.99-ncs1-rc1          -> v2.1.99-ncs1-rc1
 * [new tag]                 v2.1.99-ncs1-rc2          -> v2.1.99-ncs1-rc2
 * [new tag]                 v2.1.99-ncs1-snapshot1    -> v2.1.99-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs1           -> v2.3.0-rc1-ncs1
 * [new tag]                 v2.3.0-rc1-ncs1-rc1       -> v2.3.0-rc1-ncs1-rc1
 * [new tag]                 v2.3.0-rc1-ncs1-rc2       -> v2.3.0-rc1-ncs1-rc2
 * [new tag]                 v2.3.0-rc1-ncs1-rc3       -> v2.3.0-rc1-ncs1-rc3
 * [new tag]                 v2.3.0-rc1-ncs1-snapshot1 -> v2.3.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs2           -> v2.3.0-rc1-ncs2
 * [new tag]                 v2.3.0-rc1-ncs3           -> v2.3.0-rc1-ncs3
 * [new tag]                 v2.4.0-ncs1               -> v2.4.0-ncs1
 * [new tag]                 v2.4.0-ncs1-rc1           -> v2.4.0-ncs1-rc1
 * [new tag]                 v2.4.0-ncs1-rc2           -> v2.4.0-ncs1-rc2
 * [new tag]                 v2.4.0-ncs1-snapshot1     -> v2.4.0-ncs1-snapshot1
 * [new tag]                 v2.4.0-ncs2               -> v2.4.0-ncs2
 * [new tag]                 v2.4.0-ncs2-rc1           -> v2.4.0-ncs2-rc1
 * [new tag]                 v2.4.99-ncs1              -> v2.4.99-ncs1
 * [new tag]                 v2.4.99-ncs1-rc1          -> v2.4.99-ncs1-rc1
 * [new tag]                 v2.4.99-ncs1-snapshot1    -> v2.4.99-ncs1-snapshot1
 * [new tag]                 v2.4.99-ncs2              -> v2.4.99-ncs2
 * [new tag]                 v2.4.99-ncs2-1            -> v2.4.99-ncs2-1
 * [new tag]                 v2.4.99-ncs2-rc1          -> v2.4.99-ncs2-rc1
 * [new tag]                 v2.6.0-ncs1-rc3           -> v2.6.0-ncs1-rc3
 * [new tag]                 v2.6.0-rc1-ncs1           -> v2.6.0-rc1-ncs1
 * [new tag]                 v2.6.0-rc1-ncs1-rc1       -> v2.6.0-rc1-ncs1-rc1
 * [new tag]                 v2.6.0-rc1-ncs1-snapshot1 -> v2.6.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.6.99-ncs1              -> v2.6.99-ncs1
 * [new tag]                 v2.6.99-ncs1-1            -> v2.6.99-ncs1-1
 * [new tag]                 v2.6.99-ncs1-rc1          -> v2.6.99-ncs1-rc1
 * [new tag]                 v2.6.99-ncs1-rc2          -> v2.6.99-ncs1-rc2
 * [new tag]                 v2.6.99-ncs1-snapshot1    -> v2.6.99-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1               -> v2.7.0-ncs1
 * [new tag]                 v2.7.0-ncs1-rc1           -> v2.7.0-ncs1-rc1
 * [new tag]                 v2.7.0-ncs1-rc2           -> v2.7.0-ncs1-rc2
 * [new tag]                 v2.7.0-ncs1-snapshot1     -> v2.7.0-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1-snapshot2     -> v2.7.0-ncs1-snapshot2
 * [new tag]                 v2.7.99-ncs1              -> v2.7.99-ncs1
 * [new tag]                 v2.7.99-ncs1-1            -> v2.7.99-ncs1-1
 * [new tag]                 v2.7.99-ncs1-rc1          -> v2.7.99-ncs1-rc1
 * [new tag]                 v2.7.99-ncs1-rc2          -> v2.7.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1              -> v3.0.99-ncs1
 * [new tag]                 v3.0.99-ncs1-1            -> v3.0.99-ncs1-1
 * [new tag]                 v3.0.99-ncs1-rc1          -> v3.0.99-ncs1-rc1
 * [new tag]                 v3.0.99-ncs1-rc2          -> v3.0.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1-snapshot1    -> v3.0.99-ncs1-snapshot1
 * [new tag]                 v3.1.99-ncs1              -> v3.1.99-ncs1
 * [new tag]                 v3.1.99-ncs1-1            -> v3.1.99-ncs1-1
 * [new tag]                 v3.1.99-ncs1-2            -> v3.1.99-ncs1-2
 * [new tag]                 v3.1.99-ncs1-3            -> v3.1.99-ncs1-3
 * [new tag]                 v3.1.99-ncs1-rc1          -> v3.1.99-ncs1-rc1
 * [new tag]                 v3.1.99-ncs1-rc2          -> v3.1.99-ncs1-rc2
 * [new tag]                 v3.1.99-ncs1-snapshot1    -> v3.1.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs1              -> v3.2.99-ncs1
 * [new tag]                 v3.2.99-ncs1-rc1          -> v3.2.99-ncs1-rc1
 * [new tag]                 v3.2.99-ncs1-rc2          -> v3.2.99-ncs1-rc2
 * [new tag]                 v3.2.99-ncs1-snapshot1    -> v3.2.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs2              -> v3.2.99-ncs2
 * [new tag]                 v3.2.99-ncs2-rc1          -> v3.2.99-ncs2-rc1
 * [new tag]                 v3.2.99-ncs2-rc2          -> v3.2.99-ncs2-rc2
 * [new tag]                 v3.2.99-ncs2-snapshot1    -> v3.2.99-ncs2-snapshot1
 * [new tag]                 v3.3.99-ncs1              -> v3.3.99-ncs1
 * [new tag]                 v3.3.99-ncs1-1            -> v3.3.99-ncs1-1
 * [new tag]                 v3.3.99-ncs1-2            -> v3.3.99-ncs1-2
 * [new tag]                 v3.3.99-ncs1-3            -> v3.3.99-ncs1-3
 * [new tag]                 v3.3.99-ncs1-rc1          -> v3.3.99-ncs1-rc1
 * [new tag]                 v3.3.99-ncs1-rc2          -> v3.3.99-ncs1-rc2
 * [new tag]                 v3.3.99-ncs1-snapshot1    -> v3.3.99-ncs1-snapshot1
 * [new tag]                 v3.4.99-ncs1              -> v3.4.99-ncs1
 * [new tag]                 v3.4.99-ncs1-1            -> v3.4.99-ncs1-1
 * [new tag]                 v3.4.99-ncs1-1-rc1        -> v3.4.99-ncs1-1-rc1
 * [new tag]                 v3.4.99-ncs1-2            -> v3.4.99-ncs1-2
 * [new tag]                 v3.4.99-ncs1-3            -> v3.4.99-ncs1-3
 * [new tag]                 v3.4.99-ncs1-rc1          -> v3.4.99-ncs1-rc1
 * [new tag]                 v3.4.99-ncs1-rc2          -> v3.4.99-ncs1-rc2
 * [new tag]                 v3.4.99-ncs1-snapshot1    -> v3.4.99-ncs1-snapshot1
 * [new tag]                 v3.5.99-ncs1              -> v3.5.99-ncs1
 * [new tag]                 v3.5.99-ncs1-1            -> v3.5.99-ncs1-1
 * [new tag]                 v3.5.99-ncs1-rc1          -> v3.5.99-ncs1-rc1
 * [new tag]                 v3.5.99-ncs1-rc2          -> v3.5.99-ncs1-rc2
 * [new tag]                 v3.5.99-ncs1-snapshot1    -> v3.5.99-ncs1-snapshot1
 * [new tag]                 v3.6.99-ncs2              -> v3.6.99-ncs2
 * [new tag]                 v3.6.99-ncs2-rc1          -> v3.6.99-ncs2-rc1
 * [new tag]                 v3.6.99-ncs2-rc2          -> v3.6.99-ncs2-rc2
 * [new tag]                 v3.6.99-ncs2-rc3          -> v3.6.99-ncs2-rc3
 * [new tag]                 v3.6.99-ncs2-snapshot1    -> v3.6.99-ncs2-snapshot1
HEAD is now at 3758bcbfa5c [nrf fromtree] drivers: pinctrl_nrf: Configure QSPI IO3 pin as output set high
From https://github.com/BabbleSim/bsim_west
 * [new branch]      v2.1       -> refs/west/v2.1
 * [new branch]      v2.1.1     -> refs/west/v2.1.1
 * [new branch]      v2.2       -> refs/west/v2.2
 * [new branch]      v2.2.1     -> refs/west/v2.2.1
 * [new branch]      v2.3       -> refs/west/v2.3
HEAD is now at 384a091 west.yaml Update to 2.1.1
From https://github.com/nrfconnect/sdk-hostap
 * [new branch]          hcs                      -> refs/west/hcs
 * [new branch]          hostap_2_11_devel-ncs1-branch -> refs/west/hostap_2_11_devel-ncs1-branch
 * [new branch]          nrf700x-dev              -> refs/west/nrf700x-dev
 * [new branch]          nrf700x-test             -> refs/west/nrf700x-test
 * [new branch]          v2.5-branch              -> refs/west/v2.5-branch
 * [new branch]          v2.6-branch              -> refs/west/v2.6-branch
 * [new tag]             fix_sauce_tag_snapshot   -> fix_sauce_tag_snapshot
 * [new tag]             hostap_2_11_devel-ncs1   -> hostap_2_11_devel-ncs1
 * [new tag]             prepare_upmerge_snapshot -> prepare_upmerge_snapshot
HEAD is now at e080aa8d0 [nrf fromlist] wpa_supplicant: Add an option to disable SNR capping
From https://github.com/nrfconnect/sdk-wi-fiquicktrack-controlappc
 * [new branch]      qt_v2.5.1      -> refs/west/qt_v2.5.1
 * [new tag]         R2.1-snapshot1 -> R2.1-snapshot1
 * [new tag]         pre_zephyr_separation_snapshot -> pre_zephyr_separation_snapshot
HEAD is now at d649bd1 [nrf noup]: qt: Fix config name
From https://github.com/nrfconnect/sdk-mcuboot
 * tag                 v2.0.99-ncs1-1          -> FETCH_HEAD
 * [new tag]           v1.10.0-ncs1            -> v1.10.0-ncs1
 * [new tag]           v1.10.0-ncs1-1          -> v1.10.0-ncs1-1
 * [new tag]           v1.10.0-ncs1-rc1        -> v1.10.0-ncs1-rc1
 * [new tag]           v1.10.0-ncs1-rc2        -> v1.10.0-ncs1-rc2
 * [new tag]           v1.10.0-ncs1-snapshot1  -> v1.10.0-ncs1-snapshot1
 * [new tag]           v1.10.99-ncs1           -> v1.10.99-ncs1
 * [new tag]           v1.10.99-ncs1-1         -> v1.10.99-ncs1-1
 * [new tag]           v1.10.99-ncs1-1-rc1     -> v1.10.99-ncs1-1-rc1
 * [new tag]           v1.10.99-ncs1-2         -> v1.10.99-ncs1-2
 * [new tag]           v1.10.99-ncs1-3         -> v1.10.99-ncs1-3
 * [new tag]           v1.10.99-ncs1-rc1       -> v1.10.99-ncs1-rc1
 * [new tag]           v1.10.99-ncs1-rc2       -> v1.10.99-ncs1-rc2
 * [new tag]           v1.10.99-ncs1-snapshot1 -> v1.10.99-ncs1-snapshot1
 * [new tag]           v1.2.99-ncs1            -> v1.2.99-ncs1
 * [new tag]           v1.2.99-ncs1-rc1        -> v1.2.99-ncs1-rc1
 * [new tag]           v1.2.99-ncs2            -> v1.2.99-ncs2
 * [new tag]           v1.2.99-ncs2-rc1        -> v1.2.99-ncs2-rc1
 * [new tag]           v1.2.99-ncs2-rc2        -> v1.2.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs1            -> v1.3.99-ncs1
 * [new tag]           v1.3.99-ncs1-rc1        -> v1.3.99-ncs1-rc1
 * [new tag]           v1.3.99-ncs1-rc2        -> v1.3.99-ncs1-rc2
 * [new tag]           v1.3.99-ncs2            -> v1.3.99-ncs2
 * [new tag]           v1.3.99-ncs2-rc1        -> v1.3.99-ncs2-rc1
 * [new tag]           v1.3.99-ncs2-rc2        -> v1.3.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs2-rc3        -> v1.3.99-ncs2-rc3
 * [new tag]           v1.3.99-ncs2-rc4        -> v1.3.99-ncs2-rc4
 * [new tag]           v1.3.99-ncs3-snapshot1  -> v1.3.99-ncs3-snapshot1
 * [new tag]           v1.3.99-ncs3-snapshot2  -> v1.3.99-ncs3-snapshot2
 * [new tag]           v1.4.99-ncs1            -> v1.4.99-ncs1
 * [new tag]           v1.4.99-ncs1-rc1        -> v1.4.99-ncs1-rc1
 * [new tag]           v1.4.99-ncs1-rc2        -> v1.4.99-ncs1-rc2
 * [new tag]           v1.4.99-ncs1-rc3        -> v1.4.99-ncs1-rc3
 * [new tag]           v1.4.99-ncs1-snapshot1  -> v1.4.99-ncs1-snapshot1
 * [new tag]           v1.4.99-ncs2            -> v1.4.99-ncs2
 * [new tag]           v1.4.99-ncs2-rc1        -> v1.4.99-ncs2-rc1
 * [new tag]           v1.4.99-ncs2-rc2        -> v1.4.99-ncs2-rc2
 * [new tag]           v1.4.99-ncs2-snapshot1  -> v1.4.99-ncs2-snapshot1
 * [new tag]           v1.5.99-ncs1-rc1        -> v1.5.99-ncs1-rc1
 * [new tag]           v1.5.99-ncs1-rc2        -> v1.5.99-ncs1-rc2
 * [new tag]           v1.5.99-ncs1-rc3        -> v1.5.99-ncs1-rc3
 * [new tag]           v1.5.99-ncs1-snapshot1  -> v1.5.99-ncs1-snapshot1
 * [new tag]           v1.6.0-rc2-ncs1         -> v1.6.0-rc2-ncs1
 * [new tag]           v1.6.99-ncs1            -> v1.6.99-ncs1
 * [new tag]           v1.6.99-ncs1-rc1        -> v1.6.99-ncs1-rc1
 * [new tag]           v1.6.99-ncs1-rc2        -> v1.6.99-ncs1-rc2
 * [new tag]           v1.6.99-ncs1-snapshot1  -> v1.6.99-ncs1-snapshot1
 * [new tag]           v1.7.0-ncs1-rc1         -> v1.7.0-ncs1-rc1
 * [new tag]           v1.7.0-ncs1-rc3         -> v1.7.0-ncs1-rc3
 * [new tag]           v1.7.0-ncs1-snapshot1   -> v1.7.0-ncs1-snapshot1
 * [new tag]           v1.7.2                  -> v1.7.2
 * [new tag]           v1.7.2-ncs1             -> v1.7.2-ncs1
 * [new tag]           v1.7.2-ncs1-rc2         -> v1.7.2-ncs1-rc2
 * [new tag]           v1.7.2-ncs2             -> v1.7.2-ncs2
 * [new tag]           v1.7.2-ncs2-rc1         -> v1.7.2-ncs2-rc1
 * [new tag]           v1.7.2-ncs2-rc2         -> v1.7.2-ncs2-rc2
 * [new tag]           v1.7.2-ncs3             -> v1.7.2-ncs3
 * [new tag]           v1.7.2-ncs3-rc1         -> v1.7.2-ncs3-rc1
 * [new tag]           v1.7.2-ncs3-rc2         -> v1.7.2-ncs3-rc2
 * [new tag]           v1.7.99-ncs1            -> v1.7.99-ncs1
 * [new tag]           v1.7.99-ncs1-1          -> v1.7.99-ncs1-1
 * [new tag]           v1.7.99-ncs1-rc1        -> v1.7.99-ncs1-rc1
 * [new tag]           v1.7.99-ncs2            -> v1.7.99-ncs2
 * [new tag]           v1.7.99-ncs2-snapshot1  -> v1.7.99-ncs2-snapshot1
 * [new tag]           v1.7.99-ncs3            -> v1.7.99-ncs3
 * [new tag]           v1.7.99-ncs3-1          -> v1.7.99-ncs3-1
 * [new tag]           v1.7.99-ncs3-rc1        -> v1.7.99-ncs3-rc1
 * [new tag]           v1.7.99-ncs3-rc2        -> v1.7.99-ncs3-rc2
 * [new tag]           v1.7.99-ncs4            -> v1.7.99-ncs4
 * [new tag]           v1.7.99-ncs4-rc1        -> v1.7.99-ncs4-rc1
 * [new tag]           v1.7.99-ncs4-rc2        -> v1.7.99-ncs4-rc2
 * [new tag]           v1.8.99-ncs1            -> v1.8.99-ncs1
 * [new tag]           v1.8.99-ncs1-rc1        -> v1.8.99-ncs1-rc1
 * [new tag]           v1.8.99-ncs1-rc2        -> v1.8.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1            -> v1.9.99-ncs1
 * [new tag]           v1.9.99-ncs1-rc1        -> v1.9.99-ncs1-rc1
 * [new tag]           v1.9.99-ncs1-rc2        -> v1.9.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1-snapshot1  -> v1.9.99-ncs1-snapshot1
 * [new tag]           v1.9.99-ncs2            -> v1.9.99-ncs2
 * [new tag]           v1.9.99-ncs2-rc1        -> v1.9.99-ncs2-rc1
 * [new tag]           v1.9.99-ncs2-rc2        -> v1.9.99-ncs2-rc2
 * [new tag]           v1.9.99-ncs2-snapshot1  -> v1.9.99-ncs2-snapshot1
 * [new tag]           v1.9.99-ncs3            -> v1.9.99-ncs3
 * [new tag]           v1.9.99-ncs3-rc1        -> v1.9.99-ncs3-rc1
 * [new tag]           v1.9.99-ncs3-rc2        -> v1.9.99-ncs3-rc2
 * [new tag]           v1.9.99-ncs4            -> v1.9.99-ncs4
 * [new tag]           v1.9.99-ncs4-rc1        -> v1.9.99-ncs4-rc1
 * [new tag]           v1.9.99-ncs4-rc2        -> v1.9.99-ncs4-rc2
 * [new tag]           v1.9.99-ncs4-snapshot1  -> v1.9.99-ncs4-snapshot1
 * [new tag]           v1.9.99-ncs4-snapshot2  -> v1.9.99-ncs4-snapshot2
 * [new tag]           v2.0.99-ncs1-1          -> v2.0.99-ncs1-1
 * [new tag]           v2.1.0-ncs1             -> v2.1.0-ncs1
 * [new tag]           v2.1.0-ncs1-rc1         -> v2.1.0-ncs1-rc1
 * [new tag]           v2.1.0-ncs1-rc2         -> v2.1.0-ncs1-rc2
 * [new tag]           v2.1.0-ncs1-rc3         -> v2.1.0-ncs1-rc3
HEAD is now at 3c2f2ff1 [nrf noup] boards: thingy91x: add board config
From https://github.com/laurencelundblade/QCBOR
 * [new branch]      BeforeSpiffyDecode -> refs/west/BeforeSpiffyDecode
 * [new branch]      CDE                -> refs/west/CDE
 * [new branch]      NaN                -> refs/west/NaN
 * [new branch]      arrays             -> refs/west/arrays
 * [new branch]      better_big_num     -> refs/west/better_big_num
 * [new branch]      const              -> refs/west/const
 * [new branch]      dev                -> refs/west/dev
 * [new branch]      disable            -> refs/west/disable
 * [new branch]      enter-array        -> refs/west/enter-array
 * [new branch]      makewarn           -> refs/west/makewarn
 * [new branch]      mappie             -> refs/west/mappie
 * [new branch]      newtag             -> refs/west/newtag
 * [new branch]      ub-example         -> refs/west/ub-example
 * [new branch]      versioning         -> refs/west/versioning
 * [new branch]      warn_in_tests      -> refs/west/warn_in_tests
 * [new tag]         v1.0               -> v1.0
 * [new tag]         v1.1               -> v1.1
 * [new tag]         v1.2               -> v1.2
 * [new tag]         v1.3               -> v1.3
 * [new tag]         v1.4               -> v1.4
 * [new tag]         v1.4.1             -> v1.4.1
HEAD is now at 751d365 restore inc/qcbor.h for backwards compatibility (#181)
From https://github.com/nrfconnect/sdk-mbedtls
 * tag                   v3.5.2-ncs1-1         -> FETCH_HEAD
 * [new tag]             mbedtls-2.26.0        -> mbedtls-2.26.0
 * [new tag]             v3.0.0-ncs1           -> v3.0.0-ncs1
 * [new tag]             v3.0.0-ncs1-rc2       -> v3.0.0-ncs1-rc2
 * [new tag]             v3.0.0-ncs2           -> v3.0.0-ncs2
 * [new tag]             v3.0.0-ncs2-rc1       -> v3.0.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs1           -> v3.1.0-ncs1
 * [new tag]             v3.1.0-ncs1-rc1       -> v3.1.0-ncs1-rc1
 * [new tag]             v3.1.0-ncs1-rc2       -> v3.1.0-ncs1-rc2
 * [new tag]             v3.1.0-ncs2           -> v3.1.0-ncs2
 * [new tag]             v3.1.0-ncs2-rc1       -> v3.1.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs2-rc2       -> v3.1.0-ncs2-rc2
 * [new tag]             v3.1.0-ncs3           -> v3.1.0-ncs3
 * [new tag]             v3.1.0-ncs3-rc1       -> v3.1.0-ncs3-rc1
 * [new tag]             v3.1.0-ncs3-rc2       -> v3.1.0-ncs3-rc2
 * [new tag]             v3.3.0-ncs1           -> v3.3.0-ncs1
 * [new tag]             v3.3.0-ncs1-1         -> v3.3.0-ncs1-1
 * [new tag]             v3.3.0-ncs1-rc1       -> v3.3.0-ncs1-rc1
 * [new tag]             v3.3.0-ncs1-rc2       -> v3.3.0-ncs1-rc2
 * [new tag]             v3.3.0-ncs1-snapshot1 -> v3.3.0-ncs1-snapshot1
 * [new tag]             v3.3.0-ncs2           -> v3.3.0-ncs2
 * [new tag]             v3.3.0-ncs2-1         -> v3.3.0-ncs2-1
 * [new tag]             v3.3.0-ncs2-1-rc1     -> v3.3.0-ncs2-1-rc1
 * [new tag]             v3.3.0-ncs2-2         -> v3.3.0-ncs2-2
 * [new tag]             v3.3.0-ncs2-3         -> v3.3.0-ncs2-3
 * [new tag]             v3.3.0-ncs2-rc1       -> v3.3.0-ncs2-rc1
 * [new tag]             v3.3.0-ncs2-rc2       -> v3.3.0-ncs2-rc2
 * [new tag]             v3.5.2-ncs1           -> v3.5.2-ncs1
 * [new tag]             v3.5.2-ncs1-1         -> v3.5.2-ncs1-1
 * [new tag]             v3.5.2-ncs1-rc1       -> v3.5.2-ncs1-rc1
 * [new tag]             v3.5.2-ncs1-rc2       -> v3.5.2-ncs1-rc2
 * [new tag]             v3.5.2-ncs1-snapshot1 -> v3.5.2-ncs1-snapshot1
 * [new tag]             v3.5.2-ncs2           -> v3.5.2-ncs2
 * [new tag]             v3.5.2-ncs2-rc1       -> v3.5.2-ncs2-rc1
 * [new tag]             v3.5.2-ncs2-rc2       -> v3.5.2-ncs2-rc2
 * [new tag]             v3.5.2-ncs2-rc3       -> v3.5.2-ncs2-rc3
 * [new tag]             v3.5.2-ncs2-snapshot1 -> v3.5.2-ncs2-snapshot1
HEAD is now at 9beb52e67 [nrf noup] tls: Adapt to final PSA PAKE APIs
From https://github.com/nrfconnect/sdk-nrfxlib
 * tag                 v2.6.1       -> FETCH_HEAD
 * [new tag]           v0.1.0       -> v0.1.0
 * [new tag]           v0.1.0-rc1   -> v0.1.0-rc1
 * [new tag]           v0.3.0       -> v0.3.0
 * [new tag]           v0.3.0-rc1   -> v0.3.0-rc1
 * [new tag]           v0.3.0-rc2   -> v0.3.0-rc2
 * [new tag]           v0.4.0       -> v0.4.0
 * [new tag]           v0.4.0-rc1   -> v0.4.0-rc1
 * [new tag]           v0.4.0-rc2   -> v0.4.0-rc2
 * [new tag]           v1.0.0       -> v1.0.0
 * [new tag]           v1.0.0-rc1   -> v1.0.0-rc1
 * [new tag]           v1.0.0-rc2   -> v1.0.0-rc2
 * [new tag]           v1.0.0-rc3   -> v1.0.0-rc3
 * [new tag]           v1.0.0-rc4   -> v1.0.0-rc4
 * [new tag]           v1.1.0       -> v1.1.0
 * [new tag]           v1.1.0-rc1   -> v1.1.0-rc1
 * [new tag]           v1.1.0-rc2   -> v1.1.0-rc2
 * [new tag]           v1.1.0-rc3   -> v1.1.0-rc3
 * [new tag]           v1.2.0       -> v1.2.0
 * [new tag]           v1.2.0-rc1   -> v1.2.0-rc1
 * [new tag]           v1.2.0-rc2   -> v1.2.0-rc2
 * [new tag]           v1.2.1       -> v1.2.1
 * [new tag]           v1.3.0       -> v1.3.0
 * [new tag]           v1.3.0-rc1   -> v1.3.0-rc1
 * [new tag]           v1.3.0-rc2   -> v1.3.0-rc2
 * [new tag]           v1.3.0-rc3   -> v1.3.0-rc3
 * [new tag]           v1.3.1       -> v1.3.1
 * [new tag]           v1.4.0       -> v1.4.0
 * [new tag]           v1.4.0-rc1   -> v1.4.0-rc1
 * [new tag]           v1.4.2       -> v1.4.2
 * [new tag]           v1.5.0       -> v1.5.0
 * [new tag]           v1.5.0-rc1   -> v1.5.0-rc1
 * [new tag]           v1.5.1       -> v1.5.1
 * [new tag]           v1.5.1-rc1   -> v1.5.1-rc1
 * [new tag]           v1.5.2       -> v1.5.2
 * [new tag]           v1.6.0       -> v1.6.0
 * [new tag]           v1.6.0-rc3   -> v1.6.0-rc3
 * [new tag]           v1.6.1       -> v1.6.1
 * [new tag]           v1.7.0       -> v1.7.0
 * [new tag]           v1.7.0-rc1   -> v1.7.0-rc1
 * [new tag]           v1.7.0-rc2   -> v1.7.0-rc2
 * [new tag]           v1.7.1       -> v1.7.1
 * [new tag]           v1.8.0       -> v1.8.0
 * [new tag]           v1.8.0-rc1   -> v1.8.0-rc1
 * [new tag]           v1.8.0-rc2   -> v1.8.0-rc2
 * [new tag]           v1.9.0       -> v1.9.0
 * [new tag]           v1.9.0-rc1   -> v1.9.0-rc1
 * [new tag]           v1.9.0-rc2   -> v1.9.0-rc2
 * [new tag]           v1.9.1       -> v1.9.1
 * [new tag]           v1.9.2       -> v1.9.2
 * [new tag]           v1.9.2-dev1  -> v1.9.2-dev1
 * [new tag]           v2.0.0       -> v2.0.0
 * [new tag]           v2.0.0-rc1   -> v2.0.0-rc1
 * [new tag]           v2.0.0-rc2   -> v2.0.0-rc2
 * [new tag]           v2.0.0-rc2-1 -> v2.0.0-rc2-1
 * [new tag]           v2.0.1       -> v2.0.1
 * [new tag]           v2.0.2       -> v2.0.2
 * [new tag]           v2.1.0       -> v2.1.0
 * [new tag]           v2.1.0-rc1   -> v2.1.0-rc1
 * [new tag]           v2.1.0-rc2   -> v2.1.0-rc2
 * [new tag]           v2.1.1       -> v2.1.1
 * [new tag]           v2.1.2       -> v2.1.2
 * [new tag]           v2.1.3       -> v2.1.3
 * [new tag]           v2.1.4       -> v2.1.4
 * [new tag]           v2.2.0       -> v2.2.0
 * [new tag]           v2.2.0-rc1   -> v2.2.0-rc1
 * [new tag]           v2.2.0-rc2   -> v2.2.0-rc2
 * [new tag]           v2.3.0       -> v2.3.0
 * [new tag]           v2.3.0-rc1   -> v2.3.0-rc1
 * [new tag]           v2.3.0-rc2   -> v2.3.0-rc2
 * [new tag]           v2.4.0       -> v2.4.0
 * [new tag]           v2.4.0-rc1   -> v2.4.0-rc1
 * [new tag]           v2.4.0-rc2   -> v2.4.0-rc2
 * [new tag]           v2.4.1       -> v2.4.1
 * [new tag]           v2.4.2       -> v2.4.2
 * [new tag]           v2.4.3       -> v2.4.3
 * [new tag]           v2.4.4       -> v2.4.4
 * [new tag]           v2.5.0       -> v2.5.0
 * [new tag]           v2.5.0-rc1   -> v2.5.0-rc1
 * [new tag]           v2.5.0-rc2   -> v2.5.0-rc2
 * [new tag]           v2.5.1       -> v2.5.1
 * [new tag]           v2.5.1-rc1   -> v2.5.1-rc1
 * [new tag]           v2.5.2       -> v2.5.2
 * [new tag]           v2.5.3       -> v2.5.3
 * [new tag]           v2.6.0       -> v2.6.0
 * [new tag]           v2.6.0-rc1   -> v2.6.0-rc1
 * [new tag]           v2.6.0-rc2   -> v2.6.0-rc2
 * [new tag]           v2.6.1       -> v2.6.1
 * [new tag]           v2.7.0       -> v2.7.0
 * [new tag]           v2.7.0-rc1   -> v2.7.0-rc1
 * [new tag]           v2.7.0-rc2   -> v2.7.0-rc2
 * [new tag]           v2.7.0-rc3   -> v2.7.0-rc3
HEAD is now at 9adb63b6 nrf_wifi: Update RPU patch to rev#8fe7ff0425f
From https://github.com/nrfconnect/sdk-trusted-firmware-m
 * tag                   v2.0.0-ncs1-1          -> FETCH_HEAD
 * [new tag]             v1.2.99-ncs1-1         -> v1.2.99-ncs1-1
 * [new tag]             v1.3.99-ncs1-rc3       -> v1.3.99-ncs1-rc3
 * [new tag]             v1.3.99-ncs1-snapshot1 -> v1.3.99-ncs1-snapshot1
 * [new tag]             v1.3.99-ncs1-snapshot2 -> v1.3.99-ncs1-snapshot2
 * [new tag]             v1.3.99-ncs2-1         -> v1.3.99-ncs2-1
 * [new tag]             v1.3.99-ncs3           -> v1.3.99-ncs3
 * [new tag]             v1.3.99-ncs3-rc1       -> v1.3.99-ncs3-rc1
 * [new tag]             v1.3.99-ncs3-rc2       -> v1.3.99-ncs3-rc2
 * [new tag]             v1.5.0-ncs1            -> v1.5.0-ncs1
 * [new tag]             v1.5.0-ncs1-1          -> v1.5.0-ncs1-1
 * [new tag]             v1.5.0-ncs1-rc1        -> v1.5.0-ncs1-rc1
 * [new tag]             v1.5.0-ncs1-rc2        -> v1.5.0-ncs1-rc2
 * [new tag]             v1.5.0-ncs2            -> v1.5.0-ncs2
 * [new tag]             v1.5.0-ncs2-rc1        -> v1.5.0-ncs2-rc1
 * [new tag]             v1.5.0-ncs2-rc2        -> v1.5.0-ncs2-rc2
 * [new tag]             v1.5.0-ncs2-snapshot1  -> v1.5.0-ncs2-snapshot1
 * [new tag]             v1.6.0-ncs1            -> v1.6.0-ncs1
 * [new tag]             v1.6.0-ncs1-rc1        -> v1.6.0-ncs1-rc1
 * [new tag]             v1.6.0-ncs1-rc2        -> v1.6.0-ncs1-rc2
 * [new tag]             v1.6.0-ncs1-snapshot1  -> v1.6.0-ncs1-snapshot1
 * [new tag]             v1.6.0-ncs2            -> v1.6.0-ncs2
 * [new tag]             v1.6.0-ncs2-rc1        -> v1.6.0-ncs2-rc1
 * [new tag]             v1.6.0-ncs2-rc2        -> v1.6.0-ncs2-rc2
 * [new tag]             v1.6.0-ncs3            -> v1.6.0-ncs3
 * [new tag]             v1.6.0-ncs3-rc1        -> v1.6.0-ncs3-rc1
 * [new tag]             v1.6.0-ncs3-rc2        -> v1.6.0-ncs3-rc2
 * [new tag]             v1.7.0-ncs1            -> v1.7.0-ncs1
 * [new tag]             v1.7.0-ncs1-1          -> v1.7.0-ncs1-1
 * [new tag]             v1.7.0-ncs1-rc2        -> v1.7.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1            -> v1.8.0-ncs1
 * [new tag]             v1.8.0-ncs1-1          -> v1.8.0-ncs1-1
 * [new tag]             v1.8.0-ncs1-1-rc1      -> v1.8.0-ncs1-1-rc1
 * [new tag]             v1.8.0-ncs1-2          -> v1.8.0-ncs1-2
 * [new tag]             v1.8.0-ncs1-3          -> v1.8.0-ncs1-3
 * [new tag]             v1.8.0-ncs1-rc1        -> v1.8.0-ncs1-rc1
 * [new tag]             v1.8.0-ncs1-rc2        -> v1.8.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1-snapshot1  -> v1.8.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs1            -> v2.0.0-ncs1
 * [new tag]             v2.0.0-ncs1-1          -> v2.0.0-ncs1-1
 * [new tag]             v2.0.0-ncs1-rc1        -> v2.0.0-ncs1-rc1
 * [new tag]             v2.0.0-ncs1-rc2        -> v2.0.0-ncs1-rc2
 * [new tag]             v2.0.0-ncs1-snapshot1  -> v2.0.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs2            -> v2.0.0-ncs2
 * [new tag]             v2.0.0-ncs2-rc1        -> v2.0.0-ncs2-rc1
 * [new tag]             v2.0.0-ncs2-rc2        -> v2.0.0-ncs2-rc2
 * [new tag]             v2.0.0-ncs2-rc3        -> v2.0.0-ncs2-rc3
 * [new tag]             v2.0.0-ncs2-snapshot1  -> v2.0.0-ncs2-snapshot1
HEAD is now at 2a2e1ce5e [nrf noup] cmake: tools: Dont add a custom command for running the manifest
From https://github.com/nrfconnect/sdk-psa-arch-tests
 * [new branch]      54l_its         -> refs/west/54l_its
 * [new branch]      fix_wdt_address -> refs/west/fix_wdt_address
HEAD is now at 94a349d [nrf fromlist] Fix base address for the nrf watchdog
From https://github.com/nrfconnect/sdk-connectedhomeip
 * [new tag]               v1.6.99-20210901    -> v1.6.99-20210901
 * [new tag]               v1.6.99-snapshot1   -> v1.6.99-snapshot1
 * [new tag]               v1.7.99-20211125    -> v1.7.99-20211125
 * [new tag]               v1.9.99-matter-dev1 -> v1.9.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev1 -> v2.0.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev2 -> v2.0.99-matter-dev2
 * [new tag]               v2.1.0-snapshot1    -> v2.1.0-snapshot1
 * [new tag]               v2.2.0-snapshot1    -> v2.2.0-snapshot1
 * [new tag]               v2.3.0-snapshot1    -> v2.3.0-snapshot1
 * [new tag]               v2.4.99-snapshot1   -> v2.4.99-snapshot1
 * [new tag]               v2.5.99-dev1        -> v2.5.99-dev1
HEAD is now at ca3672fbb9 [mrp] Increase default retry interval for Thread
      2 [main] sh 450 dofork: child -1 - forked process 13168 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/cf2149caf2/mingw64/libexec/git-core\git-submodule: fork: retry: Resource temporarily unavailable
      2 [main] sh (12532) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1391408/0x10A1408.
This problem is probably due to using incompatible versions of the cygwin DLL.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version.  The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution.  Rebooting is also suggested if you
are unable to find another cygwin DLL.
1142094 [main] sh 450 dofork: child -1 - forked process 12532 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
3281896 [main] sh 450 dofork: child -1 - forked process 11076 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (14240) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1391408/0x11F1408.
7416352 [main] sh 450 dofork: child -1 - forked process 14240 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (7504) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1391408/0x1101408.
15557294 [main] sh 450 dofork: child -1 - forked process 7504 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/cf2149caf2/mingw64/libexec/git-core\git-submodule: fork: Resource temporarily unavailable
From https://github.com/nrfconnect/sdk-cjson
 * [new tag]         v1.7.14    -> v1.7.14
HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
From https://github.com/nrfconnect/azure-sdk-for-c
HEAD is now at 308c171c [nrf fromlist] Make repository a Zephyr module
From https://github.com/nrfconnect/sdk-mcu-drivers
HEAD is now at 3873a08 Added missing curly brace for #ifdef __cplusplus
From https://github.com/nrfconnect/sdk-openthread
 * [new branch]          debug/tomaszkob89/key-rotation -> refs/west/debug/tomaszkob89/key-rotation
 * [new branch]          for-testing       -> refs/west/for-testing
 * [new branch]          v1.7-branch       -> refs/west/v1.7-branch
 * [new branch]          v1.9-branch       -> refs/west/v1.9-branch
 * [new branch]          v2.0-branch       -> refs/west/v2.0-branch
 * [new branch]          v2.4-branch       -> refs/west/v2.4-branch
 * [new tag]             thread-reference-20200818-ncs1-rc1 -> thread-reference-20200818-ncs1-rc1
 * [new tag]             thread-reference-20200818-ncs1-rc3 -> thread-reference-20200818-ncs1-rc3
 * [new tag]             v1.8.99-snapshot1 -> v1.8.99-snapshot1
 * [new tag]             v1.9.99-snapshot1 -> v1.9.99-snapshot1
HEAD is now at b9dcdbca4 [cli] add documentation for `nexthop` command in `README.md` (#9882)
From https://github.com/ThrowTheSwitch/cmock
 * [new branch]      branch_2_5_1           -> refs/west/branch_2_5_1
 * [new branch]      cmock_2_6_rc           -> refs/west/cmock_2_6_rc
 * [new branch]      feature/only_config_is_shared -> refs/west/feature/only_config_is_shared
 * [new branch]      reapply_329            -> refs/west/reapply_329
 * [new branch]      revert-329-master      -> refs/west/revert-329-master
 * [new branch]      test/switch_to_actions -> refs/west/test/switch_to_actions
 * [new tag]         v2.4.5                 -> v2.4.5
 * [new tag]         v2.4.6                 -> v2.4.6
HEAD is now at f65066f Merge pull request #404 from tz18/patch-1
      3 [main] sh (13956) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1341408/0x1181408.
      2 [main] sh 1869 dofork: child -1 - forked process 13956 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (8352) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1341408/0x1201408.
1140220 [main] sh 1869 dofork: child -1 - forked process 8352 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (5132) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1341408/0x1271408.
7187323 [main] sh 1869 dofork: child -1 - forked process 5132 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (5632) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1341408/0x1401408.
11333914 [main] sh 1869 dofork: child -1 - forked process 5632 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (1488) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1341408/0x1201408.
19468360 [main] sh 1869 dofork: child -1 - forked process 1488 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
From https://github.com/memfault/memfault-firmware-sdk
 * tag               1.6.0      -> FETCH_HEAD
 * [new tag]         0.0.10     -> 0.0.10
 * [new tag]         0.0.11     -> 0.0.11
 * [new tag]         0.0.12     -> 0.0.12
 * [new tag]         0.0.13     -> 0.0.13
 * [new tag]         0.0.14     -> 0.0.14
 * [new tag]         0.0.15     -> 0.0.15
 * [new tag]         0.0.16     -> 0.0.16
 * [new tag]         0.0.17     -> 0.0.17
 * [new tag]         0.0.18     -> 0.0.18
 * [new tag]         0.0.2      -> 0.0.2
 * [new tag]         0.0.3      -> 0.0.3
 * [new tag]         0.0.4      -> 0.0.4
 * [new tag]         0.0.5      -> 0.0.5
 * [new tag]         0.0.6      -> 0.0.6
 * [new tag]         0.0.7      -> 0.0.7
 * [new tag]         0.0.8      -> 0.0.8
 * [new tag]         0.0.9      -> 0.0.9
 * [new tag]         0.10.0     -> 0.10.0
 * [new tag]         0.10.1     -> 0.10.1
 * [new tag]         0.11.0     -> 0.11.0
 * [new tag]         0.11.1     -> 0.11.1
 * [new tag]         0.11.2     -> 0.11.2
 * [new tag]         0.11.3     -> 0.11.3
 * [new tag]         0.11.4     -> 0.11.4
 * [new tag]         0.12.0     -> 0.12.0
 * [new tag]         0.13.0     -> 0.13.0
 * [new tag]         0.13.1     -> 0.13.1
 * [new tag]         0.14.0     -> 0.14.0
 * [new tag]         0.15.0     -> 0.15.0
 * [new tag]         0.16.0     -> 0.16.0
 * [new tag]         0.16.1     -> 0.16.1
 * [new tag]         0.17.0     -> 0.17.0
 * [new tag]         0.17.1     -> 0.17.1
 * [new tag]         0.18.0     -> 0.18.0
 * [new tag]         0.19.0     -> 0.19.0
 * [new tag]         0.2.1      -> 0.2.1
 * [new tag]         0.2.2      -> 0.2.2
 * [new tag]         0.2.3      -> 0.2.3
 * [new tag]         0.2.4      -> 0.2.4
 * [new tag]         0.2.5      -> 0.2.5
 * [new tag]         0.20.0     -> 0.20.0
 * [new tag]         0.20.1     -> 0.20.1
 * [new tag]         0.20.2     -> 0.20.2
 * [new tag]         0.21.0     -> 0.21.0
 * [new tag]         0.21.1     -> 0.21.1
 * [new tag]         0.22.0     -> 0.22.0
 * [new tag]         0.23.0     -> 0.23.0
 * [new tag]         0.24.0     -> 0.24.0
 * [new tag]         0.24.1     -> 0.24.1
 * [new tag]         0.24.2     -> 0.24.2
 * [new tag]         0.25.0     -> 0.25.0
 * [new tag]         0.26.0     -> 0.26.0
 * [new tag]         0.26.1     -> 0.26.1
 * [new tag]         0.27.0     -> 0.27.0
 * [new tag]         0.27.1     -> 0.27.1
 * [new tag]         0.27.2     -> 0.27.2
 * [new tag]         0.27.3     -> 0.27.3
 * [new tag]         0.28.0     -> 0.28.0
 * [new tag]         0.28.1     -> 0.28.1
 * [new tag]         0.28.2     -> 0.28.2
 * [new tag]         0.29.0     -> 0.29.0
 * [new tag]         0.29.1     -> 0.29.1
 * [new tag]         0.3.2      -> 0.3.2
 * [new tag]         0.3.3      -> 0.3.3
 * [new tag]         0.3.4      -> 0.3.4
 * [new tag]         0.30.0     -> 0.30.0
 * [new tag]         0.30.1     -> 0.30.1
 * [new tag]         0.30.2     -> 0.30.2
 * [new tag]         0.30.3     -> 0.30.3
 * [new tag]         0.30.4     -> 0.30.4
 * [new tag]         0.30.5     -> 0.30.5
 * [new tag]         0.31.0     -> 0.31.0
 * [new tag]         0.31.1     -> 0.31.1
 * [new tag]         0.31.2     -> 0.31.2
 * [new tag]         0.31.3     -> 0.31.3
 * [new tag]         0.31.4     -> 0.31.4
 * [new tag]         0.31.5     -> 0.31.5
 * [new tag]         0.32.0     -> 0.32.0
 * [new tag]         0.32.1     -> 0.32.1
 * [new tag]         0.32.2     -> 0.32.2
 * [new tag]         0.33.0     -> 0.33.0
 * [new tag]         0.33.1     -> 0.33.1
 * [new tag]         0.33.2     -> 0.33.2
 * [new tag]         0.33.3     -> 0.33.3
 * [new tag]         0.33.4     -> 0.33.4
 * [new tag]         0.33.5     -> 0.33.5
 * [new tag]         0.34.0     -> 0.34.0
 * [new tag]         0.34.1     -> 0.34.1
 * [new tag]         0.34.2     -> 0.34.2
 * [new tag]         0.35.0     -> 0.35.0
 * [new tag]         0.36.0     -> 0.36.0
 * [new tag]         0.36.1     -> 0.36.1
 * [new tag]         0.37.0     -> 0.37.0
 * [new tag]         0.37.1     -> 0.37.1
 * [new tag]         0.37.2     -> 0.37.2
 * [new tag]         0.38.0     -> 0.38.0
 * [new tag]         0.39.0     -> 0.39.0
 * [new tag]         0.39.1     -> 0.39.1
 * [new tag]         0.4.1      -> 0.4.1
 * [new tag]         0.4.2      -> 0.4.2
 * [new tag]         0.40.0     -> 0.40.0
 * [new tag]         0.41.0     -> 0.41.0
 * [new tag]         0.41.1     -> 0.41.1
 * [new tag]         0.41.2     -> 0.41.2
 * [new tag]         0.42.0     -> 0.42.0
 * [new tag]         0.42.1     -> 0.42.1
 * [new tag]         0.43.0     -> 0.43.0
 * [new tag]         0.43.1     -> 0.43.1
 * [new tag]         0.43.2     -> 0.43.2
 * [new tag]         0.43.3     -> 0.43.3
 * [new tag]         0.6.1      -> 0.6.1
 * [new tag]         0.7.0      -> 0.7.0
 * [new tag]         0.7.1      -> 0.7.1
 * [new tag]         0.7.2      -> 0.7.2
 * [new tag]         0.7.3      -> 0.7.3
 * [new tag]         0.8.2      -> 0.8.2
 * [new tag]         0.9.1      -> 0.9.1
 * [new tag]         0.9.2      -> 0.9.2
 * [new tag]         0.9.3      -> 0.9.3
 * [new tag]         1.0.0      -> 1.0.0
 * [new tag]         1.0.1      -> 1.0.1
 * [new tag]         1.1.0      -> 1.1.0
 * [new tag]         1.1.1      -> 1.1.1
 * [new tag]         1.1.2      -> 1.1.2
 * [new tag]         1.1.3      -> 1.1.3
 * [new tag]         1.10.0     -> 1.10.0
 * [new tag]         1.10.1     -> 1.10.1
 * [new tag]         1.11.0     -> 1.11.0
 * [new tag]         1.11.1     -> 1.11.1
 * [new tag]         1.11.2     -> 1.11.2
 * [new tag]         1.11.3     -> 1.11.3
 * [new tag]         1.2.0      -> 1.2.0
 * [new tag]         1.2.1      -> 1.2.1
 * [new tag]         1.2.2      -> 1.2.2
 * [new tag]         1.2.3      -> 1.2.3
 * [new tag]         1.2.4      -> 1.2.4
 * [new tag]         1.2.5      -> 1.2.5
 * [new tag]         1.3.0      -> 1.3.0
 * [new tag]         1.3.1      -> 1.3.1
 * [new tag]         1.3.2      -> 1.3.2
 * [new tag]         1.3.3      -> 1.3.3
 * [new tag]         1.3.4      -> 1.3.4
 * [new tag]         1.3.5      -> 1.3.5
 * [new tag]         1.4.0      -> 1.4.0
 * [new tag]         1.4.1      -> 1.4.1
 * [new tag]         1.4.2      -> 1.4.2
 * [new tag]         1.4.3      -> 1.4.3
 * [new tag]         1.4.4      -> 1.4.4
 * [new tag]         1.5.0      -> 1.5.0
 * [new tag]         1.5.1      -> 1.5.1
 * [new tag]         1.5.2      -> 1.5.2
 * [new tag]         1.6.0      -> 1.6.0
 * [new tag]         1.6.1      -> 1.6.1
 * [new tag]         1.6.2      -> 1.6.2
 * [new tag]         1.7.0      -> 1.7.0
 * [new tag]         1.7.1      -> 1.7.1
 * [new tag]         1.7.2      -> 1.7.2
 * [new tag]         1.7.3      -> 1.7.3
 * [new tag]         1.7.4      -> 1.7.4
 * [new tag]         1.7.5      -> 1.7.5
 * [new tag]         1.7.6      -> 1.7.6
 * [new tag]         1.7.7      -> 1.7.7
 * [new tag]         1.8.0      -> 1.8.0
 * [new tag]         1.8.1      -> 1.8.1
 * [new tag]         1.9.0      -> 1.9.0
 * [new tag]         1.9.1      -> 1.9.1
 * [new tag]         1.9.2      -> 1.9.2
 * [new tag]         1.9.3      -> 1.9.3
 * [new tag]         1.9.4      -> 1.9.4
HEAD is now at 3d51c80 Memfault Firmware SDK 1.6.0 (Build 5464)
From https://github.com/zephyrproject-rtos/canopennode
 * [new tag]         zephyr-snapshot-1 -> zephyr-snapshot-1
HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t()
From https://github.com/zephyrproject-rtos/chre
HEAD is now at 3b32c76e zephyr: link the .unstable_id data in ROM
From https://github.com/zephyrproject-rtos/lz4
 * [new tag]         lz4-r130   -> lz4-r130
 * [new tag]         r116       -> r116
 * [new tag]         r117       -> r117
 * [new tag]         r118       -> r118
 * [new tag]         r119       -> r119
 * [new tag]         r120       -> r120
 * [new tag]         r121       -> r121
 * [new tag]         r122       -> r122
 * [new tag]         r123       -> r123
 * [new tag]         r124       -> r124
 * [new tag]         r125       -> r125
 * [new tag]         r126       -> r126
 * [new tag]         r127       -> r127
 * [new tag]         r128       -> r128
 * [new tag]         r129       -> r129
 * [new tag]         r130       -> r130
 * [new tag]         r131       -> r131
 * [new tag]         rc129v0    -> rc129v0
 * [new tag]         v1.7.3     -> v1.7.3
 * [new tag]         v1.7.4     -> v1.7.4
 * [new tag]         v1.7.4.2   -> v1.7.4.2
 * [new tag]         v1.7.5     -> v1.7.5
 * [new tag]         v1.8.1     -> v1.8.1
 * [new tag]         v1.8.1.2   -> v1.8.1.2
 * [new tag]         v1.8.2     -> v1.8.2
 * [new tag]         v1.8.3     -> v1.8.3
 * [new tag]         v1.9.3     -> v1.9.3
HEAD is now at 8e303c2 zephyr: make this repo a zephyr module
From https://github.com/zephyrproject-rtos/nanopb
 * [new branch]      cifuzz_test4           -> refs/west/cifuzz_test4
 * [new branch]      dev_dynamic_nanopb_pb2 -> refs/west/dev_dynamic_nanopb_pb2
 * [new branch]      dev_markdown_docs      -> refs/west/dev_markdown_docs
 * [new branch]      maintenance_0.1        -> refs/west/maintenance_0.1
 * [new branch]      maintenance_0.2        -> refs/west/maintenance_0.2
 * [new branch]      maintenance_0.3        -> refs/west/maintenance_0.3
 * [new tag]         0.2.9.5                -> 0.2.9.5
 * [new tag]         0.3.6                  -> 0.3.6
 * [new tag]         0.3.7                  -> 0.3.7
 * [new tag]         0.3.8                  -> 0.3.8
 * [new tag]         0.3.9                  -> 0.3.9
 * [new tag]         0.3.9.1                -> 0.3.9.1
 * [new tag]         0.3.9.2                -> 0.3.9.2
 * [new tag]         0.3.9.3                -> 0.3.9.3
 * [new tag]         0.3.9.4                -> 0.3.9.4
 * [new tag]         0.3.9.5                -> 0.3.9.5
 * [new tag]         0.3.9.6                -> 0.3.9.6
 * [new tag]         0.3.9.7                -> 0.3.9.7
 * [new tag]         0.3.9.8                -> 0.3.9.8
 * [new tag]         0.4.3                  -> 0.4.3
 * [new tag]         0.4.4                  -> 0.4.4
 * [new tag]         0.4.5                  -> 0.4.5
 * [new tag]         nanopb-0.1.0           -> nanopb-0.1.0
 * [new tag]         nanopb-0.1.1           -> nanopb-0.1.1
 * [new tag]         nanopb-0.1.2           -> nanopb-0.1.2
 * [new tag]         nanopb-0.1.3           -> nanopb-0.1.3
 * [new tag]         nanopb-0.1.4           -> nanopb-0.1.4
 * [new tag]         nanopb-0.1.5           -> nanopb-0.1.5
 * [new tag]         nanopb-0.1.6           -> nanopb-0.1.6
 * [new tag]         nanopb-0.1.7           -> nanopb-0.1.7
 * [new tag]         nanopb-0.1.8           -> nanopb-0.1.8
 * [new tag]         nanopb-0.1.9           -> nanopb-0.1.9
 * [new tag]         nanopb-0.1.9.1         -> nanopb-0.1.9.1
 * [new tag]         nanopb-0.2.0           -> nanopb-0.2.0
 * [new tag]         nanopb-0.2.1           -> nanopb-0.2.1
 * [new tag]         nanopb-0.2.2           -> nanopb-0.2.2
 * [new tag]         nanopb-0.2.3           -> nanopb-0.2.3
 * [new tag]         nanopb-0.2.4           -> nanopb-0.2.4
 * [new tag]         nanopb-0.2.5           -> nanopb-0.2.5
 * [new tag]         nanopb-0.2.6           -> nanopb-0.2.6
 * [new tag]         nanopb-0.2.7           -> nanopb-0.2.7
 * [new tag]         nanopb-0.2.8           -> nanopb-0.2.8
 * [new tag]         nanopb-0.2.9           -> nanopb-0.2.9
 * [new tag]         nanopb-0.2.9.1         -> nanopb-0.2.9.1
 * [new tag]         nanopb-0.2.9.2         -> nanopb-0.2.9.2
 * [new tag]         nanopb-0.2.9.3         -> nanopb-0.2.9.3
 * [new tag]         nanopb-0.2.9.4         -> nanopb-0.2.9.4
 * [new tag]         nanopb-0.2.9.5         -> nanopb-0.2.9.5
 * [new tag]         nanopb-0.3.0           -> nanopb-0.3.0
 * [new tag]         nanopb-0.3.1           -> nanopb-0.3.1
 * [new tag]         nanopb-0.3.2           -> nanopb-0.3.2
 * [new tag]         nanopb-0.3.3           -> nanopb-0.3.3
 * [new tag]         nanopb-0.3.4           -> nanopb-0.3.4
 * [new tag]         nanopb-0.3.5           -> nanopb-0.3.5
 * [new tag]         nanopb-0.3.6           -> nanopb-0.3.6
 * [new tag]         nanopb-0.3.7           -> nanopb-0.3.7
 * [new tag]         nanopb-0.3.8           -> nanopb-0.3.8
 * [new tag]         nanopb-0.3.9           -> nanopb-0.3.9
 * [new tag]         nanopb-0.3.9.1         -> nanopb-0.3.9.1
 * [new tag]         nanopb-0.3.9.2         -> nanopb-0.3.9.2
 * [new tag]         nanopb-0.3.9.3         -> nanopb-0.3.9.3
 * [new tag]         nanopb-0.3.9.4         -> nanopb-0.3.9.4
 * [new tag]         nanopb-0.3.9.5         -> nanopb-0.3.9.5
 * [new tag]         nanopb-0.3.9.6         -> nanopb-0.3.9.6
 * [new tag]         nanopb-0.3.9.7         -> nanopb-0.3.9.7
 * [new tag]         nanopb-0.3.9.8         -> nanopb-0.3.9.8
 * [new tag]         nanopb-0.4.0           -> nanopb-0.4.0
 * [new tag]         nanopb-0.4.0-dev       -> nanopb-0.4.0-dev
 * [new tag]         nanopb-0.4.1           -> nanopb-0.4.1
 * [new tag]         nanopb-0.4.2           -> nanopb-0.4.2
 * [new tag]         nanopb-0.4.3           -> nanopb-0.4.3
 * [new tag]         nanopb-0.4.4           -> nanopb-0.4.4
 * [new tag]         nanopb-0.4.5           -> nanopb-0.4.5
HEAD is now at 42fa8b2 Merge pull request #2 from pdgendt/zephyr
From https://github.com/zephyrproject-rtos/tf-m-tests
 * [new branch]      release/1.7.x -> refs/west/release/1.7.x
HEAD is now at 08a3158 Merge pull request #8 from mswarowsky/tfm_20_upmerge
From https://github.com/zephyrproject-rtos/zscilib
 * [new branch]      gh-pages   -> refs/west/gh-pages
 * [new branch]      revert-38-fix_zephyr_3_1 -> refs/west/revert-38-fix_zephyr_3_1
 * [new tag]         v0.2.0-rc1 -> v0.2.0-rc1
HEAD is now at 34a94b0 Merge pull request #55 from nashif/remove_ztest_config
From https://github.com/zephyrproject-rtos/cmsis
HEAD is now at 4b96cbb doc: Update documentations for CMSIS 5.9.0
From https://github.com/zephyrproject-rtos/cmsis-dsp
HEAD is now at ff7b5fd1 compute Library: fix inline function that is not static
From https://github.com/zephyrproject-rtos/cmsis-nn
 * [new branch]      zephyr-v6.0.0 -> refs/west/zephyr-v6.0.0
HEAD is now at 0c8669d Merge pull request #1 from XenuIsWatching/zephyr
From https://github.com/zephyrproject-rtos/edtt
 * [new branch]      le-audio      -> refs/west/le-audio
 * [new branch]      public_master -> refs/west/public_master
HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop
From https://github.com/zephyrproject-rtos/fatfs
HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE
From https://github.com/zephyrproject-rtos/hal_nordic
 * [new branch]      dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3 -> refs/west/dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3
 * [new tag]         nrfx-2.10.0  -> nrfx-2.10.0
 * [new tag]         nrfx-2.11.0  -> nrfx-2.11.0
 * [new tag]         nrfx-3.0.0   -> nrfx-3.0.0
HEAD is now at 5470822 nrfx: Fix compilation failures in nrfx_gppi_dppi_ppib.c
From https://github.com/zephyrproject-rtos/hal_st
HEAD is now at fb8e79d sensor/vl53l1x api/core call to VL53L1_GetTickCount function
From https://github.com/zephyrproject-rtos/hal_wurthelektronik
HEAD is now at 24ca987 Initialized WE HAL module repository.
From https://github.com/zephyrproject-rtos/libmetal
HEAD is now at 03140d7 Zephyr integration: Add support for hosted test environment
From https://github.com/zephyrproject-rtos/liblc3
HEAD is now at 448f3de Merge pull request #8 from carlescufi/rename
From https://github.com/zephyrproject-rtos/littlefs
 * [new tag]         littlefs-v2.1.0 -> littlefs-v2.1.0
 * [new tag]         littlefs-v2.1.1 -> littlefs-v2.1.1
 * [new tag]         littlefs-v2.1.2 -> littlefs-v2.1.2
 * [new tag]         littlefs-v2.1.3 -> littlefs-v2.1.3
 * [new tag]         littlefs-v2.1.4 -> littlefs-v2.1.4
 * [new tag]         littlefs-v2.2.0 -> littlefs-v2.2.0
HEAD is now at ca583fd Merge tag 'v2.5.0' of https://github.com/littlefs-project/littlefs into zephyr
From https://github.com/zephyrproject-rtos/loramac-node
 * [new branch]        master        -> refs/west/master
 * [new branch]        v4.5.2-zephyr -> refs/west/v4.5.2-zephyr
 * [new branch]        v4.6.0-zephyr -> refs/west/v4.6.0-zephyr
 * [new branch]        v4.7.0-zephyr -> refs/west/v4.7.0-zephyr
 * [new branch]        zephyr-v2.6   -> refs/west/zephyr-v2.6
 * [new tag]           4.4.2-rc.4    -> 4.4.2-rc.4
 * [new tag]           V3.4          -> V3.4
 * [new tag]           v2.0          -> v2.0
 * [new tag]           v2.1          -> v2.1
 * [new tag]           v2.2          -> v2.2
 * [new tag]           v2.3.RC1      -> v2.3.RC1
 * [new tag]           v2.3.RC2      -> v2.3.RC2
 * [new tag]           v3.0          -> v3.0
 * [new tag]           v3.1          -> v3.1
 * [new tag]           v3.2          -> v3.2
 * [new tag]           v3.3          -> v3.3
 * [new tag]           v3.4.1        -> v3.4.1
 * [new tag]           v4.0.0        -> v4.0.0
 * [new tag]           v4.1.0        -> v4.1.0
 * [new tag]           v4.2.0        -> v4.2.0
 * [new tag]           v4.3.0        -> v4.3.0
 * [new tag]           v4.3.1        -> v4.3.1
 * [new tag]           v4.3.2        -> v4.3.2
 * [new tag]           v4.4.0        -> v4.4.0
 * [new tag]           v4.4.1        -> v4.4.1
 * [new tag]           v4.4.2        -> v4.4.2
 * [new tag]           v4.4.2-rc.1   -> v4.4.2-rc.1
 * [new tag]           v4.4.2-rc.2   -> v4.4.2-rc.2
 * [new tag]           v4.4.2-rc.3   -> v4.4.2-rc.3
 * [new tag]           v4.4.2-rc.5   -> v4.4.2-rc.5
 * [new tag]           v4.4.2-rc.6   -> v4.4.2-rc.6
 * [new tag]           v4.4.2-rc.7   -> v4.4.2-rc.7
 * [new tag]           v4.4.3        -> v4.4.3
 * [new tag]           v4.4.3_zephyr -> v4.4.3_zephyr
HEAD is now at 842413c5 utilities: fix one more shadowed variable
From https://github.com/zephyrproject-rtos/lvgl
 * [new branch]        zephyr     -> refs/west/zephyr
HEAD is now at 7c61a4ce zephyr: Kconfig: Add guard checking for LVGL module
From https://github.com/zephyrproject-rtos/mipi-sys-t
HEAD is now at a819419 library: allow building without wchar support
From https://github.com/zephyrproject-rtos/net-tools
HEAD is now at d68ee9d docker: Add Leshan demo server
From https://github.com/zephyrproject-rtos/nrf_hw_models
 * [new branch]      main       -> refs/west/main
HEAD is now at 52d0b4b UART: FIFO backend: Do not error out if other side disconnects Rx
From https://github.com/zephyrproject-rtos/open-amp
 * [new branch]      bump_v2024.05.0 -> refs/west/bump_v2024.05.0
 * [new branch]      v1.14-branch    -> refs/west/v1.14-branch
 * [new tag]         old_master      -> old_master
HEAD is now at 214f9fc cmake: Compile with WITH_DCACHE
From https://github.com/zephyrproject-rtos/picolibc
 * [new branch]          Z-emcb-cygwin_daemon        -> refs/west/Z-emcb-cygwin_daemon
 * [new branch]          aarch64                     -> refs/west/aarch64
 * [new branch]          add-fakeroots-dir           -> refs/west/add-fakeroots-dir
 * [new branch]          amd64_to_x86_64             -> refs/west/amd64_to_x86_64
 * [new branch]          ancient-clang               -> refs/west/ancient-clang
 * [new branch]          arc-20081103-branch         -> refs/west/arc-20081103-branch
 * [new branch]          arc-insight_6_8-branch      -> refs/west/arc-insight_6_8-branch
 * [new branch]          arm-read-tp-cleanup         -> refs/west/arm-read-tp-cleanup
 * [new branch]          binutils-2_10-branch        -> refs/west/binutils-2_10-branch
 * [new branch]          binutils-2_11-branch        -> refs/west/binutils-2_11-branch
 * [new branch]          binutils-2_12-branch        -> refs/west/binutils-2_12-branch
 * [new branch]          binutils-2_13-branch        -> refs/west/binutils-2_13-branch
 * [new branch]          binutils-2_14-branch        -> refs/west/binutils-2_14-branch
 * [new branch]          binutils-2_15-branch        -> refs/west/binutils-2_15-branch
 * [new branch]          binutils-2_16-branch        -> refs/west/binutils-2_16-branch
 * [new branch]          binutils-2_17-branch        -> refs/west/binutils-2_17-branch
 * [new branch]          binutils-2_18-branch        -> refs/west/binutils-2_18-branch
 * [new branch]          binutils-2_19-branch        -> refs/west/binutils-2_19-branch
 * [new branch]          binutils-2_20-branch        -> refs/west/binutils-2_20-branch
 * [new branch]          binutils-2_21-branch        -> refs/west/binutils-2_21-branch
 * [new branch]          binutils-2_22-branch        -> refs/west/binutils-2_22-branch
 * [new branch]          binutils-2_22_branch        -> refs/west/binutils-2_22_branch
 * [new branch]          binutils-2_23-branch        -> refs/west/binutils-2_23-branch
 * [new branch]          binutils-2_24-branch        -> refs/west/binutils-2_24-branch
 * [new branch]          binutils-arc-20080908-branch -> refs/west/binutils-arc-20080908-branch
 * [new branch]          binutils-arc-20081103-branch -> refs/west/binutils-arc-20081103-branch
 * [new branch]          binutils-csl-2_17-branch    -> refs/west/binutils-csl-2_17-branch
 * [new branch]          binutils-csl-arm-2005q1-branch -> refs/west/binutils-csl-arm-2005q1-branch
 * [new branch]          binutils-csl-gxxpro-3_4-branch -> refs/west/binutils-csl-gxxpro-3_4-branch
 * [new branch]          branch-1.4.6                -> refs/west/branch-1.4.6
 * [new branch]          branch-1.8.4                -> refs/west/branch-1.8.4
 * [new branch]          c-sky                       -> refs/west/c-sky
 * [new branch]          cagney-unwind-20030108-branch -> refs/west/cagney-unwind-20030108-branch
 * [new branch]          cagney_bfdfile-20040213-branch -> refs/west/cagney_bfdfile-20040213-branch
 * [new branch]          cagney_bigcore-20040122-branch -> refs/west/cagney_bigcore-20040122-branch
 * [new branch]          cagney_convert-20030606-branch -> refs/west/cagney_convert-20030606-branch
 * [new branch]          cagney_fileio-20030521-branch -> refs/west/cagney_fileio-20030521-branch
 * [new branch]          cagney_frameaddr-20030403-branch -> refs/west/cagney_frameaddr-20030403-branch
 * [new branch]          cagney_framebase-20030326-branch -> refs/west/cagney_framebase-20030326-branch
 * [new branch]          cagney_lazyid-20030317-branch -> refs/west/cagney_lazyid-20030317-branch
 * [new branch]          cagney_offbyone-20030303-branch -> refs/west/cagney_offbyone-20030303-branch
 * [new branch]          cagney_regbuf-20020515-branch -> refs/west/cagney_regbuf-20020515-branch
 * [new branch]          cagney_sysregs-20020825-branch -> refs/west/cagney_sysregs-20020825-branch
 * [new branch]          cagney_tramp-20040309-branch -> refs/west/cagney_tramp-20040309-branch
 * [new branch]          cagney_writestrings-20030508-branch -> refs/west/cagney_writestrings-20030508-branch
 * [new branch]          cagney_x86i386-20030821-branch -> refs/west/cagney_x86i386-20030821-branch
 * [new branch]          callout                     -> refs/west/callout
 * [new branch]          carlton_dictionary-branch   -> refs/west/carlton_dictionary-branch
 * [new branch]          cgen-1_1-branch             -> refs/west/cgen-1_1-branch
 * [new branch]          cgf-deleteme                -> refs/west/cgf-deleteme
 * [new branch]          cgf-dev-branch              -> refs/west/cgf-dev-branch
 * [new branch]          cmake                       -> refs/west/cmake
 * [new branch]          cmake-no-tls                -> refs/west/cmake-no-tls
 * [new branch]          cmake-small-ultoa           -> refs/west/cmake-small-ultoa
 * [new branch]          cr-0x3b58                   -> refs/west/cr-0x3b58
 * [new branch]          cr-0x5e6                    -> refs/west/cr-0x5e6
 * [new branch]          cr-0x5ef                    -> refs/west/cr-0x5ef
 * [new branch]          cr-0x5f1                    -> refs/west/cr-0x5f1
 * [new branch]          cr-0x9b                     -> refs/west/cr-0x9b
 * [new branch]          cr-0x9c                     -> refs/west/cr-0x9c
 * [new branch]          cr-0x9d                     -> refs/west/cr-0x9d
 * [new branch]          cr-0x9e                     -> refs/west/cr-0x9e
 * [new branch]          csl-arm-20050325-branch     -> refs/west/csl-arm-20050325-branch
 * [new branch]          cv-branch                   -> refs/west/cv-branch
 * [new branch]          cv-branch-2                 -> refs/west/cv-branch-2
 * [new branch]          cv-post-1_7_9               -> refs/west/cv-post-1_7_9
 * [new branch]          cygnus                      -> refs/west/cygnus
 * [new branch]          cygwin-1-1-4                -> refs/west/cygwin-1-1-4
 * [new branch]          cygwin-1-3-1                -> refs/west/cygwin-1-3-1
 * [new branch]          cygwin-1-3-10-1             -> refs/west/cygwin-1-3-10-1
 * [new branch]          cygwin-1-3-11-3             -> refs/west/cygwin-1-3-11-3
 * [new branch]          cygwin-1-3-12-1             -> refs/west/cygwin-1-3-12-1
 * [new branch]          cygwin-1-3-13-1             -> refs/west/cygwin-1-3-13-1
 * [new branch]          cygwin-1-3-13-2             -> refs/west/cygwin-1-3-13-2
 * [new branch]          cygwin-1-3-14-1             -> refs/west/cygwin-1-3-14-1
 * [new branch]          cygwin-1-3-15-1             -> refs/west/cygwin-1-3-15-1
 * [new branch]          cygwin-1-3-16-1             -> refs/west/cygwin-1-3-16-1
 * [new branch]          cygwin-1-3-17-1             -> refs/west/cygwin-1-3-17-1
 * [new branch]          cygwin-1-3-18-1             -> refs/west/cygwin-1-3-18-1
 * [new branch]          cygwin-1-3-19-1             -> refs/west/cygwin-1-3-19-1
 * [new branch]          cygwin-1-3-2                -> refs/west/cygwin-1-3-2
 * [new branch]          cygwin-1-3-3                -> refs/west/cygwin-1-3-3
 * [new branch]          cygwin-1-3-4                -> refs/west/cygwin-1-3-4
 * [new branch]          cygwin-1-3-5                -> refs/west/cygwin-1-3-5
 * [new branch]          cygwin-1-3-5-2              -> refs/west/cygwin-1-3-5-2
 * [new branch]          cygwin-1-3-5-3              -> refs/west/cygwin-1-3-5-3
 * [new branch]          cygwin-1-3-6-1              -> refs/west/cygwin-1-3-6-1
 * [new branch]          cygwin-1-3-6-2              -> refs/west/cygwin-1-3-6-2
 * [new branch]          cygwin-1-3-6-3              -> refs/west/cygwin-1-3-6-3
 * [new branch]          cygwin-1-3-6-4              -> refs/west/cygwin-1-3-6-4
 * [new branch]          cygwin-1-3-6-5              -> refs/west/cygwin-1-3-6-5
 * [new branch]          cygwin-1-3-6-6              -> refs/west/cygwin-1-3-6-6
 * [new branch]          cygwin-1-3-7-1              -> refs/west/cygwin-1-3-7-1
 * [new branch]          cygwin-1-3-8-1              -> refs/west/cygwin-1-3-8-1
 * [new branch]          cygwin-1-3-9                -> refs/west/cygwin-1-3-9
 * [new branch]          cygwin-1_7_29-release-branchpoint -> refs/west/cygwin-1_7_29-release-branchpoint
 * [new branch]          cygwin-2.0                  -> refs/west/cygwin-2.0
 * [new branch]          cygwin-3_0-branch           -> refs/west/cygwin-3_0-branch
 * [new branch]          cygwin-64bit-branch         -> refs/west/cygwin-64bit-branch
 * [new branch]          cygwin-64bit-premerge-branch -> refs/west/cygwin-64bit-premerge-branch
 * [new branch]          cygwin-acl                  -> refs/west/cygwin-acl
 * [new branch]          cygwin_daemon               -> refs/west/cygwin_daemon
 * [new branch]          debian                      -> refs/west/debian
 * [new branch]          dje-cgen-play1-branch       -> refs/west/dje-cgen-play1-branch
 * [new branch]          docker-builder-packages.txt-hash -> refs/west/docker-builder-packages.txt-hash
 * [new branch]          drow-cplus-branch           -> refs/west/drow-cplus-branch
 * [new branch]          drow-reverse-20070409-branch -> refs/west/drow-reverse-20070409-branch
 * [new branch]          drow_intercu-20040221-branch -> refs/west/drow_intercu-20040221-branch
 * [new branch]          ezannoni_pie-20030916-branch -> refs/west/ezannoni_pie-20030916-branch
 * [new branch]          ezannoni_pie-20040323-branch -> refs/west/ezannoni_pie-20040323-branch
 * [new branch]          fifo_doover3                -> refs/west/fifo_doover3
 * [new branch]          fixes-newlib                -> refs/west/fixes-newlib
 * [new branch]          float-inlines               -> refs/west/float-inlines
 * [new branch]          fp-zeuch                    -> refs/west/fp-zeuch
 * [new branch]          gdb-csl-20060226-branch     -> refs/west/gdb-csl-20060226-branch
 * [new branch]          gdb-csl-arm-20051020-branch -> refs/west/gdb-csl-arm-20051020-branch
 * [new branch]          gdb-csl-available-20060303-branch -> refs/west/gdb-csl-available-20060303-branch
 * [new branch]          gdb-csl-gxxpro-6_3-branch   -> refs/west/gdb-csl-gxxpro-6_3-branch
 * [new branch]          gdb-csl-symbian-20060226-branch -> refs/west/gdb-csl-symbian-20060226-branch
 * [new branch]          gdb-premipsmulti-2000-06-06-branch -> refs/west/gdb-premipsmulti-2000-06-06-branch
 * [new branch]          gdb_5_0-2000-04-10-branch   -> refs/west/gdb_5_0-2000-04-10-branch
 * [new branch]          gdb_5_1-2001-07-29-branch   -> refs/west/gdb_5_1-2001-07-29-branch
 * [new branch]          gdb_5_1_0_1-2002-01-03-branch -> refs/west/gdb_5_1_0_1-2002-01-03-branch
 * [new branch]          gdb_5_2-branch              -> refs/west/gdb_5_2-branch
 * [new branch]          gdb_5_3-branch              -> refs/west/gdb_5_3-branch
 * [new branch]          gdb_6_0-branch              -> refs/west/gdb_6_0-branch
 * [new branch]          gdb_6_1-branch              -> refs/west/gdb_6_1-branch
 * [new branch]          gdb_6_2-branch              -> refs/west/gdb_6_2-branch
 * [new branch]          gdb_6_3-branch              -> refs/west/gdb_6_3-branch
 * [new branch]          gdb_6_4-branch              -> refs/west/gdb_6_4-branch
 * [new branch]          gdb_6_5-branch              -> refs/west/gdb_6_5-branch
 * [new branch]          gdb_6_6-branch              -> refs/west/gdb_6_6-branch
 * [new branch]          gdb_6_7-branch              -> refs/west/gdb_6_7-branch
 * [new branch]          gdb_6_8-branch              -> refs/west/gdb_6_8-branch
 * [new branch]          gdb_7_0-branch              -> refs/west/gdb_7_0-branch
 * [new branch]          gdb_7_1-branch              -> refs/west/gdb_7_1-branch
 * [new branch]          gdb_7_2-branch              -> refs/west/gdb_7_2-branch
 * [new branch]          gdb_7_3-branch              -> refs/west/gdb_7_3-branch
 * [new branch]          gdb_7_4-branch              -> refs/west/gdb_7_4-branch
 * [new branch]          gdb_7_5-branch              -> refs/west/gdb_7_5-branch
 * [new branch]          gdb_7_6-branch              -> refs/west/gdb_7_6-branch
 * [new branch]          gdb_s390-2001-09-26-branch  -> refs/west/gdb_s390-2001-09-26-branch
 * [new branch]          gh                          -> refs/west/gh
 * [new branch]          insight_6_8-branch          -> refs/west/insight_6_8-branch
 * [new branch]          interps-20030202-branch     -> refs/west/interps-20030202-branch
 * [new branch]          isblank-extern-inline       -> refs/west/isblank-extern-inline
 * [new branch]          jimb-gdb_6_2-e500-branch    -> refs/west/jimb-gdb_6_2-e500-branch
 * [new branch]          jimb-macro-020506-branch    -> refs/west/jimb-macro-020506-branch
 * [new branch]          jimb-ppc64-linux-20030509-branch -> refs/west/jimb-ppc64-linux-20030509-branch
 * [new branch]          jimb-ppc64-linux-20030528-branch -> refs/west/jimb-ppc64-linux-20030528-branch
 * [new branch]          jimb-ppc64-linux-20030613-branch -> refs/west/jimb-ppc64-linux-20030613-branch
 * [new branch]          jimb-rda-nptl-branch        -> refs/west/jimb-rda-nptl-branch
 * [new branch]          kettenis-i386newframe-20030308-branch -> refs/west/kettenis-i386newframe-20030308-branch
 * [new branch]          kettenis_i386newframe-20030406-branch -> refs/west/kettenis_i386newframe-20030406-branch
 * [new branch]          kettenis_i386newframe-20030419-branch -> refs/west/kettenis_i386newframe-20030419-branch
 * [new branch]          kettenis_sparc-20030918-branch -> refs/west/kettenis_sparc-20030918-branch
 * [new branch]          kseitz_interps-20020528-branch -> refs/west/kseitz_interps-20020528-branch
 * [new branch]          locking-docs                -> refs/west/locking-docs
 * [new branch]          mingw-std-ns-branch         -> refs/west/mingw-std-ns-branch
 * [new branch]          mingwex                     -> refs/west/mingwex
 * [new branch]          msnyder-checkpoint-072509-branch -> refs/west/msnyder-checkpoint-072509-branch
 * [new branch]          msnyder-fork-checkpoint-branch -> refs/west/msnyder-fork-checkpoint-branch
 * [new branch]          msnyder-reverse-20060331-branch -> refs/west/msnyder-reverse-20060331-branch
 * [new branch]          msnyder-reverse-20060502-branch -> refs/west/msnyder-reverse-20060502-branch
 * [new branch]          msnyder-reverse-20080609-branch -> refs/west/msnyder-reverse-20080609-branch
 * [new branch]          msnyder-tracepoint-checkpoint-branch -> refs/west/msnyder-tracepoint-checkpoint-branch
 * [new branch]          msp430                      -> refs/west/msp430
 * [new branch]          multiprocess-20081120-branch -> refs/west/multiprocess-20081120-branch
 * [new branch]          newlib                      -> refs/west/newlib
 * [new branch]          newlib-1_17_0-arc           -> refs/west/newlib-1_17_0-arc
 * [new branch]          newlib-autotools-branch     -> refs/west/newlib-autotools-branch
 * [new branch]          newlib-csl-20060320-branch  -> refs/west/newlib-csl-20060320-branch
 * [new branch]          nickrob-async-20060513-branch -> refs/west/nickrob-async-20060513-branch
 * [new branch]          non-linux-ln                -> refs/west/non-linux-ln
 * [new branch]          noreparent                  -> refs/west/noreparent
 * [new branch]          offbyone-20030313-branch    -> refs/west/offbyone-20030313-branch
 * [new branch]          pre-regex                   -> refs/west/pre-regex
 * [new branch]          pregp02r1                   -> refs/west/pregp02r1
 * [new branch]          readline_4_3-import-branch  -> refs/west/readline_4_3-import-branch
 * [new branch]          readline_5_1-import-branch  -> refs/west/readline_5_1-import-branch
 * [new branch]          reverse-20080717-branch     -> refs/west/reverse-20080717-branch
 * [new branch]          reverse-20080930-branch     -> refs/west/reverse-20080930-branch
 * [new branch]          reverse-20081226-branch     -> refs/west/reverse-20081226-branch
 * [new branch]          riscv-zicsr                 -> refs/west/riscv-zicsr
 * [new branch]          semihost-2.0-all            -> refs/west/semihost-2.0-all
 * [new branch]          sid-20020905-branch         -> refs/west/sid-20020905-branch
 * [new branch]          signal-rewrite              -> refs/west/signal-rewrite
 * [new branch]          sysroot-skip-checks         -> refs/west/sysroot-skip-checks
 * [new branch]          tcltk840-20020924-branch    -> refs/west/tcltk840-20020924-branch
 * [new branch]          tls                         -> refs/west/tls
 * [new branch]          topic/af_unix               -> refs/west/topic/af_unix
 * [new branch]          topic/ansification          -> refs/west/topic/ansification
 * [new branch]          topic/fifo                  -> refs/west/topic/fifo
 * [new branch]          topic/forkables             -> refs/west/topic/forkables
 * [new branch]          topic/locales               -> refs/west/topic/locales
 * [new branch]          topic/posix_acl_funcs       -> refs/west/topic/posix_acl_funcs
 * [new branch]          topic/ssp                   -> refs/west/topic/ssp
 * [new branch]          unlabeled-1.1.1.1.2         -> refs/west/unlabeled-1.1.1.1.2
 * [new branch]          unlabeled-1.100.2           -> refs/west/unlabeled-1.100.2
 * [new branch]          unlabeled-1.1010.2          -> refs/west/unlabeled-1.1010.2
 * [new branch]          unlabeled-1.1019.2          -> refs/west/unlabeled-1.1019.2
 * [new branch]          unlabeled-1.1042.2          -> refs/west/unlabeled-1.1042.2
 * [new branch]          unlabeled-1.1042.2.1.4      -> refs/west/unlabeled-1.1042.2.1.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4  -> refs/west/unlabeled-1.1042.2.1.4.2.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4.2.2 -> refs/west/unlabeled-1.1042.2.1.4.2.4.2.2
 * [new branch]          unlabeled-1.105.2           -> refs/west/unlabeled-1.105.2
 * [new branch]          unlabeled-1.106.2           -> refs/west/unlabeled-1.106.2
 * [new branch]          unlabeled-1.106.8           -> refs/west/unlabeled-1.106.8
 * [new branch]          unlabeled-1.107.12          -> refs/west/unlabeled-1.107.12
 * [new branch]          unlabeled-1.11.2            -> refs/west/unlabeled-1.11.2
 * [new branch]          unlabeled-1.112.4           -> refs/west/unlabeled-1.112.4
 * [new branch]          unlabeled-1.116.4           -> refs/west/unlabeled-1.116.4
 * [new branch]          unlabeled-1.12.20           -> refs/west/unlabeled-1.12.20
 * [new branch]          unlabeled-1.12.30           -> refs/west/unlabeled-1.12.30
 * [new branch]          unlabeled-1.12.4            -> refs/west/unlabeled-1.12.4
 * [new branch]          unlabeled-1.120.2           -> refs/west/unlabeled-1.120.2
 * [new branch]          unlabeled-1.125.2           -> refs/west/unlabeled-1.125.2
 * [new branch]          unlabeled-1.13.10           -> refs/west/unlabeled-1.13.10
 * [new branch]          unlabeled-1.13.2            -> refs/west/unlabeled-1.13.2
 * [new branch]          unlabeled-1.13.30           -> refs/west/unlabeled-1.13.30
 * [new branch]          unlabeled-1.13.4            -> refs/west/unlabeled-1.13.4
 * [new branch]          unlabeled-1.133.2           -> refs/west/unlabeled-1.133.2
 * [new branch]          unlabeled-1.134.4           -> refs/west/unlabeled-1.134.4
 * [new branch]          unlabeled-1.135.4           -> refs/west/unlabeled-1.135.4
 * [new branch]          unlabeled-1.1370.2          -> refs/west/unlabeled-1.1370.2
 * [new branch]          unlabeled-1.142.2           -> refs/west/unlabeled-1.142.2
 * [new branch]          unlabeled-1.143.4           -> refs/west/unlabeled-1.143.4
 * [new branch]          unlabeled-1.144.2           -> refs/west/unlabeled-1.144.2
 * [new branch]          unlabeled-1.15.10           -> refs/west/unlabeled-1.15.10
 * [new branch]          unlabeled-1.15.2            -> refs/west/unlabeled-1.15.2
 * [new branch]          unlabeled-1.1527.4          -> refs/west/unlabeled-1.1527.4
 * [new branch]          unlabeled-1.153.2           -> refs/west/unlabeled-1.153.2
 * [new branch]          unlabeled-1.1563.2          -> refs/west/unlabeled-1.1563.2
 * [new branch]          unlabeled-1.1656.2          -> refs/west/unlabeled-1.1656.2
 * [new branch]          unlabeled-1.167.4           -> refs/west/unlabeled-1.167.4
 * [new branch]          unlabeled-1.17.2            -> refs/west/unlabeled-1.17.2
 * [new branch]          unlabeled-1.17.4            -> refs/west/unlabeled-1.17.4
 * [new branch]          unlabeled-1.1710.2          -> refs/west/unlabeled-1.1710.2
 * [new branch]          unlabeled-1.172.4           -> refs/west/unlabeled-1.172.4
 * [new branch]          unlabeled-1.18.10           -> refs/west/unlabeled-1.18.10
 * [new branch]          unlabeled-1.18.2            -> refs/west/unlabeled-1.18.2
 * [new branch]          unlabeled-1.1806.2          -> refs/west/unlabeled-1.1806.2
 * [new branch]          unlabeled-1.1856.2          -> refs/west/unlabeled-1.1856.2
 * [new branch]          unlabeled-1.188.2           -> refs/west/unlabeled-1.188.2
 * [new branch]          unlabeled-1.188.2.1.8       -> refs/west/unlabeled-1.188.2.1.8
 * [new branch]          unlabeled-1.188.2.1.8.2.2   -> refs/west/unlabeled-1.188.2.1.8.2.2
 * [new branch]          unlabeled-1.19.12           -> refs/west/unlabeled-1.19.12
 * [new branch]          unlabeled-1.2.2             -> refs/west/unlabeled-1.2.2
 * [new branch]          unlabeled-1.20.4            -> refs/west/unlabeled-1.20.4
 * [new branch]          unlabeled-1.21.2            -> refs/west/unlabeled-1.21.2
 * [new branch]          unlabeled-1.21.4            -> refs/west/unlabeled-1.21.4
 * [new branch]          unlabeled-1.22.2            -> refs/west/unlabeled-1.22.2
 * [new branch]          unlabeled-1.22.4            -> refs/west/unlabeled-1.22.4
 * [new branch]          unlabeled-1.226.2           -> refs/west/unlabeled-1.226.2
 * [new branch]          unlabeled-1.23.16           -> refs/west/unlabeled-1.23.16
 * [new branch]          unlabeled-1.23.2            -> refs/west/unlabeled-1.23.2
 * [new branch]          unlabeled-1.23.4            -> refs/west/unlabeled-1.23.4
 * [new branch]          unlabeled-1.231.4           -> refs/west/unlabeled-1.231.4
 * [new branch]          unlabeled-1.234.16          -> refs/west/unlabeled-1.234.16
 * [new branch]          unlabeled-1.235.2           -> refs/west/unlabeled-1.235.2
 * [new branch]          unlabeled-1.238.4           -> refs/west/unlabeled-1.238.4
 * [new branch]          unlabeled-1.24.16           -> refs/west/unlabeled-1.24.16
 * [new branch]          unlabeled-1.24.2            -> refs/west/unlabeled-1.24.2
 * [new branch]          unlabeled-1.24.4            -> refs/west/unlabeled-1.24.4
 * [new branch]          unlabeled-1.248.2           -> refs/west/unlabeled-1.248.2
 * [new branch]          unlabeled-1.253.2           -> refs/west/unlabeled-1.253.2
 * [new branch]          unlabeled-1.27.12           -> refs/west/unlabeled-1.27.12
 * [new branch]          unlabeled-1.27.8            -> refs/west/unlabeled-1.27.8
 * [new branch]          unlabeled-1.30.4            -> refs/west/unlabeled-1.30.4
 * [new branch]          unlabeled-1.31.4            -> refs/west/unlabeled-1.31.4
 * [new branch]          unlabeled-1.32.16           -> refs/west/unlabeled-1.32.16
 * [new branch]          unlabeled-1.32.2            -> refs/west/unlabeled-1.32.2
 * [new branch]          unlabeled-1.35.12           -> refs/west/unlabeled-1.35.12
 * [new branch]          unlabeled-1.38.4            -> refs/west/unlabeled-1.38.4
 * [new branch]          unlabeled-1.39.2            -> refs/west/unlabeled-1.39.2
 * [new branch]          unlabeled-1.44.2            -> refs/west/unlabeled-1.44.2
 * [new branch]          unlabeled-1.44.4            -> refs/west/unlabeled-1.44.4
 * [new branch]          unlabeled-1.45.2            -> refs/west/unlabeled-1.45.2
 * [new branch]          unlabeled-1.45.8            -> refs/west/unlabeled-1.45.8
 * [new branch]          unlabeled-1.46.4            -> refs/west/unlabeled-1.46.4
 * [new branch]          unlabeled-1.48.16           -> refs/west/unlabeled-1.48.16
 * [new branch]          unlabeled-1.5.16            -> refs/west/unlabeled-1.5.16
 * [new branch]          unlabeled-1.5.2             -> refs/west/unlabeled-1.5.2
 * [new branch]          unlabeled-1.50.2            -> refs/west/unlabeled-1.50.2
 * [new branch]          unlabeled-1.50.6            -> refs/west/unlabeled-1.50.6
 * [new branch]          unlabeled-1.52.2            -> refs/west/unlabeled-1.52.2
 * [new branch]          unlabeled-1.53.6            -> refs/west/unlabeled-1.53.6
 * [new branch]          unlabeled-1.54.4            -> refs/west/unlabeled-1.54.4
 * [new branch]          unlabeled-1.64.2            -> refs/west/unlabeled-1.64.2
 * [new branch]          unlabeled-1.65.12           -> refs/west/unlabeled-1.65.12
 * [new branch]          unlabeled-1.65.4            -> refs/west/unlabeled-1.65.4
 * [new branch]          unlabeled-1.66.2            -> refs/west/unlabeled-1.66.2
 * [new branch]          unlabeled-1.69.4            -> refs/west/unlabeled-1.69.4
 * [new branch]          unlabeled-1.74.4            -> refs/west/unlabeled-1.74.4
 * [new branch]          unlabeled-1.75.4            -> refs/west/unlabeled-1.75.4
 * [new branch]          unlabeled-1.8.2             -> refs/west/unlabeled-1.8.2
 * [new branch]          unlabeled-1.81.2            -> refs/west/unlabeled-1.81.2
 * [new branch]          unlabeled-1.83.4            -> refs/west/unlabeled-1.83.4
 * [new branch]          unlabeled-1.86.2            -> refs/west/unlabeled-1.86.2
 * [new branch]          unlabeled-1.88.2            -> refs/west/unlabeled-1.88.2
 * [new branch]          unlabeled-1.90.2            -> refs/west/unlabeled-1.90.2
 * [new branch]          unlabeled-1.90.2.1.4        -> refs/west/unlabeled-1.90.2.1.4
 * [new branch]          unlabeled-1.93.2            -> refs/west/unlabeled-1.93.2
 * [new branch]          vendor                      -> refs/west/vendor
 * [new branch]          x86-more-32                 -> refs/west/x86-more-32
 * [new branch]          zephyr-add-library          -> refs/west/zephyr-add-library
 * [new branch]          zephyr-deprecated           -> refs/west/zephyr-deprecated
 * [new branch]          zephyr-hacks                -> refs/west/zephyr-hacks
 * [new branch]          zephyr-no-posix-define      -> refs/west/zephyr-no-posix-define
 * [new branch]          zephyr-posix                -> refs/west/zephyr-posix
 * [new branch]          zephyr-source               -> refs/west/zephyr-source
 * [new tag]             1.0                         -> 1.0
 * [new tag]             1.0-1                       -> 1.0-1
 * [new tag]             1.1                         -> 1.1
 * [new tag]             1.1-1                       -> 1.1-1
 * [new tag]             1.1-2                       -> 1.1-2
 * [new tag]             1.1.1-1                     -> 1.1.1-1
 * [new tag]             1.2                         -> 1.2
 * [new tag]             1.2-1                       -> 1.2-1
 * [new tag]             1.2.1-1                     -> 1.2.1-1
 * [new tag]             1.3                         -> 1.3
 * [new tag]             1.3-1                       -> 1.3-1
 * [new tag]             1.4                         -> 1.4
 * [new tag]             1.4-1                       -> 1.4-1
 * [new tag]             1.4.1-1                     -> 1.4.1-1
 * [new tag]             1.4.1-2                     -> 1.4.1-2
 * [new tag]             1.4.2-1                     -> 1.4.2-1
 * [new tag]             1.4.2-2                     -> 1.4.2-2
 * [new tag]             1.4.2-3                     -> 1.4.2-3
 * [new tag]             1.4.3-1                     -> 1.4.3-1
 * [new tag]             1.4.4-1                     -> 1.4.4-1
 * [new tag]             1.4.5                       -> 1.4.5
 * [new tag]             1.4.5-1                     -> 1.4.5-1
 * [new tag]             1.4.6                       -> 1.4.6
 * [new tag]             1.4.6-1                     -> 1.4.6-1
 * [new tag]             1.4.7                       -> 1.4.7
 * [new tag]             1.4.7-1                     -> 1.4.7-1
 * [new tag]             1.4.7-2                     -> 1.4.7-2
 * [new tag]             1.5                         -> 1.5
 * [new tag]             1.5-1                       -> 1.5-1
 * [new tag]             1.5.1-1                     -> 1.5.1-1
 * [new tag]             1.5.1-2                     -> 1.5.1-2
 * [new tag]             1.6                         -> 1.6
 * [new tag]             1.6-1                       -> 1.6-1
 * [new tag]             1.6.1-1                     -> 1.6.1-1
 * [new tag]             1.6.2-1                     -> 1.6.2-1
 * [new tag]             1.7                         -> 1.7
 * [new tag]             1.7-1                       -> 1.7-1
 * [new tag]             1.7.1-1                     -> 1.7.1-1
 * [new tag]             1.7.2-1                     -> 1.7.2-1
 * [new tag]             1.7.2-2                     -> 1.7.2-2
 * [new tag]             1.7.3-1                     -> 1.7.3-1
 * [new tag]             1.7.3-2                     -> 1.7.3-2
 * [new tag]             1.7.4-1                     -> 1.7.4-1
 * [new tag]             1.7.5-1                     -> 1.7.5-1
 * [new tag]             1.7.6-1                     -> 1.7.6-1
 * [new tag]             1.7.8                       -> 1.7.8
 * [new tag]             1.7.9                       -> 1.7.9
 * [new tag]             1.8.2                       -> 1.8.2
 * [new tag]             1.8.2-1                     -> 1.8.2-1
 * [new tag]             1.8.4                       -> 1.8.4
 * [new tag]             1.8.6                       -> 1.8.6
 * [new tag]             3.1.0.2019.08.08            -> 3.1.0.2019.08.08
 * [new tag]             3.1.0.2019.08.08-1          -> 3.1.0.2019.08.08-1
 * [new tag]             3.1.0.2019.08.14            -> 3.1.0.2019.08.14
 * [new tag]             3.1.0.2019.08.14-1          -> 3.1.0.2019.08.14-1
 * [new tag]             EOL_registry_mounts         -> EOL_registry_mounts
 * [new tag]             Z-cygwin_daemon_merge-new_HEAD -> Z-cygwin_daemon_merge-new_HEAD
 * [new tag]             Z-cygwin_daemon_merge_HEAD  -> Z-cygwin_daemon_merge_HEAD
 * [new tag]             after-mmap-privanon-noreserve -> after-mmap-privanon-noreserve
 * [new tag]             after-mmap-revamp           -> after-mmap-revamp
 * [new tag]             arc-20081103-branchpoint    -> arc-20081103-branchpoint
 * [new tag]             arc-insight_6_8-branchpoint -> arc-insight_6_8-branchpoint
 * [new tag]             arc-sim-20090309            -> arc-sim-20090309
 * [new tag]             before-mmap-revamp          -> before-mmap-revamp
 * [new tag]             binu_ss_19990502            -> binu_ss_19990502
 * [new tag]             binu_ss_19990602            -> binu_ss_19990602
 * [new tag]             binu_ss_19990721            -> binu_ss_19990721
 * [new tag]             binutils-2_10               -> binutils-2_10
 * [new tag]             binutils-2_10-branchpoint   -> binutils-2_10-branchpoint
 * [new tag]             binutils-2_10_1             -> binutils-2_10_1
 * [new tag]             binutils-2_11               -> binutils-2_11
 * [new tag]             binutils-2_11_1             -> binutils-2_11_1
 * [new tag]             binutils-2_11_2             -> binutils-2_11_2
 * [new tag]             binutils-2_12               -> binutils-2_12
 * [new tag]             binutils-2_12-branchpoint   -> binutils-2_12-branchpoint
 * [new tag]             binutils-2_12_1             -> binutils-2_12_1
 * [new tag]             binutils-2_13               -> binutils-2_13
 * [new tag]             binutils-2_13-branchpoint   -> binutils-2_13-branchpoint
 * [new tag]             binutils-2_13_1             -> binutils-2_13_1
 * [new tag]             binutils-2_13_2             -> binutils-2_13_2
 * [new tag]             binutils-2_13_2_1           -> binutils-2_13_2_1
 * [new tag]             binutils-2_14               -> binutils-2_14
 * [new tag]             binutils-2_14-branchpoint   -> binutils-2_14-branchpoint
 * [new tag]             binutils-2_15               -> binutils-2_15
 * [new tag]             binutils-2_15-branchpoint   -> binutils-2_15-branchpoint
 * [new tag]             binutils-2_16               -> binutils-2_16
 * [new tag]             binutils-2_16-branchpoint   -> binutils-2_16-branchpoint
 * [new tag]             binutils-2_16_1             -> binutils-2_16_1
 * [new tag]             binutils-2_17               -> binutils-2_17
 * [new tag]             binutils-2_17-branchpoint   -> binutils-2_17-branchpoint
 * [new tag]             binutils-2_18               -> binutils-2_18
 * [new tag]             binutils-2_18-branchpoint   -> binutils-2_18-branchpoint
 * [new tag]             binutils-2_19               -> binutils-2_19
 * [new tag]             binutils-2_19-branchpoint   -> binutils-2_19-branchpoint
 * [new tag]             binutils-2_19_1             -> binutils-2_19_1
 * [new tag]             binutils-2_20               -> binutils-2_20
 * [new tag]             binutils-2_20-branchpoint   -> binutils-2_20-branchpoint
 * [new tag]             binutils-2_20_1             -> binutils-2_20_1
 * [new tag]             binutils-2_21               -> binutils-2_21
 * [new tag]             binutils-2_21-branchpoint   -> binutils-2_21-branchpoint
 * [new tag]             binutils-2_21_1             -> binutils-2_21_1
 * [new tag]             binutils-2_22               -> binutils-2_22
 * [new tag]             binutils-2_22-branchpoint   -> binutils-2_22-branchpoint
 * [new tag]             binutils-2_23               -> binutils-2_23
 * [new tag]             binutils-2_23-branchpoint   -> binutils-2_23-branchpoint
 * [new tag]             binutils-2_23_1             -> binutils-2_23_1
 * [new tag]             binutils-2_23_2             -> binutils-2_23_2
 * [new tag]             binutils-2_24-branchpoint   -> binutils-2_24-branchpoint
 * [new tag]             binutils-arc-20080908-branchpoint -> binutils-arc-20080908-branchpoint
 * [new tag]             binutils-arc-20081103-branchpoint -> binutils-arc-20081103-branchpoint
 * [new tag]             binutils-csl-2_17-branchpoint -> binutils-csl-2_17-branchpoint
 * [new tag]             binutils-csl-arm-2005q1-branchpoint -> binutils-csl-arm-2005q1-branchpoint
 * [new tag]             binutils-csl-arm-2005q1a    -> binutils-csl-arm-2005q1a
 * [new tag]             binutils-csl-arm-2005q1b    -> binutils-csl-arm-2005q1b
 * [new tag]             binutils-csl-arm-2006q1-6   -> binutils-csl-arm-2006q1-6
 * [new tag]             binutils-csl-arm-2006q3-19  -> binutils-csl-arm-2006q3-19
 * [new tag]             binutils-csl-arm-2006q3-21  -> binutils-csl-arm-2006q3-21
 * [new tag]             binutils-csl-arm-2006q3-26  -> binutils-csl-arm-2006q3-26
 * [new tag]             binutils-csl-arm-2006q3-27  -> binutils-csl-arm-2006q3-27
 * [new tag]             binutils-csl-coldfire-4_1-10 -> binutils-csl-coldfire-4_1-10
 * [new tag]             binutils-csl-coldfire-4_1-11 -> binutils-csl-coldfire-4_1-11
 * [new tag]             binutils-csl-coldfire-4_1-28 -> binutils-csl-coldfire-4_1-28
 * [new tag]             binutils-csl-coldfire-4_1-30 -> binutils-csl-coldfire-4_1-30
 * [new tag]             binutils-csl-coldfire-4_1-32 -> binutils-csl-coldfire-4_1-32
 * [new tag]             binutils-csl-gxxpro-3_4-branchpoint -> binutils-csl-gxxpro-3_4-branchpoint
 * [new tag]             binutils-csl-innovasic-fido-3_4_4-33 -> binutils-csl-innovasic-fido-3_4_4-33
 * [new tag]             binutils-csl-morpho-4_1-4   -> binutils-csl-morpho-4_1-4
 * [new tag]             binutils-csl-palmsource-arm-prelinker-1_0-1 -> binutils-csl-palmsource-arm-prelinker-1_0-1
 * [new tag]             binutils-csl-renesas-4_1-6  -> binutils-csl-renesas-4_1-6
 * [new tag]             binutils-csl-renesas-4_1-7  -> binutils-csl-renesas-4_1-7
 * [new tag]             binutils-csl-renesas-4_1-8  -> binutils-csl-renesas-4_1-8
 * [new tag]             binutils-csl-renesas-4_1-9  -> binutils-csl-renesas-4_1-9
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-17 -> binutils-csl-sourcerygxx-3_4_4-17
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-19 -> binutils-csl-sourcerygxx-3_4_4-19
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-21 -> binutils-csl-sourcerygxx-3_4_4-21
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-25 -> binutils-csl-sourcerygxx-3_4_4-25
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-32 -> binutils-csl-sourcerygxx-3_4_4-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-12 -> binutils-csl-sourcerygxx-4_1-12
 * [new tag]             binutils-csl-sourcerygxx-4_1-13 -> binutils-csl-sourcerygxx-4_1-13
 * [new tag]             binutils-csl-sourcerygxx-4_1-14 -> binutils-csl-sourcerygxx-4_1-14
 * [new tag]             binutils-csl-sourcerygxx-4_1-15 -> binutils-csl-sourcerygxx-4_1-15
 * [new tag]             binutils-csl-sourcerygxx-4_1-17 -> binutils-csl-sourcerygxx-4_1-17
 * [new tag]             binutils-csl-sourcerygxx-4_1-18 -> binutils-csl-sourcerygxx-4_1-18
 * [new tag]             binutils-csl-sourcerygxx-4_1-19 -> binutils-csl-sourcerygxx-4_1-19
 * [new tag]             binutils-csl-sourcerygxx-4_1-20 -> binutils-csl-sourcerygxx-4_1-20
 * [new tag]             binutils-csl-sourcerygxx-4_1-21 -> binutils-csl-sourcerygxx-4_1-21
 * [new tag]             binutils-csl-sourcerygxx-4_1-22 -> binutils-csl-sourcerygxx-4_1-22
 * [new tag]             binutils-csl-sourcerygxx-4_1-23 -> binutils-csl-sourcerygxx-4_1-23
 * [new tag]             binutils-csl-sourcerygxx-4_1-24 -> binutils-csl-sourcerygxx-4_1-24
 * [new tag]             binutils-csl-sourcerygxx-4_1-25 -> binutils-csl-sourcerygxx-4_1-25
 * [new tag]             binutils-csl-sourcerygxx-4_1-26 -> binutils-csl-sourcerygxx-4_1-26
 * [new tag]             binutils-csl-sourcerygxx-4_1-27 -> binutils-csl-sourcerygxx-4_1-27
 * [new tag]             binutils-csl-sourcerygxx-4_1-28 -> binutils-csl-sourcerygxx-4_1-28
 * [new tag]             binutils-csl-sourcerygxx-4_1-29 -> binutils-csl-sourcerygxx-4_1-29
 * [new tag]             binutils-csl-sourcerygxx-4_1-30 -> binutils-csl-sourcerygxx-4_1-30
 * [new tag]             binutils-csl-sourcerygxx-4_1-32 -> binutils-csl-sourcerygxx-4_1-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-4 -> binutils-csl-sourcerygxx-4_1-4
 * [new tag]             binutils-csl-sourcerygxx-4_1-5 -> binutils-csl-sourcerygxx-4_1-5
 * [new tag]             binutils-csl-sourcerygxx-4_1-6 -> binutils-csl-sourcerygxx-4_1-6
 * [new tag]             binutils-csl-sourcerygxx-4_1-7 -> binutils-csl-sourcerygxx-4_1-7
 * [new tag]             binutils-csl-sourcerygxx-4_1-8 -> binutils-csl-sourcerygxx-4_1-8
 * [new tag]             binutils-csl-sourcerygxx-4_1-9 -> binutils-csl-sourcerygxx-4_1-9
 * [new tag]             binutils-csl-wrs-linux-3_4_4-20 -> binutils-csl-wrs-linux-3_4_4-20
 * [new tag]             binutils-csl-wrs-linux-3_4_4-21 -> binutils-csl-wrs-linux-3_4_4-21
 * [new tag]             binutils-csl-wrs-linux-3_4_4-22 -> binutils-csl-wrs-linux-3_4_4-22
 * [new tag]             binutils-csl-wrs-linux-3_4_4-23 -> binutils-csl-wrs-linux-3_4_4-23
 * [new tag]             binutils-csl-wrs-linux-3_4_4-24 -> binutils-csl-wrs-linux-3_4_4-24
 * [new tag]             binutils_latest_snapshot    -> binutils_latest_snapshot
 * [new tag]             cagney-unwind-20030108-branchpoint -> cagney-unwind-20030108-branchpoint
 * [new tag]             cagney_bfdfile-20040213-branchpoint -> cagney_bfdfile-20040213-branchpoint
 * [new tag]             cagney_bigcore-20040122-branchpoint -> cagney_bigcore-20040122-branchpoint
 * [new tag]             cagney_convert-20030606-branchpoint -> cagney_convert-20030606-branchpoint
 * [new tag]             cagney_fileio-20030521-branchpoint -> cagney_fileio-20030521-branchpoint
 * [new tag]             cagney_frameaddr-20030403-branchpoint -> cagney_frameaddr-20030403-branchpoint
 * [new tag]             cagney_frameaddr-20030409-mergepoint -> cagney_frameaddr-20030409-mergepoint
 * [new tag]             cagney_framebase-20030326-branchpoint -> cagney_framebase-20030326-branchpoint
 * [new tag]             cagney_framebase-20030330-mergepoint -> cagney_framebase-20030330-mergepoint
 * [new tag]             cagney_lazyid-20030317-branchpoint -> cagney_lazyid-20030317-branchpoint
 * [new tag]             cagney_offbyone-20030303-branchpoint -> cagney_offbyone-20030303-branchpoint
 * [new tag]             cagney_regbuf-20020515-branchpoint -> cagney_regbuf-20020515-branchpoint
 * [new tag]             cagney_sysregs-20020825-branchpoint -> cagney_sysregs-20020825-branchpoint
 * [new tag]             cagney_tramp-20040309-branchpoint -> cagney_tramp-20040309-branchpoint
 * [new tag]             cagney_tramp-20040321-mergepoint -> cagney_tramp-20040321-mergepoint
 * [new tag]             cagney_writestrings-20030508-branchpoint -> cagney_writestrings-20030508-branchpoint
 * [new tag]             cagney_x86i386-20030821-branchpoint -> cagney_x86i386-20030821-branchpoint
 * [new tag]             carlton-dictionary-20031111-merge -> carlton-dictionary-20031111-merge
 * [new tag]             carlton_dictionary-20020920-branchpoint -> carlton_dictionary-20020920-branchpoint
 * [new tag]             carlton_dictionary-20020927-merge -> carlton_dictionary-20020927-merge
 * [new tag]             carlton_dictionary-20021011-merge -> carlton_dictionary-20021011-merge
 * [new tag]             carlton_dictionary-20021025-merge -> carlton_dictionary-20021025-merge
 * [new tag]             carlton_dictionary-20021115-merge -> carlton_dictionary-20021115-merge
 * [new tag]             carlton_dictionary-20021223-merge -> carlton_dictionary-20021223-merge
 * [new tag]             carlton_dictionary-20030207-merge -> carlton_dictionary-20030207-merge
 * [new tag]             carlton_dictionary-20030305-merge -> carlton_dictionary-20030305-merge
 * [new tag]             carlton_dictionary-20030416-merge -> carlton_dictionary-20030416-merge
 * [new tag]             carlton_dictionary-20030430-merge -> carlton_dictionary-20030430-merge
 * [new tag]             carlton_dictionary-20030523-merge -> carlton_dictionary-20030523-merge
 * [new tag]             carlton_dictionary-20030627-merge -> carlton_dictionary-20030627-merge
 * [new tag]             carlton_dictionary-20030805-merge -> carlton_dictionary-20030805-merge
 * [new tag]             carlton_dictionary-20030917-merge -> carlton_dictionary-20030917-merge
 * [new tag]             carlton_dictionary-20031215-merge -> carlton_dictionary-20031215-merge
 * [new tag]             carlton_dictionary-20040126-merge -> carlton_dictionary-20040126-merge
 * [new tag]             cgen-1_1-branchpoint        -> cgen-1_1-branchpoint
 * [new tag]             cgen-snapshot-20071001      -> cgen-snapshot-20071001
 * [new tag]             cgen-snapshot-20071101      -> cgen-snapshot-20071101
 * [new tag]             cgen-snapshot-20071201      -> cgen-snapshot-20071201
 * [new tag]             cgen-snapshot-20080101      -> cgen-snapshot-20080101
 * [new tag]             cgen-snapshot-20080201      -> cgen-snapshot-20080201
 * [new tag]             cgen-snapshot-20080301      -> cgen-snapshot-20080301
 * [new tag]             cgen-snapshot-20080401      -> cgen-snapshot-20080401
 * [new tag]             cgen-snapshot-20080501      -> cgen-snapshot-20080501
 * [new tag]             cgen-snapshot-20080601      -> cgen-snapshot-20080601
 * [new tag]             cgen-snapshot-20080701      -> cgen-snapshot-20080701
 * [new tag]             cgen-snapshot-20080801      -> cgen-snapshot-20080801
 * [new tag]             cgen-snapshot-20080901      -> cgen-snapshot-20080901
 * [new tag]             cgen-snapshot-20081001      -> cgen-snapshot-20081001
 * [new tag]             cgen-snapshot-20081101      -> cgen-snapshot-20081101
 * [new tag]             cgen-snapshot-20081201      -> cgen-snapshot-20081201
 * [new tag]             cgen-snapshot-20090101      -> cgen-snapshot-20090101
 * [new tag]             cgen-snapshot-20090201      -> cgen-snapshot-20090201
 * [new tag]             cgen-snapshot-20090301      -> cgen-snapshot-20090301
 * [new tag]             cgen-snapshot-20090401      -> cgen-snapshot-20090401
 * [new tag]             cgen-snapshot-20090501      -> cgen-snapshot-20090501
 * [new tag]             cgen-snapshot-20090601      -> cgen-snapshot-20090601
 * [new tag]             cgen-snapshot-20090701      -> cgen-snapshot-20090701
 * [new tag]             cgen-snapshot-20090801      -> cgen-snapshot-20090801
 * [new tag]             cgen-snapshot-20090901      -> cgen-snapshot-20090901
 * [new tag]             cgen-snapshot-20091001      -> cgen-snapshot-20091001
 * [new tag]             cgen-snapshot-20091101      -> cgen-snapshot-20091101
 * [new tag]             cgen-snapshot-20091201      -> cgen-snapshot-20091201
 * [new tag]             cgen-snapshot-20100101      -> cgen-snapshot-20100101
 * [new tag]             cgen-snapshot-20100201      -> cgen-snapshot-20100201
 * [new tag]             cgen-snapshot-20100301      -> cgen-snapshot-20100301
 * [new tag]             cgen-snapshot-20100401      -> cgen-snapshot-20100401
 * [new tag]             cgen-snapshot-20100501      -> cgen-snapshot-20100501
 * [new tag]             cgen-snapshot-20100601      -> cgen-snapshot-20100601
 * [new tag]             cgen-snapshot-20100701      -> cgen-snapshot-20100701
 * [new tag]             cgen-snapshot-20100801      -> cgen-snapshot-20100801
 * [new tag]             cgen-snapshot-20100901      -> cgen-snapshot-20100901
 * [new tag]             cgen-snapshot-20101001      -> cgen-snapshot-20101001
 * [new tag]             cgen-snapshot-20101101      -> cgen-snapshot-20101101
 * [new tag]             cgen-snapshot-20101201      -> cgen-snapshot-20101201
 * [new tag]             cgen-snapshot-20110101      -> cgen-snapshot-20110101
 * [new tag]             cgen-snapshot-20110201      -> cgen-snapshot-20110201
 * [new tag]             cgen-snapshot-20110301      -> cgen-snapshot-20110301
 * [new tag]             cgen-snapshot-20110401      -> cgen-snapshot-20110401
 * [new tag]             cgen-snapshot-20110501      -> cgen-snapshot-20110501
 * [new tag]             cgen-snapshot-20110601      -> cgen-snapshot-20110601
 * [new tag]             cgen-snapshot-20110701      -> cgen-snapshot-20110701
 * [new tag]             cgen-snapshot-20110801      -> cgen-snapshot-20110801
 * [new tag]             cgen-snapshot-20110901      -> cgen-snapshot-20110901
 * [new tag]             cgen-snapshot-20111001      -> cgen-snapshot-20111001
 * [new tag]             cgen-snapshot-20111101      -> cgen-snapshot-20111101
 * [new tag]             cgen-snapshot-20111201      -> cgen-snapshot-20111201
 * [new tag]             cgen-snapshot-20120101      -> cgen-snapshot-20120101
 * [new tag]             cgen-snapshot-20120201      -> cgen-snapshot-20120201
 * [new tag]             cgen-snapshot-20120301      -> cgen-snapshot-20120301
 * [new tag]             cgen-snapshot-20120401      -> cgen-snapshot-20120401
 * [new tag]             cgen-snapshot-20120501      -> cgen-snapshot-20120501
 * [new tag]             cgen-snapshot-20120601      -> cgen-snapshot-20120601
 * [new tag]             cgen-snapshot-20120701      -> cgen-snapshot-20120701
 * [new tag]             cgen-snapshot-20120801      -> cgen-snapshot-20120801
 * [new tag]             cgen-snapshot-20120901      -> cgen-snapshot-20120901
 * [new tag]             cgen-snapshot-20121001      -> cgen-snapshot-20121001
 * [new tag]             cgen-snapshot-20121101      -> cgen-snapshot-20121101
 * [new tag]             cgen-snapshot-20121201      -> cgen-snapshot-20121201
 * [new tag]             cgen-snapshot-20130101      -> cgen-snapshot-20130101
 * [new tag]             cgen-snapshot-20130201      -> cgen-snapshot-20130201
 * [new tag]             cgen-snapshot-20130301      -> cgen-snapshot-20130301
 * [new tag]             cgen-snapshot-20130401      -> cgen-snapshot-20130401
 * [new tag]             cgen-snapshot-20130501      -> cgen-snapshot-20130501
 * [new tag]             cgen-snapshot-20130601      -> cgen-snapshot-20130601
 * [new tag]             cgen-snapshot-20130701      -> cgen-snapshot-20130701
 * [new tag]             cgen-snapshot-20130801      -> cgen-snapshot-20130801
 * [new tag]             cgen-snapshot-20130901      -> cgen-snapshot-20130901
 * [new tag]             cgen-snapshot-20131001      -> cgen-snapshot-20131001
 * [new tag]             cgen-snapshot-20131101      -> cgen-snapshot-20131101
 * [new tag]             cgen-snapshot-20131201      -> cgen-snapshot-20131201
 * [new tag]             cgen-snapshot-20140101      -> cgen-snapshot-20140101
 * [new tag]             cgen-snapshot-20140201      -> cgen-snapshot-20140201
 * [new tag]             cgen-snapshot-20140301      -> cgen-snapshot-20140301
 * [new tag]             cgen-snapshot-20140401      -> cgen-snapshot-20140401
 * [new tag]             cgen-snapshot-20140501      -> cgen-snapshot-20140501
 * [new tag]             cgen-snapshot-20140601      -> cgen-snapshot-20140601
 * [new tag]             cgen-snapshot-20140701      -> cgen-snapshot-20140701
 * [new tag]             cgen-snapshot-20140801      -> cgen-snapshot-20140801
 * [new tag]             cgen-snapshot-20140901      -> cgen-snapshot-20140901
 * [new tag]             cgen-snapshot-20141001      -> cgen-snapshot-20141001
 * [new tag]             cgen-snapshot-20141101      -> cgen-snapshot-20141101
 * [new tag]             cgen-snapshot-20141201      -> cgen-snapshot-20141201
 * [new tag]             cgen-snapshot-20150101      -> cgen-snapshot-20150101
 * [new tag]             cgen-snapshot-20150201      -> cgen-snapshot-20150201
 * [new tag]             cgen-snapshot-20150301      -> cgen-snapshot-20150301
 * [new tag]             cgf-more-exit-sync          -> cgf-more-exit-sync
 * [new tag]             corinna-01                  -> corinna-01
 * [new tag]             cr-0x99                     -> cr-0x99
 * [new tag]             csl-arm-2003-q4             -> csl-arm-2003-q4
 * [new tag]             csl-arm-2004-q1             -> csl-arm-2004-q1
 * [new tag]             csl-arm-2004-q1a            -> csl-arm-2004-q1a
 * [new tag]             csl-arm-2004-q3             -> csl-arm-2004-q3
 * [new tag]             csl-arm-2004-q3d            -> csl-arm-2004-q3d
 * [new tag]             csl-arm-20050325-branchpoint -> csl-arm-20050325-branchpoint
 * [new tag]             cygnus_cvs_20020108_pre     -> cygnus_cvs_20020108_pre
 * [new tag]             cygwin-1-1-5                -> cygwin-1-1-5
 * [new tag]             cygwin-1-1-6                -> cygwin-1-1-6
 * [new tag]             cygwin-1-1-7                -> cygwin-1-1-7
 * [new tag]             cygwin-1-1-8                -> cygwin-1-1-8
 * [new tag]             cygwin-1-3-19-1-branchpoint -> cygwin-1-3-19-1-branchpoint
 * [new tag]             cygwin-1_1_1                -> cygwin-1_1_1
 * [new tag]             cygwin-1_7_1-release        -> cygwin-1_7_1-release
 * [new tag]             cygwin-1_7_10-release       -> cygwin-1_7_10-release
 * [new tag]             cygwin-1_7_11-release       -> cygwin-1_7_11-release
 * [new tag]             cygwin-1_7_12-release       -> cygwin-1_7_12-release
 * [new tag]             cygwin-1_7_14-release       -> cygwin-1_7_14-release
 * [new tag]             cygwin-1_7_14_2-release     -> cygwin-1_7_14_2-release
 * [new tag]             cygwin-1_7_15-release       -> cygwin-1_7_15-release
 * [new tag]             cygwin-1_7_16-release       -> cygwin-1_7_16-release
 * [new tag]             cygwin-1_7_17-release       -> cygwin-1_7_17-release
 * [new tag]             cygwin-1_7_18-release       -> cygwin-1_7_18-release
 * [new tag]             cygwin-1_7_19-release       -> cygwin-1_7_19-release
 * [new tag]             cygwin-1_7_2-release        -> cygwin-1_7_2-release
 * [new tag]             cygwin-1_7_20-release       -> cygwin-1_7_20-release
 * [new tag]             cygwin-1_7_21-release       -> cygwin-1_7_21-release
 * [new tag]             cygwin-1_7_22-release       -> cygwin-1_7_22-release
 * [new tag]             cygwin-1_7_23-release       -> cygwin-1_7_23-release
 * [new tag]             cygwin-1_7_24-release       -> cygwin-1_7_24-release
 * [new tag]             cygwin-1_7_25-release       -> cygwin-1_7_25-release
 * [new tag]             cygwin-1_7_26-release       -> cygwin-1_7_26-release
 * [new tag]             cygwin-1_7_27-release       -> cygwin-1_7_27-release
 * [new tag]             cygwin-1_7_28-release       -> cygwin-1_7_28-release
 * [new tag]             cygwin-1_7_29-release       -> cygwin-1_7_29-release
 * [new tag]             cygwin-1_7_3-release        -> cygwin-1_7_3-release
 * [new tag]             cygwin-1_7_30-release       -> cygwin-1_7_30-release
 * [new tag]             cygwin-1_7_31-release       -> cygwin-1_7_31-release
 * [new tag]             cygwin-1_7_32-release       -> cygwin-1_7_32-release
 * [new tag]             cygwin-1_7_33-release       -> cygwin-1_7_33-release
 * [new tag]             cygwin-1_7_34-release       -> cygwin-1_7_34-release
 * [new tag]             cygwin-1_7_35-release       -> cygwin-1_7_35-release
 * [new tag]             cygwin-1_7_4-release        -> cygwin-1_7_4-release
 * [new tag]             cygwin-1_7_5-release        -> cygwin-1_7_5-release
 * [new tag]             cygwin-1_7_7-release        -> cygwin-1_7_7-release
 * [new tag]             cygwin-1_7_8-release        -> cygwin-1_7_8-release
 * [new tag]             cygwin-1_7_9-release        -> cygwin-1_7_9-release
 * [new tag]             cygwin-2_0_0-release        -> cygwin-2_0_0-release
 * [new tag]             cygwin-2_0_1-release        -> cygwin-2_0_1-release
 * [new tag]             cygwin-2_0_2-release        -> cygwin-2_0_2-release
 * [new tag]             cygwin-2_0_3-release        -> cygwin-2_0_3-release
 * [new tag]             cygwin-2_0_4-release        -> cygwin-2_0_4-release
 * [new tag]             cygwin-2_10_0-release       -> cygwin-2_10_0-release
 * [new tag]             cygwin-2_11_0-release       -> cygwin-2_11_0-release
 * [new tag]             cygwin-2_11_1-release       -> cygwin-2_11_1-release
 * [new tag]             cygwin-2_11_2-release       -> cygwin-2_11_2-release
 * [new tag]             cygwin-2_1_0-release        -> cygwin-2_1_0-release
 * [new tag]             cygwin-2_2_0-release        -> cygwin-2_2_0-release
 * [new tag]             cygwin-2_2_1-release        -> cygwin-2_2_1-release
 * [new tag]             cygwin-2_3_0-release        -> cygwin-2_3_0-release
 * [new tag]             cygwin-2_3_1-relase         -> cygwin-2_3_1-relase
 * [new tag]             cygwin-2_3_1-release        -> cygwin-2_3_1-release
 * [new tag]             cygwin-2_4_0-release        -> cygwin-2_4_0-release
 * [new tag]             cygwin-2_4_1-release        -> cygwin-2_4_1-release
 * [new tag]             cygwin-2_5_0-release        -> cygwin-2_5_0-release
 * [new tag]             cygwin-2_5_1-release        -> cygwin-2_5_1-release
 * [new tag]             cygwin-2_5_2-release        -> cygwin-2_5_2-release
 * [new tag]             cygwin-2_6_0-release        -> cygwin-2_6_0-release
 * [new tag]             cygwin-2_6_1-release        -> cygwin-2_6_1-release
 * [new tag]             cygwin-2_7_0-release        -> cygwin-2_7_0-release
 * [new tag]             cygwin-2_8_0-release        -> cygwin-2_8_0-release
 * [new tag]             cygwin-2_8_1-release        -> cygwin-2_8_1-release
 * [new tag]             cygwin-2_8_2-release        -> cygwin-2_8_2-release
 * [new tag]             cygwin-2_9_0-release        -> cygwin-2_9_0-release
 * [new tag]             cygwin-3_0_0-release        -> cygwin-3_0_0-release
 * [new tag]             cygwin-3_0_1-release        -> cygwin-3_0_1-release
 * [new tag]             cygwin-3_0_2-release        -> cygwin-3_0_2-release
 * [new tag]             cygwin-3_0_3-release        -> cygwin-3_0_3-release
 * [new tag]             cygwin-3_0_4-release        -> cygwin-3_0_4-release
 * [new tag]             cygwin-3_0_5-release        -> cygwin-3_0_5-release
 * [new tag]             cygwin-3_0_6-release        -> cygwin-3_0_6-release
 * [new tag]             cygwin-3_0_7-release        -> cygwin-3_0_7-release
 * [new tag]             cygwin-3_1_0-release        -> cygwin-3_1_0-release
 * [new tag]             cygwin-3_1_1-release        -> cygwin-3_1_1-release
 * [new tag]             cygwin-3_1_2-release        -> cygwin-3_1_2-release
 * [new tag]             cygwin-3_1_3-release        -> cygwin-3_1_3-release
 * [new tag]             cygwin-3_1_4-release        -> cygwin-3_1_4-release
 * [new tag]             cygwin-64bit-postmerge      -> cygwin-64bit-postmerge
 * [new tag]             cygwin-64bit-premerge       -> cygwin-64bit-premerge
 * [new tag]             cygwin-pre-user-db          -> cygwin-pre-user-db
 * [new tag]             cygwin_daemon_merge_HEAD    -> cygwin_daemon_merge_HEAD
 * [new tag]             debian-2.10.0-1             -> debian-2.10.0-1
 * [new tag]             dje-cgen-play1-branchpoint  -> dje-cgen-play1-branchpoint
 * [new tag]             drop_9x_support_start       -> drop_9x_support_start
 * [new tag]             drow-cplus-branchpoint      -> drow-cplus-branchpoint
 * [new tag]             drow-cplus-merge-20021020   -> drow-cplus-merge-20021020
 * [new tag]             drow-cplus-merge-20021025   -> drow-cplus-merge-20021025
 * [new tag]             drow-cplus-merge-20031214   -> drow-cplus-merge-20031214
 * [new tag]             drow-cplus-merge-20031220   -> drow-cplus-merge-20031220
 * [new tag]             drow-cplus-merge-20031224   -> drow-cplus-merge-20031224
 * [new tag]             drow-cplus-merge-20040113   -> drow-cplus-merge-20040113
 * [new tag]             drow-cplus-merge-20040208   -> drow-cplus-merge-20040208
 * [new tag]             drow-reverse-20070409-branchpoint -> drow-reverse-20070409-branchpoint
 * [new tag]             drow_intercu-20040221-branchpoint -> drow_intercu-20040221-branchpoint
 * [new tag]             drow_intercu-merge-20040327 -> drow_intercu-merge-20040327
 * [new tag]             drow_intercu-merge-20040402 -> drow_intercu-merge-20040402
 * [new tag]             drow_intercu-merge-20040915 -> drow_intercu-merge-20040915
 * [new tag]             drow_intercu-merge-20040921 -> drow_intercu-merge-20040921
 * [new tag]             egcs_20000222               -> egcs_20000222
 * [new tag]             ezannoni_pie-20030916-branchpoint -> ezannoni_pie-20030916-branchpoint
 * [new tag]             ezannoni_pie-20040323-branchpoint -> ezannoni_pie-20040323-branchpoint
 * [new tag]             gdb-csl-20060226-branch-local-2 -> gdb-csl-20060226-branch-local-2
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-local-1 -> gdb-csl-20060226-branch-merge-to-csl-local-1
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-symbian-1 -> gdb-csl-20060226-branch-merge-to-csl-symbian-1
 * [new tag]             gdb-csl-20060226-branchpoint -> gdb-csl-20060226-branchpoint
 * [new tag]             gdb-csl-arm-20050325-2005-q1a -> gdb-csl-arm-20050325-2005-q1a
 * [new tag]             gdb-csl-arm-20050325-2005-q1b -> gdb-csl-arm-20050325-2005-q1b
 * [new tag]             gdb-csl-arm-20051020-branchpoint -> gdb-csl-arm-20051020-branchpoint
 * [new tag]             gdb-csl-arm-2006q1-6        -> gdb-csl-arm-2006q1-6
 * [new tag]             gdb-csl-available-20060303-branchpoint -> gdb-csl-available-20060303-branchpoint
 * [new tag]             gdb-csl-coldfire-4_1-10     -> gdb-csl-coldfire-4_1-10
 * [new tag]             gdb-csl-coldfire-4_1-11     -> gdb-csl-coldfire-4_1-11
 * [new tag]             gdb-csl-gxxpro-6_3-branchpoint -> gdb-csl-gxxpro-6_3-branchpoint
 * [new tag]             gdb-csl-morpho-4_1-4        -> gdb-csl-morpho-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-17 -> gdb-csl-sourcerygxx-3_4_4-17
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-19 -> gdb-csl-sourcerygxx-3_4_4-19
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-21 -> gdb-csl-sourcerygxx-3_4_4-21
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-25 -> gdb-csl-sourcerygxx-3_4_4-25
 * [new tag]             gdb-csl-sourcerygxx-4_1-12  -> gdb-csl-sourcerygxx-4_1-12
 * [new tag]             gdb-csl-sourcerygxx-4_1-13  -> gdb-csl-sourcerygxx-4_1-13
 * [new tag]             gdb-csl-sourcerygxx-4_1-14  -> gdb-csl-sourcerygxx-4_1-14
 * [new tag]             gdb-csl-sourcerygxx-4_1-17  -> gdb-csl-sourcerygxx-4_1-17
 * [new tag]             gdb-csl-sourcerygxx-4_1-4   -> gdb-csl-sourcerygxx-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-4_1-5   -> gdb-csl-sourcerygxx-4_1-5
 * [new tag]             gdb-csl-sourcerygxx-4_1-6   -> gdb-csl-sourcerygxx-4_1-6
 * [new tag]             gdb-csl-sourcerygxx-4_1-7   -> gdb-csl-sourcerygxx-4_1-7
 * [new tag]             gdb-csl-sourcerygxx-4_1-8   -> gdb-csl-sourcerygxx-4_1-8
 * [new tag]             gdb-csl-sourcerygxx-4_1-9   -> gdb-csl-sourcerygxx-4_1-9
 * [new tag]             gdb-csl-symbian-20060226-branchpoint -> gdb-csl-symbian-20060226-branchpoint
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-10 -> gdb-csl-symbian-6_4_50_20060226-10
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-11 -> gdb-csl-symbian-6_4_50_20060226-11
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-12 -> gdb-csl-symbian-6_4_50_20060226-12
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-8 -> gdb-csl-symbian-6_4_50_20060226-8
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-9 -> gdb-csl-symbian-6_4_50_20060226-9
 * [new tag]             gdb-premipsmulti-2000-06-06-branchpoint -> gdb-premipsmulti-2000-06-06-branchpoint
 * [new tag]             gdb_4_18_2-2000-05-18-release -> gdb_4_18_2-2000-05-18-release
 * [new tag]             gdb_4_95_0-2000-04-27-snapshot -> gdb_4_95_0-2000-04-27-snapshot
 * [new tag]             gdb_4_95_1-2000-05-11-snapshot -> gdb_4_95_1-2000-05-11-snapshot
 * [new tag]             gdb_5_0-2000-04-10-branchpoint -> gdb_5_0-2000-04-10-branchpoint
 * [new tag]             gdb_5_0-2000-05-19-release  -> gdb_5_0-2000-05-19-release
 * [new tag]             gdb_5_1-2001-07-29-branchpoint -> gdb_5_1-2001-07-29-branchpoint
 * [new tag]             gdb_5_1-2001-11-21-release  -> gdb_5_1-2001-11-21-release
 * [new tag]             gdb_5_1_0_1-2002-01-03-branchpoint -> gdb_5_1_0_1-2002-01-03-branchpoint
 * [new tag]             gdb_5_1_0_1-2002-01-03-release -> gdb_5_1_0_1-2002-01-03-release
 * [new tag]             gdb_5_1_1-2002-01-24-release -> gdb_5_1_1-2002-01-24-release
 * [new tag]             gdb_5_2-2002-03-03-branchpoint -> gdb_5_2-2002-03-03-branchpoint
 * [new tag]             gdb_5_2-2002-04-29-release  -> gdb_5_2-2002-04-29-release
 * [new tag]             gdb_5_2_1-2002-07-23-release -> gdb_5_2_1-2002-07-23-release
 * [new tag]             gdb_5_3-2002-09-04-branchpoint -> gdb_5_3-2002-09-04-branchpoint
 * [new tag]             gdb_5_3-2002-12-12-release  -> gdb_5_3-2002-12-12-release
 * [new tag]             gdb_6_0-2003-06-23-branchpoint -> gdb_6_0-2003-06-23-branchpoint
 * [new tag]             gdb_6_0-2003-10-04-release  -> gdb_6_0-2003-10-04-release
 * [new tag]             gdb_6_1-2004-03-01-gmt-branchpoint -> gdb_6_1-2004-03-01-gmt-branchpoint
 * [new tag]             gdb_6_1-2004-04-05-release  -> gdb_6_1-2004-04-05-release
 * [new tag]             gdb_6_1_1-20040616-release  -> gdb_6_1_1-20040616-release
 * [new tag]             gdb_6_2-2004-07-10-gmt-branchpoint -> gdb_6_2-2004-07-10-gmt-branchpoint
 * [new tag]             gdb_6_2-20040730-release    -> gdb_6_2-20040730-release
 * [new tag]             gdb_6_3-20041019-branchpoint -> gdb_6_3-20041019-branchpoint
 * [new tag]             gdb_6_3-20041109-release    -> gdb_6_3-20041109-release
 * [new tag]             gdb_6_4-2005-11-01-branchpoint -> gdb_6_4-2005-11-01-branchpoint
 * [new tag]             gdb_6_4-20051202-release    -> gdb_6_4-20051202-release
 * [new tag]             gdb_6_5-2006-05-14-branchpoint -> gdb_6_5-2006-05-14-branchpoint
 * [new tag]             gdb_6_5-20060621-release    -> gdb_6_5-20060621-release
 * [new tag]             gdb_6_6-2006-11-15-branchpoint -> gdb_6_6-2006-11-15-branchpoint
 * [new tag]             gdb_6_6-2006-12-18-release  -> gdb_6_6-2006-12-18-release
 * [new tag]             gdb_6_7-2007-09-07-branchpoint -> gdb_6_7-2007-09-07-branchpoint
 * [new tag]             gdb_6_7-2007-10-10-release  -> gdb_6_7-2007-10-10-release
 * [new tag]             gdb_6_7_1-2007-10-29-release -> gdb_6_7_1-2007-10-29-release
 * [new tag]             gdb_6_8-2008-02-26-branchpoint -> gdb_6_8-2008-02-26-branchpoint
 * [new tag]             gdb_6_8-2008-03-27-release  -> gdb_6_8-2008-03-27-release
 * [new tag]             gdb_7_0-2009-09-16-branchpoint -> gdb_7_0-2009-09-16-branchpoint
 * [new tag]             gdb_7_0-2009-10-06-release  -> gdb_7_0-2009-10-06-release
 * [new tag]             gdb_7_0_1-2009-12-22-release -> gdb_7_0_1-2009-12-22-release
 * [new tag]             gdb_7_1-2010-02-18-branchpoint -> gdb_7_1-2010-02-18-branchpoint
 * [new tag]             gdb_7_1-2010-03-18-release  -> gdb_7_1-2010-03-18-release
 * [new tag]             gdb_7_2-2010-07-07-branchpoint -> gdb_7_2-2010-07-07-branchpoint
 * [new tag]             gdb_7_2-2010-09-02-release  -> gdb_7_2-2010-09-02-release
 * [new tag]             gdb_7_3-2011-04-01-branchpoint -> gdb_7_3-2011-04-01-branchpoint
 * [new tag]             gdb_7_3-2011-07-26-release  -> gdb_7_3-2011-07-26-release
 * [new tag]             gdb_7_3_1-2011-09-04-release -> gdb_7_3_1-2011-09-04-release
 * [new tag]             gdb_7_4-2011-12-13-branchpoint -> gdb_7_4-2011-12-13-branchpoint
 * [new tag]             gdb_7_4-2012-01-24-release  -> gdb_7_4-2012-01-24-release
 * [new tag]             gdb_7_4_1-2012-04-26-release -> gdb_7_4_1-2012-04-26-release
 * [new tag]             gdb_7_5-2012-07-18-branchpoint -> gdb_7_5-2012-07-18-branchpoint
 * [new tag]             gdb_7_5-2012-08-17-release  -> gdb_7_5-2012-08-17-release
 * [new tag]             gdb_7_5_1-2012-11-29-release -> gdb_7_5_1-2012-11-29-release
 * [new tag]             gdb_7_6-2013-03-12-branchpoint -> gdb_7_6-2013-03-12-branchpoint
 * [new tag]             gdb_7_6-2013-04-26-release  -> gdb_7_6-2013-04-26-release
 * [new tag]             gdb_7_6_1-2013-08-30-release -> gdb_7_6_1-2013-08-30-release
 * [new tag]             gdb_s390-2001-09-26-branchpoint -> gdb_s390-2001-09-26-branchpoint
 * [new tag]             hmm                         -> hmm
 * [new tag]             insight-precleanup-2001-01-01 -> insight-precleanup-2001-01-01
 * [new tag]             insight_6_5-20061003-release -> insight_6_5-20061003-release
 * [new tag]             insight_6_6-20070208-release -> insight_6_6-20070208-release
 * [new tag]             insight_6_8-branchpoint     -> insight_6_8-branchpoint
 * [new tag]             interps-20030202-branchpoint -> interps-20030202-branchpoint
 * [new tag]             jimb-gdb_6_2-e500-branchpoint -> jimb-gdb_6_2-e500-branchpoint
 * [new tag]             jimb-macro-020506-branchpoint -> jimb-macro-020506-branchpoint
 * [new tag]             jimb-ppc64-linux-20030509-branchpoint -> jimb-ppc64-linux-20030509-branchpoint
 * [new tag]             jimb-ppc64-linux-20030528-branchpoint -> jimb-ppc64-linux-20030528-branchpoint
 * [new tag]             jimb-ppc64-linux-20030613-branchpoint -> jimb-ppc64-linux-20030613-branchpoint
 * [new tag]             jimb-rda-nptl-branchpoint   -> jimb-rda-nptl-branchpoint
 * [new tag]             kettenis-i386newframe-20030308-branchpoint -> kettenis-i386newframe-20030308-branchpoint
 * [new tag]             kettenis-i386newframe-20030316-mergepoint -> kettenis-i386newframe-20030316-mergepoint
 * [new tag]             kettenis_i386newframe-20030406-branchpoint -> kettenis_i386newframe-20030406-branchpoint
 * [new tag]             kettenis_i386newframe-20030419-branchpoint -> kettenis_i386newframe-20030419-branchpoint
 * [new tag]             kettenis_i386newframe-20030504-mergepoint -> kettenis_i386newframe-20030504-mergepoint
 * [new tag]             kettenis_i386newframe-20030517-mergepoint -> kettenis_i386newframe-20030517-mergepoint
 * [new tag]             kettenis_sparc-20030918-branchpoint -> kettenis_sparc-20030918-branchpoint
 * [new tag]             kseitz_interps-20020528-branchpoint -> kseitz_interps-20020528-branchpoint
 * [new tag]             kseitz_interps-20020829-merge -> kseitz_interps-20020829-merge
 * [new tag]             kseitz_interps-20020930-merge -> kseitz_interps-20020930-merge
 * [new tag]             kseitz_interps-20021103-merge -> kseitz_interps-20021103-merge
 * [new tag]             kseitz_interps-20021105-merge -> kseitz_interps-20021105-merge
 * [new tag]             mingw-runtime-2_0           -> mingw-runtime-2_0
 * [new tag]             mingw-runtime-2_4           -> mingw-runtime-2_4
 * [new tag]             msnyder-checkpoint-072509-branchpoint -> msnyder-checkpoint-072509-branchpoint
 * [new tag]             msnyder-fork-checkpoint-branchpoint -> msnyder-fork-checkpoint-branchpoint
 * [new tag]             msnyder-reverse-20060331-branchpoint -> msnyder-reverse-20060331-branchpoint
 * [new tag]             msnyder-reverse-20060502-branchpoint -> msnyder-reverse-20060502-branchpoint
 * [new tag]             msnyder-reverse-20080609-branchpoint -> msnyder-reverse-20080609-branchpoint
 * [new tag]             msnyder-tracepoint-checkpoint-branchpoint -> msnyder-tracepoint-checkpoint-branchpoint
 * [new tag]             multiprocess-20081120-branchpoint -> multiprocess-20081120-branchpoint
 * [new tag]             newlib-1_10_0               -> newlib-1_10_0
 * [new tag]             newlib-1_11_0               -> newlib-1_11_0
 * [new tag]             newlib-1_12_0               -> newlib-1_12_0
 * [new tag]             newlib-1_13_0               -> newlib-1_13_0
 * [new tag]             newlib-1_14_0               -> newlib-1_14_0
 * [new tag]             newlib-1_15_0               -> newlib-1_15_0
 * [new tag]             newlib-1_16_0               -> newlib-1_16_0
 * [new tag]             newlib-1_17_0               -> newlib-1_17_0
 * [new tag]             newlib-1_18_0               -> newlib-1_18_0
 * [new tag]             newlib-1_19_0               -> newlib-1_19_0
 * [new tag]             newlib-1_20_0               -> newlib-1_20_0
 * [new tag]             newlib-1_9_0                -> newlib-1_9_0
 * [new tag]             newlib-2000-02-17           -> newlib-2000-02-17
 * [new tag]             newlib-2_0_0                -> newlib-2_0_0
 * [new tag]             newlib-2_1_0                -> newlib-2_1_0
 * [new tag]             newlib-2_2_0                -> newlib-2_2_0
 * [new tag]             newlib-2_3_0                -> newlib-2_3_0
 * [new tag]             newlib-2_4_0                -> newlib-2_4_0
 * [new tag]             newlib-2_5_0                -> newlib-2_5_0
 * [new tag]             newlib-3.0.0                -> newlib-3.0.0
 * [new tag]             newlib-3.1.0                -> newlib-3.1.0
 * [new tag]             newlib-3.2.0                -> newlib-3.2.0
 * [new tag]             newlib-3.3.0                -> newlib-3.3.0
 * [new tag]             newlib-csl-20060320-branchpoint -> newlib-csl-20060320-branchpoint
 * [new tag]             newlib-csl-arm-2005-q1a     -> newlib-csl-arm-2005-q1a
 * [new tag]             newlib-csl-arm-2005-q1b     -> newlib-csl-arm-2005-q1b
 * [new tag]             newlib-csl-arm-2006q1-6     -> newlib-csl-arm-2006q1-6
 * [new tag]             newlib-csl-arm-2006q3-19    -> newlib-csl-arm-2006q3-19
 * [new tag]             newlib-csl-arm-2006q3-21    -> newlib-csl-arm-2006q3-21
 * [new tag]             newlib-csl-arm-2006q3-26    -> newlib-csl-arm-2006q3-26
 * [new tag]             newlib-csl-arm-2006q3-27    -> newlib-csl-arm-2006q3-27
 * [new tag]             newlib-csl-coldfire-4_1-28  -> newlib-csl-coldfire-4_1-28
 * [new tag]             newlib-csl-coldfire-4_1-30  -> newlib-csl-coldfire-4_1-30
 * [new tag]             newlib-csl-coldfire-4_1-32  -> newlib-csl-coldfire-4_1-32
 * [new tag]             newlib-csl-innovasic-fido-3_4_4-33 -> newlib-csl-innovasic-fido-3_4_4-33
 * [new tag]             newlib-csl-sourcerygxx-3_4_4-25 -> newlib-csl-sourcerygxx-3_4_4-25
 * [new tag]             newlib-csl-sourcerygxx-4_1-12 -> newlib-csl-sourcerygxx-4_1-12
 * [new tag]             newlib-csl-sourcerygxx-4_1-13 -> newlib-csl-sourcerygxx-4_1-13
 * [new tag]             newlib-csl-sourcerygxx-4_1-14 -> newlib-csl-sourcerygxx-4_1-14
 * [new tag]             newlib-csl-sourcerygxx-4_1-17 -> newlib-csl-sourcerygxx-4_1-17
 * [new tag]             newlib-csl-sourcerygxx-4_1-18 -> newlib-csl-sourcerygxx-4_1-18
 * [new tag]             newlib-csl-sourcerygxx-4_1-19 -> newlib-csl-sourcerygxx-4_1-19
 * [new tag]             newlib-csl-sourcerygxx-4_1-21 -> newlib-csl-sourcerygxx-4_1-21
 * [new tag]             newlib-csl-sourcerygxx-4_1-23 -> newlib-csl-sourcerygxx-4_1-23
 * [new tag]             newlib-csl-sourcerygxx-4_1-24 -> newlib-csl-sourcerygxx-4_1-24
 * [new tag]             newlib-csl-sourcerygxx-4_1-26 -> newlib-csl-sourcerygxx-4_1-26
 * [new tag]             newlib-csl-sourcerygxx-4_1-27 -> newlib-csl-sourcerygxx-4_1-27
 * [new tag]             newlib-csl-sourcerygxx-4_1-28 -> newlib-csl-sourcerygxx-4_1-28
 * [new tag]             newlib-csl-sourcerygxx-4_1-30 -> newlib-csl-sourcerygxx-4_1-30
 * [new tag]             newlib-csl-sourcerygxx-4_1-32 -> newlib-csl-sourcerygxx-4_1-32
 * [new tag]             newlib-csl-sourcerygxx-4_1-4 -> newlib-csl-sourcerygxx-4_1-4
 * [new tag]             newlib-csl-sourcerygxx-4_1-5 -> newlib-csl-sourcerygxx-4_1-5
 * [new tag]             newlib-csl-sourcerygxx-4_1-6 -> newlib-csl-sourcerygxx-4_1-6
 * [new tag]             newlib-csl-sourcerygxx-4_1-7 -> newlib-csl-sourcerygxx-4_1-7
 * [new tag]             newlib-csl-sourcerygxx-4_1-8 -> newlib-csl-sourcerygxx-4_1-8
 * [new tag]             newlib-csl-sourcerygxx-4_1-9 -> newlib-csl-sourcerygxx-4_1-9
 * [new tag]             newlib-snapshot-20150323    -> newlib-snapshot-20150323
 * [new tag]             newlib-snapshot-20150423    -> newlib-snapshot-20150423
 * [new tag]             newlib-snapshot-20150526    -> newlib-snapshot-20150526
 * [new tag]             newlib-snapshot-20150623    -> newlib-snapshot-20150623
 * [new tag]             newlib-snapshot-20150723    -> newlib-snapshot-20150723
 * [new tag]             newlib-snapshot-20150824    -> newlib-snapshot-20150824
 * [new tag]             newlib-snapshot-20150924    -> newlib-snapshot-20150924
 * [new tag]             newlib-snapshot-20151023    -> newlib-snapshot-20151023
 * [new tag]             newlib-snapshot-20160104    -> newlib-snapshot-20160104
 * [new tag]             newlib-snapshot-20160226    -> newlib-snapshot-20160226
 * [new tag]             newlib-snapshot-20160527    -> newlib-snapshot-20160527
 * [new tag]             newlib-snapshot-20160923    -> newlib-snapshot-20160923
 * [new tag]             newlib-snapshot-20170228    -> newlib-snapshot-20170228
 * [new tag]             newlib-snapshot-20170323    -> newlib-snapshot-20170323
 * [new tag]             newlib-snapshot-20170421    -> newlib-snapshot-20170421
 * [new tag]             newlib-snapshot-20170519    -> newlib-snapshot-20170519
 * [new tag]             newlib-snapshot-20170623    -> newlib-snapshot-20170623
 * [new tag]             newlib-snapshot-20170720    -> newlib-snapshot-20170720
 * [new tag]             newlib-snapshot-20170818    -> newlib-snapshot-20170818
 * [new tag]             newlib-snapshot-20170922    -> newlib-snapshot-20170922
 * [new tag]             newlib-snapshot-20171222    -> newlib-snapshot-20171222
 * [new tag]             newlib-snapshot-20180118    -> newlib-snapshot-20180118
 * [new tag]             newlib-snapshot-20180226    -> newlib-snapshot-20180226
 * [new tag]             newlib-snapshot-20180720    -> newlib-snapshot-20180720
 * [new tag]             newlib-snapshot-20180802    -> newlib-snapshot-20180802
 * [new tag]             newlib-snapshot-20180831    -> newlib-snapshot-20180831
 * [new tag]             newlib-snapshot-20181231    -> newlib-snapshot-20181231
 * [new tag]             newlib-snapshot-20200102    -> newlib-snapshot-20200102
 * [new tag]             nickrob-async-20060513-branchpoint -> nickrob-async-20060513-branchpoint
 * [new tag]             nickrob-async-20060828-mergepoint -> nickrob-async-20060828-mergepoint
 * [new tag]             offbyone-20030313-branchpoint -> offbyone-20030313-branchpoint
 * [new tag]             post-ptmalloc3              -> post-ptmalloc3
 * [new tag]             post_wait_sig_exit          -> post_wait_sig_exit
 * [new tag]             pre-cgf-merge               -> pre-cgf-merge
 * [new tag]             pre-cygwin-heap             -> pre-cygwin-heap
 * [new tag]             pre-no-this                 -> pre-no-this
 * [new tag]             pre-notty                   -> pre-notty
 * [new tag]             pre-posix-scan              -> pre-posix-scan
 * [new tag]             pre-ptmalloc3               -> pre-ptmalloc3
 * [new tag]             pre-ptymaster-archetype     -> pre-ptymaster-archetype
 * [new tag]             pre-ripout-set_console_state_for_spawn -> pre-ripout-set_console_state_for_spawn
 * [new tag]             pre-sigrewrite              -> pre-sigrewrite
 * [new tag]             pre_wait_sig_exit           -> pre_wait_sig_exit
 * [new tag]             predaemon                   -> predaemon
 * [new tag]             prefifo                     -> prefifo
 * [new tag]             preoverlapped               -> preoverlapped
 * [new tag]             readline_4_3-import-branchpoint -> readline_4_3-import-branchpoint
 * [new tag]             readline_5_1-import-branchpoint -> readline_5_1-import-branchpoint
 * [new tag]             reparent-point              -> reparent-point
 * [new tag]             repo-unification-2000-02-06 -> repo-unification-2000-02-06
 * [new tag]             reverse-20080717-branchpoint -> reverse-20080717-branchpoint
 * [new tag]             reverse-20080930-branchpoint -> reverse-20080930-branchpoint
 * [new tag]             reverse-20081226-branchpoint -> reverse-20081226-branchpoint
 * [new tag]             sid-20020905-branchpoint    -> sid-20020905-branchpoint
 * [new tag]             sid-snapshot-20071001       -> sid-snapshot-20071001
 * [new tag]             sid-snapshot-20071101       -> sid-snapshot-20071101
 * [new tag]             sid-snapshot-20071201       -> sid-snapshot-20071201
 * [new tag]             sid-snapshot-20080101       -> sid-snapshot-20080101
 * [new tag]             sid-snapshot-20080201       -> sid-snapshot-20080201
 * [new tag]             sid-snapshot-20080301       -> sid-snapshot-20080301
 * [new tag]             sid-snapshot-20080401       -> sid-snapshot-20080401
 * [new tag]             sid-snapshot-20080403       -> sid-snapshot-20080403
 * [new tag]             sid-snapshot-20080501       -> sid-snapshot-20080501
 * [new tag]             sid-snapshot-20080601       -> sid-snapshot-20080601
 * [new tag]             sid-snapshot-20080701       -> sid-snapshot-20080701
 * [new tag]             sid-snapshot-20080801       -> sid-snapshot-20080801
 * [new tag]             sid-snapshot-20080901       -> sid-snapshot-20080901
 * [new tag]             sid-snapshot-20081001       -> sid-snapshot-20081001
 * [new tag]             sid-snapshot-20081101       -> sid-snapshot-20081101
 * [new tag]             sid-snapshot-20081201       -> sid-snapshot-20081201
 * [new tag]             sid-snapshot-20090101       -> sid-snapshot-20090101
 * [new tag]             sid-snapshot-20090201       -> sid-snapshot-20090201
 * [new tag]             sid-snapshot-20090301       -> sid-snapshot-20090301
 * [new tag]             sid-snapshot-20090401       -> sid-snapshot-20090401
 * [new tag]             sid-snapshot-20090501       -> sid-snapshot-20090501
 * [new tag]             sid-snapshot-20090601       -> sid-snapshot-20090601
 * [new tag]             sid-snapshot-20090701       -> sid-snapshot-20090701
 * [new tag]             sid-snapshot-20090801       -> sid-snapshot-20090801
 * [new tag]             sid-snapshot-20090901       -> sid-snapshot-20090901
 * [new tag]             sid-snapshot-20091001       -> sid-snapshot-20091001
 * [new tag]             sid-snapshot-20091101       -> sid-snapshot-20091101
 * [new tag]             sid-snapshot-20091201       -> sid-snapshot-20091201
 * [new tag]             sid-snapshot-20100101       -> sid-snapshot-20100101
 * [new tag]             sid-snapshot-20100201       -> sid-snapshot-20100201
 * [new tag]             sid-snapshot-20100301       -> sid-snapshot-20100301
 * [new tag]             sid-snapshot-20100401       -> sid-snapshot-20100401
 * [new tag]             sid-snapshot-20100501       -> sid-snapshot-20100501
 * [new tag]             sid-snapshot-20100601       -> sid-snapshot-20100601
 * [new tag]             sid-snapshot-20100701       -> sid-snapshot-20100701
 * [new tag]             sid-snapshot-20100801       -> sid-snapshot-20100801
 * [new tag]             sid-snapshot-20100901       -> sid-snapshot-20100901
 * [new tag]             sid-snapshot-20101001       -> sid-snapshot-20101001
 * [new tag]             sid-snapshot-20101101       -> sid-snapshot-20101101
 * [new tag]             sid-snapshot-20101201       -> sid-snapshot-20101201
 * [new tag]             sid-snapshot-20110101       -> sid-snapshot-20110101
 * [new tag]             sid-snapshot-20110201       -> sid-snapshot-20110201
 * [new tag]             sid-snapshot-20110301       -> sid-snapshot-20110301
 * [new tag]             sid-snapshot-20110401       -> sid-snapshot-20110401
 * [new tag]             sid-snapshot-20110501       -> sid-snapshot-20110501
 * [new tag]             sid-snapshot-20110601       -> sid-snapshot-20110601
 * [new tag]             sid-snapshot-20110701       -> sid-snapshot-20110701
 * [new tag]             sid-snapshot-20110801       -> sid-snapshot-20110801
 * [new tag]             sid-snapshot-20110901       -> sid-snapshot-20110901
 * [new tag]             sid-snapshot-20111001       -> sid-snapshot-20111001
 * [new tag]             sid-snapshot-20111101       -> sid-snapshot-20111101
 * [new tag]             sid-snapshot-20111201       -> sid-snapshot-20111201
 * [new tag]             sid-snapshot-20120101       -> sid-snapshot-20120101
 * [new tag]             sid-snapshot-20120201       -> sid-snapshot-20120201
 * [new tag]             sid-snapshot-20120301       -> sid-snapshot-20120301
 * [new tag]             sid-snapshot-20120401       -> sid-snapshot-20120401
 * [new tag]             sid-snapshot-20120501       -> sid-snapshot-20120501
 * [new tag]             sid-snapshot-20120601       -> sid-snapshot-20120601
 * [new tag]             sid-snapshot-20120701       -> sid-snapshot-20120701
 * [new tag]             sid-snapshot-20120801       -> sid-snapshot-20120801
 * [new tag]             sid-snapshot-20120901       -> sid-snapshot-20120901
 * [new tag]             sid-snapshot-20121001       -> sid-snapshot-20121001
 * [new tag]             sid-snapshot-20121101       -> sid-snapshot-20121101
 * [new tag]             sid-snapshot-20121201       -> sid-snapshot-20121201
 * [new tag]             sid-snapshot-20130101       -> sid-snapshot-20130101
 * [new tag]             sid-snapshot-20130201       -> sid-snapshot-20130201
 * [new tag]             sid-snapshot-20130301       -> sid-snapshot-20130301
 * [new tag]             sid-snapshot-20130401       -> sid-snapshot-20130401
 * [new tag]             sid-snapshot-20130501       -> sid-snapshot-20130501
 * [new tag]             sid-snapshot-20130601       -> sid-snapshot-20130601
 * [new tag]             sid-snapshot-20130701       -> sid-snapshot-20130701
 * [new tag]             sid-snapshot-20130801       -> sid-snapshot-20130801
 * [new tag]             sid-snapshot-20130901       -> sid-snapshot-20130901
 * [new tag]             sid-snapshot-20131001       -> sid-snapshot-20131001
 * [new tag]             sid-snapshot-20131101       -> sid-snapshot-20131101
 * [new tag]             sid-snapshot-20131201       -> sid-snapshot-20131201
 * [new tag]             sid-snapshot-20140101       -> sid-snapshot-20140101
 * [new tag]             sid-snapshot-20140201       -> sid-snapshot-20140201
 * [new tag]             sid-snapshot-20140301       -> sid-snapshot-20140301
 * [new tag]             sid-snapshot-20140401       -> sid-snapshot-20140401
 * [new tag]             sid-snapshot-20140501       -> sid-snapshot-20140501
 * [new tag]             sid-snapshot-20140601       -> sid-snapshot-20140601
 * [new tag]             sid-snapshot-20140701       -> sid-snapshot-20140701
 * [new tag]             sid-snapshot-20140801       -> sid-snapshot-20140801
 * [new tag]             sid-snapshot-20140901       -> sid-snapshot-20140901
 * [new tag]             sid-snapshot-20141001       -> sid-snapshot-20141001
 * [new tag]             sid-snapshot-20141101       -> sid-snapshot-20141101
 * [new tag]             sid-snapshot-20141201       -> sid-snapshot-20141201
 * [new tag]             sid-snapshot-20150101       -> sid-snapshot-20150101
 * [new tag]             sid-snapshot-20150201       -> sid-snapshot-20150201
 * [new tag]             sid-snapshot-20150301       -> sid-snapshot-20150301
 * [new tag]             tcltk840-20020924-branchpoint -> tcltk840-20020924-branchpoint
 * [new tag]             w32api-1_5                  -> w32api-1_5
 * [new tag]             w32api-2_2                  -> w32api-2_2
 * [new tag]             winsup-2000-02-17           -> winsup-2000-02-17
 * [new tag]             x86_64versiong3             -> x86_64versiong3
HEAD is now at 1a5c603b9 Version 1.8.5
From https://github.com/zephyrproject-rtos/segger
 * [new branch]      master       -> refs/west/master
 * [new branch]      v1.14-branch -> refs/west/v1.14-branch
HEAD is now at 9d01912 segger: config: RTT spinlock implementation
From https://github.com/zephyrproject-rtos/tinycrypt
HEAD is now at 3e9a49d cmake: Fix conditional in root CMakeLists.txt
From https://github.com/zephyrproject-rtos/uoscore-uedhoc
 * [new branch]      zephyr     -> refs/west/zephyr
HEAD is now at 150f4eb [zephyr fromlist] Adapt to changes in name generation in zcbor 0.8.0
From https://github.com/zephyrproject-rtos/zcbor
 * [new branch]      main              -> refs/west/main
 * [new branch]      release/0.6.1     -> refs/west/release/0.6.1
 * [new branch]      release/0.8.2     -> refs/west/release/0.8.2
 * [new tag]         0.1.0             -> 0.1.0
 * [new tag]         0.2.0             -> 0.2.0
 * [new tag]         0.3.0             -> 0.3.0
 * [new tag]         0.3.1             -> 0.3.1
 * [new tag]         0.4.0             -> 0.4.0
 * [new tag]         0.5.0             -> 0.5.0
 * [new tag]         0.5.1             -> 0.5.1
 * [new tag]         0.6.0             -> 0.6.0
 * [new tag]         0.8.0             -> 0.8.0
 * [new tag]         0.8.1             -> 0.8.1
 * [new tag]         0.9.0             -> 0.9.0
 * [new tag]         deprecated-master -> deprecated-master
 * [new tag]         inital-pr         -> inital-pr
 * [new tag]         old-structure     -> old-structure
HEAD is now at d3093b5 Update version from 0.8.99 to 0.8.1
ERROR: update failed for projects: matter, cmock
Error: Launched process exited with non-zero status: 1
2024-09-07T16:37:33.640Z ERROR Error: From https://github.com/nrfconnect/sdk-zephyr
 * tag                       v3.5.99-ncs1-1            -> FETCH_HEAD
 * [new tag]                 v1.13.99-ncs1             -> v1.13.99-ncs1
 * [new tag]                 v1.13.99-ncs1-rc1         -> v1.13.99-ncs1-rc1
 * [new tag]                 v1.13.99-ncs2             -> v1.13.99-ncs2
 * [new tag]                 v1.13.99-ncs2-rc1         -> v1.13.99-ncs2-rc1
 * [new tag]                 v1.13.99-ncs2-rc2         -> v1.13.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs1             -> v1.14.99-ncs1
 * [new tag]                 v1.14.99-ncs1-rc1         -> v1.14.99-ncs1-rc1
 * [new tag]                 v1.14.99-ncs1-rc2         -> v1.14.99-ncs1-rc2
 * [new tag]                 v1.14.99-ncs2             -> v1.14.99-ncs2
 * [new tag]                 v1.14.99-ncs2-rc1         -> v1.14.99-ncs2-rc1
 * [new tag]                 v1.14.99-ncs2-rc2         -> v1.14.99-ncs2-rc2
 * [new tag]                 v1.14.99-ncs2-rc3         -> v1.14.99-ncs2-rc3
 * [new tag]                 v1.14.99-ncs2-rc4         -> v1.14.99-ncs2-rc4
 * [new tag]                 v1.14.99-ncs3-snapshot1   -> v1.14.99-ncs3-snapshot1
 * [new tag]                 v1.14.99-ncs3-snapshot2   -> v1.14.99-ncs3-snapshot2
 * [new tag]                 v2.0.99-ncs1              -> v2.0.99-ncs1
 * [new tag]                 v2.0.99-ncs1-rc1          -> v2.0.99-ncs1-rc1
 * [new tag]                 v2.0.99-ncs1-rc2          -> v2.0.99-ncs1-rc2
 * [new tag]                 v2.0.99-ncs1-rc3          -> v2.0.99-ncs1-rc3
 * [new tag]                 v2.0.99-ncs1-snapshot1    -> v2.0.99-ncs1-snapshot1
 * [new tag]                 v2.1.0-ncs1-snapshot1     -> v2.1.0-ncs1-snapshot1
 * [new tag]                 v2.1.99-ncs1              -> v2.1.99-ncs1
 * [new tag]                 v2.1.99-ncs1-rc1          -> v2.1.99-ncs1-rc1
 * [new tag]                 v2.1.99-ncs1-rc2          -> v2.1.99-ncs1-rc2
 * [new tag]                 v2.1.99-ncs1-snapshot1    -> v2.1.99-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs1           -> v2.3.0-rc1-ncs1
 * [new tag]                 v2.3.0-rc1-ncs1-rc1       -> v2.3.0-rc1-ncs1-rc1
 * [new tag]                 v2.3.0-rc1-ncs1-rc2       -> v2.3.0-rc1-ncs1-rc2
 * [new tag]                 v2.3.0-rc1-ncs1-rc3       -> v2.3.0-rc1-ncs1-rc3
 * [new tag]                 v2.3.0-rc1-ncs1-snapshot1 -> v2.3.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.3.0-rc1-ncs2           -> v2.3.0-rc1-ncs2
 * [new tag]                 v2.3.0-rc1-ncs3           -> v2.3.0-rc1-ncs3
 * [new tag]                 v2.4.0-ncs1               -> v2.4.0-ncs1
 * [new tag]                 v2.4.0-ncs1-rc1           -> v2.4.0-ncs1-rc1
 * [new tag]                 v2.4.0-ncs1-rc2           -> v2.4.0-ncs1-rc2
 * [new tag]                 v2.4.0-ncs1-snapshot1     -> v2.4.0-ncs1-snapshot1
 * [new tag]                 v2.4.0-ncs2               -> v2.4.0-ncs2
 * [new tag]                 v2.4.0-ncs2-rc1           -> v2.4.0-ncs2-rc1
 * [new tag]                 v2.4.99-ncs1              -> v2.4.99-ncs1
 * [new tag]                 v2.4.99-ncs1-rc1          -> v2.4.99-ncs1-rc1
 * [new tag]                 v2.4.99-ncs1-snapshot1    -> v2.4.99-ncs1-snapshot1
 * [new tag]                 v2.4.99-ncs2              -> v2.4.99-ncs2
 * [new tag]                 v2.4.99-ncs2-1            -> v2.4.99-ncs2-1
 * [new tag]                 v2.4.99-ncs2-rc1          -> v2.4.99-ncs2-rc1
 * [new tag]                 v2.6.0-ncs1-rc3           -> v2.6.0-ncs1-rc3
 * [new tag]                 v2.6.0-rc1-ncs1           -> v2.6.0-rc1-ncs1
 * [new tag]                 v2.6.0-rc1-ncs1-rc1       -> v2.6.0-rc1-ncs1-rc1
 * [new tag]                 v2.6.0-rc1-ncs1-snapshot1 -> v2.6.0-rc1-ncs1-snapshot1
 * [new tag]                 v2.6.99-ncs1              -> v2.6.99-ncs1
 * [new tag]                 v2.6.99-ncs1-1            -> v2.6.99-ncs1-1
 * [new tag]                 v2.6.99-ncs1-rc1          -> v2.6.99-ncs1-rc1
 * [new tag]                 v2.6.99-ncs1-rc2          -> v2.6.99-ncs1-rc2
 * [new tag]                 v2.6.99-ncs1-snapshot1    -> v2.6.99-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1               -> v2.7.0-ncs1
 * [new tag]                 v2.7.0-ncs1-rc1           -> v2.7.0-ncs1-rc1
 * [new tag]                 v2.7.0-ncs1-rc2           -> v2.7.0-ncs1-rc2
 * [new tag]                 v2.7.0-ncs1-snapshot1     -> v2.7.0-ncs1-snapshot1
 * [new tag]                 v2.7.0-ncs1-snapshot2     -> v2.7.0-ncs1-snapshot2
 * [new tag]                 v2.7.99-ncs1              -> v2.7.99-ncs1
 * [new tag]                 v2.7.99-ncs1-1            -> v2.7.99-ncs1-1
 * [new tag]                 v2.7.99-ncs1-rc1          -> v2.7.99-ncs1-rc1
 * [new tag]                 v2.7.99-ncs1-rc2          -> v2.7.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1              -> v3.0.99-ncs1
 * [new tag]                 v3.0.99-ncs1-1            -> v3.0.99-ncs1-1
 * [new tag]                 v3.0.99-ncs1-rc1          -> v3.0.99-ncs1-rc1
 * [new tag]                 v3.0.99-ncs1-rc2          -> v3.0.99-ncs1-rc2
 * [new tag]                 v3.0.99-ncs1-snapshot1    -> v3.0.99-ncs1-snapshot1
 * [new tag]                 v3.1.99-ncs1              -> v3.1.99-ncs1
 * [new tag]                 v3.1.99-ncs1-1            -> v3.1.99-ncs1-1
 * [new tag]                 v3.1.99-ncs1-2            -> v3.1.99-ncs1-2
 * [new tag]                 v3.1.99-ncs1-3            -> v3.1.99-ncs1-3
 * [new tag]                 v3.1.99-ncs1-rc1          -> v3.1.99-ncs1-rc1
 * [new tag]                 v3.1.99-ncs1-rc2          -> v3.1.99-ncs1-rc2
 * [new tag]                 v3.1.99-ncs1-snapshot1    -> v3.1.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs1              -> v3.2.99-ncs1
 * [new tag]                 v3.2.99-ncs1-rc1          -> v3.2.99-ncs1-rc1
 * [new tag]                 v3.2.99-ncs1-rc2          -> v3.2.99-ncs1-rc2
 * [new tag]                 v3.2.99-ncs1-snapshot1    -> v3.2.99-ncs1-snapshot1
 * [new tag]                 v3.2.99-ncs2              -> v3.2.99-ncs2
 * [new tag]                 v3.2.99-ncs2-rc1          -> v3.2.99-ncs2-rc1
 * [new tag]                 v3.2.99-ncs2-rc2          -> v3.2.99-ncs2-rc2
 * [new tag]                 v3.2.99-ncs2-snapshot1    -> v3.2.99-ncs2-snapshot1
 * [new tag]                 v3.3.99-ncs1              -> v3.3.99-ncs1
 * [new tag]                 v3.3.99-ncs1-1            -> v3.3.99-ncs1-1
 * [new tag]                 v3.3.99-ncs1-2            -> v3.3.99-ncs1-2
 * [new tag]                 v3.3.99-ncs1-3            -> v3.3.99-ncs1-3
 * [new tag]                 v3.3.99-ncs1-rc1          -> v3.3.99-ncs1-rc1
 * [new tag]                 v3.3.99-ncs1-rc2          -> v3.3.99-ncs1-rc2
 * [new tag]                 v3.3.99-ncs1-snapshot1    -> v3.3.99-ncs1-snapshot1
 * [new tag]                 v3.4.99-ncs1              -> v3.4.99-ncs1
 * [new tag]                 v3.4.99-ncs1-1            -> v3.4.99-ncs1-1
 * [new tag]                 v3.4.99-ncs1-1-rc1        -> v3.4.99-ncs1-1-rc1
 * [new tag]                 v3.4.99-ncs1-2            -> v3.4.99-ncs1-2
 * [new tag]                 v3.4.99-ncs1-3            -> v3.4.99-ncs1-3
 * [new tag]                 v3.4.99-ncs1-rc1          -> v3.4.99-ncs1-rc1
 * [new tag]                 v3.4.99-ncs1-rc2          -> v3.4.99-ncs1-rc2
 * [new tag]                 v3.4.99-ncs1-snapshot1    -> v3.4.99-ncs1-snapshot1
 * [new tag]                 v3.5.99-ncs1              -> v3.5.99-ncs1
 * [new tag]                 v3.5.99-ncs1-1            -> v3.5.99-ncs1-1
 * [new tag]                 v3.5.99-ncs1-rc1          -> v3.5.99-ncs1-rc1
 * [new tag]                 v3.5.99-ncs1-rc2          -> v3.5.99-ncs1-rc2
 * [new tag]                 v3.5.99-ncs1-snapshot1    -> v3.5.99-ncs1-snapshot1
 * [new tag]                 v3.6.99-ncs2              -> v3.6.99-ncs2
 * [new tag]                 v3.6.99-ncs2-rc1          -> v3.6.99-ncs2-rc1
 * [new tag]                 v3.6.99-ncs2-rc2          -> v3.6.99-ncs2-rc2
 * [new tag]                 v3.6.99-ncs2-rc3          -> v3.6.99-ncs2-rc3
 * [new tag]                 v3.6.99-ncs2-snapshot1    -> v3.6.99-ncs2-snapshot1
HEAD is now at 3758bcbfa5c [nrf fromtree] drivers: pinctrl_nrf: Configure QSPI IO3 pin as output set high
From https://github.com/BabbleSim/bsim_west
 * [new branch]      v2.1       -> refs/west/v2.1
 * [new branch]      v2.1.1     -> refs/west/v2.1.1
 * [new branch]      v2.2       -> refs/west/v2.2
 * [new branch]      v2.2.1     -> refs/west/v2.2.1
 * [new branch]      v2.3       -> refs/west/v2.3
HEAD is now at 384a091 west.yaml Update to 2.1.1
From https://github.com/nrfconnect/sdk-hostap
 * [new branch]          hcs                      -> refs/west/hcs
 * [new branch]          hostap_2_11_devel-ncs1-branch -> refs/west/hostap_2_11_devel-ncs1-branch
 * [new branch]          nrf700x-dev              -> refs/west/nrf700x-dev
 * [new branch]          nrf700x-test             -> refs/west/nrf700x-test
 * [new branch]          v2.5-branch              -> refs/west/v2.5-branch
 * [new branch]          v2.6-branch              -> refs/west/v2.6-branch
 * [new tag]             fix_sauce_tag_snapshot   -> fix_sauce_tag_snapshot
 * [new tag]             hostap_2_11_devel-ncs1   -> hostap_2_11_devel-ncs1
 * [new tag]             prepare_upmerge_snapshot -> prepare_upmerge_snapshot
HEAD is now at e080aa8d0 [nrf fromlist] wpa_supplicant: Add an option to disable SNR capping
From https://github.com/nrfconnect/sdk-wi-fiquicktrack-controlappc
 * [new branch]      qt_v2.5.1      -> refs/west/qt_v2.5.1
 * [new tag]         R2.1-snapshot1 -> R2.1-snapshot1
 * [new tag]         pre_zephyr_separation_snapshot -> pre_zephyr_separation_snapshot
HEAD is now at d649bd1 [nrf noup]: qt: Fix config name
From https://github.com/nrfconnect/sdk-mcuboot
 * tag                 v2.0.99-ncs1-1          -> FETCH_HEAD
 * [new tag]           v1.10.0-ncs1            -> v1.10.0-ncs1
 * [new tag]           v1.10.0-ncs1-1          -> v1.10.0-ncs1-1
 * [new tag]           v1.10.0-ncs1-rc1        -> v1.10.0-ncs1-rc1
 * [new tag]           v1.10.0-ncs1-rc2        -> v1.10.0-ncs1-rc2
 * [new tag]           v1.10.0-ncs1-snapshot1  -> v1.10.0-ncs1-snapshot1
 * [new tag]           v1.10.99-ncs1           -> v1.10.99-ncs1
 * [new tag]           v1.10.99-ncs1-1         -> v1.10.99-ncs1-1
 * [new tag]           v1.10.99-ncs1-1-rc1     -> v1.10.99-ncs1-1-rc1
 * [new tag]           v1.10.99-ncs1-2         -> v1.10.99-ncs1-2
 * [new tag]           v1.10.99-ncs1-3         -> v1.10.99-ncs1-3
 * [new tag]           v1.10.99-ncs1-rc1       -> v1.10.99-ncs1-rc1
 * [new tag]           v1.10.99-ncs1-rc2       -> v1.10.99-ncs1-rc2
 * [new tag]           v1.10.99-ncs1-snapshot1 -> v1.10.99-ncs1-snapshot1
 * [new tag]           v1.2.99-ncs1            -> v1.2.99-ncs1
 * [new tag]           v1.2.99-ncs1-rc1        -> v1.2.99-ncs1-rc1
 * [new tag]           v1.2.99-ncs2            -> v1.2.99-ncs2
 * [new tag]           v1.2.99-ncs2-rc1        -> v1.2.99-ncs2-rc1
 * [new tag]           v1.2.99-ncs2-rc2        -> v1.2.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs1            -> v1.3.99-ncs1
 * [new tag]           v1.3.99-ncs1-rc1        -> v1.3.99-ncs1-rc1
 * [new tag]           v1.3.99-ncs1-rc2        -> v1.3.99-ncs1-rc2
 * [new tag]           v1.3.99-ncs2            -> v1.3.99-ncs2
 * [new tag]           v1.3.99-ncs2-rc1        -> v1.3.99-ncs2-rc1
 * [new tag]           v1.3.99-ncs2-rc2        -> v1.3.99-ncs2-rc2
 * [new tag]           v1.3.99-ncs2-rc3        -> v1.3.99-ncs2-rc3
 * [new tag]           v1.3.99-ncs2-rc4        -> v1.3.99-ncs2-rc4
 * [new tag]           v1.3.99-ncs3-snapshot1  -> v1.3.99-ncs3-snapshot1
 * [new tag]           v1.3.99-ncs3-snapshot2  -> v1.3.99-ncs3-snapshot2
 * [new tag]           v1.4.99-ncs1            -> v1.4.99-ncs1
 * [new tag]           v1.4.99-ncs1-rc1        -> v1.4.99-ncs1-rc1
 * [new tag]           v1.4.99-ncs1-rc2        -> v1.4.99-ncs1-rc2
 * [new tag]           v1.4.99-ncs1-rc3        -> v1.4.99-ncs1-rc3
 * [new tag]           v1.4.99-ncs1-snapshot1  -> v1.4.99-ncs1-snapshot1
 * [new tag]           v1.4.99-ncs2            -> v1.4.99-ncs2
 * [new tag]           v1.4.99-ncs2-rc1        -> v1.4.99-ncs2-rc1
 * [new tag]           v1.4.99-ncs2-rc2        -> v1.4.99-ncs2-rc2
 * [new tag]           v1.4.99-ncs2-snapshot1  -> v1.4.99-ncs2-snapshot1
 * [new tag]           v1.5.99-ncs1-rc1        -> v1.5.99-ncs1-rc1
 * [new tag]           v1.5.99-ncs1-rc2        -> v1.5.99-ncs1-rc2
 * [new tag]           v1.5.99-ncs1-rc3        -> v1.5.99-ncs1-rc3
 * [new tag]           v1.5.99-ncs1-snapshot1  -> v1.5.99-ncs1-snapshot1
 * [new tag]           v1.6.0-rc2-ncs1         -> v1.6.0-rc2-ncs1
 * [new tag]           v1.6.99-ncs1            -> v1.6.99-ncs1
 * [new tag]           v1.6.99-ncs1-rc1        -> v1.6.99-ncs1-rc1
 * [new tag]           v1.6.99-ncs1-rc2        -> v1.6.99-ncs1-rc2
 * [new tag]           v1.6.99-ncs1-snapshot1  -> v1.6.99-ncs1-snapshot1
 * [new tag]           v1.7.0-ncs1-rc1         -> v1.7.0-ncs1-rc1
 * [new tag]           v1.7.0-ncs1-rc3         -> v1.7.0-ncs1-rc3
 * [new tag]           v1.7.0-ncs1-snapshot1   -> v1.7.0-ncs1-snapshot1
 * [new tag]           v1.7.2                  -> v1.7.2
 * [new tag]           v1.7.2-ncs1             -> v1.7.2-ncs1
 * [new tag]           v1.7.2-ncs1-rc2         -> v1.7.2-ncs1-rc2
 * [new tag]           v1.7.2-ncs2             -> v1.7.2-ncs2
 * [new tag]           v1.7.2-ncs2-rc1         -> v1.7.2-ncs2-rc1
 * [new tag]           v1.7.2-ncs2-rc2         -> v1.7.2-ncs2-rc2
 * [new tag]           v1.7.2-ncs3             -> v1.7.2-ncs3
 * [new tag]           v1.7.2-ncs3-rc1         -> v1.7.2-ncs3-rc1
 * [new tag]           v1.7.2-ncs3-rc2         -> v1.7.2-ncs3-rc2
 * [new tag]           v1.7.99-ncs1            -> v1.7.99-ncs1
 * [new tag]           v1.7.99-ncs1-1          -> v1.7.99-ncs1-1
 * [new tag]           v1.7.99-ncs1-rc1        -> v1.7.99-ncs1-rc1
 * [new tag]           v1.7.99-ncs2            -> v1.7.99-ncs2
 * [new tag]           v1.7.99-ncs2-snapshot1  -> v1.7.99-ncs2-snapshot1
 * [new tag]           v1.7.99-ncs3            -> v1.7.99-ncs3
 * [new tag]           v1.7.99-ncs3-1          -> v1.7.99-ncs3-1
 * [new tag]           v1.7.99-ncs3-rc1        -> v1.7.99-ncs3-rc1
 * [new tag]           v1.7.99-ncs3-rc2        -> v1.7.99-ncs3-rc2
 * [new tag]           v1.7.99-ncs4            -> v1.7.99-ncs4
 * [new tag]           v1.7.99-ncs4-rc1        -> v1.7.99-ncs4-rc1
 * [new tag]           v1.7.99-ncs4-rc2        -> v1.7.99-ncs4-rc2
 * [new tag]           v1.8.99-ncs1            -> v1.8.99-ncs1
 * [new tag]           v1.8.99-ncs1-rc1        -> v1.8.99-ncs1-rc1
 * [new tag]           v1.8.99-ncs1-rc2        -> v1.8.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1            -> v1.9.99-ncs1
 * [new tag]           v1.9.99-ncs1-rc1        -> v1.9.99-ncs1-rc1
 * [new tag]           v1.9.99-ncs1-rc2        -> v1.9.99-ncs1-rc2
 * [new tag]           v1.9.99-ncs1-snapshot1  -> v1.9.99-ncs1-snapshot1
 * [new tag]           v1.9.99-ncs2            -> v1.9.99-ncs2
 * [new tag]           v1.9.99-ncs2-rc1        -> v1.9.99-ncs2-rc1
 * [new tag]           v1.9.99-ncs2-rc2        -> v1.9.99-ncs2-rc2
 * [new tag]           v1.9.99-ncs2-snapshot1  -> v1.9.99-ncs2-snapshot1
 * [new tag]           v1.9.99-ncs3            -> v1.9.99-ncs3
 * [new tag]           v1.9.99-ncs3-rc1        -> v1.9.99-ncs3-rc1
 * [new tag]           v1.9.99-ncs3-rc2        -> v1.9.99-ncs3-rc2
 * [new tag]           v1.9.99-ncs4            -> v1.9.99-ncs4
 * [new tag]           v1.9.99-ncs4-rc1        -> v1.9.99-ncs4-rc1
 * [new tag]           v1.9.99-ncs4-rc2        -> v1.9.99-ncs4-rc2
 * [new tag]           v1.9.99-ncs4-snapshot1  -> v1.9.99-ncs4-snapshot1
 * [new tag]           v1.9.99-ncs4-snapshot2  -> v1.9.99-ncs4-snapshot2
 * [new tag]           v2.0.99-ncs1-1          -> v2.0.99-ncs1-1
 * [new tag]           v2.1.0-ncs1             -> v2.1.0-ncs1
 * [new tag]           v2.1.0-ncs1-rc1         -> v2.1.0-ncs1-rc1
 * [new tag]           v2.1.0-ncs1-rc2         -> v2.1.0-ncs1-rc2
 * [new tag]           v2.1.0-ncs1-rc3         -> v2.1.0-ncs1-rc3
HEAD is now at 3c2f2ff1 [nrf noup] boards: thingy91x: add board config
From https://github.com/laurencelundblade/QCBOR
 * [new branch]      BeforeSpiffyDecode -> refs/west/BeforeSpiffyDecode
 * [new branch]      CDE                -> refs/west/CDE
 * [new branch]      NaN                -> refs/west/NaN
 * [new branch]      arrays             -> refs/west/arrays
 * [new branch]      better_big_num     -> refs/west/better_big_num
 * [new branch]      const              -> refs/west/const
 * [new branch]      dev                -> refs/west/dev
 * [new branch]      disable            -> refs/west/disable
 * [new branch]      enter-array        -> refs/west/enter-array
 * [new branch]      makewarn           -> refs/west/makewarn
 * [new branch]      mappie             -> refs/west/mappie
 * [new branch]      newtag             -> refs/west/newtag
 * [new branch]      ub-example         -> refs/west/ub-example
 * [new branch]      versioning         -> refs/west/versioning
 * [new branch]      warn_in_tests      -> refs/west/warn_in_tests
 * [new tag]         v1.0               -> v1.0
 * [new tag]         v1.1               -> v1.1
 * [new tag]         v1.2               -> v1.2
 * [new tag]         v1.3               -> v1.3
 * [new tag]         v1.4               -> v1.4
 * [new tag]         v1.4.1             -> v1.4.1
HEAD is now at 751d365 restore inc/qcbor.h for backwards compatibility (#181)
From https://github.com/nrfconnect/sdk-mbedtls
 * tag                   v3.5.2-ncs1-1         -> FETCH_HEAD
 * [new tag]             mbedtls-2.26.0        -> mbedtls-2.26.0
 * [new tag]             v3.0.0-ncs1           -> v3.0.0-ncs1
 * [new tag]             v3.0.0-ncs1-rc2       -> v3.0.0-ncs1-rc2
 * [new tag]             v3.0.0-ncs2           -> v3.0.0-ncs2
 * [new tag]             v3.0.0-ncs2-rc1       -> v3.0.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs1           -> v3.1.0-ncs1
 * [new tag]             v3.1.0-ncs1-rc1       -> v3.1.0-ncs1-rc1
 * [new tag]             v3.1.0-ncs1-rc2       -> v3.1.0-ncs1-rc2
 * [new tag]             v3.1.0-ncs2           -> v3.1.0-ncs2
 * [new tag]             v3.1.0-ncs2-rc1       -> v3.1.0-ncs2-rc1
 * [new tag]             v3.1.0-ncs2-rc2       -> v3.1.0-ncs2-rc2
 * [new tag]             v3.1.0-ncs3           -> v3.1.0-ncs3
 * [new tag]             v3.1.0-ncs3-rc1       -> v3.1.0-ncs3-rc1
 * [new tag]             v3.1.0-ncs3-rc2       -> v3.1.0-ncs3-rc2
 * [new tag]             v3.3.0-ncs1           -> v3.3.0-ncs1
 * [new tag]             v3.3.0-ncs1-1         -> v3.3.0-ncs1-1
 * [new tag]             v3.3.0-ncs1-rc1       -> v3.3.0-ncs1-rc1
 * [new tag]             v3.3.0-ncs1-rc2       -> v3.3.0-ncs1-rc2
 * [new tag]             v3.3.0-ncs1-snapshot1 -> v3.3.0-ncs1-snapshot1
 * [new tag]             v3.3.0-ncs2           -> v3.3.0-ncs2
 * [new tag]             v3.3.0-ncs2-1         -> v3.3.0-ncs2-1
 * [new tag]             v3.3.0-ncs2-1-rc1     -> v3.3.0-ncs2-1-rc1
 * [new tag]             v3.3.0-ncs2-2         -> v3.3.0-ncs2-2
 * [new tag]             v3.3.0-ncs2-3         -> v3.3.0-ncs2-3
 * [new tag]             v3.3.0-ncs2-rc1       -> v3.3.0-ncs2-rc1
 * [new tag]             v3.3.0-ncs2-rc2       -> v3.3.0-ncs2-rc2
 * [new tag]             v3.5.2-ncs1           -> v3.5.2-ncs1
 * [new tag]             v3.5.2-ncs1-1         -> v3.5.2-ncs1-1
 * [new tag]             v3.5.2-ncs1-rc1       -> v3.5.2-ncs1-rc1
 * [new tag]             v3.5.2-ncs1-rc2       -> v3.5.2-ncs1-rc2
 * [new tag]             v3.5.2-ncs1-snapshot1 -> v3.5.2-ncs1-snapshot1
 * [new tag]             v3.5.2-ncs2           -> v3.5.2-ncs2
 * [new tag]             v3.5.2-ncs2-rc1       -> v3.5.2-ncs2-rc1
 * [new tag]             v3.5.2-ncs2-rc2       -> v3.5.2-ncs2-rc2
 * [new tag]             v3.5.2-ncs2-rc3       -> v3.5.2-ncs2-rc3
 * [new tag]             v3.5.2-ncs2-snapshot1 -> v3.5.2-ncs2-snapshot1
HEAD is now at 9beb52e67 [nrf noup] tls: Adapt to final PSA PAKE APIs
From https://github.com/nrfconnect/sdk-nrfxlib
 * tag                 v2.6.1       -> FETCH_HEAD
 * [new tag]           v0.1.0       -> v0.1.0
 * [new tag]           v0.1.0-rc1   -> v0.1.0-rc1
 * [new tag]           v0.3.0       -> v0.3.0
 * [new tag]           v0.3.0-rc1   -> v0.3.0-rc1
 * [new tag]           v0.3.0-rc2   -> v0.3.0-rc2
 * [new tag]           v0.4.0       -> v0.4.0
 * [new tag]           v0.4.0-rc1   -> v0.4.0-rc1
 * [new tag]           v0.4.0-rc2   -> v0.4.0-rc2
 * [new tag]           v1.0.0       -> v1.0.0
 * [new tag]           v1.0.0-rc1   -> v1.0.0-rc1
 * [new tag]           v1.0.0-rc2   -> v1.0.0-rc2
 * [new tag]           v1.0.0-rc3   -> v1.0.0-rc3
 * [new tag]           v1.0.0-rc4   -> v1.0.0-rc4
 * [new tag]           v1.1.0       -> v1.1.0
 * [new tag]           v1.1.0-rc1   -> v1.1.0-rc1
 * [new tag]           v1.1.0-rc2   -> v1.1.0-rc2
 * [new tag]           v1.1.0-rc3   -> v1.1.0-rc3
 * [new tag]           v1.2.0       -> v1.2.0
 * [new tag]           v1.2.0-rc1   -> v1.2.0-rc1
 * [new tag]           v1.2.0-rc2   -> v1.2.0-rc2
 * [new tag]           v1.2.1       -> v1.2.1
 * [new tag]           v1.3.0       -> v1.3.0
 * [new tag]           v1.3.0-rc1   -> v1.3.0-rc1
 * [new tag]           v1.3.0-rc2   -> v1.3.0-rc2
 * [new tag]           v1.3.0-rc3   -> v1.3.0-rc3
 * [new tag]           v1.3.1       -> v1.3.1
 * [new tag]           v1.4.0       -> v1.4.0
 * [new tag]           v1.4.0-rc1   -> v1.4.0-rc1
 * [new tag]           v1.4.2       -> v1.4.2
 * [new tag]           v1.5.0       -> v1.5.0
 * [new tag]           v1.5.0-rc1   -> v1.5.0-rc1
 * [new tag]           v1.5.1       -> v1.5.1
 * [new tag]           v1.5.1-rc1   -> v1.5.1-rc1
 * [new tag]           v1.5.2       -> v1.5.2
 * [new tag]           v1.6.0       -> v1.6.0
 * [new tag]           v1.6.0-rc3   -> v1.6.0-rc3
 * [new tag]           v1.6.1       -> v1.6.1
 * [new tag]           v1.7.0       -> v1.7.0
 * [new tag]           v1.7.0-rc1   -> v1.7.0-rc1
 * [new tag]           v1.7.0-rc2   -> v1.7.0-rc2
 * [new tag]           v1.7.1       -> v1.7.1
 * [new tag]           v1.8.0       -> v1.8.0
 * [new tag]           v1.8.0-rc1   -> v1.8.0-rc1
 * [new tag]           v1.8.0-rc2   -> v1.8.0-rc2
 * [new tag]           v1.9.0       -> v1.9.0
 * [new tag]           v1.9.0-rc1   -> v1.9.0-rc1
 * [new tag]           v1.9.0-rc2   -> v1.9.0-rc2
 * [new tag]           v1.9.1       -> v1.9.1
 * [new tag]           v1.9.2       -> v1.9.2
 * [new tag]           v1.9.2-dev1  -> v1.9.2-dev1
 * [new tag]           v2.0.0       -> v2.0.0
 * [new tag]           v2.0.0-rc1   -> v2.0.0-rc1
 * [new tag]           v2.0.0-rc2   -> v2.0.0-rc2
 * [new tag]           v2.0.0-rc2-1 -> v2.0.0-rc2-1
 * [new tag]           v2.0.1       -> v2.0.1
 * [new tag]           v2.0.2       -> v2.0.2
 * [new tag]           v2.1.0       -> v2.1.0
 * [new tag]           v2.1.0-rc1   -> v2.1.0-rc1
 * [new tag]           v2.1.0-rc2   -> v2.1.0-rc2
 * [new tag]           v2.1.1       -> v2.1.1
 * [new tag]           v2.1.2       -> v2.1.2
 * [new tag]           v2.1.3       -> v2.1.3
 * [new tag]           v2.1.4       -> v2.1.4
 * [new tag]           v2.2.0       -> v2.2.0
 * [new tag]           v2.2.0-rc1   -> v2.2.0-rc1
 * [new tag]           v2.2.0-rc2   -> v2.2.0-rc2
 * [new tag]           v2.3.0       -> v2.3.0
 * [new tag]           v2.3.0-rc1   -> v2.3.0-rc1
 * [new tag]           v2.3.0-rc2   -> v2.3.0-rc2
 * [new tag]           v2.4.0       -> v2.4.0
 * [new tag]           v2.4.0-rc1   -> v2.4.0-rc1
 * [new tag]           v2.4.0-rc2   -> v2.4.0-rc2
 * [new tag]           v2.4.1       -> v2.4.1
 * [new tag]           v2.4.2       -> v2.4.2
 * [new tag]           v2.4.3       -> v2.4.3
 * [new tag]           v2.4.4       -> v2.4.4
 * [new tag]           v2.5.0       -> v2.5.0
 * [new tag]           v2.5.0-rc1   -> v2.5.0-rc1
 * [new tag]           v2.5.0-rc2   -> v2.5.0-rc2
 * [new tag]           v2.5.1       -> v2.5.1
 * [new tag]           v2.5.1-rc1   -> v2.5.1-rc1
 * [new tag]           v2.5.2       -> v2.5.2
 * [new tag]           v2.5.3       -> v2.5.3
 * [new tag]           v2.6.0       -> v2.6.0
 * [new tag]           v2.6.0-rc1   -> v2.6.0-rc1
 * [new tag]           v2.6.0-rc2   -> v2.6.0-rc2
 * [new tag]           v2.6.1       -> v2.6.1
 * [new tag]           v2.7.0       -> v2.7.0
 * [new tag]           v2.7.0-rc1   -> v2.7.0-rc1
 * [new tag]           v2.7.0-rc2   -> v2.7.0-rc2
 * [new tag]           v2.7.0-rc3   -> v2.7.0-rc3
HEAD is now at 9adb63b6 nrf_wifi: Update RPU patch to rev#8fe7ff0425f
From https://github.com/nrfconnect/sdk-trusted-firmware-m
 * tag                   v2.0.0-ncs1-1          -> FETCH_HEAD
 * [new tag]             v1.2.99-ncs1-1         -> v1.2.99-ncs1-1
 * [new tag]             v1.3.99-ncs1-rc3       -> v1.3.99-ncs1-rc3
 * [new tag]             v1.3.99-ncs1-snapshot1 -> v1.3.99-ncs1-snapshot1
 * [new tag]             v1.3.99-ncs1-snapshot2 -> v1.3.99-ncs1-snapshot2
 * [new tag]             v1.3.99-ncs2-1         -> v1.3.99-ncs2-1
 * [new tag]             v1.3.99-ncs3           -> v1.3.99-ncs3
 * [new tag]             v1.3.99-ncs3-rc1       -> v1.3.99-ncs3-rc1
 * [new tag]             v1.3.99-ncs3-rc2       -> v1.3.99-ncs3-rc2
 * [new tag]             v1.5.0-ncs1            -> v1.5.0-ncs1
 * [new tag]             v1.5.0-ncs1-1          -> v1.5.0-ncs1-1
 * [new tag]             v1.5.0-ncs1-rc1        -> v1.5.0-ncs1-rc1
 * [new tag]             v1.5.0-ncs1-rc2        -> v1.5.0-ncs1-rc2
 * [new tag]             v1.5.0-ncs2            -> v1.5.0-ncs2
 * [new tag]             v1.5.0-ncs2-rc1        -> v1.5.0-ncs2-rc1
 * [new tag]             v1.5.0-ncs2-rc2        -> v1.5.0-ncs2-rc2
 * [new tag]             v1.5.0-ncs2-snapshot1  -> v1.5.0-ncs2-snapshot1
 * [new tag]             v1.6.0-ncs1            -> v1.6.0-ncs1
 * [new tag]             v1.6.0-ncs1-rc1        -> v1.6.0-ncs1-rc1
 * [new tag]             v1.6.0-ncs1-rc2        -> v1.6.0-ncs1-rc2
 * [new tag]             v1.6.0-ncs1-snapshot1  -> v1.6.0-ncs1-snapshot1
 * [new tag]             v1.6.0-ncs2            -> v1.6.0-ncs2
 * [new tag]             v1.6.0-ncs2-rc1        -> v1.6.0-ncs2-rc1
 * [new tag]             v1.6.0-ncs2-rc2        -> v1.6.0-ncs2-rc2
 * [new tag]             v1.6.0-ncs3            -> v1.6.0-ncs3
 * [new tag]             v1.6.0-ncs3-rc1        -> v1.6.0-ncs3-rc1
 * [new tag]             v1.6.0-ncs3-rc2        -> v1.6.0-ncs3-rc2
 * [new tag]             v1.7.0-ncs1            -> v1.7.0-ncs1
 * [new tag]             v1.7.0-ncs1-1          -> v1.7.0-ncs1-1
 * [new tag]             v1.7.0-ncs1-rc2        -> v1.7.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1            -> v1.8.0-ncs1
 * [new tag]             v1.8.0-ncs1-1          -> v1.8.0-ncs1-1
 * [new tag]             v1.8.0-ncs1-1-rc1      -> v1.8.0-ncs1-1-rc1
 * [new tag]             v1.8.0-ncs1-2          -> v1.8.0-ncs1-2
 * [new tag]             v1.8.0-ncs1-3          -> v1.8.0-ncs1-3
 * [new tag]             v1.8.0-ncs1-rc1        -> v1.8.0-ncs1-rc1
 * [new tag]             v1.8.0-ncs1-rc2        -> v1.8.0-ncs1-rc2
 * [new tag]             v1.8.0-ncs1-snapshot1  -> v1.8.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs1            -> v2.0.0-ncs1
 * [new tag]             v2.0.0-ncs1-1          -> v2.0.0-ncs1-1
 * [new tag]             v2.0.0-ncs1-rc1        -> v2.0.0-ncs1-rc1
 * [new tag]             v2.0.0-ncs1-rc2        -> v2.0.0-ncs1-rc2
 * [new tag]             v2.0.0-ncs1-snapshot1  -> v2.0.0-ncs1-snapshot1
 * [new tag]             v2.0.0-ncs2            -> v2.0.0-ncs2
 * [new tag]             v2.0.0-ncs2-rc1        -> v2.0.0-ncs2-rc1
 * [new tag]             v2.0.0-ncs2-rc2        -> v2.0.0-ncs2-rc2
 * [new tag]             v2.0.0-ncs2-rc3        -> v2.0.0-ncs2-rc3
 * [new tag]             v2.0.0-ncs2-snapshot1  -> v2.0.0-ncs2-snapshot1
HEAD is now at 2a2e1ce5e [nrf noup] cmake: tools: Dont add a custom command for running the manifest
From https://github.com/nrfconnect/sdk-psa-arch-tests
 * [new branch]      54l_its         -> refs/west/54l_its
 * [new branch]      fix_wdt_address -> refs/west/fix_wdt_address
HEAD is now at 94a349d [nrf fromlist] Fix base address for the nrf watchdog
From https://github.com/nrfconnect/sdk-connectedhomeip
 * [new tag]               v1.6.99-20210901    -> v1.6.99-20210901
 * [new tag]               v1.6.99-snapshot1   -> v1.6.99-snapshot1
 * [new tag]               v1.7.99-20211125    -> v1.7.99-20211125
 * [new tag]               v1.9.99-matter-dev1 -> v1.9.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev1 -> v2.0.99-matter-dev1
 * [new tag]               v2.0.99-matter-dev2 -> v2.0.99-matter-dev2
 * [new tag]               v2.1.0-snapshot1    -> v2.1.0-snapshot1
 * [new tag]               v2.2.0-snapshot1    -> v2.2.0-snapshot1
 * [new tag]               v2.3.0-snapshot1    -> v2.3.0-snapshot1
 * [new tag]               v2.4.99-snapshot1   -> v2.4.99-snapshot1
 * [new tag]               v2.5.99-dev1        -> v2.5.99-dev1
HEAD is now at ca3672fbb9 [mrp] Increase default retry interval for Thread
      2 [main] sh 450 dofork: child -1 - forked process 13168 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/cf2149caf2/mingw64/libexec/git-core\git-submodule: fork: retry: Resource temporarily unavailable
      2 [main] sh (12532) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1391408/0x10A1408.
This problem is probably due to using incompatible versions of the cygwin DLL.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version.  The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution.  Rebooting is also suggested if you
are unable to find another cygwin DLL.
1142094 [main] sh 450 dofork: child -1 - forked process 12532 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
3281896 [main] sh 450 dofork: child -1 - forked process 11076 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (14240) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1391408/0x11F1408.
7416352 [main] sh 450 dofork: child -1 - forked process 14240 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (7504) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1391408/0x1101408.
15557294 [main] sh 450 dofork: child -1 - forked process 7504 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/ncs/toolchains/cf2149caf2/mingw64/libexec/git-core\git-submodule: fork: Resource temporarily unavailable
From https://github.com/nrfconnect/sdk-cjson
 * [new tag]         v1.7.14    -> v1.7.14
HEAD is now at c6af068 [nrf fromtree] fix: potential memory leak in merge_patch() (#611)
From https://github.com/nrfconnect/azure-sdk-for-c
HEAD is now at 308c171c [nrf fromlist] Make repository a Zephyr module
From https://github.com/nrfconnect/sdk-mcu-drivers
HEAD is now at 3873a08 Added missing curly brace for #ifdef __cplusplus
From https://github.com/nrfconnect/sdk-openthread
 * [new branch]          debug/tomaszkob89/key-rotation -> refs/west/debug/tomaszkob89/key-rotation
 * [new branch]          for-testing       -> refs/west/for-testing
 * [new branch]          v1.7-branch       -> refs/west/v1.7-branch
 * [new branch]          v1.9-branch       -> refs/west/v1.9-branch
 * [new branch]          v2.0-branch       -> refs/west/v2.0-branch
 * [new branch]          v2.4-branch       -> refs/west/v2.4-branch
 * [new tag]             thread-reference-20200818-ncs1-rc1 -> thread-reference-20200818-ncs1-rc1
 * [new tag]             thread-reference-20200818-ncs1-rc3 -> thread-reference-20200818-ncs1-rc3
 * [new tag]             v1.8.99-snapshot1 -> v1.8.99-snapshot1
 * [new tag]             v1.9.99-snapshot1 -> v1.9.99-snapshot1
HEAD is now at b9dcdbca4 [cli] add documentation for `nexthop` command in `README.md` (#9882)
From https://github.com/ThrowTheSwitch/cmock
 * [new branch]      branch_2_5_1           -> refs/west/branch_2_5_1
 * [new branch]      cmock_2_6_rc           -> refs/west/cmock_2_6_rc
 * [new branch]      feature/only_config_is_shared -> refs/west/feature/only_config_is_shared
 * [new branch]      reapply_329            -> refs/west/reapply_329
 * [new branch]      revert-329-master      -> refs/west/revert-329-master
 * [new branch]      test/switch_to_actions -> refs/west/test/switch_to_actions
 * [new tag]         v2.4.5                 -> v2.4.5
 * [new tag]         v2.4.6                 -> v2.4.6
HEAD is now at f65066f Merge pull request #404 from tz18/patch-1
      3 [main] sh (13956) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1341408/0x1181408.
      2 [main] sh 1869 dofork: child -1 - forked process 13956 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (8352) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1341408/0x1201408.
1140220 [main] sh 1869 dofork: child -1 - forked process 8352 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      2 [main] sh (5132) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1341408/0x1271408.
7187323 [main] sh 1869 dofork: child -1 - forked process 5132 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (5632) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1341408/0x1401408.
11333914 [main] sh 1869 dofork: child -1 - forked process 5632 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
      3 [main] sh (1488) C:\ncs\toolchains\cf2149caf2\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1341408/0x1201408.
19468360 [main] sh 1869 dofork: child -1 - forked process 1488 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
From https://github.com/memfault/memfault-firmware-sdk
 * tag               1.6.0      -> FETCH_HEAD
 * [new tag]         0.0.10     -> 0.0.10
 * [new tag]         0.0.11     -> 0.0.11
 * [new tag]         0.0.12     -> 0.0.12
 * [new tag]         0.0.13     -> 0.0.13
 * [new tag]         0.0.14     -> 0.0.14
 * [new tag]         0.0.15     -> 0.0.15
 * [new tag]         0.0.16     -> 0.0.16
 * [new tag]         0.0.17     -> 0.0.17
 * [new tag]         0.0.18     -> 0.0.18
 * [new tag]         0.0.2      -> 0.0.2
 * [new tag]         0.0.3      -> 0.0.3
 * [new tag]         0.0.4      -> 0.0.4
 * [new tag]         0.0.5      -> 0.0.5
 * [new tag]         0.0.6      -> 0.0.6
 * [new tag]         0.0.7      -> 0.0.7
 * [new tag]         0.0.8      -> 0.0.8
 * [new tag]         0.0.9      -> 0.0.9
 * [new tag]         0.10.0     -> 0.10.0
 * [new tag]         0.10.1     -> 0.10.1
 * [new tag]         0.11.0     -> 0.11.0
 * [new tag]         0.11.1     -> 0.11.1
 * [new tag]         0.11.2     -> 0.11.2
 * [new tag]         0.11.3     -> 0.11.3
 * [new tag]         0.11.4     -> 0.11.4
 * [new tag]         0.12.0     -> 0.12.0
 * [new tag]         0.13.0     -> 0.13.0
 * [new tag]         0.13.1     -> 0.13.1
 * [new tag]         0.14.0     -> 0.14.0
 * [new tag]         0.15.0     -> 0.15.0
 * [new tag]         0.16.0     -> 0.16.0
 * [new tag]         0.16.1     -> 0.16.1
 * [new tag]         0.17.0     -> 0.17.0
 * [new tag]         0.17.1     -> 0.17.1
 * [new tag]         0.18.0     -> 0.18.0
 * [new tag]         0.19.0     -> 0.19.0
 * [new tag]         0.2.1      -> 0.2.1
 * [new tag]         0.2.2      -> 0.2.2
 * [new tag]         0.2.3      -> 0.2.3
 * [new tag]         0.2.4      -> 0.2.4
 * [new tag]         0.2.5      -> 0.2.5
 * [new tag]         0.20.0     -> 0.20.0
 * [new tag]         0.20.1     -> 0.20.1
 * [new tag]         0.20.2     -> 0.20.2
 * [new tag]         0.21.0     -> 0.21.0
 * [new tag]         0.21.1     -> 0.21.1
 * [new tag]         0.22.0     -> 0.22.0
 * [new tag]         0.23.0     -> 0.23.0
 * [new tag]         0.24.0     -> 0.24.0
 * [new tag]         0.24.1     -> 0.24.1
 * [new tag]         0.24.2     -> 0.24.2
 * [new tag]         0.25.0     -> 0.25.0
 * [new tag]         0.26.0     -> 0.26.0
 * [new tag]         0.26.1     -> 0.26.1
 * [new tag]         0.27.0     -> 0.27.0
 * [new tag]         0.27.1     -> 0.27.1
 * [new tag]         0.27.2     -> 0.27.2
 * [new tag]         0.27.3     -> 0.27.3
 * [new tag]         0.28.0     -> 0.28.0
 * [new tag]         0.28.1     -> 0.28.1
 * [new tag]         0.28.2     -> 0.28.2
 * [new tag]         0.29.0     -> 0.29.0
 * [new tag]         0.29.1     -> 0.29.1
 * [new tag]         0.3.2      -> 0.3.2
 * [new tag]         0.3.3      -> 0.3.3
 * [new tag]         0.3.4      -> 0.3.4
 * [new tag]         0.30.0     -> 0.30.0
 * [new tag]         0.30.1     -> 0.30.1
 * [new tag]         0.30.2     -> 0.30.2
 * [new tag]         0.30.3     -> 0.30.3
 * [new tag]         0.30.4     -> 0.30.4
 * [new tag]         0.30.5     -> 0.30.5
 * [new tag]         0.31.0     -> 0.31.0
 * [new tag]         0.31.1     -> 0.31.1
 * [new tag]         0.31.2     -> 0.31.2
 * [new tag]         0.31.3     -> 0.31.3
 * [new tag]         0.31.4     -> 0.31.4
 * [new tag]         0.31.5     -> 0.31.5
 * [new tag]         0.32.0     -> 0.32.0
 * [new tag]         0.32.1     -> 0.32.1
 * [new tag]         0.32.2     -> 0.32.2
 * [new tag]         0.33.0     -> 0.33.0
 * [new tag]         0.33.1     -> 0.33.1
 * [new tag]         0.33.2     -> 0.33.2
 * [new tag]         0.33.3     -> 0.33.3
 * [new tag]         0.33.4     -> 0.33.4
 * [new tag]         0.33.5     -> 0.33.5
 * [new tag]         0.34.0     -> 0.34.0
 * [new tag]         0.34.1     -> 0.34.1
 * [new tag]         0.34.2     -> 0.34.2
 * [new tag]         0.35.0     -> 0.35.0
 * [new tag]         0.36.0     -> 0.36.0
 * [new tag]         0.36.1     -> 0.36.1
 * [new tag]         0.37.0     -> 0.37.0
 * [new tag]         0.37.1     -> 0.37.1
 * [new tag]         0.37.2     -> 0.37.2
 * [new tag]         0.38.0     -> 0.38.0
 * [new tag]         0.39.0     -> 0.39.0
 * [new tag]         0.39.1     -> 0.39.1
 * [new tag]         0.4.1      -> 0.4.1
 * [new tag]         0.4.2      -> 0.4.2
 * [new tag]         0.40.0     -> 0.40.0
 * [new tag]         0.41.0     -> 0.41.0
 * [new tag]         0.41.1     -> 0.41.1
 * [new tag]         0.41.2     -> 0.41.2
 * [new tag]         0.42.0     -> 0.42.0
 * [new tag]         0.42.1     -> 0.42.1
 * [new tag]         0.43.0     -> 0.43.0
 * [new tag]         0.43.1     -> 0.43.1
 * [new tag]         0.43.2     -> 0.43.2
 * [new tag]         0.43.3     -> 0.43.3
 * [new tag]         0.6.1      -> 0.6.1
 * [new tag]         0.7.0      -> 0.7.0
 * [new tag]         0.7.1      -> 0.7.1
 * [new tag]         0.7.2      -> 0.7.2
 * [new tag]         0.7.3      -> 0.7.3
 * [new tag]         0.8.2      -> 0.8.2
 * [new tag]         0.9.1      -> 0.9.1
 * [new tag]         0.9.2      -> 0.9.2
 * [new tag]         0.9.3      -> 0.9.3
 * [new tag]         1.0.0      -> 1.0.0
 * [new tag]         1.0.1      -> 1.0.1
 * [new tag]         1.1.0      -> 1.1.0
 * [new tag]         1.1.1      -> 1.1.1
 * [new tag]         1.1.2      -> 1.1.2
 * [new tag]         1.1.3      -> 1.1.3
 * [new tag]         1.10.0     -> 1.10.0
 * [new tag]         1.10.1     -> 1.10.1
 * [new tag]         1.11.0     -> 1.11.0
 * [new tag]         1.11.1     -> 1.11.1
 * [new tag]         1.11.2     -> 1.11.2
 * [new tag]         1.11.3     -> 1.11.3
 * [new tag]         1.2.0      -> 1.2.0
 * [new tag]         1.2.1      -> 1.2.1
 * [new tag]         1.2.2      -> 1.2.2
 * [new tag]         1.2.3      -> 1.2.3
 * [new tag]         1.2.4      -> 1.2.4
 * [new tag]         1.2.5      -> 1.2.5
 * [new tag]         1.3.0      -> 1.3.0
 * [new tag]         1.3.1      -> 1.3.1
 * [new tag]         1.3.2      -> 1.3.2
 * [new tag]         1.3.3      -> 1.3.3
 * [new tag]         1.3.4      -> 1.3.4
 * [new tag]         1.3.5      -> 1.3.5
 * [new tag]         1.4.0      -> 1.4.0
 * [new tag]         1.4.1      -> 1.4.1
 * [new tag]         1.4.2      -> 1.4.2
 * [new tag]         1.4.3      -> 1.4.3
 * [new tag]         1.4.4      -> 1.4.4
 * [new tag]         1.5.0      -> 1.5.0
 * [new tag]         1.5.1      -> 1.5.1
 * [new tag]         1.5.2      -> 1.5.2
 * [new tag]         1.6.0      -> 1.6.0
 * [new tag]         1.6.1      -> 1.6.1
 * [new tag]         1.6.2      -> 1.6.2
 * [new tag]         1.7.0      -> 1.7.0
 * [new tag]         1.7.1      -> 1.7.1
 * [new tag]         1.7.2      -> 1.7.2
 * [new tag]         1.7.3      -> 1.7.3
 * [new tag]         1.7.4      -> 1.7.4
 * [new tag]         1.7.5      -> 1.7.5
 * [new tag]         1.7.6      -> 1.7.6
 * [new tag]         1.7.7      -> 1.7.7
 * [new tag]         1.8.0      -> 1.8.0
 * [new tag]         1.8.1      -> 1.8.1
 * [new tag]         1.9.0      -> 1.9.0
 * [new tag]         1.9.1      -> 1.9.1
 * [new tag]         1.9.2      -> 1.9.2
 * [new tag]         1.9.3      -> 1.9.3
 * [new tag]         1.9.4      -> 1.9.4
HEAD is now at 3d51c80 Memfault Firmware SDK 1.6.0 (Build 5464)
From https://github.com/zephyrproject-rtos/canopennode
 * [new tag]         zephyr-snapshot-1 -> zephyr-snapshot-1
HEAD is now at dec12fa stack: map CANopenNode crc16_ccitt() to Zephyr crc16_itu_t()
From https://github.com/zephyrproject-rtos/chre
HEAD is now at 3b32c76e zephyr: link the .unstable_id data in ROM
From https://github.com/zephyrproject-rtos/lz4
 * [new tag]         lz4-r130   -> lz4-r130
 * [new tag]         r116       -> r116
 * [new tag]         r117       -> r117
 * [new tag]         r118       -> r118
 * [new tag]         r119       -> r119
 * [new tag]         r120       -> r120
 * [new tag]         r121       -> r121
 * [new tag]         r122       -> r122
 * [new tag]         r123       -> r123
 * [new tag]         r124       -> r124
 * [new tag]         r125       -> r125
 * [new tag]         r126       -> r126
 * [new tag]         r127       -> r127
 * [new tag]         r128       -> r128
 * [new tag]         r129       -> r129
 * [new tag]         r130       -> r130
 * [new tag]         r131       -> r131
 * [new tag]         rc129v0    -> rc129v0
 * [new tag]         v1.7.3     -> v1.7.3
 * [new tag]         v1.7.4     -> v1.7.4
 * [new tag]         v1.7.4.2   -> v1.7.4.2
 * [new tag]         v1.7.5     -> v1.7.5
 * [new tag]         v1.8.1     -> v1.8.1
 * [new tag]         v1.8.1.2   -> v1.8.1.2
 * [new tag]         v1.8.2     -> v1.8.2
 * [new tag]         v1.8.3     -> v1.8.3
 * [new tag]         v1.9.3     -> v1.9.3
HEAD is now at 8e303c2 zephyr: make this repo a zephyr module
From https://github.com/zephyrproject-rtos/nanopb
 * [new branch]      cifuzz_test4           -> refs/west/cifuzz_test4
 * [new branch]      dev_dynamic_nanopb_pb2 -> refs/west/dev_dynamic_nanopb_pb2
 * [new branch]      dev_markdown_docs      -> refs/west/dev_markdown_docs
 * [new branch]      maintenance_0.1        -> refs/west/maintenance_0.1
 * [new branch]      maintenance_0.2        -> refs/west/maintenance_0.2
 * [new branch]      maintenance_0.3        -> refs/west/maintenance_0.3
 * [new tag]         0.2.9.5                -> 0.2.9.5
 * [new tag]         0.3.6                  -> 0.3.6
 * [new tag]         0.3.7                  -> 0.3.7
 * [new tag]         0.3.8                  -> 0.3.8
 * [new tag]         0.3.9                  -> 0.3.9
 * [new tag]         0.3.9.1                -> 0.3.9.1
 * [new tag]         0.3.9.2                -> 0.3.9.2
 * [new tag]         0.3.9.3                -> 0.3.9.3
 * [new tag]         0.3.9.4                -> 0.3.9.4
 * [new tag]         0.3.9.5                -> 0.3.9.5
 * [new tag]         0.3.9.6                -> 0.3.9.6
 * [new tag]         0.3.9.7                -> 0.3.9.7
 * [new tag]         0.3.9.8                -> 0.3.9.8
 * [new tag]         0.4.3                  -> 0.4.3
 * [new tag]         0.4.4                  -> 0.4.4
 * [new tag]         0.4.5                  -> 0.4.5
 * [new tag]         nanopb-0.1.0           -> nanopb-0.1.0
 * [new tag]         nanopb-0.1.1           -> nanopb-0.1.1
 * [new tag]         nanopb-0.1.2           -> nanopb-0.1.2
 * [new tag]         nanopb-0.1.3           -> nanopb-0.1.3
 * [new tag]         nanopb-0.1.4           -> nanopb-0.1.4
 * [new tag]         nanopb-0.1.5           -> nanopb-0.1.5
 * [new tag]         nanopb-0.1.6           -> nanopb-0.1.6
 * [new tag]         nanopb-0.1.7           -> nanopb-0.1.7
 * [new tag]         nanopb-0.1.8           -> nanopb-0.1.8
 * [new tag]         nanopb-0.1.9           -> nanopb-0.1.9
 * [new tag]         nanopb-0.1.9.1         -> nanopb-0.1.9.1
 * [new tag]         nanopb-0.2.0           -> nanopb-0.2.0
 * [new tag]         nanopb-0.2.1           -> nanopb-0.2.1
 * [new tag]         nanopb-0.2.2           -> nanopb-0.2.2
 * [new tag]         nanopb-0.2.3           -> nanopb-0.2.3
 * [new tag]         nanopb-0.2.4           -> nanopb-0.2.4
 * [new tag]         nanopb-0.2.5           -> nanopb-0.2.5
 * [new tag]         nanopb-0.2.6           -> nanopb-0.2.6
 * [new tag]         nanopb-0.2.7           -> nanopb-0.2.7
 * [new tag]         nanopb-0.2.8           -> nanopb-0.2.8
 * [new tag]         nanopb-0.2.9           -> nanopb-0.2.9
 * [new tag]         nanopb-0.2.9.1         -> nanopb-0.2.9.1
 * [new tag]         nanopb-0.2.9.2         -> nanopb-0.2.9.2
 * [new tag]         nanopb-0.2.9.3         -> nanopb-0.2.9.3
 * [new tag]         nanopb-0.2.9.4         -> nanopb-0.2.9.4
 * [new tag]         nanopb-0.2.9.5         -> nanopb-0.2.9.5
 * [new tag]         nanopb-0.3.0           -> nanopb-0.3.0
 * [new tag]         nanopb-0.3.1           -> nanopb-0.3.1
 * [new tag]         nanopb-0.3.2           -> nanopb-0.3.2
 * [new tag]         nanopb-0.3.3           -> nanopb-0.3.3
 * [new tag]         nanopb-0.3.4           -> nanopb-0.3.4
 * [new tag]         nanopb-0.3.5           -> nanopb-0.3.5
 * [new tag]         nanopb-0.3.6           -> nanopb-0.3.6
 * [new tag]         nanopb-0.3.7           -> nanopb-0.3.7
 * [new tag]         nanopb-0.3.8           -> nanopb-0.3.8
 * [new tag]         nanopb-0.3.9           -> nanopb-0.3.9
 * [new tag]         nanopb-0.3.9.1         -> nanopb-0.3.9.1
 * [new tag]         nanopb-0.3.9.2         -> nanopb-0.3.9.2
 * [new tag]         nanopb-0.3.9.3         -> nanopb-0.3.9.3
 * [new tag]         nanopb-0.3.9.4         -> nanopb-0.3.9.4
 * [new tag]         nanopb-0.3.9.5         -> nanopb-0.3.9.5
 * [new tag]         nanopb-0.3.9.6         -> nanopb-0.3.9.6
 * [new tag]         nanopb-0.3.9.7         -> nanopb-0.3.9.7
 * [new tag]         nanopb-0.3.9.8         -> nanopb-0.3.9.8
 * [new tag]         nanopb-0.4.0           -> nanopb-0.4.0
 * [new tag]         nanopb-0.4.0-dev       -> nanopb-0.4.0-dev
 * [new tag]         nanopb-0.4.1           -> nanopb-0.4.1
 * [new tag]         nanopb-0.4.2           -> nanopb-0.4.2
 * [new tag]         nanopb-0.4.3           -> nanopb-0.4.3
 * [new tag]         nanopb-0.4.4           -> nanopb-0.4.4
 * [new tag]         nanopb-0.4.5           -> nanopb-0.4.5
HEAD is now at 42fa8b2 Merge pull request #2 from pdgendt/zephyr
From https://github.com/zephyrproject-rtos/tf-m-tests
 * [new branch]      release/1.7.x -> refs/west/release/1.7.x
HEAD is now at 08a3158 Merge pull request #8 from mswarowsky/tfm_20_upmerge
From https://github.com/zephyrproject-rtos/zscilib
 * [new branch]      gh-pages   -> refs/west/gh-pages
 * [new branch]      revert-38-fix_zephyr_3_1 -> refs/west/revert-38-fix_zephyr_3_1
 * [new tag]         v0.2.0-rc1 -> v0.2.0-rc1
HEAD is now at 34a94b0 Merge pull request #55 from nashif/remove_ztest_config
From https://github.com/zephyrproject-rtos/cmsis
HEAD is now at 4b96cbb doc: Update documentations for CMSIS 5.9.0
From https://github.com/zephyrproject-rtos/cmsis-dsp
HEAD is now at ff7b5fd1 compute Library: fix inline function that is not static
From https://github.com/zephyrproject-rtos/cmsis-nn
 * [new branch]      zephyr-v6.0.0 -> refs/west/zephyr-v6.0.0
HEAD is now at 0c8669d Merge pull request #1 from XenuIsWatching/zephyr
From https://github.com/zephyrproject-rtos/edtt
 * [new branch]      le-audio      -> refs/west/le-audio
 * [new branch]      public_master -> refs/west/public_master
HEAD is now at 64e5105 edttt_bsim: Avoid infinite exception loop
From https://github.com/zephyrproject-rtos/fatfs
HEAD is now at 427159b zephyr: fix ffconf.h override use of STRINGIZE
From https://github.com/zephyrproject-rtos/hal_nordic
 * [new branch]      dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3 -> refs/west/dependabot/pip/nrfx/samples/doc/sphinx/jinja2-3.1.3
 * [new tag]         nrfx-2.10.0  -> nrfx-2.10.0
 * [new tag]         nrfx-2.11.0  -> nrfx-2.11.0
 * [new tag]         nrfx-3.0.0   -> nrfx-3.0.0
HEAD is now at 5470822 nrfx: Fix compilation failures in nrfx_gppi_dppi_ppib.c
From https://github.com/zephyrproject-rtos/hal_st
HEAD is now at fb8e79d sensor/vl53l1x api/core call to VL53L1_GetTickCount function
From https://github.com/zephyrproject-rtos/hal_wurthelektronik
HEAD is now at 24ca987 Initialized WE HAL module repository.
From https://github.com/zephyrproject-rtos/libmetal
HEAD is now at 03140d7 Zephyr integration: Add support for hosted test environment
From https://github.com/zephyrproject-rtos/liblc3
HEAD is now at 448f3de Merge pull request #8 from carlescufi/rename
From https://github.com/zephyrproject-rtos/littlefs
 * [new tag]         littlefs-v2.1.0 -> littlefs-v2.1.0
 * [new tag]         littlefs-v2.1.1 -> littlefs-v2.1.1
 * [new tag]         littlefs-v2.1.2 -> littlefs-v2.1.2
 * [new tag]         littlefs-v2.1.3 -> littlefs-v2.1.3
 * [new tag]         littlefs-v2.1.4 -> littlefs-v2.1.4
 * [new tag]         littlefs-v2.2.0 -> littlefs-v2.2.0
HEAD is now at ca583fd Merge tag 'v2.5.0' of https://github.com/littlefs-project/littlefs into zephyr
From https://github.com/zephyrproject-rtos/loramac-node
 * [new branch]        v4.5.2-zephyr -> refs/west/v4.5.2-zephyr
 * [new branch]        v4.6.0-zephyr -> refs/west/v4.6.0-zephyr
 * [new branch]        v4.7.0-zephyr -> refs/west/v4.7.0-zephyr
 * [new branch]        zephyr-v2.6   -> refs/west/zephyr-v2.6
 * [new tag]           4.4.2-rc.4    -> 4.4.2-rc.4
 * [new tag]           V3.4          -> V3.4
 * [new tag]           v2.0          -> v2.0
 * [new tag]           v2.1          -> v2.1
 * [new tag]           v2.2          -> v2.2
 * [new tag]           v2.3.RC1      -> v2.3.RC1
 * [new tag]           v2.3.RC2      -> v2.3.RC2
 * [new tag]           v3.0          -> v3.0
 * [new tag]           v3.1          -> v3.1
 * [new tag]           v3.2          -> v3.2
 * [new tag]           v3.3          -> v3.3
 * [new tag]           v3.4.1        -> v3.4.1
 * [new tag]           v4.0.0        -> v4.0.0
 * [new tag]           v4.1.0        -> v4.1.0
 * [new tag]           v4.2.0        -> v4.2.0
 * [new tag]           v4.3.0        -> v4.3.0
 * [new tag]           v4.3.1        -> v4.3.1
 * [new tag]           v4.3.2        -> v4.3.2
 * [new tag]           v4.4.0        -> v4.4.0
 * [new tag]           v4.4.1        -> v4.4.1
 * [new tag]           v4.4.2        -> v4.4.2
 * [new tag]           v4.4.2-rc.1   -> v4.4.2-rc.1
 * [new tag]           v4.4.2-rc.2   -> v4.4.2-rc.2
 * [new tag]           v4.4.2-rc.3   -> v4.4.2-rc.3
 * [new tag]           v4.4.2-rc.5   -> v4.4.2-rc.5
 * [new tag]           v4.4.2-rc.6   -> v4.4.2-rc.6
 * [new tag]           v4.4.2-rc.7   -> v4.4.2-rc.7
 * [new tag]           v4.4.3        -> v4.4.3
 * [new tag]           v4.4.3_zephyr -> v4.4.3_zephyr
HEAD is now at 842413c5 utilities: fix one more shadowed variable
From https://github.com/zephyrproject-rtos/lvgl
HEAD is now at 7c61a4ce zephyr: Kconfig: Add guard checking for LVGL module
From https://github.com/zephyrproject-rtos/mipi-sys-t
HEAD is now at a819419 library: allow building without wchar support
From https://github.com/zephyrproject-rtos/net-tools
HEAD is now at d68ee9d docker: Add Leshan demo server
From https://github.com/zephyrproject-rtos/nrf_hw_models
HEAD is now at 52d0b4b UART: FIFO backend: Do not error out if other side disconnects Rx
From https://github.com/zephyrproject-rtos/open-amp
 * [new branch]      bump_v2024.05.0 -> refs/west/bump_v2024.05.0
 * [new tag]         old_master      -> old_master
HEAD is now at 214f9fc cmake: Compile with WITH_DCACHE
From https://github.com/zephyrproject-rtos/picolibc
 * [new branch]          Z-emcb-cygwin_daemon        -> refs/west/Z-emcb-cygwin_daemon
 * [new branch]          aarch64                     -> refs/west/aarch64
 * [new branch]          add-fakeroots-dir           -> refs/west/add-fakeroots-dir
 * [new branch]          amd64_to_x86_64             -> refs/west/amd64_to_x86_64
 * [new branch]          ancient-clang               -> refs/west/ancient-clang
 * [new branch]          arc-20081103-branch         -> refs/west/arc-20081103-branch
 * [new branch]          arc-insight_6_8-branch      -> refs/west/arc-insight_6_8-branch
 * [new branch]          arm-read-tp-cleanup         -> refs/west/arm-read-tp-cleanup
 * [new branch]          binutils-2_10-branch        -> refs/west/binutils-2_10-branch
 * [new branch]          binutils-2_11-branch        -> refs/west/binutils-2_11-branch
 * [new branch]          binutils-2_12-branch        -> refs/west/binutils-2_12-branch
 * [new branch]          binutils-2_13-branch        -> refs/west/binutils-2_13-branch
 * [new branch]          binutils-2_14-branch        -> refs/west/binutils-2_14-branch
 * [new branch]          binutils-2_15-branch        -> refs/west/binutils-2_15-branch
 * [new branch]          binutils-2_16-branch        -> refs/west/binutils-2_16-branch
 * [new branch]          binutils-2_17-branch        -> refs/west/binutils-2_17-branch
 * [new branch]          binutils-2_18-branch        -> refs/west/binutils-2_18-branch
 * [new branch]          binutils-2_19-branch        -> refs/west/binutils-2_19-branch
 * [new branch]          binutils-2_20-branch        -> refs/west/binutils-2_20-branch
 * [new branch]          binutils-2_21-branch        -> refs/west/binutils-2_21-branch
 * [new branch]          binutils-2_22-branch        -> refs/west/binutils-2_22-branch
 * [new branch]          binutils-2_22_branch        -> refs/west/binutils-2_22_branch
 * [new branch]          binutils-2_23-branch        -> refs/west/binutils-2_23-branch
 * [new branch]          binutils-2_24-branch        -> refs/west/binutils-2_24-branch
 * [new branch]          binutils-arc-20080908-branch -> refs/west/binutils-arc-20080908-branch
 * [new branch]          binutils-arc-20081103-branch -> refs/west/binutils-arc-20081103-branch
 * [new branch]          binutils-csl-2_17-branch    -> refs/west/binutils-csl-2_17-branch
 * [new branch]          binutils-csl-arm-2005q1-branch -> refs/west/binutils-csl-arm-2005q1-branch
 * [new branch]          binutils-csl-gxxpro-3_4-branch -> refs/west/binutils-csl-gxxpro-3_4-branch
 * [new branch]          branch-1.4.6                -> refs/west/branch-1.4.6
 * [new branch]          branch-1.8.4                -> refs/west/branch-1.8.4
 * [new branch]          c-sky                       -> refs/west/c-sky
 * [new branch]          cagney-unwind-20030108-branch -> refs/west/cagney-unwind-20030108-branch
 * [new branch]          cagney_bfdfile-20040213-branch -> refs/west/cagney_bfdfile-20040213-branch
 * [new branch]          cagney_bigcore-20040122-branch -> refs/west/cagney_bigcore-20040122-branch
 * [new branch]          cagney_convert-20030606-branch -> refs/west/cagney_convert-20030606-branch
 * [new branch]          cagney_fileio-20030521-branch -> refs/west/cagney_fileio-20030521-branch
 * [new branch]          cagney_frameaddr-20030403-branch -> refs/west/cagney_frameaddr-20030403-branch
 * [new branch]          cagney_framebase-20030326-branch -> refs/west/cagney_framebase-20030326-branch
 * [new branch]          cagney_lazyid-20030317-branch -> refs/west/cagney_lazyid-20030317-branch
 * [new branch]          cagney_offbyone-20030303-branch -> refs/west/cagney_offbyone-20030303-branch
 * [new branch]          cagney_regbuf-20020515-branch -> refs/west/cagney_regbuf-20020515-branch
 * [new branch]          cagney_sysregs-20020825-branch -> refs/west/cagney_sysregs-20020825-branch
 * [new branch]          cagney_tramp-20040309-branch -> refs/west/cagney_tramp-20040309-branch
 * [new branch]          cagney_writestrings-20030508-branch -> refs/west/cagney_writestrings-20030508-branch
 * [new branch]          cagney_x86i386-20030821-branch -> refs/west/cagney_x86i386-20030821-branch
 * [new branch]          callout                     -> refs/west/callout
 * [new branch]          carlton_dictionary-branch   -> refs/west/carlton_dictionary-branch
 * [new branch]          cgen-1_1-branch             -> refs/west/cgen-1_1-branch
 * [new branch]          cgf-deleteme                -> refs/west/cgf-deleteme
 * [new branch]          cgf-dev-branch              -> refs/west/cgf-dev-branch
 * [new branch]          cmake                       -> refs/west/cmake
 * [new branch]          cmake-no-tls                -> refs/west/cmake-no-tls
 * [new branch]          cmake-small-ultoa           -> refs/west/cmake-small-ultoa
 * [new branch]          cr-0x3b58                   -> refs/west/cr-0x3b58
 * [new branch]          cr-0x5e6                    -> refs/west/cr-0x5e6
 * [new branch]          cr-0x5ef                    -> refs/west/cr-0x5ef
 * [new branch]          cr-0x5f1                    -> refs/west/cr-0x5f1
 * [new branch]          cr-0x9b                     -> refs/west/cr-0x9b
 * [new branch]          cr-0x9c                     -> refs/west/cr-0x9c
 * [new branch]          cr-0x9d                     -> refs/west/cr-0x9d
 * [new branch]          cr-0x9e                     -> refs/west/cr-0x9e
 * [new branch]          csl-arm-20050325-branch     -> refs/west/csl-arm-20050325-branch
 * [new branch]          cv-branch                   -> refs/west/cv-branch
 * [new branch]          cv-branch-2                 -> refs/west/cv-branch-2
 * [new branch]          cv-post-1_7_9               -> refs/west/cv-post-1_7_9
 * [new branch]          cygnus                      -> refs/west/cygnus
 * [new branch]          cygwin-1-1-4                -> refs/west/cygwin-1-1-4
 * [new branch]          cygwin-1-3-1                -> refs/west/cygwin-1-3-1
 * [new branch]          cygwin-1-3-10-1             -> refs/west/cygwin-1-3-10-1
 * [new branch]          cygwin-1-3-11-3             -> refs/west/cygwin-1-3-11-3
 * [new branch]          cygwin-1-3-12-1             -> refs/west/cygwin-1-3-12-1
 * [new branch]          cygwin-1-3-13-1             -> refs/west/cygwin-1-3-13-1
 * [new branch]          cygwin-1-3-13-2             -> refs/west/cygwin-1-3-13-2
 * [new branch]          cygwin-1-3-14-1             -> refs/west/cygwin-1-3-14-1
 * [new branch]          cygwin-1-3-15-1             -> refs/west/cygwin-1-3-15-1
 * [new branch]          cygwin-1-3-16-1             -> refs/west/cygwin-1-3-16-1
 * [new branch]          cygwin-1-3-17-1             -> refs/west/cygwin-1-3-17-1
 * [new branch]          cygwin-1-3-18-1             -> refs/west/cygwin-1-3-18-1
 * [new branch]          cygwin-1-3-19-1             -> refs/west/cygwin-1-3-19-1
 * [new branch]          cygwin-1-3-2                -> refs/west/cygwin-1-3-2
 * [new branch]          cygwin-1-3-3                -> refs/west/cygwin-1-3-3
 * [new branch]          cygwin-1-3-4                -> refs/west/cygwin-1-3-4
 * [new branch]          cygwin-1-3-5                -> refs/west/cygwin-1-3-5
 * [new branch]          cygwin-1-3-5-2              -> refs/west/cygwin-1-3-5-2
 * [new branch]          cygwin-1-3-5-3              -> refs/west/cygwin-1-3-5-3
 * [new branch]          cygwin-1-3-6-1              -> refs/west/cygwin-1-3-6-1
 * [new branch]          cygwin-1-3-6-2              -> refs/west/cygwin-1-3-6-2
 * [new branch]          cygwin-1-3-6-3              -> refs/west/cygwin-1-3-6-3
 * [new branch]          cygwin-1-3-6-4              -> refs/west/cygwin-1-3-6-4
 * [new branch]          cygwin-1-3-6-5              -> refs/west/cygwin-1-3-6-5
 * [new branch]          cygwin-1-3-6-6              -> refs/west/cygwin-1-3-6-6
 * [new branch]          cygwin-1-3-7-1              -> refs/west/cygwin-1-3-7-1
 * [new branch]          cygwin-1-3-8-1              -> refs/west/cygwin-1-3-8-1
 * [new branch]          cygwin-1-3-9                -> refs/west/cygwin-1-3-9
 * [new branch]          cygwin-1_7_29-release-branchpoint -> refs/west/cygwin-1_7_29-release-branchpoint
 * [new branch]          cygwin-2.0                  -> refs/west/cygwin-2.0
 * [new branch]          cygwin-3_0-branch           -> refs/west/cygwin-3_0-branch
 * [new branch]          cygwin-64bit-branch         -> refs/west/cygwin-64bit-branch
 * [new branch]          cygwin-64bit-premerge-branch -> refs/west/cygwin-64bit-premerge-branch
 * [new branch]          cygwin-acl                  -> refs/west/cygwin-acl
 * [new branch]          cygwin_daemon               -> refs/west/cygwin_daemon
 * [new branch]          debian                      -> refs/west/debian
 * [new branch]          dje-cgen-play1-branch       -> refs/west/dje-cgen-play1-branch
 * [new branch]          docker-builder-packages.txt-hash -> refs/west/docker-builder-packages.txt-hash
 * [new branch]          drow-cplus-branch           -> refs/west/drow-cplus-branch
 * [new branch]          drow-reverse-20070409-branch -> refs/west/drow-reverse-20070409-branch
 * [new branch]          drow_intercu-20040221-branch -> refs/west/drow_intercu-20040221-branch
 * [new branch]          ezannoni_pie-20030916-branch -> refs/west/ezannoni_pie-20030916-branch
 * [new branch]          ezannoni_pie-20040323-branch -> refs/west/ezannoni_pie-20040323-branch
 * [new branch]          fifo_doover3                -> refs/west/fifo_doover3
 * [new branch]          fixes-newlib                -> refs/west/fixes-newlib
 * [new branch]          float-inlines               -> refs/west/float-inlines
 * [new branch]          fp-zeuch                    -> refs/west/fp-zeuch
 * [new branch]          gdb-csl-20060226-branch     -> refs/west/gdb-csl-20060226-branch
 * [new branch]          gdb-csl-arm-20051020-branch -> refs/west/gdb-csl-arm-20051020-branch
 * [new branch]          gdb-csl-available-20060303-branch -> refs/west/gdb-csl-available-20060303-branch
 * [new branch]          gdb-csl-gxxpro-6_3-branch   -> refs/west/gdb-csl-gxxpro-6_3-branch
 * [new branch]          gdb-csl-symbian-20060226-branch -> refs/west/gdb-csl-symbian-20060226-branch
 * [new branch]          gdb-premipsmulti-2000-06-06-branch -> refs/west/gdb-premipsmulti-2000-06-06-branch
 * [new branch]          gdb_5_0-2000-04-10-branch   -> refs/west/gdb_5_0-2000-04-10-branch
 * [new branch]          gdb_5_1-2001-07-29-branch   -> refs/west/gdb_5_1-2001-07-29-branch
 * [new branch]          gdb_5_1_0_1-2002-01-03-branch -> refs/west/gdb_5_1_0_1-2002-01-03-branch
 * [new branch]          gdb_5_2-branch              -> refs/west/gdb_5_2-branch
 * [new branch]          gdb_5_3-branch              -> refs/west/gdb_5_3-branch
 * [new branch]          gdb_6_0-branch              -> refs/west/gdb_6_0-branch
 * [new branch]          gdb_6_1-branch              -> refs/west/gdb_6_1-branch
 * [new branch]          gdb_6_2-branch              -> refs/west/gdb_6_2-branch
 * [new branch]          gdb_6_3-branch              -> refs/west/gdb_6_3-branch
 * [new branch]          gdb_6_4-branch              -> refs/west/gdb_6_4-branch
 * [new branch]          gdb_6_5-branch              -> refs/west/gdb_6_5-branch
 * [new branch]          gdb_6_6-branch              -> refs/west/gdb_6_6-branch
 * [new branch]          gdb_6_7-branch              -> refs/west/gdb_6_7-branch
 * [new branch]          gdb_6_8-branch              -> refs/west/gdb_6_8-branch
 * [new branch]          gdb_7_0-branch              -> refs/west/gdb_7_0-branch
 * [new branch]          gdb_7_1-branch              -> refs/west/gdb_7_1-branch
 * [new branch]          gdb_7_2-branch              -> refs/west/gdb_7_2-branch
 * [new branch]          gdb_7_3-branch              -> refs/west/gdb_7_3-branch
 * [new branch]          gdb_7_4-branch              -> refs/west/gdb_7_4-branch
 * [new branch]          gdb_7_5-branch              -> refs/west/gdb_7_5-branch
 * [new branch]          gdb_7_6-branch              -> refs/west/gdb_7_6-branch
 * [new branch]          gdb_s390-2001-09-26-branch  -> refs/west/gdb_s390-2001-09-26-branch
 * [new branch]          gh                          -> refs/west/gh
 * [new branch]          insight_6_8-branch          -> refs/west/insight_6_8-branch
 * [new branch]          interps-20030202-branch     -> refs/west/interps-20030202-branch
 * [new branch]          isblank-extern-inline       -> refs/west/isblank-extern-inline
 * [new branch]          jimb-gdb_6_2-e500-branch    -> refs/west/jimb-gdb_6_2-e500-branch
 * [new branch]          jimb-macro-020506-branch    -> refs/west/jimb-macro-020506-branch
 * [new branch]          jimb-ppc64-linux-20030509-branch -> refs/west/jimb-ppc64-linux-20030509-branch
 * [new branch]          jimb-ppc64-linux-20030528-branch -> refs/west/jimb-ppc64-linux-20030528-branch
 * [new branch]          jimb-ppc64-linux-20030613-branch -> refs/west/jimb-ppc64-linux-20030613-branch
 * [new branch]          jimb-rda-nptl-branch        -> refs/west/jimb-rda-nptl-branch
 * [new branch]          kettenis-i386newframe-20030308-branch -> refs/west/kettenis-i386newframe-20030308-branch
 * [new branch]          kettenis_i386newframe-20030406-branch -> refs/west/kettenis_i386newframe-20030406-branch
 * [new branch]          kettenis_i386newframe-20030419-branch -> refs/west/kettenis_i386newframe-20030419-branch
 * [new branch]          kettenis_sparc-20030918-branch -> refs/west/kettenis_sparc-20030918-branch
 * [new branch]          kseitz_interps-20020528-branch -> refs/west/kseitz_interps-20020528-branch
 * [new branch]          locking-docs                -> refs/west/locking-docs
 * [new branch]          mingw-std-ns-branch         -> refs/west/mingw-std-ns-branch
 * [new branch]          mingwex                     -> refs/west/mingwex
 * [new branch]          msnyder-checkpoint-072509-branch -> refs/west/msnyder-checkpoint-072509-branch
 * [new branch]          msnyder-fork-checkpoint-branch -> refs/west/msnyder-fork-checkpoint-branch
 * [new branch]          msnyder-reverse-20060331-branch -> refs/west/msnyder-reverse-20060331-branch
 * [new branch]          msnyder-reverse-20060502-branch -> refs/west/msnyder-reverse-20060502-branch
 * [new branch]          msnyder-reverse-20080609-branch -> refs/west/msnyder-reverse-20080609-branch
 * [new branch]          msnyder-tracepoint-checkpoint-branch -> refs/west/msnyder-tracepoint-checkpoint-branch
 * [new branch]          msp430                      -> refs/west/msp430
 * [new branch]          multiprocess-20081120-branch -> refs/west/multiprocess-20081120-branch
 * [new branch]          newlib                      -> refs/west/newlib
 * [new branch]          newlib-1_17_0-arc           -> refs/west/newlib-1_17_0-arc
 * [new branch]          newlib-autotools-branch     -> refs/west/newlib-autotools-branch
 * [new branch]          newlib-csl-20060320-branch  -> refs/west/newlib-csl-20060320-branch
 * [new branch]          nickrob-async-20060513-branch -> refs/west/nickrob-async-20060513-branch
 * [new branch]          non-linux-ln                -> refs/west/non-linux-ln
 * [new branch]          noreparent                  -> refs/west/noreparent
 * [new branch]          offbyone-20030313-branch    -> refs/west/offbyone-20030313-branch
 * [new branch]          pre-regex                   -> refs/west/pre-regex
 * [new branch]          pregp02r1                   -> refs/west/pregp02r1
 * [new branch]          readline_4_3-import-branch  -> refs/west/readline_4_3-import-branch
 * [new branch]          readline_5_1-import-branch  -> refs/west/readline_5_1-import-branch
 * [new branch]          reverse-20080717-branch     -> refs/west/reverse-20080717-branch
 * [new branch]          reverse-20080930-branch     -> refs/west/reverse-20080930-branch
 * [new branch]          reverse-20081226-branch     -> refs/west/reverse-20081226-branch
 * [new branch]          riscv-zicsr                 -> refs/west/riscv-zicsr
 * [new branch]          semihost-2.0-all            -> refs/west/semihost-2.0-all
 * [new branch]          sid-20020905-branch         -> refs/west/sid-20020905-branch
 * [new branch]          signal-rewrite              -> refs/west/signal-rewrite
 * [new branch]          sysroot-skip-checks         -> refs/west/sysroot-skip-checks
 * [new branch]          tcltk840-20020924-branch    -> refs/west/tcltk840-20020924-branch
 * [new branch]          tls                         -> refs/west/tls
 * [new branch]          topic/af_unix               -> refs/west/topic/af_unix
 * [new branch]          topic/ansification          -> refs/west/topic/ansification
 * [new branch]          topic/fifo                  -> refs/west/topic/fifo
 * [new branch]          topic/forkables             -> refs/west/topic/forkables
 * [new branch]          topic/locales               -> refs/west/topic/locales
 * [new branch]          topic/posix_acl_funcs       -> refs/west/topic/posix_acl_funcs
 * [new branch]          topic/ssp                   -> refs/west/topic/ssp
 * [new branch]          unlabeled-1.1.1.1.2         -> refs/west/unlabeled-1.1.1.1.2
 * [new branch]          unlabeled-1.100.2           -> refs/west/unlabeled-1.100.2
 * [new branch]          unlabeled-1.1010.2          -> refs/west/unlabeled-1.1010.2
 * [new branch]          unlabeled-1.1019.2          -> refs/west/unlabeled-1.1019.2
 * [new branch]          unlabeled-1.1042.2          -> refs/west/unlabeled-1.1042.2
 * [new branch]          unlabeled-1.1042.2.1.4      -> refs/west/unlabeled-1.1042.2.1.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4  -> refs/west/unlabeled-1.1042.2.1.4.2.4
 * [new branch]          unlabeled-1.1042.2.1.4.2.4.2.2 -> refs/west/unlabeled-1.1042.2.1.4.2.4.2.2
 * [new branch]          unlabeled-1.105.2           -> refs/west/unlabeled-1.105.2
 * [new branch]          unlabeled-1.106.2           -> refs/west/unlabeled-1.106.2
 * [new branch]          unlabeled-1.106.8           -> refs/west/unlabeled-1.106.8
 * [new branch]          unlabeled-1.107.12          -> refs/west/unlabeled-1.107.12
 * [new branch]          unlabeled-1.11.2            -> refs/west/unlabeled-1.11.2
 * [new branch]          unlabeled-1.112.4           -> refs/west/unlabeled-1.112.4
 * [new branch]          unlabeled-1.116.4           -> refs/west/unlabeled-1.116.4
 * [new branch]          unlabeled-1.12.20           -> refs/west/unlabeled-1.12.20
 * [new branch]          unlabeled-1.12.30           -> refs/west/unlabeled-1.12.30
 * [new branch]          unlabeled-1.12.4            -> refs/west/unlabeled-1.12.4
 * [new branch]          unlabeled-1.120.2           -> refs/west/unlabeled-1.120.2
 * [new branch]          unlabeled-1.125.2           -> refs/west/unlabeled-1.125.2
 * [new branch]          unlabeled-1.13.10           -> refs/west/unlabeled-1.13.10
 * [new branch]          unlabeled-1.13.2            -> refs/west/unlabeled-1.13.2
 * [new branch]          unlabeled-1.13.30           -> refs/west/unlabeled-1.13.30
 * [new branch]          unlabeled-1.13.4            -> refs/west/unlabeled-1.13.4
 * [new branch]          unlabeled-1.133.2           -> refs/west/unlabeled-1.133.2
 * [new branch]          unlabeled-1.134.4           -> refs/west/unlabeled-1.134.4
 * [new branch]          unlabeled-1.135.4           -> refs/west/unlabeled-1.135.4
 * [new branch]          unlabeled-1.1370.2          -> refs/west/unlabeled-1.1370.2
 * [new branch]          unlabeled-1.142.2           -> refs/west/unlabeled-1.142.2
 * [new branch]          unlabeled-1.143.4           -> refs/west/unlabeled-1.143.4
 * [new branch]          unlabeled-1.144.2           -> refs/west/unlabeled-1.144.2
 * [new branch]          unlabeled-1.15.10           -> refs/west/unlabeled-1.15.10
 * [new branch]          unlabeled-1.15.2            -> refs/west/unlabeled-1.15.2
 * [new branch]          unlabeled-1.1527.4          -> refs/west/unlabeled-1.1527.4
 * [new branch]          unlabeled-1.153.2           -> refs/west/unlabeled-1.153.2
 * [new branch]          unlabeled-1.1563.2          -> refs/west/unlabeled-1.1563.2
 * [new branch]          unlabeled-1.1656.2          -> refs/west/unlabeled-1.1656.2
 * [new branch]          unlabeled-1.167.4           -> refs/west/unlabeled-1.167.4
 * [new branch]          unlabeled-1.17.2            -> refs/west/unlabeled-1.17.2
 * [new branch]          unlabeled-1.17.4            -> refs/west/unlabeled-1.17.4
 * [new branch]          unlabeled-1.1710.2          -> refs/west/unlabeled-1.1710.2
 * [new branch]          unlabeled-1.172.4           -> refs/west/unlabeled-1.172.4
 * [new branch]          unlabeled-1.18.10           -> refs/west/unlabeled-1.18.10
 * [new branch]          unlabeled-1.18.2            -> refs/west/unlabeled-1.18.2
 * [new branch]          unlabeled-1.1806.2          -> refs/west/unlabeled-1.1806.2
 * [new branch]          unlabeled-1.1856.2          -> refs/west/unlabeled-1.1856.2
 * [new branch]          unlabeled-1.188.2           -> refs/west/unlabeled-1.188.2
 * [new branch]          unlabeled-1.188.2.1.8       -> refs/west/unlabeled-1.188.2.1.8
 * [new branch]          unlabeled-1.188.2.1.8.2.2   -> refs/west/unlabeled-1.188.2.1.8.2.2
 * [new branch]          unlabeled-1.19.12           -> refs/west/unlabeled-1.19.12
 * [new branch]          unlabeled-1.2.2             -> refs/west/unlabeled-1.2.2
 * [new branch]          unlabeled-1.20.4            -> refs/west/unlabeled-1.20.4
 * [new branch]          unlabeled-1.21.2            -> refs/west/unlabeled-1.21.2
 * [new branch]          unlabeled-1.21.4            -> refs/west/unlabeled-1.21.4
 * [new branch]          unlabeled-1.22.2            -> refs/west/unlabeled-1.22.2
 * [new branch]          unlabeled-1.22.4            -> refs/west/unlabeled-1.22.4
 * [new branch]          unlabeled-1.226.2           -> refs/west/unlabeled-1.226.2
 * [new branch]          unlabeled-1.23.16           -> refs/west/unlabeled-1.23.16
 * [new branch]          unlabeled-1.23.2            -> refs/west/unlabeled-1.23.2
 * [new branch]          unlabeled-1.23.4            -> refs/west/unlabeled-1.23.4
 * [new branch]          unlabeled-1.231.4           -> refs/west/unlabeled-1.231.4
 * [new branch]          unlabeled-1.234.16          -> refs/west/unlabeled-1.234.16
 * [new branch]          unlabeled-1.235.2           -> refs/west/unlabeled-1.235.2
 * [new branch]          unlabeled-1.238.4           -> refs/west/unlabeled-1.238.4
 * [new branch]          unlabeled-1.24.16           -> refs/west/unlabeled-1.24.16
 * [new branch]          unlabeled-1.24.2            -> refs/west/unlabeled-1.24.2
 * [new branch]          unlabeled-1.24.4            -> refs/west/unlabeled-1.24.4
 * [new branch]          unlabeled-1.248.2           -> refs/west/unlabeled-1.248.2
 * [new branch]          unlabeled-1.253.2           -> refs/west/unlabeled-1.253.2
 * [new branch]          unlabeled-1.27.12           -> refs/west/unlabeled-1.27.12
 * [new branch]          unlabeled-1.27.8            -> refs/west/unlabeled-1.27.8
 * [new branch]          unlabeled-1.30.4            -> refs/west/unlabeled-1.30.4
 * [new branch]          unlabeled-1.31.4            -> refs/west/unlabeled-1.31.4
 * [new branch]          unlabeled-1.32.16           -> refs/west/unlabeled-1.32.16
 * [new branch]          unlabeled-1.32.2            -> refs/west/unlabeled-1.32.2
 * [new branch]          unlabeled-1.35.12           -> refs/west/unlabeled-1.35.12
 * [new branch]          unlabeled-1.38.4            -> refs/west/unlabeled-1.38.4
 * [new branch]          unlabeled-1.39.2            -> refs/west/unlabeled-1.39.2
 * [new branch]          unlabeled-1.44.2            -> refs/west/unlabeled-1.44.2
 * [new branch]          unlabeled-1.44.4            -> refs/west/unlabeled-1.44.4
 * [new branch]          unlabeled-1.45.2            -> refs/west/unlabeled-1.45.2
 * [new branch]          unlabeled-1.45.8            -> refs/west/unlabeled-1.45.8
 * [new branch]          unlabeled-1.46.4            -> refs/west/unlabeled-1.46.4
 * [new branch]          unlabeled-1.48.16           -> refs/west/unlabeled-1.48.16
 * [new branch]          unlabeled-1.5.16            -> refs/west/unlabeled-1.5.16
 * [new branch]          unlabeled-1.5.2             -> refs/west/unlabeled-1.5.2
 * [new branch]          unlabeled-1.50.2            -> refs/west/unlabeled-1.50.2
 * [new branch]          unlabeled-1.50.6            -> refs/west/unlabeled-1.50.6
 * [new branch]          unlabeled-1.52.2            -> refs/west/unlabeled-1.52.2
 * [new branch]          unlabeled-1.53.6            -> refs/west/unlabeled-1.53.6
 * [new branch]          unlabeled-1.54.4            -> refs/west/unlabeled-1.54.4
 * [new branch]          unlabeled-1.64.2            -> refs/west/unlabeled-1.64.2
 * [new branch]          unlabeled-1.65.12           -> refs/west/unlabeled-1.65.12
 * [new branch]          unlabeled-1.65.4            -> refs/west/unlabeled-1.65.4
 * [new branch]          unlabeled-1.66.2            -> refs/west/unlabeled-1.66.2
 * [new branch]          unlabeled-1.69.4            -> refs/west/unlabeled-1.69.4
 * [new branch]          unlabeled-1.74.4            -> refs/west/unlabeled-1.74.4
 * [new branch]          unlabeled-1.75.4            -> refs/west/unlabeled-1.75.4
 * [new branch]          unlabeled-1.8.2             -> refs/west/unlabeled-1.8.2
 * [new branch]          unlabeled-1.81.2            -> refs/west/unlabeled-1.81.2
 * [new branch]          unlabeled-1.83.4            -> refs/west/unlabeled-1.83.4
 * [new branch]          unlabeled-1.86.2            -> refs/west/unlabeled-1.86.2
 * [new branch]          unlabeled-1.88.2            -> refs/west/unlabeled-1.88.2
 * [new branch]          unlabeled-1.90.2            -> refs/west/unlabeled-1.90.2
 * [new branch]          unlabeled-1.90.2.1.4        -> refs/west/unlabeled-1.90.2.1.4
 * [new branch]          unlabeled-1.93.2            -> refs/west/unlabeled-1.93.2
 * [new branch]          vendor                      -> refs/west/vendor
 * [new branch]          x86-more-32                 -> refs/west/x86-more-32
 * [new branch]          zephyr-add-library          -> refs/west/zephyr-add-library
 * [new branch]          zephyr-deprecated           -> refs/west/zephyr-deprecated
 * [new branch]          zephyr-hacks                -> refs/west/zephyr-hacks
 * [new branch]          zephyr-no-posix-define      -> refs/west/zephyr-no-posix-define
 * [new branch]          zephyr-posix                -> refs/west/zephyr-posix
 * [new branch]          zephyr-source               -> refs/west/zephyr-source
 * [new tag]             1.0                         -> 1.0
 * [new tag]             1.0-1                       -> 1.0-1
 * [new tag]             1.1                         -> 1.1
 * [new tag]             1.1-1                       -> 1.1-1
 * [new tag]             1.1-2                       -> 1.1-2
 * [new tag]             1.1.1-1                     -> 1.1.1-1
 * [new tag]             1.2                         -> 1.2
 * [new tag]             1.2-1                       -> 1.2-1
 * [new tag]             1.2.1-1                     -> 1.2.1-1
 * [new tag]             1.3                         -> 1.3
 * [new tag]             1.3-1                       -> 1.3-1
 * [new tag]             1.4                         -> 1.4
 * [new tag]             1.4-1                       -> 1.4-1
 * [new tag]             1.4.1-1                     -> 1.4.1-1
 * [new tag]             1.4.1-2                     -> 1.4.1-2
 * [new tag]             1.4.2-1                     -> 1.4.2-1
 * [new tag]             1.4.2-2                     -> 1.4.2-2
 * [new tag]             1.4.2-3                     -> 1.4.2-3
 * [new tag]             1.4.3-1                     -> 1.4.3-1
 * [new tag]             1.4.4-1                     -> 1.4.4-1
 * [new tag]             1.4.5                       -> 1.4.5
 * [new tag]             1.4.5-1                     -> 1.4.5-1
 * [new tag]             1.4.6                       -> 1.4.6
 * [new tag]             1.4.6-1                     -> 1.4.6-1
 * [new tag]             1.4.7                       -> 1.4.7
 * [new tag]             1.4.7-1                     -> 1.4.7-1
 * [new tag]             1.4.7-2                     -> 1.4.7-2
 * [new tag]             1.5                         -> 1.5
 * [new tag]             1.5-1                       -> 1.5-1
 * [new tag]             1.5.1-1                     -> 1.5.1-1
 * [new tag]             1.5.1-2                     -> 1.5.1-2
 * [new tag]             1.6                         -> 1.6
 * [new tag]             1.6-1                       -> 1.6-1
 * [new tag]             1.6.1-1                     -> 1.6.1-1
 * [new tag]             1.6.2-1                     -> 1.6.2-1
 * [new tag]             1.7                         -> 1.7
 * [new tag]             1.7-1                       -> 1.7-1
 * [new tag]             1.7.1-1                     -> 1.7.1-1
 * [new tag]             1.7.2-1                     -> 1.7.2-1
 * [new tag]             1.7.2-2                     -> 1.7.2-2
 * [new tag]             1.7.3-1                     -> 1.7.3-1
 * [new tag]             1.7.3-2                     -> 1.7.3-2
 * [new tag]             1.7.4-1                     -> 1.7.4-1
 * [new tag]             1.7.5-1                     -> 1.7.5-1
 * [new tag]             1.7.6-1                     -> 1.7.6-1
 * [new tag]             1.7.8                       -> 1.7.8
 * [new tag]             1.7.9                       -> 1.7.9
 * [new tag]             1.8.2                       -> 1.8.2
 * [new tag]             1.8.2-1                     -> 1.8.2-1
 * [new tag]             1.8.4                       -> 1.8.4
 * [new tag]             1.8.6                       -> 1.8.6
 * [new tag]             3.1.0.2019.08.08            -> 3.1.0.2019.08.08
 * [new tag]             3.1.0.2019.08.08-1          -> 3.1.0.2019.08.08-1
 * [new tag]             3.1.0.2019.08.14            -> 3.1.0.2019.08.14
 * [new tag]             3.1.0.2019.08.14-1          -> 3.1.0.2019.08.14-1
 * [new tag]             EOL_registry_mounts         -> EOL_registry_mounts
 * [new tag]             Z-cygwin_daemon_merge-new_HEAD -> Z-cygwin_daemon_merge-new_HEAD
 * [new tag]             Z-cygwin_daemon_merge_HEAD  -> Z-cygwin_daemon_merge_HEAD
 * [new tag]             after-mmap-privanon-noreserve -> after-mmap-privanon-noreserve
 * [new tag]             after-mmap-revamp           -> after-mmap-revamp
 * [new tag]             arc-20081103-branchpoint    -> arc-20081103-branchpoint
 * [new tag]             arc-insight_6_8-branchpoint -> arc-insight_6_8-branchpoint
 * [new tag]             arc-sim-20090309            -> arc-sim-20090309
 * [new tag]             before-mmap-revamp          -> before-mmap-revamp
 * [new tag]             binu_ss_19990502            -> binu_ss_19990502
 * [new tag]             binu_ss_19990602            -> binu_ss_19990602
 * [new tag]             binu_ss_19990721            -> binu_ss_19990721
 * [new tag]             binutils-2_10               -> binutils-2_10
 * [new tag]             binutils-2_10-branchpoint   -> binutils-2_10-branchpoint
 * [new tag]             binutils-2_10_1             -> binutils-2_10_1
 * [new tag]             binutils-2_11               -> binutils-2_11
 * [new tag]             binutils-2_11_1             -> binutils-2_11_1
 * [new tag]             binutils-2_11_2             -> binutils-2_11_2
 * [new tag]             binutils-2_12               -> binutils-2_12
 * [new tag]             binutils-2_12-branchpoint   -> binutils-2_12-branchpoint
 * [new tag]             binutils-2_12_1             -> binutils-2_12_1
 * [new tag]             binutils-2_13               -> binutils-2_13
 * [new tag]             binutils-2_13-branchpoint   -> binutils-2_13-branchpoint
 * [new tag]             binutils-2_13_1             -> binutils-2_13_1
 * [new tag]             binutils-2_13_2             -> binutils-2_13_2
 * [new tag]             binutils-2_13_2_1           -> binutils-2_13_2_1
 * [new tag]             binutils-2_14               -> binutils-2_14
 * [new tag]             binutils-2_14-branchpoint   -> binutils-2_14-branchpoint
 * [new tag]             binutils-2_15               -> binutils-2_15
 * [new tag]             binutils-2_15-branchpoint   -> binutils-2_15-branchpoint
 * [new tag]             binutils-2_16               -> binutils-2_16
 * [new tag]             binutils-2_16-branchpoint   -> binutils-2_16-branchpoint
 * [new tag]             binutils-2_16_1             -> binutils-2_16_1
 * [new tag]             binutils-2_17               -> binutils-2_17
 * [new tag]             binutils-2_17-branchpoint   -> binutils-2_17-branchpoint
 * [new tag]             binutils-2_18               -> binutils-2_18
 * [new tag]             binutils-2_18-branchpoint   -> binutils-2_18-branchpoint
 * [new tag]             binutils-2_19               -> binutils-2_19
 * [new tag]             binutils-2_19-branchpoint   -> binutils-2_19-branchpoint
 * [new tag]             binutils-2_19_1             -> binutils-2_19_1
 * [new tag]             binutils-2_20               -> binutils-2_20
 * [new tag]             binutils-2_20-branchpoint   -> binutils-2_20-branchpoint
 * [new tag]             binutils-2_20_1             -> binutils-2_20_1
 * [new tag]             binutils-2_21               -> binutils-2_21
 * [new tag]             binutils-2_21-branchpoint   -> binutils-2_21-branchpoint
 * [new tag]             binutils-2_21_1             -> binutils-2_21_1
 * [new tag]             binutils-2_22               -> binutils-2_22
 * [new tag]             binutils-2_22-branchpoint   -> binutils-2_22-branchpoint
 * [new tag]             binutils-2_23               -> binutils-2_23
 * [new tag]             binutils-2_23-branchpoint   -> binutils-2_23-branchpoint
 * [new tag]             binutils-2_23_1             -> binutils-2_23_1
 * [new tag]             binutils-2_23_2             -> binutils-2_23_2
 * [new tag]             binutils-2_24-branchpoint   -> binutils-2_24-branchpoint
 * [new tag]             binutils-arc-20080908-branchpoint -> binutils-arc-20080908-branchpoint
 * [new tag]             binutils-arc-20081103-branchpoint -> binutils-arc-20081103-branchpoint
 * [new tag]             binutils-csl-2_17-branchpoint -> binutils-csl-2_17-branchpoint
 * [new tag]             binutils-csl-arm-2005q1-branchpoint -> binutils-csl-arm-2005q1-branchpoint
 * [new tag]             binutils-csl-arm-2005q1a    -> binutils-csl-arm-2005q1a
 * [new tag]             binutils-csl-arm-2005q1b    -> binutils-csl-arm-2005q1b
 * [new tag]             binutils-csl-arm-2006q1-6   -> binutils-csl-arm-2006q1-6
 * [new tag]             binutils-csl-arm-2006q3-19  -> binutils-csl-arm-2006q3-19
 * [new tag]             binutils-csl-arm-2006q3-21  -> binutils-csl-arm-2006q3-21
 * [new tag]             binutils-csl-arm-2006q3-26  -> binutils-csl-arm-2006q3-26
 * [new tag]             binutils-csl-arm-2006q3-27  -> binutils-csl-arm-2006q3-27
 * [new tag]             binutils-csl-coldfire-4_1-10 -> binutils-csl-coldfire-4_1-10
 * [new tag]             binutils-csl-coldfire-4_1-11 -> binutils-csl-coldfire-4_1-11
 * [new tag]             binutils-csl-coldfire-4_1-28 -> binutils-csl-coldfire-4_1-28
 * [new tag]             binutils-csl-coldfire-4_1-30 -> binutils-csl-coldfire-4_1-30
 * [new tag]             binutils-csl-coldfire-4_1-32 -> binutils-csl-coldfire-4_1-32
 * [new tag]             binutils-csl-gxxpro-3_4-branchpoint -> binutils-csl-gxxpro-3_4-branchpoint
 * [new tag]             binutils-csl-innovasic-fido-3_4_4-33 -> binutils-csl-innovasic-fido-3_4_4-33
 * [new tag]             binutils-csl-morpho-4_1-4   -> binutils-csl-morpho-4_1-4
 * [new tag]             binutils-csl-palmsource-arm-prelinker-1_0-1 -> binutils-csl-palmsource-arm-prelinker-1_0-1
 * [new tag]             binutils-csl-renesas-4_1-6  -> binutils-csl-renesas-4_1-6
 * [new tag]             binutils-csl-renesas-4_1-7  -> binutils-csl-renesas-4_1-7
 * [new tag]             binutils-csl-renesas-4_1-8  -> binutils-csl-renesas-4_1-8
 * [new tag]             binutils-csl-renesas-4_1-9  -> binutils-csl-renesas-4_1-9
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-17 -> binutils-csl-sourcerygxx-3_4_4-17
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-19 -> binutils-csl-sourcerygxx-3_4_4-19
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-21 -> binutils-csl-sourcerygxx-3_4_4-21
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-25 -> binutils-csl-sourcerygxx-3_4_4-25
 * [new tag]             binutils-csl-sourcerygxx-3_4_4-32 -> binutils-csl-sourcerygxx-3_4_4-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-12 -> binutils-csl-sourcerygxx-4_1-12
 * [new tag]             binutils-csl-sourcerygxx-4_1-13 -> binutils-csl-sourcerygxx-4_1-13
 * [new tag]             binutils-csl-sourcerygxx-4_1-14 -> binutils-csl-sourcerygxx-4_1-14
 * [new tag]             binutils-csl-sourcerygxx-4_1-15 -> binutils-csl-sourcerygxx-4_1-15
 * [new tag]             binutils-csl-sourcerygxx-4_1-17 -> binutils-csl-sourcerygxx-4_1-17
 * [new tag]             binutils-csl-sourcerygxx-4_1-18 -> binutils-csl-sourcerygxx-4_1-18
 * [new tag]             binutils-csl-sourcerygxx-4_1-19 -> binutils-csl-sourcerygxx-4_1-19
 * [new tag]             binutils-csl-sourcerygxx-4_1-20 -> binutils-csl-sourcerygxx-4_1-20
 * [new tag]             binutils-csl-sourcerygxx-4_1-21 -> binutils-csl-sourcerygxx-4_1-21
 * [new tag]             binutils-csl-sourcerygxx-4_1-22 -> binutils-csl-sourcerygxx-4_1-22
 * [new tag]             binutils-csl-sourcerygxx-4_1-23 -> binutils-csl-sourcerygxx-4_1-23
 * [new tag]             binutils-csl-sourcerygxx-4_1-24 -> binutils-csl-sourcerygxx-4_1-24
 * [new tag]             binutils-csl-sourcerygxx-4_1-25 -> binutils-csl-sourcerygxx-4_1-25
 * [new tag]             binutils-csl-sourcerygxx-4_1-26 -> binutils-csl-sourcerygxx-4_1-26
 * [new tag]             binutils-csl-sourcerygxx-4_1-27 -> binutils-csl-sourcerygxx-4_1-27
 * [new tag]             binutils-csl-sourcerygxx-4_1-28 -> binutils-csl-sourcerygxx-4_1-28
 * [new tag]             binutils-csl-sourcerygxx-4_1-29 -> binutils-csl-sourcerygxx-4_1-29
 * [new tag]             binutils-csl-sourcerygxx-4_1-30 -> binutils-csl-sourcerygxx-4_1-30
 * [new tag]             binutils-csl-sourcerygxx-4_1-32 -> binutils-csl-sourcerygxx-4_1-32
 * [new tag]             binutils-csl-sourcerygxx-4_1-4 -> binutils-csl-sourcerygxx-4_1-4
 * [new tag]             binutils-csl-sourcerygxx-4_1-5 -> binutils-csl-sourcerygxx-4_1-5
 * [new tag]             binutils-csl-sourcerygxx-4_1-6 -> binutils-csl-sourcerygxx-4_1-6
 * [new tag]             binutils-csl-sourcerygxx-4_1-7 -> binutils-csl-sourcerygxx-4_1-7
 * [new tag]             binutils-csl-sourcerygxx-4_1-8 -> binutils-csl-sourcerygxx-4_1-8
 * [new tag]             binutils-csl-sourcerygxx-4_1-9 -> binutils-csl-sourcerygxx-4_1-9
 * [new tag]             binutils-csl-wrs-linux-3_4_4-20 -> binutils-csl-wrs-linux-3_4_4-20
 * [new tag]             binutils-csl-wrs-linux-3_4_4-21 -> binutils-csl-wrs-linux-3_4_4-21
 * [new tag]             binutils-csl-wrs-linux-3_4_4-22 -> binutils-csl-wrs-linux-3_4_4-22
 * [new tag]             binutils-csl-wrs-linux-3_4_4-23 -> binutils-csl-wrs-linux-3_4_4-23
 * [new tag]             binutils-csl-wrs-linux-3_4_4-24 -> binutils-csl-wrs-linux-3_4_4-24
 * [new tag]             binutils_latest_snapshot    -> binutils_latest_snapshot
 * [new tag]             cagney-unwind-20030108-branchpoint -> cagney-unwind-20030108-branchpoint
 * [new tag]             cagney_bfdfile-20040213-branchpoint -> cagney_bfdfile-20040213-branchpoint
 * [new tag]             cagney_bigcore-20040122-branchpoint -> cagney_bigcore-20040122-branchpoint
 * [new tag]             cagney_convert-20030606-branchpoint -> cagney_convert-20030606-branchpoint
 * [new tag]             cagney_fileio-20030521-branchpoint -> cagney_fileio-20030521-branchpoint
 * [new tag]             cagney_frameaddr-20030403-branchpoint -> cagney_frameaddr-20030403-branchpoint
 * [new tag]             cagney_frameaddr-20030409-mergepoint -> cagney_frameaddr-20030409-mergepoint
 * [new tag]             cagney_framebase-20030326-branchpoint -> cagney_framebase-20030326-branchpoint
 * [new tag]             cagney_framebase-20030330-mergepoint -> cagney_framebase-20030330-mergepoint
 * [new tag]             cagney_lazyid-20030317-branchpoint -> cagney_lazyid-20030317-branchpoint
 * [new tag]             cagney_offbyone-20030303-branchpoint -> cagney_offbyone-20030303-branchpoint
 * [new tag]             cagney_regbuf-20020515-branchpoint -> cagney_regbuf-20020515-branchpoint
 * [new tag]             cagney_sysregs-20020825-branchpoint -> cagney_sysregs-20020825-branchpoint
 * [new tag]             cagney_tramp-20040309-branchpoint -> cagney_tramp-20040309-branchpoint
 * [new tag]             cagney_tramp-20040321-mergepoint -> cagney_tramp-20040321-mergepoint
 * [new tag]             cagney_writestrings-20030508-branchpoint -> cagney_writestrings-20030508-branchpoint
 * [new tag]             cagney_x86i386-20030821-branchpoint -> cagney_x86i386-20030821-branchpoint
 * [new tag]             carlton-dictionary-20031111-merge -> carlton-dictionary-20031111-merge
 * [new tag]             carlton_dictionary-20020920-branchpoint -> carlton_dictionary-20020920-branchpoint
 * [new tag]             carlton_dictionary-20020927-merge -> carlton_dictionary-20020927-merge
 * [new tag]             carlton_dictionary-20021011-merge -> carlton_dictionary-20021011-merge
 * [new tag]             carlton_dictionary-20021025-merge -> carlton_dictionary-20021025-merge
 * [new tag]             carlton_dictionary-20021115-merge -> carlton_dictionary-20021115-merge
 * [new tag]             carlton_dictionary-20021223-merge -> carlton_dictionary-20021223-merge
 * [new tag]             carlton_dictionary-20030207-merge -> carlton_dictionary-20030207-merge
 * [new tag]             carlton_dictionary-20030305-merge -> carlton_dictionary-20030305-merge
 * [new tag]             carlton_dictionary-20030416-merge -> carlton_dictionary-20030416-merge
 * [new tag]             carlton_dictionary-20030430-merge -> carlton_dictionary-20030430-merge
 * [new tag]             carlton_dictionary-20030523-merge -> carlton_dictionary-20030523-merge
 * [new tag]             carlton_dictionary-20030627-merge -> carlton_dictionary-20030627-merge
 * [new tag]             carlton_dictionary-20030805-merge -> carlton_dictionary-20030805-merge
 * [new tag]             carlton_dictionary-20030917-merge -> carlton_dictionary-20030917-merge
 * [new tag]             carlton_dictionary-20031215-merge -> carlton_dictionary-20031215-merge
 * [new tag]             carlton_dictionary-20040126-merge -> carlton_dictionary-20040126-merge
 * [new tag]             cgen-1_1-branchpoint        -> cgen-1_1-branchpoint
 * [new tag]             cgen-snapshot-20071001      -> cgen-snapshot-20071001
 * [new tag]             cgen-snapshot-20071101      -> cgen-snapshot-20071101
 * [new tag]             cgen-snapshot-20071201      -> cgen-snapshot-20071201
 * [new tag]             cgen-snapshot-20080101      -> cgen-snapshot-20080101
 * [new tag]             cgen-snapshot-20080201      -> cgen-snapshot-20080201
 * [new tag]             cgen-snapshot-20080301      -> cgen-snapshot-20080301
 * [new tag]             cgen-snapshot-20080401      -> cgen-snapshot-20080401
 * [new tag]             cgen-snapshot-20080501      -> cgen-snapshot-20080501
 * [new tag]             cgen-snapshot-20080601      -> cgen-snapshot-20080601
 * [new tag]             cgen-snapshot-20080701      -> cgen-snapshot-20080701
 * [new tag]             cgen-snapshot-20080801      -> cgen-snapshot-20080801
 * [new tag]             cgen-snapshot-20080901      -> cgen-snapshot-20080901
 * [new tag]             cgen-snapshot-20081001      -> cgen-snapshot-20081001
 * [new tag]             cgen-snapshot-20081101      -> cgen-snapshot-20081101
 * [new tag]             cgen-snapshot-20081201      -> cgen-snapshot-20081201
 * [new tag]             cgen-snapshot-20090101      -> cgen-snapshot-20090101
 * [new tag]             cgen-snapshot-20090201      -> cgen-snapshot-20090201
 * [new tag]             cgen-snapshot-20090301      -> cgen-snapshot-20090301
 * [new tag]             cgen-snapshot-20090401      -> cgen-snapshot-20090401
 * [new tag]             cgen-snapshot-20090501      -> cgen-snapshot-20090501
 * [new tag]             cgen-snapshot-20090601      -> cgen-snapshot-20090601
 * [new tag]             cgen-snapshot-20090701      -> cgen-snapshot-20090701
 * [new tag]             cgen-snapshot-20090801      -> cgen-snapshot-20090801
 * [new tag]             cgen-snapshot-20090901      -> cgen-snapshot-20090901
 * [new tag]             cgen-snapshot-20091001      -> cgen-snapshot-20091001
 * [new tag]             cgen-snapshot-20091101      -> cgen-snapshot-20091101
 * [new tag]             cgen-snapshot-20091201      -> cgen-snapshot-20091201
 * [new tag]             cgen-snapshot-20100101      -> cgen-snapshot-20100101
 * [new tag]             cgen-snapshot-20100201      -> cgen-snapshot-20100201
 * [new tag]             cgen-snapshot-20100301      -> cgen-snapshot-20100301
 * [new tag]             cgen-snapshot-20100401      -> cgen-snapshot-20100401
 * [new tag]             cgen-snapshot-20100501      -> cgen-snapshot-20100501
 * [new tag]             cgen-snapshot-20100601      -> cgen-snapshot-20100601
 * [new tag]             cgen-snapshot-20100701      -> cgen-snapshot-20100701
 * [new tag]             cgen-snapshot-20100801      -> cgen-snapshot-20100801
 * [new tag]             cgen-snapshot-20100901      -> cgen-snapshot-20100901
 * [new tag]             cgen-snapshot-20101001      -> cgen-snapshot-20101001
 * [new tag]             cgen-snapshot-20101101      -> cgen-snapshot-20101101
 * [new tag]             cgen-snapshot-20101201      -> cgen-snapshot-20101201
 * [new tag]             cgen-snapshot-20110101      -> cgen-snapshot-20110101
 * [new tag]             cgen-snapshot-20110201      -> cgen-snapshot-20110201
 * [new tag]             cgen-snapshot-20110301      -> cgen-snapshot-20110301
 * [new tag]             cgen-snapshot-20110401      -> cgen-snapshot-20110401
 * [new tag]             cgen-snapshot-20110501      -> cgen-snapshot-20110501
 * [new tag]             cgen-snapshot-20110601      -> cgen-snapshot-20110601
 * [new tag]             cgen-snapshot-20110701      -> cgen-snapshot-20110701
 * [new tag]             cgen-snapshot-20110801      -> cgen-snapshot-20110801
 * [new tag]             cgen-snapshot-20110901      -> cgen-snapshot-20110901
 * [new tag]             cgen-snapshot-20111001      -> cgen-snapshot-20111001
 * [new tag]             cgen-snapshot-20111101      -> cgen-snapshot-20111101
 * [new tag]             cgen-snapshot-20111201      -> cgen-snapshot-20111201
 * [new tag]             cgen-snapshot-20120101      -> cgen-snapshot-20120101
 * [new tag]             cgen-snapshot-20120201      -> cgen-snapshot-20120201
 * [new tag]             cgen-snapshot-20120301      -> cgen-snapshot-20120301
 * [new tag]             cgen-snapshot-20120401      -> cgen-snapshot-20120401
 * [new tag]             cgen-snapshot-20120501      -> cgen-snapshot-20120501
 * [new tag]             cgen-snapshot-20120601      -> cgen-snapshot-20120601
 * [new tag]             cgen-snapshot-20120701      -> cgen-snapshot-20120701
 * [new tag]             cgen-snapshot-20120801      -> cgen-snapshot-20120801
 * [new tag]             cgen-snapshot-20120901      -> cgen-snapshot-20120901
 * [new tag]             cgen-snapshot-20121001      -> cgen-snapshot-20121001
 * [new tag]             cgen-snapshot-20121101      -> cgen-snapshot-20121101
 * [new tag]             cgen-snapshot-20121201      -> cgen-snapshot-20121201
 * [new tag]             cgen-snapshot-20130101      -> cgen-snapshot-20130101
 * [new tag]             cgen-snapshot-20130201      -> cgen-snapshot-20130201
 * [new tag]             cgen-snapshot-20130301      -> cgen-snapshot-20130301
 * [new tag]             cgen-snapshot-20130401      -> cgen-snapshot-20130401
 * [new tag]             cgen-snapshot-20130501      -> cgen-snapshot-20130501
 * [new tag]             cgen-snapshot-20130601      -> cgen-snapshot-20130601
 * [new tag]             cgen-snapshot-20130701      -> cgen-snapshot-20130701
 * [new tag]             cgen-snapshot-20130801      -> cgen-snapshot-20130801
 * [new tag]             cgen-snapshot-20130901      -> cgen-snapshot-20130901
 * [new tag]             cgen-snapshot-20131001      -> cgen-snapshot-20131001
 * [new tag]             cgen-snapshot-20131101      -> cgen-snapshot-20131101
 * [new tag]             cgen-snapshot-20131201      -> cgen-snapshot-20131201
 * [new tag]             cgen-snapshot-20140101      -> cgen-snapshot-20140101
 * [new tag]             cgen-snapshot-20140201      -> cgen-snapshot-20140201
 * [new tag]             cgen-snapshot-20140301      -> cgen-snapshot-20140301
 * [new tag]             cgen-snapshot-20140401      -> cgen-snapshot-20140401
 * [new tag]             cgen-snapshot-20140501      -> cgen-snapshot-20140501
 * [new tag]             cgen-snapshot-20140601      -> cgen-snapshot-20140601
 * [new tag]             cgen-snapshot-20140701      -> cgen-snapshot-20140701
 * [new tag]             cgen-snapshot-20140801      -> cgen-snapshot-20140801
 * [new tag]             cgen-snapshot-20140901      -> cgen-snapshot-20140901
 * [new tag]             cgen-snapshot-20141001      -> cgen-snapshot-20141001
 * [new tag]             cgen-snapshot-20141101      -> cgen-snapshot-20141101
 * [new tag]             cgen-snapshot-20141201      -> cgen-snapshot-20141201
 * [new tag]             cgen-snapshot-20150101      -> cgen-snapshot-20150101
 * [new tag]             cgen-snapshot-20150201      -> cgen-snapshot-20150201
 * [new tag]             cgen-snapshot-20150301      -> cgen-snapshot-20150301
 * [new tag]             cgf-more-exit-sync          -> cgf-more-exit-sync
 * [new tag]             corinna-01                  -> corinna-01
 * [new tag]             cr-0x99                     -> cr-0x99
 * [new tag]             csl-arm-2003-q4             -> csl-arm-2003-q4
 * [new tag]             csl-arm-2004-q1             -> csl-arm-2004-q1
 * [new tag]             csl-arm-2004-q1a            -> csl-arm-2004-q1a
 * [new tag]             csl-arm-2004-q3             -> csl-arm-2004-q3
 * [new tag]             csl-arm-2004-q3d            -> csl-arm-2004-q3d
 * [new tag]             csl-arm-20050325-branchpoint -> csl-arm-20050325-branchpoint
 * [new tag]             cygnus_cvs_20020108_pre     -> cygnus_cvs_20020108_pre
 * [new tag]             cygwin-1-1-5                -> cygwin-1-1-5
 * [new tag]             cygwin-1-1-6                -> cygwin-1-1-6
 * [new tag]             cygwin-1-1-7                -> cygwin-1-1-7
 * [new tag]             cygwin-1-1-8                -> cygwin-1-1-8
 * [new tag]             cygwin-1-3-19-1-branchpoint -> cygwin-1-3-19-1-branchpoint
 * [new tag]             cygwin-1_1_1                -> cygwin-1_1_1
 * [new tag]             cygwin-1_7_1-release        -> cygwin-1_7_1-release
 * [new tag]             cygwin-1_7_10-release       -> cygwin-1_7_10-release
 * [new tag]             cygwin-1_7_11-release       -> cygwin-1_7_11-release
 * [new tag]             cygwin-1_7_12-release       -> cygwin-1_7_12-release
 * [new tag]             cygwin-1_7_14-release       -> cygwin-1_7_14-release
 * [new tag]             cygwin-1_7_14_2-release     -> cygwin-1_7_14_2-release
 * [new tag]             cygwin-1_7_15-release       -> cygwin-1_7_15-release
 * [new tag]             cygwin-1_7_16-release       -> cygwin-1_7_16-release
 * [new tag]             cygwin-1_7_17-release       -> cygwin-1_7_17-release
 * [new tag]             cygwin-1_7_18-release       -> cygwin-1_7_18-release
 * [new tag]             cygwin-1_7_19-release       -> cygwin-1_7_19-release
 * [new tag]             cygwin-1_7_2-release        -> cygwin-1_7_2-release
 * [new tag]             cygwin-1_7_20-release       -> cygwin-1_7_20-release
 * [new tag]             cygwin-1_7_21-release       -> cygwin-1_7_21-release
 * [new tag]             cygwin-1_7_22-release       -> cygwin-1_7_22-release
 * [new tag]             cygwin-1_7_23-release       -> cygwin-1_7_23-release
 * [new tag]             cygwin-1_7_24-release       -> cygwin-1_7_24-release
 * [new tag]             cygwin-1_7_25-release       -> cygwin-1_7_25-release
 * [new tag]             cygwin-1_7_26-release       -> cygwin-1_7_26-release
 * [new tag]             cygwin-1_7_27-release       -> cygwin-1_7_27-release
 * [new tag]             cygwin-1_7_28-release       -> cygwin-1_7_28-release
 * [new tag]             cygwin-1_7_29-release       -> cygwin-1_7_29-release
 * [new tag]             cygwin-1_7_3-release        -> cygwin-1_7_3-release
 * [new tag]             cygwin-1_7_30-release       -> cygwin-1_7_30-release
 * [new tag]             cygwin-1_7_31-release       -> cygwin-1_7_31-release
 * [new tag]             cygwin-1_7_32-release       -> cygwin-1_7_32-release
 * [new tag]             cygwin-1_7_33-release       -> cygwin-1_7_33-release
 * [new tag]             cygwin-1_7_34-release       -> cygwin-1_7_34-release
 * [new tag]             cygwin-1_7_35-release       -> cygwin-1_7_35-release
 * [new tag]             cygwin-1_7_4-release        -> cygwin-1_7_4-release
 * [new tag]             cygwin-1_7_5-release        -> cygwin-1_7_5-release
 * [new tag]             cygwin-1_7_7-release        -> cygwin-1_7_7-release
 * [new tag]             cygwin-1_7_8-release        -> cygwin-1_7_8-release
 * [new tag]             cygwin-1_7_9-release        -> cygwin-1_7_9-release
 * [new tag]             cygwin-2_0_0-release        -> cygwin-2_0_0-release
 * [new tag]             cygwin-2_0_1-release        -> cygwin-2_0_1-release
 * [new tag]             cygwin-2_0_2-release        -> cygwin-2_0_2-release
 * [new tag]             cygwin-2_0_3-release        -> cygwin-2_0_3-release
 * [new tag]             cygwin-2_0_4-release        -> cygwin-2_0_4-release
 * [new tag]             cygwin-2_10_0-release       -> cygwin-2_10_0-release
 * [new tag]             cygwin-2_11_0-release       -> cygwin-2_11_0-release
 * [new tag]             cygwin-2_11_1-release       -> cygwin-2_11_1-release
 * [new tag]             cygwin-2_11_2-release       -> cygwin-2_11_2-release
 * [new tag]             cygwin-2_1_0-release        -> cygwin-2_1_0-release
 * [new tag]             cygwin-2_2_0-release        -> cygwin-2_2_0-release
 * [new tag]             cygwin-2_2_1-release        -> cygwin-2_2_1-release
 * [new tag]             cygwin-2_3_0-release        -> cygwin-2_3_0-release
 * [new tag]             cygwin-2_3_1-relase         -> cygwin-2_3_1-relase
 * [new tag]             cygwin-2_3_1-release        -> cygwin-2_3_1-release
 * [new tag]             cygwin-2_4_0-release        -> cygwin-2_4_0-release
 * [new tag]             cygwin-2_4_1-release        -> cygwin-2_4_1-release
 * [new tag]             cygwin-2_5_0-release        -> cygwin-2_5_0-release
 * [new tag]             cygwin-2_5_1-release        -> cygwin-2_5_1-release
 * [new tag]             cygwin-2_5_2-release        -> cygwin-2_5_2-release
 * [new tag]             cygwin-2_6_0-release        -> cygwin-2_6_0-release
 * [new tag]             cygwin-2_6_1-release        -> cygwin-2_6_1-release
 * [new tag]             cygwin-2_7_0-release        -> cygwin-2_7_0-release
 * [new tag]             cygwin-2_8_0-release        -> cygwin-2_8_0-release
 * [new tag]             cygwin-2_8_1-release        -> cygwin-2_8_1-release
 * [new tag]             cygwin-2_8_2-release        -> cygwin-2_8_2-release
 * [new tag]             cygwin-2_9_0-release        -> cygwin-2_9_0-release
 * [new tag]             cygwin-3_0_0-release        -> cygwin-3_0_0-release
 * [new tag]             cygwin-3_0_1-release        -> cygwin-3_0_1-release
 * [new tag]             cygwin-3_0_2-release        -> cygwin-3_0_2-release
 * [new tag]             cygwin-3_0_3-release        -> cygwin-3_0_3-release
 * [new tag]             cygwin-3_0_4-release        -> cygwin-3_0_4-release
 * [new tag]             cygwin-3_0_5-release        -> cygwin-3_0_5-release
 * [new tag]             cygwin-3_0_6-release        -> cygwin-3_0_6-release
 * [new tag]             cygwin-3_0_7-release        -> cygwin-3_0_7-release
 * [new tag]             cygwin-3_1_0-release        -> cygwin-3_1_0-release
 * [new tag]             cygwin-3_1_1-release        -> cygwin-3_1_1-release
 * [new tag]             cygwin-3_1_2-release        -> cygwin-3_1_2-release
 * [new tag]             cygwin-3_1_3-release        -> cygwin-3_1_3-release
 * [new tag]             cygwin-3_1_4-release        -> cygwin-3_1_4-release
 * [new tag]             cygwin-64bit-postmerge      -> cygwin-64bit-postmerge
 * [new tag]             cygwin-64bit-premerge       -> cygwin-64bit-premerge
 * [new tag]             cygwin-pre-user-db          -> cygwin-pre-user-db
 * [new tag]             cygwin_daemon_merge_HEAD    -> cygwin_daemon_merge_HEAD
 * [new tag]             debian-2.10.0-1             -> debian-2.10.0-1
 * [new tag]             dje-cgen-play1-branchpoint  -> dje-cgen-play1-branchpoint
 * [new tag]             drop_9x_support_start       -> drop_9x_support_start
 * [new tag]             drow-cplus-branchpoint      -> drow-cplus-branchpoint
 * [new tag]             drow-cplus-merge-20021020   -> drow-cplus-merge-20021020
 * [new tag]             drow-cplus-merge-20021025   -> drow-cplus-merge-20021025
 * [new tag]             drow-cplus-merge-20031214   -> drow-cplus-merge-20031214
 * [new tag]             drow-cplus-merge-20031220   -> drow-cplus-merge-20031220
 * [new tag]             drow-cplus-merge-20031224   -> drow-cplus-merge-20031224
 * [new tag]             drow-cplus-merge-20040113   -> drow-cplus-merge-20040113
 * [new tag]             drow-cplus-merge-20040208   -> drow-cplus-merge-20040208
 * [new tag]             drow-reverse-20070409-branchpoint -> drow-reverse-20070409-branchpoint
 * [new tag]             drow_intercu-20040221-branchpoint -> drow_intercu-20040221-branchpoint
 * [new tag]             drow_intercu-merge-20040327 -> drow_intercu-merge-20040327
 * [new tag]             drow_intercu-merge-20040402 -> drow_intercu-merge-20040402
 * [new tag]             drow_intercu-merge-20040915 -> drow_intercu-merge-20040915
 * [new tag]             drow_intercu-merge-20040921 -> drow_intercu-merge-20040921
 * [new tag]             egcs_20000222               -> egcs_20000222
 * [new tag]             ezannoni_pie-20030916-branchpoint -> ezannoni_pie-20030916-branchpoint
 * [new tag]             ezannoni_pie-20040323-branchpoint -> ezannoni_pie-20040323-branchpoint
 * [new tag]             gdb-csl-20060226-branch-local-2 -> gdb-csl-20060226-branch-local-2
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-local-1 -> gdb-csl-20060226-branch-merge-to-csl-local-1
 * [new tag]             gdb-csl-20060226-branch-merge-to-csl-symbian-1 -> gdb-csl-20060226-branch-merge-to-csl-symbian-1
 * [new tag]             gdb-csl-20060226-branchpoint -> gdb-csl-20060226-branchpoint
 * [new tag]             gdb-csl-arm-20050325-2005-q1a -> gdb-csl-arm-20050325-2005-q1a
 * [new tag]             gdb-csl-arm-20050325-2005-q1b -> gdb-csl-arm-20050325-2005-q1b
 * [new tag]             gdb-csl-arm-20051020-branchpoint -> gdb-csl-arm-20051020-branchpoint
 * [new tag]             gdb-csl-arm-2006q1-6        -> gdb-csl-arm-2006q1-6
 * [new tag]             gdb-csl-available-20060303-branchpoint -> gdb-csl-available-20060303-branchpoint
 * [new tag]             gdb-csl-coldfire-4_1-10     -> gdb-csl-coldfire-4_1-10
 * [new tag]             gdb-csl-coldfire-4_1-11     -> gdb-csl-coldfire-4_1-11
 * [new tag]             gdb-csl-gxxpro-6_3-branchpoint -> gdb-csl-gxxpro-6_3-branchpoint
 * [new tag]             gdb-csl-morpho-4_1-4        -> gdb-csl-morpho-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-17 -> gdb-csl-sourcerygxx-3_4_4-17
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-19 -> gdb-csl-sourcerygxx-3_4_4-19
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-21 -> gdb-csl-sourcerygxx-3_4_4-21
 * [new tag]             gdb-csl-sourcerygxx-3_4_4-25 -> gdb-csl-sourcerygxx-3_4_4-25
 * [new tag]             gdb-csl-sourcerygxx-4_1-12  -> gdb-csl-sourcerygxx-4_1-12
 * [new tag]             gdb-csl-sourcerygxx-4_1-13  -> gdb-csl-sourcerygxx-4_1-13
 * [new tag]             gdb-csl-sourcerygxx-4_1-14  -> gdb-csl-sourcerygxx-4_1-14
 * [new tag]             gdb-csl-sourcerygxx-4_1-17  -> gdb-csl-sourcerygxx-4_1-17
 * [new tag]             gdb-csl-sourcerygxx-4_1-4   -> gdb-csl-sourcerygxx-4_1-4
 * [new tag]             gdb-csl-sourcerygxx-4_1-5   -> gdb-csl-sourcerygxx-4_1-5
 * [new tag]             gdb-csl-sourcerygxx-4_1-6   -> gdb-csl-sourcerygxx-4_1-6
 * [new tag]             gdb-csl-sourcerygxx-4_1-7   -> gdb-csl-sourcerygxx-4_1-7
 * [new tag]             gdb-csl-sourcerygxx-4_1-8   -> gdb-csl-sourcerygxx-4_1-8
 * [new tag]             gdb-csl-sourcerygxx-4_1-9   -> gdb-csl-sourcerygxx-4_1-9
 * [new tag]             gdb-csl-symbian-20060226-branchpoint -> gdb-csl-symbian-20060226-branchpoint
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-10 -> gdb-csl-symbian-6_4_50_20060226-10
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-11 -> gdb-csl-symbian-6_4_50_20060226-11
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-12 -> gdb-csl-symbian-6_4_50_20060226-12
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-8 -> gdb-csl-symbian-6_4_50_20060226-8
 * [new tag]             gdb-csl-symbian-6_4_50_20060226-9 -> gdb-csl-symbian-6_4_50_20060226-9
 * [new tag]             gdb-premipsmulti-2000-06-06-branchpoint -> gdb-premipsmulti-2000-06-06-branchpoint
 * [new tag]             gdb_4_18_2-2000-05-18-release -> gdb_4_18_2-2000-05-18-release
 * [new tag]             gdb_4_95_0-2000-04-27-snapshot -> gdb_4_95_0-2000-04-27-snapshot
 * [new tag]             gdb_4_95_1-2000-05-11-snapshot -> gdb_4_95_1-2000-05-11-snapshot
 * [new tag]             gdb_5_0-2000-04-10-branchpoint -> gdb_5_0-2000-04-10-branchpoint
 * [new tag]             gdb_5_0-2000-05-19-release  -> gdb_5_0-2000-05-19-release
 * [new tag]             gdb_5_1-2001-07-29-branchpoint -> gdb_5_1-2001-07-29-branchpoint
 * [new tag]             gdb_5_1-2001-11-21-release  -> gdb_5_1-2001-11-21-release
 * [new tag]             gdb_5_1_0_1-2002-01-03-branchpoint -> gdb_5_1_0_1-2002-01-03-branchpoint
 * [new tag]             gdb_5_1_0_1-2002-01-03-release -> gdb_5_1_0_1-2002-01-03-release
 * [new tag]             gdb_5_1_1-2002-01-24-release -> gdb_5_1_1-2002-01-24-release
 * [new tag]             gdb_5_2-2002-03-03-branchpoint -> gdb_5_2-2002-03-03-branchpoint
 * [new tag]             gdb_5_2-2002-04-29-release  -> gdb_5_2-2002-04-29-release
 * [new tag]             gdb_5_2_1-2002-07-23-release -> gdb_5_2_1-2002-07-23-release
 * [new tag]             gdb_5_3-2002-09-04-branchpoint -> gdb_5_3-2002-09-04-branchpoint
 * [new tag]             gdb_5_3-2002-12-12-release  -> gdb_5_3-2002-12-12-release
 * [new tag]             gdb_6_0-2003-06-23-branchpoint -> gdb_6_0-2003-06-23-branchpoint
 * [new tag]             gdb_6_0-2003-10-04-release  -> gdb_6_0-2003-10-04-release
 * [new tag]             gdb_6_1-2004-03-01-gmt-branchpoint -> gdb_6_1-2004-03-01-gmt-branchpoint
 * [new tag]             gdb_6_1-2004-04-05-release  -> gdb_6_1-2004-04-05-release
 * [new tag]             gdb_6_1_1-20040616-release  -> gdb_6_1_1-20040616-release
 * [new tag]             gdb_6_2-2004-07-10-gmt-branchpoint -> gdb_6_2-2004-07-10-gmt-branchpoint
 * [new tag]             gdb_6_2-20040730-release    -> gdb_6_2-20040730-release
 * [new tag]             gdb_6_3-20041019-branchpoint -> gdb_6_3-20041019-branchpoint
 * [new tag]             gdb_6_3-20041109-release    -> gdb_6_3-20041109-release
 * [new tag]             gdb_6_4-2005-11-01-branchpoint -> gdb_6_4-2005-11-01-branchpoint
 * [new tag]             gdb_6_4-20051202-release    -> gdb_6_4-20051202-release
 * [new tag]             gdb_6_5-2006-05-14-branchpoint -> gdb_6_5-2006-05-14-branchpoint
 * [new tag]             gdb_6_5-20060621-release    -> gdb_6_5-20060621-release
 * [new tag]             gdb_6_6-2006-11-15-branchpoint -> gdb_6_6-2006-11-15-branchpoint
 * [new tag]             gdb_6_6-2006-12-18-release  -> gdb_6_6-2006-12-18-release
 * [new tag]             gdb_6_7-2007-09-07-branchpoint -> gdb_6_7-2007-09-07-branchpoint
 * [new tag]             gdb_6_7-2007-10-10-release  -> gdb_6_7-2007-10-10-release
 * [new tag]             gdb_6_7_1-2007-10-29-release -> gdb_6_7_1-2007-10-29-release
 * [new tag]             gdb_6_8-2008-02-26-branchpoint -> gdb_6_8-2008-02-26-branchpoint
 * [new tag]             gdb_6_8-2008-03-27-release  -> gdb_6_8-2008-03-27-release
 * [new tag]             gdb_7_0-2009-09-16-branchpoint -> gdb_7_0-2009-09-16-branchpoint
 * [new tag]             gdb_7_0-2009-10-06-release  -> gdb_7_0-2009-10-06-release
 * [new tag]             gdb_7_0_1-2009-12-22-release -> gdb_7_0_1-2009-12-22-release
 * [new tag]             gdb_7_1-2010-02-18-branchpoint -> gdb_7_1-2010-02-18-branchpoint
 * [new tag]             gdb_7_1-2010-03-18-release  -> gdb_7_1-2010-03-18-release
 * [new tag]             gdb_7_2-2010-07-07-branchpoint -> gdb_7_2-2010-07-07-branchpoint
 * [new tag]             gdb_7_2-2010-09-02-release  -> gdb_7_2-2010-09-02-release
 * [new tag]             gdb_7_3-2011-04-01-branchpoint -> gdb_7_3-2011-04-01-branchpoint
 * [new tag]             gdb_7_3-2011-07-26-release  -> gdb_7_3-2011-07-26-release
 * [new tag]             gdb_7_3_1-2011-09-04-release -> gdb_7_3_1-2011-09-04-release
 * [new tag]             gdb_7_4-2011-12-13-branchpoint -> gdb_7_4-2011-12-13-branchpoint
 * [new tag]             gdb_7_4-2012-01-24-release  -> gdb_7_4-2012-01-24-release
 * [new tag]             gdb_7_4_1-2012-04-26-release -> gdb_7_4_1-2012-04-26-release
 * [new tag]             gdb_7_5-2012-07-18-branchpoint -> gdb_7_5-2012-07-18-branchpoint
 * [new tag]             gdb_7_5-2012-08-17-release  -> gdb_7_5-2012-08-17-release
 * [new tag]             gdb_7_5_1-2012-11-29-release -> gdb_7_5_1-2012-11-29-release
 * [new tag]             gdb_7_6-2013-03-12-branchpoint -> gdb_7_6-2013-03-12-branchpoint
 * [new tag]             gdb_7_6-2013-04-26-release  -> gdb_7_6-2013-04-26-release
 * [new tag]             gdb_7_6_1-2013-08-30-release -> gdb_7_6_1-2013-08-30-release
 * [new tag]             gdb_s390-2001-09-26-branchpoint -> gdb_s390-2001-09-26-branchpoint
 * [new tag]             hmm                         -> hmm
 * [new tag]             insight-precleanup-2001-01-01 -> insight-precleanup-2001-01-01
 * [new tag]             insight_6_5-20061003-release -> insight_6_5-20061003-release
 * [new tag]             insight_6_6-20070208-release -> insight_6_6-20070208-release
 * [new tag]             insight_6_8-branchpoint     -> insight_6_8-branchpoint
 * [new tag]             interps-20030202-branchpoint -> interps-20030202-branchpoint
 * [new tag]             jimb-gdb_6_2-e500-branchpoint -> jimb-gdb_6_2-e500-branchpoint
 * [new tag]             jimb-macro-020506-branchpoint -> jimb-macro-020506-branchpoint
 * [new tag]             jimb-ppc64-linux-20030509-branchpoint -> jimb-ppc64-linux-20030509-branchpoint
 * [new tag]             jimb-ppc64-linux-20030528-branchpoint -> jimb-ppc64-linux-20030528-branchpoint
 * [new tag]             jimb-ppc64-linux-20030613-branchpoint -> jimb-ppc64-linux-20030613-branchpoint
 * [new tag]             jimb-rda-nptl-branchpoint   -> jimb-rda-nptl-branchpoint
 * [new tag]             kettenis-i386newframe-20030308-branchpoint -> kettenis-i386newframe-20030308-branchpoint
 * [new tag]             kettenis-i386newframe-20030316-mergepoint -> kettenis-i386newframe-20030316-mergepoint
 * [new tag]             kettenis_i386newframe-20030406-branchpoint -> kettenis_i386newframe-20030406-branchpoint
 * [new tag]             kettenis_i386newframe-20030419-branchpoint -> kettenis_i386newframe-20030419-branchpoint
 * [new tag]             kettenis_i386newframe-20030504-mergepoint -> kettenis_i386newframe-20030504-mergepoint
 * [new tag]             kettenis_i386newframe-20030517-mergepoint -> kettenis_i386newframe-20030517-mergepoint
 * [new tag]             kettenis_sparc-20030918-branchpoint -> kettenis_sparc-20030918-branchpoint
 * [new tag]             kseitz_interps-20020528-branchpoint -> kseitz_interps-20020528-branchpoint
 * [new tag]             kseitz_interps-20020829-merge -> kseitz_interps-20020829-merge
 * [new tag]             kseitz_interps-20020930-merge -> kseitz_interps-20020930-merge
 * [new tag]             kseitz_interps-20021103-merge -> kseitz_interps-20021103-merge
 * [new tag]             kseitz_interps-20021105-merge -> kseitz_interps-20021105-merge
 * [new tag]             mingw-runtime-2_0           -> mingw-runtime-2_0
 * [new tag]             mingw-runtime-2_4           -> mingw-runtime-2_4
 * [new tag]             msnyder-checkpoint-072509-branchpoint -> msnyder-checkpoint-072509-branchpoint
 * [new tag]             msnyder-fork-checkpoint-branchpoint -> msnyder-fork-checkpoint-branchpoint
 * [new tag]             msnyder-reverse-20060331-branchpoint -> msnyder-reverse-20060331-branchpoint
 * [new tag]             msnyder-reverse-20060502-branchpoint -> msnyder-reverse-20060502-branchpoint
 * [new tag]             msnyder-reverse-20080609-branchpoint -> msnyder-reverse-20080609-branchpoint
 * [new tag]             msnyder-tracepoint-checkpoint-branchpoint -> msnyder-tracepoint-checkpoint-branchpoint
 * [new tag]             multiprocess-20081120-branchpoint -> multiprocess-20081120-branchpoint
 * [new tag]             newlib-1_10_0               -> newlib-1_10_0
 * [new tag]             newlib-1_11_0               -> newlib-1_11_0
 * [new tag]             newlib-1_12_0               -> newlib-1_12_0
 * [new tag]             newlib-1_13_0               -> newlib-1_13_0
 * [new tag]             newlib-1_14_0               -> newlib-1_14_0
 * [new tag]             newlib-1_15_0               -> newlib-1_15_0
 * [new tag]             newlib-1_16_0               -> newlib-1_16_0
 * [new tag]             newlib-1_17_0               -> newlib-1_17_0
 * [new tag]             newlib-1_18_0               -> newlib-1_18_0
 * [new tag]             newlib-1_19_0               -> newlib-1_19_0
 * [new tag]             newlib-1_20_0               -> newlib-1_20_0
 * [new tag]             newlib-1_9_0                -> newlib-1_9_0
 * [new tag]             newlib-2000-02-17           -> newlib-2000-02-17
 * [new tag]             newlib-2_0_0                -> newlib-2_0_0
 * [new tag]             newlib-2_1_0                -> newlib-2_1_0
 * [new tag]             newlib-2_2_0                -> newlib-2_2_0
 * [new tag]             newlib-2_3_0                -> newlib-2_3_0
 * [new tag]             newlib-2_4_0                -> newlib-2_4_0
 * [new tag]             newlib-2_5_0                -> newlib-2_5_0
 * [new tag]             newlib-3.0.0                -> newlib-3.0.0
 * [new tag]             newlib-3.1.0                -> newlib-3.1.0
 * [new tag]             newlib-3.2.0                -> newlib-3.2.0
 * [new tag]             newlib-3.3.0                -> newlib-3.3.0
 * [new tag]             newlib-csl-20060320-branchpoint -> newlib-csl-20060320-branchpoint
 * [new tag]             newlib-csl-arm-2005-q1a     -> newlib-csl-arm-2005-q1a
 * [new tag]             newlib-csl-arm-2005-q1b     -> newlib-csl-arm-2005-q1b
 * [new tag]             newlib-csl-arm-2006q1-6     -> newlib-csl-arm-2006q1-6
 * [new tag]             newlib-csl-arm-2006q3-19    -> newlib-csl-arm-2006q3-19
 * [new tag]             newlib-csl-arm-2006q3-21    -> newlib-csl-arm-2006q3-21
 * [new tag]             newlib-csl-arm-2006q3-26    -> newlib-csl-arm-2006q3-26
 * [new tag]             newlib-csl-arm-2006q3-27    -> newlib-csl-arm-2006q3-27
 * [new tag]             newlib-csl-coldfire-4_1-28  -> newlib-csl-coldfire-4_1-28
 * [new tag]             newlib-csl-coldfire-4_1-30  -> newlib-csl-coldfire-4_1-30
 * [new tag]             newlib-csl-coldfire-4_1-32  -> newlib-csl-coldfire-4_1-32
 * [new tag]             newlib-csl-innovasic-fido-3_4_4-33 -> newlib-csl-innovasic-fido-3_4_4-33
 * [new tag]             newlib-csl-sourcerygxx-3_4_4-25 -> newlib-csl-sourcerygxx-3_4_4-25
 * [new tag]             newlib-csl-sourcerygxx-4_1-12 -> newlib-csl-sourcerygxx-4_1-12
 * [new tag]             newlib-csl-sourcerygxx-4_1-13 -> newlib-csl-sourcerygxx-4_1-13
 * [new tag]             newlib-csl-sourcerygxx-4_1-14 -> newlib-csl-sourcerygxx-4_1-14
 * [new tag]             newlib-csl-sourcerygxx-4_1-17 -> newlib-csl-sourcerygxx-4_1-17
 * [new tag]             newlib-csl-sourcerygxx-4_1-18 -> newlib-csl-sourcerygxx-4_1-18
 * [new tag]             newlib-csl-sourcerygxx-4_1-19 -> newlib-csl-sourcerygxx-4_1-19
 * [new tag]             newlib-csl-sourcerygxx-4_1-21 -> newlib-csl-sourcerygxx-4_1-21
 * [new tag]             newlib-csl-sourcerygxx-4_1-23 -> newlib-csl-sourcerygxx-4_1-23
 * [new tag]             newlib-csl-sourcerygxx-4_1-24 -> newlib-csl-sourcerygxx-4_1-24
 * [new tag]             newlib-csl-sourcerygxx-4_1-26 -> newlib-csl-sourcerygxx-4_1-26
 * [new tag]             newlib-csl-sourcerygxx-4_1-27 -> newlib-csl-sourcerygxx-4_1-27
 * [new tag]             newlib-csl-sourcerygxx-4_1-28 -> newlib-csl-sourcerygxx-4_1-28
 * [new tag]             newlib-csl-sourcerygxx-4_1-30 -> newlib-csl-sourcerygxx-4_1-30
 * [new tag]             newlib-csl-sourcerygxx-4_1-32 -> newlib-csl-sourcerygxx-4_1-32
 * [new tag]             newlib-csl-sourcerygxx-4_1-4 -> newlib-csl-sourcerygxx-4_1-4
 * [new tag]             newlib-csl-sourcerygxx-4_1-5 -> newlib-csl-sourcerygxx-4_1-5
 * [new tag]             newlib-csl-sourcerygxx-4_1-6 -> newlib-csl-sourcerygxx-4_1-6
 * [new tag]             newlib-csl-sourcerygxx-4_1-7 -> newlib-csl-sourcerygxx-4_1-7
 * [new tag]             newlib-csl-sourcerygxx-4_1-8 -> newlib-csl-sourcerygxx-4_1-8
 * [new tag]             newlib-csl-sourcerygxx-4_1-9 -> newlib-csl-sourcerygxx-4_1-9
 * [new tag]             newlib-snapshot-20150323    -> newlib-snapshot-20150323
 * [new tag]             newlib-snapshot-20150423    -> newlib-snapshot-20150423
 * [new tag]             newlib-snapshot-20150526    -> newlib-snapshot-20150526
 * [new tag]             newlib-snapshot-20150623    -> newlib-snapshot-20150623
 * [new tag]             newlib-snapshot-20150723    -> newlib-snapshot-20150723
 * [new tag]             newlib-snapshot-20150824    -> newlib-snapshot-20150824
 * [new tag]             newlib-snapshot-20150924    -> newlib-snapshot-20150924
 * [new tag]             newlib-snapshot-20151023    -> newlib-snapshot-20151023
 * [new tag]             newlib-snapshot-20160104    -> newlib-snapshot-20160104
 * [new tag]             newlib-snapshot-20160226    -> newlib-snapshot-20160226
 * [new tag]             newlib-snapshot-20160527    -> newlib-snapshot-20160527
 * [new tag]             newlib-snapshot-20160923    -> newlib-snapshot-20160923
 * [new tag]             newlib-snapshot-20170228    -> newlib-snapshot-20170228
 * [new tag]             newlib-snapshot-20170323    -> newlib-snapshot-20170323
 * [new tag]             newlib-snapshot-20170421    -> newlib-snapshot-20170421
 * [new tag]             newlib-snapshot-20170519    -> newlib-snapshot-20170519
 * [new tag]             newlib-snapshot-20170623    -> newlib-snapshot-20170623
 * [new tag]             newlib-snapshot-20170720    -> newlib-snapshot-20170720
 * [new tag]             newlib-snapshot-20170818    -> newlib-snapshot-20170818
 * [new tag]             newlib-snapshot-20170922    -> newlib-snapshot-20170922
 * [new tag]             newlib-snapshot-20171222    -> newlib-snapshot-20171222
 * [new tag]             newlib-snapshot-20180118    -> newlib-snapshot-20180118
 * [new tag]             newlib-snapshot-20180226    -> newlib-snapshot-20180226
 * [new tag]             newlib-snapshot-20180720    -> newlib-snapshot-20180720
 * [new tag]             newlib-snapshot-20180802    -> newlib-snapshot-20180802
 * [new tag]             newlib-snapshot-20180831    -> newlib-snapshot-20180831
 * [new tag]             newlib-snapshot-20181231    -> newlib-snapshot-20181231
 * [new tag]             newlib-snapshot-20200102    -> newlib-snapshot-20200102
 * [new tag]             nickrob-async-20060513-branchpoint -> nickrob-async-20060513-branchpoint
 * [new tag]             nickrob-async-20060828-mergepoint -> nickrob-async-20060828-mergepoint
 * [new tag]             offbyone-20030313-branchpoint -> offbyone-20030313-branchpoint
 * [new tag]             post-ptmalloc3              -> post-ptmalloc3
 * [new tag]             post_wait_sig_exit          -> post_wait_sig_exit
 * [new tag]             pre-cgf-merge               -> pre-cgf-merge
 * [new tag]             pre-cygwin-heap             -> pre-cygwin-heap
 * [new tag]             pre-no-this                 -> pre-no-this
 * [new tag]             pre-notty                   -> pre-notty
 * [new tag]             pre-posix-scan              -> pre-posix-scan
 * [new tag]             pre-ptmalloc3               -> pre-ptmalloc3
 * [new tag]             pre-ptymaster-archetype     -> pre-ptymaster-archetype
 * [new tag]             pre-ripout-set_console_state_for_spawn -> pre-ripout-set_console_state_for_spawn
 * [new tag]             pre-sigrewrite              -> pre-sigrewrite
 * [new tag]             pre_wait_sig_exit           -> pre_wait_sig_exit
 * [new tag]             predaemon                   -> predaemon
 * [new tag]             prefifo                     -> prefifo
 * [new tag]             preoverlapped               -> preoverlapped
 * [new tag]             readline_4_3-import-branchpoint -> readline_4_3-import-branchpoint
 * [new tag]             readline_5_1-import-branchpoint -> readline_5_1-import-branchpoint
 * [new tag]             reparent-point              -> reparent-point
 * [new tag]             repo-unification-2000-02-06 -> repo-unification-2000-02-06
 * [new tag]             reverse-20080717-branchpoint -> reverse-20080717-branchpoint
 * [new tag]             reverse-20080930-branchpoint -> reverse-20080930-branchpoint
 * [new tag]             reverse-20081226-branchpoint -> reverse-20081226-branchpoint
 * [new tag]             sid-20020905-branchpoint    -> sid-20020905-branchpoint
 * [new tag]             sid-snapshot-20071001       -> sid-snapshot-20071001
 * [new tag]             sid-snapshot-20071101       -> sid-snapshot-20071101
 * [new tag]             sid-snapshot-20071201       -> sid-snapshot-20071201
 * [new tag]             sid-snapshot-20080101       -> sid-snapshot-20080101
 * [new tag]             sid-snapshot-20080201       -> sid-snapshot-20080201
 * [new tag]             sid-snapshot-20080301       -> sid-snapshot-20080301
 * [new tag]             sid-snapshot-20080401       -> sid-snapshot-20080401
 * [new tag]             sid-snapshot-20080403       -> sid-snapshot-20080403
 * [new tag]             sid-snapshot-20080501       -> sid-snapshot-20080501
 * [new tag]             sid-snapshot-20080601       -> sid-snapshot-20080601
 * [new tag]             sid-snapshot-20080701       -> sid-snapshot-20080701
 * [new tag]             sid-snapshot-20080801       -> sid-snapshot-20080801
 * [new tag]             sid-snapshot-20080901       -> sid-snapshot-20080901
 * [new tag]             sid-snapshot-20081001       -> sid-snapshot-20081001
 * [new tag]             sid-snapshot-20081101       -> sid-snapshot-20081101
 * [new tag]             sid-snapshot-20081201       -> sid-snapshot-20081201
 * [new tag]             sid-snapshot-20090101       -> sid-snapshot-20090101
 * [new tag]             sid-snapshot-20090201       -> sid-snapshot-20090201
 * [new tag]             sid-snapshot-20090301       -> sid-snapshot-20090301
 * [new tag]             sid-snapshot-20090401       -> sid-snapshot-20090401
 * [new tag]             sid-snapshot-20090501       -> sid-snapshot-20090501
 * [new tag]             sid-snapshot-20090601       -> sid-snapshot-20090601
 * [new tag]             sid-snapshot-20090701       -> sid-snapshot-20090701
 * [new tag]             sid-snapshot-20090801       -> sid-snapshot-20090801
 * [new tag]             sid-snapshot-20090901       -> sid-snapshot-20090901
 * [new tag]             sid-snapshot-20091001       -> sid-snapshot-20091001
 * [new tag]             sid-snapshot-20091101       -> sid-snapshot-20091101
 * [new tag]             sid-snapshot-20091201       -> sid-snapshot-20091201
 * [new tag]             sid-snapshot-20100101       -> sid-snapshot-20100101
 * [new tag]             sid-snapshot-20100201       -> sid-snapshot-20100201
 * [new tag]             sid-snapshot-20100301       -> sid-snapshot-20100301
 * [new tag]             sid-snapshot-20100401       -> sid-snapshot-20100401
 * [new tag]             sid-snapshot-20100501       -> sid-snapshot-20100501
 * [new tag]             sid-snapshot-20100601       -> sid-snapshot-20100601
 * [new tag]             sid-snapshot-20100701       -> sid-snapshot-20100701
 * [new tag]             sid-snapshot-20100801       -> sid-snapshot-20100801
 * [new tag]             sid-snapshot-20100901       -> sid-snapshot-20100901
 * [new tag]             sid-snapshot-20101001       -> sid-snapshot-20101001
 * [new tag]             sid-snapshot-20101101       -> sid-snapshot-20101101
 * [new tag]             sid-snapshot-20101201       -> sid-snapshot-20101201
 * [new tag]             sid-snapshot-20110101       -> sid-snapshot-20110101
 * [new tag]             sid-snapshot-20110201       -> sid-snapshot-20110201
 * [new tag]             sid-snapshot-20110301       -> sid-snapshot-20110301
 * [new tag]             sid-snapshot-20110401       -> sid-snapshot-20110401
 * [new tag]             sid-snapshot-20110501       -> sid-snapshot-20110501
 * [new tag]             sid-snapshot-20110601       -> sid-snapshot-20110601
 * [new tag]             sid-snapshot-20110701       -> sid-snapshot-20110701
 * [new tag]             sid-snapshot-20110801       -> sid-snapshot-20110801
 * [new tag]             sid-snapshot-20110901       -> sid-snapshot-20110901
 * [new tag]             sid-snapshot-20111001       -> sid-snapshot-20111001
 * [new tag]             sid-snapshot-20111101       -> sid-snapshot-20111101
 * [new tag]             sid-snapshot-20111201       -> sid-snapshot-20111201
 * [new tag]             sid-snapshot-20120101       -> sid-snapshot-20120101
 * [new tag]             sid-snapshot-20120201       -> sid-snapshot-20120201
 * [new tag]             sid-snapshot-20120301       -> sid-snapshot-20120301
 * [new tag]             sid-snapshot-20120401       -> sid-snapshot-20120401
 * [new tag]             sid-snapshot-20120501       -> sid-snapshot-20120501
 * [new tag]             sid-snapshot-20120601       -> sid-snapshot-20120601
 * [new tag]             sid-snapshot-20120701       -> sid-snapshot-20120701
 * [new tag]             sid-snapshot-20120801       -> sid-snapshot-20120801
 * [new tag]             sid-snapshot-20120901       -> sid-snapshot-20120901
 * [new tag]             sid-snapshot-20121001       -> sid-snapshot-20121001
 * [new tag]             sid-snapshot-20121101       -> sid-snapshot-20121101
 * [new tag]             sid-snapshot-20121201       -> sid-snapshot-20121201
 * [new tag]             sid-snapshot-20130101       -> sid-snapshot-20130101
 * [new tag]             sid-snapshot-20130201       -> sid-snapshot-20130201
 * [new tag]             sid-snapshot-20130301       -> sid-snapshot-20130301
 * [new tag]             sid-snapshot-20130401       -> sid-snapshot-20130401
 * [new tag]             sid-snapshot-20130501       -> sid-snapshot-20130501
 * [new tag]             sid-snapshot-20130601       -> sid-snapshot-20130601
 * [new tag]             sid-snapshot-20130701       -> sid-snapshot-20130701
 * [new tag]             sid-snapshot-20130801       -> sid-snapshot-20130801
 * [new tag]             sid-snapshot-20130901       -> sid-snapshot-20130901
 * [new tag]             sid-snapshot-20131001       -> sid-snapshot-20131001
 * [new tag]             sid-snapshot-20131101       -> sid-snapshot-20131101
 * [new tag]             sid-snapshot-20131201       -> sid-snapshot-20131201
 * [new tag]             sid-snapshot-20140101       -> sid-snapshot-20140101
 * [new tag]             sid-snapshot-20140201       -> sid-snapshot-20140201
 * [new tag]             sid-snapshot-20140301       -> sid-snapshot-20140301
 * [new tag]             sid-snapshot-20140401       -> sid-snapshot-20140401
 * [new tag]             sid-snapshot-20140501       -> sid-snapshot-20140501
 * [new tag]             sid-snapshot-20140601       -> sid-snapshot-20140601
 * [new tag]             sid-snapshot-20140701       -> sid-snapshot-20140701
 * [new tag]             sid-snapshot-20140801       -> sid-snapshot-20140801
 * [new tag]             sid-snapshot-20140901       -> sid-snapshot-20140901
 * [new tag]             sid-snapshot-20141001       -> sid-snapshot-20141001
 * [new tag]             sid-snapshot-20141101       -> sid-snapshot-20141101
 * [new tag]             sid-snapshot-20141201       -> sid-snapshot-20141201
 * [new tag]             sid-snapshot-20150101       -> sid-snapshot-20150101
 * [new tag]             sid-snapshot-20150201       -> sid-snapshot-20150201
 * [new tag]             sid-snapshot-20150301       -> sid-snapshot-20150301
 * [new tag]             tcltk840-20020924-branchpoint -> tcltk840-20020924-branchpoint
 * [new tag]             w32api-1_5                  -> w32api-1_5
 * [new tag]             w32api-2_2                  -> w32api-2_2
 * [new tag]             winsup-2000-02-17           -> winsup-2000-02-17
 * [new tag]             x86_64versiong3             -> x86_64versiong3
HEAD is now at 1a5c603b9 Version 1.8.5
From https://github.com/zephyrproject-rtos/segger
 * [new branch]      master       -> refs/west/master
 * [new branch]      v1.14-branch -> refs/west/v1.14-branch
HEAD is now at 9d01912 segger: config: RTT spinlock implementation
From https://github.com/zephyrproject-rtos/tinycrypt
HEAD is now at 3e9a49d cmake: Fix conditional in root CMakeLists.txt
From https://github.com/zephyrproject-rtos/uoscore-uedhoc
 * [new branch]      zephyr     -> refs/west/zephyr
HEAD is now at 150f4eb [zephyr fromlist] Adapt to changes in name generation in zcbor 0.8.0
From https://github.com/zephyrproject-rtos/zcbor
 * [new branch]      main              -> refs/west/main
 * [new branch]      release/0.6.1     -> refs/west/release/0.6.1
 * [new branch]      release/0.8.2     -> refs/west/release/0.8.2
 * [new tag]         0.1.0             -> 0.1.0
 * [new tag]         0.2.0             -> 0.2.0
 * [new tag]         0.3.0             -> 0.3.0
 * [new tag]         0.3.1             -> 0.3.1
 * [new tag]         0.4.0             -> 0.4.0
 * [new tag]         0.5.0             -> 0.5.0
 * [new tag]         0.5.1             -> 0.5.1
 * [new tag]         0.6.0             -> 0.6.0
 * [new tag]         0.8.0             -> 0.8.0
 * [new tag]         0.8.1             -> 0.8.1
 * [new tag]         0.9.0             -> 0.9.0
 * [new tag]         deprecated-master -> deprecated-master
 * [new tag]         inital-pr         -> inital-pr
 * [new tag]         old-structure     -> old-structure
HEAD is now at d3093b5 Update version from 0.8.99 to 0.8.1
ERROR: update failed for projects: matter, cmock
Error: Launched process exited with non-zero status: 1
2024-09-07T16:40:30.647Z DEBUG Sending event "toolchain-manager: running nrfutil toolchain-manager"
2024-09-07T16:41:21.645Z INFO Successfully removed toolchain directory: C:\ncs\toolchains\cf2149caf2
From other forum threads, this seems to be a network connection issue. But I am having a stable ~50Mbps download speed and have tried installing during off-peak hours, so I have no idea what's wrong. Please help, thank you.
