Format of certification files needed to use secure MQTT in nRF-9160 and nRF-9151
Hi all,
Recently I am trying to start a secure MQTT connect between Rabbit MQ broker and nRF-9160 or nRF-9151.
nRF9160 is running Serial LTE Modem(SLM) application with v2.4.0 SDK , and nRF-9151 is also running SLM but under v2.7.0 SDK.
Broker was set to single way MQTTS with credentials applied from "let's encrypt" (or called simple MQTTS as I heard, which only clients would check server, server doesn't check client).
I'm now using PC tool "Cellular Monitor" to import certificate files, and according to the GUI, there could be CA certificate(CA) / Client Certificate(CC) / Private Key(PK).
My questions are:
  1. According to ChatGPT (might not be correct...):
    "when running simple MQTTS,
    server needs       CA certificate / Server Certificate / Server Private Key,
    and clients need Client CA Certificate / Client Private Key, Client Certificate usually is not a must."
    So... does server and clients both use the same CA certificate file? Does server and client need to have different private key file?
  2. I've got 3 files named "cert.pem" "chain.pem" "privkey.pem" provided by server side colleague (I assume these are CA file, CC file and PK file).
    However when I import them into SLM with cellular monitor tool, no matter if I feed CA only / CA + PK / CA + CC + PK, AT#XMQTTCON always returns "ERROR"(Any method to found reason of error?).
    As I'm surfing trying to find some solution, I noticed that some company requires user to turn .pem files into one-line format before feeding them. So does \r and \n needed to remove before feeding my certificate file into SLM?
    (Connection to MQTT port success, but connection to MQTTS port with <sec_tag> returns ERROR
  3. I've noticed there are a command AT%KEYGEN. But I'm not sure if I need to use this and how do I use this.
    As mentioned in question 1, do I have to generate a private key per client by it self or can it just use the same PK file as server?
    If it is a must to generate a private key by each client themself, is this the correct command I should use?
    The first purpose stated in the page "Client private key and certificate signing request (CSR) (<key_type> 2, <response_content> 0)" seems kind of like what I need, as it says it could be used for TLS credential. But 1st how does it know which CA should it try to apply client certificate + private key (could CA certificate file help?), 2nd we are only doing simple MQTTS so we might not need the generated client certificate, would "extra certificate file" be a concern or we may just ignore it?
  • Hi Øyvind,
    Thanks for the reply,
    Recently I'm testing with MQTTX PC software with all the certificate files I've got.
    It took me really long time to realize that I probably should import root certificate(ISRG Root X1) as CA file instead of some CA certificate files like cert.pem or fullchain.pem ...etc.
    However when I came back to try with 9160 module(using TERA term), it pops Error when I tries to import the root CA to it, no matter with or without \r\n
    AT+CFUN=4
    OK
    AT%CMNG=01
    %CMNG: 4294967293,10,"2C43952EE9E000FF2ACC4E2ED0897C0A72AD5FA72C3D934E81741CBD54F05BD1"
    %CMNG: 4294967294,6,"88204F1D300667A8DFE05F6C7018C0607B0DFF8D6D69221FF4C2FA7E50543842"
    %CMNG: 4294967292,11,"B2C46C2AE7C81943A8BD6DD4ED2A50B659A225A098A177BACB575459CD57CAEF"
    OK
    AT%CMNG=0,0,0"
    -----BEGIN CERTIFICATE-----
    MIIFazCCA1OgAwIBAgIRAIIQz7DSQONZRGPgu2OCiwAwDQYJKoZIhvcNAQELBQAw
    TzELMAkGA1UEBhMCVVMxKTAnBgNVBAoTIEludGVybmV0IFNlY3VyaXR5IFJlc2Vh
    cmNoIEdyb3VwMRUwEwYDVQQDEwxJU1JHIFJvb3QgWDEwHhcNMTUwNjA0MTEwNDM4
    WhcNMzUwNjA0MTEwNDM4WjBPMQswCQYDVQQGEwJVUzEpMCcGA1UEChMgSW50ZXJu
    ZXQgU2VjdXJpdHkgUmVzZWFyY2ggR3JvdXAxFTATBgNVBAMTDElTUkcgUm9vdCBY
    MTCCAiIwDQYJKoZIhvcNAQEBBQADggIPADCCAgoCggIBAK3oJHP0FDfzm54rVygc
    h77ct984kIxuPOZXoHj3dcKi/vVqbvYATyjb3miGbESTtrFj/RQSa78f0uoxmyF+
    0TM8ukj13Xnfs7j/EvEhmkvBioZxaUpmZmyPfjxwv60pIgbz5MDmgK7iS4+3mX6U
    A5/TR5d8mUgjU+g4rk8Kb4Mu0UlXjIB0ttov0DiNewNwIRt18jA8+o+u3dpjq+sW
    T8KOEUt+zwvo/7V3LvSye0rgTBIlDHCNAymg4VMk7BPZ7hm/ELNKjD+Jo2FR3qyH
    B5T0Y3HsLuJvW5iB4YlcNHlsdu87kGJ55tukmi8mxdAQ4Q7e2RCOFvu396j3x+UC
    B5iPNgiV5+I3lg02dZ77DnKxHZu8A/lJBdiB3QW0KtZB6awBdpUKD9jf1b0SHzUv
    KBds0pjBqAlkd25HN7rOrFleaJ1/ctaJxQZBKT5ZPt0m9STJEadao0xAH0ahmbWn
    OlFuhjuefXKnEgV4We0+UXgVCwOPjdAvBbI+e0ocS3MFEvzG6uBQE3xDk3SzynTn
    jh8BCNAw1FtxNrQHusEwMFxIt4I7mKZ9YIqioymCzLq9gwQbooMDQaHWBfEbwrbw
    qHyGO0aoSCqI3Haadr8faqU9GY/rOPNk3sgrDQoo//fb4hVC1CLQJ13hef4Y53CI
    rU7m2Ys6xt0nUW7/vGT1M0NPAgMBAAGjQjBAMA4GA1UdDwEB/wQEAwIBBjAPBgNV
    HRMBAf8EBTADAQH/MB0GA1UdDgQWBBR5tFnme7bl5AFzgAiIyBpY9umbbjANBgkq
    hkiG9w0BAQsFAAOCAgEAVR9YqbyyqFDQDLHYGmkgJykIrGF1XIpu+ILlaS/V9lZL
    ubhzEFnTIZd+50xx+7LSYK05qAvqFyFWhfFQDlnrzuBZ6brJFe+GnY+EgPbk6ZGQ
    3BebYhtF8GaV0nxvwuo77x/Py9auJ/GpsMiu/X1+mvoiBOv/2X/qkSsisRcOj/KK
    NFtY2PwByVS5uCbMiogziUwthDyC3+6WVwW6LLv3xLfHTjuCvjHIInNzktHCgKQ5
    ORAzI4JMPJ+GslWYHb4phowim57iaztXOoJwTdwJx4nLCgdNbOhdjsnvzqvHu7Ur
    TkXWStAmzOVyyghqpZXjFaH3pO3JLF+l+/+sKAIuvtd7u+Nxe5AW0wdeRlN8NwdC
    jNPElpzVmbUq4JUagEiuTDkHzsxHpFKVK7q4+63SM1N95R1NbdWhscdCb+ZAJzVc
    oyi3B43njTOQ5yOf+1CceWxG1bQVs5ZufpsMljq4Ui0/1lvh+wjChP4kqKOJ2qxq
    4RgqsahDYVvTH9w7jXbyLeiNdd8XM2w9U/t7y0Ff/9yi0GE44Za4rF2LN9d11TPA
    mRGunUHBcnWEvgJBQl9nJEiU0Zsnvgc/ubhPgXRR4Xq37Z0j4r7g1SgEEzwxA57d
    emyPxgcYxn/eR44/KJ4EBs+lVDR3veyJm+kXQ99b21/+jh5Xos1AnX5iItreGCc=
    -----END CERTIFICATE-----
    ERROR
    AT%SHORTHWVERSION
    %HWVERSION: nRF9160 SICA B1A
    OK
    AT%SHORTSWVER
    %SHORTSWVER: nrf9160_1.3.4
    OK
    AT%#XSLMVER
    #XSLMVER: "2.4.0","2.4.0-lte-788c5f11c0d6"
    OK
    And below is the root CA I've been trying, downloaded from Let's Encrypt pageCertificate details (self-signed): pem format.
    Do you have any idea what might the problems are?
  • Note that you can use the Cellular Monitor's certificate manager to provision certificates to your device.
    Using the AT command CMNG, please note that there is a missing comma ',' in your command
    Alan-Ni said:
    AT%CMNG=0,0,0"
    This should be > AT%CMNG=0,0,0,"
    I had not issues provisioning the root CA in your last comment with both the Certificate Manager and AT command directly as above.
    Øyvind
  • Hi Øyvind,
    Ahh... how did I miss that.. thanks a lot for pointing that out!
    While the Tera term couldn't work, I also tried to import with Cellular monitor tool within nRF Connect for desktop and that works.
    I've tried importing the original ISRG Root X1 and another no \r\n version ISRG Root X1, but both of them end up with ERROR when I'm trying to start the MQTTS connect.
    As I mentioned at the top post, we are trying simple MQTTS(one way SSL MQTTS, only clients will verify server).Since MQTTX app could connect successfully with ISRG Root X1 provided as CA file only, I believe this "simple MQTTS" is a doable method.
    Now I'm confused that when I get the ERROR response when sending AT#XMQTTCON=... command, is it because SLM thinks I'm missing Client Certificate and Private Key? Or is it because the ISRG Root X1 file is not in the correct format? Is there any way to get more detail about the reason of ERROR?
    I'm quite confident with syntax issue this time because connecting to the non secure MQTT port (8883->1883, and without <sec_tag>) works fine
  • Hi Øyvind,
    I've tried again, and it worked this time.
    It turns out the real problem was not the certificate, but the URL.
    I've been using IP to start connection back when I'm connecting to the non-secure MQTT port, but the secure port was set to only accept connection using hostname.
    Anyway, I'm able to start the one way secure MQTT with nRF-9160(2.4.0SDK) and nRF-9151(2.7.0SDK) SLM now.
    Thanks for the help!!
    Below is my simple summary and the log of success connection.
    For starting a one way secure MQTT connection as client, I need to provide "Root CA"(not CA, not CC, not intermediate CA or any other, but "Root" CA only).
    In my case, the certificates used by MQTTS broker was applied from Let's Encrypt, so I have to prepare the Let's Encrypt root CA -- ISRG root X1. It could be downloaded directly from their website.
    I've downloaded the .pem format version, and tested to import the original file or the "one line" version(hand edit to remove CR LF), both worked well.
    Here is the log (I've replace the account / password/ hostname with star).
    Ready
    > AT+CFUN=4
    OK
    > AT%CMNG=1
    %CMNG: 16842753,0,"2C43952EE9E000FF2ACC4E2ED0897C0A72AD5FA72C3D934E81741CBD54F05BD1"
    %CMNG: 16842753,1,"B5CC275CEF820E6D3AE874BB0A3876719D2C4E92AE9A825FF253CC10A2B3B604"
    %CMNG: 16842753,2,"EF7DEF697E9778C213F1E39F6ED34E0A686B8F475826E9286B6FD594B69035D4"
    %CMNG: 4294967292,11,"672E2F05962B4EFBFA8801255D87E0E0418F2DDF4DDAEFC59E9B4162F512CB63"
    %CMNG: 4294967294,6,"ABF134FC1313E3D2ABF1DE5B9426AF7A9E8A177A6B35A2B0FAD6A8EB0952B424"
    OK
    > AT%CMNG=0,0,0,"-----BEGIN CERTIFICATE-----
    QAw
    ZXQgU2VjdXJpdHk
    m54rVygc
    T8KOEUt+zw
    OFvu396j3x+UC
    jh8BC
    VC1CLQJ13hef4Y53CI
    u
    ORAzI4JMPJ+GslWYHb4
    NwdC
    mRGunUHBcnWEvg
    iItreGCc=
    -----END CERTIFICATE-----"
    OK
    > AT%CMNG=1
    %CMNG: 0,0,"BD6681410FB05ECD2B414AFA3B02E285132CD289F9CAD10E5C850FC9888E576E"
    OK
    > AT+CEREG=1
    OK
    > AT+CFUN=1
    OK
    +CEREG: 2
    +CEREG: 1
    > AT+CEREG?
    +CEREG: 1,1
    OK
    > AT#XMQTTCFG="client_0012768",30,0
    OK
    > AT#XMQTTCON=1,"********","********","********",8883,0
    OK
    #XMQTTEVT: 9,0
    > AT+CGMR
    mfw_nrf91x1_2.0.1
    OK
    #XMQTTEVT: 9,0
    > AT#XMQTTCON=0,"********","********","********",8883,0
    #XMQTTEVT: 1,0
    OK
    OK
    #XMQTTEVT: 0,0
    #XMQTTEVT: 9,0
    #XMQTTEVT: 9,0
    > AT#XMQTTPUB="TEST","ABCDEFG",0,0
    OK
    #XMQTTEVT: 9,0
    OK
    #XMQTTEVT: 9,0
    OK
    #XMQTTEVT: 9,0
  • Hello! That is good news! Happy to hear you found the solution.
    Øyvind
