Install NCS 2.7.0 failed
I'm installing NCS with Toolchain Manager v1.5.2, but failed at installing SDK
What should I do to check the installation?
There are multiple errors:
Failed to clone the repositories: Error: error: RPC failed; curl 92 HTTP/2 stream 0 was not closed cleanly: CANCEL (err 8) error: 359 bytes of body are still expected fetch-pack: unexpected disconnect while reading sideband packet fatal: early EOF fatal: fetch-pack: invalid index-pack output FATAL ERROR: command exited with status 128: fetch -f --tags -- https://github.com/nrfconnect/sdk-zephyr v3.6.99-ncs2 Error: Launched process exited with non-zero status: 128 Error: Subprocess C:\Users\user\AppData\Roaming\nrfconnect\nrfutil-sandboxes\toolchain-manager\0.15.0\bin\nrfutil-toolchain-manager.exe failed with unexpected exit code Some(128)
