Some time i got this error msg
error] [ Client] - Encountered error -105: Command connect_to_emu_with_snr executed for 40 milliseconds with result -105
ERROR: Unable to connect to a debugger.
[error] [ Worker] - JLinkARM.dll Open returned error 'Cannot connect to J-Link.'
ERROR: The JLinkARM DLL timed out while communicating to the J-Link probe.
ERROR: If the error condition persists, run the same command again with
ERROR: argument -- log, contact Nordic Semiconductor and provide the generated
ERROR: log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 35: nrfjprog --program .....edge/build_1/zephyr/merged.hex --sectoranduicrerase --verify -f NRF52 --snr 1050250697
[error] [ Client] - Encountered error -160: Command verify_file executed for 318 milliseconds with result -160
[error] [ nRF52] - Failed while performing 'Verify' operation on target address 0x00000000.
-160: Data does not match in address range [0x00000000 - 0x000088BD] (Flash)
Expected byte value 0xC0 but read 0x80 at address 0x00001448.
[error] [ nRF52] - Failed while verifying device. -160: Data does not match in address range [0x00000000 - 0x000088BD] (Flash)
[error] [ Worker] - Data does not match in address range [0x00000000 - 0x000088BD] (Flash)
ERROR: Write verify failed.
a recover or earease all helps but not garanteed.
