Hi All,
I'm working with the NRF52 Preview DK, with SDK V 0.92.
I've been looking at and tweaking the SPI_Master tutorial found under /examples/peripheral/spi_master/ while following the documentation for the SPI Hardware Drivers found here:
So far, I've been able to successfully write data out on the MOSI pin of the SPI1 peripheral, verified using a saleae logic analyzer. However, I've had to change the trigger settings because the slave select pin does not seem to be toggling low to initialize the transaction. (see attached screen capture).
I've tried overriding the default NRF_DRV_SPI_DEFAULT_CONFIG() value for ss_pin with the SPIM1_SS_PIN found in the pca13006.h file like so, but still no luck.
// 2) Configure and Initialize the instance
nrf_drv_spi_config_t config = NRF_DRV_SPI_DEFAULT_CONFIG(1);
config.frequency = NRF_DRV_SPI_FREQ_1M;
config.mode = NRF_DRV_SPI_MODE_3;
config.bit_order = NRF_DRV_SPI_BIT_ORDER_LSB_FIRST;
config.ss_pin = SPIM1_SS_PIN;
Any other ideas on how I can "enable" the slave select of the SPI1 peripheral?
I've attached my entire main code at the bottom of this post
Thanks!
int main(void){
uint32_t err_code;
const uint8_t *tx_buf="Helloooo";
uint8_t tx_buf_len=9;
uint8_t *rx_buf="World";
uint8_t rx_buf_len=6;
SEGGER_RTT_printf(0, "Hello World! Let's Initialize the SPI1 Peripheral as master\n");
// 1) Create an SPI master driver instance to control SPI1 peripheral
static const nrf_drv_spi_t m_spi_master_1 = NRF_DRV_SPI_INSTANCE(1);
err_code = nrf_drv_spi_init(&m_spi_master_1, &config, NULL); // NULL event handler = blocking mode
if (err_code != NRF_SUCCESS){
SEGGER_RTT_printf(0, "Could not properly run nrf_drv_spi_init() to initialize SPI Peripheral\n");
return -1;
// Send data continuously in infinite loop
for(;;){
err_code = nrf_drv_spi_transfer(&m_spi_master_1, tx_buf, tx_buf_len, rx_buf, rx_buf_len);
nrf_delay_ms(100);
// Uninitialize the SPI Master Driver instance
nrf_drv_spi_uninit(&m_spi_master_1);
return 0;
