I am currently developing a project using the nRF52810 as my controller, with SEGGER Embedded Studio (version 5.42a) and SDK version 17.0.2 as my development environment. During the development phase, I am testing the timer peripheral example project from the directory nRF5_SDK_17.0.2_d674dde\examples\peripheral\timer\pca10040\blank\ses. I flashed the code onto the nRF52832 PCA10040 development board, and the four LEDs on the board turn on and off based on the time_ms value.
The issue is that when I change the time_ms value from 1000 (1 second) to 300000 (5 minutes), the LED indications are incorrect. The LEDs turn on and off within 30 seconds instead of 5 minutes. However, when I change the time_ms value to up to 4 minutes, the LEDs behave as expected, with the correct 4-minute delay. What could be causing this issue?
Is there a timeout when using the timer? Or does it require any prescaler or timer bit width adjustments?
Your response is valuable.
Studio version 5.42a
SDK: nRF5 SDK 17.0.2
iam attaching the code for better understanding .
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "nrf_drv_timer.h"
#include "bsp.h"
#include "app_error.h"
const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(0);
* @brief Handler for timer events.
void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context)
static uint32_t i;
int j=0;
uint32_t led_to_invert = ((i++) % LEDS_NUMBER);
switch (event_type)
case NRF_TIMER_EVENT_COMPARE0:
bsp_board_led_invert(led_to_invert);
//nrf_gpio_pin_toggle(12);
//Do nothing.
uint32_t time_ms = 300000; //Time(in miliseconds) between consecutive compare events.
uint32_t time_ticks;
uint32_t err_code = NRF_SUCCESS;
//Configure all leds on board.
//nrf_gpio_cfg_output(12);
//nrf_gpio_cfg_output(11);
//Configure TIMER_LED for generating simple light effect - leds on board will invert his state one after the other.
err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer_led_event_handler);
time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_LED, time_ms);
nrf_drv_timer_extended_compare(
&TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
nrf_drv_timer_enable(&TIMER_LED);
while (1)
__WFI();
