I want to use ppi to drive PWM. Attachment is my code files, it can't work.
How should I configure it.
Hi!
Could you explain a bit about what you are you trying to develop and solve?
You could perhaps just use this sample here? https://github.com/nrfconnect/sdk-zephyr/blob/main/samples/drivers/led_pwm/src/main.c
Thank you!
I want to use PWM PPI mode to send data to an external radio chip.
Now, I can't trigger PPI task by an IN-event.
bool pwm_play_ppi_task_event_init(pwm_play_t *pp)
#if defined(__ZEPHYR__)
//Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?
// IRQ_CONNECT(NRFX_IRQ_NUMBER_GET(NRF_GPIOTE_INST_GET(0)), IRQ_PRIO_LOWEST,
// NRFX_GPIOTE_INST_HANDLER_GET(0), 0, 0);
nrfx_err_t err;
if(NULL == pp)return false;
nrfx_gpiote_trigger_config_t trigger_config = {
.trigger = pp->trigger,
.p_in_channel = &pp->gpiote_channel,
nrfx_gpiote_input_pin_config_t input_pin_config = {
.p_trigger_config = &trigger_config,
.p_pull_config = &pp->pin_pull,
.p_handler_config = &pp->gpiote_handler,
err = nrfx_gpiote_init(&pp->gpiote, NRFX_GPIOTE_DEFAULT_CONFIG_IRQ_PRIORITY);
if (err != NRFX_SUCCESS && err != NRFX_ERROR_ALREADY) {
LOG_ERR("gpiote_init failed with: %x\n", err);
return false;
err = nrfx_gpiote_channel_alloc(&pp->gpiote, &pp->gpiote_channel);
if (err != NRFX_SUCCESS) {
LOG_ERR("gpiote_channel_alloc failed with: %x\n", err);
return false;
err = nrfx_gpiote_input_configure(&pp->gpiote, pp->pin, &input_pin_config);
LOG_ERR("gpiote_input_configure failed with: %x\n", err);
return false;
nrfx_gpiote_trigger_enable(&pp->gpiote, pp->pin, true);
err = nrfx_gppi_channel_alloc(&pp->gppi_channel);
LOG_ERR("gppi_channel_alloc failed with: %x\n", err);
return false;
nrfx_gppi_channel_endpoints_setup(pp->gppi_channel,
nrfx_gpiote_in_event_address_get(&pp->gpiote, pp->pin), pp->task_addres);
LOG_INF("gppi_channel %u, gpiote_channel %u, task_addres %u", pp->gppi_channel, pp->gpiote_channel, pp->task_addres);
return true;
These code can work.
