nrf52840 going into fault continously
Hi, I am trying to run DHCP Client example using ethernet w5500 and my nrf is continously going into fault. sometimes it gets the ip correctly and goes into fault and other times when it starts immediately goes into fault.
I have ran same code on nrf52832 and it works fine, even tries it on nrf9160 and works fine, the issue occur on this one
any insights on this ?
This pictures shows it got the IP from router and went into fault
This picture shows it went into fault in the start
I tried running mqtt with ethernet and was going into fault as well and mqtt with ethernet works fine on nrf52832
Also I tried increasing stack size and also given alot of heap but same issue, so it is definitly not related to that.
  • nrf52840 dts
     * Copyright (c) 2017 Linaro Limited
    /dts-v1/;
    #include <nordic/nrf52840_qiaa.dtsi>
    #include "nrf52840dk_nrf52840-pinctrl.dtsi"
    #include <zephyr/dt-bindings/input/input-event-codes.h>
    	model = "Nordic nRF52840 DK NRF52840";
    	compatible = "nordic,nrf52840-dk-nrf52840";
    	chosen {
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,bt-mon-uart = &uart0;
    		zephyr,bt-c2h-uart = &uart0;
    		zephyr,sram = &sram0;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    		zephyr,ieee802154 = &ieee802154;
    	leds {
    		compatible = "gpio-leds";
    		led0: led_0 {
    			gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
    			label = "Green LED 0";
    		led1: led_1 {
    			gpios = <&gpio0 14 GPIO_ACTIVE_LOW>;
    			label = "Green LED 1";
    		led2: led_2 {
    			gpios = <&gpio0 15 GPIO_ACTIVE_LOW>;
    			label = "Green LED 2";
    		led3: led_3 {
    			gpios = <&gpio0 16 GPIO_ACTIVE_LOW>;
    			label = "Green LED 3";
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led0: pwm_led_0 {
    			pwms = <&pwm0 0 PWM_MSEC(20) PWM_POLARITY_INVERTED>;
    	buttons {
    		compatible = "gpio-keys";
    		button0: button_0 {
    			gpios = <&gpio0 11 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 0";
    			zephyr,code = <INPUT_KEY_0>;
    		button1: button_1 {
    			gpios = <&gpio0 12 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 1";
    			zephyr,code = <INPUT_KEY_1>;
    		button2: button_2 {
    			gpios = <&gpio0 24 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 2";
    			zephyr,code = <INPUT_KEY_2>;
    		button3: button_3 {
    			gpios = <&gpio0 25 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 3";
    			zephyr,code = <INPUT_KEY_3>;
    	arduino_header: connector {
    		compatible = "arduino-header-r3";
    		#gpio-cells = <2>;
    		gpio-map-mask = <0xffffffff 0xffffffc0>;
    		gpio-map-pass-thru = <0 0x3f>;
    		gpio-map = <0 0 &gpio0 3 0>,	/* A0 */
    			   <1 0 &gpio0 4 0>,	/* A1 */
    			   <2 0 &gpio0 28 0>,	/* A2 */
    			   <3 0 &gpio0 29 0>,	/* A3 */
    			   <4 0 &gpio0 30 0>,	/* A4 */
    			   <5 0 &gpio0 31 0>,	/* A5 */
    			   <6 0 &gpio1 1 0>,	/* D0 */
    			   <7 0 &gpio1 2 0>,	/* D1 */
    			   <8 0 &gpio1 3 0>,	/* D2 */
    			   <9 0 &gpio1 4 0>,	/* D3 */
    			   <10 0 &gpio1 5 0>,	/* D4 */
    			   <11 0 &gpio1 6 0>,	/* D5 */
    			   <12 0 &gpio1 7 0>,	/* D6 */
    			   <13 0 &gpio1 8 0>,	/* D7 */
    			   <14 0 &gpio1 10 0>,	/* D8 */
    			   <15 0 &gpio1 11 0>,	/* D9 */
    			   <16 0 &gpio1 12 0>,	/* D10 */
    			   <17 0 &gpio1 13 0>,	/* D11 */
    			   <18 0 &gpio1 14 0>,	/* D12 */
    			   <19 0 &gpio1 15 0>,	/* D13 */
    			   <20 0 &gpio0 26 0>,	/* D14 */
    			   <21 0 &gpio0 27 0>;	/* D15 */
    	arduino_adc: analog-connector {
    		compatible = "arduino,uno-adc";
    		#io-channel-cells = <1>;
    		io-channel-map = <0 &adc 1>,	/* A0 = P0.3 = AIN1 */
    				 <1 &adc 2>,	/* A1 = P0.4 = AIN2 */
    				 <2 &adc 4>,	/* A2 = P0.28 = AIN4 */
    				 <3 &adc 5>,	/* A3 = P0.29 = AIN5 */
    				 <4 &adc 6>,	/* A4 = P0.30 = AIN6 */
    				 <5 &adc 7>;	/* A5 = P0.31 = AIN7 */
    	/* These aliases are provided for compatibility with samples */
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    		led3 = &led3;
    		pwm-led0 = &pwm_led0;
    		sw0 = &button0;
    		sw1 = &button1;
    		sw2 = &button2;
    		sw3 = &button3;
    		bootloader-led0 = &led0;
    		mcuboot-button0 = &button0;
    		mcuboot-led0 = &led0;
    		watchdog0 = &wdt0;
    		spi-flash0 = &mx25r64;
    &adc {
    	status = "okay";
    &uicr {
    	gpio-as-nreset;
    &gpiote {
    	status = "okay";
    &gpio0 {
    	status = "okay";
    	gpio-reserved-ranges = <0 2>, <6 1>, <8 3>, <17 7>;
    	gpio-line-names = "XL1", "XL2", "AREF", "A0", "A1", "RTS", "TXD",
    		"CTS", "RXD", "NFC1", "NFC2", "BUTTON1", "BUTTON2", "LED1",
    		"LED2", "LED3", "LED4", "QSPI CS", "RESET", "QSPI CLK",
    		"QSPI DIO0", "QSPI DIO1", "QSPI DIO2", "QSPI DIO3","BUTTON3",
    		"BUTTON4", "SDA", "SCL", "A2", "A3", "A4", "A5";
    &gpio1 {
    	status = "okay";
    	gpio-line-names = "", "D0", "D1", "D2", "D3", "D4", "D5", "D6",
    		"D7", "", "D8", "D9", "D10", "D11", "D12", "D13";
    &uart0 {
    	status = "okay";
    	current-speed = <115200>;
    	pinctrl-0 = <&uart0_default>;
    	pinctrl-1 = <&uart0_sleep>;
    arduino_serial: &uart1 {
    	pinctrl-0 = <&uart1_default>;
    	pinctrl-1 = <&uart1_sleep>;
    arduino_i2c: &i2c0 {
    	compatible = "nordic,nrf-twi";
    	status = "okay";
    	pinctrl-0 = <&i2c0_default>;
    	pinctrl-1 = <&i2c0_sleep>;
    &i2c1 {
    	/* Cannot be used together with spi1. */
    	/* status = "okay"; */
    	pinctrl-0 = <&i2c1_default>;
    	pinctrl-1 = <&i2c1_sleep>;
    &pwm0 {
    	status = "okay";
    	pinctrl-0 = <&pwm0_default>;
    	pinctrl-1 = <&pwm0_sleep>;
    &spi0 {
    	compatible = "nordic,nrf-spi";
    	/* Cannot be used together with i2c0. */
    	pinctrl-0 = <&spi0_default>;
    	pinctrl-1 = <&spi0_sleep>;
    &spi1 {
    	status = "okay";
    	pinctrl-0 = <&spi1_default>;
    	pinctrl-1 = <&spi1_sleep>;
    &spi2 {
    	status = "disabled";
    	pinctrl-0 = <&spi2_default>;
    	pinctrl-1 = <&spi2_sleep>;
    &qspi {
    	status = "okay";
    	pinctrl-0 = <&qspi_default>;
    	pinctrl-1 = <&qspi_sleep>;
    	mx25r64: mx25r6435f@0 {
    		compatible = "nordic,qspi-nor";
    		reg = <0>;
    		/* MX25R64 supports only pp and pp4io */
    		writeoc = "pp4io";
    		/* MX25R64 supports all readoc options */
    		readoc = "read4io";
    		sck-frequency = <8000000>;
    		jedec-id = [c2 28 17];
    		sfdp-bfp = [
    			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
    			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
    			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
    			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
    		size = <67108864>;
    		has-dpd;
    		t-enter-dpd = <10000>;
    		t-exit-dpd = <35000>;
    arduino_spi: &spi3 {
    	status = "okay";
    	cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>; /* D10 */
    	pinctrl-0 = <&spi3_default>;
    	pinctrl-1 = <&spi3_sleep>;
    &ieee802154 {
    	status = "okay";
    &flash0 {
    	partitions {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		boot_partition: partition@0 {
    			label = "mcuboot";
    			reg = <0x00000000 0x0000C000>;
    		slot0_partition: partition@c000 {
    			label = "image-0";
    			reg = <0x0000C000 0x00076000>;
    		slot1_partition: partition@82000 {
    			label = "image-1";
    			reg = <0x00082000 0x00076000>;
    		 * The flash starting at 0x000f8000 and ending at
    		 * 0x000fffff is reserved for use by the application.
    		 * Storage partition will be used by FCB/LittleFS/NVS
    		 * if enabled.
    		storage_partition: partition@f8000 {
    			label = "storage";
    			reg = <0x000f8000 0x00008000>;
    zephyr_udc0: &usbd {
    	compatible = "nordic,nrf-usbd";
    	status = "okay";
    And here is my overlay for W5500
    /* Copyright (c) 2022 Linumiz
    &arduino_spi {
    	status = "okay";
    	/*Custom added by me */
    	eth_w5500_arceli_eth_w5500: eth_w5500@0 {
    		compatible = "wiznet,w5500";
    		reg = <0x0>;
    		spi-max-frequency = <80000000>;
    		int-gpios = <&arduino_header 15 GPIO_ACTIVE_LOW>;	/* D9 */
    		reset-gpios = <&arduino_header 14 GPIO_ACTIVE_LOW>;	/* D8 */
    		local-mac-address = [ 02 08 dc 86 07 e2 ];
    I know you can get all the info from .dts file but incase I am attaching this as well.
    Thank you for sharing this.
    Can you try to lower the SPI frequency to 4 MHz, for testing purposes? That is the line: "spi-max-frequency = <4000000>;"
    Håkon
  • Hi can you explain a little bit how do you find addresses in .map file ?
    Do you have a logic analyser available?
    I would recommend that you scope your SPI pins, including cs-gpios/int-gpios/reset-gpios, to see if there is something out of the ordinary on the bus there. If you are not that experienced with SPI, feel free to share the trace here.
    RAM is mapped from address 0x2000_0000 and upwards. Each RAM location is tagged with a starting address and a size. Since the thread that the fault is pointing to is a part of the w5500 structure, it will not find it directly, so we have to find the nearest RAM address location to see what object is using that area.
    Håkon
