Currently, my environment uses a mobile network shared through a wired connection to an RT-AX57 router.
I am working in the VSCode environment using SDK v2.6.1.
Devices: Nest Mini
Phone: Samsung A30
Each time I try to add a device via Google Home, it fails due to a timeout.
For the Matter Lock, I have configured everything through the Google Developer Console, but when I try to add it, even the image doesn't appear, which makes me think the Google Developer Console settings might not be loading properly.
I'm not sure if this is the issue.
As for the Matter Thermostat, I tried modifying the prj.conf and changed CONFIG_CHIP_DEVICE_PRODUCT_ID to 32773, setting the device as a light. I noticed that a light bulb icon appears, which suggests that the Google Developer Console settings are being recognized, but I still cannot add the device.
this is lock log cannot find device
uart:~$ *** Booting nRF Connect SDK v3.5.99-ncs1-1 *** I: 276 [DL]BLE address: C4:83:0E:48:20:4A D: 312 [DL]WiFiManager has been initialized I: 317 [DL]CHIP task running I: Init CHIP stack I: 326 [SVR]Subscription persistence not supported I: 330 [SVR]Server initializing... I: 333 [TS]Last Known Good Time: [unknown] I: 337 [TS]Setting Last Known Good Time to firmware build time 2023-10-14T01:16:48 I: 345 [DMG]AccessControl: initializing I: 349 [DMG]Examples::AccessControlDelegate::Init I: 353 [DMG]AccessControl: setting I: 356 [DMG]DefaultAclStorage: initializing I: 360 [DMG]DefaultAclStorage: 0 entries loaded D: 364 [IN]UDP::Init bind&listen port=5540 D: 368 [IN]UDP::Init bound to port=5540 D: 372 [IN]BLEBase::Init - setting/overriding transport D: 377 [IN]TransportMgr initialized I: 384 [ZCL]Using ZAP configuration... I: 389 [DMG]AccessControlCluster: initializing D: 393 [DL]Boot reason: 1 I: 395 [ZCL]Initiating Admin Commissioning cluster. I: 400 [ZCL]Door Lock server initialized I: 403 [ZCL]Door Lock cluster initialized at endpoint #1 I: 409 [ZCL]0xde895ep 1 clus 0x0000_0101 attr 0x0000_0013 not supported E: 415 [ZCL]Failed to set DoorLock number of RFID users: 86 I: 420 [DIS]Updating services using commissioning mode 0 I: 426 [DIS]CHIP minimal mDNS started advertising. I: 430 [IN]CASE Server enabling CASE session setups D: 435 [IN]SecureSession[0x20004958]: Allocated Type:2 LSID:11764 I: 441 [SVR]Joining Multicast groups I: 444 [SVR]Server Listening... I: 447 [DL]Device Configuration: I: 450 [DL] Serial Number: 11223344556677889900 I: 455 [DL] Vendor Id: 65521 (0xFFF1) I: 458 [DL] Product Id: 32774 (0x8006) I: 462 [DL] Product Name: not-specified I: 465 [DL] Hardware Version: 0 I: 468 [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021 I: 473 [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00) I: 480 [DL] Manufacturing Date: 2022-01-01 I: 484 [DL] Device Type: 65535 (0xFFFF) I: 487 [SVR]SetupQRCode: [MT:8IXS142C00KA0648G00] I: 492 [SVR]Copy/paste the below URL in a browser to see the QR Code: I: 498 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A8IXS142C00KA0648G00 I: 507 [SVR]Manual pairing code: [34970112332] E: 511 [DL]Long dispatch time: 188 ms, for event type 2
this is template log timeout
uart:~$ *** Booting nRF Connect SDK v3.5.99-ncs1-1 *** I: 153 [DL]BLE address: F5:1E:A9:49:EE:F6 D: 183 [DL]WiFiManager has been initialized I: 188 [DL]CHIP task running I: Init CHIP stack I: 193 [SVR]Subscription persistence not supported I: 197 [SVR]Server initializing... I: 201 [TS]Last Known Good Time: 2023-10-14T01:16:48 I: 206 [DMG]AccessControl: initializing I: 209 [DMG]Examples::AccessControlDelegate::Init I: 214 [DMG]AccessControl: setting I: 217 [DMG]DefaultAclStorage: initializing I: 221 [DMG]DefaultAclStorage: 0 entries loaded D: 225 [IN]UDP::Init bind&listen port=5540 D: 229 [IN]UDP::Init bound to port=5540 D: 232 [IN]BLEBase::Init - setting/overriding transport D: 237 [IN]TransportMgr initialized I: 242 [ZCL]Using ZAP configuration... I: 247 [DMG]AccessControlCluster: initializing D: 251 [DL]Boot reason: 1 I: 253 [ZCL]Initiating Admin Commissioning cluster. D: 259 [IN]SecureSession[0x200044c8]: Allocated Type:1 LSID:35570 D: 264 [DL]CHIPoBLE advertising set to on I: 268 [DIS]Updating services using commissioning mode 1 I: 273 [DIS]CHIP minimal mDNS started advertising. D: 278 [DL]Using wifi MAC for hostname I: 282 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 D: 291 [DIS]Responding with _matterc._udp.local D: 295 [DIS]Responding with EB2BC0A5558BF1F2._matterc._udp.local D: 301 [DIS]Responding with F4CE360024AE.local D: 305 [DIS]Responding with F4CE360024AE.local D: 309 [DIS]Responding with _V65521._sub._matterc._udp.local D: 314 [DIS]Responding with _S15._sub._matterc._udp.local D: 319 [DIS]Responding with _L3840._sub._matterc._udp.local D: 325 [DIS]Responding with _CM._sub._matterc._udp.local D: 330 [DIS]Responding with EB2BC0A5558BF1F2._matterc._udp.local I: 336 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: EB2BC0A5558BF1F2. I: 345 [DIS]mDNS service published: _matterc._udp I: 349 [DIS]Updating services using commissioning mode 1 I: 354 [DIS]CHIP minimal mDNS started advertising. D: 359 [DL]Using wifi MAC for hostname I: 363 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 D: 372 [DIS]Responding with _matterc._udp.local D: 376 [DIS]Responding with EB2BC0A5558BF1F2._matterc._udp.local D: 382 [DIS]Responding with F4CE360024AE.local D: 386 [DIS]Responding with F4CE360024AE.local D: 390 [DIS]Responding with _V65521._sub._matterc._udp.local D: 396 [DIS]Responding with _S15._sub._matterc._udp.local D: 401 [DIS]Responding with _L3840._sub._matterc._udp.local D: 406 [DIS]Responding with _CM._sub._matterc._udp.local D: 411 [DIS]Responding with EB2BC0A5558BF1F2._matterc._udp.local I: 417 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: EB2BC0A5558BF1F2. I: 426 [DIS]mDNS service published: _matterc._udp I: 431 [IN]CASE Server enabling CASE session setups D: 436 [IN]SecureSession[0x20004588]: Allocated Type:2 LSID:35571 I: 441 [SVR]Joining Multicast groups I: 445 [SVR]Server Listening... I: 448 [DL]Device Configuration: I: 451 [DL] Serial Number: 11223344556677889900 I: 455 [DL] Vendor Id: 65521 (0xFFF1) I: 458 [DL] Product Id: 32773 (0x8005) I: 462 [DL] Product Name: not-specified I: 466 [DL] Hardware Version: 0 I: 469 [DL] Setup Pin Code (0 for UNKNOWN/ERROR): 20202021 I: 474 [DL] Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00) I: 480 [DL] Manufacturing Date: 2022-01-01 I: 484 [DL] Device Type: 65535 (0xFFFF) I: 488 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00] I: 492 [SVR]Copy/paste the below URL in a browser to see the QR Code: I: 498 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00 I: 507 [SVR]Manual pairing code: [34970112332] E: 511 [DL]Long dispatch time: 320 ms, for event type 2 I: 520 [DL]CHIPoBLE advertising started I: 3746 [DL]Current number of connections: 1/1 I: 3750 [DL]BLE connection established (ConnId: 0x00) I: 3755 [DL]CHIPoBLE advertising stopped D: 4476 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 4483 [BLE]local and remote recv window sizes = 5 I: 4487 [BLE]selected BTP version 4 I: 4491 [BLE]using BTP fragment sizes rx 128 / tx 128. D: 4550 [DL]ConnId: 0x00, New CCCD value: 0x0002 D: 4554 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6) D: 4561 [IN]BLE EndPoint 0x2000b0f0 Connection Complete I: 4566 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 131) D: 4774 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 4782 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 4790 [EM]>>> [E:48639r S:0 M:174071045] (U) Msg RX from 0:2F7D2B38E0B183DB [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest) I: 4803 [EM]<<< [E:48639r S:0 M:172248504] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) D: 4815 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) I: 4823 [SVR]Commissioning session establishment step started D: 4909 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 4917 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 18) D: 4999 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 5007 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 5015 [EM]>>> [E:48639r S:0 M:174071046] (U) Msg RX from 0:2F7D2B38E0B183DB [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1) I: 6396 [EM]<<< [E:48639r S:0 M:172248505] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2) D: 6408 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) E: 6416 [DL]Long dispatch time: 1409 ms, for event type 16388 D: 6529 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 6537 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 6) D: 6619 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 6627 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 6635 [EM]>>> [E:48639r S:0 M:174071047] (U) Msg RX from 0:2F7D2B38E0B183DB [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3) I: 6646 [EM]<<< [E:48639r S:0 M:172248506] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport) D: 6658 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 35) I: 6667 [SC]SecureSession[0x200044c8, LSID:35570]: State change 'kEstablishing' --> 'kActive' D: 6675 [IN]SecureSession[0x200044c8]: Activated - Type:1 LSID:35570 D: 6681 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:35570 PSID:14100! I: 6689 [SVR]Commissioning completed session establishment step I: 6695 [DIS]Updating services using commissioning mode 0 I: 6701 [DIS]CHIP minimal mDNS started advertising. D: 6705 [DL]CHIPoBLE advertising set to off I: 6710 [SVR]Device completed Rendezvous process D: 6754 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 6800 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 6807 [EM]>>> [E:48640r S:35570 M:72872369] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 6818 [IM]Received Read request I: 6823 [EM]<<< [E:48640r S:35570 M:113290107] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 6834 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 91) D: 6889 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 6897 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 6905 [EM]>>> [E:48641r S:35570 M:72872370] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 6916 [IM]Received Read request I: 6920 [EM]<<< [E:48641r S:35570 M:113290108] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 6931 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72) D: 7024 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 7032 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 7040 [EM]>>> [E:48642r S:35570 M:72872371] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 7051 [IM]Received Read request I: 7055 [EM]<<< [E:48642r S:35570 M:113290109] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 7066 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72) D: 7159 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 7167 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 7175 [EM]>>> [E:48643r S:35570 M:72872372] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 7186 [IM]Received Read request I: 7190 [EM]<<< [E:48643r S:35570 M:113290110] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 7201 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72) D: 7294 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 7302 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 7310 [EM]>>> [E:48644r S:35570 M:72872373] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 7321 [IM]Received Read request I: 7325 [EM]<<< [E:48644r S:35570 M:113290111] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 7336 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 7429 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 7437 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 7445 [EM]>>> [E:48645r S:35570 M:72872374] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 7456 [IM]Received Read request I: 7460 [EM]<<< [E:48645r S:35570 M:113290112] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 7471 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 7564 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 7572 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 7580 [EM]>>> [E:48646r S:35570 M:72872375] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 7591 [IM]Received Read request I: 7595 [EM]<<< [E:48646r S:35570 M:113290113] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 7606 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 7699 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 7707 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 7715 [EM]>>> [E:48647r S:35570 M:72872376] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 7727 [ZCL]OpCreds: Certificate Chain request received for DAC I: 7736 [EM]<<< [E:48647r S:35570 M:113290114] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 7748 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 7834 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 7842 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 7924 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 7932 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 8014 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 8022 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 8105 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 8112 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 8119 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 57) D: 8194 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 8240 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 8247 [EM]>>> [E:48648r S:35570 M:72872377] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 8258 [IM]Received Read request I: 8263 [EM]<<< [E:48648r S:35570 M:113290115] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 8274 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 91) D: 8374 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 8382 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 8390 [EM]>>> [E:48649r S:35570 M:72872378] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 8401 [IM]Received Read request I: 8405 [EM]<<< [E:48649r S:35570 M:113290116] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 8416 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 72) D: 8509 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 9185 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 9192 [EM]>>> [E:48650r S:35570 M:72872379] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:0a (IM:TimedRequest) I: 9204 [EM]<<< [E:48650r S:35570 M:113290117] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:01 (IM:StatusResponse) D: 9215 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43) D: 9274 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 9282 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 9290 [EM]>>> [E:48650r S:35570 M:72872380] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 9302 [FS]GeneralCommissioning: Received ArmFailSafe (120s) I: 9309 [EM]<<< [E:48650r S:35570 M:113290118] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 9320 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 9409 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 9417 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 9425 [EM]>>> [E:48651r S:35570 M:72872381] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest) D: 9436 [IM]Received Read request I: 9440 [EM]<<< [E:48651r S:35570 M:113290119] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) D: 9451 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 9544 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 9552 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 9560 [EM]>>> [E:48652r S:35570 M:72872382] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:0a (IM:TimedRequest) I: 9572 [EM]<<< [E:48652r S:35570 M:113290120] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:01 (IM:StatusResponse) D: 9583 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 43) D: 9679 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 9687 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 9695 [EM]>>> [E:48652r S:35570 M:72872383] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 9710 [EM]<<< [E:48652r S:35570 M:113290121] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 9722 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 9814 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 9822 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 9830 [EM]>>> [E:48653r S:35570 M:72872384] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 9842 [ZCL]OpCreds: Certificate Chain request received for PAI I: 9851 [EM]<<< [E:48653r S:35570 M:113290122] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 9863 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 9949 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 9957 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 10039 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 10047 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 10129 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 10137 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 10220 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 10227 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 10234 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 28) D: 10309 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 10317 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 10325 [EM]>>> [E:48654r S:35570 M:72872385] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 10337 [ZCL]OpCreds: Received an AttestationRequest command I: 10374 [ZCL]OpCreds: AttestationRequest successful. I: 10383 [EM]<<< [E:48654r S:35570 M:113290123] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 10395 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 10489 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 10497 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 10579 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 10587 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 10669 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 10677 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 10760 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 10767 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 10775 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 10849 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 10857 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 92) D: 10939 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 10947 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 10955 [EM]>>> [E:48655r S:35570 M:72872386] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 10967 [ZCL]OpCreds: Received a CSRRequest command I: 11117 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded I: 11153 [ZCL]OpCreds: CSRRequest successful. I: 11159 [EM]<<< [E:48655r S:35570 M:113290124] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 11172 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) E: 11179 [DL]Long dispatch time: 232 ms, for event type 16388 D: 11254 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 11262 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 128) D: 11389 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 11397 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 126) D: 11479 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 12965 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 13056 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 13146 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 13155 [EM]>>> [E:48656r S:35570 M:72872387] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 13167 [ZCL]OpCreds: Received an AddTrustedRootCertificate command I: 13229 [ZCL]OpCreds: AddTrustedRootCertificate successful. I: 13236 [EM]<<< [E:48656r S:35570 M:113290125] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 13248 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 68) E: 13255 [DL]Long dispatch time: 110 ms, for event type 16388 D: 13324 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 13332 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 13416 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 13506 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 13596 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 13603 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 13684 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 13692 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 13775 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 13786 [EM]>>> [E:48657r S:35570 M:72872388] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest) I: 13798 [ZCL]OpCreds: Received an AddNOC command I: 13805 [FP]Validating NOC chain I: 13921 [FP]NOC chain validation successful I: 13925 [FP]Added new fabric at index: 0x1 I: 13929 [FP]Assigned compressed fabric ID: 0x7BABAAB43C4053C0, node ID: 0x000000000E634654 I: 13937 [TS]Last Known Good Time: 2023-10-14T01:16:48 I: 13942 [TS]New proposed Last Known Good Time: 2024-09-11T15:59:54 I: 13948 [TS]Updating pending Last Known Good Time to 2024-09-11T15:59:54 I: 13962 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0xFFFFFFFD00010001 D: 13971 [DL]Using wifi MAC for hostname I: 13975 [DIS]Advertise operational node 7BABAAB43C4053C0-000000000E634654 D: 13982 [DIS]Responding with _matter._tcp.local D: 13986 [DIS]Responding with 7BABAAB43C4053C0-000000000E634654._matter._tcp.local D: 13993 [DIS]Responding with 7BABAAB43C4053C0-000000000E634654._matter._tcp.local D: 14001 [DIS]Responding with F4CE360024AE.local D: 14005 [DIS]Responding with F4CE360024AE.local D: 14009 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local I: 14016 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-000000000E634654. I: 14026 [DIS]mDNS service published: _matter._tcp I: 14031 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC I: 14038 [EM]<<< [E:48657r S:35570 M:113290126] (S) Msg TX to 1:FFFFFFFB00000000 [53C0] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 14050 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) E: 14058 [DL]Long dispatch time: 283 ms, for event type 16388 D: 14134 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 14142 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 14150 [EM]>>> [E:48658r S:35570 M:72872389] (S) Msg RX from 1:FFFFFFFB00000000 [53C0] --- Type 0001:08 (IM:InvokeCommandRequest) I: 14164 [EM]<<< [E:48658r S:35570 M:113290127] (S) Msg TX to 1:FFFFFFFB00000000 [53C0] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 14176 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 14269 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 14277 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 14285 [EM]>>> [E:48659r S:35570 M:72872390] (S) Msg RX from 1:FFFFFFFB00000000 [53C0] --- Type 0001:02 (IM:ReadRequest) D: 14296 [IM]Received Read request I: 14301 [EM]<<< [E:48659r S:35570 M:113290128] (S) Msg TX to 1:FFFFFFFB00000000 [53C0] [BLE] --- Type 0001:05 (IM:ReportData) D: 14312 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 71) D: 14404 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) D: 14412 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) I: 14420 [EM]>>> [E:48660r S:35570 M:72872391] (S) Msg RX from 1:FFFFFFFB00000000 [53C0] --- Type 0001:08 (IM:InvokeCommandRequest) D: 14432 [DL]Connecting to WiFi network: jim_wifi D: 14440 [DL]WiFi scanning started... D: 16920 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 17014 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) I: 19055 [DL]Wi-Fi scan done (0) I: 20600 [DL]Connection to jim_wifi requested [RSSI=-26] E: 20605 [DL]Long dispatch time: 1550 ms, for event type 3 D: 20612 [DL]Write request received for CHIPoBLE RX characteristic (ConnId 0x00) D: 23119 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 3) D: 23179 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) I: 24757 [DL]Connected to WiFi network I: 24765 [EM]<<< [E:48660r S:35570 M:113290129] (S) Msg TX to 1:FFFFFFFB00000000 [53C0] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) D: 24778 [DL]Sending indication for CHIPoBLE TX characteristic (ConnId 00, len 69) D: 24785 [DL]Using wifi MAC for hostname I: 24789 [DIS]Advertise operational node 7BABAAB43C4053C0-000000000E634654 D: 24796 [DIS]Responding with _matter._tcp.local D: 24800 [DIS]Responding with 7BABAAB43C4053C0-000000000E634654._matter._tcp.local D: 24808 [DIS]Responding with 7BABAAB43C4053C0-000000000E634654._matter._tcp.local D: 24816 [DIS]Responding with F4CE360024AE.local D: 24820 [DIS]Responding with F4CE360024AE.local D: 24825 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local I: 24831 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-000000000E634654. E: 24843 [DIS]Failed to advertise records: 46 I: 24848 [DIS]mDNS service published: _matter._tcp I: 24852 [SVR]Operational advertising enabled I: 24858 [SWU]Stopping the watchdog timer I: 24862 [SWU]Starting the periodic query timer, timeout: 86400 seconds I: 24868 [SVR]Server initialization complete I: 24872 [DIS]Updating services using commissioning mode 0 I: 24879 [DIS]CHIP minimal mDNS started advertising. D: 24892 [DL]Using wifi MAC for hostname I: 24896 [DIS]Advertise operational node 7BABAAB43C4053C0-000000000E634654 D: 24903 [DIS]Responding with _matter._tcp.local D: 24908 [DIS]Responding with 7BABAAB43C4053C0-000000000E634654._matter._tcp.local D: 24915 [DIS]Responding with 7BABAAB43C4053C0-000000000E634654._matter._tcp.local D: 24927 [DIS]Responding with F4CE360024AE.local D: 24931 [DIS]Responding with F4CE360024AE.local D: 24935 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local I: 24942 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-000000000E634654. I: 24955 [DIS]mDNS service published: _matter._tcp D: 24960 [DL]Indication for CHIPoBLE TX characteristic done (ConnId 0x00, result 0x00) I: 24968 [DIS]Updating services using commissioning mode 0 I: 24974 [DIS]CHIP minimal mDNS started advertising. D: 24985 [DL]Using wifi MAC for hostname I: 24990 [DIS]Advertise operational node 7BABAAB43C4053C0-000000000E634654 D: 24997 [DIS]Responding with _matter._tcp.local D: 25001 [DIS]Responding with 7BABAAB43C4053C0-000000000E634654._matter._tcp.local D: 25008 [DIS]Responding with 7BABAAB43C4053C0-000000000E634654._matter._tcp.local D: 25016 [DIS]Responding with F4CE360024AE.local D: 25021 [DIS]Responding with F4CE360024AE.local D: 25025 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local I: 25032 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-000000000E634654. I: 25045 [DIS]mDNS service published: _matter._tcp I: 25197 [EM]>>> [E:48661r S:0 M:174071048] (U) Msg RX from 0:5242AD7C77F8459D [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1) I: 25209 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20005de8 I: 25217 [EM]<<< [E:48661r S:0 M:172248507 (Ack:174071048)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 25236 [SC]Received Sigma1 msg I: 25242 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x000000000E634654 I: 25428 [EM]<<< [E:48661r S:0 M:172248508 (Ack:174071048)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0000:31 (SecureChannel:CASE_Sigma2) I: 25447 [SC]Sent Sigma2 msg I: 25551 [EM]>>> [E:48661r S:0 M:174071049 (Ack:172248508)] (U) Msg RX from 0:5242AD7C77F8459D [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3) I: 25564 [EM]<<< [E:48661r S:0 M:172248509 (Ack:174071049)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 25581 [SC]Received Sigma3 msg E: 25590 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time E: 25773 [DL]Long dispatch time: 173 ms, for event type 2 I: 25784 [EM]<<< [E:48661r S:0 M:172248510 (Ack:174071049)] (U) Msg TX to 0:0000000000000000 [0000] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0000:40 (SecureChannel:StatusReport) I: 25803 [SC]SecureSession[0x20004588, LSID:35571]: State change 'kEstablishing' --> 'kActive' D: 25811 [IN]SecureSession[0x20004588]: Activated - Type:2 LSID:35571 D: 25817 [IN]New secure session activated for device <00000000089E37C8, 1>, LSID:35571 PSID:14101! I: 25826 [IN]CASE Session established to peer: <00000000089E37C8, 1> D: 25832 [IN]SecureSession[0x20004648]: Allocated Type:2 LSID:35572 I: 25839 [DL]Current number of connections: 0/1 I: 25845 [DL]BLE GAP connection terminated (reason 0x13) I: 25930 [EM]>>> [E:48661r S:0 M:174071050 (Ack:172248510)] (U) Msg RX from 0:5242AD7C77F8459D [0000] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 25949 [EM]>>> [E:48662r S:35571 M:112898286] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0001:02 (IM:ReadRequest) D: 25960 [IM]Received Read request I: 25966 [EM]<<< [E:48662r S:35571 M:69422669 (Ack:112898286)] (S) Msg TX to 1:00000000089E37C8 [53C0] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0001:05 (IM:ReportData) I: 25991 [EM]>>> [E:48662r S:35571 M:112898287 (Ack:69422669)] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 26707 [EM]>>> [E:48663r S:35571 M:112898288] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0001:02 (IM:ReadRequest) D: 26718 [IM]Received Read request I: 26723 [EM]<<< [E:48663r S:35571 M:69422670 (Ack:112898288)] (S) Msg TX to 1:00000000089E37C8 [53C0] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0001:05 (IM:ReportData) I: 26750 [EM]>>> [E:48663r S:35571 M:112898289 (Ack:69422670)] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 27401 [EM]>>> [E:48664r S:35571 M:112898290] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0001:02 (IM:ReadRequest) D: 27412 [IM]Received Read request E: 27420 [DMG]Error retrieving data from clusterId: 0x0000_002A, err = b I: 27433 [EM]<<< [E:48664r S:35571 M:69422671 (Ack:112898290)] (S) Msg TX to 1:00000000089E37C8 [53C0] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0001:05 (IM:ReportData) I: 27503 [EM]>>> [E:48664r S:35571 M:112898291 (Ack:69422671)] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0001:01 (IM:StatusResponse) I: 27516 [IM]Received status response, status is 0x00 E: 27525 [DMG]Error retrieving data from clusterId: 0x0000_001D, err = b I: 27537 [EM]<<< [E:48664r S:35571 M:69422672 (Ack:112898291)] (S) Msg TX to 1:00000000089E37C8 [53C0] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0001:05 (IM:ReportData) I: 27602 [EM]>>> [E:48664r S:35571 M:112898292 (Ack:69422672)] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0001:01 (IM:StatusResponse) I: 27615 [IM]Received status response, status is 0x00 I: 27621 [EM]<<< [E:48664r S:35571 M:69422673 (Ack:112898292)] (S) Msg TX to 1:00000000089E37C8 [53C0] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0001:05 (IM:ReportData) I: 27648 [EM]>>> [E:48664r S:35571 M:112898293 (Ack:69422673)] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 28346 [EM]>>> [E:48665r S:35571 M:112898294] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0001:0a (IM:TimedRequest) I: 28358 [EM]<<< [E:48665r S:35571 M:69422674 (Ack:112898294)] (S) Msg TX to 1:00000000089E37C8 [53C0] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0001:01 (IM:StatusResponse) I: 28381 [EM]>>> [E:48665r S:35571 M:112898295 (Ack:69422674)] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0001:08 (IM:InvokeCommandRequest) I: 28394 [FS]GeneralCommissioning: Received ArmFailSafe (1s) I: 28404 [EM]<<< [E:48665r S:35571 M:69422675 (Ack:112898295)] (S) Msg TX to 1:00000000089E37C8 [53C0] [UDP:[fe80::c04f:22ff:fe4d:2aa1]:39866] --- Type 0001:09 (IM:InvokeCommandResponse) I: 28429 [EM]>>> [E:48665r S:35571 M:112898296 (Ack:69422675)] (S) Msg RX from 1:00000000089E37C8 [53C0] --- Type 0000:10 (SecureChannel:StandaloneAck) I: 29403 [FS]Fail-safe timer expired E: 29406 [SVR]Failsafe timer expired D: 29409 [IN]SecureSession[0x200044c8]: MarkForEviction Type:1 LSID:35570 I: 29416 [SC]SecureSession[0x200044c8, LSID:35570]: State change 'kActive' --> 'kPendingEviction' D: 29427 [IN]SecureSession[0x200044c8]: Released - Type:1 LSID:35570 E: 29433 [SVR]Commissioning failed (attempt 1): 32 D: 29438 [IN]Clearing BLE pending packets. I: 29442 [BLE]Releasing end point's BLE connection back to application. I: 29448 [DL]Closing BLE GATT connection (ConnId 00) D: 29453 [IN]SecureSession[0x200044c8]: Allocated Type:1 LSID:35573 D: 29459 [DL]CHIPoBLE advertising set to on I: 29463 [DIS]Updating services using commissioning mode 1 I: 29468 [DIS]CHIP minimal mDNS started advertising. D: 29480 [DL]Using wifi MAC for hostname I: 29485 [DIS]Advertise operational node 7BABAAB43C4053C0-000000000E634654 D: 29492 [DIS]Responding with _matter._tcp.local D: 29496 [DIS]Responding with 7BABAAB43C4053C0-000000000E634654._matter._tcp.local D: 29503 [DIS]Responding with 7BABAAB43C4053C0-000000000E634654._matter._tcp.local D: 29511 [DIS]Responding with F4CE360024AE.local D: 29515 [DIS]Responding with F4CE360024AE.local D: 29519 [DIS]Responding with _I7BABAAB43C4053C0._sub._matter._tcp.local I: 29527 [DIS]CHIP minimal mDNS configured as 'Operational device'; instance name: 7BABAAB43C4053C0-000000000E634654. I: 29540 [DIS]mDNS service published: _matter._tcp D: 29545 [DL]Using wifi MAC for hostname I: 29549 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 D: 29558 [DIS]Responding with _matterc._udp.local D: 29563 [DIS]Responding with EB2BC0A5558BF1F2._matterc._udp.local D: 29569 [DIS]Responding with F4CE360024AE.local D: 29573 [DIS]Responding with F4CE360024AE.local D: 29577 [DIS]Responding with _V65521._sub._matterc._udp.local D: 29583 [DIS]Responding with _S15._sub._matterc._udp.local D: 29588 [DIS]Responding with _L3840._sub._matterc._udp.local D: 29594 [DIS]Responding with _CM._sub._matterc._udp.local D: 29599 [DIS]Responding with EB2BC0A5558BF1F2._matterc._udp.local I: 29605 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: EB2BC0A5558BF1F2. I: 29626 [DIS]mDNS service published: _matterc._udp E: 29634 [ZCL]OpCreds: Got FailSafeTimerExpired E: 29638 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry! D: 29644 [IN]Expiring all sessions for fabric 0x1!! D: 29649 [IN]SecureSession[0x20004588]: MarkForEviction Type:2 LSID:35571 I: 29655 [SC]SecureSession[0x20004588, LSID:35571]: State change 'kActive' --> 'kPendingEviction' D: 29664 [IN]SecureSession[0x20004588]: Released - Type:2 LSID:35571 E: 29670 [FP]Reverting pending fabric data for fabric 0x1 E: 29676 [FP]Warning: metadata not found during delete of fabric 0x1 I: 29685 [FP]Fabric (0x1) deleted. I: 29688 [ZCL]OpCreds: Fabric index 0x1 was removed I: 29693 [DIS]Updating services using commissioning mode 1 I: 29699 [DIS]CHIP minimal mDNS started advertising. D: 29729 [DL]Using wifi MAC for hostname I: 29734 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1 D: 29743 [DIS]Responding with _matterc._udp.local D: 29747 [DIS]Responding with EB2BC0A5558BF1F2._matterc._udp.local D: 29753 [DIS]Responding with F4CE360024AE.local D: 29757 [DIS]Responding with F4CE360024AE.local D: 29762 [DIS]Responding with _V65521._sub._matterc._udp.local D: 29767 [DIS]Responding with _S15._sub._matterc._udp.local D: 29773 [DIS]Responding with _L3840._sub._matterc._udp.local D: 29778 [DIS]Responding with _CM._sub._matterc._udp.local D: 29784 [DIS]Responding with EB2BC0A5558BF1F2._matterc._udp.local I: 29789 [DIS]CHIP minimal mDNS configured as 'Commissionable node device'; instance name: EB2BC0A5558BF1F2. I: 29804 [DIS]mDNS service published: _matterc._udp I: 29821 [TS]Pending Last Known Good Time: 2024-09-11T15:59:54 I: 29827 [TS]Previous Last Known Good Time: 2023-10-14T01:16:48 I: 29834 [TS]Reverted Last Known Good Time to previous value E: 29839 [FP]Warning: metadata not found during delete of fabric 0x1 E: 29847 [ZCL]OpCreds: failed to delete fabric at index 1: d8 D: 29874 [DL]Disconnect requested E: 29877 [DL]Long dispatch time: 471 ms, for event type 32782 I: 29882 [FS]Fail-safe cleanly disarmed I: 29889 [DL]CHIPoBLE advertising started I: 29892 [DL]WiFi station disconnected I: 30689 [TS]Pending Last Known Good Time: 2023-10-14T01:16:48 I: 30695 [TS]Previous Last Known Good Time: 2023-10-14T01:16:48 I: 30700 [TS]Reverted Last Known Good Time to previous value I: 30706 [DL]Performing factory reset
