[nrf conenct] Can't manage SDKS in VScode
hello. I'm currently working on nRF connect for VS code and I'm having a problem.
After downloading the nRF connect for VS code extension, I'm having an issue with setting up the SDK and toolchain and not being able to get the SDK.
[Manage SDKs] >> [Install SDK]
If I go through the process, the nRF Connect output window will display the
[16:00:59] Update available nsscprodmedia.blob.core.windows.net/.../nrf-command-line-tools-10.24.2-x64.exe
[16:01:01] =========== Toolchain validation report for nRF Connect SDK Toolchain v2.5.0 ===========
️Exclamation️ git is required but not found. Make sure the "git" executable is in your PATH.
️Exclamation️ jlink is required but not found. Please ensure that SEGGER J-Link Software and Documentation Pack is installed.
️Exclamation️ nrfjprog couldn't be executed. Please ensure that SEGGER J-Link Software and Documentation Pack and nRF Command Line Tools are both installed.
spawn C:\Windows\System32 ENOENT
It outputs the same log record as above.
I tried saving the environment variable again to resolve this, but it didn't work.
Here is my Support Information.
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro",
    "osKernel": "10.0.19045",
    "vscode": "1.93.0",
    "electron": "30.4.0",
    "node": "v20.15.1"
  "system": {
    "date": "2024-09-12T07:08:55.185Z",
    "vscodeRoot": "c:\\Users\\CU\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:07:57",
    "osUptime": "00:30:42",
    "cpu": "Intel(R) Core(TM) i5-9400F CPU @ 2.90GHz"
  "workspace": {
    "name": "socket_tel_ex1-main",
    "workspaceFile": null,
    "folders": [
      "c:\\Users\\CU\\Documents\\GitHub\\socket_tel_ex1-main"
  "sdks": [],
  "activeBuild": "c:\\Users\\CU\\Documents\\GitHub\\socket_tel_ex1-main\\build",
  "apps": [
      "workspace": "c:\\Users\\CU\\Documents\\GitHub\\socket_tel_ex1-main",
      "uri": "c:\\Users\\CU\\Documents\\GitHub\\socket_tel_ex1-main",
      "buildConfigurations": [
          "id": "c:\\Users\\CU\\Documents\\GitHub\\socket_tel_ex1-main\\build",
          "name": "build",
          "boardId": "nrf9160dk_nrf9160_ns",
          "type": "Zephyr",
          "isChild": false,
          "isStale": false,
          "taskBindings": {
            "build": [],
            "pristineBuild": [],
            "flash": [],
            "eraseAndFlash": []
  "workspaceState": "freestanding-unconfigured",
  "toolchains": [
      "version": "2.5.0",
      "path": "c:\\ncs\\toolchains\\c57af46cb7"
  "activeToolchain": {
    "type": "installation",
    "path": "c:\\ncs\\toolchains\\c57af46cb7",
    "version": "2.5.0",
    "displayName": "nRF Connect SDK Toolchain v2.5.0"
  "connectedDevices": [
      "serialNumber": "000960034717"
  "deviceProvider": "nrfutil",
  "tools": {
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": null,
    "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": null,
    "C:\\ncs\\toolchains\\c57af46cb7\\cmake": null,
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Scripts\\west.exe": null,
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\python.exe": null,
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\ninja.exe": null,
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\gperf.exe": null,
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\dtc.exe": null,
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\gn.exe": null,
    "C:\\ncs\\toolchains\\c57af46cb7\\mingw64\\bin\\git.exe": null,
    "arm-gdbPath": "c:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe",
    "riscv-gdbPath": "not found"
  "nrfutil": {
    "nrfutil-device": {
      "version": "2.5.0",
      "binPath": "c:\\Users\\CU\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.9.87-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device"
    "nrfutil-toolchain-manager": {
      "version": "0.14.4",
      "binPath": "c:\\Users\\CU\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.9.87-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
  "environment": {
    "westEnv": {
      "HOME": "C:\\Users\\CU",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\CU",
      "PATH": "C:\\ncs\\toolchains\\c57af46cb7;C:\\ncs\\toolchains\\c57af46cb7\\mingw64\\bin;C:\\ncs\\toolchains\\c57af46cb7\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\c57af46cb7\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\aarch64-zephyr-elf\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\x86_64-zephyr-elf\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\Users\\CU\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.9.87-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Launcher\\;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312\\Scripts\\;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312\\;C:\\Users\\CU\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\CU\\AppData\\Local\\atom\\bin;C:\\Users\\CU\\AppData\\Local\\GitHubDesktop\\bin;C:\\Program Files\\Git\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;C:\\Program Files\\SEGGER\\JLink_V794e;C:\\Users\\CU\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\WINDOWS\\system32\\cmd.exe;",
      "ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk",
      "PYTHONPATH": "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Lib;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Lib\\site-packages"
    "inherited": {
      "HOMEDRIVE": "C:",
      "Path": "C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Launcher\\;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312\\Scripts\\;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312\\;C:\\Users\\CU\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\CU\\AppData\\Local\\atom\\bin;C:\\Users\\CU\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\CU\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312;C:\\Program Files\\Git\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;C:\\Program Files\\SEGGER\\JLink_V794e;C:\\Users\\CU\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\WINDOWS\\system32\\cmd.exe;",
      "PATH": "C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files\\Git\\cmd;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Launcher\\;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312\\Scripts\\;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312\\;C:\\Users\\CU\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\CU\\AppData\\Local\\atom\\bin;C:\\Users\\CU\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\CU\\AppData\\Local\\GitHubDesktop\\bin;C:\\Users\\CU\\AppData\\Local\\Programs\\Python\\Python312;C:\\Program Files\\Git\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;C:\\Program Files\\SEGGER\\JLink_V794e;C:\\Users\\CU\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\WINDOWS\\system32\\cmd.exe;"
  "terminal": {
    "defaultProfile": "Command Prompt"
  "config": {
      "topdir": "${nrf-connect.sdk:2.5.0}",
      "toolchain": {
        "path": "${nrf-connect.toolchain:2.5.0}"
      "ozonePath": "",
      "applications": [
        "${workspaceFolder}"
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig"
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "taskBindings": {},
      "buildTerminal": {
        "condensedProgress": true
      "debugging": {
        "flash": true,
        "bindings": {},
        "justMyCode": true
      "deviceProvider": "nrfjprog",
      "flash": {
        "softreset": false,
        "erase": false,
        "recover": false
      "enableTelemetry": true,
      "thirdpartyIntegration": {},
      "toolchainManager": {
        "indexURL": null,
        "installDirectory": null
      "nrfutil": {
        "home": null
      "defaultOpenAction": "ask"
      "terminalMode": "character"
  "extensions": {
    "internal": {
        "version": "2024.9.87",
        "path": "c:\\Users\\CU\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.9.87-win32-x64",
        "isActive": true
        "version": "2024.9.14",
        "path": "c:\\Users\\CU\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.9.14",
        "isActive": true
        "version": "2024.9.26",
        "path": "c:\\Users\\CU\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2024.9.26",
        "isActive": true
        "version": "2024.9.20",
        "path": "c:\\Users\\CU\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2024.9.20",
        "isActive": true
    "external": {
      "marus25.cortex-debug": null,
      "ms-vscode.cpptools": "1.21.6",
      "ms-vscode.js-debug": "1.93.0",
      "ms-vscode.vscode-js-profile-table": "1.0.9",
      "alefragnani.project-manager": "12.8.0",
      "codezombiech.gitignore": "0.9.0",
      "donjayamanne.git-extension-pack": "0.1.3",
      "donjayamanne.githistory": "0.6.20",
      "eamodio.gitlens": "15.4.0",
      "fabiospampinato.vscode-diff": "2.1.2",
      "L13RARY.l13-diff": "1.3.8",
      "mhutchie.git-graph": "1.30.0",
      "MS-CEINTL.vscode-language-pack-ko": "1.93.2024091109",
      "ms-dotnettools.csdevkit": "1.10.18",
      "ms-dotnettools.csharp": "2.45.20",
      "ms-dotnettools.vscode-dotnet-runtime": "2.1.5",
      "ms-python.debugpy": "2024.10.0",
      "ms-python.python": "2024.14.0",
      "ms-python.vscode-pylance": "2024.9.1",
      "politoleo.iar": "1.6.0",
      "seanwu.vscode-qt-for-python": "7.6.0",
      "tonka3000.qtvsctools": "0.11.0",
      "twxs.cmake": "0.0.17",
      "ziyasal.vscode-open-in-github": "1.3.6"
The bottom line is that I am not able to activate the SDK right now.
Any kind of advice to resolve this would be appreciated.
