We are working on nrf5340 board with NS and TF-M setup and we have SDK v2.7.0
We need to have a flash partition to store the some secure data may be a size of 4KB inside the TF-M.
Please help us or direct us to any reference.
Sorry about this, I forgot to erase the partitions when testing, so it had the layout of a former flashed firmware.
This was my working configuration. I see that there is a problem with the PS partition size, which is for some reason set to 0x4000, while the partition size is actually 0x8000, so I set it explicitly:
CONFIG_BUILD_WITH_TFM=y # CONFIG_TFM_PROFILE_TYPE_NOT_SET=y # CONFIG_TFM_PROFILE_TYPE_MEDIUM=y CONFIG_TFM_PROFILE_TYPE_SMALL=y CONFIG_TFM_PS_MAX_ASSET_SIZE=3800 CONFIG_MAIN_STACK_SIZE=4096 CONFIG_PM_PARTITION_SIZE_TFM_PROTECTED_STORAGE=0x8000
Håkon
Hi Håkon
Thank you that worked for me.
One last question, I found this TF-M profile table and I see TFM PROTECTED STORAGE is set to OFF in the SMALL profile. If so, how is it working on our setup.
If I set to any other profile except SMALL, I get -132 error and why is so?
My deepest apologies for sharing incorrect information.
Note that we recommend to either use minimal or full TFM profile, as shown here:
https://docs.nordicsemi.com/bundle/ncs-2.7.0/page/nrf/security/tfm.html#minimal_build
If you have CONFIG_TFM_PROFILE_TYPE_NOT_SET that implies a "full" implementation, and you need to adjust this configuration:
# Adjust even higher if storing larger files CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE=6400
Jithin A said:I found this TF-M profile table and I see TFM PROTECTED STORAGE is set to OFF in the SMALL profile.
I think there's an issue with how kconfig shows the tfm subsys vs. what is actually set in the cmake files to the TFM build. I see that the configuration is greyed out, but it does indeed pass this to the tfm image:
build/$IMAGE_NAME/tfm/CMakeCache.txt:TFM_PARTITION_PROTECTED_STORAGE:BOOL=ON
Sorry for all the back-and-forth in this matter.
Håkon
Thank you for letting me know, will test above and let you know.
