Matter commissioning issue in ThreadNetworkSetup step
After commissioning with a smart speaker such as Apple HomePod,  if the device is deleted and re-commissioned with a Test-harness, it results in an error with networkingStatus=2 in 'ThreadNetworkSetup'.
networkingStatus=2 means that adding the network configuration would exceed the limit. Should networkingStatus be set to 0 on the node when removing it from the network, or is it expected behavior for the controller side to change it?
[1721090298.852644][2768:2770] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
[1721090298.852720][2768:2770] CHIP:CTL: Received NetworkConfig response, networkingStatus=2
[1721090298.852807][2768:2770] CHIP:CTL: Error on commissioning step 'ThreadNetworkSetup': 'src/controller/CHIPDeviceController.cpp:2285: CHIP Error 0x000000AC: Internal error'
[1721090298.852861][2768:2770] CHIP:CTL: Failed to perform commissioning step 21
[1721090298.852947][2768:2770] CHIP:CTL: Going from commissioning step 'ThreadNetworkSetup' with lastErr = 'src/controller/CHIPDeviceController.cpp:2285: CHIP Error 0x000000AC: Internal error' -> 'Cleanup'
[1721090298.853020][2768:2770] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = 'src/controller/CHIPDeviceController.cpp:2285: CHIP Error 0x000000AC: Internal error'
[1721090298.853119][2768:2770] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
[1721090298.853192][2768:2770] CHIP:TOO: Device commissioning Failure: src/controller/CHIPDeviceController.cpp:2285: CHIP Error 0x000000AC: Internal error
[1721090298.853351][2768:2770] CHIP:DMG: ICR moving to [AwaitingDe]
[1721090298.853865][2768:2768] CHIP:CTL: Shutting down the commissioner
[1721090298.854065][2768:2768] CHIP:DIS: Closing all BLE connections
[1721090298.854130][2768:2768] CHIP:IN: Clearing BLE pending packets.
[1721090298.854743][2768:2768] CHIP:BLE: Auto-closing end point's BLE connection.
[1721090298.854802][2768:2768] CHIP:DL: Closing BLE GATT connection (con 0xffffac06d050)
[1721090298.854975][2768:2769] CHIP:DL: BluezDisconnect peer=E2:D2:F1:12:30:CE
[1721090299.287815][2768:2768] CHIP:IN: SecureSession[0xffffa400ae70]: MarkForEviction Type:1 LSID:32480
[1721090299.287911][2768:2768] CHIP:SC: SecureSession[0xffffa400ae70, LSID:32480]: State change 'kActive' --> 'kPendingEviction'
[1721090299.287997][2768:2768] CHIP:IN: SecureSession[0xffffa400ae70]: Released - Type:1 LSID:32480
[1721090299.288058][2768:2768] CHIP:CTL: Shutting down the controller
[1721090299.288109][2768:2768] CHIP:IN: Expiring all sessions for fabric 0x1!!
[1721090299.288152][2768:2768] CHIP:FP: Forgetting fabric 0x1
[1721090299.288211][2768:2768] CHIP:TS: Pending Last Known Good Time: 2023-10-03T16:51:18
[1721090299.288177][2768:2769] CHIP:DL: Bluez disconnected
[1721090299.288288][2768:2769] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1721090299.288381][2768:2768] CHIP:TS: Previous Last Known Good Time: 2023-10-03T16:51:18
[1721090299.288401][2768:2768] CHIP:TS: Reverted Last Known Good Time to previous value
[1721090299.288444][2768:2768] CHIP:CTL: Shutting down the commissioner
[1721090299.288526][2768:2768] CHIP:CTL: Shutting down the controller
[1721090299.288546][2768:2768] CHIP:CTL: Shutting down the System State, this will teardown the CHIP Stack
[1721090299.288690][2768:2768] CHIP:DMG: All ReadHandler-s are clean, clear GlobalDirtySet
[1721090299.288820][2768:2768] CHIP:FP: Shutting down FabricTable
[1721090299.288891][2768:2768] CHIP:TS: Pending Last Known Good Time: 2023-10-03T16:51:18
[1721090299.289078][2768:2768] CHIP:TS: Previous Last Known Good Time: 2023-10-03T16:51:18
[1721090299.289132][2768:2768] CHIP:TS: Reverted Last Known Good Time to previous value
[1721090299.289403][2768:2768] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-17I1ld)
[1721090299.290022][2768:2768] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1721090299.290091][2768:2768] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1721090299.290112][2768:2768] CHIP:DL: Inet Layer shutdown
[1721090299.290130][2768:2768] CHIP:DL: BLE shutdown
[1721090299.292226][2768:2768] CHIP:DL: System Layer shutdown
[1721090299.292669][2768:2768] CHIP:TOO: Run command failure: src/controller/CHIPDeviceController.cpp:2285: CHIP Error 0x000000AC: Internal error
