LTE reconnection issue
Hello everyone,
I Have a LTE reconnection issue after LTE signal loss with SDK 1.3.6. I was doing some LTE connectivity tests by placing the board in a faraday box. After reopening the box the modem does not register back to network. (always cereg = 2). I've attached wireshark capture made with the cellular monitor tool. I also did the same test with SDK 2.5.2 and was not able to reproduce the problem.
Board: nRF9160DK
Modem firmware: 1.3.6
SDK: 2.6.1
Steps to reproduce:
1) Wait until the LTE is connected with the network
2) Close the faraday box and wait up to 1 minute
3) Open the box
Information on  the capture files:
Both capture files has been generated from reset and contains 1 connection loss action.
nRF9160_SDK2.6.1.pcapng
LTE connection loss at line 151 for around 1 minute
nrf9160_SDK2.5.2.pcapng
LTE connection loss at line 158 for around 1 minute
Can you help me to figure out why, in the case of SDK 2.6.1, is not able to reconnect to network at all ? Thanks for your help!
Eric
nRF9160_SDK2.6.1.pcapngnRF9160_SDK2.5.2.pcapng
Parents Reply
  • Hi 0yvind,
    I finally found the problem. By doing your modem traces, I tried another SIM card manufacturer and found that the first time the device register on the network, it connects in LTE-M. When the device lost connection, it tries to reconnect in NB-IOT. The problem is NB-IOT is not widely support in Canada. The supported bearers changed from SDK 2.5.2 and version 2.6.2. I had to enforce to use the LTE-M bearer by adding these configuration options in the prj.conf.
    CONFIG_LTE_NETWORK_MODE_LTE_M=y
    CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT=n
    I just want to thank you for the quick support you gave me!
    Eric
