We want the system to be in low power mode in idle state. Therefore after advertisement is sent the BLE is switched off using bt_disable. The return for this function is fine. But after sleep
when we try to enable ble using bt_enable, this function returns -11.
We debugged and we saw that the end point attach does not happen and so the semaphore take function() fails.
Can you tell us what we are missing. We are attaching the prj.conf file of application core here.
We are using nrf sdk version 2.,6.1
# GPIO Enable CONFIG_GPIO=y CONFIG_I2S=y # SPI Enable CONFIG_SPI=y CONFIG_SPI_ASYNC=y # I2C Enable CONFIG_I2C=y # Floating Point Enable CONFIG_ASSERT=y CONFIG_CBPRINTF_FP_SUPPORT=n CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=n CONFIG_FPU=y CONFIG_CMSIS_DSP=y CONFIG_NEWLIB_LIBC=y # LOG Enable CONFIG_LOG=n CONFIG_LOG_MODE_IMMEDIATE=n #CONFIG_LOG_DEFAULT_LEVEL=3 CONFIG_CONSOLE=n CONFIG_UART_CONSOLE=n # Flash Storage Enable CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_NVS=y CONFIG_REBOOT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y # CONFIG_FLASH_MAP=y # CONFIG_SETTINGS=y # BLE Config CONFIG_BT=y CONFIG_BT_PERIPHERAL=y # CONFIG_BT_DEVICE_NAME="IntelliVibe-BAT_DK" CONFIG_BT_DEVICE_NAME="BLE-TEST" CONFIG_BT_GATT_NOTIFY_MULTIPLE=y CONFIG_BT_GATT_CLIENT=y CONFIG_BT_USER_PHY_UPDATE=y CONFIG_BT_USER_DATA_LEN_UPDATE=y CONFIG_BT_BUF_ACL_RX_SIZE=517 CONFIG_BT_BUF_ACL_TX_SIZE=517 CONFIG_BT_L2CAP_TX_MTU=517 CONFIG_BT_DEVICE_NAME_DYNAMIC=y CONFIG_BT_MAX_CONN=1 CONFIG_BT_HCI_VS_EXT=y # CONFIG_BT_CTLR=y # CONFIG_BT_SETTINGS=y # CONFIG_BT_HCI_ACL_FLOW_CONTROL=y # CONFIG_BT_BAS=y CONFIG_BT_CTS_CLIENT=y CONFIG_BT_PERIPHERAL_PREF_MIN_INT=800 CONFIG_BT_PERIPHERAL_PREF_MAX_INT=800 CONFIG_BT_PERIPHERAL_PREF_LATENCY=0 CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400 CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y CONFIG_BT_BUF_ACL_TX_COUNT=20 CONFIG_BT_L2CAP_TX_BUF_COUNT=10 # CONFIG_BT_BUF_ACL_TX_SIZE=39 # CONFIG_BT_CTLR_DATA_LENGTH_MAX=39 # STEP 2 - Enable MCUboot and FOTA CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y CONFIG_SECURE_BOOT=y CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 CONFIG_PM_DEVICE=y CONFIG_PM_DEVICE_RUNTIME=y CONFIG_BOARD_ENABLE_DCDC_APP=n CONFIG_BOARD_ENABLE_DCDC_HV=n CONFIG_BOARD_ENABLE_DCDC_NET=n.
