Hi there,
I'm working on NCS2.7.0 and nrf52840.
I used the chip-cert to generate custom DAC, PAI, and PAA with VID = 0x1234 and PID = 0x5678, then placed the PAA in the /var/paa-root-certs directory on the Raspberry Pi.
Then I follow these step to generate CD and write into my FW.
https://docs.nordicsemi.com/bundle/ncs-2.7.0/page/nrf/protocols/matter/end_product/configuring_cd.html
However, when the TH attempted to pair with the device, it failed during the 'AttestationVerification' step, and the error number "101" means can not found PAA. But I've been put custom PAA into Pi.
Any Suggestion?
ubuntu@ubuntu:~/apps$ ./chip-tool pairing ble-thread 1 hex:0e080000000000010000000300001135060004001fffe0020811111111222222220708fd9e133317e6182c051000112233445566778899aa1234567890030e4f70656e54687265616444656d6f010212340410445f2b5ca6f2a93a55ce570a70efeecb0c0402a0f7f8 20240910 3840 --trace_decode 1
[1726125689.419477][1237356:1237356] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_tool_kvs
[1726125689.423485][1237356:1237356] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1726125689.423555][1237356:1237356] CHIP:DL: ChipLinuxStorage::Init: Attempt to re-initialize with KVS config file: /tmp/chip_kvs
[1726125689.430238][1237356:1237356] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1726125689.430537][1237356:1237356] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1726125689.430677][1237356:1237356] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1726125689.431211][1237356:1237356] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-PJg5ca)
[1726125689.481440][1237356:1237356] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1726125689.481541][1237356:1237356] CHIP:DL: NVS set: chip-counters/reboot-count = 105 (0x69)
[1726125689.482923][1237356:1237356] CHIP:DL: Got Ethernet interface: eth0
[1726125689.484038][1237356:1237356] CHIP:DL: Found the primary Ethernet interface:eth0
[1726125689.485135][1237356:1237356] CHIP:DL: Got WiFi interface: wlan0
[1726125689.485277][1237356:1237356] CHIP:DL: Failed to reset WiFi statistic counts
[1726125689.485370][1237356:1237356] CHIP:IN: UDP::Init bind&listen port=0
[1726125689.485527][1237356:1237356] CHIP:IN: UDP::Init bound to port=36583
[1726125689.485580][1237356:1237356] CHIP:IN: BLEBase::Init - setting/overriding transport
[1726125689.485624][1237356:1237356] CHIP:IN: TransportMgr initialized
[1726125689.485722][1237356:1237356] CHIP:FP: Initializing FabricTable from persistent storage
[1726125689.486046][1237356:1237356] CHIP:TS: Last Known Good Time: 2023-10-14T01:16:48
[1726125689.488033][1237356:1237356] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x720B8D447BDBC4C7, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1726125689.488933][1237356:1237356] CHIP:FP: Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x26C15A92CF15DB6E, FabricId 0x0000000000000002, NodeId 0x000000000001B669, VendorId 0xFFF1
[1726125689.545585][1237356:1237356] CHIP:ZCL: Using ZAP configuration...
[1726125689.564424][1237356:1237356] CHIP:DL: Avahi client registered
[1726125689.564584][1237356:1237356] CHIP:CTL: System State Initialized...
[1726125689.564779][1237356:1237356] CHIP:CTL: Setting attestation nonce to random value
[1726125689.564826][1237356:1237356] CHIP:CTL: Setting CSR nonce to random value
[1726125689.564972][1237356:1237356] CHIP:IN: UDP::Init bind&listen port=5550
[1726125689.565120][1237356:1237356] CHIP:IN: UDP::Init bound to port=5550
[1726125689.565147][1237356:1237356] CHIP:IN: TransportMgr initialized
[1726125689.565453][1237356:1237371] CHIP:DL: CHIP task running
[1726125689.566017][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 32786
[1726125689.567406][1237356:1237371] CHIP:CTL: Setting attestation nonce to random value
[1726125689.567850][1237356:1237371] CHIP:CTL: Setting CSR nonce to random value
[1726125689.570681][1237356:1237371] CHIP:CTL: Generating NOC
[1726125689.573936][1237356:1237371] CHIP:FP: Validating NOC chain
[1726125689.577696][1237356:1237371] CHIP:FP: NOC chain validation successful
[1726125689.578023][1237356:1237371] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1726125689.578073][1237356:1237371] CHIP:TS: Last Known Good Time: 2023-10-14T01:16:48
[1726125689.578094][1237356:1237371] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1726125689.578113][1237356:1237371] CHIP:TS: Retaining current Last Known Good Time
[1726125689.588425][1237356:1237371] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1726125689.593362][1237356:1237371] CHIP:TS: Committing Last Known Good Time to storage: 2023-10-14T01:16:48
[1726125689.600142][1237356:1237371] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 720B8D447BDBC4C7)
[1726125689.600239][1237356:1237371] CHIP:IN: UDP::Init bind&listen port=5550
[1726125689.600437][1237356:1237371] CHIP:IN: UDP::Init bound to port=5550
[1726125689.600497][1237356:1237371] CHIP:IN: TransportMgr initialized
[1726125689.817716][1237356:1237371] CHIP:CTL: Setting thread operational dataset from parameters
[1726125689.821448][1237356:1237371] CHIP:CTL: Setting attestation nonce to random value
[1726125689.825135][1237356:1237371] CHIP:CTL: Setting CSR nonce to random value
[1726125689.828808][1237356:1237371] CHIP:CTL: Checking ICD registration parameters
[1726125689.830507][1237356:1237371] CHIP:CTL: Commission called for node ID 0x0000000000000001
[1726125689.830682][1237356:1237371] CHIP:DL: Long dispatch time: 264 ms, for event type 2
[1726125689.860432][1237356:1237371] CHIP:DL: BlueZ integration init success
[1726125689.877016][1237356:1237368] CHIP:BLE: BLE removing known devices.
[1726125689.879714][1237356:1237368] CHIP:BLE: BLE initiating scan.
[1726125689.886056][1237356:1237371] CHIP:BLE: ChipDeviceScanner has started scanning!
[1726125689.905231][1237356:1237368] CHIP:BLE: Device D0:39:33:30:44:3C does not look like a CHIP device.
[1726125689.929331][1237356:1237368] CHIP:BLE: New device scanned: DE:D8:49:5B:8A:D3
[1726125689.929892][1237356:1237368] CHIP:BLE: Device discriminator match. Attempting to connect.
[1726125689.939131][1237356:1237368] CHIP:BLE: ChipDeviceScanner has stopped scanning!
[1726125690.259095][1237356:1237368] CHIP:DL: ConnectDevice complete
[1726125690.259163][1237356:1237368] CHIP:BLE: New device connected: DE:D8:49:5B:8A:D3
[1726125691.741137][1237356:1237368] CHIP:DL: Char /org/bluez/hci0/dev_DE_D8_49_5B_8A_D3/service0010 on service /org/bluez/hci0/dev_DE_D8_49_5B_8A_D3/service0010
[1726125691.741319][1237356:1237368] CHIP:DL: Char /org/bluez/hci0/dev_DE_D8_49_5B_8A_D3/service0010 on service /org/bluez/hci0/dev_DE_D8_49_5B_8A_D3/service0010
[1726125691.741405][1237356:1237368] CHIP:DL: Char /org/bluez/hci0/dev_DE_D8_49_5B_8A_D3/service0010 on service /org/bluez/hci0/dev_DE_D8_49_5B_8A_D3/service0010
[1726125691.741526][1237356:1237368] CHIP:DL: New BLE connection: conn 0xffffa4010130, device DE:D8:49:5B:8A:D3, path /org/bluez/hci0/dev_DE_D8_49_5B_8A_D3
[1726125691.741719][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16385
[1726125691.741775][1237356:1237371] CHIP:DIS: Closing all BLE connections
[1726125691.741897][1237356:1237371] CHIP:IN: BleConnectionComplete: endPoint 0xaaaaab82c358
[1726125691.742641][1237356:1237371] CHIP:IN: SecureSession[0xffffac00a4c0]: Allocated Type:1 LSID:64780
[1726125691.742748][1237356:1237371] CHIP:SC: Assigned local session key ID 64780
[1726125691.743168][1237356:1237371] CHIP:DMG: >> to BLE | 125782654 | [Secure Channel (0) / Password-Based Key Derivation Parameters Request (0x20) / Session = 0 / Exchange = 18843]
[1726125691.743254][1237356:1237371] CHIP:DMG: Header Flags =
[1726125691.743298][1237356:1237371] CHIP:DMG: {
[1726125691.743350][1237356:1237371] CHIP:DMG: Message (0x04) =
[1726125691.743393][1237356:1237371] CHIP:DMG: {
[1726125691.743438][1237356:1237371] CHIP:DMG: SourceNodeId = 882638345F7D1A5A
[1726125691.743481][1237356:1237371] CHIP:DMG: }
[1726125691.743531][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125691.743575][1237356:1237371] CHIP:DMG: {
[1726125691.743614][1237356:1237371] CHIP:DMG: Initiator = true
[1726125691.743656][1237356:1237371] CHIP:DMG: }
[1726125691.743705][1237356:1237371] CHIP:DMG: }
[1726125691.743747][1237356:1237371] CHIP:DMG:
[1726125691.743795][1237356:1237371] CHIP:DMG: Decrypted Payload (76 bytes) =
[1726125691.743838][1237356:1237371] CHIP:DMG: {
[1726125691.743880][1237356:1237371] CHIP:DMG: data = 1530012088b74d16c2ae52e69abfb9301661923714c9eb3b80d13b37f3342a32794320a025020cfd240300280435052501f40125022c012503a00f24041124050b2606000003012407011818
[1726125691.743922][1237356:1237371] CHIP:DMG: }
[1726125691.743964][1237356:1237371] CHIP:DMG:
[1726125691.744059][1237356:1237371] CHIP:DMG: Parameters =
[1726125691.744106][1237356:1237371] CHIP:DMG: {
[1726125691.744152][1237356:1237371] CHIP:DMG: Initiator Random (32) = 88B74D16C2AE52E69ABFB9301661923714C9EB3B80D13B37F3342A32794320A0
[1726125691.744195][1237356:1237371] CHIP:DMG: Initiator Session Id = 64780
[1726125691.744236][1237356:1237371] CHIP:DMG: Passcode Id = 0
[1726125691.744288][1237356:1237371] CHIP:DMG: hasPBKDFParameters = false
[1726125691.744335][1237356:1237371] CHIP:DMG: SED =
[1726125691.744378][1237356:1237371] CHIP:DMG: {
[1726125691.744423][1237356:1237371] CHIP:DMG: Idle Retransmit Timeout = 500
[1726125691.744468][1237356:1237371] CHIP:DMG: Active Retransmit Timeout = 300
[1726125691.744515][1237356:1237371] CHIP:DMG: }
[1726125691.744558][1237356:1237371] CHIP:DMG: }
[1726125691.744598][1237356:1237371] CHIP:DMG:
[1726125691.744640][1237356:1237371] CHIP:DMG:
[1726125691.744705][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125691.744750][1237356:1237371] CHIP:DMG: {
[1726125691.744796][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125691.744839][1237356:1237371] CHIP:DMG: }
[1726125691.744933][1237356:1237371] CHIP:DMG:
[1726125691.745003][1237356:1237371] CHIP:EM: <<< [E:18843i S:0 M:125782654] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
[1726125691.745076][1237356:1237371] CHIP:IN: Message appended to BLE send queue
[1726125691.745123][1237356:1237371] CHIP:SC: Sent PBKDF param request
[1726125692.019633][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125692.111291][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125692.111418][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
[1726125692.111879][1237356:1237371] CHIP:BLE: subscribe complete, ep = 0xaaaaab82c358
[1726125692.111929][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125692.111976][1237356:1237371] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
[1726125692.112018][1237356:1237371] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
[1726125692.112296][1237356:1237371] CHIP:BLE: local and remote recv window size = 5
[1726125692.112840][1237356:1237371] CHIP:IN: BLE EndPoint 0xaaaaab82c358 Connection Complete
[1726125692.244948][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125692.247818][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125692.248526][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125692.249162][1237356:1237371] CHIP:DMG: << from BLE | 236663842 | [Secure Channel (0) / Password-Based Key Derivation Parameters Response (0x21) / Session = 0 / Exchange = 18843]
[1726125692.249623][1237356:1237371] CHIP:DMG: Header Flags =
[1726125692.250030][1237356:1237371] CHIP:DMG: {
[1726125692.250370][1237356:1237371] CHIP:DMG: Message (0x01) =
[1726125692.250433][1237356:1237371] CHIP:DMG: {
[1726125692.250485][1237356:1237371] CHIP:DMG: DestinationNodeId = 882638345F7D1A5A
[1726125692.250804][1237356:1237371] CHIP:DMG: }
[1726125692.250864][1237356:1237371] CHIP:DMG: }
[1726125692.250885][1237356:1237371] CHIP:DMG:
[1726125692.250917][1237356:1237371] CHIP:DMG: Decrypted Payload (132 bytes) =
[1726125692.250934][1237356:1237371] CHIP:DMG: {
[1726125692.250951][1237356:1237371] CHIP:DMG: data = 1530012088b74d16c2ae52e69abfb9301661923714c9eb3b80d13b37f3342a32794320a03002207d1d3ed1284e682f75716dffb0b19884a45d159a2e140a64b63f3573e44736a82503927535042501e8033002105350414b453250204b65792053616c741835052501d0072502d0072503a00f24041124050b2606000003012407011818
[1726125692.250973][1237356:1237371] CHIP:DMG: }
[1726125692.250991][1237356:1237371] CHIP:DMG:
[1726125692.251053][1237356:1237371] CHIP:DMG: Parameters =
[1726125692.251133][1237356:1237371] CHIP:DMG: {
[1726125692.251160][1237356:1237371] CHIP:DMG: Initiator Random (32) = 88B74D16C2AE52E69ABFB9301661923714C9EB3B80D13B37F3342A32794320A0
[1726125692.251180][1237356:1237371] CHIP:DMG: Responder Random (32) = 7D1D3ED1284E682F75716DFFB0B19884A45D159A2E140A64B63F3573E44736A8
[1726125692.251196][1237356:1237371] CHIP:DMG: Responder Session Id = 30098
[1726125692.251219][1237356:1237371] CHIP:DMG: Iteration Count = 1000
[1726125692.251244][1237356:1237371] CHIP:DMG: Salt (16) = 5350414B453250204B65792053616C74
[1726125692.251266][1237356:1237371] CHIP:DMG: SED =
[1726125692.251281][1237356:1237371] CHIP:DMG: {
[1726125692.251298][1237356:1237371] CHIP:DMG: Idle Retransmit Timeout = 2000
[1726125692.251316][1237356:1237371] CHIP:DMG: Active Retransmit Timeout = 2000
[1726125692.251336][1237356:1237371] CHIP:DMG: }
[1726125692.251352][1237356:1237371] CHIP:DMG: }
[1726125692.251367][1237356:1237371] CHIP:DMG:
[1726125692.251512][1237356:1237371] CHIP:DMG:
[1726125692.251630][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125692.251761][1237356:1237371] CHIP:DMG: {
[1726125692.251822][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125692.251896][1237356:1237371] CHIP:DMG: }
[1726125692.251979][1237356:1237371] CHIP:DMG:
[1726125692.252085][1237356:1237371] CHIP:EM: >>> [E:18843i S:0 M:236663842] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
[1726125692.252145][1237356:1237371] CHIP:EM: Found matching exchange: 18843i, Delegate: 0xffffac011020
[1726125692.252238][1237356:1237371] CHIP:SC: Received PBKDF param response
[1726125692.252323][1237356:1237371] CHIP:SC: Peer assigned session ID 30098
[1726125692.252447][1237356:1237371] CHIP:SC: Found MRP parameters in the message
[1726125692.259575][1237356:1237371] CHIP:DMG: >> to BLE | 125782655 | [Secure Channel (0) / Password Authenticated Session Establishment '1' (0x22) / Session = 0 / Exchange = 18843]
[1726125692.259962][1237356:1237371] CHIP:DMG: Header Flags =
[1726125692.260145][1237356:1237371] CHIP:DMG: {
[1726125692.260321][1237356:1237371] CHIP:DMG: Message (0x04) =
[1726125692.260626][1237356:1237371] CHIP:DMG: {
[1726125692.260834][1237356:1237371] CHIP:DMG: SourceNodeId = 882638345F7D1A5A
[1726125692.261073][1237356:1237371] CHIP:DMG: }
[1726125692.261352][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125692.261623][1237356:1237371] CHIP:DMG: {
[1726125692.262111][1237356:1237371] CHIP:DMG: Initiator = true
[1726125692.262557][1237356:1237371] CHIP:DMG: }
[1726125692.262926][1237356:1237371] CHIP:DMG: }
[1726125692.263225][1237356:1237371] CHIP:DMG:
[1726125692.263548][1237356:1237371] CHIP:DMG: Decrypted Payload (70 bytes) =
[1726125692.264045][1237356:1237371] CHIP:DMG: {
[1726125692.264742][1237356:1237371] CHIP:DMG: data = 1530014104aebf24c2c7a9eecc9f76bed1fe0e7e0df3c18783b536c115e0ec4eab1de76fa3ed723be04fdfd48c1945ab06f35fd122c2c8086a0c208d74e3eb6d8b73de9a1818
[1726125692.265034][1237356:1237371] CHIP:DMG: }
[1726125692.266417][1237356:1237371] CHIP:DMG:
[1726125692.266688][1237356:1237371] CHIP:DMG: Parameters =
[1726125692.266928][1237356:1237371] CHIP:DMG: {
[1726125692.267165][1237356:1237371] CHIP:DMG: pA (65) = 04AEBF24C2C7A9EECC9F76BED1FE0E7E0DF3C18783B536C115E0EC4EAB1DE76FA3ED723BE04FDFD48C1945AB06F35FD122C2C8086A0C208D74E3EB6D8B73DE9A18
[1726125692.267344][1237356:1237371] CHIP:DMG: }
[1726125692.267502][1237356:1237371] CHIP:DMG:
[1726125692.267717][1237356:1237371] CHIP:DMG:
[1726125692.267959][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125692.268154][1237356:1237371] CHIP:DMG: {
[1726125692.268319][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125692.268511][1237356:1237371] CHIP:DMG: }
[1726125692.268691][1237356:1237371] CHIP:DMG:
[1726125692.268977][1237356:1237371] CHIP:EM: <<< [E:18843i S:0 M:125782655] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:22 (SecureChannel:PASE_Pake1)
[1726125692.271158][1237356:1237371] CHIP:SC: Sent spake2p msg1
[1726125692.334997][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125692.471767][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125692.472471][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125692.473082][1237356:1237371] CHIP:DMG: << from BLE | 236663843 | [Secure Channel (0) / Password Authenticated Session Establishment '2' (0x23) / Session = 0 / Exchange = 18843]
[1726125692.473484][1237356:1237371] CHIP:DMG: Header Flags =
[1726125692.473748][1237356:1237371] CHIP:DMG: {
[1726125692.474049][1237356:1237371] CHIP:DMG: Message (0x01) =
[1726125692.474448][1237356:1237371] CHIP:DMG: {
[1726125692.474782][1237356:1237371] CHIP:DMG: DestinationNodeId = 882638345F7D1A5A
[1726125692.474866][1237356:1237371] CHIP:DMG: }
[1726125692.474939][1237356:1237371] CHIP:DMG: }
[1726125692.475005][1237356:1237371] CHIP:DMG:
[1726125692.475119][1237356:1237371] CHIP:DMG: Decrypted Payload (105 bytes) =
[1726125692.475420][1237356:1237371] CHIP:DMG: {
[1726125692.475503][1237356:1237371] CHIP:DMG: data = 1530014104f51dcd441f90f0166a377e5c4d90742be354786fc187723611e7d14f18e6f268154131473a2cab2452bb91fc84c381d53b401a65b76526c38a4ba0dea52312e93002206c3a1d3e23e77e3f92420c9904e602f239693cdf60c08db49982534601f7d53418
[1726125692.475558][1237356:1237371] CHIP:DMG: }
[1726125692.475621][1237356:1237371] CHIP:DMG:
[1726125692.476057][1237356:1237371] CHIP:DMG: Parameters =
[1726125692.476142][1237356:1237371] CHIP:DMG: {
[1726125692.476200][1237356:1237371] CHIP:DMG: pB (65) = 04F51DCD441F90F0166A377E5C4D90742BE354786FC187723611E7D14F18E6F268154131473A2CAB2452BB91FC84C381D53B401A65B76526C38A4BA0DEA52312E9
[1726125692.476270][1237356:1237371] CHIP:DMG: cB (32) = 6C3A1D3E23E77E3F92420C9904E602F239693CDF60C08DB49982534601F7D534
[1726125692.476384][1237356:1237371] CHIP:DMG: }
[1726125692.476698][1237356:1237371] CHIP:DMG:
[1726125692.476778][1237356:1237371] CHIP:DMG:
[1726125692.476895][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125692.477252][1237356:1237371] CHIP:DMG: {
[1726125692.477352][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125692.477423][1237356:1237371] CHIP:DMG: }
[1726125692.477539][1237356:1237371] CHIP:DMG:
[1726125692.477860][1237356:1237371] CHIP:EM: >>> [E:18843i S:0 M:236663843] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
[1726125692.477956][1237356:1237371] CHIP:EM: Found matching exchange: 18843i, Delegate: 0xffffac011020
[1726125692.478057][1237356:1237371] CHIP:SC: Received spake2p msg2
[1726125692.480343][1237356:1237371] CHIP:DMG: >> to BLE | 125782656 | [Secure Channel (0) / Password Authenticated Session Establishment '3' (0x24) / Session = 0 / Exchange = 18843]
[1726125692.480802][1237356:1237371] CHIP:DMG: Header Flags =
[1726125692.481233][1237356:1237371] CHIP:DMG: {
[1726125692.481511][1237356:1237371] CHIP:DMG: Message (0x04) =
[1726125692.481937][1237356:1237371] CHIP:DMG: {
[1726125692.482443][1237356:1237371] CHIP:DMG: SourceNodeId = 882638345F7D1A5A
[1726125692.482819][1237356:1237371] CHIP:DMG: }
[1726125692.483205][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125692.483561][1237356:1237371] CHIP:DMG: {
[1726125692.484045][1237356:1237371] CHIP:DMG: Initiator = true
[1726125692.484450][1237356:1237371] CHIP:DMG: }
[1726125692.484818][1237356:1237371] CHIP:DMG: }
[1726125692.485175][1237356:1237371] CHIP:DMG:
[1726125692.495018][1237356:1237371] CHIP:DMG: Decrypted Payload (37 bytes) =
[1726125692.495101][1237356:1237371] CHIP:DMG: {
[1726125692.495151][1237356:1237371] CHIP:DMG: data = 15300120db9dd46be74c535af9d024ea081be8409de90f563a0f28204eef0c59568983da18
[1726125692.495202][1237356:1237371] CHIP:DMG: }
[1726125692.495252][1237356:1237371] CHIP:DMG:
[1726125692.495345][1237356:1237371] CHIP:DMG: Parameters =
[1726125692.495859][1237356:1237371] CHIP:DMG: {
[1726125692.495991][1237356:1237371] CHIP:DMG: cA (32) = DB9DD46BE74C535AF9D024EA081BE8409DE90F563A0F28204EEF0C59568983DA
[1726125692.496042][1237356:1237371] CHIP:DMG: }
[1726125692.496087][1237356:1237371] CHIP:DMG:
[1726125692.496133][1237356:1237371] CHIP:DMG:
[1726125692.496326][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125692.496388][1237356:1237371] CHIP:DMG: {
[1726125692.496696][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125692.496752][1237356:1237371] CHIP:DMG: }
[1726125692.496799][1237356:1237371] CHIP:DMG:
[1726125692.496906][1237356:1237371] CHIP:EM: <<< [E:18843i S:0 M:125782656] (U) Msg TX to 0:0000000000000000 [0000] [BLE] --- Type 0000:24 (SecureChannel:PASE_Pake3)
[1726125692.498080][1237356:1237371] CHIP:SC: Sent spake2p msg3
[1726125692.559649][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125692.605490][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125692.605759][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125692.606121][1237356:1237371] CHIP:DMG: << from BLE | 236663844 | [Secure Channel (0) / Status Report (0x40) / Session = 0 / Exchange = 18843]
[1726125692.606169][1237356:1237371] CHIP:DMG: Header Flags =
[1726125692.606192][1237356:1237371] CHIP:DMG: {
[1726125692.606217][1237356:1237371] CHIP:DMG: Message (0x01) =
[1726125692.606233][1237356:1237371] CHIP:DMG: {
[1726125692.606251][1237356:1237371] CHIP:DMG: DestinationNodeId = 882638345F7D1A5A
[1726125692.606273][1237356:1237371] CHIP:DMG: }
[1726125692.606301][1237356:1237371] CHIP:DMG: }
[1726125692.606317][1237356:1237371] CHIP:DMG:
[1726125692.606340][1237356:1237371] CHIP:DMG: Decrypted Payload (8 bytes) =
[1726125692.606356][1237356:1237371] CHIP:DMG: {
[1726125692.606371][1237356:1237371] CHIP:DMG: data = 0000000000000000
[1726125692.606386][1237356:1237371] CHIP:DMG: }
[1726125692.606405][1237356:1237371] CHIP:DMG:
[1726125692.606432][1237356:1237371] CHIP:DMG: Parameters =
[1726125692.606448][1237356:1237371] CHIP:DMG: {
[1726125692.606464][1237356:1237371] CHIP:DMG: GeneralStatusCode = 0
[1726125692.606479][1237356:1237371] CHIP:DMG: ProtocolId = 0
[1726125692.606494][1237356:1237371] CHIP:DMG: ProtocolCode = 0
[1726125692.606578][1237356:1237371] CHIP:DMG: }
[1726125692.606596][1237356:1237371] CHIP:DMG:
[1726125692.606612][1237356:1237371] CHIP:DMG:
[1726125692.606652][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125692.606673][1237356:1237371] CHIP:DMG: {
[1726125692.606693][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125692.606710][1237356:1237371] CHIP:DMG: }
[1726125692.606725][1237356:1237371] CHIP:DMG:
[1726125692.606756][1237356:1237371] CHIP:EM: >>> [E:18843i S:0 M:236663844] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
[1726125692.606785][1237356:1237371] CHIP:EM: Found matching exchange: 18843i, Delegate: 0xffffac011020
[1726125692.607092][1237356:1237371] CHIP:SC: SecureSession[0xffffac00a4c0, LSID:64780]: State change 'kEstablishing' --> 'kActive'
[1726125692.607132][1237356:1237371] CHIP:IN: SecureSession[0xffffac00a4c0]: Activated - Type:1 LSID:64780
[1726125692.607153][1237356:1237371] CHIP:IN: New secure session activated for device <FFFFFFFB00000000, 0>, LSID:64780 PSID:30098!
[1726125692.607224][1237356:1237371] CHIP:CTL: Remote device completed SPAKE2+ handshake
[1726125692.607249][1237356:1237371] CHIP:TOO: Pairing Success
[1726125692.607267][1237356:1237371] CHIP:TOO: PASE establishment successful
[1726125692.607288][1237356:1237371] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1726125692.607313][1237356:1237371] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
[1726125692.607332][1237356:1237371] CHIP:CTL: Sending read request for commissioning information
[1726125692.607406][1237356:1237371] CHIP:DMG: SendReadRequest ReadClient[0xffffac009ff0]: Sending Read Request
[1726125692.607743][1237356:1237371] CHIP:DMG: >> to BLE | 127805170 | [Interaction Model (1) / Read Request (0x02) / Session = 30098 / Exchange = 18844]
[1726125692.607833][1237356:1237371] CHIP:DMG: Header Flags =
[1726125692.607857][1237356:1237371] CHIP:DMG: {
[1726125692.607890][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125692.607939][1237356:1237371] CHIP:DMG: {
[1726125692.607961][1237356:1237371] CHIP:DMG: Initiator = true
[1726125692.607981][1237356:1237371] CHIP:DMG: }
[1726125692.608006][1237356:1237371] CHIP:DMG: }
[1726125692.608026][1237356:1237371] CHIP:DMG:
[1726125692.608050][1237356:1237371] CHIP:DMG: Decrypted Payload (101 bytes) =
[1726125692.608070][1237356:1237371] CHIP:DMG: {
[1726125692.608090][1237356:1237371] CHIP:DMG: data = 153600172403312504fcff181724020024033024040018172402002403302404011817240200240330240402181724020024033024040318172402002403282404021817240200240328240404181724033124040318172402002403381818280324ff0b18
[1726125692.608112][1237356:1237371] CHIP:DMG: }
[1726125692.608130][1237356:1237371] CHIP:DMG:
[1726125692.608196][1237356:1237371] CHIP:DMG: ReadRequestMessage =
[1726125692.608220][1237356:1237371] CHIP:DMG: {
[1726125692.608239][1237356:1237371] CHIP:DMG: AttributePathIBs =
[1726125692.608292][1237356:1237371] CHIP:DMG: [
[1726125692.608362][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.608441][1237356:1237371] CHIP:DMG: {
[1726125692.608522][1237356:1237371] CHIP:DMG: Cluster = 0x31,
[1726125692.608607][1237356:1237371] CHIP:DMG: Attribute = 0x0000_FFFC,
[1726125692.608691][1237356:1237371] CHIP:DMG: }
[1726125692.608768][1237356:1237371] CHIP:DMG:
[1726125692.608904][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.608990][1237356:1237371] CHIP:DMG: {
[1726125692.609095][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.609185][1237356:1237371] CHIP:DMG: Cluster = 0x30,
[1726125692.609270][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0000,
[1726125692.609354][1237356:1237371] CHIP:DMG: }
[1726125692.609430][1237356:1237371] CHIP:DMG:
[1726125692.609505][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.609580][1237356:1237371] CHIP:DMG: {
[1726125692.609655][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.609743][1237356:1237371] CHIP:DMG: Cluster = 0x30,
[1726125692.609902][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0001,
[1726125692.609989][1237356:1237371] CHIP:DMG: }
[1726125692.610091][1237356:1237371] CHIP:DMG:
[1726125692.610166][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.610266][1237356:1237371] CHIP:DMG: {
[1726125692.610343][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.610453][1237356:1237371] CHIP:DMG: Cluster = 0x30,
[1726125692.610566][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0002,
[1726125692.610652][1237356:1237371] CHIP:DMG: }
[1726125692.610754][1237356:1237371] CHIP:DMG:
[1726125692.610829][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.610929][1237356:1237371] CHIP:DMG: {
[1726125692.611005][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.611115][1237356:1237371] CHIP:DMG: Cluster = 0x30,
[1726125692.611215][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0003,
[1726125692.613471][1237356:1237371] CHIP:DMG: }
[1726125692.613805][1237356:1237371] CHIP:DMG:
[1726125692.613911][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.614014][1237356:1237371] CHIP:DMG: {
[1726125692.614093][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.614208][1237356:1237371] CHIP:DMG: Cluster = 0x28,
[1726125692.614322][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0002,
[1726125692.614408][1237356:1237371] CHIP:DMG: }
[1726125692.614513][1237356:1237371] CHIP:DMG:
[1726125692.614614][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.614693][1237356:1237371] CHIP:DMG: {
[1726125692.614797][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.615258][1237356:1237371] CHIP:DMG: Cluster = 0x28,
[1726125692.615359][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0004,
[1726125692.615472][1237356:1237371] CHIP:DMG: }
[1726125692.615671][1237356:1237371] CHIP:DMG:
[1726125692.616029][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.617628][1237356:1237371] CHIP:DMG: {
[1726125692.618069][1237356:1237371] CHIP:DMG: Cluster = 0x31,
[1726125692.618194][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0003,
[1726125692.618282][1237356:1237371] CHIP:DMG: }
[1726125692.618365][1237356:1237371] CHIP:DMG:
[1726125692.618476][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.618935][1237356:1237371] CHIP:DMG: {
[1726125692.619052][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.619142][1237356:1237371] CHIP:DMG: Cluster = 0x38,
[1726125692.619308][1237356:1237371] CHIP:DMG: }
[1726125692.619416][1237356:1237371] CHIP:DMG:
[1726125692.619493][1237356:1237371] CHIP:DMG: ],
[1726125692.619896][1237356:1237371] CHIP:DMG:
[1726125692.620014][1237356:1237371] CHIP:DMG: isFabricFiltered = false,
[1726125692.620086][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125692.620151][1237356:1237371] CHIP:DMG: },
[1726125692.620529][1237356:1237371] CHIP:DMG:
[1726125692.620664][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125692.621002][1237356:1237371] CHIP:DMG: {
[1726125692.621075][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125692.621121][1237356:1237371] CHIP:DMG: }
[1726125692.621164][1237356:1237371] CHIP:DMG:
[1726125692.621390][1237356:1237371] CHIP:EM: <<< [E:18844i S:64780 M:127805170] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:02 (IM:ReadRequest)
[1726125692.624484][1237356:1237371] CHIP:DMG: MoveToState ReadClient[0xffffac009ff0]: Moving to [AwaitingIn]
[1726125692.694551][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125692.748653][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125692.749323][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125692.831783][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125692.834037][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125692.834496][1237356:1237371] CHIP:DMG: << from BLE | 105600308 | [Interaction Model (1) / Report Data (0x05) / Session = 64780 / Exchange = 18844]
[1726125692.834818][1237356:1237371] CHIP:DMG: Header Flags =
[1726125692.834992][1237356:1237371] CHIP:DMG: {
[1726125692.836640][1237356:1237371] CHIP:DMG: }
[1726125692.836985][1237356:1237371] CHIP:DMG:
[1726125692.837054][1237356:1237371] CHIP:DMG: Decrypted Payload (228 bytes) =
[1726125692.837101][1237356:1237371] CHIP:DMG: {
[1726125692.837145][1237356:1237371] CHIP:DMG: data = 1536011535012600e97ee3dc37012402002403312404031824021418181535012600b316b9883701240200240328240404182502785618181535012600b316b9883701240200240328240402182502341218181535012600e489729637012402002403302404031824020018181535012600e489729637012402002403302404021824020018181535012600e4897296370124020024033024040118350224003c250184031818181535012600e489729637012402002403302404001824020018181535012600e97ee3dc37012402002403312504fcff18240202181818290424ff0b18
[1726125692.837193][1237356:1237371] CHIP:DMG: }
[1726125692.837233][1237356:1237371] CHIP:DMG:
[1726125692.837682][1237356:1237371] CHIP:DMG:
[1726125692.837766][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125692.837811][1237356:1237371] CHIP:DMG: {
[1726125692.837906][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125692.838103][1237356:1237371] CHIP:DMG: }
[1726125692.839647][1237356:1237371] CHIP:DMG:
[1726125692.839988][1237356:1237371] CHIP:EM: >>> [E:18844i S:64780 M:105600308] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
[1726125692.840053][1237356:1237371] CHIP:EM: Found matching exchange: 18844i, Delegate: 0xffffac00a000
[1726125692.840179][1237356:1237371] CHIP:DMG: ReportDataMessage =
[1726125692.840493][1237356:1237371] CHIP:DMG: {
[1726125692.840548][1237356:1237371] CHIP:DMG: AttributeReportIBs =
[1726125692.840620][1237356:1237371] CHIP:DMG: [
[1726125692.840681][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125692.840759][1237356:1237371] CHIP:DMG: {
[1726125692.842658][1237356:1237371] CHIP:DMG: AttributeDataIB =
[1726125692.842797][1237356:1237371] CHIP:DMG: {
[1726125692.843188][1237356:1237371] CHIP:DMG: DataVersion = 0xdce37ee9,
[1726125692.845409][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.845557][1237356:1237371] CHIP:DMG: {
[1726125692.845928][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.846042][1237356:1237371] CHIP:DMG: Cluster = 0x31,
[1726125692.846152][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0003,
[1726125692.846258][1237356:1237371] CHIP:DMG: }
[1726125692.847187][1237356:1237371] CHIP:DMG:
[1726125692.847301][1237356:1237371] CHIP:DMG: Data = 20,
[1726125692.847397][1237356:1237371] CHIP:DMG: },
[1726125692.851226][1237356:1237371] CHIP:DMG:
[1726125692.851608][1237356:1237371] CHIP:DMG: },
[1726125692.851716][1237356:1237371] CHIP:DMG:
[1726125692.851784][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125692.851867][1237356:1237371] CHIP:DMG: {
[1726125692.851942][1237356:1237371] CHIP:DMG: AttributeDataIB =
[1726125692.852353][1237356:1237371] CHIP:DMG: {
[1726125692.852454][1237356:1237371] CHIP:DMG: DataVersion = 0x88b916b3,
[1726125692.852620][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.852783][1237356:1237371] CHIP:DMG: {
[1726125692.852918][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.853277][1237356:1237371] CHIP:DMG: Cluster = 0x28,
[1726125692.853394][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0004,
[1726125692.853737][1237356:1237371] CHIP:DMG: }
[1726125692.854114][1237356:1237371] CHIP:DMG:
[1726125692.854223][1237356:1237371] CHIP:DMG: Data = 22136,
[1726125692.854318][1237356:1237371] CHIP:DMG: },
[1726125692.854409][1237356:1237371] CHIP:DMG:
[1726125692.854749][1237356:1237371] CHIP:DMG: },
[1726125692.854853][1237356:1237371] CHIP:DMG:
[1726125692.854925][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125692.855006][1237356:1237371] CHIP:DMG: {
[1726125692.855330][1237356:1237371] CHIP:DMG: AttributeDataIB =
[1726125692.855434][1237356:1237371] CHIP:DMG: {
[1726125692.855524][1237356:1237371] CHIP:DMG: DataVersion = 0x88b916b3,
[1726125692.855675][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.855976][1237356:1237371] CHIP:DMG: {
[1726125692.856084][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.856396][1237356:1237371] CHIP:DMG: Cluster = 0x28,
[1726125692.856515][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0002,
[1726125692.856621][1237356:1237371] CHIP:DMG: }
[1726125692.856722][1237356:1237371] CHIP:DMG:
[1726125692.856977][1237356:1237371] CHIP:DMG: Data = 4660,
[1726125692.857079][1237356:1237371] CHIP:DMG: },
[1726125692.857420][1237356:1237371] CHIP:DMG:
[1726125692.857502][1237356:1237371] CHIP:DMG: },
[1726125692.857592][1237356:1237371] CHIP:DMG:
[1726125692.857656][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125692.857736][1237356:1237371] CHIP:DMG: {
[1726125692.858803][1237356:1237371] CHIP:DMG: AttributeDataIB =
[1726125692.858923][1237356:1237371] CHIP:DMG: {
[1726125692.859347][1237356:1237371] CHIP:DMG: DataVersion = 0x967289e4,
[1726125692.859451][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.859550][1237356:1237371] CHIP:DMG: {
[1726125692.859648][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.859755][1237356:1237371] CHIP:DMG: Cluster = 0x30,
[1726125692.860172][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0003,
[1726125692.860285][1237356:1237371] CHIP:DMG: }
[1726125692.860387][1237356:1237371] CHIP:DMG:
[1726125692.860681][1237356:1237371] CHIP:DMG: Data = 0,
[1726125692.860782][1237356:1237371] CHIP:DMG: },
[1726125692.860900][1237356:1237371] CHIP:DMG:
[1726125692.861239][1237356:1237371] CHIP:DMG: },
[1726125692.861341][1237356:1237371] CHIP:DMG:
[1726125692.861773][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125692.861895][1237356:1237371] CHIP:DMG: {
[1726125692.862246][1237356:1237371] CHIP:DMG: AttributeDataIB =
[1726125692.862354][1237356:1237371] CHIP:DMG: {
[1726125692.862445][1237356:1237371] CHIP:DMG: DataVersion = 0x967289e4,
[1726125692.862540][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.862973][1237356:1237371] CHIP:DMG: {
[1726125692.863085][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.863270][1237356:1237371] CHIP:DMG: Cluster = 0x30,
[1726125692.863601][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0002,
[1726125692.863713][1237356:1237371] CHIP:DMG: }
[1726125692.864110][1237356:1237371] CHIP:DMG:
[1726125692.864223][1237356:1237371] CHIP:DMG: Data = 0,
[1726125692.864573][1237356:1237371] CHIP:DMG: },
[1726125692.864692][1237356:1237371] CHIP:DMG:
[1726125692.864768][1237356:1237371] CHIP:DMG: },
[1726125692.864999][1237356:1237371] CHIP:DMG:
[1726125692.865299][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125692.865400][1237356:1237371] CHIP:DMG: {
[1726125692.865478][1237356:1237371] CHIP:DMG: AttributeDataIB =
[1726125692.865645][1237356:1237371] CHIP:DMG: {
[1726125692.865965][1237356:1237371] CHIP:DMG: DataVersion = 0x967289e4,
[1726125692.866072][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.866255][1237356:1237371] CHIP:DMG: {
[1726125692.866584][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.866703][1237356:1237371] CHIP:DMG: Cluster = 0x30,
[1726125692.866814][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0001,
[1726125692.867004][1237356:1237371] CHIP:DMG: }
[1726125692.867334][1237356:1237371] CHIP:DMG:
[1726125692.867443][1237356:1237371] CHIP:DMG: Data =
[1726125692.867621][1237356:1237371] CHIP:DMG: {
[1726125692.868647][1237356:1237371] CHIP:DMG: 0x0 = 60,
[1726125692.869036][1237356:1237371] CHIP:DMG: 0x1 = 900,
[1726125692.869252][1237356:1237371] CHIP:DMG: },
[1726125692.869352][1237356:1237371] CHIP:DMG: },
[1726125692.869446][1237356:1237371] CHIP:DMG:
[1726125692.869778][1237356:1237371] CHIP:DMG: },
[1726125692.869884][1237356:1237371] CHIP:DMG:
[1726125692.869951][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125692.870372][1237356:1237371] CHIP:DMG: {
[1726125692.870462][1237356:1237371] CHIP:DMG: AttributeDataIB =
[1726125692.870551][1237356:1237371] CHIP:DMG: {
[1726125692.870913][1237356:1237371] CHIP:DMG: DataVersion = 0x967289e4,
[1726125692.871020][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.871199][1237356:1237371] CHIP:DMG: {
[1726125692.871304][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.871651][1237356:1237371] CHIP:DMG: Cluster = 0x30,
[1726125692.871803][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0000,
[1726125692.873255][1237356:1237371] CHIP:DMG: }
[1726125692.873710][1237356:1237371] CHIP:DMG:
[1726125692.873746][1237356:1237371] CHIP:DMG: Data = 0,
[1726125692.874148][1237356:1237371] CHIP:DMG: },
[1726125692.874254][1237356:1237371] CHIP:DMG:
[1726125692.874315][1237356:1237371] CHIP:DMG: },
[1726125692.874351][1237356:1237371] CHIP:DMG:
[1726125692.874370][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125692.874396][1237356:1237371] CHIP:DMG: {
[1726125692.874448][1237356:1237371] CHIP:DMG: AttributeDataIB =
[1726125692.874473][1237356:1237371] CHIP:DMG: {
[1726125692.874497][1237356:1237371] CHIP:DMG: DataVersion = 0xdce37ee9,
[1726125692.874560][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.874586][1237356:1237371] CHIP:DMG: {
[1726125692.874610][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.877643][1237356:1237371] CHIP:DMG: Cluster = 0x31,
[1726125692.877909][1237356:1237371] CHIP:DMG: Attribute = 0x0000_FFFC,
[1726125692.878199][1237356:1237371] CHIP:DMG: }
[1726125692.878662][1237356:1237371] CHIP:DMG:
[1726125692.879036][1237356:1237371] CHIP:DMG: Data = 2,
[1726125692.879174][1237356:1237371] CHIP:DMG: },
[1726125692.879379][1237356:1237371] CHIP:DMG:
[1726125692.879757][1237356:1237371] CHIP:DMG: },
[1726125692.879844][1237356:1237371] CHIP:DMG:
[1726125692.880985][1237356:1237371] CHIP:DMG: ],
[1726125692.881068][1237356:1237371] CHIP:DMG:
[1726125692.881094][1237356:1237371] CHIP:DMG: SuppressResponse = true,
[1726125692.881118][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125692.881144][1237356:1237371] CHIP:DMG: }
[1726125692.881882][1237356:1237371] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
[1726125692.881935][1237356:1237371] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ReadCommissioningInfo2'
[1726125692.881969][1237356:1237371] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo2'
[1726125692.882011][1237356:1237371] CHIP:DMG: SendReadRequest ReadClient[0xffffac009ff0]: Sending Read Request
[1726125692.882374][1237356:1237371] CHIP:DMG: >> to BLE | 127805171 | [Interaction Model (1) / Read Request (0x02) / Session = 30098 / Exchange = 18845]
[1726125692.882423][1237356:1237371] CHIP:DMG: Header Flags =
[1726125692.882445][1237356:1237371] CHIP:DMG: {
[1726125692.882478][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125692.882500][1237356:1237371] CHIP:DMG: {
[1726125692.882517][1237356:1237371] CHIP:DMG: Initiator = true
[1726125692.882536][1237356:1237371] CHIP:DMG: }
[1726125692.882561][1237356:1237371] CHIP:DMG: }
[1726125692.882581][1237356:1237371] CHIP:DMG:
[1726125692.882605][1237356:1237371] CHIP:DMG: Decrypted Payload (55 bytes) =
[1726125692.882625][1237356:1237371] CHIP:DMG: {
[1726125692.882644][1237356:1237371] CHIP:DMG: data = 1536001724020024033024040418172402002403462504fcff181724020024034624040618172402002403462404071818280324ff0b18
[1726125692.882663][1237356:1237371] CHIP:DMG: }
[1726125692.882681][1237356:1237371] CHIP:DMG:
[1726125692.882736][1237356:1237371] CHIP:DMG: ReadRequestMessage =
[1726125692.882759][1237356:1237371] CHIP:DMG: {
[1726125692.882777][1237356:1237371] CHIP:DMG: AttributePathIBs =
[1726125692.882804][1237356:1237371] CHIP:DMG: [
[1726125692.882824][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.882847][1237356:1237371] CHIP:DMG: {
[1726125692.882873][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.882901][1237356:1237371] CHIP:DMG: Cluster = 0x30,
[1726125692.882934][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0004,
[1726125692.882964][1237356:1237371] CHIP:DMG: }
[1726125692.882992][1237356:1237371] CHIP:DMG:
[1726125692.883016][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.883040][1237356:1237371] CHIP:DMG: {
[1726125692.883065][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.883097][1237356:1237371] CHIP:DMG: Cluster = 0x46,
[1726125692.883128][1237356:1237371] CHIP:DMG: Attribute = 0x0000_FFFC,
[1726125692.883153][1237356:1237371] CHIP:DMG: }
[1726125692.883180][1237356:1237371] CHIP:DMG:
[1726125692.883202][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.883227][1237356:1237371] CHIP:DMG: {
[1726125692.883252][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.883284][1237356:1237371] CHIP:DMG: Cluster = 0x46,
[1726125692.883311][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0006,
[1726125692.883338][1237356:1237371] CHIP:DMG: }
[1726125692.883362][1237356:1237371] CHIP:DMG:
[1726125692.883385][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125692.883410][1237356:1237371] CHIP:DMG: {
[1726125692.883436][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125692.883463][1237356:1237371] CHIP:DMG: Cluster = 0x46,
[1726125692.883492][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0007,
[1726125692.883519][1237356:1237371] CHIP:DMG: }
[1726125692.883546][1237356:1237371] CHIP:DMG:
[1726125692.883569][1237356:1237371] CHIP:DMG: ],
[1726125692.883597][1237356:1237371] CHIP:DMG:
[1726125692.883618][1237356:1237371] CHIP:DMG: isFabricFiltered = false,
[1726125692.883639][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125692.883658][1237356:1237371] CHIP:DMG: },
[1726125692.883675][1237356:1237371] CHIP:DMG:
[1726125692.883714][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125692.883736][1237356:1237371] CHIP:DMG: {
[1726125692.883758][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125692.883775][1237356:1237371] CHIP:DMG: }
[1726125692.883792][1237356:1237371] CHIP:DMG:
[1726125692.883899][1237356:1237371] CHIP:EM: <<< [E:18845i S:64780 M:127805171] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:02 (IM:ReadRequest)
[1726125692.885570][1237356:1237371] CHIP:DMG: MoveToState ReadClient[0xffffac009ff0]: Moving to [AwaitingIn]
[1726125692.965162][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125693.011548][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125693.011872][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125693.012350][1237356:1237371] CHIP:DMG: << from BLE | 105600309 | [Interaction Model (1) / Report Data (0x05) / Session = 64780 / Exchange = 18845]
[1726125693.012410][1237356:1237371] CHIP:DMG: Header Flags =
[1726125693.012434][1237356:1237371] CHIP:DMG: {
[1726125693.012471][1237356:1237371] CHIP:DMG: }
[1726125693.012491][1237356:1237371] CHIP:DMG:
[1726125693.012517][1237356:1237371] CHIP:DMG: Decrypted Payload (105 bytes) =
[1726125693.012538][1237356:1237371] CHIP:DMG: {
[1726125693.012558][1237356:1237371] CHIP:DMG: data = 15360115350037002402002403462404071835012400c318181815350037002402002403462404061835012400c318181815350037002402002403462504fcff1835012400c31818181535012600e48972963701240200240330240404182902181818290424ff0b18
[1726125693.012582][1237356:1237371] CHIP:DMG: }
[1726125693.012601][1237356:1237371] CHIP:DMG:
[1726125693.012686][1237356:1237371] CHIP:DMG:
[1726125693.012737][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125693.012762][1237356:1237371] CHIP:DMG: {
[1726125693.012786][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125693.012807][1237356:1237371] CHIP:DMG: }
[1726125693.012826][1237356:1237371] CHIP:DMG:
[1726125693.012928][1237356:1237371] CHIP:EM: >>> [E:18845i S:64780 M:105600309] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
[1726125693.012961][1237356:1237371] CHIP:EM: Found matching exchange: 18845i, Delegate: 0xffffac00a000
[1726125693.013057][1237356:1237371] CHIP:DMG: ReportDataMessage =
[1726125693.013086][1237356:1237371] CHIP:DMG: {
[1726125693.013106][1237356:1237371] CHIP:DMG: AttributeReportIBs =
[1726125693.013139][1237356:1237371] CHIP:DMG: [
[1726125693.013219][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125693.013307][1237356:1237371] CHIP:DMG: {
[1726125693.013386][1237356:1237371] CHIP:DMG: AttributeStatusIB =
[1726125693.013513][1237356:1237371] CHIP:DMG: {
[1726125693.014329][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125693.015285][1237356:1237371] CHIP:DMG: {
[1726125693.016345][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125693.017401][1237356:1237371] CHIP:DMG: Cluster = 0x46,
[1726125693.019773][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0007,
[1726125693.020134][1237356:1237371] CHIP:DMG: }
[1726125693.020288][1237356:1237371] CHIP:DMG:
[1726125693.020648][1237356:1237371] CHIP:DMG: StatusIB =
[1726125693.020790][1237356:1237371] CHIP:DMG: {
[1726125693.021097][1237356:1237371] CHIP:DMG: status = 0xc3 (UNSUPPORTED_CLUSTER),
[1726125693.021215][1237356:1237371] CHIP:DMG: },
[1726125693.021325][1237356:1237371] CHIP:DMG:
[1726125693.021655][1237356:1237371] CHIP:DMG: },
[1726125693.021803][1237356:1237371] CHIP:DMG:
[1726125693.022090][1237356:1237371] CHIP:DMG: },
[1726125693.022235][1237356:1237371] CHIP:DMG:
[1726125693.022476][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125693.022574][1237356:1237371] CHIP:DMG: {
[1726125693.022794][1237356:1237371] CHIP:DMG: AttributeStatusIB =
[1726125693.022900][1237356:1237371] CHIP:DMG: {
[1726125693.022991][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125693.023341][1237356:1237371] CHIP:DMG: {
[1726125693.023484][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125693.023829][1237356:1237371] CHIP:DMG: Cluster = 0x46,
[1726125693.024001][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0006,
[1726125693.024272][1237356:1237371] CHIP:DMG: }
[1726125693.024401][1237356:1237371] CHIP:DMG:
[1726125693.024658][1237356:1237371] CHIP:DMG: StatusIB =
[1726125693.024814][1237356:1237371] CHIP:DMG: {
[1726125693.025319][1237356:1237371] CHIP:DMG: status = 0xc3 (UNSUPPORTED_CLUSTER),
[1726125693.025495][1237356:1237371] CHIP:DMG: },
[1726125693.025891][1237356:1237371] CHIP:DMG:
[1726125693.025993][1237356:1237371] CHIP:DMG: },
[1726125693.026090][1237356:1237371] CHIP:DMG:
[1726125693.026171][1237356:1237371] CHIP:DMG: },
[1726125693.026524][1237356:1237371] CHIP:DMG:
[1726125693.026633][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125693.026758][1237356:1237371] CHIP:DMG: {
[1726125693.027135][1237356:1237371] CHIP:DMG: AttributeStatusIB =
[1726125693.027286][1237356:1237371] CHIP:DMG: {
[1726125693.027403][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125693.027508][1237356:1237371] CHIP:DMG: {
[1726125693.027876][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125693.028001][1237356:1237371] CHIP:DMG: Cluster = 0x46,
[1726125693.028149][1237356:1237371] CHIP:DMG: Attribute = 0x0000_FFFC,
[1726125693.028522][1237356:1237371] CHIP:DMG: }
[1726125693.028689][1237356:1237371] CHIP:DMG:
[1726125693.028823][1237356:1237371] CHIP:DMG: StatusIB =
[1726125693.029272][1237356:1237371] CHIP:DMG: {
[1726125693.029384][1237356:1237371] CHIP:DMG: status = 0xc3 (UNSUPPORTED_CLUSTER),
[1726125693.029496][1237356:1237371] CHIP:DMG: },
[1726125693.029601][1237356:1237371] CHIP:DMG:
[1726125693.029964][1237356:1237371] CHIP:DMG: },
[1726125693.030105][1237356:1237371] CHIP:DMG:
[1726125693.030208][1237356:1237371] CHIP:DMG: },
[1726125693.030665][1237356:1237371] CHIP:DMG:
[1726125693.030770][1237356:1237371] CHIP:DMG: AttributeReportIB =
[1726125693.030861][1237356:1237371] CHIP:DMG: {
[1726125693.030943][1237356:1237371] CHIP:DMG: AttributeDataIB =
[1726125693.031275][1237356:1237371] CHIP:DMG: {
[1726125693.031384][1237356:1237371] CHIP:DMG: DataVersion = 0x967289e4,
[1726125693.031523][1237356:1237371] CHIP:DMG: AttributePathIB =
[1726125693.031947][1237356:1237371] CHIP:DMG: {
[1726125693.032110][1237356:1237371] CHIP:DMG: Endpoint = 0x0,
[1726125693.032277][1237356:1237371] CHIP:DMG: Cluster = 0x30,
[1726125693.032687][1237356:1237371] CHIP:DMG: Attribute = 0x0000_0004,
[1726125693.032885][1237356:1237371] CHIP:DMG: }
[1726125693.033004][1237356:1237371] CHIP:DMG:
[1726125693.033373][1237356:1237371] CHIP:DMG: Data = true,
[1726125693.033582][1237356:1237371] CHIP:DMG: },
[1726125693.033748][1237356:1237371] CHIP:DMG:
[1726125693.033888][1237356:1237371] CHIP:DMG: },
[1726125693.034303][1237356:1237371] CHIP:DMG:
[1726125693.034401][1237356:1237371] CHIP:DMG: ],
[1726125693.034518][1237356:1237371] CHIP:DMG:
[1726125693.034602][1237356:1237371] CHIP:DMG: SuppressResponse = true,
[1726125693.034901][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125693.034974][1237356:1237371] CHIP:DMG: }
[1726125693.035510][1237356:1237371] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
[1726125693.036037][1237356:1237371] CHIP:SVR: OnReadCommissioningInfo - vendorId=0x1234 productId=0x5678
[1726125693.036364][1237356:1237371] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo2'
[1726125693.036656][1237356:1237371] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo2' -> 'ArmFailSafe'
[1726125693.036950][1237356:1237371] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
[1726125693.037048][1237356:1237371] CHIP:CTL: Arming failsafe (60 seconds)
[1726125693.037451][1237356:1237371] CHIP:DMG: ICR moving to [AddingComm]
[1726125693.037761][1237356:1237371] CHIP:DMG: ICR moving to [AddedComma]
[1726125693.038229][1237356:1237371] CHIP:DMG: >> to BLE | 127805172 | [Interaction Model (1) / InvokeCommandRequest (0x08) / Session = 30098 / Exchange = 18846]
[1726125693.038634][1237356:1237371] CHIP:DMG: Header Flags =
[1726125693.038844][1237356:1237371] CHIP:DMG: {
[1726125693.039082][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125693.039331][1237356:1237371] CHIP:DMG: {
[1726125693.039575][1237356:1237371] CHIP:DMG: Initiator = true
[1726125693.039682][1237356:1237371] CHIP:DMG: }
[1726125693.039798][1237356:1237371] CHIP:DMG: }
[1726125693.040182][1237356:1237371] CHIP:DMG:
[1726125693.040315][1237356:1237371] CHIP:DMG: Decrypted Payload (35 bytes) =
[1726125693.040613][1237356:1237371] CHIP:DMG: {
[1726125693.040709][1237356:1237371] CHIP:DMG: data = 1528002801360215370024000024013024020018350124003c24010418181824ff0b18
[1726125693.040758][1237356:1237371] CHIP:DMG: }
[1726125693.040805][1237356:1237371] CHIP:DMG:
[1726125693.040958][1237356:1237371] CHIP:DMG: InvokeRequestMessage =
[1726125693.041272][1237356:1237371] CHIP:DMG: {
[1726125693.041367][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125693.041641][1237356:1237371] CHIP:DMG: timedRequest = false,
[1726125693.041743][1237356:1237371] CHIP:DMG: InvokeRequests =
[1726125693.041821][1237356:1237371] CHIP:DMG: [
[1726125693.042176][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125693.042333][1237356:1237371] CHIP:DMG: {
[1726125693.042460][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125693.042848][1237356:1237371] CHIP:DMG: {
[1726125693.042948][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125693.043077][1237356:1237371] CHIP:DMG: ClusterId = 0x30,
[1726125693.043207][1237356:1237371] CHIP:DMG: CommandId = 0x0,
[1726125693.043547][1237356:1237371] CHIP:DMG: },
[1726125693.043672][1237356:1237371] CHIP:DMG:
[1726125693.043781][1237356:1237371] CHIP:DMG: CommandFields =
[1726125693.044144][1237356:1237371] CHIP:DMG: {
[1726125693.044380][1237356:1237371] CHIP:DMG: 0x0 = 60,
[1726125693.044797][1237356:1237371] CHIP:DMG: 0x1 = 4,
[1726125693.044938][1237356:1237371] CHIP:DMG: },
[1726125693.045252][1237356:1237371] CHIP:DMG: },
[1726125693.045374][1237356:1237371] CHIP:DMG:
[1726125693.045470][1237356:1237371] CHIP:DMG: ],
[1726125693.045546][1237356:1237371] CHIP:DMG:
[1726125693.045833][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125693.045947][1237356:1237371] CHIP:DMG: },
[1726125693.046044][1237356:1237371] CHIP:DMG:
[1726125693.046193][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125693.046472][1237356:1237371] CHIP:DMG: {
[1726125693.046716][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125693.046831][1237356:1237371] CHIP:DMG: }
[1726125693.047063][1237356:1237371] CHIP:DMG:
[1726125693.047309][1237356:1237371] CHIP:EM: <<< [E:18846i S:64780 M:127805172] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
[1726125693.048914][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingRe]
[1726125693.144822][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125693.190955][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125693.191362][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125693.191892][1237356:1237371] CHIP:DMG: << from BLE | 105600310 | [Interaction Model (1) / InvokeCommandResponse (0x09) / Session = 64780 / Exchange = 18846]
[1726125693.192245][1237356:1237371] CHIP:DMG: Header Flags =
[1726125693.192461][1237356:1237371] CHIP:DMG: {
[1726125693.192680][1237356:1237371] CHIP:DMG: }
[1726125693.192892][1237356:1237371] CHIP:DMG:
[1726125693.192960][1237356:1237371] CHIP:DMG: Decrypted Payload (36 bytes) =
[1726125693.193179][1237356:1237371] CHIP:DMG: {
[1726125693.193235][1237356:1237371] CHIP:DMG: data = 152800360115350037002400002401302402011835012400002c01001818181824ff0b18
[1726125693.193282][1237356:1237371] CHIP:DMG: }
[1726125693.193326][1237356:1237371] CHIP:DMG:
[1726125693.193635][1237356:1237371] CHIP:DMG:
[1726125693.193962][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125693.194022][1237356:1237371] CHIP:DMG: {
[1726125693.194075][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125693.194156][1237356:1237371] CHIP:DMG: }
[1726125693.194205][1237356:1237371] CHIP:DMG:
[1726125693.194460][1237356:1237371] CHIP:EM: >>> [E:18846i S:64780 M:105600310] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1726125693.194730][1237356:1237371] CHIP:EM: Found matching exchange: 18846i, Delegate: 0xffffac008628
[1726125693.194853][1237356:1237371] CHIP:DMG: ICR moving to [ResponseRe]
[1726125693.195311][1237356:1237371] CHIP:DMG: InvokeResponseMessage =
[1726125693.195380][1237356:1237371] CHIP:DMG: {
[1726125693.195429][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125693.195530][1237356:1237371] CHIP:DMG: InvokeResponseIBs =
[1726125693.195640][1237356:1237371] CHIP:DMG: [
[1726125693.195832][1237356:1237371] CHIP:DMG: InvokeResponseIB =
[1726125693.196085][1237356:1237371] CHIP:DMG: {
[1726125693.196321][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125693.196418][1237356:1237371] CHIP:DMG: {
[1726125693.196744][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125693.196899][1237356:1237371] CHIP:DMG: {
[1726125693.197048][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125693.197317][1237356:1237371] CHIP:DMG: ClusterId = 0x30,
[1726125693.197585][1237356:1237371] CHIP:DMG: CommandId = 0x1,
[1726125693.197788][1237356:1237371] CHIP:DMG: },
[1726125693.198176][1237356:1237371] CHIP:DMG:
[1726125693.198272][1237356:1237371] CHIP:DMG: CommandFields =
[1726125693.198375][1237356:1237371] CHIP:DMG: {
[1726125693.198478][1237356:1237371] CHIP:DMG: 0x0 = 0,
[1726125693.198625][1237356:1237371] CHIP:DMG: 0x1 = "" (0 chars),
[1726125693.198953][1237356:1237371] CHIP:DMG: },
[1726125693.199219][1237356:1237371] CHIP:DMG: },
[1726125693.199385][1237356:1237371] CHIP:DMG:
[1726125693.199755][1237356:1237371] CHIP:DMG: },
[1726125693.199895][1237356:1237371] CHIP:DMG:
[1726125693.199994][1237356:1237371] CHIP:DMG: ],
[1726125693.200098][1237356:1237371] CHIP:DMG:
[1726125693.200183][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125693.200397][1237356:1237371] CHIP:DMG: },
[1726125693.200675][1237356:1237371] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1726125693.201074][1237356:1237371] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1726125693.201187][1237356:1237371] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
[1726125693.201267][1237356:1237371] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1726125693.201462][1237356:1237371] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
[1726125693.201543][1237356:1237371] CHIP:CTL: Setting Regulatory Config
[1726125693.201730][1237356:1237371] CHIP:CTL: Device does not support configurable regulatory location
[1726125693.202034][1237356:1237371] CHIP:DMG: ICR moving to [AddingComm]
[1726125693.202364][1237356:1237371] CHIP:DMG: ICR moving to [AddedComma]
[1726125693.203090][1237356:1237371] CHIP:DMG: >> to BLE | 127805173 | [Interaction Model (1) / InvokeCommandRequest (0x08) / Session = 30098 / Exchange = 18847]
[1726125693.203384][1237356:1237371] CHIP:DMG: Header Flags =
[1726125693.203587][1237356:1237371] CHIP:DMG: {
[1726125693.203890][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125693.203944][1237356:1237371] CHIP:DMG: {
[1726125693.203988][1237356:1237371] CHIP:DMG: Initiator = true
[1726125693.204034][1237356:1237371] CHIP:DMG: }
[1726125693.204087][1237356:1237371] CHIP:DMG: }
[1726125693.204317][1237356:1237371] CHIP:DMG:
[1726125693.204423][1237356:1237371] CHIP:DMG: Decrypted Payload (40 bytes) =
[1726125693.204501][1237356:1237371] CHIP:DMG: {
[1726125693.204667][1237356:1237371] CHIP:DMG: data = 152800280136021537002400002401302402021835012400002c0102585824020518181824ff0b18
[1726125693.204752][1237356:1237371] CHIP:DMG: }
[1726125693.204873][1237356:1237371] CHIP:DMG:
[1726125693.205252][1237356:1237371] CHIP:DMG: InvokeRequestMessage =
[1726125693.205558][1237356:1237371] CHIP:DMG: {
[1726125693.205616][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125693.205690][1237356:1237371] CHIP:DMG: timedRequest = false,
[1726125693.205760][1237356:1237371] CHIP:DMG: InvokeRequests =
[1726125693.205836][1237356:1237371] CHIP:DMG: [
[1726125693.206063][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125693.206241][1237356:1237371] CHIP:DMG: {
[1726125693.206433][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125693.206692][1237356:1237371] CHIP:DMG: {
[1726125693.207111][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125693.207259][1237356:1237371] CHIP:DMG: ClusterId = 0x30,
[1726125693.207422][1237356:1237371] CHIP:DMG: CommandId = 0x2,
[1726125693.207548][1237356:1237371] CHIP:DMG: },
[1726125693.207791][1237356:1237371] CHIP:DMG:
[1726125693.207900][1237356:1237371] CHIP:DMG: CommandFields =
[1726125693.208154][1237356:1237371] CHIP:DMG: {
[1726125693.208516][1237356:1237371] CHIP:DMG: 0x0 = 0,
[1726125693.208636][1237356:1237371] CHIP:DMG: 0x1 = "XX" (2 chars),
[1726125693.208738][1237356:1237371] CHIP:DMG: 0x2 = 5,
[1726125693.208841][1237356:1237371] CHIP:DMG: },
[1726125693.209143][1237356:1237371] CHIP:DMG: },
[1726125693.209352][1237356:1237371] CHIP:DMG:
[1726125693.209549][1237356:1237371] CHIP:DMG: ],
[1726125693.209750][1237356:1237371] CHIP:DMG:
[1726125693.210079][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125693.210151][1237356:1237371] CHIP:DMG: },
[1726125693.210203][1237356:1237371] CHIP:DMG:
[1726125693.210295][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125693.210346][1237356:1237371] CHIP:DMG: {
[1726125693.210604][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125693.210663][1237356:1237371] CHIP:DMG: }
[1726125693.210708][1237356:1237371] CHIP:DMG:
[1726125693.211183][1237356:1237371] CHIP:EM: <<< [E:18847i S:64780 M:127805173] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
[1726125693.212204][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingRe]
[1726125693.212610][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingDe]
[1726125693.279728][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125693.325738][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125693.326107][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125693.326497][1237356:1237371] CHIP:DMG: << from BLE | 105600311 | [Interaction Model (1) / InvokeCommandResponse (0x09) / Session = 64780 / Exchange = 18847]
[1726125693.326541][1237356:1237371] CHIP:DMG: Header Flags =
[1726125693.326563][1237356:1237371] CHIP:DMG: {
[1726125693.326598][1237356:1237371] CHIP:DMG: }
[1726125693.326617][1237356:1237371] CHIP:DMG:
[1726125693.326641][1237356:1237371] CHIP:DMG: Decrypted Payload (36 bytes) =
[1726125693.326660][1237356:1237371] CHIP:DMG: {
[1726125693.326679][1237356:1237371] CHIP:DMG: data = 152800360115350037002400002401302402031835012400002c01001818181824ff0b18
[1726125693.326698][1237356:1237371] CHIP:DMG: }
[1726125693.326715][1237356:1237371] CHIP:DMG:
[1726125693.326772][1237356:1237371] CHIP:DMG:
[1726125693.326811][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125693.326831][1237356:1237371] CHIP:DMG: {
[1726125693.326849][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125693.326868][1237356:1237371] CHIP:DMG: }
[1726125693.326885][1237356:1237371] CHIP:DMG:
[1726125693.326915][1237356:1237371] CHIP:EM: >>> [E:18847i S:64780 M:105600311] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1726125693.326942][1237356:1237371] CHIP:EM: Found matching exchange: 18847i, Delegate: 0xffffac0087d8
[1726125693.326979][1237356:1237371] CHIP:DMG: ICR moving to [ResponseRe]
[1726125693.327017][1237356:1237371] CHIP:DMG: InvokeResponseMessage =
[1726125693.327038][1237356:1237371] CHIP:DMG: {
[1726125693.327058][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125693.327104][1237356:1237371] CHIP:DMG: InvokeResponseIBs =
[1726125693.327176][1237356:1237371] CHIP:DMG: [
[1726125693.327237][1237356:1237371] CHIP:DMG: InvokeResponseIB =
[1726125693.327315][1237356:1237371] CHIP:DMG: {
[1726125693.327385][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125693.327468][1237356:1237371] CHIP:DMG: {
[1726125693.327548][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125693.327639][1237356:1237371] CHIP:DMG: {
[1726125693.327730][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125693.327832][1237356:1237371] CHIP:DMG: ClusterId = 0x30,
[1726125693.327932][1237356:1237371] CHIP:DMG: CommandId = 0x3,
[1726125693.328030][1237356:1237371] CHIP:DMG: },
[1726125693.328123][1237356:1237371] CHIP:DMG:
[1726125693.328203][1237356:1237371] CHIP:DMG: CommandFields =
[1726125693.328296][1237356:1237371] CHIP:DMG: {
[1726125693.328389][1237356:1237371] CHIP:DMG: 0x0 = 0,
[1726125693.328492][1237356:1237371] CHIP:DMG: 0x1 = "" (0 chars),
[1726125693.328593][1237356:1237371] CHIP:DMG: },
[1726125693.328682][1237356:1237371] CHIP:DMG: },
[1726125693.328766][1237356:1237371] CHIP:DMG:
[1726125693.328835][1237356:1237371] CHIP:DMG: },
[1726125693.328925][1237356:1237371] CHIP:DMG:
[1726125693.328986][1237356:1237371] CHIP:DMG: ],
[1726125693.329053][1237356:1237371] CHIP:DMG:
[1726125693.329105][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125693.329164][1237356:1237371] CHIP:DMG: },
[1726125693.329247][1237356:1237371] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1726125693.329311][1237356:1237371] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
[1726125693.329343][1237356:1237371] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
[1726125693.329365][1237356:1237371] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
[1726125693.329393][1237356:1237371] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
[1726125693.329411][1237356:1237371] CHIP:CTL: Sending request for PAI certificate
[1726125693.329429][1237356:1237371] CHIP:CTL: Sending Certificate Chain request to 0xffffac010fd0 device
[1726125693.329500][1237356:1237371] CHIP:DMG: ICR moving to [AddingComm]
[1726125693.329557][1237356:1237371] CHIP:DMG: ICR moving to [AddedComma]
[1726125693.329801][1237356:1237371] CHIP:DMG: >> to BLE | 127805174 | [Interaction Model (1) / InvokeCommandRequest (0x08) / Session = 30098 / Exchange = 18848]
[1726125693.329839][1237356:1237371] CHIP:DMG: Header Flags =
[1726125693.329858][1237356:1237371] CHIP:DMG: {
[1726125693.329888][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125693.329908][1237356:1237371] CHIP:DMG: {
[1726125693.329925][1237356:1237371] CHIP:DMG: Initiator = true
[1726125693.329942][1237356:1237371] CHIP:DMG: }
[1726125693.329966][1237356:1237371] CHIP:DMG: }
[1726125693.329985][1237356:1237371] CHIP:DMG:
[1726125693.330007][1237356:1237371] CHIP:DMG: Decrypted Payload (32 bytes) =
[1726125693.330026][1237356:1237371] CHIP:DMG: {
[1726125693.330045][1237356:1237371] CHIP:DMG: data = 1528002801360215370024000024013e24020218350124000218181824ff0b18
[1726125693.330317][1237356:1237371] CHIP:DMG: }
[1726125693.330341][1237356:1237371] CHIP:DMG:
[1726125693.330405][1237356:1237371] CHIP:DMG: InvokeRequestMessage =
[1726125693.330429][1237356:1237371] CHIP:DMG: {
[1726125693.330449][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125693.330472][1237356:1237371] CHIP:DMG: timedRequest = false,
[1726125693.330492][1237356:1237371] CHIP:DMG: InvokeRequests =
[1726125693.330518][1237356:1237371] CHIP:DMG: [
[1726125693.330539][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125693.330591][1237356:1237371] CHIP:DMG: {
[1726125693.330661][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125693.330743][1237356:1237371] CHIP:DMG: {
[1726125693.330826][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125693.330918][1237356:1237371] CHIP:DMG: ClusterId = 0x3e,
[1726125693.331009][1237356:1237371] CHIP:DMG: CommandId = 0x2,
[1726125693.331099][1237356:1237371] CHIP:DMG: },
[1726125693.331181][1237356:1237371] CHIP:DMG:
[1726125693.331252][1237356:1237371] CHIP:DMG: CommandFields =
[1726125693.331334][1237356:1237371] CHIP:DMG: {
[1726125693.331416][1237356:1237371] CHIP:DMG: 0x0 = 2,
[1726125693.331510][1237356:1237371] CHIP:DMG: },
[1726125693.331588][1237356:1237371] CHIP:DMG: },
[1726125693.331663][1237356:1237371] CHIP:DMG:
[1726125693.331722][1237356:1237371] CHIP:DMG: ],
[1726125693.331788][1237356:1237371] CHIP:DMG:
[1726125693.331840][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125693.331900][1237356:1237371] CHIP:DMG: },
[1726125693.331943][1237356:1237371] CHIP:DMG:
[1726125693.332008][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125693.332052][1237356:1237371] CHIP:DMG: {
[1726125693.332097][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125693.332140][1237356:1237371] CHIP:DMG: }
[1726125693.332180][1237356:1237371] CHIP:DMG:
[1726125693.332300][1237356:1237371] CHIP:EM: <<< [E:18848i S:64780 M:127805174] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
[1726125693.332832][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingRe]
[1726125693.332957][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingDe]
[1726125693.414973][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125693.469595][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125693.470114][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125693.553050][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125693.553272][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125693.640095][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125693.640255][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125693.640786][1237356:1237371] CHIP:DMG: << from BLE | 105600312 | [Interaction Model (1) / InvokeCommandResponse (0x09) / Session = 64780 / Exchange = 18848]
[1726125693.640866][1237356:1237371] CHIP:DMG: Header Flags =
[1726125693.640889][1237356:1237371] CHIP:DMG: {
[1726125693.640930][1237356:1237371] CHIP:DMG: }
[1726125693.640950][1237356:1237371] CHIP:DMG:
[1726125693.640978][1237356:1237371] CHIP:DMG: Decrypted Payload (453 bytes) =
[1726125693.640998][1237356:1237371] CHIP:DMG: {
[1726125693.641018][1237356:1237371] CHIP:DMG: data = 1528003601153500370024000024013e2402031835013100a3013082019f30820144a003020102020868aaa164492bb0d0300a06082a8648ce3d04030230163114301206035504030c0b4465786174656b20504141301e170d3230313031353134323334335a170d3430313031353134323334325a302c3114301206035504030c0b4465786174656b2050414931143012060a2b0601040182a27c02010c04313233343059301306072a8648ce3d020106082a8648ce3d03010703420004840e3641d9396247c6971420cf665558e7fb1c76127238f9821342a92a484a9dd4ab00f664f1f035b0fc59f2abc41783b3b514780a629bf304e7807b15b4edcba366306430120603551d130101ff040830060101ff020100300e0603551d0f0101ff040403020106301d0603551d0e04160414b568efdcfd129b36db434ec810ac925a72da92aa301f0603551d2304183016801469273074cce372f87f8f84f6f4f24351995612ca300a06082a8648ce3d0403020349003046022100c1d18b07bac393eb6433bfc9e3411f7ef84bf6b525b8ecaab235df966ede0e17022100964ceb3760e2b65c95fcbc47eb2780e75a97b7dcd2c7616fcf8b29d002d6bad51818181824ff0b18
[1726125693.641046][1237356:1237371] CHIP:DMG: }
[1726125693.641064][1237356:1237371] CHIP:DMG:
[1726125693.641167][1237356:1237371] CHIP:DMG: DAC/PAI (419) =
[1726125693.641216][1237356:1237371] CHIP:DMG: {
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
[1726125693.641310][1237356:1237371] CHIP:DMG: }
[1726125693.641329][1237356:1237371] CHIP:DMG:
[1726125693.641356][1237356:1237371] CHIP:DMG:
[1726125693.641407][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125693.641428][1237356:1237371] CHIP:DMG: {
[1726125693.641453][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125693.641472][1237356:1237371] CHIP:DMG: }
[1726125693.641490][1237356:1237371] CHIP:DMG:
[1726125693.641533][1237356:1237371] CHIP:EM: >>> [E:18848i S:64780 M:105600312] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1726125693.641562][1237356:1237371] CHIP:EM: Found matching exchange: 18848i, Delegate: 0xffffac008628
[1726125693.641608][1237356:1237371] CHIP:DMG: ICR moving to [ResponseRe]
[1726125693.641653][1237356:1237371] CHIP:DMG: InvokeResponseMessage =
[1726125693.641676][1237356:1237371] CHIP:DMG: {
[1726125693.641696][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125693.641718][1237356:1237371] CHIP:DMG: InvokeResponseIBs =
[1726125693.641744][1237356:1237371] CHIP:DMG: [
[1726125693.641766][1237356:1237371] CHIP:DMG: InvokeResponseIB =
[1726125693.641826][1237356:1237371] CHIP:DMG: {
[1726125693.641903][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125693.641989][1237356:1237371] CHIP:DMG: {
[1726125693.642073][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125693.642168][1237356:1237371] CHIP:DMG: {
[1726125693.642265][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125693.642370][1237356:1237371] CHIP:DMG: ClusterId = 0x3e,
[1726125693.642473][1237356:1237371] CHIP:DMG: CommandId = 0x3,
[1726125693.642575][1237356:1237371] CHIP:DMG: },
[1726125693.642671][1237356:1237371] CHIP:DMG:
[1726125693.642756][1237356:1237371] CHIP:DMG: CommandFields =
[1726125693.642921][1237356:1237371] CHIP:DMG: {
[1726125693.643084][1237356:1237371] CHIP:DMG: 0x0 = [
[1726125693.643358][1237356:1237371] CHIP:DMG: 0x30, 0x82, 0x01, 0x9f, 0x30, 0x82, 0x01, 0x44, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x68, 0xaa, 0xa1, 0x64, 0x49, 0x2b, 0xb0, 0xd0, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x16, 0x31, 0x14, 0x30, 0x12, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0b, 0x44, 0x65, 0x78, 0x61, 0x74, 0x65, 0x6b, 0x20, 0x50, 0x41, 0x41, 0x30, 0x1e, 0x17, 0x0d, 0x32, 0x30, 0x31, 0x30, 0x31, 0x35, 0x31, 0x34, 0x32, 0x33, 0x34, 0x33, 0x5a, 0x17, 0x0d, 0x34, 0x30, 0x31, 0x30, 0x31, 0x35, 0x31, 0x34, 0x32, 0x33, 0x34, 0x32, 0x5a, 0x30, 0x2c, 0x31, 0x14, 0x30, 0x12, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0b, 0x44, 0x65, 0x78, 0x61, 0x74, 0x65, 0x6b, 0x20, 0x50, 0x41, 0x49, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x32, 0x33, 0x34, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0x84, 0x0e, 0x36, 0x41, 0xd9, 0x39, 0x62, 0x47, 0xc6, 0x97, 0x14, 0x20, 0xcf, 0x66, 0x55, 0x58, 0xe7, 0xfb, 0x1c, 0x76, 0x12, 0x72, 0x38, 0xf9, 0x82, 0x13, 0x42, 0xa9, 0x2a, 0x48, 0x4a, 0x9d, 0xd4, 0xab, 0x00, 0xf6, 0x64, 0xf1, 0xf0, 0x35, 0xb0, 0xfc, 0x59, 0xf2, 0xab, 0xc4, 0x17, 0x83, 0xb3, 0xb5, 0x14, 0x78, 0x0a, 0x62, 0x9b, 0xf3, 0x04, 0xe7, 0x80, 0x7b, 0x15, 0xb4, 0xed, 0xcb, 0xa3, 0x66, 0x30, 0x64, 0x30, 0x12, 0x06, 0x03, 0x55, 0x1d, 0x13, 0x01, 0x01, 0xff, 0x04, 0x08, 0x30, 0x06, 0x01, 0x01, 0xff, 0x02, 0x01, 0x00, 0x30, 0x0e, 0x06, 0x03, 0x55, 0x1d, 0x0f, 0x01, 0x01, 0xff, 0x04, 0x04, 0x03, 0x02, 0x01, 0x06, 0x30, 0x1d, 0x06, 0x03, 0x55, 0x1d, 0x0e, 0x04, 0x16, 0x04, 0x14, 0xb5, 0x68, 0xef, 0xdc, 0x
[1726125693.643555][1237356:1237371] CHIP:DMG: ] (419 bytes)
[1726125693.643663][1237356:1237371] CHIP:DMG: },
[1726125693.643788][1237356:1237371] CHIP:DMG: },
[1726125693.643924][1237356:1237371] CHIP:DMG:
[1726125693.644062][1237356:1237371] CHIP:DMG: },
[1726125693.644175][1237356:1237371] CHIP:DMG:
[1726125693.644267][1237356:1237371] CHIP:DMG: ],
[1726125693.644370][1237356:1237371] CHIP:DMG:
[1726125693.644456][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125693.644552][1237356:1237371] CHIP:DMG: },
[1726125693.644649][1237356:1237371] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1726125693.644721][1237356:1237371] CHIP:CTL: Received certificate chain from the device
[1726125693.644778][1237356:1237371] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
[1726125693.644832][1237356:1237371] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
[1726125693.644947][1237356:1237371] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
[1726125693.644993][1237356:1237371] CHIP:CTL: Sending request for DAC certificate
[1726125693.645036][1237356:1237371] CHIP:CTL: Sending Certificate Chain request to 0xffffac010fd0 device
[1726125693.645154][1237356:1237371] CHIP:DMG: ICR moving to [AddingComm]
[1726125693.645217][1237356:1237371] CHIP:DMG: ICR moving to [AddedComma]
[1726125693.645847][1237356:1237371] CHIP:DMG: >> to BLE | 127805175 | [Interaction Model (1) / InvokeCommandRequest (0x08) / Session = 30098 / Exchange = 18849]
[1726125693.646002][1237356:1237371] CHIP:DMG: Header Flags =
[1726125693.646096][1237356:1237371] CHIP:DMG: {
[1726125693.646156][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125693.646208][1237356:1237371] CHIP:DMG: {
[1726125693.646249][1237356:1237371] CHIP:DMG: Initiator = true
[1726125693.646292][1237356:1237371] CHIP:DMG: }
[1726125693.646344][1237356:1237371] CHIP:DMG: }
[1726125693.646386][1237356:1237371] CHIP:DMG:
[1726125693.646438][1237356:1237371] CHIP:DMG: Decrypted Payload (32 bytes) =
[1726125693.646481][1237356:1237371] CHIP:DMG: {
[1726125693.646524][1237356:1237371] CHIP:DMG: data = 1528002801360215370024000024013e24020218350124000118181824ff0b18
[1726125693.646566][1237356:1237371] CHIP:DMG: }
[1726125693.652995][1237356:1237371] CHIP:DMG:
[1726125693.653099][1237356:1237371] CHIP:DMG: InvokeRequestMessage =
[1726125693.653131][1237356:1237371] CHIP:DMG: {
[1726125693.653155][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125693.653183][1237356:1237371] CHIP:DMG: timedRequest = false,
[1726125693.653205][1237356:1237371] CHIP:DMG: InvokeRequests =
[1726125693.653232][1237356:1237371] CHIP:DMG: [
[1726125693.653255][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125693.653303][1237356:1237371] CHIP:DMG: {
[1726125693.653329][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125693.653370][1237356:1237371] CHIP:DMG: {
[1726125693.653396][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125693.653429][1237356:1237371] CHIP:DMG: ClusterId = 0x3e,
[1726125693.653468][1237356:1237371] CHIP:DMG: CommandId = 0x2,
[1726125693.653499][1237356:1237371] CHIP:DMG: },
[1726125693.653537][1237356:1237371] CHIP:DMG:
[1726125693.653562][1237356:1237371] CHIP:DMG: CommandFields =
[1726125693.653603][1237356:1237371] CHIP:DMG: {
[1726125693.653635][1237356:1237371] CHIP:DMG: 0x0 = 1,
[1726125693.653674][1237356:1237371] CHIP:DMG: },
[1726125693.653699][1237356:1237371] CHIP:DMG: },
[1726125693.653738][1237356:1237371] CHIP:DMG:
[1726125693.653760][1237356:1237371] CHIP:DMG: ],
[1726125693.653798][1237356:1237371] CHIP:DMG:
[1726125693.653819][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125693.653849][1237356:1237371] CHIP:DMG: },
[1726125693.653871][1237356:1237371] CHIP:DMG:
[1726125693.653944][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125693.653982][1237356:1237371] CHIP:DMG: {
[1726125693.654009][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125693.654029][1237356:1237371] CHIP:DMG: }
[1726125693.654057][1237356:1237371] CHIP:DMG:
[1726125693.654194][1237356:1237371] CHIP:EM: <<< [E:18849i S:64780 M:127805175] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
[1726125693.654877][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingRe]
[1726125693.655014][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingDe]
[1726125693.729673][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125693.785408][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125693.785761][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125693.869096][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125693.869496][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125693.956771][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125693.957179][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125693.957855][1237356:1237371] CHIP:DMG: << from BLE | 105600313 | [Interaction Model (1) / InvokeCommandResponse (0x09) / Session = 64780 / Exchange = 18849]
[1726125693.958043][1237356:1237371] CHIP:DMG: Header Flags =
[1726125693.958133][1237356:1237371] CHIP:DMG: {
[1726125693.958253][1237356:1237371] CHIP:DMG: }
[1726125693.958336][1237356:1237371] CHIP:DMG:
[1726125693.958440][1237356:1237371] CHIP:DMG: Decrypted Payload (489 bytes) =
[1726125693.958542][1237356:1237371] CHIP:DMG: {
[1726125693.958629][1237356:1237371] CHIP:DMG: data = 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
[1726125693.958757][1237356:1237371] CHIP:DMG: }
[1726125693.958818][1237356:1237371] CHIP:DMG:
[1726125693.958969][1237356:1237371] CHIP:DMG: DAC/PAI (455) =
[1726125693.959051][1237356:1237371] CHIP:DMG: {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[1726125693.959401][1237356:1237371] CHIP:DMG: }
[1726125693.959487][1237356:1237371] CHIP:DMG:
[1726125693.959562][1237356:1237371] CHIP:DMG:
[1726125693.959666][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125693.959714][1237356:1237371] CHIP:DMG: {
[1726125693.959784][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125693.959840][1237356:1237371] CHIP:DMG: }
[1726125693.959892][1237356:1237371] CHIP:DMG:
[1726125693.959982][1237356:1237371] CHIP:EM: >>> [E:18849i S:64780 M:105600313] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1726125693.960074][1237356:1237371] CHIP:EM: Found matching exchange: 18849i, Delegate: 0xffffac016ca8
[1726125693.960174][1237356:1237371] CHIP:DMG: ICR moving to [ResponseRe]
[1726125693.960274][1237356:1237371] CHIP:DMG: InvokeResponseMessage =
[1726125693.960334][1237356:1237371] CHIP:DMG: {
[1726125693.960380][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125693.960574][1237356:1237371] CHIP:DMG: InvokeResponseIBs =
[1726125693.960664][1237356:1237371] CHIP:DMG: [
[1726125693.960730][1237356:1237371] CHIP:DMG: InvokeResponseIB =
[1726125693.960893][1237356:1237371] CHIP:DMG: {
[1726125693.960974][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125693.961062][1237356:1237371] CHIP:DMG: {
[1726125693.961147][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125693.961263][1237356:1237371] CHIP:DMG: {
[1726125693.961367][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125693.961490][1237356:1237371] CHIP:DMG: ClusterId = 0x3e,
[1726125693.961626][1237356:1237371] CHIP:DMG: CommandId = 0x3,
[1726125693.961759][1237356:1237371] CHIP:DMG: },
[1726125693.961878][1237356:1237371] CHIP:DMG:
[1726125693.961989][1237356:1237371] CHIP:DMG: CommandFields =
[1726125693.962106][1237356:1237371] CHIP:DMG: {
[1726125693.962225][1237356:1237371] CHIP:DMG: 0x0 = [
[1726125693.962467][1237356:1237371] CHIP:DMG: 0x30, 0x82, 0x01, 0xc3, 0x30, 0x82, 0x01, 0x6a, 0xa0, 0x03, 0x02, 0x01, 0x02, 0x02, 0x08, 0x50, 0x55, 0x99, 0x0c, 0xb1, 0xb0, 0x7e, 0x98, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x30, 0x2c, 0x31, 0x14, 0x30, 0x12, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0b, 0x44, 0x65, 0x78, 0x61, 0x74, 0x65, 0x6b, 0x20, 0x50, 0x41, 0x49, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x32, 0x33, 0x34, 0x30, 0x1e, 0x17, 0x0d, 0x32, 0x30, 0x31, 0x30, 0x31, 0x35, 0x31, 0x34, 0x32, 0x33, 0x34, 0x33, 0x5a, 0x17, 0x0d, 0x34, 0x30, 0x31, 0x30, 0x31, 0x35, 0x31, 0x34, 0x32, 0x33, 0x34, 0x32, 0x5a, 0x30, 0x42, 0x31, 0x14, 0x30, 0x12, 0x06, 0x03, 0x55, 0x04, 0x03, 0x0c, 0x0b, 0x44, 0x65, 0x78, 0x61, 0x74, 0x65, 0x6b, 0x20, 0x44, 0x41, 0x43, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x01, 0x0c, 0x04, 0x31, 0x32, 0x33, 0x34, 0x31, 0x14, 0x30, 0x12, 0x06, 0x0a, 0x2b, 0x06, 0x01, 0x04, 0x01, 0x82, 0xa2, 0x7c, 0x02, 0x02, 0x0c, 0x04, 0x35, 0x36, 0x37, 0x38, 0x30, 0x59, 0x30, 0x13, 0x06, 0x07, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x02, 0x01, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x03, 0x01, 0x07, 0x03, 0x42, 0x00, 0x04, 0xd6, 0x46, 0x31, 0x36, 0x28, 0xb3, 0x00, 0x40, 0xf0, 0x5c, 0xb7, 0xf8, 0xe0, 0xcd, 0x58, 0xd2, 0x16, 0xdc, 0x4f, 0xca, 0x00, 0x9b, 0xe6, 0x48, 0x3a, 0xa6, 0xe9, 0x88, 0x3c, 0x1b, 0x93, 0x5b, 0x2b, 0xc0, 0x26, 0x6f, 0x81, 0xb6, 0x95, 0x51, 0x40, 0xb0, 0x3b, 0xb5, 0xd6, 0x5d, 0x19, 0x0b, 0x62, 0x40, 0xf8, 0x92, 0x07, 0x4f, 0x88, 0xa4, 0x54, 0x08, 0x65, 0x99, 0x65, 0x58, 0x54, 0x21, 0xa3, 0x60, 0x30, 0x5e, 0x30, 0x0c, 0x06, 0x03, 0x55, 0x1d, 0x13, 0x
[1726125693.962667][1237356:1237371] CHIP:DMG: ] (455 bytes)
[1726125693.962780][1237356:1237371] CHIP:DMG: },
[1726125693.962924][1237356:1237371] CHIP:DMG: },
[1726125693.963029][1237356:1237371] CHIP:DMG:
[1726125693.963336][1237356:1237371] CHIP:DMG: },
[1726125693.963425][1237356:1237371] CHIP:DMG:
[1726125693.963506][1237356:1237371] CHIP:DMG: ],
[1726125693.963579][1237356:1237371] CHIP:DMG:
[1726125693.964183][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125693.964278][1237356:1237371] CHIP:DMG: },
[1726125693.964397][1237356:1237371] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1726125693.964475][1237356:1237371] CHIP:CTL: Received certificate chain from the device
[1726125693.964536][1237356:1237371] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
[1726125693.964591][1237356:1237371] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
[1726125693.964653][1237356:1237371] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
[1726125693.964732][1237356:1237371] CHIP:CTL: Sending Attestation Request to the device.
[1726125693.964781][1237356:1237371] CHIP:CTL: Sending Attestation request to 0xffffac010fd0 device
[1726125693.965591][1237356:1237371] CHIP:DMG: ICR moving to [AddingComm]
[1726125693.965752][1237356:1237371] CHIP:DMG: ICR moving to [AddedComma]
[1726125693.966169][1237356:1237371] CHIP:DMG: >> to BLE | 127805176 | [Interaction Model (1) / InvokeCommandRequest (0x08) / Session = 30098 / Exchange = 18850]
[1726125693.966837][1237356:1237371] CHIP:DMG: Header Flags =
[1726125693.967251][1237356:1237371] CHIP:DMG: {
[1726125693.967432][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125693.967770][1237356:1237371] CHIP:DMG: {
[1726125693.967826][1237356:1237371] CHIP:DMG: Initiator = true
[1726125693.967874][1237356:1237371] CHIP:DMG: }
[1726125693.967939][1237356:1237371] CHIP:DMG: }
[1726125693.968018][1237356:1237371] CHIP:DMG:
[1726125693.968382][1237356:1237371] CHIP:DMG: Decrypted Payload (64 bytes) =
[1726125693.968555][1237356:1237371] CHIP:DMG: {
[1726125693.968634][1237356:1237371] CHIP:DMG: data = 1528002801360215370024000024013e240200183501300020a04d626cff597c9c2f948d1e886b41e36f99b46a520e7ca1a7a585df4caf41f918181824ff0b18
[1726125693.968686][1237356:1237371] CHIP:DMG: }
[1726125693.968741][1237356:1237371] CHIP:DMG:
[1726125693.968831][1237356:1237371] CHIP:DMG: InvokeRequestMessage =
[1726125693.968880][1237356:1237371] CHIP:DMG: {
[1726125693.969206][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125693.969271][1237356:1237371] CHIP:DMG: timedRequest = false,
[1726125693.969290][1237356:1237371] CHIP:DMG: InvokeRequests =
[1726125693.969318][1237356:1237371] CHIP:DMG: [
[1726125693.969336][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125693.969357][1237356:1237371] CHIP:DMG: {
[1726125693.969440][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125693.969500][1237356:1237371] CHIP:DMG: {
[1726125693.969552][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125693.969577][1237356:1237371] CHIP:DMG: ClusterId = 0x3e,
[1726125693.969636][1237356:1237371] CHIP:DMG: CommandId = 0x0,
[1726125693.969660][1237356:1237371] CHIP:DMG: },
[1726125693.969715][1237356:1237371] CHIP:DMG:
[1726125693.969736][1237356:1237371] CHIP:DMG: CommandFields =
[1726125693.969794][1237356:1237371] CHIP:DMG: {
[1726125693.969848][1237356:1237371] CHIP:DMG: 0x0 = [
[1726125693.969883][1237356:1237371] CHIP:DMG: 0xa0, 0x4d, 0x62, 0x6c, 0xff, 0x59, 0x7c, 0x9c, 0x2f, 0x94, 0x8d, 0x1e, 0x88, 0x6b, 0x41, 0xe3, 0x6f, 0x99, 0xb4, 0x6a, 0x52, 0x0e, 0x7c, 0xa1, 0xa7, 0xa5, 0x85, 0xdf, 0x4c, 0xaf, 0x41, 0xf9,
[1726125693.969950][1237356:1237371] CHIP:DMG: ] (32 bytes)
[1726125693.970009][1237356:1237371] CHIP:DMG: },
[1726125693.970032][1237356:1237371] CHIP:DMG: },
[1726125693.970057][1237356:1237371] CHIP:DMG:
[1726125693.970074][1237356:1237371] CHIP:DMG: ],
[1726125693.970099][1237356:1237371] CHIP:DMG:
[1726125693.970158][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125693.970177][1237356:1237371] CHIP:DMG: },
[1726125693.970231][1237356:1237371] CHIP:DMG:
[1726125693.970332][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125693.970353][1237356:1237371] CHIP:DMG: {
[1726125693.970375][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125693.970423][1237356:1237371] CHIP:DMG: }
[1726125693.970439][1237356:1237371] CHIP:DMG:
[1726125693.970569][1237356:1237371] CHIP:EM: <<< [E:18850i S:64780 M:127805176] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
[1726125693.971896][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingRe]
[1726125693.972249][1237356:1237371] CHIP:CTL: Sent Attestation request, waiting for the Attestation Information
[1726125693.972545][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingDe]
[1726125694.046678][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125694.137955][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125694.138222][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125694.272244][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125694.272467][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125694.272977][1237356:1237371] CHIP:DMG: << from BLE | 105600314 | [Interaction Model (1) / InvokeCommandResponse (0x09) / Session = 64780 / Exchange = 18850]
[1726125694.273043][1237356:1237371] CHIP:DMG: Header Flags =
[1726125694.273065][1237356:1237371] CHIP:DMG: {
[1726125694.273104][1237356:1237371] CHIP:DMG: }
[1726125694.273125][1237356:1237371] CHIP:DMG:
[1726125694.273174][1237356:1237371] CHIP:DMG: Decrypted Payload (380 bytes) =
[1726125694.273196][1237356:1237371] CHIP:DMG: {
[1726125694.273216][1237356:1237371] CHIP:DMG: data = 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
[1726125694.273243][1237356:1237371] CHIP:DMG: }
[1726125694.273262][1237356:1237371] CHIP:DMG:
[1726125694.273379][1237356:1237371] CHIP:DMG: Attestation Elements (279 bytes) =
[1726125694.273419][1237356:1237371] CHIP:DMG: {
[1726125694.273440][1237356:1237371] CHIP:DMG: Certification Declaration =
[1726125694.273459][1237356:1237371] CHIP:DMG: {
[1726125694.274447][1237356:1237371] CHIP:DMG: Format Version = 1
[1726125694.274504][1237356:1237371] CHIP:DMG: Vendor Id = 4660
[1726125694.274526][1237356:1237371] CHIP:DMG: Product Ids =
[1726125694.274546][1237356:1237371] CHIP:DMG: {
[1726125694.274566][1237356:1237371] CHIP:DMG: Product Id = 22136
[1726125694.274587][1237356:1237371] CHIP:DMG: }
[1726125694.274607][1237356:1237371] CHIP:DMG: Device Type Id = 257
[1726125694.274634][1237356:1237371] CHIP:DMG: Certificate Id (19) = ZIG20141ZB330003-24
[1726125694.274657][1237356:1237371] CHIP:DMG: Security Level = 0
[1726125694.274678][1237356:1237371] CHIP:DMG: Security Information = 0
[1726125694.274699][1237356:1237371] CHIP:DMG: Version Number = 9876
[1726125694.274720][1237356:1237371] CHIP:DMG: Certification Type = 1
[1726125694.274742][1237356:1237371] CHIP:DMG: }
[1726125694.274766][1237356:1237371] CHIP:DMG: Attestation Nonce (32) = A04D626CFF597C9C2F948D1E886B41E36F99B46A520E7CA1A7A585DF4CAF41F9
[1726125694.274786][1237356:1237371] CHIP:DMG: Timestamp = 0
[1726125694.274805][1237356:1237371] CHIP:DMG: }
[1726125694.274823][1237356:1237371] CHIP:DMG:
[1726125694.274851][1237356:1237371] CHIP:DMG:
[1726125694.274912][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125694.274937][1237356:1237371] CHIP:DMG: {
[1726125694.274962][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125694.274983][1237356:1237371] CHIP:DMG: }
[1726125694.275000][1237356:1237371] CHIP:DMG:
[1726125694.275048][1237356:1237371] CHIP:EM: >>> [E:18850i S:64780 M:105600314] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1726125694.275105][1237356:1237371] CHIP:EM: Found matching exchange: 18850i, Delegate: 0xffffac008628
[1726125694.275160][1237356:1237371] CHIP:DMG: ICR moving to [ResponseRe]
[1726125694.275210][1237356:1237371] CHIP:DMG: InvokeResponseMessage =
[1726125694.275235][1237356:1237371] CHIP:DMG: {
[1726125694.275256][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125694.275279][1237356:1237371] CHIP:DMG: InvokeResponseIBs =
[1726125694.275307][1237356:1237371] CHIP:DMG: [
[1726125694.275328][1237356:1237371] CHIP:DMG: InvokeResponseIB =
[1726125694.275365][1237356:1237371] CHIP:DMG: {
[1726125694.275403][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125694.275434][1237356:1237371] CHIP:DMG: {
[1726125694.275461][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125694.275494][1237356:1237371] CHIP:DMG: {
[1726125694.275518][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125694.275542][1237356:1237371] CHIP:DMG: ClusterId = 0x3e,
[1726125694.275570][1237356:1237371] CHIP:DMG: CommandId = 0x1,
[1726125694.275610][1237356:1237371] CHIP:DMG: },
[1726125694.275646][1237356:1237371] CHIP:DMG:
[1726125694.275677][1237356:1237371] CHIP:DMG: CommandFields =
[1726125694.275709][1237356:1237371] CHIP:DMG: {
[1726125694.275744][1237356:1237371] CHIP:DMG: 0x0 = [
[1726125694.275871][1237356:1237371] CHIP:DMG: 0x15, 0x30, 0x01, 0xec, 0x30, 0x81, 0xe9, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x02, 0xa0, 0x81, 0xdb, 0x30, 0x81, 0xd8, 0x02, 0x01, 0x03, 0x31, 0x0d, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x45, 0x06, 0x09, 0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x07, 0x01, 0xa0, 0x38, 0x04, 0x36, 0x15, 0x24, 0x00, 0x01, 0x25, 0x01, 0x34, 0x12, 0x36, 0x02, 0x05, 0x78, 0x56, 0x18, 0x25, 0x03, 0x01, 0x01, 0x2c, 0x04, 0x13, 0x5a, 0x49, 0x47, 0x32, 0x30, 0x31, 0x34, 0x31, 0x5a, 0x42, 0x33, 0x33, 0x30, 0x30, 0x30, 0x33, 0x2d, 0x32, 0x34, 0x24, 0x05, 0x00, 0x24, 0x06, 0x00, 0x25, 0x07, 0x94, 0x26, 0x24, 0x08, 0x01, 0x18, 0x31, 0x7d, 0x30, 0x7b, 0x02, 0x01, 0x03, 0x80, 0x14, 0x62, 0xfa, 0x82, 0x33, 0x59, 0xac, 0xfa, 0xa9, 0x96, 0x3e, 0x1c, 0xfa, 0x14, 0x0a, 0xdd, 0xf5, 0x04, 0xf3, 0x71, 0x60, 0x30, 0x0b, 0x06, 0x09, 0x60, 0x86, 0x48, 0x01, 0x65, 0x03, 0x04, 0x02, 0x01, 0x30, 0x0a, 0x06, 0x08, 0x2a, 0x86, 0x48, 0xce, 0x3d, 0x04, 0x03, 0x02, 0x04, 0x47, 0x30, 0x45, 0x02, 0x21, 0x00, 0xd0, 0x2b, 0xd7, 0xbc, 0x68, 0xdf, 0xb9, 0x54, 0x83, 0xf1, 0x96, 0x26, 0x8b, 0x4c, 0x7c, 0x71, 0x0a, 0x05, 0xed, 0xd8, 0xeb, 0xc9, 0x82, 0xa8, 0x9e, 0x14, 0xd5, 0xbd, 0x72, 0xe4, 0x72, 0x42, 0x02, 0x20, 0x25, 0x54, 0x3c, 0xea, 0x1f, 0xb1, 0x4b, 0x58, 0x78, 0xbf, 0x68, 0xb8, 0x43, 0x40, 0x0c, 0x48, 0x66, 0xdf, 0xc8, 0xde, 0xf2, 0x65, 0xa6, 0x25, 0x96, 0xd0, 0x66, 0x50, 0xcd, 0x66, 0xfa, 0xe9, 0x30, 0x02, 0x20, 0xa0, 0x4d, 0x62, 0x6c, 0xff, 0x59, 0x7c, 0x9c, 0x2f, 0x94, 0x8d, 0x1e, 0x88, 0x6b, 0x41, 0xe3, 0x6f, 0x99, 0xb4, 0x6a, 0x52, 0x0e, 0x7c, 0xa1, 0xa7, 0xa5, 0x85, 0xdf, 0x4c, 0xaf, 0x41, 0xf9, 0x24, 0x03, 0x00, 0x18,
[1726125694.275952][1237356:1237371] CHIP:DMG: ] (279 bytes)
[1726125694.275989][1237356:1237371] CHIP:DMG: 0x1 = [
[1726125694.276039][1237356:1237371] CHIP:DMG: 0x99, 0x3f, 0x7a, 0x63, 0x08, 0x24, 0x6d, 0xd1, 0x60, 0xdb, 0x4a, 0xf0, 0x48, 0x70, 0xef, 0xa1, 0xdc, 0xe4, 0xc7, 0x0d, 0x3c, 0xad, 0x82, 0x1f, 0x66, 0x45, 0xa7, 0x34, 0x7e, 0x7a, 0x92, 0xda, 0x51, 0xf2, 0x35, 0xa2, 0x03, 0x17, 0xa5, 0xb6, 0xd9, 0x55, 0xed, 0x3e, 0x8e, 0xb4, 0x00, 0x81, 0x47, 0xd0, 0x91, 0x89, 0x77, 0xa8, 0x1a, 0x95, 0xa3, 0x00, 0xb3, 0x9b, 0x75, 0x33, 0x72, 0xbd,
[1726125694.276095][1237356:1237371] CHIP:DMG: ] (64 bytes)
[1726125694.276135][1237356:1237371] CHIP:DMG: },
[1726125694.276165][1237356:1237371] CHIP:DMG: },
[1726125694.276201][1237356:1237371] CHIP:DMG:
[1726125694.276224][1237356:1237371] CHIP:DMG: },
[1726125694.276249][1237356:1237371] CHIP:DMG:
[1726125694.276269][1237356:1237371] CHIP:DMG: ],
[1726125694.276298][1237356:1237371] CHIP:DMG:
[1726125694.276333][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125694.276359][1237356:1237371] CHIP:DMG: },
[1726125694.276442][1237356:1237371] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1726125694.276496][1237356:1237371] CHIP:CTL: Received Attestation Information from the device
[1726125694.276532][1237356:1237371] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
[1726125694.276557][1237356:1237371] CHIP:CTL: AutoCommissioner setting attestationElements buffer size 279/279
[1726125694.276621][1237356:1237371] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1726125694.276657][1237356:1237371] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
[1726125694.276693][1237356:1237371] CHIP:CTL: Verifying attestation
[1726125694.307612][1237356:1237371] CHIP:CTL: Failed in verifying 'Attestation Information' command received from the device: err 101. Look at AttestationVerificationResult enum to understand the errors
[1726125694.307710][1237356:1237371] CHIP:CTL: Error on commissioning step 'AttestationVerification': 'src/controller/CHIPDeviceController.cpp:1119: CHIP Error 0x000000AC: Internal error'
[1726125694.307734][1237356:1237371] CHIP:CTL: Failed to perform commissioning step 13
[1726125694.307759][1237356:1237371] CHIP:CTL: Going from commissioning step 'AttestationVerification' with lastErr = 'src/controller/CHIPDeviceController.cpp:1119: CHIP Error 0x000000AC: Internal error' -> 'Cleanup'
[1726125694.307794][1237356:1237371] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = 'src/controller/CHIPDeviceController.cpp:1119: CHIP Error 0x000000AC: Internal error'
[1726125694.307817][1237356:1237371] CHIP:CTL: Expiring failsafe on proxy 0xffffac010fd0
[1726125694.307923][1237356:1237371] CHIP:DMG: ICR moving to [AddingComm]
[1726125694.307961][1237356:1237371] CHIP:DMG: ICR moving to [AddedComma]
[1726125694.308333][1237356:1237371] CHIP:DMG: >> to BLE | 127805177 | [Interaction Model (1) / InvokeCommandRequest (0x08) / Session = 30098 / Exchange = 18851]
[1726125694.308389][1237356:1237371] CHIP:DMG: Header Flags =
[1726125694.308411][1237356:1237371] CHIP:DMG: {
[1726125694.308443][1237356:1237371] CHIP:DMG: Exchange (0x01) =
[1726125694.308463][1237356:1237371] CHIP:DMG: {
[1726125694.308480][1237356:1237371] CHIP:DMG: Initiator = true
[1726125694.308498][1237356:1237371] CHIP:DMG: }
[1726125694.308522][1237356:1237371] CHIP:DMG: }
[1726125694.308542][1237356:1237371] CHIP:DMG:
[1726125694.308568][1237356:1237371] CHIP:DMG: Decrypted Payload (35 bytes) =
[1726125694.308588][1237356:1237371] CHIP:DMG: {
[1726125694.308608][1237356:1237371] CHIP:DMG: data = 1528002801360215370024000024013024020018350124000024010018181824ff0b18
[1726125694.308627][1237356:1237371] CHIP:DMG: }
[1726125694.308644][1237356:1237371] CHIP:DMG:
[1726125694.308724][1237356:1237371] CHIP:DMG: InvokeRequestMessage =
[1726125694.308754][1237356:1237371] CHIP:DMG: {
[1726125694.308775][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125694.308802][1237356:1237371] CHIP:DMG: timedRequest = false,
[1726125694.308824][1237356:1237371] CHIP:DMG: InvokeRequests =
[1726125694.312939][1237356:1237371] CHIP:DMG: [
[1726125694.313031][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125694.313095][1237356:1237371] CHIP:DMG: {
[1726125694.313127][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125694.313231][1237356:1237371] CHIP:DMG: {
[1726125694.313268][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125694.313302][1237356:1237371] CHIP:DMG: ClusterId = 0x30,
[1726125694.313347][1237356:1237371] CHIP:DMG: CommandId = 0x0,
[1726125694.313376][1237356:1237371] CHIP:DMG: },
[1726125694.313409][1237356:1237371] CHIP:DMG:
[1726125694.313434][1237356:1237371] CHIP:DMG: CommandFields =
[1726125694.313465][1237356:1237371] CHIP:DMG: {
[1726125694.313529][1237356:1237371] CHIP:DMG: 0x0 = 0,
[1726125694.313575][1237356:1237371] CHIP:DMG: 0x1 = 0,
[1726125694.313608][1237356:1237371] CHIP:DMG: },
[1726125694.313634][1237356:1237371] CHIP:DMG: },
[1726125694.313661][1237356:1237371] CHIP:DMG:
[1726125694.313683][1237356:1237371] CHIP:DMG: ],
[1726125694.313710][1237356:1237371] CHIP:DMG:
[1726125694.313731][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125694.313753][1237356:1237371] CHIP:DMG: },
[1726125694.313776][1237356:1237371] CHIP:DMG:
[1726125694.313855][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125694.313880][1237356:1237371] CHIP:DMG: {
[1726125694.313903][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125694.313934][1237356:1237371] CHIP:DMG: }
[1726125694.313952][1237356:1237371] CHIP:DMG:
[1726125694.315492][1237356:1237371] CHIP:EM: <<< [E:18851i S:64780 M:127805177] (S) Msg TX to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:08 (IM:InvokeCommandRequest)
[1726125694.316196][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingRe]
[1726125694.316361][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingDe]
[1726125694.404771][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16387
[1726125694.450953][1237356:1237368] CHIP:DL: Indication received, conn = 0xffffa4010130
[1726125694.451463][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16389
[1726125694.451936][1237356:1237371] CHIP:DMG: << from BLE | 105600315 | [Interaction Model (1) / InvokeCommandResponse (0x09) / Session = 64780 / Exchange = 18851]
[1726125694.452000][1237356:1237371] CHIP:DMG: Header Flags =
[1726125694.452022][1237356:1237371] CHIP:DMG: {
[1726125694.452060][1237356:1237371] CHIP:DMG: }
[1726125694.452080][1237356:1237371] CHIP:DMG:
[1726125694.452107][1237356:1237371] CHIP:DMG: Decrypted Payload (36 bytes) =
[1726125694.452128][1237356:1237371] CHIP:DMG: {
[1726125694.452145][1237356:1237371] CHIP:DMG: data = 152800360115350037002400002401302402011835012400002c01001818181824ff0b18
[1726125694.452161][1237356:1237371] CHIP:DMG: }
[1726125694.452179][1237356:1237371] CHIP:DMG:
[1726125694.452241][1237356:1237371] CHIP:DMG:
[1726125694.452289][1237356:1237371] CHIP:DMG: Additional Fields =
[1726125694.452311][1237356:1237371] CHIP:DMG: {
[1726125694.452334][1237356:1237371] CHIP:DMG: peer_address = BLE
[1726125694.452356][1237356:1237371] CHIP:DMG: }
[1726125694.452374][1237356:1237371] CHIP:DMG:
[1726125694.452415][1237356:1237371] CHIP:EM: >>> [E:18851i S:64780 M:105600315] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1726125694.452460][1237356:1237371] CHIP:EM: Found matching exchange: 18851i, Delegate: 0xffffac016ca8
[1726125694.452509][1237356:1237371] CHIP:DMG: ICR moving to [ResponseRe]
[1726125694.452553][1237356:1237371] CHIP:DMG: InvokeResponseMessage =
[1726125694.452575][1237356:1237371] CHIP:DMG: {
[1726125694.452596][1237356:1237371] CHIP:DMG: suppressResponse = false,
[1726125694.452619][1237356:1237371] CHIP:DMG: InvokeResponseIBs =
[1726125694.452647][1237356:1237371] CHIP:DMG: [
[1726125694.452682][1237356:1237371] CHIP:DMG: InvokeResponseIB =
[1726125694.452718][1237356:1237371] CHIP:DMG: {
[1726125694.452741][1237356:1237371] CHIP:DMG: CommandDataIB =
[1726125694.452772][1237356:1237371] CHIP:DMG: {
[1726125694.452800][1237356:1237371] CHIP:DMG: CommandPathIB =
[1726125694.452832][1237356:1237371] CHIP:DMG: {
[1726125694.452892][1237356:1237371] CHIP:DMG: EndpointId = 0x0,
[1726125694.452920][1237356:1237371] CHIP:DMG: ClusterId = 0x30,
[1726125694.452949][1237356:1237371] CHIP:DMG: CommandId = 0x1,
[1726125694.452983][1237356:1237371] CHIP:DMG: },
[1726125694.453018][1237356:1237371] CHIP:DMG:
[1726125694.453066][1237356:1237371] CHIP:DMG: CommandFields =
[1726125694.453095][1237356:1237371] CHIP:DMG: {
[1726125694.453129][1237356:1237371] CHIP:DMG: 0x0 = 0,
[1726125694.453171][1237356:1237371] CHIP:DMG: 0x1 = "" (0 chars),
[1726125694.453209][1237356:1237371] CHIP:DMG: },
[1726125694.453240][1237356:1237371] CHIP:DMG: },
[1726125694.453275][1237356:1237371] CHIP:DMG:
[1726125694.453300][1237356:1237371] CHIP:DMG: },
[1726125694.453328][1237356:1237371] CHIP:DMG:
[1726125694.453349][1237356:1237371] CHIP:DMG: ],
[1726125694.453379][1237356:1237371] CHIP:DMG:
[1726125694.453401][1237356:1237371] CHIP:DMG: InteractionModelRevision = 11
[1726125694.453425][1237356:1237371] CHIP:DMG: },
[1726125694.453497][1237356:1237371] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1726125694.453545][1237356:1237371] CHIP:CTL: Failsafe disarmed
[1726125694.453585][1237356:1237371] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
[1726125694.453647][1237356:1237371] CHIP:TOO: Device commissioning Failure: src/controller/CHIPDeviceController.cpp:1119: CHIP Error 0x000000AC: Internal error
[1726125694.453701][1237356:1237371] CHIP:DIS: Closing all BLE connections
[1726125694.453730][1237356:1237371] CHIP:IN: Clearing BLE pending packets.
[1726125694.454516][1237356:1237371] CHIP:BLE: Auto-closing end point's BLE connection.
[1726125694.454574][1237356:1237371] CHIP:DL: Closing BLE GATT connection (con 0xffffa4010130)
[1726125694.457155][1237356:1237368] CHIP:DL: BluezDisconnect peer=DE:D8:49:5B:8A:D3
[1726125694.722178][1237356:1237368] CHIP:DL: Bluez disconnected
[1726125694.727589][1237356:1237368] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1726125694.722301][1237356:1237371] CHIP:IN: SecureSession[0xffffac00a4c0]: MarkForEviction Type:1 LSID:64780
[1726125694.727882][1237356:1237371] CHIP:SC: SecureSession[0xffffac00a4c0, LSID:64780]: State change 'kActive' --> 'kPendingEviction'
[1726125694.728015][1237356:1237371] CHIP:DMG: ICR moving to [AwaitingDe]
[1726125694.728080][1237356:1237371] CHIP:IN: SecureSession[0xffffac00a4c0]: Released - Type:1 LSID:64780
[1726125694.728121][1237356:1237371] CHIP:DL: Long dispatch time: 277 ms, for event type 16389
[1726125694.728149][1237356:1237371] CHIP:DL: HandlePlatformSpecificBLEEvent 16388
[1726125694.728169][1237356:1237371] CHIP:BLE: no endpoint for unsub complete
[1726125694.728428][1237356:1237356] CHIP:CTL: Shutting down the commissioner
[1726125694.728586][1237356:1237356] CHIP:CTL: Shutting down the controller
[1726125694.728643][1237356:1237356] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1726125694.728689][1237356:1237356] CHIP:FP: Forgetting fabric 0x1
[1726125694.728751][1237356:1237356] CHIP:TS: Pending Last Known Good Time: 2023-10-14T01:16:48
[1726125694.729067][1237356:1237356] CHIP:TS: Previous Last Known Good Time: 2023-10-14T01:16:48
[1726125694.729267][1237356:1237356] CHIP:TS: Reverted Last Known Good Time to previous value
[1726125694.729378][1237356:1237356] CHIP:CTL: Shutting down the commissioner
[1726125694.729544][1237356:1237356] CHIP:CTL: Shutting down the controller
[1726125694.729632][1237356:1237356] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1726125694.730508][1237356:1237356] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1726125694.731016][1237356:1237356] CHIP:FP: Shutting down FabricTable
[1726125694.731117][1237356:1237356] CHIP:TS: Pending Last Known Good Time: 2023-10-14T01:16:48
[1726125694.731346][1237356:1237356] CHIP:TS: Previous Last Known Good Time: 2023-10-14T01:16:48
[1726125694.731748][1237356:1237356] CHIP:TS: Reverted Last Known Good Time to previous value
[1726125694.732074][1237356:1237356] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-C7x0Yh)
[1726125694.733138][1237356:1237356] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1726125694.733631][1237356:1237356] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1726125694.733912][1237356:1237356] CHIP:DL: Inet Layer shutdown
[1726125694.734179][1237356:1237356] CHIP:DL: BLE shutdown
[1726125694.740304][1237356:1237356] CHIP:DL: System Layer shutdown
[1726125694.741664][1237356:1237356] CHIP:TOO: Run command failure: src/controller/CHIPDeviceController.cpp:1119: CHIP Error 0x000000AC: Internal errorThanks,
Ethan
