We are working on nrf5340 board with NS and TF-M setup and we have SDK v2.7.0
We need to have a flash partition to store the some secure data may be a size of 4KB inside the TF-M.
Please help us or direct us to any reference.
By changing the sizeof, it does not make the string any larger. You are effectively reading outside of the pointer. This also uses stack memory, as it declares a char array of size 1000, so you will need to adjust the main stack size, as previously mentioned.
I would recommend that you instead declare a static/global array of your wanted size and store that.
Håkon
Thank you for the quick response, let me try and get back to you shortly.
I tried the way you suggested and now I am getting PSA_ERROR_GENERIC_ERROR (-132) when writing.
Also, I have set CONFIG_TFM_PS_MAX_ASSET_SIZE to 4020
You need to expand the partition in order to write larger asset sizes, and you also need to set a different TFM profile.
This is the configuration I am using now:
CONFIG_BUILD_WITH_TFM=y #CONFIG_TFM_PROFILE_TYPE_NOT_SET=y CONFIG_TFM_PROFILE_TYPE_MEDIUM=y CONFIG_TFM_PS_MAX_ASSET_SIZE=4000 CONFIG_MAIN_STACK_SIZE=4096
And here is a larger pm_static.yml (store as pm_static.yml this in your project and delete build folder and regenerate the project):
app:
address: 0x40000
end_address: 0xf4000
region: flash_primary
otp:
address: 0xff8100
end_address: 0xff83fc
region: otp
rpmsg_nrf53_sram:
address: 0x20070000
end_address: 0x20080000
placement:
before:
- end
region: sram_primary
sram_nonsecure:
address: 0x20030000
orig_span: &id001
- sram_primary
- rpmsg_nrf53_sram
span: *id001
sram_primary:
address: 0x20030000
end_address: 0x20070000
sram_secure:
address: 0x20000000
end_address: 0x20030000
orig_span: &id002
- tfm_sram
span: *id002
tfm:
address: 0x0
end_address: 0x40000
placement:
before:
- app
tfm_its:
address: 0xf4000
end_address: 0xf6000
inside:
- tfm_storage
placement:
align:
start: 0x4000
before:
- tfm_otp_nv_counters
tfm_nonsecure:
address: 0x40000
orig_span: &id003
- app
span: *id003
tfm_otp_nv_counters:
address: 0xf6000
end_address: 0xf8000
inside:
- tfm_storage
placement:
align:
start: 0x4000
before:
- tfm_ps
tfm_ps:
address: 0xf8000
end_address: 0x100000
inside:
- tfm_storage
placement:
align:
start: 0x4000
before:
- end
tfm_secure:
address: 0x0
orig_span: &id004
- tfm
span: *id004
tfm_sram:
address: 0x20000000
inside:
- sram_secure
placement:
after:
- start
tfm_storage:
address: 0xf4000
orig_span: &id005
- tfm_ps
- tfm_its
span: *id005
Håkon
Hi Håkon,
Thank you for the response.
The above suggestion did not work for me, I am seeing the same -132 error when I run the code.
I removed build directory and rebuilt the project, yet the same result.
I can confirm the partitions.yml in build/zephyr/partition.yml updated your setup.
