hi ,
I am currently developing a project using the nRF52810 as my controller and SEGGER Embedded Studio (version 5.42a) as my IDE. I have successfully integrated the Timer and SAADC peripherals into the ble_app_uart/pca10040e/s112
example project from the nRF5 SDK.
In my application, I am using the 4th SAADC channel (AIN4) to read ADC values, which correspond to the device's battery voltage. I am using a 12-bit resolution and all the default configurations of the SAADC.
My goal is to convert the ADC value into a millivolt reading. Specifically, I need to:
Convert this ADC value into a voltage (in millivolts, mV).
I understand that the value read from the ADC can be translated into a voltage based on the reference voltage and resolution, but I would appreciate guidance on how to accurately calculate the millivolts from the ADC value using the SAADC.
I am attaching the relevant portion of my SAADC code below for your reference.
ret_code_t err_code;
/* setup m_timer for compare event every 400ms */
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 500);
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
timer_compare_event_addr,
saadc_sample_task_addr);
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
int i,sum=0;
// NRF_LOG_INFO("ADC event number: %d\n", (int)m_adc_evt_counter);
//printf("ADC event number: %d\n", (int)m_adc_evt_counter);
for (i = 0; i < SAMPLES_IN_BUFFER; i++)
int adc_value = p_event->data.done.p_buffer[i];
// NRF_LOG_INFO("%d\n", p_event->data.done.p_buffer[i]);
// printf("%d\n", p_event->data.done.p_buffer[i]);
sum+=adc_value;
average_adc_value = sum / SAMPLES_IN_BUFFER;
NRF_LOG_INFO("average adc value : %d\n",average_adc_value);
printf("average adc value : %d\n",average_adc_value);
m_adc_evt_counter++;
void saadc_init(void)
nrf_saadc_channel_config_t channel_config =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
Project Details:
- SDK: nRF5 SDK 17.0.2
- IDE: SEGGER Embedded Studio 5.42a
- Controller: nRF52810
- Peripherals: Timer and SAADC (using default configuration for SAADC, with a 12-bit resolution)
Any help or insights on converting the ADC value to millivolts would be greatly appreciated.
Thank you for your support.
SILTVM
