I was developing on Visual Studio Code earlier, and for some reason, I cannot build pristine. If I try to edit the build configuration, it never loads, and if I try to copy the build command to do it manually, I get the following error message
"Error running command nrf-connect.copyBuildCommand: Cannot read properties of undefined (reading 'filter'). This is likely caused by the extension that contributes nrf-connect.copyBuildCommand."
Even if I type the build command itself, it will build without adding in 'pristine', but when I do add it, it just hangs.
This was the first time I have done any code changes for a few days, so assumed it was the latest update on the extensions, so rolled them all back to last stable ones, but that hasn't fixed it.
Damien
