After migrating from NCS 1.8.0 to the latest NCS 2.7.0 version, I am no longer able to disable PRINTK
, which we previously did to reduce flash memory usage, as we were critically close to the limit.
Currently, I am unable to achieve this. I ran the bluetooth_lbs
example with prj_minimal.conf
, where disabling PRINTK
is mentioned, but I still see output from PRINTK
warning: PRINTK (defined at subsys/debug/Kconfig:204) was assigned the value 'n' but got the value 'y'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PRINTK and/or look up PRINTK in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. warning: EARLY_CONSOLE (defined at subsys/debug/Kconfig:223) was assigned the value 'n' but got the value 'y'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_EARLY_CONSOLE and/or look up EARLY_CONSOLE in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
It is also not possible to disable it using the nRF Kconfig GUI.
Is there a way to disable it in this version?
