Distance
When using two 52833 boards for distance measurement, when testing at 60cm, the distance value obtained sometimes wobbles between 0.6-1.2m, but sometimes stabilised around a certain value. When I use the two boards again, this value will change again, making my offset value uncertain
  • Hi
    Can you show me the log where you see this wobbly measurements? Does it usually stabilize at 60cm or more here? I assume this is during Zero-distance calibration on your end? What kind of environment are you doing these tests in? If there is a lot of radio interference that could explain the very wobbly. Also, what SDK version are you using for testing here?
    Simon
