How to program nRF52840-QFN48 chipset using nRF52840-DK?
I want to program a nRF52840-QFN48 package chipset which does not have USB pins. I gone through several articles on the forum but nothing work for me.
Many of them suggested that you need J-Link programmer or nRF52840-DK can also work. I have nRF52840-DK with me. I made a connections as follows:
nRF52840-DK nRF52840-QFN48
SWDIO SWDIO
SWDCLK SWDCLK
VDD[3.3V] VDD [3.3V]
GND GND
I have generated to source code .hex file using arduino IDE and tried both programming mode i.e. 1. command line [using nrfjprog] and 2. nRF Connect for Desktop to flash the nRF52840-QFN48 using nRF52840-DK board.
Please suggest me if my approach is not proper or if I was missing anything.
Thanks and Regards,
Kapil S
    Your connections are correct, but please note that the "VTG" pin needs to be connected to the VDD.
    This is because that is a sense-pin for the nRF52840-DK to switch to that specific programming port.
    Could you share any logs from nrfjprog? "nrfjprog --recover -f nrf52 --log" should create a .log file which you can upload here.
    Håkon
  • Hi Håkon
    Thank you for your reply. I made the changes as you suggested above.
    Please find attached a .log file for your reference.
    C:\Users\Kapil>nrfjprog --recover -f nrf52 --log
    Recovering device. This operation might take 30s.
    Erasing user code and UICR flash areas.
  • That shows a successful connection, meaning nrfjprog was able to successfully erase the device. You can try to program a sample now and see if that works?
    Håkon
  • Thanks for confirming that up to this everything is OK. I will check by program a device  and let you know the status.
    Thanks and Regards,
    Kapil S
    I have uploaded the LED blinking code successfully on my nRF52840-QFN48 chipset. But I didn't observe LED flashing on my board. I checked the memory content using "nRF-Connect-Desktop" tool. I am not sure what are the cause and how to test it further to resolve an issue.
    Please guide me if you have any idea or suggestions.
    Kapil S.
