Can't connect to BLE peripheral using bt_le_set_auto_conn via HCI
I have Thingy:91 dev board. I have flashed hci_lpuart sample to nrf52840 and successfully ran lte_ble_gateway sample. Now in my application I want to connect to the same hard-coded peripheral, address of which I know. I try to use bt_le_set_auto_conn to establish connection, but connection always fails with the message:
[00:07:24.113,311] <dbg> bt_hci_core: hci_event: event 0x3e
[00:07:24.113,342] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x02
[00:07:24.113,342] <dbg> bt_scan: bt_hci_le_adv_report: Adv number of reports 1
[00:07:24.113,464] <dbg> bt_scan: le_adv_recv: D3:6F:83:29:A1:91 (random) event 0, len 26, rssi -47 dBm
[00:07:24.113,464] <dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x200c param_len 2
[00:07:24.113,494] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x20018974
[00:07:24.113,525] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x20018974 opcode 0x200c len 5
[00:07:24.113,616] <dbg> bt_hci_core: process_events: count 2
[00:07:24.113,616] <dbg> bt_hci_core: process_events: ev->state 4
[00:07:24.113,647] <dbg> bt_hci_core: send_cmd: calling net_buf_get
[00:07:24.113,647] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
[00:07:24.113,677] <dbg> bt_hci_core: send_cmd: Sending command 0x200c (buf 0x20018974) to driver
[00:07:24.113,708] <dbg> bt_hci_core: bt_send: buf 0x20018974 len 5 type 0
[00:07:24.113,769] <dbg> bt_hci_core: process_events: ev->state 0
[00:07:24.113,800] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 2 events
[00:07:24.115,447] <dbg> bt_hci_core: bt_recv_unsafe: buf 0x20018560 len 6
[00:07:24.115,478] <dbg> bt_hci_core: hci_cmd_complete: opcode 0x200c
[00:07:24.115,509] <dbg> bt_hci_core: hci_cmd_done: opcode 0x200c status 0x00 buf 0x20018560
[00:07:24.115,570] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x20018974 opcode 0x200c len 1
[00:07:24.115,661] <dbg> bt_id: set_random_address: F7:0B:12:8F:37:44
[00:07:24.115,692] <dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x2005 param_len 6
[00:07:24.115,722] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x20018974
[00:07:24.115,753] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x20018974 opcode 0x2005 len 9
[00:07:24.115,814] <dbg> bt_hci_core: process_events: count 2
[00:07:24.115,844] <dbg> bt_hci_core: process_events: ev->state 4
[00:07:24.115,844] <dbg> bt_hci_core: send_cmd: calling net_buf_get
[00:07:24.115,875] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
[00:07:24.115,905] <dbg> bt_hci_core: send_cmd: Sending command 0x2005 (buf 0x20018974) to driver
[00:07:24.115,905] <dbg> bt_hci_core: bt_send: buf 0x20018974 len 9 type 0
[00:07:24.115,966] <dbg> bt_hci_core: process_events: ev->state 0
[00:07:24.115,997] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 2 events
[00:07:24.117,675] <dbg> bt_hci_core: bt_recv_unsafe: buf 0x20018560 len 6
[00:07:24.117,706] <dbg> bt_hci_core: hci_cmd_complete: opcode 0x2005
[00:07:24.117,706] <dbg> bt_hci_core: hci_cmd_done: opcode 0x2005 status 0x00 buf 0x20018560
[00:07:24.117,797] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x20018974 opcode 0x2005 len 1
[00:07:24.117,828] <dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x200d param_len 25
[00:07:24.117,858] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x20018974
[00:07:24.117,889] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x20018974 opcode 0x200d len 28
[00:07:24.117,950] <dbg> bt_hci_core: process_events: count 2
[00:07:24.117,980] <dbg> bt_hci_core: process_events: ev->state 4
[00:07:24.117,980] <dbg> bt_hci_core: send_cmd: calling net_buf_get
[00:07:24.118,011] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
[00:07:24.118,041] <dbg> bt_hci_core: send_cmd: Sending command 0x200d (buf 0x20018974) to driver
[00:07:24.118,041] <dbg> bt_hci_core: bt_send: buf 0x20018974 len 28 type 0
[00:07:24.118,133] <dbg> bt_hci_core: process_events: ev->state 0
[00:07:24.118,164] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 2 events
[00:07:24.119,995] <dbg> bt_hci_core: bt_recv_unsafe: buf 0x20018560 len 6
[00:07:24.120,025] <dbg> bt_hci_core: hci_cmd_status: opcode 0x200d
[00:07:24.120,056] <dbg> bt_hci_core: hci_cmd_done: opcode 0x200d status 0x30 buf 0x20018560
[00:07:24.120,117] <wrn> bt_hci_core: opcode 0x200d status 0x30
[00:07:24.120,239] <err> https_client: Failed to connect to D3:6F:83:29:A1:91 (random) (31)
My code looks like this:
bt_addr_le_t addr = {0};
struct bt_conn *conn;
static void ble_ready(int err)
LOG_INF("Bluetooth ready, %d", err);
bt_conn_cb_register(&conn_callbacks);
char * addr_str = "D3:6F:83:29:A1:91";
bt_addr_le_from_str(addr_str, "random", &addr);
LOG_INF("Auto connecting");
int err2 = bt_le_set_auto_conn(&addr, &param);
if(err2) {
LOG_ERR("Could not start autoconnect - %d", err);
My proj.conf has the same Bluetooth settings as in lte_ble_gateway sample:
# Enable Bluetooth stack and libraries
CONFIG_BT=y
CONFIG_BT_H4=y
CONFIG_BT_WAIT_NOP=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_CREATE_CONN_TIMEOUT=10
CONFIG_BT_HCI=y
I can connect to device If I specify service UUID in scan filters and perform a scan. Also I can connect if I add address to scan filters and perform a scan, but bt_le_set_auto_conn does not work. Please help!
    In the beginning of the trace I can find that it throw an HCI failed to connect:
    The below means:
    SDC_HCI_OPCODE_CMD_LE_CREATE_CONN = 0x200d,
    2.47 PARAMETER OUT OF MANDATORY RANGE (0x30)
    The Parameter Out Of Mandatory Range error code indicates that a parameter
    value requested is outside the mandatory range of parameters for the given
    HCI command or LMP PDU and the recipient does not accept that value.
    Likely some illegal connection parameters provided, so I would have started looking there.
    Kenneth
  • My connection parameters are nothing out of ordinary. Since I have moved on with CONFIG_BT_FILTER_ACCEPT_LIST and bt_conn_le_create_auto as bt_le_set_auto_conn is being deprecated, I use the same connection params:
    struct bt_le_conn_param conn_param = {
    .interval_max = 15, .interval_min = 15, .latency = 0, .timeout = 800};
    I think you can close this issue.
