I am currently developing software of the nrf9160 and am having trouble with a firmware upgrade. The firmware data is received via UART. All of the functions work as expected but when the device reboots, the new firmware doesn't run.
int firmware_update_demo(char *URL)
char *demo_pointer = NULL;
const void *buf;
size_t len;
size_t firmware_update_len;
int response = 0;
uint8_t mcubuf[1000];
dfu_target_mcuboot_set_buf(mcubuf, sizeof(mcubuf));
int set_buf = dfu_target_mcuboot_init((size_t)file_size,0, NULL);
LOG_WRN("Dfu target init: %d", set_buf);
CODE TO COLLECT THE DATA OVER SERIAL IS HERE
int offset_get = dfu_target_mcuboot_offset_get(&fota_offset);
LOG_INF("Offset get: %d", offset_get);
LOG_INF("offset: %d", fota_offset);
int dfu_write = dfu_target_mcuboot_write(firmware_block, content_len);
LOG_INF("dfu write: %d", dfu_write);
int download_done = dfu_target_mcuboot_done(true);
LOG_INF("DOWNLOAD DONE: %d", download_done);
// Set back variables to default values
fota_offset = 0;
start_range = 0;
int schedule_update = dfu_target_mcuboot_schedule_update(0);
LOG_ERR("Update Scheduled: %d", schedule_update);
k_sleep(K_MSEC(10000));
sys_reboot(1);
return 0;
My PRJ file is as follows:
# General config CONFIG_NEWLIB_LIBC=y CONFIG_ASSERT=y CONFIG_REBOOT=y # Network CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_IPV6=n CONFIG_NET_IPV4=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_OFFLOAD=y # Sensors CONFIG_SPI=y CONFIG_SENSOR=y # LwM2M and IPSO CONFIG_LWM2M=y CONFIG_LWM2M_COAP_BLOCK_SIZE=512 CONFIG_LWM2M_COAP_MAX_MSG_SIZE=1280 CONFIG_LWM2M_ENGINE_MAX_OBSERVER=15 CONFIG_LWM2M_ENGINE_MAX_MESSAGES=15 CONFIG_LWM2M_ENGINE_MAX_PENDING=15 CONFIG_LWM2M_ENGINE_MAX_REPLIES=15 CONFIG_LWM2M_DNS_SUPPORT=y CONFIG_LWM2M_RW_JSON_SUPPORT=n CONFIG_LWM2M_SERVER_DEFAULT_PMIN=1 CONFIG_LWM2M_SERVER_DEFAULT_PMAX=300 CONFIG_LWM2M_CLIENT_UTILS=y CONFIG_LWM2M_CLIENT_UTILS_LOCATION_OBJ_SUPPORT=n CONFIG_LWM2M_IPSO_SUPPORT=y # DTLS settings CONFIG_LWM2M_DTLS_SUPPORT=y # Modem key management CONFIG_MODEM_KEY_MGMT=y # Default app to debug logging CONFIG_LOG=y CONFIG_APP_LOG_LEVEL_DBG=y # Support HEX style PSK values (double the size + NULL char) CONFIG_LWM2M_SECURITY_KEY_SIZE=33 # extend CoAP retry timing to 4 seconds for LTE/LTE-M CONFIG_COAP_INIT_ACK_TIMEOUT_MS=4000 # Enable CoAP extended option length CONFIG_COAP_EXTENDED_OPTIONS_LEN=y CONFIG_COAP_EXTENDED_OPTIONS_LEN_VALUE=40 # Enable settings storage CONFIG_SETTINGS=y CONFIG_FCB=y CONFIG_SETTINGS_FCB=y CONFIG_FLASH_MAP=y CONFIG_STREAM_FLASH=y # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y # Modem library CONFIG_NRF_MODEM_LIB=y # Modem info CONFIG_MODEM_INFO=y CONFIG_MODEM_INFO_ADD_DATE_TIME=n # Enable shell CONFIG_LWM2M_SHELL=y # Heap and stacks CONFIG_HEAP_MEM_POOL_SIZE=16384 CONFIG_MAIN_STACK_SIZE=4096 CONFIG_LWM2M_ENGINE_STACK_SIZE=3072 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2048 # Allow FOTA downloads using download-client CONFIG_DOWNLOAD_CLIENT=y CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096 CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y CONFIG_FOTA_DOWNLOAD=y # Application version CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.0.0" # Set LwM2M Server IP address here CONFIG_LWM2M_CLIENT_UTILS_SERVER="coaps://leshan.eclipseprojects.io:5684" # Application Event Manager CONFIG_APP_EVENT_MANAGER=y # Date-Time library CONFIG_DATE_TIME=y CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=86400 # Enable LwM2M Queue Mode CONFIG_LWM2M_QUEUE_MODE_ENABLED=y # Enable TLS session caching to prevent doing a full TLS handshake for every send. CONFIG_LWM2M_TLS_SESSION_CACHING=y # Socket close is skipped at RX off idle state which optimize power consumption # Socket close call will enable RCC connection for send Alert message to server # Alert is now send right before opening a new connection. CONFIG_LWM2M_RD_CLIENT_SUSPEND_SOCKET_AT_IDLE=y # Sets the duration that the lwm2m engine will be polling for data after transmission before # the socket is closed. # Adjust so that we can detach from network in 30 seconds CONFIG_LWM2M_QUEUE_MODE_UPTIME=30 # Set lifetime of 12 hours CONFIG_LWM2M_ENGINE_DEFAULT_LIFETIME=43200 # Do registration update after 5400 seconds (90 minutes) CONFIG_LWM2M_UPDATE_PERIOD=5400 CONFIG_LWM2M_SECONDS_TO_UPDATE_EARLY=60 # Configure PSM mode CONFIG_LTE_PSM_REQ=y # Request periodic TAU of 3600 seconds (60 minutes) CONFIG_LTE_PSM_REQ_RPTAU="00000110" # Set Requested Active Time (RAT) to 30 seconds. Preferably a little bit longer than the # configured LWM2M_QUEUE_MODE_UPTIME. Due to NAT/firewall UDP connections are usually # closed within 30-60 seconds so there is in general no point in setting a longer # Queue mode uptime / LTE PSM active time. CONFIG_LTE_PSM_REQ_RAT="00001111" # Request eDRX mode CONFIG_LTE_EDRX_REQ=y # Request eDRX cycle length of 10.24 seconds for LTE-M CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="0001" # Request eDRX cycle length of 20.48 seconds for NB-IoT CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="0010" # Request Paging time window of 1.28 seconds for LTE-M CONFIG_LTE_PTW_VALUE_LTE_M="0000" # Request Paging time window of 2.56 seconds for NB-IoT CONFIG_LTE_PTW_VALUE_NBIOT="0000" # Get notification before Tracking Area Update (TAU). Notification triggers registration # update and TAU will be sent with the update which decreases power consumption. CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS=y # Optimize powersaving by using tickless mode in LwM2M engine CONFIG_NET_SOCKETPAIR=y CONFIG_LWM2M_TICKLESS=y # NBIOT Usage CONFIG_LTE_NETWORK_MODE_NBIOT=y CONFIG_PDN=y CONFIG_PDN_DEFAULTS_OVERRIDE=y CONFIG_PDN_DEFAULT_APN="nbiot.vodacom.za" CONFIG_LTE_NETWORK_MODE_NBIOT=y CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=n # Enable LwM2M Queue Mode CONFIG_LWM2M_QUEUE_MODE_ENABLED=y # Enable TLS session caching to prevent doing a full TLS handshake for every send. CONFIG_LWM2M_TLS_SESSION_CACHING=y # Socket close is skipped at RX off idle state which optimize power consumption # Socket close call will enable RCC connection for send Alert message to server # Alert is now send right before opening a new connection. CONFIG_LWM2M_RD_CLIENT_SUSPEND_SOCKET_AT_IDLE=y # Sets the duration that the lwm2m engine will be polling for data after transmission before # the socket is closed. # Adjust so that we can detach from network in 30 seconds CONFIG_LWM2M_QUEUE_MODE_UPTIME=45 # Set lifetime of 12 hours CONFIG_LWM2M_ENGINE_DEFAULT_LIFETIME=3600 # Do registration update after 5400 seconds (90 minutes) CONFIG_LWM2M_SECONDS_TO_UPDATE_EARLY=3000 # Request eDRX cycle length of 20.48 seconds for NB-IoT CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="0010" # Sensors CONFIG_I2C=y CONFIG_SPI=n CONFIG_SENSOR=n #Enable/Disable RTT or UART Logging CONFIG_CONSOLE=y CONFIG_LOG=y CONFIG_APP_LOG_LEVEL_DBG=y CONFIG_USE_SEGGER_RTT=y CONFIG_RTT_CONSOLE=y CONFIG_UART_CONSOLE=n # Set LwM2M Server IP address here # CONFIG_LWM2M_CLIENT_UTILS_SERVER="coaps://leshan.eclipseprojects.io:5684" CONFIG_LWM2M_CLIENT_UTILS_SERVER="coaps://dev.lwm2m.automatechcloud.co.za:5683" # Configure lwm2m version CONFIG_LWM2M_VERSION_1_1=y CONFIG_LWM2M_SERVER_OBJECT_VERSION_1_1=y CONFIG_JSON_LIBRARY=y CONFIG_BASE64=y CONFIG_LWM2M_RW_SENML_JSON_SUPPORT=y # w1 sensor interface configuration CONFIG_SENSOR=y CONFIG_W1=y # Enabling RTC CONFIG_COUNTER=y CONFIG_PCF85063A=y # Battery measurement CONFIG_ADC=y # Power saving CONFIG_PM_DEVICE=y # Configure internal flash CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y CONFIG_LTE_NETWORK_USE_FALLBACK=n CONFIG_LTE_NETWORK_TIMEOUT=60 CONFIG_WATCHDOG=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_UART_LINE_CTRL=n CONFIG_MODBUS=y CONFIG_MODBUS_ROLE_CLIENT=y CONFIG_MODBUS_RAW_ADU=y CONFIG_UART_USE_RUNTIME_CONFIGURE=y CONFIG_LWM2M_CLIENT_UTILS_DOWNLOADER_SEC_TAG=35724861 CONFIG_LWM2M_CLIENT_UTILS_SERVER_TLS_TAG=35724861 CONFIG_DFU_TARGET=y CONFIG_LWM2M_CLIENT_UTILS_RAI=y CONFIG_AT_MONITOR_HEAP_SIZE=1024 CONFIG_SERIAL=y # DEMO CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_DFU_TARGET=y CONFIG_DFU_TARGET_MCUBOOT=y CONFIG_FLASH=y CONFIG_IMG_ERASE_PROGRESSIVELY=y CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y
On Startup i am also calling:
