How to add Skyworks fem to nrf5340 audio
I am using nrf5340 audio sample with the custom board. The nRF Connect SDK version I used is v2.7.0.
I referred to this post and tried to add skyworks fem to my nrf5340 audio application.
The following is the part I modified:
nrf5340_audio_dk_nrf5340_cpunet.overlay
    nrf_radio_fem: pa_lna {
        compatible = "skyworks,sky66112-11", "generic-fem-two-ctrl-pins";
        ctx-gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>;
        ctx-settle-time-us = < 23 >;
        crx-gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>;
        crx-settle-time-us = < 5 >;
        cps-gpios = <&gpio1 0 GPIO_ACTIVE_HIGH>;
        tx-gain-db = < 13 >;
        rx-gain-db = < 14 >;
&radio {
	fem = <&nrf_radio_fem>;
nrf5340_audio_dk_nrf5340_cpuapp.overlay
prj.conf
CONFIG_MPSL=y
CONFIG_MPSL_FEM_ONLY=y
CONFIG_MPSL_FEM_SIMPLE_GPIO=y
But it doesn't seem to work.
Is there any way to add skyworks fem to nrf5340 audio application?
  • Hi, and once again I am very sorry about the wait,
    LandyWang said:
    My compile error is as follows:
    So that is good that it atleast gives you an error, showing that the files are being taken into account. I think maybe the build system didn't register the conf files last time I tried to build this - I think I am now running into the same issue you are here if I am trying to enable MPSL explicitly. Or something along those lines. The error looks the same.
    [200/205] Linking C executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map C:/nordic/ownApplications/nrf5340_audio_sys27/build_2/ipc_radio/zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && C:\ncs\toolchains\ce3b5ff664\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D C:\nordic\ownApplications\nrf5340_audio_sys27\build_2\ipc_radio\zephyr && C:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.exe -E true""
    c:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(hci_driver.c.obj): in function `mpsl_work_submit':
    C:/nordic/ncs/v2.7.0/nrf/include/mpsl/mpsl_work.h:47: undefined reference to `mpsl_work_q'
    c:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(ecdh.c.obj): in function `hci_cmd_le_read_local_p256_public_key':
    C:/nordic/ncs/v2.7.0/nrf/subsys/bluetooth/controller/ecdh.c:316: undefined reference to `mpsl_work_q'
    c:/ncs/toolchains/ce3b5ff664/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a(ecdh.c.obj): in function `cmd_le_generate_dhkey':
    C:/nordic/ncs/v2.7.0/nrf/subsys/bluetooth/controller/ecdh.c:327: undefined reference to `mpsl_work_q'
    collect2.exe: error: ld returned 1 exit status
    [15/20] Generating ../merged.hex
    FAILED: modules/nrf/ipc_radio-prefix/src/ipc_radio-stamp/ipc_radio-build C:/nordic/ownApplications/nrf5340_audio_sys27/build_2/modules/nrf/ipc_radio-prefix/src/ipc_radio-stamp/ipc_radio-build
    cmd.exe /C "cd /D C:\nordic\ownApplications\nrf5340_audio_sys27\build_2\ipc_radio && C:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.exe --build ."
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\ce3b5ff664\opt\bin\cmake.EXE' --build C:/nordic/ownApplications/nrf5340_audio_sys27/build_2
    * The terminal process terminated with exit code: 1.
    * Terminal will be reused by tasks, press any key to close it.
    However, this builds for me in the audio sample, and automatically adds MPSL as well.
    sysbuild/ipc_radio.overlay
            crx-gpios = <&gpio1 5 GPIO_ACTIVE_LOW>;
            cps-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>;
    &radio {
    boards/nrf5340_audio_dk_nrf5340_cpuapp.overlay
    &usbd {
    	hs_0: hs_0 {
    		compatible = "usb-audio-hs";
    		mic-feature-mute;
    		mic-channel-l;
    		mic-channel-r;
    		hp-feature-mute;
    		hp-channel-l;
    		hp-channel-r;
    Now sometimes when I build with a new build configuration, it's not automatically finding the appcore overlay for me. Either way, that can be circumvented by adding it manually in the build-config GUI. The reference to usbdd here is just from the audio sample, so I simply added the references to fem underneath this.
    Does that build for you?
    Regards
  • Thanks for your assistance.
    I used the new configuration you suggested and still encountered the same error.
    2. Add /sysbuild/ipc_radio.conf
    I had to remove sysbuild/ipc_radio.conf mentioned in here than it can compile successfully. I am confused whether the MPSL related config is really compiled?
    In addition, after using the new configuration and removing sysbuild/ipc_radio.conf, although the compilation was successful, the longest distance bis gateway and bis headset could maintain sync did not increase when measured.
    I believe MPSL wasn't required to be set explicitly. Did you have anything other than MPSL enabled there? If you check the buildfiles you can see that MPSL is still being enabled from just the right dts nodes being there.
    So the output power depends on what you've configured both the FEM and the nRF to transmit. You can configure how much you want it to output using  eg. CONFIG_BT_CTLR_TX_PWR_ANTENNA, and how much the FEM is configured to contribute with using tx-gain-db in the FEMs dts node. Then the SoC TXPOWER is changed to compensate for the remainder such that TXPOWER+FEM gain <= CONFIG_BT_CTRL_TX_PWR_ANTENNA. So for instance if you happened to be using the nRF52840, and have set a static 20dB gain in the FEM, and set CONFIG_BT_CTRL_TX_PWR_ANTENNA=15dBm, you'll only get 12dBm on the antenna, since -8dBm is the closest you can get on the '840.
    This is a difficult way to test it. Could you try instead doing it this way?
    Elfving
  • Did you have anything other than MPSL enabled there?
    In addition to MPSL, I also enable these in prj.conf.
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
    CONFIG_I2C=y
    CONFIG_I2C_NRFX=y
    Which file should I check to confirm that MPSL is enabled?
    I understand, it means that I set tx-gain_db to 13 and rx_gain_db to 14 in the overlay, then if I set CONFIG_BT_CTLR_TX_PWR_ANTENNA to 0, then I will get -3dBm in tx and -2 dBm in rx, is that right?
    But when I tried to add CONFIG_BT_CTLR_TX_PWR_ANTENNA=0, the following warning appeared:
    CONFIG_BT_CTLR_TX_PWR_ANTENNA couldn't be set. Missing dependencies:
    BT_CTLR
    I tried using this way but got the error.
    C:\WINDOWS\system32>nrfjprog --memrd 0x4000150C --log
    [error] [SeggerBackend] - JLinkARM.dll ReadMem returned error 1.
    [error] [  nRF53] - The read access failed due to memory protection.
    ERROR: Access to the selected address is blocked by the SPU.
  • Hi Landy,
    Håkon is away this week. I will try to help in the mean time.
    You can check the generated .config file in build\zephyr folder to see what configuration has been enabled. Please check if you have CONFIG_MPSL=y. There are some more CONFIG_MPSL_FEM_* configuration, maybe they are relevant to your project.
    CONFIG_BT_CTLR_TX_PWR_ANTENNA should be set in the firmware for the network core (BT_CTRL = Bluetooth controller ) , in your case it can be the ipc_radio remote image.
    Seems like the chip  has readback protection. Please check if you have enabled APPROTECT.
