SDK : 2.6.1
uC: nrf5340
I want to use the feature "revoking private keys" as described here:
First I generate 3 private/public key pairs with openSSL e.g.:
openssl ecparam -name prime256v1 -genkey -noout -out priv_a.pem
openssl ec -in priv_a.pem -pubout -outform PEM -out pub_a.pem
Then I added the following lines to prj.conf
CONFIG_SECURE_BOOT=y CONFIG_SB_SIGNING_KEY_FILE="D:/Projekte/test/priv_a.pem" CONFIG_SB_PUBLIC_KEY_FILES="D:/Projekte/test/pub_b.pem,D:/Projekte/test/pub_c.pem"
And finally I added the b0 container to the pm_static.yml:
b0_container: address: 0x0 orig_span: &id001 - b0 - provision size: 0x9000 span: *id001 b0: address: 0x0 size: 0x8000 provision: address: 0x8000 size: 0x1000 mcuboot: address: 0x9000 region: flash_primary size: 0x10000 mcuboot_pad: address: 0x19000 region: flash_primary size: 0x200 mcuboot_primary: address: 0x19000 orig_span: &id002 - mcuboot_pad - app region: flash_primary size: 0xd7000 span: *id002 mcuboot_primary_app: address: 0x19200 orig_span: &id003 - app region: flash_primary size: 0xd6e00 span: *id003 app: address: 0x19200 region: flash_primary size: 0xd6e00 settings_storage: address: 0xf0000 region: flash_primary size: 0x10000 mcuboot_primary_1: address: 0x0 size: 0x40000 device: flash_ctrl region: ram_flash mcuboot_secondary: address: 0x00000 size: 0xe0000 device: IS25LP016D region: external_flash mcuboot_secondary_1: address: 0xe0000 size: 0x40000 device: IS25LP016D region: external_flash external_flash_qs: address: 0x120000 size: 0x1000 device: IS25LP016D region: external_flash external_flash_log: address: 0x121000 size: 0xdf000 device: IS25LP016D region: external_flash pcd_sram: address: 0x20000000 size: 0x2000 region: sram_primary
When running the program the system hangs in the B0 bootloader.
Here you can see the debug output:
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
Attempting to boot slot 0.
Attempting to boot from address 0x19200.
Firwmare has been invalidated: 0x91020000.
Failed to validate, permanently invalidating!
Attempting to boot slot 1.
No fw_info struct found.
No bootable image found. Aborting boot.
What could be the problem ?
Is there any example that works on a nrf5340-DK board ?
Georg
